Hi Tom,
please pull this next batch of Marvell MVEBU related patches:
---------------------------------------------------------------- - pci_mvebu: Fix access to config space and PCIe Root Port (Pali) - a37xx: pci: Program the data strobe for config read requests (Pali) - kwboot: Misc improvements and fixes (Pali) ----------------------------------------------------------------
Here the Azure build, without any issues:
https://dev.azure.com/sr0718/u-boot/_build/results?buildId=130&view=resu...
Thanks, Stefan
The following changes since commit a79115dde373f7cdb181040dd6489fd0b21bfbd2:
Prepare v2022.01-rc1 (2021-11-01 15:16:43 -0400)
git@source.denx.de:u-boot/custodians/u-boot-marvell.git
for you to fetch changes up to 57fa6fb93291cdcabc1c38d874d12257a879f8ee:
arm: a37xx: pci: Program the data strobe for config read requests (2021-11-03 06:45:34 +0100)
---------------------------------------------------------------- Pali Rohár (28): pci: pci_mvebu: Fix write_config() with PCI_SIZE_8 or PCI_SIZE_16 pci: pci_mvebu: Fix read_config() with PCI_SIZE_8 or PCI_SIZE_16 pci: pci_mvebu: Properly configure and use PCI Bridge (PCIe Root Port) pci: pci_mvebu: Remove unused functions pci: pci_mvebu: Fix place of link up detection pci: pci_mvebu: Do not automatically enable bus mastering on PCI Bridge pci: pci_mvebu: Setup PCI controller to Root Complex mode pci: pci_mvebu: Fix comment about driver class name tools: kwboot: Initialize rfds to zero tools: kwboot: Fix initialization of tty device tools: kwboot: Reserve enough space for patching kwbimage in memory tools: kwboot: Validate 4-byte image data checksum tools: kwboot: Inject baudrate change back code after data part tools: kwboot: Recalculate 4-byte data checksum after injecting baudrate code tools: kwboot: Correctly set configuration of UART for BootROM messages tools: kwboot: Show verbose message when waiting for baudrate change magic tools: kwboot: Simplify code for aligning image header tools: kwboot: Do not modify kwbimage header before increasing its size tools: kwboot: Calculate real used space in kwbimage header when calling kwboot_img_grow_hdr() tools: kwboot: Change retry loop from decreasing to increasing tools: kwboot: Resend first 3 xmodem retry packets immediately tools: kwboot: Fix sending retry of last header packet tools: kwboot: Do not call tcdrain() after each sent packet tools: kwboot: Increase delay after changing baudrate in ARM code tools: kwboot: Replace ARM mov + movt instruction pair by mov + orr tools: kwboot: Do not use stack when setting baudrate back to default value tools: kwboot: Do not send magic seq when changing baudrate back to 115200 arm: a37xx: pci: Program the data strobe for config read requests
drivers/pci/pci-aardvark.c | 3 + drivers/pci/pci_mvebu.c | 275 ++++++++++++++++++++++-------- tools/kwboot.c | 407 +++++++++++++++++++++++++++------------------ 3 files changed, 451 insertions(+), 234 deletions(-)
Stefan Roese
