[U-Boot-Users] [PATCH 4/9] Add definitions for 440EPx/GRx SDRAM controller to ppc440.h
This patch adds the Denali SDRAM controller definitions to "ppc440.h". It also fixes two typos in the definitions, so the board-specific "sdram.h" files containing these definitions are also fixed to avoid compiler warnings.
Signed-off-by: Larry Johnson lrj@acm.org --- board/amcc/sequoia/sdram.h | 4 +- board/lwmon5/sdram.h | 4 +- include/ppc440.h | 514 +++++++++++++++++++++++++++++++++++++++---- 3 files changed, 470 insertions(+), 52 deletions(-)
diff --git a/board/amcc/sequoia/sdram.h b/board/amcc/sequoia/sdram.h index 7f847aa..6a7bf01 100644 --- a/board/amcc/sequoia/sdram.h +++ b/board/amcc/sequoia/sdram.h @@ -395,8 +395,8 @@ #define DDR0_26_TRAS_MAX_ENCODE(n) ((((unsigned long)(n))&0xFFFF)<<16) #define DDR0_26_TRAS_MAX_DECODE(n) ((((unsigned long)(n))>>16)&0xFFFF) #define DDR0_26_TREF_MASK 0x00003FFF -#define DDR0_26_TREF_ENCODE(n) ((((unsigned long)(n))&0x3FF)<<0) -#define DDR0_26_TREF_DECODE(n) ((((unsigned long)(n))>>0)&0x3FF) +#define DDR0_26_TREF_ENCODE(n) ((((unsigned long)(n))&0x3FFF)<<0) +#define DDR0_26_TREF_DECODE(n) ((((unsigned long)(n))>>0)&0x3FFF)
#define DDR0_27 0x1B #define DDR0_27_EMRS_DATA_MASK 0x3FFF0000 diff --git a/board/lwmon5/sdram.h b/board/lwmon5/sdram.h index 7f847aa..6a7bf01 100644 --- a/board/lwmon5/sdram.h +++ b/board/lwmon5/sdram.h @@ -395,8 +395,8 @@ #define DDR0_26_TRAS_MAX_ENCODE(n) ((((unsigned long)(n))&0xFFFF)<<16) #define DDR0_26_TRAS_MAX_DECODE(n) ((((unsigned long)(n))>>16)&0xFFFF) #define DDR0_26_TREF_MASK 0x00003FFF -#define DDR0_26_TREF_ENCODE(n) ((((unsigned long)(n))&0x3FF)<<0) -#define DDR0_26_TREF_DECODE(n) ((((unsigned long)(n))>>0)&0x3FF) +#define DDR0_26_TREF_ENCODE(n) ((((unsigned long)(n))&0x3FFF)<<0) +#define DDR0_26_TREF_DECODE(n) ((((unsigned long)(n))>>0)&0x3FFF)
#define DDR0_27 0x1B #define DDR0_27_EMRS_DATA_MASK 0x3FFF0000 diff --git a/include/ppc440.h b/include/ppc440.h index 21e8836..90e56b0 100644 --- a/include/ppc440.h +++ b/include/ppc440.h @@ -19,6 +19,30 @@ | LICENSED MATERIAL - PROGRAM PROPERTY OF I B M +----------------------------------------------------------------------------*/
+/* + * (C) Copyright 2006 + * Sylvie Gohl, AMCC/IBM, gohl.sylvie@fr.ibm.com + * Jacqueline Pira-Ferriol, AMCC/IBM, jpira-ferriol@fr.ibm.com + * Thierry Roman, AMCC/IBM, thierry_roman@fr.ibm.com + * Alain Saurel, AMCC/IBM, alain.saurel@fr.ibm.com + * Robert Snyder, AMCC/IBM, rob.snyder@fr.ibm.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + #ifndef __PPC440_H__ #define __PPC440_H__
@@ -186,54 +210,6 @@ #define sdr_plbtr 0x4200 #define sdr_mfr 0x4300 /* SDR0_MFR reg */
-#if defined(CONFIG_440EPX) || defined(CONFIG_440GRX) /* test-only!!!! */ -#define DDR0_00 0x00 -#define DDR0_01 0x01 -#define DDR0_02 0x02 -#define DDR0_03 0x03 -#define DDR0_04 0x04 -#define DDR0_05 0x05 -#define DDR0_06 0x06 -#define DDR0_07 0x07 -#define DDR0_08 0x08 -#define DDR0_09 0x09 -#define DDR0_10 0x0A -#define DDR0_11 0x0B -#define DDR0_12 0x0C -#define DDR0_13 0x0D -#define DDR0_14 0x0E -#define DDR0_15 0x0F -#define DDR0_16 0x10 -#define DDR0_17 0x11 -#define DDR0_18 0x12 -#define DDR0_19 0x13 -#define DDR0_20 0x14 -#define DDR0_21 0x15 -#define DDR0_22 0x16 -#define DDR0_23 0x17 -#define DDR0_24 0x18 -#define DDR0_25 0x19 -#define DDR0_26 0x1A -#define DDR0_27 0x1B -#define DDR0_28 0x1C -#define DDR0_29 0x1D -#define DDR0_30 0x1E -#define DDR0_31 0x1F -#define DDR0_32 0x20 -#define DDR0_33 0x21 -#define DDR0_34 0x22 -#define DDR0_35 0x23 -#define DDR0_36 0x24 -#define DDR0_37 0x25 -#define DDR0_38 0x26 -#define DDR0_39 0x27 -#define DDR0_40 0x28 -#define DDR0_41 0x29 -#define DDR0_42 0x2A -#define DDR0_43 0x2B -#define DDR0_44 0x2C -#endif /*CONFIG_440EPX*/ - /*----------------------------------------------------------------------------- | SDRAM Controller +----------------------------------------------------------------------------*/ @@ -817,6 +793,448 @@ #define SDR0_MFR_FIXD 0x10000000 /* Workaround for PCI/DMA */ #endif /* CONFIG_440SPE */
+#if defined(CONFIG_440EPX) || defined(CONFIG_440GRX) +/*----------------------------------------------------------------------------- + | SDRAM Controller + +----------------------------------------------------------------------------*/ +#define DDR0_00 0x00 +#define DDR0_00_INT_ACK_MASK 0x7F000000 /* Write only */ +#define DDR0_00_INT_ACK_ALL 0x7F000000 +#define DDR0_00_INT_ACK_ENCODE(n) ((((unsigned long)(n))&0x7F)<<24) +#define DDR0_00_INT_ACK_DECODE(n) ((((unsigned long)(n))>>24)&0x7F) +/* Status */ +#define DDR0_00_INT_STATUS_MASK 0x00FF0000 /* Read only */ +/* Bit0. A single access outside the defined PHYSICAL memory space detected. */ +#define DDR0_00_INT_STATUS_BIT0 0x00010000 +/* Bit1. Multiple accesses outside the defined PHYSICAL memory space detected. */ +#define DDR0_00_INT_STATUS_BIT1 0x00020000 +/* Bit2. Single correctable ECC event detected */ +#define DDR0_00_INT_STATUS_BIT2 0x00040000 +/* Bit3. Multiple correctable ECC events detected. */ +#define DDR0_00_INT_STATUS_BIT3 0x00080000 +/* Bit4. Single uncorrectable ECC event detected. */ +#define DDR0_00_INT_STATUS_BIT4 0x00100000 +/* Bit5. Multiple uncorrectable ECC events detected. */ +#define DDR0_00_INT_STATUS_BIT5 0x00200000 +/* Bit6. DRAM initialization complete. */ +#define DDR0_00_INT_STATUS_BIT6 0x00400000 +/* Bit7. Logical OR of all lower bits. */ +#define DDR0_00_INT_STATUS_BIT7 0x00800000 + +#define DDR0_00_INT_STATUS_ENCODE(n) ((((unsigned long)(n))&0xFF)<<16) +#define DDR0_00_INT_STATUS_DECODE(n) ((((unsigned long)(n))>>16)&0xFF) +#define DDR0_00_DLL_INCREMENT_MASK 0x00007F00 +#define DDR0_00_DLL_INCREMENT_ENCODE(n) ((((unsigned long)(n))&0x7F)<<8) +#define DDR0_00_DLL_INCREMENT_DECODE(n) ((((unsigned long)(n))>>8)&0x7F) +#define DDR0_00_DLL_START_POINT_MASK 0x0000007F +#define DDR0_00_DLL_START_POINT_ENCODE(n) ((((unsigned long)(n))&0x7F)<<0) +#define DDR0_00_DLL_START_POINT_DECODE(n) ((((unsigned long)(n))>>0)&0x7F) + +#define DDR0_01 0x01 +#define DDR0_01_PLB0_DB_CS_LOWER_MASK 0x1F000000 +#define DDR0_01_PLB0_DB_CS_LOWER_ENCODE(n) ((((unsigned long)(n))&0x1F)<<24) +#define DDR0_01_PLB0_DB_CS_LOWER_DECODE(n) ((((unsigned long)(n))>>24)&0x1F) +#define DDR0_01_PLB0_DB_CS_UPPER_MASK 0x001F0000 +#define DDR0_01_PLB0_DB_CS_UPPER_ENCODE(n) ((((unsigned long)(n))&0x1F)<<16) +#define DDR0_01_PLB0_DB_CS_UPPER_DECODE(n) ((((unsigned long)(n))>>16)&0x1F) +#define DDR0_01_OUT_OF_RANGE_TYPE_MASK 0x00000700 /* Read only */ +#define DDR0_01_OUT_OF_RANGE_TYPE_ENCODE(n) ((((unsigned long)(n))&0x7)<<8) +#define DDR0_01_OUT_OF_RANGE_TYPE_DECODE(n) ((((unsigned long)(n))>>8)&0x7) +#define DDR0_01_INT_MASK_MASK 0x000000FF +#define DDR0_01_INT_MASK_ENCODE(n) ((((unsigned long)(n))&0xFF)<<0) +#define DDR0_01_INT_MASK_DECODE(n) ((((unsigned long)(n))>>0)&0xFF) +#define DDR0_01_INT_MASK_ALL_ON 0x000000FF +#define DDR0_01_INT_MASK_ALL_OFF 0x00000000 + +#define DDR0_02 0x02 +#define DDR0_02_MAX_CS_REG_MASK 0x02000000 /* Read only */ +#define DDR0_02_MAX_CS_REG_ENCODE(n) ((((unsigned long)(n))&0x2)<<24) +#define DDR0_02_MAX_CS_REG_DECODE(n) ((((unsigned long)(n))>>24)&0x2) +#define DDR0_02_MAX_COL_REG_MASK 0x000F0000 /* Read only */ +#define DDR0_02_MAX_COL_REG_ENCODE(n) ((((unsigned long)(n))&0xF)<<16) +#define DDR0_02_MAX_COL_REG_DECODE(n) ((((unsigned long)(n))>>16)&0xF) +#define DDR0_02_MAX_ROW_REG_MASK 0x00000F00 /* Read only */ +#define DDR0_02_MAX_ROW_REG_ENCODE(n) ((((unsigned long)(n))&0xF)<<8) +#define DDR0_02_MAX_ROW_REG_DECODE(n) ((((unsigned long)(n))>>8)&0xF) +#define DDR0_02_START_MASK 0x00000001 +#define DDR0_02_START_ENCODE(n) ((((unsigned long)(n))&0x1)<<0) +#define DDR0_02_START_DECODE(n) ((((unsigned long)(n))>>0)&0x1) +#define DDR0_02_START_OFF 0x00000000 +#define DDR0_02_START_ON 0x00000001 + +#define DDR0_03 0x03 +#define DDR0_03_BSTLEN_MASK 0x07000000 +#define DDR0_03_BSTLEN_ENCODE(n) ((((unsigned long)(n))&0x7)<<24) +#define DDR0_03_BSTLEN_DECODE(n) ((((unsigned long)(n))>>24)&0x7) +#define DDR0_03_CASLAT_MASK 0x00070000 +#define DDR0_03_CASLAT_ENCODE(n) ((((unsigned long)(n))&0x7)<<16) +#define DDR0_03_CASLAT_DECODE(n) ((((unsigned long)(n))>>16)&0x7) +#define DDR0_03_CASLAT_LIN_MASK 0x00000F00 +#define DDR0_03_CASLAT_LIN_ENCODE(n) ((((unsigned long)(n))&0xF)<<8) +#define DDR0_03_CASLAT_LIN_DECODE(n) ((((unsigned long)(n))>>8)&0xF) +#define DDR0_03_INITAREF_MASK 0x0000000F +#define DDR0_03_INITAREF_ENCODE(n) ((((unsigned long)(n))&0xF)<<0) +#define DDR0_03_INITAREF_DECODE(n) ((((unsigned long)(n))>>0)&0xF) + +#define DDR0_04 0x04 +#define DDR0_04_TRC_MASK 0x1F000000 +#define DDR0_04_TRC_ENCODE(n) ((((unsigned long)(n))&0x1F)<<24) +#define DDR0_04_TRC_DECODE(n) ((((unsigned long)(n))>>24)&0x1F) +#define DDR0_04_TRRD_MASK 0x00070000 +#define DDR0_04_TRRD_ENCODE(n) ((((unsigned long)(n))&0x7)<<16) +#define DDR0_04_TRRD_DECODE(n) ((((unsigned long)(n))>>16)&0x7) +#define DDR0_04_TRTP_MASK 0x00000700 +#define DDR0_04_TRTP_ENCODE(n) ((((unsigned long)(n))&0x7)<<8) +#define DDR0_04_TRTP_DECODE(n) ((((unsigned long)(n))>>8)&0x7) + +#define DDR0_05 0x05 +#define DDR0_05_TMRD_MASK 0x1F000000 +#define DDR0_05_TMRD_ENCODE(n) ((((unsigned long)(n))&0x1F)<<24) +#define DDR0_05_TMRD_DECODE(n) ((((unsigned long)(n))>>24)&0x1F) +#define DDR0_05_TEMRS_MASK 0x00070000 +#define DDR0_05_TEMRS_ENCODE(n) ((((unsigned long)(n))&0x7)<<16) +#define DDR0_05_TEMRS_DECODE(n) ((((unsigned long)(n))>>16)&0x7) +#define DDR0_05_TRP_MASK 0x00000F00 +#define DDR0_05_TRP_ENCODE(n) ((((unsigned long)(n))&0xF)<<8) +#define DDR0_05_TRP_DECODE(n) ((((unsigned long)(n))>>8)&0xF) +#define DDR0_05_TRAS_MIN_MASK 0x000000FF +#define DDR0_05_TRAS_MIN_ENCODE(n) ((((unsigned long)(n))&0xFF)<<0) +#define DDR0_05_TRAS_MIN_DECODE(n) ((((unsigned long)(n))>>0)&0xFF) + +#define DDR0_06 0x06 +#define DDR0_06_WRITEINTERP_MASK 0x01000000 +#define DDR0_06_WRITEINTERP_ENCODE(n) ((((unsigned long)(n))&0x1)<<24) +#define DDR0_06_WRITEINTERP_DECODE(n) ((((unsigned long)(n))>>24)&0x1) +#define DDR0_06_TWTR_MASK 0x00070000 +#define DDR0_06_TWTR_ENCODE(n) ((((unsigned long)(n))&0x7)<<16) +#define DDR0_06_TWTR_DECODE(n) ((((unsigned long)(n))>>16)&0x7) +#define DDR0_06_TDLL_MASK 0x0000FF00 +#define DDR0_06_TDLL_ENCODE(n) ((((unsigned long)(n))&0xFF)<<8) +#define DDR0_06_TDLL_DECODE(n) ((((unsigned long)(n))>>8)&0xFF) +#define DDR0_06_TRFC_MASK 0x0000007F +#define DDR0_06_TRFC_ENCODE(n) ((((unsigned long)(n))&0x7F)<<0) +#define DDR0_06_TRFC_DECODE(n) ((((unsigned long)(n))>>0)&0x7F) + +#define DDR0_07 0x07 +#define DDR0_07_NO_CMD_INIT_MASK 0x01000000 +#define DDR0_07_NO_CMD_INIT_ENCODE(n) ((((unsigned long)(n))&0x1)<<24) +#define DDR0_07_NO_CMD_INIT_DECODE(n) ((((unsigned long)(n))>>24)&0x1) +#define DDR0_07_TFAW_MASK 0x001F0000 +#define DDR0_07_TFAW_ENCODE(n) ((((unsigned long)(n))&0x1F)<<16) +#define DDR0_07_TFAW_DECODE(n) ((((unsigned long)(n))>>16)&0x1F) +#define DDR0_07_AUTO_REFRESH_MODE_MASK 0x00000100 +#define DDR0_07_AUTO_REFRESH_MODE_ENCODE(n) ((((unsigned long)(n))&0x1)<<8) +#define DDR0_07_AUTO_REFRESH_MODE_DECODE(n) ((((unsigned long)(n))>>8)&0x1) +#define DDR0_07_AREFRESH_MASK 0x00000001 +#define DDR0_07_AREFRESH_ENCODE(n) ((((unsigned long)(n))&0x1)<<0) +#define DDR0_07_AREFRESH_DECODE(n) ((((unsigned long)(n))>>0)&0x1) + +#define DDR0_08 0x08 +#define DDR0_08_WRLAT_MASK 0x07000000 +#define DDR0_08_WRLAT_ENCODE(n) ((((unsigned long)(n))&0x7)<<24) +#define DDR0_08_WRLAT_DECODE(n) ((((unsigned long)(n))>>24)&0x7) +#define DDR0_08_TCPD_MASK 0x00FF0000 +#define DDR0_08_TCPD_ENCODE(n) ((((unsigned long)(n))&0xFF)<<16) +#define DDR0_08_TCPD_DECODE(n) ((((unsigned long)(n))>>16)&0xFF) +#define DDR0_08_DQS_N_EN_MASK 0x00000100 +#define DDR0_08_DQS_N_EN_ENCODE(n) ((((unsigned long)(n))&0x1)<<8) +#define DDR0_08_DQS_N_EN_DECODE(n) ((((unsigned long)(n))>>8)&0x1) +#define DDR0_08_DDRII_SDRAM_MODE_MASK 0x00000001 +#define DDR0_08_DDRII_ENCODE(n) ((((unsigned long)(n))&0x1)<<0) +#define DDR0_08_DDRII_DECODE(n) ((((unsigned long)(n))>>0)&0x1) + +#define DDR0_09 0x09 +#define DDR0_09_OCD_ADJUST_PDN_CS_0_MASK 0x1F000000 +#define DDR0_09_OCD_ADJUST_PDN_CS_0_ENCODE(n) ((((unsigned long)(n))&0x1F)<<24) +#define DDR0_09_OCD_ADJUST_PDN_CS_0_DECODE(n) ((((unsigned long)(n))>>24)&0x1F) +#define DDR0_09_RTT_0_MASK 0x00030000 +#define DDR0_09_RTT_0_ENCODE(n) ((((unsigned long)(n))&0x3)<<16) +#define DDR0_09_RTT_0_DECODE(n) ((((unsigned long)(n))>>16)&0x3) +#define DDR0_09_WR_DQS_SHIFT_BYPASS_MASK 0x00007F00 +#define DDR0_09_WR_DQS_SHIFT_BYPASS_ENCODE(n) ((((unsigned long)(n))&0x7F)<<8) +#define DDR0_09_WR_DQS_SHIFT_BYPASS_DECODE(n) ((((unsigned long)(n))>>8)&0x7F) +#define DDR0_09_WR_DQS_SHIFT_MASK 0x0000007F +#define DDR0_09_WR_DQS_SHIFT_ENCODE(n) ((((unsigned long)(n))&0x7F)<<0) +#define DDR0_09_WR_DQS_SHIFT_DECODE(n) ((((unsigned long)(n))>>0)&0x7F) + +#define DDR0_10 0x0A +#define DDR0_10_WRITE_MODEREG_MASK 0x00010000 /* Write only */ +#define DDR0_10_WRITE_MODEREG_ENCODE(n) ((((unsigned long)(n))&0x1)<<16) +#define DDR0_10_WRITE_MODEREG_DECODE(n) ((((unsigned long)(n))>>16)&0x1) +#define DDR0_10_CS_MAP_MASK 0x00000300 +#define DDR0_10_CS_MAP_NO_MEM 0x00000000 +#define DDR0_10_CS_MAP_RANK0_INSTALLED 0x00000100 +#define DDR0_10_CS_MAP_RANK1_INSTALLED 0x00000200 +#define DDR0_10_CS_MAP_ENCODE(n) ((((unsigned long)(n))&0x3)<<8) +#define DDR0_10_CS_MAP_DECODE(n) ((((unsigned long)(n))>>8)&0x3) +#define DDR0_10_OCD_ADJUST_PUP_CS_0_MASK 0x0000001F +#define DDR0_10_OCD_ADJUST_PUP_CS_0_ENCODE(n) ((((unsigned long)(n))&0x1F)<<0) +#define DDR0_10_OCD_ADJUST_PUP_CS_0_DECODE(n) ((((unsigned long)(n))>>0)&0x1F) + +#define DDR0_11 0x0B +#define DDR0_11_SREFRESH_MASK 0x01000000 +#define DDR0_11_SREFRESH_ENCODE(n) ((((unsigned long)(n))&0x1)<<24) +#define DDR0_11_SREFRESH_DECODE(n) ((((unsigned long)(n))>>24)&0x1F) +#define DDR0_11_TXSNR_MASK 0x00FF0000 +#define DDR0_11_TXSNR_ENCODE(n) ((((unsigned long)(n))&0xFF)<<16) +#define DDR0_11_TXSNR_DECODE(n) ((((unsigned long)(n))>>16)&0xFF) +#define DDR0_11_TXSR_MASK 0x0000FF00 +#define DDR0_11_TXSR_ENCODE(n) ((((unsigned long)(n))&0xFF)<<8) +#define DDR0_11_TXSR_DECODE(n) ((((unsigned long)(n))>>8)&0xFF) + +#define DDR0_12 0x0C +#define DDR0_12_TCKE_MASK 0x0000007 +#define DDR0_12_TCKE_ENCODE(n) ((((unsigned long)(n))&0x7)<<0) +#define DDR0_12_TCKE_DECODE(n) ((((unsigned long)(n))>>0)&0x7) + +#define DDR0_14 0x0E +#define DDR0_14_DLL_BYPASS_MODE_MASK 0x01000000 +#define DDR0_14_DLL_BYPASS_MODE_ENCODE(n) ((((unsigned long)(n))&0x1)<<24) +#define DDR0_14_DLL_BYPASS_MODE_DECODE(n) ((((unsigned long)(n))>>24)&0x1) +#define DDR0_14_REDUC_MASK 0x00010000 +#define DDR0_14_REDUC_64BITS 0x00000000 +#define DDR0_14_REDUC_32BITS 0x00010000 +#define DDR0_14_REDUC_ENCODE(n) ((((unsigned long)(n))&0x1)<<16) +#define DDR0_14_REDUC_DECODE(n) ((((unsigned long)(n))>>16)&0x1) +#define DDR0_14_REG_DIMM_ENABLE_MASK 0x00000100 +#define DDR0_14_REG_DIMM_ENABLE_ENCODE(n) ((((unsigned long)(n))&0x1)<<8) +#define DDR0_14_REG_DIMM_ENABLE_DECODE(n) ((((unsigned long)(n))>>8)&0x1) + +#define DDR0_17 0x11 +#define DDR0_17_DLL_DQS_DELAY_0_MASK 0x7F000000 +#define DDR0_17_DLL_DQS_DELAY_0_ENCODE(n) ((((unsigned long)(n))&0x7F)<<24) +#define DDR0_17_DLL_DQS_DELAY_0_DECODE(n) ((((unsigned long)(n))>>24)&0x7F) +#define DDR0_17_DLLLOCKREG_MASK 0x00010000 /* Read only */ +#define DDR0_17_DLLLOCKREG_LOCKED 0x00010000 +#define DDR0_17_DLLLOCKREG_UNLOCKED 0x00000000 +#define DDR0_17_DLLLOCKREG_ENCODE(n) ((((unsigned long)(n))&0x1)<<16) +#define DDR0_17_DLLLOCKREG_DECODE(n) ((((unsigned long)(n))>>16)&0x1) +#define DDR0_17_DLL_LOCK_MASK 0x00007F00 /* Read only */ +#define DDR0_17_DLL_LOCK_ENCODE(n) ((((unsigned long)(n))&0x7F)<<8) +#define DDR0_17_DLL_LOCK_DECODE(n) ((((unsigned long)(n))>>8)&0x7F) + +#define DDR0_18 0x12 +#define DDR0_18_DLL_DQS_DELAY_X_MASK 0x7F7F7F7F +#define DDR0_18_DLL_DQS_DELAY_4_MASK 0x7F000000 +#define DDR0_18_DLL_DQS_DELAY_4_ENCODE(n) ((((unsigned long)(n))&0x7F)<<24) +#define DDR0_18_DLL_DQS_DELAY_4_DECODE(n) ((((unsigned long)(n))>>24)&0x7F) +#define DDR0_18_DLL_DQS_DELAY_3_MASK 0x007F0000 +#define DDR0_18_DLL_DQS_DELAY_3_ENCODE(n) ((((unsigned long)(n))&0x7F)<<16) +#define DDR0_18_DLL_DQS_DELAY_3_DECODE(n) ((((unsigned long)(n))>>16)&0x7F) +#define DDR0_18_DLL_DQS_DELAY_2_MASK 0x00007F00 +#define DDR0_18_DLL_DQS_DELAY_2_ENCODE(n) ((((unsigned long)(n))&0x7F)<<8) +#define DDR0_18_DLL_DQS_DELAY_2_DECODE(n) ((((unsigned long)(n))>>8)&0x7F) +#define DDR0_18_DLL_DQS_DELAY_1_MASK 0x0000007F +#define DDR0_18_DLL_DQS_DELAY_1_ENCODE(n) ((((unsigned long)(n))&0x7F)<<0) +#define DDR0_18_DLL_DQS_DELAY_1_DECODE(n) ((((unsigned long)(n))>>0)&0x7F) + +#define DDR0_19 0x13 +#define DDR0_19_DLL_DQS_DELAY_X_MASK 0x7F7F7F7F +#define DDR0_19_DLL_DQS_DELAY_8_MASK 0x7F000000 +#define DDR0_19_DLL_DQS_DELAY_8_ENCODE(n) ((((unsigned long)(n))&0x7F)<<24) +#define DDR0_19_DLL_DQS_DELAY_8_DECODE(n) ((((unsigned long)(n))>>24)&0x7F) +#define DDR0_19_DLL_DQS_DELAY_7_MASK 0x007F0000 +#define DDR0_19_DLL_DQS_DELAY_7_ENCODE(n) ((((unsigned long)(n))&0x7F)<<16) +#define DDR0_19_DLL_DQS_DELAY_7_DECODE(n) ((((unsigned long)(n))>>16)&0x7F) +#define DDR0_19_DLL_DQS_DELAY_6_MASK 0x00007F00 +#define DDR0_19_DLL_DQS_DELAY_6_ENCODE(n) ((((unsigned long)(n))&0x7F)<<8) +#define DDR0_19_DLL_DQS_DELAY_6_DECODE(n) ((((unsigned long)(n))>>8)&0x7F) +#define DDR0_19_DLL_DQS_DELAY_5_MASK 0x0000007F +#define DDR0_19_DLL_DQS_DELAY_5_ENCODE(n) ((((unsigned long)(n))&0x7F)<<0) +#define DDR0_19_DLL_DQS_DELAY_5_DECODE(n) ((((unsigned long)(n))>>0)&0x7F) + +#define DDR0_20 0x14 +#define DDR0_20_DLL_DQS_BYPASS_3_MASK 0x7F000000 +#define DDR0_20_DLL_DQS_BYPASS_3_ENCODE(n) ((((unsigned long)(n))&0x7F)<<24) +#define DDR0_20_DLL_DQS_BYPASS_3_DECODE(n) ((((unsigned long)(n))>>24)&0x7F) +#define DDR0_20_DLL_DQS_BYPASS_2_MASK 0x007F0000 +#define DDR0_20_DLL_DQS_BYPASS_2_ENCODE(n) ((((unsigned long)(n))&0x7F)<<16) +#define DDR0_20_DLL_DQS_BYPASS_2_DECODE(n) ((((unsigned long)(n))>>16)&0x7F) +#define DDR0_20_DLL_DQS_BYPASS_1_MASK 0x00007F00 +#define DDR0_20_DLL_DQS_BYPASS_1_ENCODE(n) ((((unsigned long)(n))&0x7F)<<8) +#define DDR0_20_DLL_DQS_BYPASS_1_DECODE(n) ((((unsigned long)(n))>>8)&0x7F) +#define DDR0_20_DLL_DQS_BYPASS_0_MASK 0x0000007F +#define DDR0_20_DLL_DQS_BYPASS_0_ENCODE(n) ((((unsigned long)(n))&0x7F)<<0) +#define DDR0_20_DLL_DQS_BYPASS_0_DECODE(n) ((((unsigned long)(n))>>0)&0x7F) + +#define DDR0_21 0x15 +#define DDR0_21_DLL_DQS_BYPASS_7_MASK 0x7F000000 +#define DDR0_21_DLL_DQS_BYPASS_7_ENCODE(n) ((((unsigned long)(n))&0x7F)<<24) +#define DDR0_21_DLL_DQS_BYPASS_7_DECODE(n) ((((unsigned long)(n))>>24)&0x7F) +#define DDR0_21_DLL_DQS_BYPASS_6_MASK 0x007F0000 +#define DDR0_21_DLL_DQS_BYPASS_6_ENCODE(n) ((((unsigned long)(n))&0x7F)<<16) +#define DDR0_21_DLL_DQS_BYPASS_6_DECODE(n) ((((unsigned long)(n))>>16)&0x7F) +#define DDR0_21_DLL_DQS_BYPASS_5_MASK 0x00007F00 +#define DDR0_21_DLL_DQS_BYPASS_5_ENCODE(n) ((((unsigned long)(n))&0x7F)<<8) +#define DDR0_21_DLL_DQS_BYPASS_5_DECODE(n) ((((unsigned long)(n))>>8)&0x7F) +#define DDR0_21_DLL_DQS_BYPASS_4_MASK 0x0000007F +#define DDR0_21_DLL_DQS_BYPASS_4_ENCODE(n) ((((unsigned long)(n))&0x7F)<<0) +#define DDR0_21_DLL_DQS_BYPASS_4_DECODE(n) ((((unsigned long)(n))>>0)&0x7F) + +#define DDR0_22 0x16 +#define DDR0_22_CTRL_RAW_MASK 0x03000000 +#define DDR0_22_CTRL_RAW_ECC_DISABLE 0x00000000 /* ECC not being used */ +#define DDR0_22_CTRL_RAW_ECC_CHECK_ONLY 0x01000000 /* ECC checking is on, but no attempts to correct */ +#define DDR0_22_CTRL_RAW_NO_ECC_RAM 0x02000000 /* No ECC RAM storage available */ +#define DDR0_22_CTRL_RAW_ECC_ENABLE 0x03000000 /* ECC checking and correcting on */ +#define DDR0_22_CTRL_RAW_ENCODE(n) ((((unsigned long)(n))&0x3)<<24) +#define DDR0_22_CTRL_RAW_DECODE(n) ((((unsigned long)(n))>>24)&0x3) +#define DDR0_22_DQS_OUT_SHIFT_BYPASS_MASK 0x007F0000 +#define DDR0_22_DQS_OUT_SHIFT_BYPASS_ENCODE(n) ((((unsigned long)(n))&0x7F)<<16) +#define DDR0_22_DQS_OUT_SHIFT_BYPASS_DECODE(n) ((((unsigned long)(n))>>16)&0x7F) +#define DDR0_22_DQS_OUT_SHIFT_MASK 0x00007F00 +#define DDR0_22_DQS_OUT_SHIFT_ENCODE(n) ((((unsigned long)(n))&0x7F)<<8) +#define DDR0_22_DQS_OUT_SHIFT_DECODE(n) ((((unsigned long)(n))>>8)&0x7F) +#define DDR0_22_DLL_DQS_BYPASS_8_MASK 0x0000007F +#define DDR0_22_DLL_DQS_BYPASS_8_ENCODE(n) ((((unsigned long)(n))&0x7F)<<0) +#define DDR0_22_DLL_DQS_BYPASS_8_DECODE(n) ((((unsigned long)(n))>>0)&0x7F) + +#define DDR0_23 0x17 +#define DDR0_23_ODT_RD_MAP_CS0_MASK 0x03000000 +#define DDR0_23_ODT_RD_MAP_CS0_ENCODE(n) ((((unsigned long)(n))&0x3)<<24) +#define DDR0_23_ODT_RD_MAP_CS0_DECODE(n) ((((unsigned long)(n))>>24)&0x3) +#define DDR0_23_ECC_C_SYND_MASK 0x00FF0000 /* Read only */ +#define DDR0_23_ECC_C_SYND_ENCODE(n) ((((unsigned long)(n))&0xFF)<<16) +#define DDR0_23_ECC_C_SYND_DECODE(n) ((((unsigned long)(n))>>16)&0xFF) +#define DDR0_23_ECC_U_SYND_MASK 0x0000FF00 /* Read only */ +#define DDR0_23_ECC_U_SYND_ENCODE(n) ((((unsigned long)(n))&0xFF)<<8) +#define DDR0_23_ECC_U_SYND_DECODE(n) ((((unsigned long)(n))>>8)&0xFF) +#define DDR0_23_FWC_MASK 0x00000001 /* Write only */ +#define DDR0_23_FWC_ENCODE(n) ((((unsigned long)(n))&0x1)<<0) +#define DDR0_23_FWC_DECODE(n) ((((unsigned long)(n))>>0)&0x1) + +#define DDR0_24 0x18 +#define DDR0_24_RTT_PAD_TERMINATION_MASK 0x03000000 +#define DDR0_24_RTT_PAD_TERMINATION_ENCODE(n) ((((unsigned long)(n))&0x3)<<24) +#define DDR0_24_RTT_PAD_TERMINATION_DECODE(n) ((((unsigned long)(n))>>24)&0x3) +#define DDR0_24_ODT_WR_MAP_CS1_MASK 0x00030000 +#define DDR0_24_ODT_WR_MAP_CS1_ENCODE(n) ((((unsigned long)(n))&0x3)<<16) +#define DDR0_24_ODT_WR_MAP_CS1_DECODE(n) ((((unsigned long)(n))>>16)&0x3) +#define DDR0_24_ODT_RD_MAP_CS1_MASK 0x00000300 +#define DDR0_24_ODT_RD_MAP_CS1_ENCODE(n) ((((unsigned long)(n))&0x3)<<8) +#define DDR0_24_ODT_RD_MAP_CS1_DECODE(n) ((((unsigned long)(n))>>8)&0x3) +#define DDR0_24_ODT_WR_MAP_CS0_MASK 0x00000003 +#define DDR0_24_ODT_WR_MAP_CS0_ENCODE(n) ((((unsigned long)(n))&0x3)<<0) +#define DDR0_24_ODT_WR_MAP_CS0_DECODE(n) ((((unsigned long)(n))>>0)&0x3) + +#define DDR0_25 0x19 +#define DDR0_25_VERSION_MASK 0xFFFF0000 /* Read only */ +#define DDR0_25_VERSION_ENCODE(n) ((((unsigned long)(n))&0xFFFF)<<16) +#define DDR0_25_VERSION_DECODE(n) ((((unsigned long)(n))>>16)&0xFFFF) +#define DDR0_25_OUT_OF_RANGE_LENGTH_MASK 0x000003FF /* Read only */ +#define DDR0_25_OUT_OF_RANGE_LENGTH_ENCODE(n) ((((unsigned long)(n))&0x3FF)<<0) +#define DDR0_25_OUT_OF_RANGE_LENGTH_DECODE(n) ((((unsigned long)(n))>>0)&0x3FF) + +#define DDR0_26 0x1A +#define DDR0_26_TRAS_MAX_MASK 0xFFFF0000 +#define DDR0_26_TRAS_MAX_ENCODE(n) ((((unsigned long)(n))&0xFFFF)<<16) +#define DDR0_26_TRAS_MAX_DECODE(n) ((((unsigned long)(n))>>16)&0xFFFF) +#define DDR0_26_TREF_MASK 0x00003FFF +#define DDR0_26_TREF_ENCODE(n) ((((unsigned long)(n))&0x3FFF)<<0) +#define DDR0_26_TREF_DECODE(n) ((((unsigned long)(n))>>0)&0x3FFF) + +#define DDR0_27 0x1B +#define DDR0_27_EMRS_DATA_MASK 0x3FFF0000 +#define DDR0_27_EMRS_DATA_ENCODE(n) ((((unsigned long)(n))&0x3FFF)<<16) +#define DDR0_27_EMRS_DATA_DECODE(n) ((((unsigned long)(n))>>16)&0x3FFF) +#define DDR0_27_TINIT_MASK 0x0000FFFF +#define DDR0_27_TINIT_ENCODE(n) ((((unsigned long)(n))&0xFFFF)<<0) +#define DDR0_27_TINIT_DECODE(n) ((((unsigned long)(n))>>0)&0xFFFF) + +#define DDR0_28 0x1C +#define DDR0_28_EMRS3_DATA_MASK 0x3FFF0000 +#define DDR0_28_EMRS3_DATA_ENCODE(n) ((((unsigned long)(n))&0x3FFF)<<16) +#define DDR0_28_EMRS3_DATA_DECODE(n) ((((unsigned long)(n))>>16)&0x3FFF) +#define DDR0_28_EMRS2_DATA_MASK 0x00003FFF +#define DDR0_28_EMRS2_DATA_ENCODE(n) ((((unsigned long)(n))&0x3FFF)<<0) +#define DDR0_28_EMRS2_DATA_DECODE(n) ((((unsigned long)(n))>>0)&0x3FFF) + +#define DDR0_31 0x1F +#define DDR0_31_XOR_CHECK_BITS_MASK 0x0000FFFF +#define DDR0_31_XOR_CHECK_BITS_ENCODE(n) ((((unsigned long)(n))&0xFFFF)<<0) +#define DDR0_31_XOR_CHECK_BITS_DECODE(n) ((((unsigned long)(n))>>0)&0xFFFF) + +#define DDR0_32 0x20 +#define DDR0_32_OUT_OF_RANGE_ADDR_MASK 0xFFFFFFFF /* Read only */ +#define DDR0_32_OUT_OF_RANGE_ADDR_ENCODE(n) ((((unsigned long)(n))&0xFFFFFFFF)<<0) +#define DDR0_32_OUT_OF_RANGE_ADDR_DECODE(n) ((((unsigned long)(n))>>0)&0xFFFFFFFF) + +#define DDR0_33 0x21 +#define DDR0_33_OUT_OF_RANGE_ADDR_MASK 0x00000001 /* Read only */ +#define DDR0_33_OUT_OF_RANGE_ADDR_ENCODE(n) ((((unsigned long)(n))&0x1)<<0) +#define DDR0_33_OUT_OF_RANGE_ADDR_DECODE(n) ((((unsigned long)(n))>>0)&0x1) + +#define DDR0_34 0x22 +#define DDR0_34_ECC_U_ADDR_MASK 0xFFFFFFFF /* Read only */ +#define DDR0_34_ECC_U_ADDR_ENCODE(n) ((((unsigned long)(n))&0xFFFFFFFF)<<0) +#define DDR0_34_ECC_U_ADDR_DECODE(n) ((((unsigned long)(n))>>0)&0xFFFFFFFF) + +#define DDR0_35 0x23 +#define DDR0_35_ECC_U_ADDR_MASK 0x00000001 /* Read only */ +#define DDR0_35_ECC_U_ADDR_ENCODE(n) ((((unsigned long)(n))&0x1)<<0) +#define DDR0_35_ECC_U_ADDR_DECODE(n) ((((unsigned long)(n))>>0)&0x1) + +#define DDR0_36 0x24 +#define DDR0_36_ECC_U_DATA_MASK 0xFFFFFFFF /* Read only */ +#define DDR0_36_ECC_U_DATA_ENCODE(n) ((((unsigned long)(n))&0xFFFFFFFF)<<0) +#define DDR0_36_ECC_U_DATA_DECODE(n) ((((unsigned long)(n))>>0)&0xFFFFFFFF) + +#define DDR0_37 0x25 +#define DDR0_37_ECC_U_DATA_MASK 0xFFFFFFFF /* Read only */ +#define DDR0_37_ECC_U_DATA_ENCODE(n) ((((unsigned long)(n))&0xFFFFFFFF)<<0) +#define DDR0_37_ECC_U_DATA_DECODE(n) ((((unsigned long)(n))>>0)&0xFFFFFFFF) + +#define DDR0_38 0x26 +#define DDR0_38_ECC_C_ADDR_MASK 0xFFFFFFFF /* Read only */ +#define DDR0_38_ECC_C_ADDR_ENCODE(n) ((((unsigned long)(n))&0xFFFFFFFF)<<0) +#define DDR0_38_ECC_C_ADDR_DECODE(n) ((((unsigned long)(n))>>0)&0xFFFFFFFF) + +#define DDR0_39 0x27 +#define DDR0_39_ECC_C_ADDR_MASK 0x00000001 /* Read only */ +#define DDR0_39_ECC_C_ADDR_ENCODE(n) ((((unsigned long)(n))&0x1)<<0) +#define DDR0_39_ECC_C_ADDR_DECODE(n) ((((unsigned long)(n))>>0)&0x1) + +#define DDR0_40 0x28 +#define DDR0_40_ECC_C_DATA_MASK 0xFFFFFFFF /* Read only */ +#define DDR0_40_ECC_C_DATA_ENCODE(n) ((((unsigned long)(n))&0xFFFFFFFF)<<0) +#define DDR0_40_ECC_C_DATA_DECODE(n) ((((unsigned long)(n))>>0)&0xFFFFFFFF) + +#define DDR0_41 0x29 +#define DDR0_41_ECC_C_DATA_MASK 0xFFFFFFFF /* Read only */ +#define DDR0_41_ECC_C_DATA_ENCODE(n) ((((unsigned long)(n))&0xFFFFFFFF)<<0) +#define DDR0_41_ECC_C_DATA_DECODE(n) ((((unsigned long)(n))>>0)&0xFFFFFFFF) + +#define DDR0_42 0x2A +#define DDR0_42_ADDR_PINS_MASK 0x07000000 +#define DDR0_42_ADDR_PINS_ENCODE(n) ((((unsigned long)(n))&0x7)<<24) +#define DDR0_42_ADDR_PINS_DECODE(n) ((((unsigned long)(n))>>24)&0x7) +#define DDR0_42_CASLAT_LIN_GATE_MASK 0x0000000F +#define DDR0_42_CASLAT_LIN_GATE_ENCODE(n) ((((unsigned long)(n))&0xF)<<0) +#define DDR0_42_CASLAT_LIN_GATE_DECODE(n) ((((unsigned long)(n))>>0)&0xF) + +#define DDR0_43 0x2B +#define DDR0_43_TWR_MASK 0x07000000 +#define DDR0_43_TWR_ENCODE(n) ((((unsigned long)(n))&0x7)<<24) +#define DDR0_43_TWR_DECODE(n) ((((unsigned long)(n))>>24)&0x7) +#define DDR0_43_APREBIT_MASK 0x000F0000 +#define DDR0_43_APREBIT_ENCODE(n) ((((unsigned long)(n))&0xF)<<16) +#define DDR0_43_APREBIT_DECODE(n) ((((unsigned long)(n))>>16)&0xF) +#define DDR0_43_COLUMN_SIZE_MASK 0x00000700 +#define DDR0_43_COLUMN_SIZE_ENCODE(n) ((((unsigned long)(n))&0x7)<<8) +#define DDR0_43_COLUMN_SIZE_DECODE(n) ((((unsigned long)(n))>>8)&0x7) +#define DDR0_43_EIGHT_BANK_MODE_MASK 0x00000001 +#define DDR0_43_EIGHT_BANK_MODE_8_BANKS 0x00000001 +#define DDR0_43_EIGHT_BANK_MODE_4_BANKS 0x00000000 +#define DDR0_43_EIGHT_BANK_MODE_ENCODE(n) ((((unsigned long)(n))&0x1)<<0) +#define DDR0_43_EIGHT_BANK_MODE_DECODE(n) ((((unsigned long)(n))>>0)&0x1) + +#define DDR0_44 0x2C +#define DDR0_44_TRCD_MASK 0x000000FF +#define DDR0_44_TRCD_ENCODE(n) ((((unsigned long)(n))&0xFF)<<0) +#define DDR0_44_TRCD_DECODE(n) ((((unsigned long)(n))>>0)&0xFF) + +#endif /* CONFIG_440EPX */ + /*----------------------------------------------------------------------------- | External Bus Controller +----------------------------------------------------------------------------*/
Larry Johnson
