[U-Boot] Pull request: u-boot-arm/master
Hi Tom,
The following changes since commit eeb72e67619b98d2502fe634a3a5d9953de92ad0:
Merge branch 'master' of git://git.denx.de/u-boot-arm (2014-02-26 16:49:58 -0500)
git://git.denx.de/u-boot-arm master
for you to fetch changes up to 27019e4a949fc3be2e895ac20839c4d4d119f902:
arm: atmel: sama5d3: add nand spl boot support (2014-03-09 19:19:13 +0100)
---------------------------------------------------------------- Albert ARIBAUD (1): Merge branch 'u-boot-tegra/master' into 'u-boot-arm/master'
Andreas Henriksson (2): at91sam9263ek: add mmc support at91 gpio: fix typo in compatibility macro
Bo Shen (4): ARM: atmel: add sama5d3 Xplained board support arm: atmel: sama5d3: add spi spl boot support mtd: nand: atmel: prepare for nand spl boot support arm: atmel: sama5d3: add nand spl boot support
Dave Gerlach (3): ARM: AM43xx: EMIF: configure self-refresh entry delay ARM: AM43xx: Write sdram_config to secure_emif_sdram_config ARM: AM43xx: Change DDR3 Reset Value
Enric Balletbo i Serra (1): OMAP3: igep00x0: Enable required clocks for GPIO that are used.
Hannes Petermaier (1): board/BuR/common: fix phy addresses
Lokesh Vutla (1): ARM: AM4372: Update EMIF registers for DDR3
Mugunthan V N (6): drivers: net: cpsw: add support to have phy address from cpsw platform data ARM: AM43xx: clocks: Enable CPGMAC clock control ARM: AM43xx: Add CPSW support to AM43xx EPOS and GP EVM ARM: AM335x: add support for reading cpsw 2nd mac address from efuse ARM: DRA7xx: add support for reading cpsw 2nd mac from efuse ARM: AM43xx: Add Ethernet boot support to SPL
Stefan Roese (1): arm: am335x: DXR2: Reset SMSC LAN9303 switch via GPIO upon bootup
Stephen Warren (8): ARM: tegra: move CONFIG_TEGRAnn ARM: tegra: fix pmc_pwrgate_timer_mult register definition ARM: tegra: fix NV_PA_CSITE_BASE for Tegra124 ARM: tegra: simplify halt_avp() ARM: tegra: set CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS ARM: tegra: convert tegra to use distro defaults ARM: tegra: rework boot scripts ARM: tegra: implement bootcmd_pxe
arch/arm/cpu/arm720t/tegra-common/cpu.c | 5 ++- arch/arm/cpu/arm720t/tegra124/cpu.c | 4 +-- arch/arm/cpu/arm926ejs/at91/at91sam9263_devices.c | 25 ++++++++++++++ arch/arm/cpu/armv7/am33xx/clock_am43xx.c | 1 + arch/arm/cpu/armv7/am33xx/ddr.c | 5 +-- arch/arm/cpu/armv7/am33xx/emif4.c | 2 +- arch/arm/cpu/at91-common/spl.c | 4 +++ arch/arm/include/asm/arch-at91/gpio.h | 2 +- arch/arm/include/asm/arch-at91/spl.h | 4 +++ arch/arm/include/asm/arch-tegra/pmc.h | 11 +++++++ arch/arm/include/asm/arch-tegra/tegra.h | 5 +++ arch/arm/include/asm/arch-tegra114/tegra.h | 2 ++ arch/arm/include/asm/arch-tegra124/tegra.h | 2 ++ arch/arm/include/asm/arch-tegra20/tegra.h | 2 ++ arch/arm/include/asm/arch-tegra30/tegra.h | 2 ++ board/BuR/common/common.c | 4 +-- board/atmel/at91sam9263ek/at91sam9263ek.c | 10 ++++++ board/atmel/sama5d3_xplained/Makefile | 15 +++++++++ board/atmel/sama5d3_xplained/sama5d3_xplained.c | 130 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/atmel/sama5d3xek/sama5d3xek.c | 4 +++ board/compulab/cm_t335/cm_t335.c | 2 +- board/isee/igep0033/board.c | 2 +- board/phytec/pcm051/board.c | 4 +-- board/siemens/dxr2/board.c | 9 ++++- board/siemens/dxr2/mux.c | 2 ++ board/siemens/pxm2/board.c | 4 +-- board/siemens/rut/board.c | 4 +-- board/silica/pengwyn/board.c | 4 +-- board/ti/am335x/board.c | 19 +++++++++-- board/ti/am43xx/board.c | 100 ++++++++++++++++++++++++++++++++++++++++++++++++++++++- board/ti/am43xx/mux.c | 44 +++++++++++++++++++++++-- board/ti/dra7xx/evm.c | 19 +++++++++-- board/ti/ti814x/evm.c | 4 +-- boards.cfg | 2 ++ drivers/mtd/nand/atmel_nand.c | 208 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/net/cpsw.c | 4 +-- include/configs/am335x_evm.h | 1 - include/configs/am335x_igep0033.h | 1 - include/configs/am43xx_evm.h | 26 +++++++++++++++ include/configs/at91sam9263ek.h | 13 ++++++++ include/configs/bur_am335x_common.h | 1 - include/configs/cm_t335.h | 1 - include/configs/dra7xx_evm.h | 1 - include/configs/dxr2.h | 2 +- include/configs/omap3_igep00x0.h | 5 +++ include/configs/pcm051.h | 1 - include/configs/pengwyn.h | 1 - include/configs/pxm2.h | 1 - include/configs/rut.h | 1 - include/configs/sama5d3_xplained.h | 203 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ include/configs/sama5d3xek.h | 23 +++++++++++++ include/configs/tegra-common-post.h | 57 ++++++++++++++++++++++++++------ include/configs/tegra-common.h | 20 +++-------- include/configs/tegra114-common.h | 10 +++--- include/configs/tegra124-common.h | 6 +--- include/configs/tegra20-common.h | 10 +++--- include/configs/tegra30-common.h | 10 +++--- include/configs/ti814x_evm.h | 1 - include/configs/ti_am335x_common.h | 1 + include/cpsw.h | 2 +- include/nand.h | 6 ++++ 61 files changed, 983 insertions(+), 91 deletions(-) create mode 100644 board/atmel/sama5d3_xplained/Makefile create mode 100644 board/atmel/sama5d3_xplained/sama5d3_xplained.c create mode 100644 include/configs/sama5d3_xplained.h
Amicalement,
On Mon, Mar 10, 2014 at 07:16:44PM +0100, Albert ARIBAUD wrote:
Hi Tom,
Albert ARIBAUD
