[U-Boot] u-boot on raspberry 2: booting in SVC secure mode
Hi, as explained here http://community.arm.com/message/25127, it is possible to boot the raspberry 2 in secure mode, by adding the kernel_old=1 option in config.txt. The main effects of this option are: - all 4 cores start executing in secure SVC mode instead of non-secure SVC mode - all 4 cores start at 0x0000 instead of 0x8000 - the initial boot code that setup SMP and exits secure mode is not executed
After browsing u-boot's source code, it seems that their boot code is more or less extracted from what u-boot is doing. However I didn't manage to compile u-boot for the raspberry 2 supporting this secure mode.
Could anyone explain me what options I need to configure in rpi_2_defconfig so that u-boot supports secure boot for the raspberry 2 and what the boot sequence will be in this case ? I don't mind fixing the code if necessary but I'm a bit lost in the order of events in the initialization.
Best, Vincent
mode
executed
(Luckily I just happened to notice this message while looking at another one nearby. CCing the relevant board maintainer(s) explicitly would help your messages be noticed)
To modify U-Boot to support the alternate entry point/load address, you'd hopefully only need to change the definition of CONFIG_SYS_TEXT_BASE in include/configs/rpi*.h.
I wasn't aware of the thread/option you mention, so I have not attempted to boot the RPi2 U-Boot in secure mode. If you're lucky, U-Boot itself will "just work" once TEXT_BASE is fixed.
To boot a kernel, you'll probably need to at least configure the ARM architected timers CNTFRQ register for the kernel. Perhaps there are a few other things like that missing?
It might be interesting to enable U-Boot's PSCI support on the RPi2, so that an upstream kernel could gain SMP support without the need for explicit BCM2836 SMP support code.
So far, I haven't attempted anything with an (upstream) kernel on RPi2, just U-Boot.
Hi, I finally hacked my way through U-boot and I managed to add raspberry's boot code inside U-boot so that it can start as usual when using kernel_old = 1. I don't think we want this as a final solution but it made me understand a few things about U-boot architecture (in short: I added a new section located at 0x0 which executes raspberry's code, and then jump to the usual _start entry point). I didn't try to modify CONFIG_SYS_TEXT_BASE yet, I'll try this morning.
From what I gathered from the source code, I think I have to activate some
options (like the ones in arch/arm/cpu/armv7/Kconfig) so that U-boot starts in secure mode, but adding them to rpi_2_defconfig doesn't seem to change anything in .config, so I'm not sure that my current U-boot is "secure boot aware". Should I add ARMV7_BOOT_SEC_DEFAULT by hand in .config or something like that ?
Thank you for your feedback !
Best, Vincent
2015-02-25 19:38 GMT+01:00 Stephen Warren swarren@wwwdotorg.org:
mode
executed
Hi Vincent,
From what I gathered from the source code, I think I have to activate some options (like the ones in arch/arm/cpu/armv7/Kconfig) so that U-boot starts in secure mode, but adding them to rpi_2_defconfig doesn't seem to change anything in .config, so I'm not sure that my current U-boot is "secure boot aware". Should I add ARMV7_BOOT_SEC_DEFAULT by hand in .config or something like that ?
AFAIK you don't need to tell U-Boot that it runs in secure: unless it accesses any secure/non-secure specific peripherals it should work fine in both modes. Setting ARMV7_BOOT_SEC_DEFAULT just prevents U-Boot to switch into non-sec, but there is no real reason to do so - at least not for Linux.
You should do away with the original Raspi firmware snippet - not only from a legal point of view. Thanks to Marc U-Boot has now a much better implementation than my original HYP-mode switcher, also this gives you PSCI support basically for free. So just select ARMV7_VIRT and ARMV7_NONSEC.
Do you know if there is a TrustZone Controller in that SoC? That would be needed to guard the resident U-Boot code from the OS. Some SoCs have secure on-chip SRAM usable for that purpose, that would do it, too. But skimming through the BCM2835 .pdf I don't spot any of those, unfortunately.
Cheers, Andre.
mode
executed
I tried what Stephen suggested, and just changing CONFIG_SYS_TEXT_BASE to 0x0 (with kernel_old=1) does not work: the board display some garbage on the uart then hangs. The content of the garbage makes me thinks that nothing is done to handle the four cores in this setting which ends up badly. I expected this since raspberry's "firmware" only let one core run free. I think I need to configure U-boot so that it deals with this SMP scenario (I just don't know how).
My goal is to use U-boot to load some small homemade baremetal kernels on the raspberry (using serial or tftp loading), in *secure mode*, so I need U-boot to stay in secure mode, or at least let me install my own secure_monitor code before switching to non-secure mode.
I made a couple attempts of adding secure mode support by adding options in configs/rpi_2_defconfig but they don't seem to be taken into account. Where do you suggest I put ARMV7_virt and ARMV7_NONSEC ?
Best, Vincent
2015-02-26 10:17 GMT+01:00 Andre Przywara andre.przywara@arm.com:
Hi Vincent,
kernel_old
some
starts
Cheers, Andre.
possible
in
SVC
mode
executed
more
boot
necessary
you'd
will
few
Oh and I don't think there is a TZ Address space controller on the raspberry, or at least I am not aware of any.
2015-02-26 10:32 GMT+01:00 Vincent vincent.siles@gmail.com:
Best, Vincent
Hi Vincent,
kernel_old
0x0
some
starts
Cheers, Andre.
possible
option in
non-secure SVC
mode
executed
more
to
boot
necessary
another
help
you'd
attempted
will
few
Hi Vincent,
Ah yes, it seems like there should be code to branch off on secondary codes based on MPIDR reading in start.S early. I try to take a look at it later.
So you should set ARMV7_BOOT_SEC_DEFAULT in this case then. Do you desperately need the other three cores? If not you could get away with disabling the SMP parts of the code for the time being, putting the other cores in WFI or WFE.
adding: ------ config ARMV7_NONSEC default y config ARMV7_VIRT default y ------ to board/raspberrypi/rpi_2/Kconfig did the trick for me, though it (correctly) complains about some missing bits. I will not find time until tonight to work on this, so you may want to take a look at commits fafbc6c000db and e261c83aa04c meanwhile to see what needs to be done in this regard for a new board. I couldn't get u-boot to output anything at all with kernel_old=1 on my quick try yesterday, what is your current setup to get to the UART garbage? Did you enable some kind of early debug or did you put any extra code at 0x0? I tried setting SYS_TEXT_BASE to 0x0, but that didn't change anything.
Cheers, Andre.
Hi Vincent,
kernel_old
some
starts
Cheers, Andre.
possible
in
SVC
mode
executed
more
boot
necessary
you'd
will
few
2015-02-27 10:41 GMT+01:00 Andre Przywara andre.przywara@arm.com:
Hi Vincent,
I don't care about the other cores for now, I only need one core. I put them in wfi quite early in the process.
in
Where
adding:
Thank you, I was changing rpi_2_defconfing instead of rpi_2/Kconfig.
Indeed I tried again earlier and nothing showed up... I might have had
other changes that I don't remember (like ARMV7_BOOT_SEC_DEFAULT or something like that).
Thank you for your interest, I'll have a look at the commits you pointed out. I don't think I'll be able to have a clear look before next week, so there's no rush :)
Best, Vincent
Cheers, Andre.
Hi Vincent,
kernel_old
0x0
some
starts
like
that ?
Cheers, Andre.
possible
option
in
non-secure
SVC
mode
executed
more
to
boot
necessary
another
help
you'd
in
attempted
will
few
so
RPi2,
just U-Boot.
That expectation seems correct! I hacked in some code right at the start of U-Boot (reset: in arch/arm/cpu/armv7/start.S) that extracted the CPUID from the MPIDR register, and only allowed CPU0 to continue. With that in place, kernel_old=1 and CONFIG_SYS_TEXT_BASE=0 worked.
Interesting that all CPU cores get released at reset; the other SoCs I've used only release CPU0 and you have to explicitly boot CPUn.
I would suggest adding #defines to include/configs/rpi_2.h.
Thank to your last email, I finally managed to boot in secure mode with (what I consider as) minimal changes: - kernel_old=1 - CONFIG_SYS_TEXT_BASE=0 - halting other cores in start.S:reset - commenting away line 113 in arch/arm/cpu/armv7/virt-v7.c: smp_set_core_boot_addr((unsigned long)secure_ram_addr(_smp_pen), -1); - hack around _smp_pen so the code compiles correctly - adding two defines to rpi_2.h #define CONFIG_ARMV7_NONSEC #define CONFIG_ARMV7_BOOT_SEC_DEFAULT
I'm uploading this fork on github (https://github.com/vsiles/u-boot) if anyone is interested. I'm pretty sure that not the "right" way to do it, but it works for now :) Thank you very much for your help V.
2015-02-28 5:58 GMT+01:00 Stephen Warren swarren@wwwdotorg.org:
Andre Przywara
Stephen Warren
Vincent
