[PATCH v1] arm: dts: rockchip: rk3128: fix DT node names
The rk3128 DT node names should be generic. Rename them to the pattern defined in the DT bindings.
Signed-off-by: Johan Jonker jbx6244@gmail.com --- arch/arm/dts/rk3128-evb.dts | 5 +++ arch/arm/dts/rk3128.dtsi | 62 +++++++++++++++++-------------------- 2 files changed, 33 insertions(+), 34 deletions(-)
diff --git a/arch/arm/dts/rk3128-evb.dts b/arch/arm/dts/rk3128-evb.dts index e7d8f7c9..93291d78 100644 --- a/arch/arm/dts/rk3128-evb.dts +++ b/arch/arm/dts/rk3128-evb.dts @@ -15,6 +15,11 @@ stdout-path = &uart2; };
+ memory@60000000 { + device_type = "memory"; + reg = <0x60000000 0x40000000>; + }; + vcc5v0_otg: vcc5v0-otg-drv { compatible = "regulator-fixed"; regulator-name = "vcc5v0_otg"; diff --git a/arch/arm/dts/rk3128.dtsi b/arch/arm/dts/rk3128.dtsi index 589818da..f66efde3 100644 --- a/arch/arm/dts/rk3128.dtsi +++ b/arch/arm/dts/rk3128.dtsi @@ -8,7 +8,6 @@ #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/pinctrl/rockchip.h> #include <dt-bindings/clock/rk3128-cru.h> -#include "skeleton.dtsi"
/ { compatible = "rockchip,rk3128"; @@ -34,11 +33,6 @@ mmc1 = &sdmmc; };
- memory { - device_type = "memory"; - reg = <0x60000000 0x40000000>; - }; - arm-pmu { compatible = "arm,cortex-a7-pmu"; interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>, @@ -52,10 +46,10 @@ #size-cells = <0>; enable-method = "rockchip,rk3128-smp";
- cpu0:cpu@0x000 { + cpu0: cpu@0 { device_type = "cpu"; compatible = "arm,cortex-a7"; - reg = <0x000>; + reg = <0x0>; operating-points = < /* KHz uV */ 816000 1000000 @@ -65,22 +59,22 @@ clocks = <&cru ARMCLK>; };
- cpu1:cpu@0x001 { + cpu1: cpu@1 { device_type = "cpu"; compatible = "arm,cortex-a7"; - reg = <0x001>; + reg = <0x1>; };
- cpu2:cpu@0x002 { + cpu2: cpu@2 { device_type = "cpu"; compatible = "arm,cortex-a7"; - reg = <0x002>; + reg = <0x2>; };
- cpu3:cpu@0x003 { + cpu3: cpu@3 { device_type = "cpu"; compatible = "arm,cortex-a7"; - reg = <0x003>; + reg = <0x3>; }; };
@@ -165,7 +159,7 @@ interrupt-parent = <&gic>; ranges;
- pdma: pdma@20078000 { + pdma: dma-controller@20078000 { compatible = "arm,pl330", "arm,primecell"; reg = <0x20078000 0x4000>; arm,pl330-broken-no-flushp;//2 @@ -207,7 +201,7 @@ rockchip,broadcast = <1>; };
- watchdog: wdt@2004c000 { + watchdog: watchdog@2004c000 { compatible = "rockchip,watch dog"; reg = <0x2004c000 0x100>; clock-names = "pclk_wdt"; @@ -224,7 +218,7 @@ #reset-cells = <1>; };
- nandc: nandc@10500000 { + nandc: nand-controller@10500000 { compatible = "rockchip,rk-nandc"; reg = <0x10500000 0x4000>; interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>; @@ -247,7 +241,7 @@ assigned-clock-rates = <594000000>; };
- uart0: serial0@20060000 { + uart0: serial@20060000 { compatible = "rockchip,rk3128-uart", "snps,dw-apb-uart"; reg = <0x20060000 0x100>; interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; @@ -262,7 +256,7 @@ #dma-cells = <2>; };
- uart1: serial1@20064000 { + uart1: serial@20064000 { compatible = "rockchip,rk3128-uart", "snps,dw-apb-uart"; reg = <0x20064000 0x100>; interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; @@ -277,7 +271,7 @@ #dma-cells = <2>; };
- uart2: serial2@20068000 { + uart2: serial@20068000 { compatible = "rockchip,rk3128-uart", "snps,dw-apb-uart"; reg = <0x20068000 0x100>; interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; @@ -304,7 +298,7 @@ status = "disabled"; };
- pwm0: pwm0@20050000 { + pwm0: pwm@20050000 { compatible = "rockchip,rk3128-pwm", "rockchip,rk3288-pwm"; reg = <0x20050000 0x10>; #pwm-cells = <3>; @@ -314,7 +308,7 @@ clock-names = "pwm"; };
- pwm1: pwm1@20050010 { + pwm1: pwm@20050010 { compatible = "rockchip,rk3128-pwm", "rockchip,rk3288-pwm"; reg = <0x20050010 0x10>; #pwm-cells = <3>; @@ -324,7 +318,7 @@ clock-names = "pwm"; };
- pwm2: pwm2@20050020 { + pwm2: pwm@20050020 { compatible = "rockchip,rk3128-pwm", "rockchip,rk3288-pwm"; reg = <0x20050020 0x10>; #pwm-cells = <3>; @@ -334,7 +328,7 @@ clock-names = "pwm"; };
- pwm3: pwm3@20050030 { + pwm3: pwm@20050030 { compatible = "rockchip,rk3128-pwm", "rockchip,rk3288-pwm"; reg = <0x20050030 0x10>; #pwm-cells = <3>; @@ -430,7 +424,7 @@ status = "disabled"; };
- sdmmc: dwmmc@10214000 { + sdmmc: mmc@10214000 { compatible = "rockchip,rk312x-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x10214000 0x4000>; interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; @@ -444,7 +438,7 @@ status = "disabled"; };
- emmc: dwmmc@1021c000 { + emmc: mmc@1021c000 { compatible = "rockchip,rk3128-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x1021c000 0x4000>; interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; @@ -462,7 +456,7 @@ status = "disabled"; };
- i2c0: i2c0@20072000 { + i2c0: i2c@20072000 { compatible = "rockchip,rk3128-i2c", "rockchip,rk3288-i2c"; reg = <20072000 0x1000>; interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; @@ -474,7 +468,7 @@ pinctrl-0 = <&i2c0_xfer>; };
- i2c1: i2c1@20056000 { + i2c1: i2c@20056000 { compatible = "rockchip,rk3128-i2c", "rockchip,rk3288-i2c"; reg = <0x20056000 0x1000>; interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; @@ -486,7 +480,7 @@ pinctrl-0 = <&i2c1_xfer>; };
- i2c2: i2c2@2005a000 { + i2c2: i2c@2005a000 { compatible = "rockchip,rk3128-i2c", "rockchip,rk3288-i2c"; reg = <0x2005a000 0x1000>; interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; @@ -498,7 +492,7 @@ pinctrl-0 = <&i2c2_xfer>; };
- i2c3: i2c3@2005e000 { + i2c3: i2c@2005e000 { compatible = "rockchip,rk3128-i2c", "rockchip,rk3288-i2c"; reg = <0x2005e000 0x1000>; interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; @@ -544,7 +538,7 @@ #size-cells = <1>; ranges;
- gpio0: gpio0@2007c000 { + gpio0: gpio@2007c000 { compatible = "rockchip,gpio-bank"; reg = <0x2007c000 0x100>; interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; @@ -555,7 +549,7 @@ #interrupt-cells = <2>; };
- gpio1: gpio1@20080000 { + gpio1: gpio@20080000 { compatible = "rockchip,gpio-bank"; reg = <0x20080000 0x100>; interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; @@ -566,7 +560,7 @@ #interrupt-cells = <2>; };
- gpio2: gpio2@20084000 { + gpio2: gpio@20084000 { compatible = "rockchip,gpio-bank"; reg = <0x20084000 0x100>; interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; @@ -577,7 +571,7 @@ #interrupt-cells = <2>; };
- gpio3: gpio2@20088000 { + gpio3: gpio@20088000 { compatible = "rockchip,gpio-bank"; reg = <0x20088000 0x100>; interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>;
Hi Johan,
If you would like to clean up and sync the dts with kernel for rk3128, could you please group them in one patch set?
Or else it's very easy to lead to conflict.
- memory@60000000 {
- vcc5v0_otg: vcc5v0-otg-drv { compatible = "regulator-fixed"; regulator-name = "vcc5v0_otg";
- memory {
cpu0:cpu@0x000 {
reg = <0x000>;
cpu1:cpu@0x001 {
reg = <0x001>;
};reg = <0x1>;
cpu2:cpu@0x002 {
reg = <0x002>;
};reg = <0x2>;
cpu3:cpu@0x003 {
reg = <0x003>;
}; };reg = <0x3>;
- watchdog: watchdog@2004c000 { compatible = "rockchip,watch dog"; reg = <0x2004c000 0x100>; clock-names = "pclk_wdt";
- nandc: nand-controller@10500000 { compatible = "rockchip,rk-nandc"; reg = <0x10500000 0x4000>; interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>;
- uart0: serial@20060000 { compatible = "rockchip,rk3128-uart", "snps,dw-apb-uart"; reg = <0x20060000 0x100>; interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>;
- uart1: serial@20064000 { compatible = "rockchip,rk3128-uart", "snps,dw-apb-uart"; reg = <0x20064000 0x100>; interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>;
- uart2: serial@20068000 { compatible = "rockchip,rk3128-uart", "snps,dw-apb-uart"; reg = <0x20068000 0x100>; interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>;
- pwm0: pwm@20050000 { compatible = "rockchip,rk3128-pwm", "rockchip,rk3288-pwm"; reg = <0x20050000 0x10>; #pwm-cells = <3>;
- pwm1: pwm@20050010 { compatible = "rockchip,rk3128-pwm", "rockchip,rk3288-pwm"; reg = <0x20050010 0x10>; #pwm-cells = <3>;
- pwm2: pwm@20050020 { compatible = "rockchip,rk3128-pwm", "rockchip,rk3288-pwm"; reg = <0x20050020 0x10>; #pwm-cells = <3>;
- pwm3: pwm@20050030 { compatible = "rockchip,rk3128-pwm", "rockchip,rk3288-pwm"; reg = <0x20050030 0x10>; #pwm-cells = <3>;
- sdmmc: mmc@10214000 { compatible = "rockchip,rk312x-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x10214000 0x4000>; interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>;
- emmc: mmc@1021c000 { compatible = "rockchip,rk3128-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x1021c000 0x4000>; interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>;
- i2c0: i2c@20072000 { compatible = "rockchip,rk3128-i2c", "rockchip,rk3288-i2c"; reg = <20072000 0x1000>; interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>;
- i2c1: i2c@20056000 { compatible = "rockchip,rk3128-i2c", "rockchip,rk3288-i2c"; reg = <0x20056000 0x1000>; interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>;
- i2c2: i2c@2005a000 { compatible = "rockchip,rk3128-i2c", "rockchip,rk3288-i2c"; reg = <0x2005a000 0x1000>; interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>;
- i2c3: i2c@2005e000 { compatible = "rockchip,rk3128-i2c", "rockchip,rk3288-i2c"; reg = <0x2005e000 0x1000>; interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>;
Johan Jonker
Kever Yang
