[U-Boot] [PATCH] fsl-ifc-nand : Corrected the programming of chip select
Corrected the chip selection in IFC_NAND_CSEL register. Due to this issue in multi-chip nand use-case, IFC was always pointing to the last probed chip even though the user select another device through "nand device" command.
Signed-off-by: Ronak Desai ronak.desai@rockwellcollins.com Signed-off-by: Matthew Weber matthew.weber@rockwellcollins.com --- drivers/mtd/nand/fsl_ifc_nand.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/fsl_ifc_nand.c b/drivers/mtd/nand/fsl_ifc_nand.c index 7001cbd..2ce4a7d 100644 --- a/drivers/mtd/nand/fsl_ifc_nand.c +++ b/drivers/mtd/nand/fsl_ifc_nand.c @@ -296,7 +296,7 @@ static int fsl_ifc_run_command(struct mtd_info *mtd) int i;
/* set the chip select for NAND Transaction */ - ifc_out32(&ifc->ifc_nand.nand_csel, ifc_ctrl->cs_nand); + ifc_out32(&ifc->ifc_nand.nand_csel, priv->bank << IFC_NAND_CSEL_SHIFT);
/* start read/write seq */ ifc_out32(&ifc->ifc_nand.nandseq_strt,
Ouch. fsl_ifc_sram_init() should also be updated and cs_nand removed.
-Scott
We don't need to update fsl_ifc_sram_init() as fsl_ifc_sram_init is called from the fsl_ifc_chip_init which configures the ifc_ctrl->cs_nand with correct value based on the chip-select under initialization.
Best Regards, Ronak Desai
nand.c
-Scott
We don't *need* to but we should. Chipselect is a property of the chip, not the controller, so it doesn't belong in the controller struct (unless it's going to be updated per-transaction like page, column, etc. but we already have priv->bank so let's just use it).
-Scott
Matt Weber
Ronak Desai
Scott Wood
