[U-Boot] [PATCH] video: Fix splash screen alignment
commit d484b52 "video: Skip bitmaps which do not fit into the screen in cfb_console" breaks splash screen alignment which is passed in as magic (BMP_ALIGN_CENTER) x/y coordinates. Moving the check after the alignment block fixes this.
Signed-off-by: Matthias Weisser weisserm@arcor.de --- drivers/video/cfb_console.c | 14 +++++++------- 1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 26f673a..61e1058 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -1515,13 +1515,6 @@ int video_display_bitmap(ulong bmp_image, int x, int y)
padded_line = (((width * bpp + 7) / 8) + 3) & ~0x3;
- /* - * Just ignore elements which are completely beyond screen - * dimensions. - */ - if ((x >= VIDEO_VISIBLE_COLS) || (y >= VIDEO_VISIBLE_ROWS)) - return 0; - #ifdef CONFIG_SPLASH_SCREEN_ALIGN if (x == BMP_ALIGN_CENTER) x = max(0, (VIDEO_VISIBLE_COLS - width) / 2); @@ -1534,6 +1527,13 @@ int video_display_bitmap(ulong bmp_image, int x, int y) y = max(0, VIDEO_VISIBLE_ROWS - height + y + 1); #endif /* CONFIG_SPLASH_SCREEN_ALIGN */
+ /* + * Just ignore elements which are completely beyond screen + * dimensions. + */ + if ((x >= VIDEO_VISIBLE_COLS) || (y >= VIDEO_VISIBLE_ROWS)) + return 0; + if ((x + width) > VIDEO_VISIBLE_COLS) width = VIDEO_VISIBLE_COLS - x; if ((y + height) > VIDEO_VISIBLE_ROWS)
* dimensions.
* dimensions.
-- 1.7.9.5
Hello,
applied, thanks!
Anatolij
Anatolij Gustschin
Matthias Weisser
