[U-Boot] [PATCH v2] ARM: OMAP: Convert IO macros
Convert IO macros to readx/writex.
Signed-off-by: Dirk Behme dirk.behme@gmail.com
Changes in v2:
- Do only IO macro conversion, don't mix with coding style.
v2 version of this patch previous patch v1 obsolete.
Note: Patch is against U-Boot master commit 1378174a1351c0285736863a665ab758fe8d5f71 "Merge branch 'master' of /home/wd/git/u-boot/custodians"
--- drivers/i2c/omap24xx_i2c.c | 131 +++++++++++++++++++++------------------------ 1 files changed, 64 insertions(+), 67 deletions(-)
Index: u-boot-main/drivers/i2c/omap24xx_i2c.c =================================================================== --- u-boot-main.orig/drivers/i2c/omap24xx_i2c.c +++ u-boot-main/drivers/i2c/omap24xx_i2c.c @@ -25,9 +25,6 @@ #include <asm/arch/i2c.h> #include <asm/io.h>
-#define inw(a) __raw_readw(a) -#define outw(a,v) __raw_writew(a,v) - static void wait_for_bb (void); static u16 wait_for_pin (void); static void flush_fifo(void); @@ -36,32 +33,32 @@ void i2c_init (int speed, int slaveadd) { u16 scl;
- outw(0x2, I2C_SYSC); /* for ES2 after soft reset */ + writew(0x2, I2C_SYSC); /* for ES2 after soft reset */ udelay(1000); - outw(0x0, I2C_SYSC); /* will probably self clear but */ + writew(0x0, I2C_SYSC); /* will probably self clear but */
- if (inw (I2C_CON) & I2C_CON_EN) { - outw (0, I2C_CON); + if (readw (I2C_CON) & I2C_CON_EN) { + writew (0, I2C_CON); udelay (50000); }
/* 12MHz I2C module clock */ - outw (0, I2C_PSC); + writew (0, I2C_PSC); speed = speed/1000; /* 100 or 400 */ scl = ((12000/(speed*2)) - 7); /* use 7 when PSC = 0 */ - outw (scl, I2C_SCLL); - outw (scl, I2C_SCLH); + writew (scl, I2C_SCLL); + writew (scl, I2C_SCLH); /* own address */ - outw (slaveadd, I2C_OA); - outw (I2C_CON_EN, I2C_CON); + writew (slaveadd, I2C_OA); + writew (I2C_CON_EN, I2C_CON);
/* have to enable intrrupts or OMAP i2c module doesn't work */ - outw (I2C_IE_XRDY_IE | I2C_IE_RRDY_IE | I2C_IE_ARDY_IE | - I2C_IE_NACK_IE | I2C_IE_AL_IE, I2C_IE); + writew (I2C_IE_XRDY_IE | I2C_IE_RRDY_IE | I2C_IE_ARDY_IE | + I2C_IE_NACK_IE | I2C_IE_AL_IE, I2C_IE); udelay (1000); flush_fifo(); - outw (0xFFFF, I2C_STAT); - outw (0, I2C_CNT); + writew (0xFFFF, I2C_STAT); + writew (0, I2C_CNT); }
static int i2c_read_byte (u8 devaddr, u8 regoffset, u8 * value) @@ -73,19 +70,19 @@ static int i2c_read_byte (u8 devaddr, u8 wait_for_bb ();
/* one byte only */ - outw (1, I2C_CNT); + writew (1, I2C_CNT); /* set slave address */ - outw (devaddr, I2C_SA); + writew (devaddr, I2C_SA); /* no stop bit needed here */ - outw (I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_TRX, I2C_CON); + writew (I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_TRX, I2C_CON);
status = wait_for_pin ();
if (status & I2C_STAT_XRDY) { /* Important: have to use byte access */ - *(volatile u8 *) (I2C_DATA) = regoffset; + writeb (regoffset, I2C_DATA); udelay (20000); - if (inw (I2C_STAT) & I2C_STAT_NACK) { + if (readw (I2C_STAT) & I2C_STAT_NACK) { i2c_error = 1; } } else { @@ -94,42 +91,42 @@ static int i2c_read_byte (u8 devaddr, u8
if (!i2c_error) { /* free bus, otherwise we can't use a combined transction */ - outw (0, I2C_CON); - while (inw (I2C_STAT) || (inw (I2C_CON) & I2C_CON_MST)) { + writew (0, I2C_CON); + while (readw (I2C_STAT) || (readw (I2C_CON) & I2C_CON_MST)) { udelay (10000); /* Have to clear pending interrupt to clear I2C_STAT */ - outw (0xFFFF, I2C_STAT); + writew (0xFFFF, I2C_STAT); }
wait_for_bb (); /* set slave address */ - outw (devaddr, I2C_SA); + writew (devaddr, I2C_SA); /* read one byte from slave */ - outw (1, I2C_CNT); + writew (1, I2C_CNT); /* need stop bit here */ - outw (I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_STP, - I2C_CON); + writew (I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_STP, + I2C_CON);
status = wait_for_pin (); if (status & I2C_STAT_RRDY) { - *value = inw (I2C_DATA); + *value = readw (I2C_DATA); udelay (20000); } else { i2c_error = 1; }
if (!i2c_error) { - outw (I2C_CON_EN, I2C_CON); - while (inw (I2C_STAT) - || (inw (I2C_CON) & I2C_CON_MST)) { + writew (I2C_CON_EN, I2C_CON); + while (readw (I2C_STAT) + || (readw (I2C_CON) & I2C_CON_MST)) { udelay (10000); - outw (0xFFFF, I2C_STAT); + writew (0xFFFF, I2C_STAT); } } } flush_fifo(); - outw (0xFFFF, I2C_STAT); - outw (0, I2C_CNT); + writew (0xFFFF, I2C_STAT); + writew (0, I2C_CNT); return i2c_error; }
@@ -142,22 +139,22 @@ static int i2c_write_byte (u8 devaddr, u wait_for_bb ();
/* two bytes */ - outw (2, I2C_CNT); + writew (2, I2C_CNT); /* set slave address */ - outw (devaddr, I2C_SA); + writew (devaddr, I2C_SA); /* stop bit needed here */ - outw (I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_TRX | - I2C_CON_STP, I2C_CON); + writew (I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_TRX | + I2C_CON_STP, I2C_CON);
/* wait until state change */ status = wait_for_pin ();
if (status & I2C_STAT_XRDY) { /* send out two bytes */ - outw ((value << 8) + regoffset, I2C_DATA); + writew ((value << 8) + regoffset, I2C_DATA); /* must have enough delay to allow BB bit to go low */ udelay (50000); - if (inw (I2C_STAT) & I2C_STAT_NACK) { + if (readw (I2C_STAT) & I2C_STAT_NACK) { i2c_error = 1; } } else { @@ -167,18 +164,18 @@ static int i2c_write_byte (u8 devaddr, u if (!i2c_error) { int eout = 200;
- outw (I2C_CON_EN, I2C_CON); - while ((stat = inw (I2C_STAT)) || (inw (I2C_CON) & I2C_CON_MST)) { + writew (I2C_CON_EN, I2C_CON); + while ((stat = readw (I2C_STAT)) || (readw (I2C_CON) & I2C_CON_MST)) { udelay (1000); /* have to read to clear intrrupt */ - outw (0xFFFF, I2C_STAT); + writew (0xFFFF, I2C_STAT); if(--eout == 0) /* better leave with error than hang */ break; } } flush_fifo(); - outw (0xFFFF, I2C_STAT); - outw (0, I2C_CNT); + writew (0xFFFF, I2C_STAT); + writew (0, I2C_CNT); return i2c_error; }
@@ -189,10 +186,10 @@ static void flush_fifo(void) * you get a bus error */ while(1){ - stat = inw(I2C_STAT); + stat = readw(I2C_STAT); if(stat == I2C_STAT_RRDY){ - inw(I2C_DATA); - outw(I2C_STAT_RRDY,I2C_STAT); + readw(I2C_DATA); + writew(I2C_STAT_RRDY,I2C_STAT); udelay(1000); }else break; @@ -203,7 +200,7 @@ int i2c_probe (uchar chip) { int res = 1; /* default = fail */
- if (chip == inw (I2C_OA)) { + if (chip == readw (I2C_OA)) { return res; }
@@ -211,27 +208,27 @@ int i2c_probe (uchar chip) wait_for_bb ();
/* try to read one byte */ - outw (1, I2C_CNT); + writew (1, I2C_CNT); /* set slave address */ - outw (chip, I2C_SA); + writew (chip, I2C_SA); /* stop bit needed here */ - outw (I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_STP, I2C_CON); + writew (I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_STP, I2C_CON); /* enough delay for the NACK bit set */ udelay (50000);
- if (!(inw (I2C_STAT) & I2C_STAT_NACK)) { + if (!(readw (I2C_STAT) & I2C_STAT_NACK)) { res = 0; /* success case */ flush_fifo(); - outw(0xFFFF, I2C_STAT); + writew(0xFFFF, I2C_STAT); } else { - outw(0xFFFF, I2C_STAT); /* failue, clear sources*/ - outw (inw (I2C_CON) | I2C_CON_STP, I2C_CON); /* finish up xfer */ + writew(0xFFFF, I2C_STAT); /* failue, clear sources*/ + writew (readw (I2C_CON) | I2C_CON_STP, I2C_CON); /* finish up xfer */ udelay(20000); wait_for_bb (); } flush_fifo(); - outw (0, I2C_CNT); /* don't allow any more data in...we don't want it.*/ - outw(0xFFFF, I2C_STAT); + writew (0, I2C_CNT); /* don't allow any more data in...we don't want it.*/ + writew(0xFFFF, I2C_STAT); return res; }
@@ -290,17 +287,17 @@ static void wait_for_bb (void) int timeout = 10; u16 stat;
- outw(0xFFFF, I2C_STAT); /* clear current interruts...*/ - while ((stat = inw (I2C_STAT) & I2C_STAT_BB) && timeout--) { - outw (stat, I2C_STAT); + writew(0xFFFF, I2C_STAT); /* clear current interruts...*/ + while ((stat = readw (I2C_STAT) & I2C_STAT_BB) && timeout--) { + writew (stat, I2C_STAT); udelay (50000); }
if (timeout <= 0) { printf ("timed out in wait_for_bb: I2C_STAT=%x\n", - inw (I2C_STAT)); + readw (I2C_STAT)); } - outw(0xFFFF, I2C_STAT); /* clear delayed stuff*/ + writew(0xFFFF, I2C_STAT); /* clear delayed stuff*/ }
static u16 wait_for_pin (void) @@ -310,7 +307,7 @@ static u16 wait_for_pin (void)
do { udelay (1000); - status = inw (I2C_STAT); + status = readw (I2C_STAT); } while ( !(status & (I2C_STAT_ROVR | I2C_STAT_XUDF | I2C_STAT_XRDY | I2C_STAT_RRDY | I2C_STAT_ARDY | I2C_STAT_NACK | @@ -318,8 +315,8 @@ static u16 wait_for_pin (void)
if (timeout <= 0) { printf ("timed out in wait_for_pin: I2C_STAT=%x\n", - inw (I2C_STAT)); - outw(0xFFFF, I2C_STAT); + readw (I2C_STAT)); + writew(0xFFFF, I2C_STAT); } return status; }
dirk.behmeï¼ googlemail.com
