[U-Boot] [PATCH] mx25pdk: Align the environment with other FSL boards
Allow the boot of a device tree mainline kernel by aligning the environment variables with other FSL boards.
Tested NFS boot of a dt 3.14-rc5 kernel.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- include/configs/mx25pdk.h | 103 +++++++++++++++++++++++++++++++++++++++++++--- 1 file changed, 98 insertions(+), 5 deletions(-)
diff --git a/include/configs/mx25pdk.h b/include/configs/mx25pdk.h index af6aafa..aff2419 100644 --- a/include/configs/mx25pdk.h +++ b/include/configs/mx25pdk.h @@ -62,6 +62,7 @@ /* No NOR flash present */ #define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_ENV_SIZE (8 * 1024) +#define CONFIG_SYS_MMC_ENV_DEV 0
#define CONFIG_SYS_NO_FLASH #define CONFIG_ENV_IS_IN_MMC @@ -69,7 +70,7 @@
/* U-Boot general configuration */ #define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ /* Print buffer sz */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16) @@ -132,12 +133,104 @@ #define CONFIG_LOADADDR 0x81000000 /* loadaddr env var */ #define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR
+#define CONFIG_DEFAULT_FDT_FILE "imx25-pdk.dtb" + #define CONFIG_EXTRA_ENV_SETTINGS \ "script=boot.scr\0" \ - "uimage=uImage\0" \ - "netargs=setenv bootargs console=ttymxc0,${baudrate} " \ + "image=zImage\0" \ + "console=ttymxc0\0" \ + "splashpos=m,m\0" \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "fdt_addr=0x82000000\0" \ + "boot_fdt=try\0" \ + "ip_dyn=yes\0" \ + "mmcdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \ + "mmcpart=1\0" \ + "mmcroot=/dev/mmcblk0p2 rootwait rw\0" \ + "update_sd_firmware_filename=u-boot.imx\0" \ + "update_sd_firmware=" \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "if mmc dev ${mmcdev}; then " \ + "if ${get_cmd} ${update_sd_firmware_filename}; then " \ + "setexpr fw_sz ${filesize} / 0x200; " \ + "setexpr fw_sz ${fw_sz} + 1; " \ + "mmc write ${loadaddr} 0x2 ${fw_sz}; " \ + "fi; " \ + "fi\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} " \ + "root=${mmcroot}\0" \ + "loadbootscript=" \ + "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "bootz ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootz; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootz; " \ + "fi;\0" \ + "netargs=setenv bootargs console=${console},${baudrate} " \ "root=/dev/nfs " \ - "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ - "bootcmd=run netargs; dhcp ${uimage}; bootm\0" \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${image}; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "bootz ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootz; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootz; " \ + "fi;\0" + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loadimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "else run netboot; fi" + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_AUTO_COMPLETE + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
#endif /* __CONFIG_H */
Awesome!
Acked-by: Otavio Salvador otavio@ossystems.com.br
Hi Fabio,
- "image=zImage\0" \
- "console=ttymxc0\0" \
- "splashpos=m,m\0" \
- "fdt_high=0xffffffff\0" \
- "initrd_high=0xffffffff\0" \
- "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \
- "fdt_addr=0x82000000\0" \
- "boot_fdt=try\0" \
- "ip_dyn=yes\0" \
- "mmcdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \
- "mmcpart=1\0" \
- "mmcroot=/dev/mmcblk0p2 rootwait rw\0" \
- "update_sd_firmware_filename=u-boot.imx\0" \
- "update_sd_firmware=" \
"else " \
"fi; " \
"fi; " \
"fi\0" \
- "mmcargs=setenv bootargs console=${console},${baudrate} " \
- "loadbootscript=" \
- "bootscript=echo Running bootscript from mmc ...; " \
"source\0" \
- "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \
- "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \
- "mmcboot=echo Booting from mmc ...; " \
"run mmcargs; " \
"else " \
"bootz; " \
"else " \
"fi; " \
"fi; " \
"else " \
"bootz; " \
"fi;\0" \
- "netargs=setenv bootargs console=${console},${baudrate} " \ "root=/dev/nfs " \
"run netargs; " \
"else " \
"fi; " \
"else " \
"bootz; " \
"else " \
"fi; " \
"fi; " \
"else " \
"bootz; " \
"fi;\0"
"else " \
"run mmcboot; " \
"fi; " \
"fi; " \
Agree. It would be easier to have later a common code for the environment if all boards share the same default.
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Fabio Estevam
Otavio Salvador
Stefano Babic
