[U-Boot] [PATCH 0/2] xtensa: clean up SYS_MONITOR_LEN/SYS_TEXT_ADDR
Hello,
this series moves SYS_MONITOR_LEN to Kconfig for board/cadence/xtfpga, removes SYS_MEMORY_TOP and renames CONFIG_SYS_TEXT_ADDR to XTENSA_SYS_TEXT_ADDR.
Max Filippov (2): board/cadence/xtfpga: move SYS_MONITOR_LEN to Kconfig xtensa: clean up CONFIG_SYS_TEXT_ADDR
arch/xtensa/cpu/start.S | 2 +- arch/xtensa/cpu/u-boot.lds | 4 ++-- board/cadence/xtfpga/Kconfig | 5 +++++ include/configs/xtfpga.h | 12 ++---------- 4 files changed, 10 insertions(+), 13 deletions(-)
Signed-off-by: Max Filippov jcmvbkbc@gmail.com --- board/cadence/xtfpga/Kconfig | 5 +++++ include/configs/xtfpga.h | 7 ------- 2 files changed, 5 insertions(+), 7 deletions(-)
diff --git a/board/cadence/xtfpga/Kconfig b/board/cadence/xtfpga/Kconfig index 69296be49c7a..67ae3860b6d4 100644 --- a/board/cadence/xtfpga/Kconfig +++ b/board/cadence/xtfpga/Kconfig @@ -36,4 +36,9 @@ config BOARD_SDRAM_SIZE default 0x18000000 if XTFPGA_ML605 default 0x38000000 if XTFPGA_KC705
+config SYS_MONITOR_LEN + hex + default 0x00020000 if XTFPGA_LX60 + default 0x00040000 if !XTFPGA_LX60 + endif diff --git a/include/configs/xtfpga.h b/include/configs/xtfpga.h index 79cc1e8fc1b8..86c7e7cf279c 100644 --- a/include/configs/xtfpga.h +++ b/include/configs/xtfpga.h @@ -59,13 +59,6 @@
#define CONFIG_SYS_SDRAM_BASE MEMADDR(0x00000000)
-/* Lx60 can only map 128kb memory (instead of 256kb) when running under OCD */ -#ifdef CONFIG_XTFPGA_LX60 -# define CONFIG_SYS_MONITOR_LEN 0x00020000 /* 128KB */ -#else -# define CONFIG_SYS_MONITOR_LEN 0x00040000 /* 256KB */ -#endif - #define CONFIG_SYS_MALLOC_LEN (256 << 10) /* heap 256KB */
/* Linux boot param area in RAM (used only when booting linux) */
- hex
- default 0x00020000 if XTFPGA_LX60
- default 0x00040000 if !XTFPGA_LX60
We need to migrate everyone, not just xtensa. This might be a tad tricky, so I'll put it on my plate. Thanks!
Drop CONFIG_SYS_MEMORY_TOP. Rename CONFIG_SYS_TEXT_ADDR to XTENSA_SYS_TEXT_ADDR.
Signed-off-by: Max Filippov jcmvbkbc@gmail.com --- arch/xtensa/cpu/start.S | 2 +- arch/xtensa/cpu/u-boot.lds | 4 ++-- include/configs/xtfpga.h | 5 ++--- 3 files changed, 5 insertions(+), 6 deletions(-)
diff --git a/arch/xtensa/cpu/start.S b/arch/xtensa/cpu/start.S index 8e4bc99e4295..cdb875da5339 100644 --- a/arch/xtensa/cpu/start.S +++ b/arch/xtensa/cpu/start.S @@ -226,7 +226,7 @@ _start: #endif
movi a0, 0 - movi sp, (CONFIG_SYS_TEXT_ADDR - 16) & 0xfffffff0 + movi sp, (XTENSA_SYS_TEXT_ADDR - 16) & 0xfffffff0
#ifdef CONFIG_DEBUG_UART movi a4, debug_uart_init diff --git a/arch/xtensa/cpu/u-boot.lds b/arch/xtensa/cpu/u-boot.lds index 853ae5a94891..7200bc59fbfc 100644 --- a/arch/xtensa/cpu/u-boot.lds +++ b/arch/xtensa/cpu/u-boot.lds @@ -74,9 +74,9 @@ SECTIONS SECTION_VECTOR(DoubleExceptionVector,text,XCHAL_DOUBLEEXC_VECTOR_VADDR, FOLLOWING(.DoubleExceptionVector.literal))
- __monitor_start = CONFIG_SYS_TEXT_ADDR; + __monitor_start = XTENSA_SYS_TEXT_ADDR;
- SECTION_text(CONFIG_SYS_TEXT_ADDR, FOLLOWING(.DoubleExceptionVector.text)) + SECTION_text(XTENSA_SYS_TEXT_ADDR, FOLLOWING(.DoubleExceptionVector.text)) SECTION_rodata(ALIGN(16), FOLLOWING(.text)) SECTION_u_boot_list(ALIGN(16), FOLLOWING(.rodata)) SECTION_data(ALIGN(16), FOLLOWING(.u_boot_list)) diff --git a/include/configs/xtfpga.h b/include/configs/xtfpga.h index 86c7e7cf279c..d0b3b34571d2 100644 --- a/include/configs/xtfpga.h +++ b/include/configs/xtfpga.h @@ -91,9 +91,8 @@ #define CONFIG_SYS_MEMORY_SIZE CONFIG_SYS_SDRAM_SIZE #endif
-#define CONFIG_SYS_MEMORY_TOP MEMADDR(CONFIG_SYS_MEMORY_SIZE) -#define CONFIG_SYS_TEXT_ADDR \ - (CONFIG_SYS_MEMORY_TOP - CONFIG_SYS_MONITOR_LEN) +#define XTENSA_SYS_TEXT_ADDR \ + (MEMADDR(CONFIG_SYS_MEMORY_SIZE) - CONFIG_SYS_MONITOR_LEN)
/* Used by tftpboot; env var 'loadaddr' */ #define CONFIG_SYS_LOAD_ADDR MEMADDR(0x02000000)
Max Filippov
