[U-Boot] [PATCH] powerpc/t4240qds: fix offset of serdes when checking its' reference clock
T4240 has 4 serdes, each serdes has 4k memory space, two PLLs. We use PLL1CR0 to check the serdes reference clock.
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com --- arch/powerpc/include/asm/immap_85xx.h | 6 ++++++ board/freescale/t4qds/t4240qds.c | 10 ++++++---- 2 files changed, 12 insertions(+), 4 deletions(-)
diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 8258ab3..dfb370e 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -2905,6 +2905,8 @@ struct ccsr_sfp_regs { #endif #define CONFIG_SYS_FSL_CORENET_SERDES_OFFSET 0xEA000 #define CONFIG_SYS_FSL_CORENET_SERDES2_OFFSET 0xEB000 +#define CONFIG_SYS_FSL_CORENET_SERDES3_OFFSET 0xEC000 +#define CONFIG_SYS_FSL_CORENET_SERDES4_OFFSET 0xED000 #define CONFIG_SYS_FSL_CPC_OFFSET 0x10000 #define CONFIG_SYS_FSL_SCFG_OFFSET 0xFC000 #define CONFIG_SYS_MPC85xx_DMA1_OFFSET 0x100000 @@ -3090,6 +3092,10 @@ struct ccsr_sfp_regs { (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CORENET_SERDES_OFFSET) #define CONFIG_SYS_FSL_CORENET_SERDES2_ADDR \ (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CORENET_SERDES2_OFFSET) +#define CONFIG_SYS_FSL_CORENET_SERDES3_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CORENET_SERDES3_OFFSET) +#define CONFIG_SYS_FSL_CORENET_SERDES4_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CORENET_SERDES4_OFFSET) #define CONFIG_SYS_MPC85xx_USB1_ADDR \ (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_USB1_OFFSET) #define CONFIG_SYS_MPC85xx_USB2_ADDR \ diff --git a/board/freescale/t4qds/t4240qds.c b/board/freescale/t4qds/t4240qds.c index fe1bc7f..cbe62c1 100644 --- a/board/freescale/t4qds/t4240qds.c +++ b/board/freescale/t4qds/t4240qds.c @@ -638,9 +638,10 @@ unsigned long get_board_ddr_clk(void) int misc_init_r(void) { u8 sw; - serdes_corenet_t *srds_regs = - (void *)CONFIG_SYS_FSL_CORENET_SERDES_ADDR; + void *srds_base = (void *)CONFIG_SYS_FSL_CORENET_SERDES_ADDR; + serdes_corenet_t *srds_regs; u32 actual[MAX_SERDES]; + u32 pllcr0, expected; unsigned int i;
sw = QIXIS_READ(brdcfg[2]); @@ -663,8 +664,9 @@ int misc_init_r(void) }
for (i = 0; i < MAX_SERDES; i++) { - u32 pllcr0 = srds_regs->bank[i].pllcr0; - u32 expected = pllcr0 & SRDS_PLLCR0_RFCK_SEL_MASK; + srds_regs = srds_base + i * 0x1000; + pllcr0 = srds_regs->bank[0].pllcr0; + expected = pllcr0 & SRDS_PLLCR0_RFCK_SEL_MASK; if (expected != actual[i]) { printf("Warning: SERDES%u expects reference clock %sMHz, but actual is %sMHz\n", i + 1, serdes_clock_to_string(expected),
shh.xie@gmail.com
