[PATCH 10/14] ti: Drop panda board
DM, DM_SPI and other driver model migration deadlines are expired for this board.
Drop it.
Cc: Lokesh Vutla lokeshvutla@ti.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/mach-omap2/omap4/Kconfig | 4 - board/ti/panda/Kconfig | 12 -- board/ti/panda/MAINTAINERS | 6 - board/ti/panda/Makefile | 6 - board/ti/panda/panda.c | 346 ------------------------------ board/ti/panda/panda_mux_data.h | 86 -------- configs/omap4_panda_defconfig | 42 ---- include/configs/omap4_panda.h | 34 --- 8 files changed, 536 deletions(-) delete mode 100644 board/ti/panda/Kconfig delete mode 100644 board/ti/panda/MAINTAINERS delete mode 100644 board/ti/panda/Makefile delete mode 100644 board/ti/panda/panda.c delete mode 100644 board/ti/panda/panda_mux_data.h delete mode 100644 configs/omap4_panda_defconfig delete mode 100644 include/configs/omap4_panda.h
diff --git a/arch/arm/mach-omap2/omap4/Kconfig b/arch/arm/mach-omap2/omap4/Kconfig index 899289b645..4cc360f38a 100644 --- a/arch/arm/mach-omap2/omap4/Kconfig +++ b/arch/arm/mach-omap2/omap4/Kconfig @@ -4,9 +4,6 @@ choice prompt "OMAP4 board select" optional
-config TARGET_OMAP4_PANDA - bool "TI OMAP4 PandaBoard" - config TARGET_OMAP4_SDP4430 bool "TI OMAP4 SDP4430"
@@ -18,7 +15,6 @@ endchoice config SYS_SOC default "omap4"
-source "board/ti/panda/Kconfig" source "board/ti/sdp4430/Kconfig" source "board/amazon/kc1/Kconfig"
diff --git a/board/ti/panda/Kconfig b/board/ti/panda/Kconfig deleted file mode 100644 index 8f277b612a..0000000000 --- a/board/ti/panda/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_OMAP4_PANDA - -config SYS_BOARD - default "panda" - -config SYS_VENDOR - default "ti" - -config SYS_CONFIG_NAME - default "omap4_panda" - -endif diff --git a/board/ti/panda/MAINTAINERS b/board/ti/panda/MAINTAINERS deleted file mode 100644 index 2142368271..0000000000 --- a/board/ti/panda/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -PANDA BOARD -M: Lokesh Vutla lokeshvutla@ti.com -S: Maintained -F: board/ti/panda/ -F: include/configs/omap4_panda.h -F: configs/omap4_panda_defconfig diff --git a/board/ti/panda/Makefile b/board/ti/panda/Makefile deleted file mode 100644 index dd2ff33afa..0000000000 --- a/board/ti/panda/Makefile +++ /dev/null @@ -1,6 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# (C) Copyright 2000, 2001, 2002 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. - -obj-y := panda.o diff --git a/board/ti/panda/panda.c b/board/ti/panda/panda.c deleted file mode 100644 index 9ebecfdbf5..0000000000 --- a/board/ti/panda/panda.c +++ /dev/null @@ -1,346 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2010 - * Texas Instruments Incorporated, <www.ti.com> - * Steve Sakoman steve@sakoman.com - */ -#include <common.h> -#include <init.h> -#include <log.h> -#include <net.h> -#include <asm/mach-types.h> -#include <asm/arch/sys_proto.h> -#include <asm/arch/mmc_host_def.h> -#include <asm/arch/clock.h> -#include <asm/arch/gpio.h> -#include <asm/gpio.h> -#include <env.h> -#include <twl6030.h> - -#include "panda_mux_data.h" - -#ifdef CONFIG_USB_EHCI_HCD -#include <usb.h> -#include <asm/arch/ehci.h> -#include <asm/ehci-omap.h> -#endif - -#define PANDA_ULPI_PHY_TYPE_GPIO 182 -#define PANDA_BOARD_ID_1_GPIO 101 -#define PANDA_ES_BOARD_ID_1_GPIO 48 -#define PANDA_BOARD_ID_2_GPIO 171 -#define PANDA_ES_BOARD_ID_3_GPIO 3 -#define PANDA_ES_BOARD_ID_4_GPIO 2 - -DECLARE_GLOBAL_DATA_PTR; - -const struct omap_sysinfo sysinfo = { - "Board: OMAP4 Panda\n" -}; - -struct omap4_scrm_regs *const scrm = (struct omap4_scrm_regs *)0x4a30a000; - -/** - * @brief board_init - * - * @return 0 - */ -int board_init(void) -{ - gpmc_init(); - - gd->bd->bi_arch_number = MACH_TYPE_OMAP4_PANDA; - gd->bd->bi_boot_params = (0x80000000 + 0x100); /* boot param addr */ - - return 0; -} - -int board_eth_init(bd_t *bis) -{ - return 0; -} - -/* -* Routine: get_board_revision -* Description: Detect if we are running on a panda revision A1-A6, -* or an ES panda board. This can be done by reading -* the level of GPIOs and checking the processor revisions. -* This should result in: -* Panda 4430: -* GPIO171, GPIO101, GPIO182: 0 1 1 => A1-A5 -* GPIO171, GPIO101, GPIO182: 1 0 1 => A6 -* Panda ES: -* GPIO2, GPIO3, GPIO171, GPIO48, GPIO182: 0 0 0 1 1 => B1/B2 -* GPIO2, GPIO3, GPIO171, GPIO48, GPIO182: 0 0 1 1 1 => B3 -*/ -int get_board_revision(void) -{ - int board_id0, board_id1, board_id2; - int board_id3, board_id4; - int board_id; - - int processor_rev = omap_revision(); - - /* Setup the mux for the common board ID pins (gpio 171 and 182) */ - writew((IEN | M3), (*ctrl)->control_padconf_core_base + UNIPRO_TX0); - writew((IEN | M3), (*ctrl)->control_padconf_core_base + FREF_CLK2_OUT); - - board_id0 = gpio_get_value(PANDA_ULPI_PHY_TYPE_GPIO); - board_id2 = gpio_get_value(PANDA_BOARD_ID_2_GPIO); - - if ((processor_rev >= OMAP4460_ES1_0 && - processor_rev <= OMAP4460_ES1_1)) { - /* - * Setup the mux for the ES specific board ID pins (gpio 101, - * 2 and 3. - */ - writew((IEN | M3), (*ctrl)->control_padconf_core_base + - GPMC_A24); - writew((IEN | M3), (*ctrl)->control_padconf_core_base + - UNIPRO_RY0); - writew((IEN | M3), (*ctrl)->control_padconf_core_base + - UNIPRO_RX1); - - board_id1 = gpio_get_value(PANDA_ES_BOARD_ID_1_GPIO); - board_id3 = gpio_get_value(PANDA_ES_BOARD_ID_3_GPIO); - board_id4 = gpio_get_value(PANDA_ES_BOARD_ID_4_GPIO); - -#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - env_set("board_name", "panda-es"); -#endif - board_id = ((board_id4 << 4) | (board_id3 << 3) | - (board_id2 << 2) | (board_id1 << 1) | (board_id0)); - } else { - /* Setup the mux for the Ax specific board ID pins (gpio 101) */ - writew((IEN | M3), (*ctrl)->control_padconf_core_base + - FREF_CLK2_OUT); - - board_id1 = gpio_get_value(PANDA_BOARD_ID_1_GPIO); - board_id = ((board_id2 << 2) | (board_id1 << 1) | (board_id0)); - -#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - if ((board_id >= 0x3) && (processor_rev == OMAP4430_ES2_3)) - env_set("board_name", "panda-a4"); -#endif - } - - return board_id; -} - -/** - * is_panda_es_rev_b3() - Detect if we are running on rev B3 of panda board ES - * - * - * Detect if we are running on B3 version of ES panda board, - * This can be done by reading the level of GPIO 171 and checking the - * processor revisions. - * GPIO171: 1 => Panda ES Rev B3 - * - * Return : return 1 if Panda ES Rev B3 , else return 0 - */ -u8 is_panda_es_rev_b3(void) -{ - int processor_rev = omap_revision(); - int ret = 0; - - if ((processor_rev >= OMAP4460_ES1_0 && - processor_rev <= OMAP4460_ES1_1)) { - - /* Setup the mux for the common board ID pins (gpio 171) */ - writew((IEN | M3), - (*ctrl)->control_padconf_core_base + UNIPRO_TX0); - - /* if processor_rev is panda ES and GPIO171 is 1,it is rev b3 */ - ret = gpio_get_value(PANDA_BOARD_ID_2_GPIO); - } - return ret; -} - -#ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS -/* - * emif_get_reg_dump() - emif_get_reg_dump strong function - * - * @emif_nr - emif base - * @regs - reg dump of timing values - * - * Strong function to override emif_get_reg_dump weak function in sdram_elpida.c - */ -void emif_get_reg_dump(u32 emif_nr, const struct emif_regs **regs) -{ - u32 omap4_rev = omap_revision(); - - /* Same devices and geometry on both EMIFs */ - if (omap4_rev == OMAP4430_ES1_0) - *regs = &emif_regs_elpida_380_mhz_1cs; - else if (omap4_rev == OMAP4430_ES2_0) - *regs = &emif_regs_elpida_200_mhz_2cs; - else if (omap4_rev == OMAP4430_ES2_3) - *regs = &emif_regs_elpida_400_mhz_1cs; - else if (omap4_rev < OMAP4470_ES1_0) { - if(is_panda_es_rev_b3()) - *regs = &emif_regs_elpida_400_mhz_1cs; - else - *regs = &emif_regs_elpida_400_mhz_2cs; - } - else - *regs = &emif_regs_elpida_400_mhz_1cs; -} - -void emif_get_dmm_regs(const struct dmm_lisa_map_regs - **dmm_lisa_regs) -{ - u32 omap_rev = omap_revision(); - - if (omap_rev == OMAP4430_ES1_0) - *dmm_lisa_regs = &lisa_map_2G_x_1_x_2; - else if (omap_rev == OMAP4430_ES2_3) - *dmm_lisa_regs = &lisa_map_2G_x_2_x_2; - else if (omap_rev < OMAP4460_ES1_0) - *dmm_lisa_regs = &lisa_map_2G_x_2_x_2; - else - *dmm_lisa_regs = &ma_lisa_map_2G_x_2_x_2; -} - -#endif - -/** - * @brief misc_init_r - Configure Panda board specific configurations - * such as power configurations, ethernet initialization as phase2 of - * boot sequence - * - * @return 0 - */ -int misc_init_r(void) -{ - int phy_type; - u32 auxclk, altclksrc; - - /* EHCI is not supported on ES1.0 */ - if (omap_revision() == OMAP4430_ES1_0) - return 0; - - get_board_revision(); - - gpio_direction_input(PANDA_ULPI_PHY_TYPE_GPIO); - phy_type = gpio_get_value(PANDA_ULPI_PHY_TYPE_GPIO); - - if (phy_type == 1) { - /* ULPI PHY supplied by auxclk3 derived from sys_clk */ - debug("ULPI PHY supplied by auxclk3\n"); - - auxclk = readl(&scrm->auxclk3); - /* Select sys_clk */ - auxclk &= ~AUXCLK_SRCSELECT_MASK; - auxclk |= AUXCLK_SRCSELECT_SYS_CLK << AUXCLK_SRCSELECT_SHIFT; - /* Set the divisor to 2 */ - auxclk &= ~AUXCLK_CLKDIV_MASK; - auxclk |= AUXCLK_CLKDIV_2 << AUXCLK_CLKDIV_SHIFT; - /* Request auxilary clock #3 */ - auxclk |= AUXCLK_ENABLE_MASK; - - writel(auxclk, &scrm->auxclk3); - } else { - /* ULPI PHY supplied by auxclk1 derived from PER dpll */ - debug("ULPI PHY supplied by auxclk1\n"); - - auxclk = readl(&scrm->auxclk1); - /* Select per DPLL */ - auxclk &= ~AUXCLK_SRCSELECT_MASK; - auxclk |= AUXCLK_SRCSELECT_PER_DPLL << AUXCLK_SRCSELECT_SHIFT; - /* Set the divisor to 16 */ - auxclk &= ~AUXCLK_CLKDIV_MASK; - auxclk |= AUXCLK_CLKDIV_16 << AUXCLK_CLKDIV_SHIFT; - /* Request auxilary clock #3 */ - auxclk |= AUXCLK_ENABLE_MASK; - - writel(auxclk, &scrm->auxclk1); - } - - altclksrc = readl(&scrm->altclksrc); - - /* Activate alternate system clock supplier */ - altclksrc &= ~ALTCLKSRC_MODE_MASK; - altclksrc |= ALTCLKSRC_MODE_ACTIVE; - - /* enable clocks */ - altclksrc |= ALTCLKSRC_ENABLE_INT_MASK | ALTCLKSRC_ENABLE_EXT_MASK; - - writel(altclksrc, &scrm->altclksrc); - - omap_die_id_usbethaddr(); - - return 0; -} - -void set_muxconf_regs(void) -{ - do_set_mux((*ctrl)->control_padconf_core_base, - core_padconf_array_essential, - sizeof(core_padconf_array_essential) / - sizeof(struct pad_conf_entry)); - - do_set_mux((*ctrl)->control_padconf_wkup_base, - wkup_padconf_array_essential, - sizeof(wkup_padconf_array_essential) / - sizeof(struct pad_conf_entry)); - - if (omap_revision() >= OMAP4460_ES1_0) - do_set_mux((*ctrl)->control_padconf_wkup_base, - wkup_padconf_array_essential_4460, - sizeof(wkup_padconf_array_essential_4460) / - sizeof(struct pad_conf_entry)); -} - -#if defined(CONFIG_MMC) -int board_mmc_init(bd_t *bis) -{ - return omap_mmc_init(0, 0, 0, -1, -1); -} - -#if !defined(CONFIG_SPL_BUILD) -void board_mmc_power_init(void) -{ - twl6030_power_mmc_init(0); -} -#endif -#endif - -#ifdef CONFIG_USB_EHCI_HCD - -static struct omap_usbhs_board_data usbhs_bdata = { - .port_mode[0] = OMAP_EHCI_PORT_MODE_PHY, - .port_mode[1] = OMAP_USBHS_PORT_MODE_UNUSED, - .port_mode[2] = OMAP_USBHS_PORT_MODE_UNUSED, -}; - -int ehci_hcd_init(int index, enum usb_init_type init, - struct ehci_hccr **hccr, struct ehci_hcor **hcor) -{ - int ret; - unsigned int utmi_clk; - - /* Now we can enable our port clocks */ - utmi_clk = readl((void *)CM_L3INIT_HSUSBHOST_CLKCTRL); - utmi_clk |= HSUSBHOST_CLKCTRL_CLKSEL_UTMI_P1_MASK; - setbits_le32((void *)CM_L3INIT_HSUSBHOST_CLKCTRL, utmi_clk); - - ret = omap_ehci_hcd_init(index, &usbhs_bdata, hccr, hcor); - if (ret < 0) - return ret; - - return 0; -} - -int ehci_hcd_stop(int index) -{ - return omap_ehci_hcd_stop(); -} -#endif - -/* - * get_board_rev() - get board revision - */ -u32 get_board_rev(void) -{ - return 0x20; -} diff --git a/board/ti/panda/panda_mux_data.h b/board/ti/panda/panda_mux_data.h deleted file mode 100644 index ad9e36525b..0000000000 --- a/board/ti/panda/panda_mux_data.h +++ /dev/null @@ -1,86 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2010 - * Texas Instruments Incorporated, <www.ti.com> - * - * Balaji Krishnamoorthy balajitk@ti.com - * Aneesh V aneesh@ti.com - */ -#ifndef _PANDA_MUX_DATA_H_ -#define _PANDA_MUX_DATA_H_ - -#include <asm/arch/mux_omap4.h> - - -const struct pad_conf_entry core_padconf_array_essential[] = { - -{GPMC_AD0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat0 */ -{GPMC_AD1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat1 */ -{GPMC_AD2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat2 */ -{GPMC_AD3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat3 */ -{GPMC_AD4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat4 */ -{GPMC_AD5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat5 */ -{GPMC_AD6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat6 */ -{GPMC_AD7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat7 */ -{GPMC_NOE, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M1)}, /* sdmmc2_clk */ -{GPMC_NWE, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_cmd */ -{SDMMC1_CLK, (PTU | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc1_clk */ -{SDMMC1_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_cmd */ -{SDMMC1_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat0 */ -{SDMMC1_DAT1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat1 */ -{SDMMC1_DAT2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat2 */ -{SDMMC1_DAT3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat3 */ -{SDMMC1_DAT4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat4 */ -{SDMMC1_DAT5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat5 */ -{SDMMC1_DAT6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat6 */ -{SDMMC1_DAT7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat7 */ -{I2C1_SCL, (PTU | IEN | M0)}, /* i2c1_scl */ -{I2C1_SDA, (PTU | IEN | M0)}, /* i2c1_sda */ -{I2C2_SCL, (PTU | IEN | M0)}, /* i2c2_scl */ -{I2C2_SDA, (PTU | IEN | M0)}, /* i2c2_sda */ -{I2C3_SCL, (PTU | IEN | M0)}, /* i2c3_scl */ -{I2C3_SDA, (PTU | IEN | M0)}, /* i2c3_sda */ -{I2C4_SCL, (PTU | IEN | M0)}, /* i2c4_scl */ -{I2C4_SDA, (PTU | IEN | M0)}, /* i2c4_sda */ -{UART3_CTS_RCTX, (PTU | IEN | M0)}, /* uart3_tx */ -{UART3_RTS_SD, (M0)}, /* uart3_rts_sd */ -{UART3_RX_IRRX, (IEN | M0)}, /* uart3_rx */ -{UART3_TX_IRTX, (M0)}, /* uart3_tx */ -{USBB1_ULPITLL_CLK, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M4)},/* usbb1_ulpiphy_clk */ -{USBB1_ULPITLL_STP, (OFF_EN | OFF_OUT_PTD | M4)}, /* usbb1_ulpiphy_stp */ -{USBB1_ULPITLL_DIR, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dir */ -{USBB1_ULPITLL_NXT, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_nxt */ -{USBB1_ULPITLL_DAT0, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat0 */ -{USBB1_ULPITLL_DAT1, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat1 */ -{USBB1_ULPITLL_DAT2, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat2 */ -{USBB1_ULPITLL_DAT3, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat3 */ -{USBB1_ULPITLL_DAT4, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat4 */ -{USBB1_ULPITLL_DAT5, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat5 */ -{USBB1_ULPITLL_DAT6, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat6 */ -{USBB1_ULPITLL_DAT7, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat7 */ -{USBB1_HSIC_DATA, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usbb1_hsic_data */ -{USBB1_HSIC_STROBE, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usbb1_hsic_strobe */ -{USBC1_ICUSB_DP, (IEN | M0)}, /* usbc1_icusb_dp */ -{USBC1_ICUSB_DM, (IEN | M0)}, /* usbc1_icusb_dm */ -{UNIPRO_TY2, (PTU | IEN | M3)}, /* gpio_1 */ -{GPMC_WAIT1, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M3)}, /* gpio_62 */ -{FREF_CLK2_OUT, (PTU | IEN | M3)}, /* gpio_182 */ - -}; - -const struct pad_conf_entry wkup_padconf_array_essential[] = { - -{PAD1_SR_SCL, (PTU | IEN | M0)}, /* sr_scl */ -{PAD0_SR_SDA, (PTU | IEN | M0)}, /* sr_sda */ -{PAD1_SYS_32K, (IEN | M0)}, /* sys_32k */ -{PAD0_FREF_CLK3_OUT, (M0)}, /* fref_clk3_out */ - -}; - -const struct pad_conf_entry wkup_padconf_array_essential_4460[] = { - -{PAD1_FREF_CLK4_REQ, (M3)}, /* gpio_wk7 for TPS: Mode 3 */ - -}; - -#endif /* _PANDA_MUX_DATA_H_ */ diff --git a/configs/omap4_panda_defconfig b/configs/omap4_panda_defconfig deleted file mode 100644 index 3ac6319d2d..0000000000 --- a/configs/omap4_panda_defconfig +++ /dev/null @@ -1,42 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_OMAP2PLUS=y -CONFIG_OMAP44XX=y -CONFIG_TARGET_OMAP4_PANDA=y -CONFIG_SPL=y -CONFIG_SPL_TEXT_BASE=0x40300000 -CONFIG_DISTRO_DEFAULTS=y -CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" -CONFIG_SYS_CONSOLE_IS_IN_ENV=y -CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y -# CONFIG_SPL_FS_EXT4 is not set -# CONFIG_SPL_I2C_SUPPORT is not set -# CONFIG_SPL_NAND_SUPPORT is not set -CONFIG_SPL_OS_BOOT=y -CONFIG_CMD_SPL=y -CONFIG_CMD_ASKENV=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set -CONFIG_CMD_EXT4_WRITE=y -CONFIG_ENV_IS_IN_FAT=y -CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_MMC_OMAP_HS=y -CONFIG_CONS_INDEX=3 -CONFIG_SYS_NS16550=y -CONFIG_SPI=y -CONFIG_OMAP3_SPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_MUSB_UDC=y -CONFIG_USB_OMAP3=y -CONFIG_USB_GADGET=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_SMSC95XX=y -CONFIG_OF_LIBFDT=y diff --git a/include/configs/omap4_panda.h b/include/configs/omap4_panda.h deleted file mode 100644 index 835b7c299e..0000000000 --- a/include/configs/omap4_panda.h +++ /dev/null @@ -1,34 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2010 - * Texas Instruments Incorporated. - * Steve Sakoman steve@sakoman.com - * - * Configuration settings for the TI OMAP4 Panda board. - * See ti_omap4_common.h for OMAP4 common part - */ - -#ifndef __CONFIG_PANDA_H -#define __CONFIG_PANDA_H - -/* - * High Level Configuration Options - */ - -/* USB UHH support options */ -#define CONFIG_OMAP_EHCI_PHY1_RESET_GPIO 1 -#define CONFIG_OMAP_EHCI_PHY2_RESET_GPIO 62 - -/* USB Networking options */ - -#define CONFIG_UBOOT_ENABLE_PADS_ALL - -#include <configs/ti_omap4_common.h> - -/* GPIO */ - -/* ENV related config options */ - -#define CONFIG_ENV_OVERWRITE - -#endif /* __CONFIG_PANDA_H */
Drop it.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/mach-omap2/omap4/Kconfig | 4 -- board/ti/sdp4430/Kconfig | 15 ----- board/ti/sdp4430/MAINTAINERS | 6 -- board/ti/sdp4430/Makefile | 10 --- board/ti/sdp4430/cmd_bat.c | 41 ------------ board/ti/sdp4430/sdp.c | 100 ---------------------------- board/ti/sdp4430/sdp4430_mux_data.h | 67 ------------------- configs/omap4_sdp4430_defconfig | 42 ------------ include/configs/omap4_sdp4430.h | 25 ------- 9 files changed, 310 deletions(-) delete mode 100644 board/ti/sdp4430/Kconfig delete mode 100644 board/ti/sdp4430/MAINTAINERS delete mode 100644 board/ti/sdp4430/Makefile delete mode 100644 board/ti/sdp4430/cmd_bat.c delete mode 100644 board/ti/sdp4430/sdp.c delete mode 100644 board/ti/sdp4430/sdp4430_mux_data.h delete mode 100644 configs/omap4_sdp4430_defconfig delete mode 100644 include/configs/omap4_sdp4430.h
diff --git a/arch/arm/mach-omap2/omap4/Kconfig b/arch/arm/mach-omap2/omap4/Kconfig index 4cc360f38a..f1c60f3562 100644 --- a/arch/arm/mach-omap2/omap4/Kconfig +++ b/arch/arm/mach-omap2/omap4/Kconfig @@ -4,9 +4,6 @@ choice prompt "OMAP4 board select" optional
-config TARGET_OMAP4_SDP4430 - bool "TI OMAP4 SDP4430" - config TARGET_KC1 bool "Amazon Kindle Fire (first generation)"
@@ -15,7 +12,6 @@ endchoice config SYS_SOC default "omap4"
-source "board/ti/sdp4430/Kconfig" source "board/amazon/kc1/Kconfig"
endif diff --git a/board/ti/sdp4430/Kconfig b/board/ti/sdp4430/Kconfig deleted file mode 100644 index 36f1852821..0000000000 --- a/board/ti/sdp4430/Kconfig +++ /dev/null @@ -1,15 +0,0 @@ -if TARGET_OMAP4_SDP4430 - -config SYS_BOARD - default "sdp4430" - -config SYS_VENDOR - default "ti" - -config SYS_CONFIG_NAME - default "omap4_sdp4430" - -config CMD_BAT - bool "Enable board-specific battery command" - -endif diff --git a/board/ti/sdp4430/MAINTAINERS b/board/ti/sdp4430/MAINTAINERS deleted file mode 100644 index ac4d0ccc19..0000000000 --- a/board/ti/sdp4430/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -SDP4430 BOARD -M: Lokesh Vutla lokeshvutla@ti.com -S: Maintained -F: board/ti/sdp4430/ -F: include/configs/omap4_sdp4430.h -F: configs/omap4_sdp4430_defconfig diff --git a/board/ti/sdp4430/Makefile b/board/ti/sdp4430/Makefile deleted file mode 100644 index ae06945612..0000000000 --- a/board/ti/sdp4430/Makefile +++ /dev/null @@ -1,10 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# (C) Copyright 2000, 2001, 2002 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. - -obj-y := sdp.o - -ifndef CONFIG_SPL_BUILD -obj-y += cmd_bat.o -endif diff --git a/board/ti/sdp4430/cmd_bat.c b/board/ti/sdp4430/cmd_bat.c deleted file mode 100644 index 6c1e6ca393..0000000000 --- a/board/ti/sdp4430/cmd_bat.c +++ /dev/null @@ -1,41 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2010 Texas Instruments - */ - -#include <common.h> -#include <command.h> - -#ifdef CONFIG_CMD_BAT -#include <twl6030.h> - -int do_vbat(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) -{ - if (argc == 2) { - if (strncmp(argv[1], "startcharge", 12) == 0) - twl6030_start_usb_charging(); - else if (strncmp(argv[1], "stopcharge", 11) == 0) - twl6030_stop_usb_charging(); - else if (strncmp(argv[1], "status", 7) == 0) { - twl6030_get_battery_voltage(); - twl6030_get_battery_current(); - } else { - goto bat_cmd_usage; - } - } else { - goto bat_cmd_usage; - } - return 0; - -bat_cmd_usage: - return cmd_usage(cmdtp); -} - -U_BOOT_CMD( - bat, 2, 1, do_vbat, - "battery charging, voltage/current measurements", - "status - display battery voltage and current\n" - "bat startcharge - start charging via USB\n" - "bat stopcharge - stop charging\n" -); -#endif /* CONFIG_CMD_BAT */ diff --git a/board/ti/sdp4430/sdp.c b/board/ti/sdp4430/sdp.c deleted file mode 100644 index a5b3504045..0000000000 --- a/board/ti/sdp4430/sdp.c +++ /dev/null @@ -1,100 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2010 - * Texas Instruments Incorporated, <www.ti.com> - * Aneesh V aneesh@ti.com - * Steve Sakoman steve@sakoman.com - */ -#include <common.h> -#include <init.h> -#include <net.h> -#include <twl6030.h> -#include <asm/arch/sys_proto.h> -#include <asm/arch/mmc_host_def.h> - -#include "sdp4430_mux_data.h" - -DECLARE_GLOBAL_DATA_PTR; - -const struct omap_sysinfo sysinfo = { - "Board: OMAP4430 SDP\n" -}; - -/** - * @brief board_init - * - * @return 0 - */ -int board_init(void) -{ - gpmc_init(); - - gd->bd->bi_boot_params = (0x80000000 + 0x100); /* boot param addr */ - - return 0; -} - -int board_eth_init(bd_t *bis) -{ - return 0; -} - -/** - * @brief misc_init_r - Configure SDP board specific configurations - * such as power configurations, ethernet initialization as phase2 of - * boot sequence - * - * @return 0 - */ -int misc_init_r(void) -{ -#ifdef CONFIG_TWL6030_POWER - twl6030_init_battery_charging(); -#endif - return 0; -} - -void set_muxconf_regs(void) -{ - do_set_mux((*ctrl)->control_padconf_core_base, - core_padconf_array_essential, - sizeof(core_padconf_array_essential) / - sizeof(struct pad_conf_entry)); - - do_set_mux((*ctrl)->control_padconf_wkup_base, - wkup_padconf_array_essential, - sizeof(wkup_padconf_array_essential) / - sizeof(struct pad_conf_entry)); - - if ((omap_revision() >= OMAP4460_ES1_0) && - (omap_revision() < OMAP4470_ES1_0)) - do_set_mux((*ctrl)->control_padconf_wkup_base, - wkup_padconf_array_essential_4460, - sizeof(wkup_padconf_array_essential_4460) / - sizeof(struct pad_conf_entry)); -} - -#if defined(CONFIG_MMC) -int board_mmc_init(bd_t *bis) -{ - omap_mmc_init(0, 0, 0, -1, -1); - omap_mmc_init(1, 0, 0, -1, -1); - return 0; -} - -#if !defined(CONFIG_SPL_BUILD) -void board_mmc_power_init(void) -{ - twl6030_power_mmc_init(0); - twl6030_power_mmc_init(1); -} -#endif -#endif - -/* - * get_board_rev() - get board revision - */ -u32 get_board_rev(void) -{ - return 0x20; -} diff --git a/board/ti/sdp4430/sdp4430_mux_data.h b/board/ti/sdp4430/sdp4430_mux_data.h deleted file mode 100644 index 934419f40e..0000000000 --- a/board/ti/sdp4430/sdp4430_mux_data.h +++ /dev/null @@ -1,67 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2010 - * Texas Instruments Incorporated, <www.ti.com> - * - * Balaji Krishnamoorthy balajitk@ti.com - * Aneesh V aneesh@ti.com - */ -#ifndef _SDP4430_MUX_DATA_H -#define _SDP4430_MUX_DATA_H - -#include <asm/arch/mux_omap4.h> - -const struct pad_conf_entry core_padconf_array_essential[] = { - -{GPMC_AD0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat0 */ -{GPMC_AD1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat1 */ -{GPMC_AD2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat2 */ -{GPMC_AD3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat3 */ -{GPMC_AD4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat4 */ -{GPMC_AD5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat5 */ -{GPMC_AD6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat6 */ -{GPMC_AD7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat7 */ -{GPMC_NOE, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M1)}, /* sdmmc2_clk */ -{GPMC_NWE, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_cmd */ -{SDMMC1_CLK, (PTU | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc1_clk */ -{SDMMC1_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_cmd */ -{SDMMC1_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat0 */ -{SDMMC1_DAT1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat1 */ -{SDMMC1_DAT2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat2 */ -{SDMMC1_DAT3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat3 */ -{SDMMC1_DAT4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat4 */ -{SDMMC1_DAT5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat5 */ -{SDMMC1_DAT6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat6 */ -{SDMMC1_DAT7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat7 */ -{UART3_CTS_RCTX, (PTU | IEN | M0)}, /* uart3_tx */ -{UART3_RTS_SD, (M0)}, /* uart3_rts_sd */ -{UART3_RX_IRRX, (IEN | M0)}, /* uart3_rx */ -{UART3_TX_IRTX, (M0)}, /* uart3_tx */ -{USBB1_ULPITLL_DAT4, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat4 */ -{USBB1_ULPITLL_DAT5, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat5 */ -{USBB1_ULPITLL_DAT6, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat6 */ -{USBB1_ULPITLL_DAT7, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat7 */ -{USBB1_HSIC_DATA, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usbb1_hsic_data */ -{USBB1_HSIC_STROBE, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usbb1_hsic_strobe */ -{USBC1_ICUSB_DP, (IEN | M0)}, /* usbc1_icusb_dp */ -{USBC1_ICUSB_DM, (IEN | M0)}, /* usbc1_icusb_dm */ -{USBA0_OTG_CE, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* usba0_otg_ce */ -{USBA0_OTG_DP, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usba0_otg_dp */ -{USBA0_OTG_DM, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usba0_otg_dm */ -}; - -const struct pad_conf_entry wkup_padconf_array_essential[] = { - -{PAD1_SR_SCL, (PTU | IEN | M0)}, /* sr_scl */ -{PAD0_SR_SDA, (PTU | IEN | M0)}, /* sr_sda */ -{PAD1_SYS_32K, (IEN | M0)} /* sys_32k */ - -}; - -const struct pad_conf_entry wkup_padconf_array_essential_4460[] = { - -{PAD1_FREF_CLK4_REQ, (M3)}, /* gpio_wk7 for TPS: Mode 3 */ - -}; - -#endif /* _SDP4430_MUX_DATA_H */ diff --git a/configs/omap4_sdp4430_defconfig b/configs/omap4_sdp4430_defconfig deleted file mode 100644 index 219721388f..0000000000 --- a/configs/omap4_sdp4430_defconfig +++ /dev/null @@ -1,42 +0,0 @@ -CONFIG_ARM=y -# CONFIG_SPL_USE_ARCH_MEMCPY is not set -# CONFIG_SPL_USE_ARCH_MEMSET is not set -CONFIG_ARCH_OMAP2PLUS=y -CONFIG_ENV_OFFSET=0xE0000 -CONFIG_OMAP44XX=y -CONFIG_TARGET_OMAP4_SDP4430=y -CONFIG_CMD_BAT=y -CONFIG_SPL=y -CONFIG_SPL_TEXT_BASE=0x40300000 -CONFIG_DISTRO_DEFAULTS=y -CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" -CONFIG_SYS_CONSOLE_IS_IN_ENV=y -CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y -# CONFIG_SPL_I2C_SUPPORT is not set -# CONFIG_SPL_NAND_SUPPORT is not set -CONFIG_CMD_ASKENV=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_SPI=y -# CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NFS is not set -CONFIG_CMD_EXT4_WRITE=y -# CONFIG_EFI_PARTITION is not set -CONFIG_SPL_PARTITION_UUIDS=y -CONFIG_ENV_IS_IN_MMC=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_MMC_OMAP_HS=y -CONFIG_CONS_INDEX=3 -CONFIG_SYS_NS16550=y -CONFIG_SPI=y -CONFIG_OMAP3_SPI=y -CONFIG_USB=y -CONFIG_USB_MUSB_UDC=y -CONFIG_USB_OMAP3=y -CONFIG_USB_GADGET=y -CONFIG_FAT_WRITE=y -# CONFIG_REGEX is not set -CONFIG_OF_LIBFDT=y -# CONFIG_EFI_LOADER is not set diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h deleted file mode 100644 index 884f45df22..0000000000 --- a/include/configs/omap4_sdp4430.h +++ /dev/null @@ -1,25 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2010 - * Texas Instruments Incorporated. - * Aneesh V aneesh@ti.com - * Steve Sakoman steve@sakoman.com - * - * Configuration settings for the TI SDP4430 board. - * See ti_omap4_common.h for OMAP4 common part - */ - -#ifndef __CONFIG_SDP4430_H -#define __CONFIG_SDP4430_H - -/* - * High Level Configuration Options - */ -#define CONFIG_MACH_TYPE MACH_TYPE_OMAP_4430SDP - -#include <configs/ti_omap4_common.h> - -/* ENV related config options */ -#define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) */ - -#endif /* __CONFIG_SDP4430_H */
On Tue, May 26, 2020 at 11:17 PM Jagan Teki jagan@amarulasolutions.com wrote:
Drop it.
Added board maintainer.
Drop it.
Cc: Lokesh Vutla lokeshvutla@ti.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/mach-omap2/omap5/Kconfig | 4 - board/ti/omap5_uevm/Kconfig | 12 -- board/ti/omap5_uevm/MAINTAINERS | 6 - board/ti/omap5_uevm/Makefile | 6 - board/ti/omap5_uevm/README | 25 --- board/ti/omap5_uevm/evm.c | 283 ------------------------------ board/ti/omap5_uevm/mux_data.h | 57 ------ configs/omap5_uevm_defconfig | 55 ------ include/configs/omap5_uevm.h | 62 ------- 9 files changed, 510 deletions(-) delete mode 100644 board/ti/omap5_uevm/Kconfig delete mode 100644 board/ti/omap5_uevm/MAINTAINERS delete mode 100644 board/ti/omap5_uevm/Makefile delete mode 100644 board/ti/omap5_uevm/README delete mode 100644 board/ti/omap5_uevm/evm.c delete mode 100644 board/ti/omap5_uevm/mux_data.h delete mode 100644 configs/omap5_uevm_defconfig delete mode 100644 include/configs/omap5_uevm.h
diff --git a/arch/arm/mach-omap2/omap5/Kconfig b/arch/arm/mach-omap2/omap5/Kconfig index a0c0b93a00..e73106e321 100644 --- a/arch/arm/mach-omap2/omap5/Kconfig +++ b/arch/arm/mach-omap2/omap5/Kconfig @@ -9,9 +9,6 @@ choice prompt "OMAP5 board select" optional
-config TARGET_OMAP5_UEVM - bool "TI OMAP5 uEVM board" - config TARGET_DRA7XX_EVM bool "TI DRA7XX" select BOARD_LATE_INIT @@ -153,7 +150,6 @@ endchoice endmenu endif
-source "board/ti/omap5_uevm/Kconfig" source "board/ti/dra7xx/Kconfig" source "board/ti/am57xx/Kconfig"
diff --git a/board/ti/omap5_uevm/Kconfig b/board/ti/omap5_uevm/Kconfig deleted file mode 100644 index aa13844544..0000000000 --- a/board/ti/omap5_uevm/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_OMAP5_UEVM - -config SYS_BOARD - default "omap5_uevm" - -config SYS_VENDOR - default "ti" - -config SYS_CONFIG_NAME - default "omap5_uevm" - -endif diff --git a/board/ti/omap5_uevm/MAINTAINERS b/board/ti/omap5_uevm/MAINTAINERS deleted file mode 100644 index 280ea2f91f..0000000000 --- a/board/ti/omap5_uevm/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -OMAP5_UEVM BOARD -M: Lokesh Vutla lokeshvutla@ti.com -S: Maintained -F: board/ti/omap5_uevm/ -F: include/configs/omap5_uevm.h -F: configs/omap5_uevm_defconfig diff --git a/board/ti/omap5_uevm/Makefile b/board/ti/omap5_uevm/Makefile deleted file mode 100644 index 17ee516d26..0000000000 --- a/board/ti/omap5_uevm/Makefile +++ /dev/null @@ -1,6 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# (C) Copyright 2000, 2001, 2002 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. - -obj-y := evm.o diff --git a/board/ti/omap5_uevm/README b/board/ti/omap5_uevm/README deleted file mode 100644 index 970e2eceb7..0000000000 --- a/board/ti/omap5_uevm/README +++ /dev/null @@ -1,25 +0,0 @@ -Summary -======= - -This document covers various features of the 'omap5_uevm' build and some -related uses. - -eMMC boot partition use -======================= - -It is possible, depending on SYSBOOT configuration to boot from the eMMC -boot partitions using (name depending on documentation referenced) -Alternative Boot operation mode or Boot Sequence Option 1/2. In this -example we load MLO and u-boot.img from the build into DDR and then use -'mmc bootbus' to set the required rate (see TRM) and 'mmc partconfig' to -set boot0 as the boot device. -U-Boot # setenv autoload no -U-Boot # usb start -U-Boot # dhcp -U-Boot # mmc dev 1 1 -U-Boot # tftp ${loadaddr} omap5uevm/MLO -U-Boot # mmc write ${loadaddr} 0 100 -U-Boot # tftp ${loadaddr} omap5uevm/u-boot.img -U-Boot # mmc write ${loadaddr} 300 400 -U-Boot # mmc bootbus 1 2 0 2 -U-Boot # mmc partconf 1 1 1 0 diff --git a/board/ti/omap5_uevm/evm.c b/board/ti/omap5_uevm/evm.c deleted file mode 100644 index e35f319b46..0000000000 --- a/board/ti/omap5_uevm/evm.c +++ /dev/null @@ -1,283 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2010 - * Texas Instruments Incorporated, <www.ti.com> - * Aneesh V aneesh@ti.com - * Steve Sakoman steve@sakoman.com - */ -#include <common.h> -#include <init.h> -#include <net.h> -#include <palmas.h> -#include <asm/arch/omap.h> -#include <asm/arch/sys_proto.h> -#include <asm/arch/mmc_host_def.h> -#include <tca642x.h> -#include <usb.h> -#include <linux/delay.h> -#include <linux/usb/gadget.h> -#include <dwc3-uboot.h> -#include <dwc3-omap-uboot.h> -#include <ti-usb-phy-uboot.h> - -#include "mux_data.h" - -#if defined(CONFIG_USB_EHCI_HCD) || defined(CONFIG_USB_XHCI_OMAP) -#include <sata.h> -#include <usb.h> -#include <asm/gpio.h> -#include <asm/mach-types.h> -#include <asm/arch/clock.h> -#include <asm/arch/ehci.h> -#include <asm/ehci-omap.h> -#include <asm/arch/sata.h> - -#define DIE_ID_REG_BASE (OMAP54XX_L4_CORE_BASE + 0x2000) -#define DIE_ID_REG_OFFSET 0x200 - -#endif - -DECLARE_GLOBAL_DATA_PTR; - -const struct omap_sysinfo sysinfo = { - "Board: OMAP5432 uEVM\n" -}; - -/** - * @brief tca642x_init - uEVM default values for the GPIO expander - * input reg, output reg, polarity reg, configuration reg - */ -struct tca642x_bank_info tca642x_init[] = { - { .input_reg = 0x00, - .output_reg = 0x04, - .polarity_reg = 0x00, - .configuration_reg = 0x80 }, - { .input_reg = 0x00, - .output_reg = 0x00, - .polarity_reg = 0x00, - .configuration_reg = 0xff }, - { .input_reg = 0x00, - .output_reg = 0x00, - .polarity_reg = 0x00, - .configuration_reg = 0x40 }, -}; - -#ifdef CONFIG_USB_DWC3 -static struct dwc3_device usb_otg_ss = { - .maximum_speed = USB_SPEED_SUPER, - .base = OMAP5XX_USB_OTG_SS_BASE, - .tx_fifo_resize = false, - .index = 0, -}; - -static struct dwc3_omap_device usb_otg_ss_glue = { - .base = (void *)OMAP5XX_USB_OTG_SS_GLUE_BASE, - .utmi_mode = DWC3_OMAP_UTMI_MODE_SW, - .index = 0, -}; - -static struct ti_usb_phy_device usb_phy_device = { - .pll_ctrl_base = (void *)OMAP5XX_USB3_PHY_PLL_CTRL, - .usb2_phy_power = (void *)OMAP5XX_USB2_PHY_POWER, - .usb3_phy_power = (void *)OMAP5XX_USB3_PHY_POWER, - .index = 0, -}; - -int board_usb_init(int index, enum usb_init_type init) -{ - if (index) { - printf("Invalid Controller Index\n"); - return -EINVAL; - } - - if (init == USB_INIT_DEVICE) { - usb_otg_ss.dr_mode = USB_DR_MODE_PERIPHERAL; - usb_otg_ss_glue.vbus_id_status = OMAP_DWC3_VBUS_VALID; - } else { - usb_otg_ss.dr_mode = USB_DR_MODE_HOST; - usb_otg_ss_glue.vbus_id_status = OMAP_DWC3_ID_GROUND; - } - - enable_usb_clocks(index); - ti_usb_phy_uboot_init(&usb_phy_device); - dwc3_omap_uboot_init(&usb_otg_ss_glue); - dwc3_uboot_init(&usb_otg_ss); - - return 0; -} - -int board_usb_cleanup(int index, enum usb_init_type init) -{ - if (index) { - printf("Invalid Controller Index\n"); - return -EINVAL; - } - - ti_usb_phy_uboot_exit(index); - dwc3_uboot_exit(index); - dwc3_omap_uboot_exit(index); - disable_usb_clocks(index); - - return 0; -} - -int usb_gadget_handle_interrupts(int index) -{ - u32 status; - - status = dwc3_omap_uboot_interrupt_status(index); - if (status) - dwc3_uboot_handle_interrupt(index); - - return 0; -} -#endif - -/** - * @brief board_init - * - * @return 0 - */ -int board_init(void) -{ - gpmc_init(); - gd->bd->bi_arch_number = MACH_TYPE_OMAP5_SEVM; - gd->bd->bi_boot_params = (0x80000000 + 0x100); /* boot param addr */ - - tca642x_set_inital_state(CONFIG_SYS_I2C_TCA642X_ADDR, tca642x_init); - - return 0; -} - -int board_eth_init(bd_t *bis) -{ - return 0; -} - -#if defined(CONFIG_USB_EHCI_HCD) || defined(CONFIG_USB_XHCI_OMAP) -static void enable_host_clocks(void) -{ - int auxclk; - int hs_clk_ctrl_val = (OPTFCLKEN_HSIC60M_P3_CLK | - OPTFCLKEN_HSIC480M_P3_CLK | - OPTFCLKEN_HSIC60M_P2_CLK | - OPTFCLKEN_HSIC480M_P2_CLK | - OPTFCLKEN_UTMI_P3_CLK | OPTFCLKEN_UTMI_P2_CLK); - - /* Enable port 2 and 3 clocks*/ - setbits_le32((*prcm)->cm_l3init_hsusbhost_clkctrl, hs_clk_ctrl_val); - - /* Enable port 2 and 3 usb host ports tll clocks*/ - setbits_le32((*prcm)->cm_l3init_hsusbtll_clkctrl, - (OPTFCLKEN_USB_CH1_CLK_ENABLE | OPTFCLKEN_USB_CH2_CLK_ENABLE)); -#ifdef CONFIG_USB_XHCI_OMAP - /* Enable the USB OTG Super speed clocks */ - setbits_le32((*prcm)->cm_l3init_usb_otg_ss_clkctrl, - (OPTFCLKEN_REFCLK960M | OTG_SS_CLKCTRL_MODULEMODE_HW)); -#endif - - auxclk = readl((*prcm)->scrm_auxclk1); - /* Request auxilary clock */ - auxclk |= AUXCLK_ENABLE_MASK; - writel(auxclk, (*prcm)->scrm_auxclk1); -} -#endif - -/** - * @brief misc_init_r - Configure EVM board specific configurations - * such as power configurations, ethernet initialization as phase2 of - * boot sequence - * - * @return 0 - */ -int misc_init_r(void) -{ -#ifdef CONFIG_PALMAS_POWER - palmas_init_settings(); -#endif - - omap_die_id_usbethaddr(); - - return 0; -} - -void set_muxconf_regs(void) -{ - do_set_mux((*ctrl)->control_padconf_core_base, - core_padconf_array_essential, - sizeof(core_padconf_array_essential) / - sizeof(struct pad_conf_entry)); - - do_set_mux((*ctrl)->control_padconf_wkup_base, - wkup_padconf_array_essential, - sizeof(wkup_padconf_array_essential) / - sizeof(struct pad_conf_entry)); -} - -#if defined(CONFIG_MMC) -int board_mmc_init(bd_t *bis) -{ - omap_mmc_init(0, 0, 0, -1, -1); - omap_mmc_init(1, 0, 0, -1, -1); - return 0; -} -#endif - -#ifdef CONFIG_USB_EHCI_HCD -static struct omap_usbhs_board_data usbhs_bdata = { - .port_mode[0] = OMAP_USBHS_PORT_MODE_UNUSED, - .port_mode[1] = OMAP_EHCI_PORT_MODE_HSIC, - .port_mode[2] = OMAP_EHCI_PORT_MODE_HSIC, -}; - -int ehci_hcd_init(int index, enum usb_init_type init, - struct ehci_hccr **hccr, struct ehci_hcor **hcor) -{ - int ret; - - enable_host_clocks(); - - ret = omap_ehci_hcd_init(index, &usbhs_bdata, hccr, hcor); - if (ret < 0) { - puts("Failed to initialize ehci\n"); - return ret; - } - - return 0; -} - -int ehci_hcd_stop(void) -{ - return omap_ehci_hcd_stop(); -} - -void usb_hub_reset_devices(struct usb_hub_device *hub, int port) -{ - /* The LAN9730 needs to be reset after the port power has been set. */ - if (port == 3) { - gpio_direction_output(CONFIG_OMAP_EHCI_PHY3_RESET_GPIO, 0); - udelay(10); - gpio_direction_output(CONFIG_OMAP_EHCI_PHY3_RESET_GPIO, 1); - } -} -#endif - -#ifdef CONFIG_USB_XHCI_OMAP -/** - * @brief board_usb_init - Configure EVM board specific configurations - * for the LDO's and clocks for the USB blocks. - * - * @return 0 - */ -int board_usb_init(int index, enum usb_init_type init) -{ - int ret; -#ifdef CONFIG_PALMAS_USB_SS_PWR - ret = palmas_enable_ss_ldo(); -#endif - - enable_host_clocks(); - - return 0; -} -#endif diff --git a/board/ti/omap5_uevm/mux_data.h b/board/ti/omap5_uevm/mux_data.h deleted file mode 100644 index 3c4ba47497..0000000000 --- a/board/ti/omap5_uevm/mux_data.h +++ /dev/null @@ -1,57 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2010 - * Texas Instruments Incorporated, <www.ti.com> - * - * Sricharan R r.sricharan@ti.com - */ -#ifndef _EVM5430_MUX_DATA_H -#define _EVM5430_MUX_DATA_H - -#include <asm/arch/mux_omap5.h> - -const struct pad_conf_entry core_padconf_array_essential[] = { - - {EMMC_CLK, (PTU | IEN | M0)}, /* EMMC_CLK */ - {EMMC_CMD, (PTU | IEN | M0)}, /* EMMC_CMD */ - {EMMC_DATA0, (PTU | IEN | M0)}, /* EMMC_DATA0 */ - {EMMC_DATA1, (PTU | IEN | M0)}, /* EMMC_DATA1 */ - {EMMC_DATA2, (PTU | IEN | M0)}, /* EMMC_DATA2 */ - {EMMC_DATA3, (PTU | IEN | M0)}, /* EMMC_DATA3 */ - {EMMC_DATA4, (PTU | IEN | M0)}, /* EMMC_DATA4 */ - {EMMC_DATA5, (PTU | IEN | M0)}, /* EMMC_DATA5 */ - {EMMC_DATA6, (PTU | IEN | M0)}, /* EMMC_DATA6 */ - {EMMC_DATA7, (PTU | IEN | M0)}, /* EMMC_DATA7 */ - {SDCARD_CLK, (PTU | IEN | M0)}, /* SDCARD_CLK */ - {SDCARD_CMD, (PTU | IEN | M0)}, /* SDCARD_CMD */ - {SDCARD_DATA0, (PTU | IEN | M0)}, /* SDCARD_DATA0*/ - {SDCARD_DATA1, (PTU | IEN | M0)}, /* SDCARD_DATA1*/ - {SDCARD_DATA2, (PTU | IEN | M0)}, /* SDCARD_DATA2*/ - {SDCARD_DATA3, (PTU | IEN | M0)}, /* SDCARD_DATA3*/ - {UART3_RX_IRRX, (PTU | IEN | M0)}, /* UART3_RX_IRRX */ - {UART3_TX_IRTX, (M0)}, /* UART3_TX_IRTX */ - {USBB1_HSIC_STROBE, (PTU | IEN | M0)}, /* USBB1_HSIC_STROBE */ - {USBB1_HSIC_DATA, (PTU | IEN | M0)}, /* USBB1_HSIC_DATA */ - {USBB2_HSIC_STROBE, (PTU | IEN | M0)}, /* USBB2_HSIC_STROBE */ - {USBB2_HSIC_DATA, (PTU | IEN | M0)}, /* USBB2_HSIC_DATA */ - {USBB3_HSIC_STROBE, (PTU | IEN | M0)}, /* USBB3_HSIC_STROBE*/ - {USBB3_HSIC_DATA, (PTU | IEN | M0)}, /* USBB3_HSIC_DATA */ - {USBD0_HS_DP, (IEN | M0)}, /* USBD0_HS_DP */ - {USBD0_HS_DM, (IEN | M0)}, /* USBD0_HS_DM */ - {USBD0_SS_RX, (IEN | M0)}, /* USBD0_SS_RX */ - {I2C5_SCL, (IEN | M0)}, /* I2C5_SCL */ - {I2C5_SDA, (IEN | M0)}, /* I2C5_SDA */ - {HSI2_ACWAKE, (PTU | M6)}, /* HSI2_ACWAKE */ - {HSI2_CAFLAG, (PTU | M6)}, /* HSI2_CAFLAG */ -}; - -const struct pad_conf_entry wkup_padconf_array_essential[] = { - - {SR_PMIC_SCL, (PTU | IEN | M0)}, /* SR_PMIC_SCL */ - {SR_PMIC_SDA, (PTU | IEN | M0)}, /* SR_PMIC_SDA */ - {SYS_32K, (IEN | M0)}, /* SYS_32K */ - {FREF_CLK1_OUT, (PTD | IEN | M0)}, /* FREF_CLK1_OUT */ - -}; - -#endif /* _EVM4430_MUX_DATA_H */ diff --git a/configs/omap5_uevm_defconfig b/configs/omap5_uevm_defconfig deleted file mode 100644 index 487f7f305c..0000000000 --- a/configs/omap5_uevm_defconfig +++ /dev/null @@ -1,55 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_OMAP2PLUS=y -CONFIG_OMAP54XX=y -CONFIG_TARGET_OMAP5_UEVM=y -CONFIG_OMAP_PLATFORM_RESET_TIME_MAX_USEC=16296 -CONFIG_SPL=y -CONFIG_ENV_OFFSET_REDUND=0x280000 -CONFIG_ARMV7_LPAE=y -CONFIG_SPL_TEXT_BASE=0x40300000 -CONFIG_DISTRO_DEFAULTS=y -# CONFIG_USE_BOOTCOMMAND is not set -CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y -# CONFIG_SPL_NAND_SUPPORT is not set -CONFIG_SPL_OS_BOOT=y -CONFIG_CMD_SPL=y -CONFIG_CMD_ASKENV=y -CONFIG_CMD_DFU=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_GPT=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_EXT4_WRITE=y -CONFIG_ENV_IS_IN_MMC=y -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_SCSI_AHCI=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y -CONFIG_CMD_TCA642X=y -CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_MMC_OMAP_HS=y -CONFIG_SCSI=y -CONFIG_CONS_INDEX=3 -CONFIG_SYS_NS16550=y -CONFIG_SPI=y -CONFIG_OMAP3_SPI=y -CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_DWC3=y -CONFIG_USB_DWC3_OMAP=y -CONFIG_USB_DWC3_PHY_OMAP=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" -CONFIG_USB_GADGET_VENDOR_NUM=0x0403 -CONFIG_USB_GADGET_PRODUCT_NUM=0xbd00 -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_SMSC95XX=y -CONFIG_FAT_WRITE=y -CONFIG_OF_LIBFDT=y diff --git a/include/configs/omap5_uevm.h b/include/configs/omap5_uevm.h deleted file mode 100644 index 53589c03ea..0000000000 --- a/include/configs/omap5_uevm.h +++ /dev/null @@ -1,62 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2013 - * Texas Instruments Incorporated. - * Sricharan R r.sricharan@ti.com - * - * Configuration settings for the TI EVM5430 board. - * See ti_omap5_common.h for omap5 common settings. - */ - -#ifndef __CONFIG_OMAP5_EVM_H -#define __CONFIG_OMAP5_EVM_H - -#include <environment/ti/dfu.h> - -#ifndef CONFIG_SPL_BUILD -/* Define the default GPT table for eMMC */ -#define PARTS_DEFAULT \ - "uuid_disk=${uuid_gpt_disk};" \ - "name=rootfs,start=2MiB,size=-,uuid=${uuid_gpt_rootfs}" -#endif - -#define DFUARGS \ - "dfu_bufsiz=0x10000\0" \ - DFU_ALT_INFO_MMC \ - DFU_ALT_INFO_EMMC \ - DFU_ALT_INFO_RAM - -#include <configs/ti_omap5_common.h> - -#define CONFIG_SYS_NS16550_COM3 UART3_BASE - -/* MMC ENV related defines */ -#define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) */ - -/* Enhance our eMMC support / experience. */ -#define CONFIG_HSMMC2_8BIT - -/* Required support for the TCA642X GPIO we have on the uEVM */ -#define CONFIG_TCA642X -#define CONFIG_SYS_I2C_TCA642X_BUS_NUM 4 -#define CONFIG_SYS_I2C_TCA642X_ADDR 0x22 - -/* USB UHH support options */ -#define CONFIG_EHCI_HCD_INIT_AFTER_RESET - -#define CONFIG_OMAP_EHCI_PHY2_RESET_GPIO 80 -#define CONFIG_OMAP_EHCI_PHY3_RESET_GPIO 79 - -/* Enabled commands */ - -/* USB Networking options */ - -#define CONSOLEDEV "ttyS2" - -#define CONFIG_SCSI_AHCI_PLAT -#define CONFIG_SYS_SCSI_MAX_SCSI_ID 1 -#define CONFIG_SYS_SCSI_MAX_LUN 1 -#define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ - CONFIG_SYS_SCSI_MAX_LUN) - -#endif /* __CONFIG_OMAP5_EVM_H */
Now all boards are using this omap3 spi driver in dm model, so drop the nondm code.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/spi/Kconfig | 14 ++--- drivers/spi/omap3_spi.c | 136 ---------------------------------------- 2 files changed, 7 insertions(+), 143 deletions(-)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 09b9cb17d8..8fccfbf20d 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -226,6 +226,13 @@ config NXP_FSPI Enable the NXP FlexSPI (FSPI) driver. This driver can be used to access the SPI NOR flash on platforms embedding this NXP IP core.
+config OMAP3_SPI + bool "McSPI driver for OMAP" + help + SPI master controller for OMAP24XX and later Multichannel SPI + (McSPI). This driver be used to access SPI chips on platforms + embedding this OMAP3 McSPI IP core. + config PIC32_SPI bool "Microchip PIC32 SPI driver" depends on MACH_PIC32 @@ -429,11 +436,4 @@ config MXC_SPI Enable the MXC SPI controller driver. This driver can be used on various i.MX SoCs such as i.MX31/35/51/6/7.
-config OMAP3_SPI - bool "McSPI driver for OMAP" - help - SPI master controller for OMAP24XX and later Multichannel SPI - (McSPI). This driver be used to access SPI chips on platforms - embedding this OMAP3 McSPI IP core. - endif # menu "SPI Support" diff --git a/drivers/spi/omap3_spi.c b/drivers/spi/omap3_spi.c index 6a615d1498..39e6813469 100644 --- a/drivers/spi/omap3_spi.c +++ b/drivers/spi/omap3_spi.c @@ -25,16 +25,6 @@
-#if defined(CONFIG_AM33XX) || defined(CONFIG_AM43XX) -#define OMAP3_MCSPI1_BASE 0x48030100 -#define OMAP3_MCSPI2_BASE 0x481A0100 -#else -#define OMAP3_MCSPI1_BASE 0x48098000 -#define OMAP3_MCSPI2_BASE 0x4809A000 -#define OMAP3_MCSPI3_BASE 0x480B8000 -#define OMAP3_MCSPI4_BASE 0x480BA000 -#endif - #define OMAP4_MCSPI_REG_OFFSET 0x100
struct omap2_mcspi_platform_config { @@ -109,9 +99,6 @@ struct mcspi { };
struct omap3_spi_priv { -#ifndef CONFIG_DM_SPI - struct spi_slave slave; -#endif struct mcspi *regs; unsigned int cs; unsigned int freq; @@ -455,128 +442,6 @@ static void _omap3_spi_claim_bus(struct omap3_spi_priv *priv) writel(conf, &priv->regs->modulctrl); }
-#ifndef CONFIG_DM_SPI - -static inline struct omap3_spi_priv *to_omap3_spi(struct spi_slave *slave) -{ - return container_of(slave, struct omap3_spi_priv, slave); -} - -void spi_free_slave(struct spi_slave *slave) -{ - struct omap3_spi_priv *priv = to_omap3_spi(slave); - - free(priv); -} - -int spi_claim_bus(struct spi_slave *slave) -{ - struct omap3_spi_priv *priv = to_omap3_spi(slave); - - spi_reset(priv->regs); - - _omap3_spi_claim_bus(priv); - _omap3_spi_set_wordlen(priv); - _omap3_spi_set_mode(priv); - _omap3_spi_set_speed(priv); - - return 0; -} - -void spi_release_bus(struct spi_slave *slave) -{ - struct omap3_spi_priv *priv = to_omap3_spi(slave); - - writel(OMAP3_MCSPI_MODULCTRL_MS, &priv->regs->modulctrl); -} - -struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, - unsigned int max_hz, unsigned int mode) -{ - struct omap3_spi_priv *priv; - struct mcspi *regs; - - /* - * OMAP3 McSPI (MultiChannel SPI) has 4 busses (modules) - * with different number of chip selects (CS, channels): - * McSPI1 has 4 CS (bus 0, cs 0 - 3) - * McSPI2 has 2 CS (bus 1, cs 0 - 1) - * McSPI3 has 2 CS (bus 2, cs 0 - 1) - * McSPI4 has 1 CS (bus 3, cs 0) - */ - - switch (bus) { - case 0: - regs = (struct mcspi *)OMAP3_MCSPI1_BASE; - break; -#ifdef OMAP3_MCSPI2_BASE - case 1: - regs = (struct mcspi *)OMAP3_MCSPI2_BASE; - break; -#endif -#ifdef OMAP3_MCSPI3_BASE - case 2: - regs = (struct mcspi *)OMAP3_MCSPI3_BASE; - break; -#endif -#ifdef OMAP3_MCSPI4_BASE - case 3: - regs = (struct mcspi *)OMAP3_MCSPI4_BASE; - break; -#endif - default: - printf("SPI error: unsupported bus %i. Supported busses 0 - 3\n", bus); - return NULL; - } - - if (((bus == 0) && (cs > 3)) || - ((bus == 1) && (cs > 1)) || - ((bus == 2) && (cs > 1)) || - ((bus == 3) && (cs > 0))) { - printf("SPI error: unsupported chip select %i on bus %i\n", cs, bus); - return NULL; - } - - if (max_hz > OMAP3_MCSPI_MAX_FREQ) { - printf("SPI error: unsupported frequency %i Hz. Max frequency is 48 MHz\n", - max_hz); - return NULL; - } - - if (mode > SPI_MODE_3) { - printf("SPI error: unsupported SPI mode %i\n", mode); - return NULL; - } - - priv = spi_alloc_slave(struct omap3_spi_priv, bus, cs); - if (!priv) { - printf("SPI error: malloc of SPI structure failed\n"); - return NULL; - } - - priv->regs = regs; - priv->cs = cs; - priv->freq = max_hz; - priv->mode = mode; - priv->wordlen = priv->slave.wordlen; -#if 0 - /* Please migrate to DM_SPI support for this feature. */ - priv->pin_dir = MCSPI_PINDIR_D0_OUT_D1_IN; -#endif - - return &priv->slave; -} - -int spi_xfer(struct spi_slave *slave, unsigned int bitlen, - const void *dout, void *din, unsigned long flags) -{ - struct omap3_spi_priv *priv = to_omap3_spi(slave); - - return _spi_xfer(priv, bitlen, dout, din, flags); -} - -#else - static int omap3_spi_claim_bus(struct udevice *dev) { struct udevice *bus = dev->parent; @@ -701,4 +566,3 @@ U_BOOT_DRIVER(omap3_spi) = { .ops = &omap3_spi_ops, .priv_auto_alloc_size = sizeof(struct omap3_spi_priv), }; -#endif
ompa3 and fsl_dspi are fully converted into DM_SPI.
Update it.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- doc/driver-model/migration.rst | 2 -- 1 file changed, 2 deletions(-)
diff --git a/doc/driver-model/migration.rst b/doc/driver-model/migration.rst index 2c0e2c7f06..408643974c 100644 --- a/doc/driver-model/migration.rst +++ b/doc/driver-model/migration.rst @@ -75,10 +75,8 @@ No dm conversion yet::
Partially converted::
- drivers/spi/fsl_dspi.c drivers/spi/kirkwood_spi.c drivers/spi/mxc_spi.c - drivers/spi/omap3_spi.c drivers/spi/sh_qspi.c
* Status: In progress
Jagan Teki
