[PATCH v2 0/3] malloc: Enable profiling dlmalloc with valgrind
This series adds support for running valgrind against U-Boot's internal malloc. This allows for much more useful reports to be generated.
Changes in v2: - Fix one branch of rEALLOc missing a VALGRING_*_BLOCK call - Add some additional suppressions for cALLOc and rEALLOc - Simplify calloc clearing logic - Drop incorrect sbrk patch
Sean Anderson (3): Add valgrind headers to U-Boot malloc: Annotate allocator for valgrind doc: sandbox: Document how to run sandbox with valgrind
Kconfig | 14 + Licenses/README | 1 + Licenses/bzip2-1.0.6.txt | 30 + common/dlmalloc.c | 35 +- common/malloc_simple.c | 10 + doc/arch/sandbox.rst | 14 +- include/malloc.h | 4 + include/valgrind/memcheck.h | 251 ++ include/valgrind/valgrind.h | 7106 +++++++++++++++++++++++++++++++++++ scripts/u-boot.supp | 53 + 10 files changed, 7513 insertions(+), 5 deletions(-) create mode 100644 Licenses/bzip2-1.0.6.txt create mode 100644 include/valgrind/memcheck.h create mode 100644 include/valgrind/valgrind.h create mode 100644 scripts/u-boot.supp
Valgrind uses magic code sequences to define an ABI that the client may use to request behavior from the host. In particular, this may be used to inform valgrind about custom allocators, such as the one used in U-Boot.
This adds headers defining these sequences to U-Boot. It also adds a config option to disable emission of these sequences entirely, in the (likely) event that the user does not wish to use valgrind. Note that this option was originally called NVALGRIND, but was renamed (and inverted) to CONFIG_VALGRIND.
These headers were copied from valgrind 3.16.1-4 as distributed in Arch Linux. They are licensed with the bzip2 1.16 license. This appears to be a BSD license with some clauses from Zlib.
Signed-off-by: Sean Anderson seanga2@gmail.com Reviewed-by: Simon Glass sjg@chromium.org ---
(no changes since v1)
Kconfig | 14 + Licenses/README | 1 + Licenses/bzip2-1.0.6.txt | 30 + include/valgrind/memcheck.h | 251 ++ include/valgrind/valgrind.h | 7106 +++++++++++++++++++++++++++++++++++ 5 files changed, 7402 insertions(+) create mode 100644 Licenses/bzip2-1.0.6.txt create mode 100644 include/valgrind/memcheck.h create mode 100644 include/valgrind/valgrind.h
diff --git a/Kconfig b/Kconfig index 86f0a39bb0..c05f304325 100644 --- a/Kconfig +++ b/Kconfig @@ -240,6 +240,20 @@ config TPL_SYS_MALLOC_F_LEN particular needs this to operate, so that it can allocate the initial serial device and any others that are needed.
+config VALGRIND + bool "Inform valgrind about memory allocations" + help + Valgrind is an instrumentation framework for building dynamic analysis + tools. In particular, it may be used to detect memory management bugs + in U-Boot. It relies on knowing when heap blocks are allocated in + order to give accurate results. This happens automatically for + standard allocator functions provided by the host OS. However, this + doesn't automatically happen for U-Boot's malloc implementation. + + Enable this option to annotate U-Boot's malloc implementation so that + it can be handled accurately by Valgrind. If you aren't planning on + using valgrind to debug U-Boot, say 'n'. + menuconfig EXPERT bool "Configure standard U-Boot features (expert users)" default y diff --git a/Licenses/README b/Licenses/README index c23ad216fc..d09f0fe2cb 100644 --- a/Licenses/README +++ b/Licenses/README @@ -139,6 +139,7 @@ License identifier syntax
Full name SPDX Identifier OSI Approved File name URI ======================================================================================================================================= +bzip2 and libbzip2 License v1.0.6 bzip2-1.0.6 bzip2-1.0.6.txt https://spdx.org/licenses/bzip2-1.0.6.html GNU General Public License v2.0 only GPL-2.0 Y gpl-2.0.txt http://www.gnu.org/licenses/gpl-2.0.txt GNU General Public License v2.0 or later GPL-2.0+ Y gpl-2.0.txt http://www.gnu.org/licenses/gpl-2.0.txt GNU Library General Public License v2 or later LGPL-2.0+ Y lgpl-2.0.txt http://www.gnu.org/licenses/old-licenses/lgpl-2.0.txt diff --git a/Licenses/bzip2-1.0.6.txt b/Licenses/bzip2-1.0.6.txt new file mode 100644 index 0000000000..2adb26c394 --- /dev/null +++ b/Licenses/bzip2-1.0.6.txt @@ -0,0 +1,30 @@ +Redistribution and use in source and binary forms, with or without +modification, are permitted provided that the following conditions +are met: + +1. Redistributions of source code must retain the above copyright + notice, this list of conditions and the following disclaimer. + +2. The origin of this software must not be misrepresented; you must + not claim that you wrote the original software. If you use this + software in a product, an acknowledgment in the product + documentation would be appreciated but is not required. + +3. Altered source versions must be plainly marked as such, and must + not be misrepresented as being the original software. + +4. The name of the author may not be used to endorse or promote + products derived from this software without specific prior written + permission. + +THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS +OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED +WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE +ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY +DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL +DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE +GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS +INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, +WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING +NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS +SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. diff --git a/include/valgrind/memcheck.h b/include/valgrind/memcheck.h new file mode 100644 index 0000000000..a4f65ab387 --- /dev/null +++ b/include/valgrind/memcheck.h @@ -0,0 +1,251 @@ +/* SPDX-License-Identifier: bzip2-1.0.6 */ +/* + This file is part of MemCheck, a heavyweight Valgrind tool for + detecting memory errors. + + Copyright (C) 2000-2017 Julian Seward. All rights reserved. + */ + +#ifndef __MEMCHECK_H +#define __MEMCHECK_H + + +/* This file is for inclusion into client (your!) code. + + You can use these macros to manipulate and query memory permissions + inside your own programs. + + See comment near the top of valgrind.h on how to use them. +*/ + +#include "valgrind.h" + +/* !! ABIWARNING !! ABIWARNING !! ABIWARNING !! ABIWARNING !! + This enum comprises an ABI exported by Valgrind to programs + which use client requests. DO NOT CHANGE THE ORDER OF THESE + ENTRIES, NOR DELETE ANY -- add new ones at the end. */ +typedef + enum { + VG_USERREQ__MAKE_MEM_NOACCESS = VG_USERREQ_TOOL_BASE('M','C'), + VG_USERREQ__MAKE_MEM_UNDEFINED, + VG_USERREQ__MAKE_MEM_DEFINED, + VG_USERREQ__DISCARD, + VG_USERREQ__CHECK_MEM_IS_ADDRESSABLE, + VG_USERREQ__CHECK_MEM_IS_DEFINED, + VG_USERREQ__DO_LEAK_CHECK, + VG_USERREQ__COUNT_LEAKS, + + VG_USERREQ__GET_VBITS, + VG_USERREQ__SET_VBITS, + + VG_USERREQ__CREATE_BLOCK, + + VG_USERREQ__MAKE_MEM_DEFINED_IF_ADDRESSABLE, + + /* Not next to VG_USERREQ__COUNT_LEAKS because it was added later. */ + VG_USERREQ__COUNT_LEAK_BLOCKS, + + VG_USERREQ__ENABLE_ADDR_ERROR_REPORTING_IN_RANGE, + VG_USERREQ__DISABLE_ADDR_ERROR_REPORTING_IN_RANGE, + + /* This is just for memcheck's internal use - don't use it */ + _VG_USERREQ__MEMCHECK_RECORD_OVERLAP_ERROR + = VG_USERREQ_TOOL_BASE('M','C') + 256 + } Vg_MemCheckClientRequest; + + + +/* Client-code macros to manipulate the state of memory. */ + +/* Mark memory at _qzz_addr as unaddressable for _qzz_len bytes. */ +#define VALGRIND_MAKE_MEM_NOACCESS(_qzz_addr,_qzz_len) \ + VALGRIND_DO_CLIENT_REQUEST_EXPR(0 /* default return */, \ + VG_USERREQ__MAKE_MEM_NOACCESS, \ + (_qzz_addr), (_qzz_len), 0, 0, 0) + +/* Similarly, mark memory at _qzz_addr as addressable but undefined + for _qzz_len bytes. */ +#define VALGRIND_MAKE_MEM_UNDEFINED(_qzz_addr,_qzz_len) \ + VALGRIND_DO_CLIENT_REQUEST_EXPR(0 /* default return */, \ + VG_USERREQ__MAKE_MEM_UNDEFINED, \ + (_qzz_addr), (_qzz_len), 0, 0, 0) + +/* Similarly, mark memory at _qzz_addr as addressable and defined + for _qzz_len bytes. */ +#define VALGRIND_MAKE_MEM_DEFINED(_qzz_addr,_qzz_len) \ + VALGRIND_DO_CLIENT_REQUEST_EXPR(0 /* default return */, \ + VG_USERREQ__MAKE_MEM_DEFINED, \ + (_qzz_addr), (_qzz_len), 0, 0, 0) + +/* Similar to VALGRIND_MAKE_MEM_DEFINED except that addressability is + not altered: bytes which are addressable are marked as defined, + but those which are not addressable are left unchanged. */ +#define VALGRIND_MAKE_MEM_DEFINED_IF_ADDRESSABLE(_qzz_addr,_qzz_len) \ + VALGRIND_DO_CLIENT_REQUEST_EXPR(0 /* default return */, \ + VG_USERREQ__MAKE_MEM_DEFINED_IF_ADDRESSABLE, \ + (_qzz_addr), (_qzz_len), 0, 0, 0) + +/* Create a block-description handle. The description is an ascii + string which is included in any messages pertaining to addresses + within the specified memory range. Has no other effect on the + properties of the memory range. */ +#define VALGRIND_CREATE_BLOCK(_qzz_addr,_qzz_len, _qzz_desc) \ + VALGRIND_DO_CLIENT_REQUEST_EXPR(0 /* default return */, \ + VG_USERREQ__CREATE_BLOCK, \ + (_qzz_addr), (_qzz_len), (_qzz_desc), \ + 0, 0) + +/* Discard a block-description-handle. Returns 1 for an + invalid handle, 0 for a valid handle. */ +#define VALGRIND_DISCARD(_qzz_blkindex) \ + VALGRIND_DO_CLIENT_REQUEST_EXPR(0 /* default return */, \ + VG_USERREQ__DISCARD, \ + 0, (_qzz_blkindex), 0, 0, 0) + + +/* Client-code macros to check the state of memory. */ + +/* Check that memory at _qzz_addr is addressable for _qzz_len bytes. + If suitable addressibility is not established, Valgrind prints an + error message and returns the address of the first offending byte. + Otherwise it returns zero. */ +#define VALGRIND_CHECK_MEM_IS_ADDRESSABLE(_qzz_addr,_qzz_len) \ + VALGRIND_DO_CLIENT_REQUEST_EXPR(0, \ + VG_USERREQ__CHECK_MEM_IS_ADDRESSABLE, \ + (_qzz_addr), (_qzz_len), 0, 0, 0) + +/* Check that memory at _qzz_addr is addressable and defined for + _qzz_len bytes. If suitable addressibility and definedness are not + established, Valgrind prints an error message and returns the + address of the first offending byte. Otherwise it returns zero. */ +#define VALGRIND_CHECK_MEM_IS_DEFINED(_qzz_addr,_qzz_len) \ + VALGRIND_DO_CLIENT_REQUEST_EXPR(0, \ + VG_USERREQ__CHECK_MEM_IS_DEFINED, \ + (_qzz_addr), (_qzz_len), 0, 0, 0) + +/* Use this macro to force the definedness and addressibility of an + lvalue to be checked. If suitable addressibility and definedness + are not established, Valgrind prints an error message and returns + the address of the first offending byte. Otherwise it returns + zero. */ +#define VALGRIND_CHECK_VALUE_IS_DEFINED(__lvalue) \ + VALGRIND_CHECK_MEM_IS_DEFINED( \ + (volatile unsigned char *)&(__lvalue), \ + (unsigned long)(sizeof (__lvalue))) + + +/* Do a full memory leak check (like --leak-check=full) mid-execution. */ +#define VALGRIND_DO_LEAK_CHECK \ + VALGRIND_DO_CLIENT_REQUEST_STMT(VG_USERREQ__DO_LEAK_CHECK, \ + 0, 0, 0, 0, 0) + +/* Same as VALGRIND_DO_LEAK_CHECK but only showing the entries for + which there was an increase in leaked bytes or leaked nr of blocks + since the previous leak search. */ +#define VALGRIND_DO_ADDED_LEAK_CHECK \ + VALGRIND_DO_CLIENT_REQUEST_STMT(VG_USERREQ__DO_LEAK_CHECK, \ + 0, 1, 0, 0, 0) + +/* Same as VALGRIND_DO_ADDED_LEAK_CHECK but showing entries with + increased or decreased leaked bytes/blocks since previous leak + search. */ +#define VALGRIND_DO_CHANGED_LEAK_CHECK \ + VALGRIND_DO_CLIENT_REQUEST_STMT(VG_USERREQ__DO_LEAK_CHECK, \ + 0, 2, 0, 0, 0) + +/* Do a summary memory leak check (like --leak-check=summary) mid-execution. */ +#define VALGRIND_DO_QUICK_LEAK_CHECK \ + VALGRIND_DO_CLIENT_REQUEST_STMT(VG_USERREQ__DO_LEAK_CHECK, \ + 1, 0, 0, 0, 0) + +/* Return number of leaked, dubious, reachable and suppressed bytes found by + all previous leak checks. They must be lvalues. */ +#define VALGRIND_COUNT_LEAKS(leaked, dubious, reachable, suppressed) \ + /* For safety on 64-bit platforms we assign the results to private + unsigned long variables, then assign these to the lvalues the user + specified, which works no matter what type 'leaked', 'dubious', etc + are. We also initialise '_qzz_leaked', etc because + VG_USERREQ__COUNT_LEAKS doesn't mark the values returned as + defined. */ \ + { \ + unsigned long _qzz_leaked = 0, _qzz_dubious = 0; \ + unsigned long _qzz_reachable = 0, _qzz_suppressed = 0; \ + VALGRIND_DO_CLIENT_REQUEST_STMT( \ + VG_USERREQ__COUNT_LEAKS, \ + &_qzz_leaked, &_qzz_dubious, \ + &_qzz_reachable, &_qzz_suppressed, 0); \ + leaked = _qzz_leaked; \ + dubious = _qzz_dubious; \ + reachable = _qzz_reachable; \ + suppressed = _qzz_suppressed; \ + } + +/* Return number of leaked, dubious, reachable and suppressed bytes found by + all previous leak checks. They must be lvalues. */ +#define VALGRIND_COUNT_LEAK_BLOCKS(leaked, dubious, reachable, suppressed) \ + /* For safety on 64-bit platforms we assign the results to private + unsigned long variables, then assign these to the lvalues the user + specified, which works no matter what type 'leaked', 'dubious', etc + are. We also initialise '_qzz_leaked', etc because + VG_USERREQ__COUNT_LEAKS doesn't mark the values returned as + defined. */ \ + { \ + unsigned long _qzz_leaked = 0, _qzz_dubious = 0; \ + unsigned long _qzz_reachable = 0, _qzz_suppressed = 0; \ + VALGRIND_DO_CLIENT_REQUEST_STMT( \ + VG_USERREQ__COUNT_LEAK_BLOCKS, \ + &_qzz_leaked, &_qzz_dubious, \ + &_qzz_reachable, &_qzz_suppressed, 0); \ + leaked = _qzz_leaked; \ + dubious = _qzz_dubious; \ + reachable = _qzz_reachable; \ + suppressed = _qzz_suppressed; \ + } + + +/* Get the validity data for addresses [zza..zza+zznbytes-1] and copy it + into the provided zzvbits array. Return values: + 0 if not running on valgrind + 1 success + 2 [previously indicated unaligned arrays; these are now allowed] + 3 if any parts of zzsrc/zzvbits are not addressable. + The metadata is not copied in cases 0, 2 or 3 so it should be + impossible to segfault your system by using this call. +*/ +#define VALGRIND_GET_VBITS(zza,zzvbits,zznbytes) \ + (unsigned)VALGRIND_DO_CLIENT_REQUEST_EXPR(0, \ + VG_USERREQ__GET_VBITS, \ + (const char*)(zza), \ + (char*)(zzvbits), \ + (zznbytes), 0, 0) + +/* Set the validity data for addresses [zza..zza+zznbytes-1], copying it + from the provided zzvbits array. Return values: + 0 if not running on valgrind + 1 success + 2 [previously indicated unaligned arrays; these are now allowed] + 3 if any parts of zza/zzvbits are not addressable. + The metadata is not copied in cases 0, 2 or 3 so it should be + impossible to segfault your system by using this call. +*/ +#define VALGRIND_SET_VBITS(zza,zzvbits,zznbytes) \ + (unsigned)VALGRIND_DO_CLIENT_REQUEST_EXPR(0, \ + VG_USERREQ__SET_VBITS, \ + (const char*)(zza), \ + (const char*)(zzvbits), \ + (zznbytes), 0, 0 ) + +/* Disable and re-enable reporting of addressing errors in the + specified address range. */ +#define VALGRIND_DISABLE_ADDR_ERROR_REPORTING_IN_RANGE(_qzz_addr,_qzz_len) \ + VALGRIND_DO_CLIENT_REQUEST_EXPR(0 /* default return */, \ + VG_USERREQ__DISABLE_ADDR_ERROR_REPORTING_IN_RANGE, \ + (_qzz_addr), (_qzz_len), 0, 0, 0) + +#define VALGRIND_ENABLE_ADDR_ERROR_REPORTING_IN_RANGE(_qzz_addr,_qzz_len) \ + VALGRIND_DO_CLIENT_REQUEST_EXPR(0 /* default return */, \ + VG_USERREQ__ENABLE_ADDR_ERROR_REPORTING_IN_RANGE, \ + (_qzz_addr), (_qzz_len), 0, 0, 0) + +#endif + diff --git a/include/valgrind/valgrind.h b/include/valgrind/valgrind.h new file mode 100644 index 0000000000..e59a7fde32 --- /dev/null +++ b/include/valgrind/valgrind.h @@ -0,0 +1,7106 @@ +/* SPDX-License-Identifier: GPL-2.0+ AND bzip2-1.0.6 */ +/* + This file is part of Valgrind, a dynamic binary instrumentation + framework. + + Copyright (C) 2000-2017 Julian Seward. All rights reserved. + Copyright (C) 2021 Sean Anderson seanga2@gmail.com +*/ + +/* This file is for inclusion into client (your!) code. + + You can use these macros to manipulate and query Valgrind's + execution inside your own programs. + + The resulting executables will still run without Valgrind, just a + little bit more slowly than they otherwise would, but otherwise + unchanged. When not running on valgrind, each client request + consumes very few (eg. 7) instructions, so the resulting performance + loss is negligible unless you plan to execute client requests + millions of times per second. Nevertheless, if that is still a + problem, you can compile with the NVALGRIND symbol defined (gcc + -DNVALGRIND) so that client requests are not even compiled in. */ + +#ifndef __VALGRIND_H +#define __VALGRIND_H + + +/* ------------------------------------------------------------------ */ +/* VERSION NUMBER OF VALGRIND */ +/* ------------------------------------------------------------------ */ + +/* Specify Valgrind's version number, so that user code can + conditionally compile based on our version number. Note that these + were introduced at version 3.6 and so do not exist in version 3.5 + or earlier. The recommended way to use them to check for "version + X.Y or later" is (eg) + +#if defined(__VALGRIND_MAJOR__) && defined(__VALGRIND_MINOR__) \ + && (__VALGRIND_MAJOR__ > 3 \ + || (__VALGRIND_MAJOR__ == 3 && __VALGRIND_MINOR__ >= 6)) +*/ +#define __VALGRIND_MAJOR__ 3 +#define __VALGRIND_MINOR__ 16 + + +#include <stdarg.h> + +/* Nb: this file might be included in a file compiled with -ansi. So + we can't use C++ style "//" comments nor the "asm" keyword (instead + use "__asm__"). */ + +/* Derive some tags indicating what the target platform is. Note + that in this file we're using the compiler's CPP symbols for + identifying architectures, which are different to the ones we use + within the rest of Valgrind. Note, __powerpc__ is active for both + 32 and 64-bit PPC, whereas __powerpc64__ is only active for the + latter (on Linux, that is). + + Misc note: how to find out what's predefined in gcc by default: + gcc -Wp,-dM somefile.c +*/ +#undef PLAT_x86_darwin +#undef PLAT_amd64_darwin +#undef PLAT_x86_win32 +#undef PLAT_amd64_win64 +#undef PLAT_x86_linux +#undef PLAT_amd64_linux +#undef PLAT_ppc32_linux +#undef PLAT_ppc64be_linux +#undef PLAT_ppc64le_linux +#undef PLAT_arm_linux +#undef PLAT_arm64_linux +#undef PLAT_s390x_linux +#undef PLAT_mips32_linux +#undef PLAT_mips64_linux +#undef PLAT_nanomips_linux +#undef PLAT_x86_solaris +#undef PLAT_amd64_solaris + + +#if defined(__APPLE__) && defined(__i386__) +# define PLAT_x86_darwin 1 +#elif defined(__APPLE__) && defined(__x86_64__) +# define PLAT_amd64_darwin 1 +#elif (defined(__MINGW32__) && defined(__i386__)) \ + || defined(__CYGWIN32__) \ + || (defined(_WIN32) && defined(_M_IX86)) +# define PLAT_x86_win32 1 +#elif (defined(__MINGW32__) && defined(__x86_64__)) \ + || (defined(_WIN32) && defined(_M_X64)) +/* __MINGW32__ and _WIN32 are defined in 64 bit mode as well. */ +# define PLAT_amd64_win64 1 +#elif defined(__linux__) && defined(__i386__) +# define PLAT_x86_linux 1 +#elif defined(__linux__) && defined(__x86_64__) && !defined(__ILP32__) +# define PLAT_amd64_linux 1 +#elif defined(__linux__) && defined(__powerpc__) && !defined(__powerpc64__) +# define PLAT_ppc32_linux 1 +#elif defined(__linux__) && defined(__powerpc__) && defined(__powerpc64__) && _CALL_ELF != 2 +/* Big Endian uses ELF version 1 */ +# define PLAT_ppc64be_linux 1 +#elif defined(__linux__) && defined(__powerpc__) && defined(__powerpc64__) && _CALL_ELF == 2 +/* Little Endian uses ELF version 2 */ +# define PLAT_ppc64le_linux 1 +#elif defined(__linux__) && defined(__arm__) && !defined(__aarch64__) +# define PLAT_arm_linux 1 +#elif defined(__linux__) && defined(__aarch64__) && !defined(__arm__) +# define PLAT_arm64_linux 1 +#elif defined(__linux__) && defined(__s390__) && defined(__s390x__) +# define PLAT_s390x_linux 1 +#elif defined(__linux__) && defined(__mips__) && (__mips==64) +# define PLAT_mips64_linux 1 +#elif defined(__linux__) && defined(__mips__) && (__mips==32) +# define PLAT_mips32_linux 1 +#elif defined(__linux__) && defined(__nanomips__) +# define PLAT_nanomips_linux 1 +#elif defined(__sun) && defined(__i386__) +# define PLAT_x86_solaris 1 +#elif defined(__sun) && defined(__x86_64__) +# define PLAT_amd64_solaris 1 +#else +/* If we're not compiling for our target platform, don't generate + any inline asms. */ +# undef CONFIG_VALGRIND +#endif + + +/* ------------------------------------------------------------------ */ +/* ARCHITECTURE SPECIFICS for SPECIAL INSTRUCTIONS. There is nothing */ +/* in here of use to end-users -- skip to the next section. */ +/* ------------------------------------------------------------------ */ + +/* + * VALGRIND_DO_CLIENT_REQUEST(): a statement that invokes a Valgrind client + * request. Accepts both pointers and integers as arguments. + * + * VALGRIND_DO_CLIENT_REQUEST_STMT(): a statement that invokes a Valgrind + * client request that does not return a value. + + * VALGRIND_DO_CLIENT_REQUEST_EXPR(): a C expression that invokes a Valgrind + * client request and whose value equals the client request result. Accepts + * both pointers and integers as arguments. Note that such calls are not + * necessarily pure functions -- they may have side effects. + */ + +#define VALGRIND_DO_CLIENT_REQUEST(_zzq_rlval, _zzq_default, \ + _zzq_request, _zzq_arg1, _zzq_arg2, \ + _zzq_arg3, _zzq_arg4, _zzq_arg5) \ + do { (_zzq_rlval) = VALGRIND_DO_CLIENT_REQUEST_EXPR((_zzq_default), \ + (_zzq_request), (_zzq_arg1), (_zzq_arg2), \ + (_zzq_arg3), (_zzq_arg4), (_zzq_arg5)); } while (0) + +#define VALGRIND_DO_CLIENT_REQUEST_STMT(_zzq_request, _zzq_arg1, \ + _zzq_arg2, _zzq_arg3, _zzq_arg4, _zzq_arg5) \ + do { (void) VALGRIND_DO_CLIENT_REQUEST_EXPR(0, \ + (_zzq_request), (_zzq_arg1), (_zzq_arg2), \ + (_zzq_arg3), (_zzq_arg4), (_zzq_arg5)); } while (0) + +#if !IS_ENABLED(CONFIG_VALGRIND) + +/* Define NVALGRIND to completely remove the Valgrind magic sequence + from the compiled code (analogous to NDEBUG's effects on + assert()) */ +#define VALGRIND_DO_CLIENT_REQUEST_EXPR( \ + _zzq_default, _zzq_request, \ + _zzq_arg1, _zzq_arg2, _zzq_arg3, _zzq_arg4, _zzq_arg5) \ + (_zzq_default) + +#else /* ! CONFIG_VALGRIND */ + +/* The following defines the magic code sequences which the JITter + spots and handles magically. Don't look too closely at them as + they will rot your brain. + + The assembly code sequences for all architectures is in this one + file. This is because this file must be stand-alone, and we don't + want to have multiple files. + + For VALGRIND_DO_CLIENT_REQUEST, we must ensure that the default + value gets put in the return slot, so that everything works when + this is executed not under Valgrind. Args are passed in a memory + block, and so there's no intrinsic limit to the number that could + be passed, but it's currently five. + + The macro args are: + _zzq_rlval result lvalue + _zzq_default default value (result returned when running on real CPU) + _zzq_request request code + _zzq_arg1..5 request params + + The other two macros are used to support function wrapping, and are + a lot simpler. VALGRIND_GET_NR_CONTEXT returns the value of the + guest's NRADDR pseudo-register and whatever other information is + needed to safely run the call original from the wrapper: on + ppc64-linux, the R2 value at the divert point is also needed. This + information is abstracted into a user-visible type, OrigFn. + + VALGRIND_CALL_NOREDIR_* behaves the same as the following on the + guest, but guarantees that the branch instruction will not be + redirected: x86: call *%eax, amd64: call *%rax, ppc32/ppc64: + branch-and-link-to-r11. VALGRIND_CALL_NOREDIR is just text, not a + complete inline asm, since it needs to be combined with more magic + inline asm stuff to be useful. +*/ + +/* ----------------- x86-{linux,darwin,solaris} ---------------- */ + +#if defined(PLAT_x86_linux) || defined(PLAT_x86_darwin) \ + || (defined(PLAT_x86_win32) && defined(__GNUC__)) \ + || defined(PLAT_x86_solaris) + +typedef + struct { + unsigned int nraddr; /* where's the code? */ + } + OrigFn; + +#define __SPECIAL_INSTRUCTION_PREAMBLE \ + "roll $3, %%edi ; roll $13, %%edi\n\t" \ + "roll $29, %%edi ; roll $19, %%edi\n\t" + +#define VALGRIND_DO_CLIENT_REQUEST_EXPR( \ + _zzq_default, _zzq_request, \ + _zzq_arg1, _zzq_arg2, _zzq_arg3, _zzq_arg4, _zzq_arg5) \ + __extension__ \ + ({volatile unsigned int _zzq_args[6]; \ + volatile unsigned int _zzq_result; \ + _zzq_args[0] = (unsigned int)(_zzq_request); \ + _zzq_args[1] = (unsigned int)(_zzq_arg1); \ + _zzq_args[2] = (unsigned int)(_zzq_arg2); \ + _zzq_args[3] = (unsigned int)(_zzq_arg3); \ + _zzq_args[4] = (unsigned int)(_zzq_arg4); \ + _zzq_args[5] = (unsigned int)(_zzq_arg5); \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + /* %EDX = client_request ( %EAX ) */ \ + "xchgl %%ebx,%%ebx" \ + : "=d" (_zzq_result) \ + : "a" (&_zzq_args[0]), "0" (_zzq_default) \ + : "cc", "memory" \ + ); \ + _zzq_result; \ + }) + +#define VALGRIND_GET_NR_CONTEXT(_zzq_rlval) \ + { volatile OrigFn* _zzq_orig = &(_zzq_rlval); \ + volatile unsigned int __addr; \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + /* %EAX = guest_NRADDR */ \ + "xchgl %%ecx,%%ecx" \ + : "=a" (__addr) \ + : \ + : "cc", "memory" \ + ); \ + _zzq_orig->nraddr = __addr; \ + } + +#define VALGRIND_CALL_NOREDIR_EAX \ + __SPECIAL_INSTRUCTION_PREAMBLE \ + /* call-noredir *%EAX */ \ + "xchgl %%edx,%%edx\n\t" + +#define VALGRIND_VEX_INJECT_IR() \ + do { \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + "xchgl %%edi,%%edi\n\t" \ + : : : "cc", "memory" \ + ); \ + } while (0) + +#endif /* PLAT_x86_linux || PLAT_x86_darwin || (PLAT_x86_win32 && __GNUC__) + || PLAT_x86_solaris */ + +/* ------------------------- x86-Win32 ------------------------- */ + +#if defined(PLAT_x86_win32) && !defined(__GNUC__) + +typedef + struct { + unsigned int nraddr; /* where's the code? */ + } + OrigFn; + +#if defined(_MSC_VER) + +#define __SPECIAL_INSTRUCTION_PREAMBLE \ + __asm rol edi, 3 __asm rol edi, 13 \ + __asm rol edi, 29 __asm rol edi, 19 + +#define VALGRIND_DO_CLIENT_REQUEST_EXPR( \ + _zzq_default, _zzq_request, \ + _zzq_arg1, _zzq_arg2, _zzq_arg3, _zzq_arg4, _zzq_arg5) \ + valgrind_do_client_request_expr((uintptr_t)(_zzq_default), \ + (uintptr_t)(_zzq_request), (uintptr_t)(_zzq_arg1), \ + (uintptr_t)(_zzq_arg2), (uintptr_t)(_zzq_arg3), \ + (uintptr_t)(_zzq_arg4), (uintptr_t)(_zzq_arg5)) + +static __inline uintptr_t +valgrind_do_client_request_expr(uintptr_t _zzq_default, uintptr_t _zzq_request, + uintptr_t _zzq_arg1, uintptr_t _zzq_arg2, + uintptr_t _zzq_arg3, uintptr_t _zzq_arg4, + uintptr_t _zzq_arg5) +{ + volatile uintptr_t _zzq_args[6]; + volatile unsigned int _zzq_result; + _zzq_args[0] = (uintptr_t)(_zzq_request); + _zzq_args[1] = (uintptr_t)(_zzq_arg1); + _zzq_args[2] = (uintptr_t)(_zzq_arg2); + _zzq_args[3] = (uintptr_t)(_zzq_arg3); + _zzq_args[4] = (uintptr_t)(_zzq_arg4); + _zzq_args[5] = (uintptr_t)(_zzq_arg5); + __asm { __asm lea eax, _zzq_args __asm mov edx, _zzq_default + __SPECIAL_INSTRUCTION_PREAMBLE + /* %EDX = client_request ( %EAX ) */ + __asm xchg ebx,ebx + __asm mov _zzq_result, edx + } + return _zzq_result; +} + +#define VALGRIND_GET_NR_CONTEXT(_zzq_rlval) \ + { volatile OrigFn* _zzq_orig = &(_zzq_rlval); \ + volatile unsigned int __addr; \ + __asm { __SPECIAL_INSTRUCTION_PREAMBLE \ + /* %EAX = guest_NRADDR */ \ + __asm xchg ecx,ecx \ + __asm mov __addr, eax \ + } \ + _zzq_orig->nraddr = __addr; \ + } + +#define VALGRIND_CALL_NOREDIR_EAX ERROR + +#define VALGRIND_VEX_INJECT_IR() \ + do { \ + __asm { __SPECIAL_INSTRUCTION_PREAMBLE \ + __asm xchg edi,edi \ + } \ + } while (0) + +#else +#error Unsupported compiler. +#endif + +#endif /* PLAT_x86_win32 */ + +/* ----------------- amd64-{linux,darwin,solaris} --------------- */ + +#if defined(PLAT_amd64_linux) || defined(PLAT_amd64_darwin) \ + || defined(PLAT_amd64_solaris) \ + || (defined(PLAT_amd64_win64) && defined(__GNUC__)) + +typedef + struct { + unsigned long int nraddr; /* where's the code? */ + } + OrigFn; + +#define __SPECIAL_INSTRUCTION_PREAMBLE \ + "rolq $3, %%rdi ; rolq $13, %%rdi\n\t" \ + "rolq $61, %%rdi ; rolq $51, %%rdi\n\t" + +#define VALGRIND_DO_CLIENT_REQUEST_EXPR( \ + _zzq_default, _zzq_request, \ + _zzq_arg1, _zzq_arg2, _zzq_arg3, _zzq_arg4, _zzq_arg5) \ + __extension__ \ + ({ volatile unsigned long int _zzq_args[6]; \ + volatile unsigned long int _zzq_result; \ + _zzq_args[0] = (unsigned long int)(_zzq_request); \ + _zzq_args[1] = (unsigned long int)(_zzq_arg1); \ + _zzq_args[2] = (unsigned long int)(_zzq_arg2); \ + _zzq_args[3] = (unsigned long int)(_zzq_arg3); \ + _zzq_args[4] = (unsigned long int)(_zzq_arg4); \ + _zzq_args[5] = (unsigned long int)(_zzq_arg5); \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + /* %RDX = client_request ( %RAX ) */ \ + "xchgq %%rbx,%%rbx" \ + : "=d" (_zzq_result) \ + : "a" (&_zzq_args[0]), "0" (_zzq_default) \ + : "cc", "memory" \ + ); \ + _zzq_result; \ + }) + +#define VALGRIND_GET_NR_CONTEXT(_zzq_rlval) \ + { volatile OrigFn* _zzq_orig = &(_zzq_rlval); \ + volatile unsigned long int __addr; \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + /* %RAX = guest_NRADDR */ \ + "xchgq %%rcx,%%rcx" \ + : "=a" (__addr) \ + : \ + : "cc", "memory" \ + ); \ + _zzq_orig->nraddr = __addr; \ + } + +#define VALGRIND_CALL_NOREDIR_RAX \ + __SPECIAL_INSTRUCTION_PREAMBLE \ + /* call-noredir *%RAX */ \ + "xchgq %%rdx,%%rdx\n\t" + +#define VALGRIND_VEX_INJECT_IR() \ + do { \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + "xchgq %%rdi,%%rdi\n\t" \ + : : : "cc", "memory" \ + ); \ + } while (0) + +#endif /* PLAT_amd64_linux || PLAT_amd64_darwin || PLAT_amd64_solaris */ + +/* ------------------------- amd64-Win64 ------------------------- */ + +#if defined(PLAT_amd64_win64) && !defined(__GNUC__) + +#error Unsupported compiler. + +#endif /* PLAT_amd64_win64 */ + +/* ------------------------ ppc32-linux ------------------------ */ + +#if defined(PLAT_ppc32_linux) + +typedef + struct { + unsigned int nraddr; /* where's the code? */ + } + OrigFn; + +#define __SPECIAL_INSTRUCTION_PREAMBLE \ + "rlwinm 0,0,3,0,31 ; rlwinm 0,0,13,0,31\n\t" \ + "rlwinm 0,0,29,0,31 ; rlwinm 0,0,19,0,31\n\t" + +#define VALGRIND_DO_CLIENT_REQUEST_EXPR( \ + _zzq_default, _zzq_request, \ + _zzq_arg1, _zzq_arg2, _zzq_arg3, _zzq_arg4, _zzq_arg5) \ + \ + __extension__ \ + ({ unsigned int _zzq_args[6]; \ + unsigned int _zzq_result; \ + unsigned int* _zzq_ptr; \ + _zzq_args[0] = (unsigned int)(_zzq_request); \ + _zzq_args[1] = (unsigned int)(_zzq_arg1); \ + _zzq_args[2] = (unsigned int)(_zzq_arg2); \ + _zzq_args[3] = (unsigned int)(_zzq_arg3); \ + _zzq_args[4] = (unsigned int)(_zzq_arg4); \ + _zzq_args[5] = (unsigned int)(_zzq_arg5); \ + _zzq_ptr = _zzq_args; \ + __asm__ volatile("mr 3,%1\n\t" /*default*/ \ + "mr 4,%2\n\t" /*ptr*/ \ + __SPECIAL_INSTRUCTION_PREAMBLE \ + /* %R3 = client_request ( %R4 ) */ \ + "or 1,1,1\n\t" \ + "mr %0,3" /*result*/ \ + : "=b" (_zzq_result) \ + : "b" (_zzq_default), "b" (_zzq_ptr) \ + : "cc", "memory", "r3", "r4"); \ + _zzq_result; \ + }) + +#define VALGRIND_GET_NR_CONTEXT(_zzq_rlval) \ + { volatile OrigFn* _zzq_orig = &(_zzq_rlval); \ + unsigned int __addr; \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + /* %R3 = guest_NRADDR */ \ + "or 2,2,2\n\t" \ + "mr %0,3" \ + : "=b" (__addr) \ + : \ + : "cc", "memory", "r3" \ + ); \ + _zzq_orig->nraddr = __addr; \ + } + +#define VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + __SPECIAL_INSTRUCTION_PREAMBLE \ + /* branch-and-link-to-noredir *%R11 */ \ + "or 3,3,3\n\t" + +#define VALGRIND_VEX_INJECT_IR() \ + do { \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + "or 5,5,5\n\t" \ + ); \ + } while (0) + +#endif /* PLAT_ppc32_linux */ + +/* ------------------------ ppc64-linux ------------------------ */ + +#if defined(PLAT_ppc64be_linux) + +typedef + struct { + unsigned long int nraddr; /* where's the code? */ + unsigned long int r2; /* what tocptr do we need? */ + } + OrigFn; + +#define __SPECIAL_INSTRUCTION_PREAMBLE \ + "rotldi 0,0,3 ; rotldi 0,0,13\n\t" \ + "rotldi 0,0,61 ; rotldi 0,0,51\n\t" + +#define VALGRIND_DO_CLIENT_REQUEST_EXPR( \ + _zzq_default, _zzq_request, \ + _zzq_arg1, _zzq_arg2, _zzq_arg3, _zzq_arg4, _zzq_arg5) \ + \ + __extension__ \ + ({ unsigned long int _zzq_args[6]; \ + unsigned long int _zzq_result; \ + unsigned long int* _zzq_ptr; \ + _zzq_args[0] = (unsigned long int)(_zzq_request); \ + _zzq_args[1] = (unsigned long int)(_zzq_arg1); \ + _zzq_args[2] = (unsigned long int)(_zzq_arg2); \ + _zzq_args[3] = (unsigned long int)(_zzq_arg3); \ + _zzq_args[4] = (unsigned long int)(_zzq_arg4); \ + _zzq_args[5] = (unsigned long int)(_zzq_arg5); \ + _zzq_ptr = _zzq_args; \ + __asm__ volatile("mr 3,%1\n\t" /*default*/ \ + "mr 4,%2\n\t" /*ptr*/ \ + __SPECIAL_INSTRUCTION_PREAMBLE \ + /* %R3 = client_request ( %R4 ) */ \ + "or 1,1,1\n\t" \ + "mr %0,3" /*result*/ \ + : "=b" (_zzq_result) \ + : "b" (_zzq_default), "b" (_zzq_ptr) \ + : "cc", "memory", "r3", "r4"); \ + _zzq_result; \ + }) + +#define VALGRIND_GET_NR_CONTEXT(_zzq_rlval) \ + { volatile OrigFn* _zzq_orig = &(_zzq_rlval); \ + unsigned long int __addr; \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + /* %R3 = guest_NRADDR */ \ + "or 2,2,2\n\t" \ + "mr %0,3" \ + : "=b" (__addr) \ + : \ + : "cc", "memory", "r3" \ + ); \ + _zzq_orig->nraddr = __addr; \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + /* %R3 = guest_NRADDR_GPR2 */ \ + "or 4,4,4\n\t" \ + "mr %0,3" \ + : "=b" (__addr) \ + : \ + : "cc", "memory", "r3" \ + ); \ + _zzq_orig->r2 = __addr; \ + } + +#define VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + __SPECIAL_INSTRUCTION_PREAMBLE \ + /* branch-and-link-to-noredir *%R11 */ \ + "or 3,3,3\n\t" + +#define VALGRIND_VEX_INJECT_IR() \ + do { \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + "or 5,5,5\n\t" \ + ); \ + } while (0) + +#endif /* PLAT_ppc64be_linux */ + +#if defined(PLAT_ppc64le_linux) + +typedef + struct { + unsigned long int nraddr; /* where's the code? */ + unsigned long int r2; /* what tocptr do we need? */ + } + OrigFn; + +#define __SPECIAL_INSTRUCTION_PREAMBLE \ + "rotldi 0,0,3 ; rotldi 0,0,13\n\t" \ + "rotldi 0,0,61 ; rotldi 0,0,51\n\t" + +#define VALGRIND_DO_CLIENT_REQUEST_EXPR( \ + _zzq_default, _zzq_request, \ + _zzq_arg1, _zzq_arg2, _zzq_arg3, _zzq_arg4, _zzq_arg5) \ + \ + __extension__ \ + ({ unsigned long int _zzq_args[6]; \ + unsigned long int _zzq_result; \ + unsigned long int* _zzq_ptr; \ + _zzq_args[0] = (unsigned long int)(_zzq_request); \ + _zzq_args[1] = (unsigned long int)(_zzq_arg1); \ + _zzq_args[2] = (unsigned long int)(_zzq_arg2); \ + _zzq_args[3] = (unsigned long int)(_zzq_arg3); \ + _zzq_args[4] = (unsigned long int)(_zzq_arg4); \ + _zzq_args[5] = (unsigned long int)(_zzq_arg5); \ + _zzq_ptr = _zzq_args; \ + __asm__ volatile("mr 3,%1\n\t" /*default*/ \ + "mr 4,%2\n\t" /*ptr*/ \ + __SPECIAL_INSTRUCTION_PREAMBLE \ + /* %R3 = client_request ( %R4 ) */ \ + "or 1,1,1\n\t" \ + "mr %0,3" /*result*/ \ + : "=b" (_zzq_result) \ + : "b" (_zzq_default), "b" (_zzq_ptr) \ + : "cc", "memory", "r3", "r4"); \ + _zzq_result; \ + }) + +#define VALGRIND_GET_NR_CONTEXT(_zzq_rlval) \ + { volatile OrigFn* _zzq_orig = &(_zzq_rlval); \ + unsigned long int __addr; \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + /* %R3 = guest_NRADDR */ \ + "or 2,2,2\n\t" \ + "mr %0,3" \ + : "=b" (__addr) \ + : \ + : "cc", "memory", "r3" \ + ); \ + _zzq_orig->nraddr = __addr; \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + /* %R3 = guest_NRADDR_GPR2 */ \ + "or 4,4,4\n\t" \ + "mr %0,3" \ + : "=b" (__addr) \ + : \ + : "cc", "memory", "r3" \ + ); \ + _zzq_orig->r2 = __addr; \ + } + +#define VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R12 \ + __SPECIAL_INSTRUCTION_PREAMBLE \ + /* branch-and-link-to-noredir *%R12 */ \ + "or 3,3,3\n\t" + +#define VALGRIND_VEX_INJECT_IR() \ + do { \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + "or 5,5,5\n\t" \ + ); \ + } while (0) + +#endif /* PLAT_ppc64le_linux */ + +/* ------------------------- arm-linux ------------------------- */ + +#if defined(PLAT_arm_linux) + +typedef + struct { + unsigned int nraddr; /* where's the code? */ + } + OrigFn; + +#define __SPECIAL_INSTRUCTION_PREAMBLE \ + "mov r12, r12, ror #3 ; mov r12, r12, ror #13 \n\t" \ + "mov r12, r12, ror #29 ; mov r12, r12, ror #19 \n\t" + +#define VALGRIND_DO_CLIENT_REQUEST_EXPR( \ + _zzq_default, _zzq_request, \ + _zzq_arg1, _zzq_arg2, _zzq_arg3, _zzq_arg4, _zzq_arg5) \ + \ + __extension__ \ + ({volatile unsigned int _zzq_args[6]; \ + volatile unsigned int _zzq_result; \ + _zzq_args[0] = (unsigned int)(_zzq_request); \ + _zzq_args[1] = (unsigned int)(_zzq_arg1); \ + _zzq_args[2] = (unsigned int)(_zzq_arg2); \ + _zzq_args[3] = (unsigned int)(_zzq_arg3); \ + _zzq_args[4] = (unsigned int)(_zzq_arg4); \ + _zzq_args[5] = (unsigned int)(_zzq_arg5); \ + __asm__ volatile("mov r3, %1\n\t" /*default*/ \ + "mov r4, %2\n\t" /*ptr*/ \ + __SPECIAL_INSTRUCTION_PREAMBLE \ + /* R3 = client_request ( R4 ) */ \ + "orr r10, r10, r10\n\t" \ + "mov %0, r3" /*result*/ \ + : "=r" (_zzq_result) \ + : "r" (_zzq_default), "r" (&_zzq_args[0]) \ + : "cc","memory", "r3", "r4"); \ + _zzq_result; \ + }) + +#define VALGRIND_GET_NR_CONTEXT(_zzq_rlval) \ + { volatile OrigFn* _zzq_orig = &(_zzq_rlval); \ + unsigned int __addr; \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + /* R3 = guest_NRADDR */ \ + "orr r11, r11, r11\n\t" \ + "mov %0, r3" \ + : "=r" (__addr) \ + : \ + : "cc", "memory", "r3" \ + ); \ + _zzq_orig->nraddr = __addr; \ + } + +#define VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R4 \ + __SPECIAL_INSTRUCTION_PREAMBLE \ + /* branch-and-link-to-noredir *%R4 */ \ + "orr r12, r12, r12\n\t" + +#define VALGRIND_VEX_INJECT_IR() \ + do { \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + "orr r9, r9, r9\n\t" \ + : : : "cc", "memory" \ + ); \ + } while (0) + +#endif /* PLAT_arm_linux */ + +/* ------------------------ arm64-linux ------------------------- */ + +#if defined(PLAT_arm64_linux) + +typedef + struct { + unsigned long int nraddr; /* where's the code? */ + } + OrigFn; + +#define __SPECIAL_INSTRUCTION_PREAMBLE \ + "ror x12, x12, #3 ; ror x12, x12, #13 \n\t" \ + "ror x12, x12, #51 ; ror x12, x12, #61 \n\t" + +#define VALGRIND_DO_CLIENT_REQUEST_EXPR( \ + _zzq_default, _zzq_request, \ + _zzq_arg1, _zzq_arg2, _zzq_arg3, _zzq_arg4, _zzq_arg5) \ + \ + __extension__ \ + ({volatile unsigned long int _zzq_args[6]; \ + volatile unsigned long int _zzq_result; \ + _zzq_args[0] = (unsigned long int)(_zzq_request); \ + _zzq_args[1] = (unsigned long int)(_zzq_arg1); \ + _zzq_args[2] = (unsigned long int)(_zzq_arg2); \ + _zzq_args[3] = (unsigned long int)(_zzq_arg3); \ + _zzq_args[4] = (unsigned long int)(_zzq_arg4); \ + _zzq_args[5] = (unsigned long int)(_zzq_arg5); \ + __asm__ volatile("mov x3, %1\n\t" /*default*/ \ + "mov x4, %2\n\t" /*ptr*/ \ + __SPECIAL_INSTRUCTION_PREAMBLE \ + /* X3 = client_request ( X4 ) */ \ + "orr x10, x10, x10\n\t" \ + "mov %0, x3" /*result*/ \ + : "=r" (_zzq_result) \ + : "r" ((unsigned long int)(_zzq_default)), \ + "r" (&_zzq_args[0]) \ + : "cc","memory", "x3", "x4"); \ + _zzq_result; \ + }) + +#define VALGRIND_GET_NR_CONTEXT(_zzq_rlval) \ + { volatile OrigFn* _zzq_orig = &(_zzq_rlval); \ + unsigned long int __addr; \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + /* X3 = guest_NRADDR */ \ + "orr x11, x11, x11\n\t" \ + "mov %0, x3" \ + : "=r" (__addr) \ + : \ + : "cc", "memory", "x3" \ + ); \ + _zzq_orig->nraddr = __addr; \ + } + +#define VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_X8 \ + __SPECIAL_INSTRUCTION_PREAMBLE \ + /* branch-and-link-to-noredir X8 */ \ + "orr x12, x12, x12\n\t" + +#define VALGRIND_VEX_INJECT_IR() \ + do { \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + "orr x9, x9, x9\n\t" \ + : : : "cc", "memory" \ + ); \ + } while (0) + +#endif /* PLAT_arm64_linux */ + +/* ------------------------ s390x-linux ------------------------ */ + +#if defined(PLAT_s390x_linux) + +typedef + struct { + unsigned long int nraddr; /* where's the code? */ + } + OrigFn; + +/* __SPECIAL_INSTRUCTION_PREAMBLE will be used to identify Valgrind specific + * code. This detection is implemented in platform specific toIR.c + * (e.g. VEX/priv/guest_s390_decoder.c). + */ +#define __SPECIAL_INSTRUCTION_PREAMBLE \ + "lr 15,15\n\t" \ + "lr 1,1\n\t" \ + "lr 2,2\n\t" \ + "lr 3,3\n\t" + +#define __CLIENT_REQUEST_CODE "lr 2,2\n\t" +#define __GET_NR_CONTEXT_CODE "lr 3,3\n\t" +#define __CALL_NO_REDIR_CODE "lr 4,4\n\t" +#define __VEX_INJECT_IR_CODE "lr 5,5\n\t" + +#define VALGRIND_DO_CLIENT_REQUEST_EXPR( \ + _zzq_default, _zzq_request, \ + _zzq_arg1, _zzq_arg2, _zzq_arg3, _zzq_arg4, _zzq_arg5) \ + __extension__ \ + ({volatile unsigned long int _zzq_args[6]; \ + volatile unsigned long int _zzq_result; \ + _zzq_args[0] = (unsigned long int)(_zzq_request); \ + _zzq_args[1] = (unsigned long int)(_zzq_arg1); \ + _zzq_args[2] = (unsigned long int)(_zzq_arg2); \ + _zzq_args[3] = (unsigned long int)(_zzq_arg3); \ + _zzq_args[4] = (unsigned long int)(_zzq_arg4); \ + _zzq_args[5] = (unsigned long int)(_zzq_arg5); \ + __asm__ volatile(/* r2 = args */ \ + "lgr 2,%1\n\t" \ + /* r3 = default */ \ + "lgr 3,%2\n\t" \ + __SPECIAL_INSTRUCTION_PREAMBLE \ + __CLIENT_REQUEST_CODE \ + /* results = r3 */ \ + "lgr %0, 3\n\t" \ + : "=d" (_zzq_result) \ + : "a" (&_zzq_args[0]), "0" (_zzq_default) \ + : "cc", "2", "3", "memory" \ + ); \ + _zzq_result; \ + }) + +#define VALGRIND_GET_NR_CONTEXT(_zzq_rlval) \ + { volatile OrigFn* _zzq_orig = &(_zzq_rlval); \ + volatile unsigned long int __addr; \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + __GET_NR_CONTEXT_CODE \ + "lgr %0, 3\n\t" \ + : "=a" (__addr) \ + : \ + : "cc", "3", "memory" \ + ); \ + _zzq_orig->nraddr = __addr; \ + } + +#define VALGRIND_CALL_NOREDIR_R1 \ + __SPECIAL_INSTRUCTION_PREAMBLE \ + __CALL_NO_REDIR_CODE + +#define VALGRIND_VEX_INJECT_IR() \ + do { \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + __VEX_INJECT_IR_CODE); \ + } while (0) + +#endif /* PLAT_s390x_linux */ + +/* ------------------------- mips32-linux ---------------- */ + +#if defined(PLAT_mips32_linux) + +typedef + struct { + unsigned int nraddr; /* where's the code? */ + } + OrigFn; + +/* .word 0x342 + * .word 0x742 + * .word 0xC2 + * .word 0x4C2*/ +#define __SPECIAL_INSTRUCTION_PREAMBLE \ + "srl $0, $0, 13\n\t" \ + "srl $0, $0, 29\n\t" \ + "srl $0, $0, 3\n\t" \ + "srl $0, $0, 19\n\t" + +#define VALGRIND_DO_CLIENT_REQUEST_EXPR( \ + _zzq_default, _zzq_request, \ + _zzq_arg1, _zzq_arg2, _zzq_arg3, _zzq_arg4, _zzq_arg5) \ + __extension__ \ + ({ volatile unsigned int _zzq_args[6]; \ + volatile unsigned int _zzq_result; \ + _zzq_args[0] = (unsigned int)(_zzq_request); \ + _zzq_args[1] = (unsigned int)(_zzq_arg1); \ + _zzq_args[2] = (unsigned int)(_zzq_arg2); \ + _zzq_args[3] = (unsigned int)(_zzq_arg3); \ + _zzq_args[4] = (unsigned int)(_zzq_arg4); \ + _zzq_args[5] = (unsigned int)(_zzq_arg5); \ + __asm__ volatile("move $11, %1\n\t" /*default*/ \ + "move $12, %2\n\t" /*ptr*/ \ + __SPECIAL_INSTRUCTION_PREAMBLE \ + /* T3 = client_request ( T4 ) */ \ + "or $13, $13, $13\n\t" \ + "move %0, $11\n\t" /*result*/ \ + : "=r" (_zzq_result) \ + : "r" (_zzq_default), "r" (&_zzq_args[0]) \ + : "$11", "$12", "memory"); \ + _zzq_result; \ + }) + +#define VALGRIND_GET_NR_CONTEXT(_zzq_rlval) \ + { volatile OrigFn* _zzq_orig = &(_zzq_rlval); \ + volatile unsigned int __addr; \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + /* %t9 = guest_NRADDR */ \ + "or $14, $14, $14\n\t" \ + "move %0, $11" /*result*/ \ + : "=r" (__addr) \ + : \ + : "$11" \ + ); \ + _zzq_orig->nraddr = __addr; \ + } + +#define VALGRIND_CALL_NOREDIR_T9 \ + __SPECIAL_INSTRUCTION_PREAMBLE \ + /* call-noredir *%t9 */ \ + "or $15, $15, $15\n\t" + +#define VALGRIND_VEX_INJECT_IR() \ + do { \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + "or $11, $11, $11\n\t" \ + ); \ + } while (0) + + +#endif /* PLAT_mips32_linux */ + +/* ------------------------- mips64-linux ---------------- */ + +#if defined(PLAT_mips64_linux) + +typedef + struct { + unsigned long nraddr; /* where's the code? */ + } + OrigFn; + +/* dsll $0,$0, 3 + * dsll $0,$0, 13 + * dsll $0,$0, 29 + * dsll $0,$0, 19*/ +#define __SPECIAL_INSTRUCTION_PREAMBLE \ + "dsll $0,$0, 3 ; dsll $0,$0,13\n\t" \ + "dsll $0,$0,29 ; dsll $0,$0,19\n\t" + +#define VALGRIND_DO_CLIENT_REQUEST_EXPR( \ + _zzq_default, _zzq_request, \ + _zzq_arg1, _zzq_arg2, _zzq_arg3, _zzq_arg4, _zzq_arg5) \ + __extension__ \ + ({ volatile unsigned long int _zzq_args[6]; \ + volatile unsigned long int _zzq_result; \ + _zzq_args[0] = (unsigned long int)(_zzq_request); \ + _zzq_args[1] = (unsigned long int)(_zzq_arg1); \ + _zzq_args[2] = (unsigned long int)(_zzq_arg2); \ + _zzq_args[3] = (unsigned long int)(_zzq_arg3); \ + _zzq_args[4] = (unsigned long int)(_zzq_arg4); \ + _zzq_args[5] = (unsigned long int)(_zzq_arg5); \ + __asm__ volatile("move $11, %1\n\t" /*default*/ \ + "move $12, %2\n\t" /*ptr*/ \ + __SPECIAL_INSTRUCTION_PREAMBLE \ + /* $11 = client_request ( $12 ) */ \ + "or $13, $13, $13\n\t" \ + "move %0, $11\n\t" /*result*/ \ + : "=r" (_zzq_result) \ + : "r" (_zzq_default), "r" (&_zzq_args[0]) \ + : "$11", "$12", "memory"); \ + _zzq_result; \ + }) + +#define VALGRIND_GET_NR_CONTEXT(_zzq_rlval) \ + { volatile OrigFn* _zzq_orig = &(_zzq_rlval); \ + volatile unsigned long int __addr; \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + /* $11 = guest_NRADDR */ \ + "or $14, $14, $14\n\t" \ + "move %0, $11" /*result*/ \ + : "=r" (__addr) \ + : \ + : "$11"); \ + _zzq_orig->nraddr = __addr; \ + } + +#define VALGRIND_CALL_NOREDIR_T9 \ + __SPECIAL_INSTRUCTION_PREAMBLE \ + /* call-noredir $25 */ \ + "or $15, $15, $15\n\t" + +#define VALGRIND_VEX_INJECT_IR() \ + do { \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + "or $11, $11, $11\n\t" \ + ); \ + } while (0) + +#endif /* PLAT_mips64_linux */ + +#if defined(PLAT_nanomips_linux) + +typedef + struct { + unsigned int nraddr; /* where's the code? */ + } + OrigFn; +/* + 8000 c04d srl zero, zero, 13 + 8000 c05d srl zero, zero, 29 + 8000 c043 srl zero, zero, 3 + 8000 c053 srl zero, zero, 19 +*/ + +#define __SPECIAL_INSTRUCTION_PREAMBLE "srl[32] $zero, $zero, 13 \n\t" \ + "srl[32] $zero, $zero, 29 \n\t" \ + "srl[32] $zero, $zero, 3 \n\t" \ + "srl[32] $zero, $zero, 19 \n\t" + +#define VALGRIND_DO_CLIENT_REQUEST_EXPR( \ + _zzq_default, _zzq_request, \ + _zzq_arg1, _zzq_arg2, _zzq_arg3, _zzq_arg4, _zzq_arg5) \ + __extension__ \ + ({ volatile unsigned int _zzq_args[6]; \ + volatile unsigned int _zzq_result; \ + _zzq_args[0] = (unsigned int)(_zzq_request); \ + _zzq_args[1] = (unsigned int)(_zzq_arg1); \ + _zzq_args[2] = (unsigned int)(_zzq_arg2); \ + _zzq_args[3] = (unsigned int)(_zzq_arg3); \ + _zzq_args[4] = (unsigned int)(_zzq_arg4); \ + _zzq_args[5] = (unsigned int)(_zzq_arg5); \ + __asm__ volatile("move $a7, %1\n\t" /* default */ \ + "move $t0, %2\n\t" /* ptr */ \ + __SPECIAL_INSTRUCTION_PREAMBLE \ + /* $a7 = client_request( $t0 ) */ \ + "or[32] $t0, $t0, $t0\n\t" \ + "move %0, $a7\n\t" /* result */ \ + : "=r" (_zzq_result) \ + : "r" (_zzq_default), "r" (&_zzq_args[0]) \ + : "$a7", "$t0", "memory"); \ + _zzq_result; \ + }) + +#define VALGRIND_GET_NR_CONTEXT(_zzq_rlval) \ + { volatile OrigFn* _zzq_orig = &(_zzq_rlval); \ + volatile unsigned long int __addr; \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + /* $a7 = guest_NRADDR */ \ + "or[32] $t1, $t1, $t1\n\t" \ + "move %0, $a7" /*result*/ \ + : "=r" (__addr) \ + : \ + : "$a7"); \ + _zzq_orig->nraddr = __addr; \ + } + +#define VALGRIND_CALL_NOREDIR_T9 \ + __SPECIAL_INSTRUCTION_PREAMBLE \ + /* call-noredir $25 */ \ + "or[32] $t2, $t2, $t2\n\t" + +#define VALGRIND_VEX_INJECT_IR() \ + do { \ + __asm__ volatile(__SPECIAL_INSTRUCTION_PREAMBLE \ + "or[32] $t3, $t3, $t3\n\t" \ + ); \ + } while (0) + +#endif +/* Insert assembly code for other platforms here... */ + +#endif /* CONFIG_VALGRIND */ + + +/* ------------------------------------------------------------------ */ +/* PLATFORM SPECIFICS for FUNCTION WRAPPING. This is all very */ +/* ugly. It's the least-worst tradeoff I can think of. */ +/* ------------------------------------------------------------------ */ + +/* This section defines magic (a.k.a appalling-hack) macros for doing + guaranteed-no-redirection macros, so as to get from function + wrappers to the functions they are wrapping. The whole point is to + construct standard call sequences, but to do the call itself with a + special no-redirect call pseudo-instruction that the JIT + understands and handles specially. This section is long and + repetitious, and I can't see a way to make it shorter. + + The naming scheme is as follows: + + CALL_FN_{W,v}_{v,W,WW,WWW,WWWW,5W,6W,7W,etc} + + 'W' stands for "word" and 'v' for "void". Hence there are + different macros for calling arity 0, 1, 2, 3, 4, etc, functions, + and for each, the possibility of returning a word-typed result, or + no result. +*/ + +/* Use these to write the name of your wrapper. NOTE: duplicates + VG_WRAP_FUNCTION_Z{U,Z} in pub_tool_redir.h. NOTE also: inserts + the default behaviour equivalance class tag "0000" into the name. + See pub_tool_redir.h for details -- normally you don't need to + think about this, though. */ + +/* Use an extra level of macroisation so as to ensure the soname/fnname + args are fully macro-expanded before pasting them together. */ +#define VG_CONCAT4(_aa,_bb,_cc,_dd) _aa##_bb##_cc##_dd + +#define I_WRAP_SONAME_FNNAME_ZU(soname,fnname) \ + VG_CONCAT4(_vgw00000ZU_,soname,_,fnname) + +#define I_WRAP_SONAME_FNNAME_ZZ(soname,fnname) \ + VG_CONCAT4(_vgw00000ZZ_,soname,_,fnname) + +/* Use this macro from within a wrapper function to collect the + context (address and possibly other info) of the original function. + Once you have that you can then use it in one of the CALL_FN_ + macros. The type of the argument _lval is OrigFn. */ +#define VALGRIND_GET_ORIG_FN(_lval) VALGRIND_GET_NR_CONTEXT(_lval) + +/* Also provide end-user facilities for function replacement, rather + than wrapping. A replacement function differs from a wrapper in + that it has no way to get hold of the original function being + called, and hence no way to call onwards to it. In a replacement + function, VALGRIND_GET_ORIG_FN always returns zero. */ + +#define I_REPLACE_SONAME_FNNAME_ZU(soname,fnname) \ + VG_CONCAT4(_vgr00000ZU_,soname,_,fnname) + +#define I_REPLACE_SONAME_FNNAME_ZZ(soname,fnname) \ + VG_CONCAT4(_vgr00000ZZ_,soname,_,fnname) + +/* Derivatives of the main macros below, for calling functions + returning void. */ + +#define CALL_FN_v_v(fnptr) \ + do { volatile unsigned long _junk; \ + CALL_FN_W_v(_junk,fnptr); } while (0) + +#define CALL_FN_v_W(fnptr, arg1) \ + do { volatile unsigned long _junk; \ + CALL_FN_W_W(_junk,fnptr,arg1); } while (0) + +#define CALL_FN_v_WW(fnptr, arg1,arg2) \ + do { volatile unsigned long _junk; \ + CALL_FN_W_WW(_junk,fnptr,arg1,arg2); } while (0) + +#define CALL_FN_v_WWW(fnptr, arg1,arg2,arg3) \ + do { volatile unsigned long _junk; \ + CALL_FN_W_WWW(_junk,fnptr,arg1,arg2,arg3); } while (0) + +#define CALL_FN_v_WWWW(fnptr, arg1,arg2,arg3,arg4) \ + do { volatile unsigned long _junk; \ + CALL_FN_W_WWWW(_junk,fnptr,arg1,arg2,arg3,arg4); } while (0) + +#define CALL_FN_v_5W(fnptr, arg1,arg2,arg3,arg4,arg5) \ + do { volatile unsigned long _junk; \ + CALL_FN_W_5W(_junk,fnptr,arg1,arg2,arg3,arg4,arg5); } while (0) + +#define CALL_FN_v_6W(fnptr, arg1,arg2,arg3,arg4,arg5,arg6) \ + do { volatile unsigned long _junk; \ + CALL_FN_W_6W(_junk,fnptr,arg1,arg2,arg3,arg4,arg5,arg6); } while (0) + +#define CALL_FN_v_7W(fnptr, arg1,arg2,arg3,arg4,arg5,arg6,arg7) \ + do { volatile unsigned long _junk; \ + CALL_FN_W_7W(_junk,fnptr,arg1,arg2,arg3,arg4,arg5,arg6,arg7); } while (0) + +/* ----------------- x86-{linux,darwin,solaris} ---------------- */ + +#if defined(PLAT_x86_linux) || defined(PLAT_x86_darwin) \ + || defined(PLAT_x86_solaris) + +/* These regs are trashed by the hidden call. No need to mention eax + as gcc can already see that, plus causes gcc to bomb. */ +#define __CALLER_SAVED_REGS /*"eax"*/ "ecx", "edx" + +/* Macros to save and align the stack before making a function + call and restore it afterwards as gcc may not keep the stack + pointer aligned if it doesn't realise calls are being made + to other functions. */ + +#define VALGRIND_ALIGN_STACK \ + "movl %%esp,%%edi\n\t" \ + "andl $0xfffffff0,%%esp\n\t" +#define VALGRIND_RESTORE_STACK \ + "movl %%edi,%%esp\n\t" + +/* These CALL_FN_ macros assume that on x86-linux, sizeof(unsigned + long) == 4. */ + +#define CALL_FN_W_v(lval, orig) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[1]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "movl (%%eax), %%eax\n\t" /* target->%eax */ \ + VALGRIND_CALL_NOREDIR_EAX \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "edi" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_W(lval, orig, arg1) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[2]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "subl $12, %%esp\n\t" \ + "pushl 4(%%eax)\n\t" \ + "movl (%%eax), %%eax\n\t" /* target->%eax */ \ + VALGRIND_CALL_NOREDIR_EAX \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "edi" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WW(lval, orig, arg1,arg2) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "subl $8, %%esp\n\t" \ + "pushl 8(%%eax)\n\t" \ + "pushl 4(%%eax)\n\t" \ + "movl (%%eax), %%eax\n\t" /* target->%eax */ \ + VALGRIND_CALL_NOREDIR_EAX \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "edi" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WWW(lval, orig, arg1,arg2,arg3) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[4]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "subl $4, %%esp\n\t" \ + "pushl 12(%%eax)\n\t" \ + "pushl 8(%%eax)\n\t" \ + "pushl 4(%%eax)\n\t" \ + "movl (%%eax), %%eax\n\t" /* target->%eax */ \ + VALGRIND_CALL_NOREDIR_EAX \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "edi" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WWWW(lval, orig, arg1,arg2,arg3,arg4) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[5]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "pushl 16(%%eax)\n\t" \ + "pushl 12(%%eax)\n\t" \ + "pushl 8(%%eax)\n\t" \ + "pushl 4(%%eax)\n\t" \ + "movl (%%eax), %%eax\n\t" /* target->%eax */ \ + VALGRIND_CALL_NOREDIR_EAX \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "edi" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_5W(lval, orig, arg1,arg2,arg3,arg4,arg5) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[6]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "subl $12, %%esp\n\t" \ + "pushl 20(%%eax)\n\t" \ + "pushl 16(%%eax)\n\t" \ + "pushl 12(%%eax)\n\t" \ + "pushl 8(%%eax)\n\t" \ + "pushl 4(%%eax)\n\t" \ + "movl (%%eax), %%eax\n\t" /* target->%eax */ \ + VALGRIND_CALL_NOREDIR_EAX \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "edi" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_6W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[7]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "subl $8, %%esp\n\t" \ + "pushl 24(%%eax)\n\t" \ + "pushl 20(%%eax)\n\t" \ + "pushl 16(%%eax)\n\t" \ + "pushl 12(%%eax)\n\t" \ + "pushl 8(%%eax)\n\t" \ + "pushl 4(%%eax)\n\t" \ + "movl (%%eax), %%eax\n\t" /* target->%eax */ \ + VALGRIND_CALL_NOREDIR_EAX \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "edi" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_7W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[8]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "subl $4, %%esp\n\t" \ + "pushl 28(%%eax)\n\t" \ + "pushl 24(%%eax)\n\t" \ + "pushl 20(%%eax)\n\t" \ + "pushl 16(%%eax)\n\t" \ + "pushl 12(%%eax)\n\t" \ + "pushl 8(%%eax)\n\t" \ + "pushl 4(%%eax)\n\t" \ + "movl (%%eax), %%eax\n\t" /* target->%eax */ \ + VALGRIND_CALL_NOREDIR_EAX \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "edi" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_8W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[9]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "pushl 32(%%eax)\n\t" \ + "pushl 28(%%eax)\n\t" \ + "pushl 24(%%eax)\n\t" \ + "pushl 20(%%eax)\n\t" \ + "pushl 16(%%eax)\n\t" \ + "pushl 12(%%eax)\n\t" \ + "pushl 8(%%eax)\n\t" \ + "pushl 4(%%eax)\n\t" \ + "movl (%%eax), %%eax\n\t" /* target->%eax */ \ + VALGRIND_CALL_NOREDIR_EAX \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "edi" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_9W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[10]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + _argvec[9] = (unsigned long)(arg9); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "subl $12, %%esp\n\t" \ + "pushl 36(%%eax)\n\t" \ + "pushl 32(%%eax)\n\t" \ + "pushl 28(%%eax)\n\t" \ + "pushl 24(%%eax)\n\t" \ + "pushl 20(%%eax)\n\t" \ + "pushl 16(%%eax)\n\t" \ + "pushl 12(%%eax)\n\t" \ + "pushl 8(%%eax)\n\t" \ + "pushl 4(%%eax)\n\t" \ + "movl (%%eax), %%eax\n\t" /* target->%eax */ \ + VALGRIND_CALL_NOREDIR_EAX \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "edi" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_10W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9,arg10) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[11]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + _argvec[9] = (unsigned long)(arg9); \ + _argvec[10] = (unsigned long)(arg10); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "subl $8, %%esp\n\t" \ + "pushl 40(%%eax)\n\t" \ + "pushl 36(%%eax)\n\t" \ + "pushl 32(%%eax)\n\t" \ + "pushl 28(%%eax)\n\t" \ + "pushl 24(%%eax)\n\t" \ + "pushl 20(%%eax)\n\t" \ + "pushl 16(%%eax)\n\t" \ + "pushl 12(%%eax)\n\t" \ + "pushl 8(%%eax)\n\t" \ + "pushl 4(%%eax)\n\t" \ + "movl (%%eax), %%eax\n\t" /* target->%eax */ \ + VALGRIND_CALL_NOREDIR_EAX \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "edi" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_11W(lval, orig, arg1,arg2,arg3,arg4,arg5, \ + arg6,arg7,arg8,arg9,arg10, \ + arg11) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[12]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + _argvec[9] = (unsigned long)(arg9); \ + _argvec[10] = (unsigned long)(arg10); \ + _argvec[11] = (unsigned long)(arg11); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "subl $4, %%esp\n\t" \ + "pushl 44(%%eax)\n\t" \ + "pushl 40(%%eax)\n\t" \ + "pushl 36(%%eax)\n\t" \ + "pushl 32(%%eax)\n\t" \ + "pushl 28(%%eax)\n\t" \ + "pushl 24(%%eax)\n\t" \ + "pushl 20(%%eax)\n\t" \ + "pushl 16(%%eax)\n\t" \ + "pushl 12(%%eax)\n\t" \ + "pushl 8(%%eax)\n\t" \ + "pushl 4(%%eax)\n\t" \ + "movl (%%eax), %%eax\n\t" /* target->%eax */ \ + VALGRIND_CALL_NOREDIR_EAX \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "edi" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_12W(lval, orig, arg1,arg2,arg3,arg4,arg5, \ + arg6,arg7,arg8,arg9,arg10, \ + arg11,arg12) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[13]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + _argvec[9] = (unsigned long)(arg9); \ + _argvec[10] = (unsigned long)(arg10); \ + _argvec[11] = (unsigned long)(arg11); \ + _argvec[12] = (unsigned long)(arg12); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "pushl 48(%%eax)\n\t" \ + "pushl 44(%%eax)\n\t" \ + "pushl 40(%%eax)\n\t" \ + "pushl 36(%%eax)\n\t" \ + "pushl 32(%%eax)\n\t" \ + "pushl 28(%%eax)\n\t" \ + "pushl 24(%%eax)\n\t" \ + "pushl 20(%%eax)\n\t" \ + "pushl 16(%%eax)\n\t" \ + "pushl 12(%%eax)\n\t" \ + "pushl 8(%%eax)\n\t" \ + "pushl 4(%%eax)\n\t" \ + "movl (%%eax), %%eax\n\t" /* target->%eax */ \ + VALGRIND_CALL_NOREDIR_EAX \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "edi" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#endif /* PLAT_x86_linux || PLAT_x86_darwin || PLAT_x86_solaris */ + +/* ---------------- amd64-{linux,darwin,solaris} --------------- */ + +#if defined(PLAT_amd64_linux) || defined(PLAT_amd64_darwin) \ + || defined(PLAT_amd64_solaris) + +/* ARGREGS: rdi rsi rdx rcx r8 r9 (the rest on stack in R-to-L order) */ + +/* These regs are trashed by the hidden call. */ +#define __CALLER_SAVED_REGS /*"rax",*/ "rcx", "rdx", "rsi", \ + "rdi", "r8", "r9", "r10", "r11" + +/* This is all pretty complex. It's so as to make stack unwinding + work reliably. See bug 243270. The basic problem is the sub and + add of 128 of %rsp in all of the following macros. If gcc believes + the CFA is in %rsp, then unwinding may fail, because what's at the + CFA is not what gcc "expected" when it constructs the CFIs for the + places where the macros are instantiated. + + But we can't just add a CFI annotation to increase the CFA offset + by 128, to match the sub of 128 from %rsp, because we don't know + whether gcc has chosen %rsp as the CFA at that point, or whether it + has chosen some other register (eg, %rbp). In the latter case, + adding a CFI annotation to change the CFA offset is simply wrong. + + So the solution is to get hold of the CFA using + __builtin_dwarf_cfa(), put it in a known register, and add a + CFI annotation to say what the register is. We choose %rbp for + this (perhaps perversely), because: + + (1) %rbp is already subject to unwinding. If a new register was + chosen then the unwinder would have to unwind it in all stack + traces, which is expensive, and + + (2) %rbp is already subject to precise exception updates in the + JIT. If a new register was chosen, we'd have to have precise + exceptions for it too, which reduces performance of the + generated code. + + However .. one extra complication. We can't just whack the result + of __builtin_dwarf_cfa() into %rbp and then add %rbp to the + list of trashed registers at the end of the inline assembly + fragments; gcc won't allow %rbp to appear in that list. Hence + instead we need to stash %rbp in %r15 for the duration of the asm, + and say that %r15 is trashed instead. gcc seems happy to go with + that. + + Oh .. and this all needs to be conditionalised so that it is + unchanged from before this commit, when compiled with older gccs + that don't support __builtin_dwarf_cfa. Furthermore, since + this header file is freestanding, it has to be independent of + config.h, and so the following conditionalisation cannot depend on + configure time checks. + + Although it's not clear from + 'defined(__GNUC__) && defined(__GCC_HAVE_DWARF2_CFI_ASM)', + this expression excludes Darwin. + .cfi directives in Darwin assembly appear to be completely + different and I haven't investigated how they work. + + For even more entertainment value, note we have to use the + completely undocumented __builtin_dwarf_cfa(), which appears to + really compute the CFA, whereas __builtin_frame_address(0) claims + to but actually doesn't. See + https://bugs.kde.org/show_bug.cgi?id=243270#c47 +*/ +#if defined(__GNUC__) && defined(__GCC_HAVE_DWARF2_CFI_ASM) +# define __FRAME_POINTER \ + ,"r"(__builtin_dwarf_cfa()) +# define VALGRIND_CFI_PROLOGUE \ + "movq %%rbp, %%r15\n\t" \ + "movq %2, %%rbp\n\t" \ + ".cfi_remember_state\n\t" \ + ".cfi_def_cfa rbp, 0\n\t" +# define VALGRIND_CFI_EPILOGUE \ + "movq %%r15, %%rbp\n\t" \ + ".cfi_restore_state\n\t" +#else +# define __FRAME_POINTER +# define VALGRIND_CFI_PROLOGUE +# define VALGRIND_CFI_EPILOGUE +#endif + +/* Macros to save and align the stack before making a function + call and restore it afterwards as gcc may not keep the stack + pointer aligned if it doesn't realise calls are being made + to other functions. */ + +#define VALGRIND_ALIGN_STACK \ + "movq %%rsp,%%r14\n\t" \ + "andq $0xfffffffffffffff0,%%rsp\n\t" +#define VALGRIND_RESTORE_STACK \ + "movq %%r14,%%rsp\n\t" + +/* These CALL_FN_ macros assume that on amd64-linux, sizeof(unsigned + long) == 8. */ + +/* NB 9 Sept 07. There is a nasty kludge here in all these CALL_FN_ + macros. In order not to trash the stack redzone, we need to drop + %rsp by 128 before the hidden call, and restore afterwards. The + nastyness is that it is only by luck that the stack still appears + to be unwindable during the hidden call - since then the behaviour + of any routine using this macro does not match what the CFI data + says. Sigh. + + Why is this important? Imagine that a wrapper has a stack + allocated local, and passes to the hidden call, a pointer to it. + Because gcc does not know about the hidden call, it may allocate + that local in the redzone. Unfortunately the hidden call may then + trash it before it comes to use it. So we must step clear of the + redzone, for the duration of the hidden call, to make it safe. + + Probably the same problem afflicts the other redzone-style ABIs too + (ppc64-linux); but for those, the stack is + self describing (none of this CFI nonsense) so at least messing + with the stack pointer doesn't give a danger of non-unwindable + stack. */ + +#define CALL_FN_W_v(lval, orig) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[1]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + VALGRIND_ALIGN_STACK \ + "subq $128,%%rsp\n\t" \ + "movq (%%rax), %%rax\n\t" /* target->%rax */ \ + VALGRIND_CALL_NOREDIR_RAX \ + VALGRIND_RESTORE_STACK \ + VALGRIND_CFI_EPILOGUE \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r14", "r15" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_W(lval, orig, arg1) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[2]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + VALGRIND_ALIGN_STACK \ + "subq $128,%%rsp\n\t" \ + "movq 8(%%rax), %%rdi\n\t" \ + "movq (%%rax), %%rax\n\t" /* target->%rax */ \ + VALGRIND_CALL_NOREDIR_RAX \ + VALGRIND_RESTORE_STACK \ + VALGRIND_CFI_EPILOGUE \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r14", "r15" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WW(lval, orig, arg1,arg2) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + VALGRIND_ALIGN_STACK \ + "subq $128,%%rsp\n\t" \ + "movq 16(%%rax), %%rsi\n\t" \ + "movq 8(%%rax), %%rdi\n\t" \ + "movq (%%rax), %%rax\n\t" /* target->%rax */ \ + VALGRIND_CALL_NOREDIR_RAX \ + VALGRIND_RESTORE_STACK \ + VALGRIND_CFI_EPILOGUE \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r14", "r15" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WWW(lval, orig, arg1,arg2,arg3) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[4]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + VALGRIND_ALIGN_STACK \ + "subq $128,%%rsp\n\t" \ + "movq 24(%%rax), %%rdx\n\t" \ + "movq 16(%%rax), %%rsi\n\t" \ + "movq 8(%%rax), %%rdi\n\t" \ + "movq (%%rax), %%rax\n\t" /* target->%rax */ \ + VALGRIND_CALL_NOREDIR_RAX \ + VALGRIND_RESTORE_STACK \ + VALGRIND_CFI_EPILOGUE \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r14", "r15" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WWWW(lval, orig, arg1,arg2,arg3,arg4) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[5]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + VALGRIND_ALIGN_STACK \ + "subq $128,%%rsp\n\t" \ + "movq 32(%%rax), %%rcx\n\t" \ + "movq 24(%%rax), %%rdx\n\t" \ + "movq 16(%%rax), %%rsi\n\t" \ + "movq 8(%%rax), %%rdi\n\t" \ + "movq (%%rax), %%rax\n\t" /* target->%rax */ \ + VALGRIND_CALL_NOREDIR_RAX \ + VALGRIND_RESTORE_STACK \ + VALGRIND_CFI_EPILOGUE \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r14", "r15" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_5W(lval, orig, arg1,arg2,arg3,arg4,arg5) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[6]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + VALGRIND_ALIGN_STACK \ + "subq $128,%%rsp\n\t" \ + "movq 40(%%rax), %%r8\n\t" \ + "movq 32(%%rax), %%rcx\n\t" \ + "movq 24(%%rax), %%rdx\n\t" \ + "movq 16(%%rax), %%rsi\n\t" \ + "movq 8(%%rax), %%rdi\n\t" \ + "movq (%%rax), %%rax\n\t" /* target->%rax */ \ + VALGRIND_CALL_NOREDIR_RAX \ + VALGRIND_RESTORE_STACK \ + VALGRIND_CFI_EPILOGUE \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r14", "r15" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_6W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[7]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + VALGRIND_ALIGN_STACK \ + "subq $128,%%rsp\n\t" \ + "movq 48(%%rax), %%r9\n\t" \ + "movq 40(%%rax), %%r8\n\t" \ + "movq 32(%%rax), %%rcx\n\t" \ + "movq 24(%%rax), %%rdx\n\t" \ + "movq 16(%%rax), %%rsi\n\t" \ + "movq 8(%%rax), %%rdi\n\t" \ + "movq (%%rax), %%rax\n\t" /* target->%rax */ \ + VALGRIND_CALL_NOREDIR_RAX \ + VALGRIND_RESTORE_STACK \ + VALGRIND_CFI_EPILOGUE \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r14", "r15" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_7W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[8]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + VALGRIND_ALIGN_STACK \ + "subq $136,%%rsp\n\t" \ + "pushq 56(%%rax)\n\t" \ + "movq 48(%%rax), %%r9\n\t" \ + "movq 40(%%rax), %%r8\n\t" \ + "movq 32(%%rax), %%rcx\n\t" \ + "movq 24(%%rax), %%rdx\n\t" \ + "movq 16(%%rax), %%rsi\n\t" \ + "movq 8(%%rax), %%rdi\n\t" \ + "movq (%%rax), %%rax\n\t" /* target->%rax */ \ + VALGRIND_CALL_NOREDIR_RAX \ + VALGRIND_RESTORE_STACK \ + VALGRIND_CFI_EPILOGUE \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r14", "r15" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_8W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[9]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + VALGRIND_ALIGN_STACK \ + "subq $128,%%rsp\n\t" \ + "pushq 64(%%rax)\n\t" \ + "pushq 56(%%rax)\n\t" \ + "movq 48(%%rax), %%r9\n\t" \ + "movq 40(%%rax), %%r8\n\t" \ + "movq 32(%%rax), %%rcx\n\t" \ + "movq 24(%%rax), %%rdx\n\t" \ + "movq 16(%%rax), %%rsi\n\t" \ + "movq 8(%%rax), %%rdi\n\t" \ + "movq (%%rax), %%rax\n\t" /* target->%rax */ \ + VALGRIND_CALL_NOREDIR_RAX \ + VALGRIND_RESTORE_STACK \ + VALGRIND_CFI_EPILOGUE \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r14", "r15" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_9W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[10]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + _argvec[9] = (unsigned long)(arg9); \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + VALGRIND_ALIGN_STACK \ + "subq $136,%%rsp\n\t" \ + "pushq 72(%%rax)\n\t" \ + "pushq 64(%%rax)\n\t" \ + "pushq 56(%%rax)\n\t" \ + "movq 48(%%rax), %%r9\n\t" \ + "movq 40(%%rax), %%r8\n\t" \ + "movq 32(%%rax), %%rcx\n\t" \ + "movq 24(%%rax), %%rdx\n\t" \ + "movq 16(%%rax), %%rsi\n\t" \ + "movq 8(%%rax), %%rdi\n\t" \ + "movq (%%rax), %%rax\n\t" /* target->%rax */ \ + VALGRIND_CALL_NOREDIR_RAX \ + VALGRIND_RESTORE_STACK \ + VALGRIND_CFI_EPILOGUE \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r14", "r15" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_10W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9,arg10) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[11]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + _argvec[9] = (unsigned long)(arg9); \ + _argvec[10] = (unsigned long)(arg10); \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + VALGRIND_ALIGN_STACK \ + "subq $128,%%rsp\n\t" \ + "pushq 80(%%rax)\n\t" \ + "pushq 72(%%rax)\n\t" \ + "pushq 64(%%rax)\n\t" \ + "pushq 56(%%rax)\n\t" \ + "movq 48(%%rax), %%r9\n\t" \ + "movq 40(%%rax), %%r8\n\t" \ + "movq 32(%%rax), %%rcx\n\t" \ + "movq 24(%%rax), %%rdx\n\t" \ + "movq 16(%%rax), %%rsi\n\t" \ + "movq 8(%%rax), %%rdi\n\t" \ + "movq (%%rax), %%rax\n\t" /* target->%rax */ \ + VALGRIND_CALL_NOREDIR_RAX \ + VALGRIND_RESTORE_STACK \ + VALGRIND_CFI_EPILOGUE \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r14", "r15" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_11W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9,arg10,arg11) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[12]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + _argvec[9] = (unsigned long)(arg9); \ + _argvec[10] = (unsigned long)(arg10); \ + _argvec[11] = (unsigned long)(arg11); \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + VALGRIND_ALIGN_STACK \ + "subq $136,%%rsp\n\t" \ + "pushq 88(%%rax)\n\t" \ + "pushq 80(%%rax)\n\t" \ + "pushq 72(%%rax)\n\t" \ + "pushq 64(%%rax)\n\t" \ + "pushq 56(%%rax)\n\t" \ + "movq 48(%%rax), %%r9\n\t" \ + "movq 40(%%rax), %%r8\n\t" \ + "movq 32(%%rax), %%rcx\n\t" \ + "movq 24(%%rax), %%rdx\n\t" \ + "movq 16(%%rax), %%rsi\n\t" \ + "movq 8(%%rax), %%rdi\n\t" \ + "movq (%%rax), %%rax\n\t" /* target->%rax */ \ + VALGRIND_CALL_NOREDIR_RAX \ + VALGRIND_RESTORE_STACK \ + VALGRIND_CFI_EPILOGUE \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r14", "r15" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_12W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9,arg10,arg11,arg12) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[13]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + _argvec[9] = (unsigned long)(arg9); \ + _argvec[10] = (unsigned long)(arg10); \ + _argvec[11] = (unsigned long)(arg11); \ + _argvec[12] = (unsigned long)(arg12); \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + VALGRIND_ALIGN_STACK \ + "subq $128,%%rsp\n\t" \ + "pushq 96(%%rax)\n\t" \ + "pushq 88(%%rax)\n\t" \ + "pushq 80(%%rax)\n\t" \ + "pushq 72(%%rax)\n\t" \ + "pushq 64(%%rax)\n\t" \ + "pushq 56(%%rax)\n\t" \ + "movq 48(%%rax), %%r9\n\t" \ + "movq 40(%%rax), %%r8\n\t" \ + "movq 32(%%rax), %%rcx\n\t" \ + "movq 24(%%rax), %%rdx\n\t" \ + "movq 16(%%rax), %%rsi\n\t" \ + "movq 8(%%rax), %%rdi\n\t" \ + "movq (%%rax), %%rax\n\t" /* target->%rax */ \ + VALGRIND_CALL_NOREDIR_RAX \ + VALGRIND_RESTORE_STACK \ + VALGRIND_CFI_EPILOGUE \ + : /*out*/ "=a" (_res) \ + : /*in*/ "a" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r14", "r15" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#endif /* PLAT_amd64_linux || PLAT_amd64_darwin || PLAT_amd64_solaris */ + +/* ------------------------ ppc32-linux ------------------------ */ + +#if defined(PLAT_ppc32_linux) + +/* This is useful for finding out about the on-stack stuff: + + extern int f9 ( int,int,int,int,int,int,int,int,int ); + extern int f10 ( int,int,int,int,int,int,int,int,int,int ); + extern int f11 ( int,int,int,int,int,int,int,int,int,int,int ); + extern int f12 ( int,int,int,int,int,int,int,int,int,int,int,int ); + + int g9 ( void ) { + return f9(11,22,33,44,55,66,77,88,99); + } + int g10 ( void ) { + return f10(11,22,33,44,55,66,77,88,99,110); + } + int g11 ( void ) { + return f11(11,22,33,44,55,66,77,88,99,110,121); + } + int g12 ( void ) { + return f12(11,22,33,44,55,66,77,88,99,110,121,132); + } +*/ + +/* ARGREGS: r3 r4 r5 r6 r7 r8 r9 r10 (the rest on stack somewhere) */ + +/* These regs are trashed by the hidden call. */ +#define __CALLER_SAVED_REGS \ + "lr", "ctr", "xer", \ + "cr0", "cr1", "cr2", "cr3", "cr4", "cr5", "cr6", "cr7", \ + "r0", "r2", "r3", "r4", "r5", "r6", "r7", "r8", "r9", "r10", \ + "r11", "r12", "r13" + +/* Macros to save and align the stack before making a function + call and restore it afterwards as gcc may not keep the stack + pointer aligned if it doesn't realise calls are being made + to other functions. */ + +#define VALGRIND_ALIGN_STACK \ + "mr 28,1\n\t" \ + "rlwinm 1,1,0,0,27\n\t" +#define VALGRIND_RESTORE_STACK \ + "mr 1,28\n\t" + +/* These CALL_FN_ macros assume that on ppc32-linux, + sizeof(unsigned long) == 4. */ + +#define CALL_FN_W_v(lval, orig) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[1]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "lwz 11,0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + VALGRIND_RESTORE_STACK \ + "mr %0,3" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_W(lval, orig, arg1) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[2]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)arg1; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "lwz 3,4(11)\n\t" /* arg1->r3 */ \ + "lwz 11,0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + VALGRIND_RESTORE_STACK \ + "mr %0,3" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WW(lval, orig, arg1,arg2) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)arg1; \ + _argvec[2] = (unsigned long)arg2; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "lwz 3,4(11)\n\t" /* arg1->r3 */ \ + "lwz 4,8(11)\n\t" \ + "lwz 11,0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + VALGRIND_RESTORE_STACK \ + "mr %0,3" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WWW(lval, orig, arg1,arg2,arg3) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[4]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)arg1; \ + _argvec[2] = (unsigned long)arg2; \ + _argvec[3] = (unsigned long)arg3; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "lwz 3,4(11)\n\t" /* arg1->r3 */ \ + "lwz 4,8(11)\n\t" \ + "lwz 5,12(11)\n\t" \ + "lwz 11,0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + VALGRIND_RESTORE_STACK \ + "mr %0,3" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WWWW(lval, orig, arg1,arg2,arg3,arg4) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[5]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)arg1; \ + _argvec[2] = (unsigned long)arg2; \ + _argvec[3] = (unsigned long)arg3; \ + _argvec[4] = (unsigned long)arg4; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "lwz 3,4(11)\n\t" /* arg1->r3 */ \ + "lwz 4,8(11)\n\t" \ + "lwz 5,12(11)\n\t" \ + "lwz 6,16(11)\n\t" /* arg4->r6 */ \ + "lwz 11,0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + VALGRIND_RESTORE_STACK \ + "mr %0,3" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_5W(lval, orig, arg1,arg2,arg3,arg4,arg5) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[6]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)arg1; \ + _argvec[2] = (unsigned long)arg2; \ + _argvec[3] = (unsigned long)arg3; \ + _argvec[4] = (unsigned long)arg4; \ + _argvec[5] = (unsigned long)arg5; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "lwz 3,4(11)\n\t" /* arg1->r3 */ \ + "lwz 4,8(11)\n\t" \ + "lwz 5,12(11)\n\t" \ + "lwz 6,16(11)\n\t" /* arg4->r6 */ \ + "lwz 7,20(11)\n\t" \ + "lwz 11,0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + VALGRIND_RESTORE_STACK \ + "mr %0,3" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_6W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[7]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)arg1; \ + _argvec[2] = (unsigned long)arg2; \ + _argvec[3] = (unsigned long)arg3; \ + _argvec[4] = (unsigned long)arg4; \ + _argvec[5] = (unsigned long)arg5; \ + _argvec[6] = (unsigned long)arg6; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "lwz 3,4(11)\n\t" /* arg1->r3 */ \ + "lwz 4,8(11)\n\t" \ + "lwz 5,12(11)\n\t" \ + "lwz 6,16(11)\n\t" /* arg4->r6 */ \ + "lwz 7,20(11)\n\t" \ + "lwz 8,24(11)\n\t" \ + "lwz 11,0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + VALGRIND_RESTORE_STACK \ + "mr %0,3" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_7W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[8]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)arg1; \ + _argvec[2] = (unsigned long)arg2; \ + _argvec[3] = (unsigned long)arg3; \ + _argvec[4] = (unsigned long)arg4; \ + _argvec[5] = (unsigned long)arg5; \ + _argvec[6] = (unsigned long)arg6; \ + _argvec[7] = (unsigned long)arg7; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "lwz 3,4(11)\n\t" /* arg1->r3 */ \ + "lwz 4,8(11)\n\t" \ + "lwz 5,12(11)\n\t" \ + "lwz 6,16(11)\n\t" /* arg4->r6 */ \ + "lwz 7,20(11)\n\t" \ + "lwz 8,24(11)\n\t" \ + "lwz 9,28(11)\n\t" \ + "lwz 11,0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + VALGRIND_RESTORE_STACK \ + "mr %0,3" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_8W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[9]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)arg1; \ + _argvec[2] = (unsigned long)arg2; \ + _argvec[3] = (unsigned long)arg3; \ + _argvec[4] = (unsigned long)arg4; \ + _argvec[5] = (unsigned long)arg5; \ + _argvec[6] = (unsigned long)arg6; \ + _argvec[7] = (unsigned long)arg7; \ + _argvec[8] = (unsigned long)arg8; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "lwz 3,4(11)\n\t" /* arg1->r3 */ \ + "lwz 4,8(11)\n\t" \ + "lwz 5,12(11)\n\t" \ + "lwz 6,16(11)\n\t" /* arg4->r6 */ \ + "lwz 7,20(11)\n\t" \ + "lwz 8,24(11)\n\t" \ + "lwz 9,28(11)\n\t" \ + "lwz 10,32(11)\n\t" /* arg8->r10 */ \ + "lwz 11,0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + VALGRIND_RESTORE_STACK \ + "mr %0,3" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_9W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[10]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)arg1; \ + _argvec[2] = (unsigned long)arg2; \ + _argvec[3] = (unsigned long)arg3; \ + _argvec[4] = (unsigned long)arg4; \ + _argvec[5] = (unsigned long)arg5; \ + _argvec[6] = (unsigned long)arg6; \ + _argvec[7] = (unsigned long)arg7; \ + _argvec[8] = (unsigned long)arg8; \ + _argvec[9] = (unsigned long)arg9; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "addi 1,1,-16\n\t" \ + /* arg9 */ \ + "lwz 3,36(11)\n\t" \ + "stw 3,8(1)\n\t" \ + /* args1-8 */ \ + "lwz 3,4(11)\n\t" /* arg1->r3 */ \ + "lwz 4,8(11)\n\t" \ + "lwz 5,12(11)\n\t" \ + "lwz 6,16(11)\n\t" /* arg4->r6 */ \ + "lwz 7,20(11)\n\t" \ + "lwz 8,24(11)\n\t" \ + "lwz 9,28(11)\n\t" \ + "lwz 10,32(11)\n\t" /* arg8->r10 */ \ + "lwz 11,0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + VALGRIND_RESTORE_STACK \ + "mr %0,3" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_10W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9,arg10) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[11]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)arg1; \ + _argvec[2] = (unsigned long)arg2; \ + _argvec[3] = (unsigned long)arg3; \ + _argvec[4] = (unsigned long)arg4; \ + _argvec[5] = (unsigned long)arg5; \ + _argvec[6] = (unsigned long)arg6; \ + _argvec[7] = (unsigned long)arg7; \ + _argvec[8] = (unsigned long)arg8; \ + _argvec[9] = (unsigned long)arg9; \ + _argvec[10] = (unsigned long)arg10; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "addi 1,1,-16\n\t" \ + /* arg10 */ \ + "lwz 3,40(11)\n\t" \ + "stw 3,12(1)\n\t" \ + /* arg9 */ \ + "lwz 3,36(11)\n\t" \ + "stw 3,8(1)\n\t" \ + /* args1-8 */ \ + "lwz 3,4(11)\n\t" /* arg1->r3 */ \ + "lwz 4,8(11)\n\t" \ + "lwz 5,12(11)\n\t" \ + "lwz 6,16(11)\n\t" /* arg4->r6 */ \ + "lwz 7,20(11)\n\t" \ + "lwz 8,24(11)\n\t" \ + "lwz 9,28(11)\n\t" \ + "lwz 10,32(11)\n\t" /* arg8->r10 */ \ + "lwz 11,0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + VALGRIND_RESTORE_STACK \ + "mr %0,3" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_11W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9,arg10,arg11) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[12]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)arg1; \ + _argvec[2] = (unsigned long)arg2; \ + _argvec[3] = (unsigned long)arg3; \ + _argvec[4] = (unsigned long)arg4; \ + _argvec[5] = (unsigned long)arg5; \ + _argvec[6] = (unsigned long)arg6; \ + _argvec[7] = (unsigned long)arg7; \ + _argvec[8] = (unsigned long)arg8; \ + _argvec[9] = (unsigned long)arg9; \ + _argvec[10] = (unsigned long)arg10; \ + _argvec[11] = (unsigned long)arg11; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "addi 1,1,-32\n\t" \ + /* arg11 */ \ + "lwz 3,44(11)\n\t" \ + "stw 3,16(1)\n\t" \ + /* arg10 */ \ + "lwz 3,40(11)\n\t" \ + "stw 3,12(1)\n\t" \ + /* arg9 */ \ + "lwz 3,36(11)\n\t" \ + "stw 3,8(1)\n\t" \ + /* args1-8 */ \ + "lwz 3,4(11)\n\t" /* arg1->r3 */ \ + "lwz 4,8(11)\n\t" \ + "lwz 5,12(11)\n\t" \ + "lwz 6,16(11)\n\t" /* arg4->r6 */ \ + "lwz 7,20(11)\n\t" \ + "lwz 8,24(11)\n\t" \ + "lwz 9,28(11)\n\t" \ + "lwz 10,32(11)\n\t" /* arg8->r10 */ \ + "lwz 11,0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + VALGRIND_RESTORE_STACK \ + "mr %0,3" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_12W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9,arg10,arg11,arg12) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[13]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)arg1; \ + _argvec[2] = (unsigned long)arg2; \ + _argvec[3] = (unsigned long)arg3; \ + _argvec[4] = (unsigned long)arg4; \ + _argvec[5] = (unsigned long)arg5; \ + _argvec[6] = (unsigned long)arg6; \ + _argvec[7] = (unsigned long)arg7; \ + _argvec[8] = (unsigned long)arg8; \ + _argvec[9] = (unsigned long)arg9; \ + _argvec[10] = (unsigned long)arg10; \ + _argvec[11] = (unsigned long)arg11; \ + _argvec[12] = (unsigned long)arg12; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "addi 1,1,-32\n\t" \ + /* arg12 */ \ + "lwz 3,48(11)\n\t" \ + "stw 3,20(1)\n\t" \ + /* arg11 */ \ + "lwz 3,44(11)\n\t" \ + "stw 3,16(1)\n\t" \ + /* arg10 */ \ + "lwz 3,40(11)\n\t" \ + "stw 3,12(1)\n\t" \ + /* arg9 */ \ + "lwz 3,36(11)\n\t" \ + "stw 3,8(1)\n\t" \ + /* args1-8 */ \ + "lwz 3,4(11)\n\t" /* arg1->r3 */ \ + "lwz 4,8(11)\n\t" \ + "lwz 5,12(11)\n\t" \ + "lwz 6,16(11)\n\t" /* arg4->r6 */ \ + "lwz 7,20(11)\n\t" \ + "lwz 8,24(11)\n\t" \ + "lwz 9,28(11)\n\t" \ + "lwz 10,32(11)\n\t" /* arg8->r10 */ \ + "lwz 11,0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + VALGRIND_RESTORE_STACK \ + "mr %0,3" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#endif /* PLAT_ppc32_linux */ + +/* ------------------------ ppc64-linux ------------------------ */ + +#if defined(PLAT_ppc64be_linux) + +/* ARGREGS: r3 r4 r5 r6 r7 r8 r9 r10 (the rest on stack somewhere) */ + +/* These regs are trashed by the hidden call. */ +#define __CALLER_SAVED_REGS \ + "lr", "ctr", "xer", \ + "cr0", "cr1", "cr2", "cr3", "cr4", "cr5", "cr6", "cr7", \ + "r0", "r3", "r4", "r5", "r6", "r7", "r8", "r9", "r10", \ + "r11", "r12", "r13" + +/* Macros to save and align the stack before making a function + call and restore it afterwards as gcc may not keep the stack + pointer aligned if it doesn't realise calls are being made + to other functions. */ + +#define VALGRIND_ALIGN_STACK \ + "mr 28,1\n\t" \ + "rldicr 1,1,0,59\n\t" +#define VALGRIND_RESTORE_STACK \ + "mr 1,28\n\t" + +/* These CALL_FN_ macros assume that on ppc64-linux, sizeof(unsigned + long) == 8. */ + +#define CALL_FN_W_v(lval, orig) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+0]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "std 2,-16(11)\n\t" /* save tocptr */ \ + "ld 2,-8(11)\n\t" /* use nraddr's tocptr */ \ + "ld 11, 0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + "mr 11,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(11)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_W(lval, orig, arg1) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+1]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + _argvec[2+1] = (unsigned long)arg1; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "std 2,-16(11)\n\t" /* save tocptr */ \ + "ld 2,-8(11)\n\t" /* use nraddr's tocptr */ \ + "ld 3, 8(11)\n\t" /* arg1->r3 */ \ + "ld 11, 0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + "mr 11,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(11)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WW(lval, orig, arg1,arg2) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+2]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + _argvec[2+1] = (unsigned long)arg1; \ + _argvec[2+2] = (unsigned long)arg2; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "std 2,-16(11)\n\t" /* save tocptr */ \ + "ld 2,-8(11)\n\t" /* use nraddr's tocptr */ \ + "ld 3, 8(11)\n\t" /* arg1->r3 */ \ + "ld 4, 16(11)\n\t" /* arg2->r4 */ \ + "ld 11, 0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + "mr 11,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(11)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WWW(lval, orig, arg1,arg2,arg3) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+3]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + _argvec[2+1] = (unsigned long)arg1; \ + _argvec[2+2] = (unsigned long)arg2; \ + _argvec[2+3] = (unsigned long)arg3; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "std 2,-16(11)\n\t" /* save tocptr */ \ + "ld 2,-8(11)\n\t" /* use nraddr's tocptr */ \ + "ld 3, 8(11)\n\t" /* arg1->r3 */ \ + "ld 4, 16(11)\n\t" /* arg2->r4 */ \ + "ld 5, 24(11)\n\t" /* arg3->r5 */ \ + "ld 11, 0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + "mr 11,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(11)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WWWW(lval, orig, arg1,arg2,arg3,arg4) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+4]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + _argvec[2+1] = (unsigned long)arg1; \ + _argvec[2+2] = (unsigned long)arg2; \ + _argvec[2+3] = (unsigned long)arg3; \ + _argvec[2+4] = (unsigned long)arg4; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "std 2,-16(11)\n\t" /* save tocptr */ \ + "ld 2,-8(11)\n\t" /* use nraddr's tocptr */ \ + "ld 3, 8(11)\n\t" /* arg1->r3 */ \ + "ld 4, 16(11)\n\t" /* arg2->r4 */ \ + "ld 5, 24(11)\n\t" /* arg3->r5 */ \ + "ld 6, 32(11)\n\t" /* arg4->r6 */ \ + "ld 11, 0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + "mr 11,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(11)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_5W(lval, orig, arg1,arg2,arg3,arg4,arg5) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+5]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + _argvec[2+1] = (unsigned long)arg1; \ + _argvec[2+2] = (unsigned long)arg2; \ + _argvec[2+3] = (unsigned long)arg3; \ + _argvec[2+4] = (unsigned long)arg4; \ + _argvec[2+5] = (unsigned long)arg5; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "std 2,-16(11)\n\t" /* save tocptr */ \ + "ld 2,-8(11)\n\t" /* use nraddr's tocptr */ \ + "ld 3, 8(11)\n\t" /* arg1->r3 */ \ + "ld 4, 16(11)\n\t" /* arg2->r4 */ \ + "ld 5, 24(11)\n\t" /* arg3->r5 */ \ + "ld 6, 32(11)\n\t" /* arg4->r6 */ \ + "ld 7, 40(11)\n\t" /* arg5->r7 */ \ + "ld 11, 0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + "mr 11,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(11)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_6W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+6]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + _argvec[2+1] = (unsigned long)arg1; \ + _argvec[2+2] = (unsigned long)arg2; \ + _argvec[2+3] = (unsigned long)arg3; \ + _argvec[2+4] = (unsigned long)arg4; \ + _argvec[2+5] = (unsigned long)arg5; \ + _argvec[2+6] = (unsigned long)arg6; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "std 2,-16(11)\n\t" /* save tocptr */ \ + "ld 2,-8(11)\n\t" /* use nraddr's tocptr */ \ + "ld 3, 8(11)\n\t" /* arg1->r3 */ \ + "ld 4, 16(11)\n\t" /* arg2->r4 */ \ + "ld 5, 24(11)\n\t" /* arg3->r5 */ \ + "ld 6, 32(11)\n\t" /* arg4->r6 */ \ + "ld 7, 40(11)\n\t" /* arg5->r7 */ \ + "ld 8, 48(11)\n\t" /* arg6->r8 */ \ + "ld 11, 0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + "mr 11,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(11)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_7W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+7]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + _argvec[2+1] = (unsigned long)arg1; \ + _argvec[2+2] = (unsigned long)arg2; \ + _argvec[2+3] = (unsigned long)arg3; \ + _argvec[2+4] = (unsigned long)arg4; \ + _argvec[2+5] = (unsigned long)arg5; \ + _argvec[2+6] = (unsigned long)arg6; \ + _argvec[2+7] = (unsigned long)arg7; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "std 2,-16(11)\n\t" /* save tocptr */ \ + "ld 2,-8(11)\n\t" /* use nraddr's tocptr */ \ + "ld 3, 8(11)\n\t" /* arg1->r3 */ \ + "ld 4, 16(11)\n\t" /* arg2->r4 */ \ + "ld 5, 24(11)\n\t" /* arg3->r5 */ \ + "ld 6, 32(11)\n\t" /* arg4->r6 */ \ + "ld 7, 40(11)\n\t" /* arg5->r7 */ \ + "ld 8, 48(11)\n\t" /* arg6->r8 */ \ + "ld 9, 56(11)\n\t" /* arg7->r9 */ \ + "ld 11, 0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + "mr 11,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(11)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_8W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+8]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + _argvec[2+1] = (unsigned long)arg1; \ + _argvec[2+2] = (unsigned long)arg2; \ + _argvec[2+3] = (unsigned long)arg3; \ + _argvec[2+4] = (unsigned long)arg4; \ + _argvec[2+5] = (unsigned long)arg5; \ + _argvec[2+6] = (unsigned long)arg6; \ + _argvec[2+7] = (unsigned long)arg7; \ + _argvec[2+8] = (unsigned long)arg8; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "std 2,-16(11)\n\t" /* save tocptr */ \ + "ld 2,-8(11)\n\t" /* use nraddr's tocptr */ \ + "ld 3, 8(11)\n\t" /* arg1->r3 */ \ + "ld 4, 16(11)\n\t" /* arg2->r4 */ \ + "ld 5, 24(11)\n\t" /* arg3->r5 */ \ + "ld 6, 32(11)\n\t" /* arg4->r6 */ \ + "ld 7, 40(11)\n\t" /* arg5->r7 */ \ + "ld 8, 48(11)\n\t" /* arg6->r8 */ \ + "ld 9, 56(11)\n\t" /* arg7->r9 */ \ + "ld 10, 64(11)\n\t" /* arg8->r10 */ \ + "ld 11, 0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + "mr 11,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(11)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_9W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+9]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + _argvec[2+1] = (unsigned long)arg1; \ + _argvec[2+2] = (unsigned long)arg2; \ + _argvec[2+3] = (unsigned long)arg3; \ + _argvec[2+4] = (unsigned long)arg4; \ + _argvec[2+5] = (unsigned long)arg5; \ + _argvec[2+6] = (unsigned long)arg6; \ + _argvec[2+7] = (unsigned long)arg7; \ + _argvec[2+8] = (unsigned long)arg8; \ + _argvec[2+9] = (unsigned long)arg9; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "std 2,-16(11)\n\t" /* save tocptr */ \ + "ld 2,-8(11)\n\t" /* use nraddr's tocptr */ \ + "addi 1,1,-128\n\t" /* expand stack frame */ \ + /* arg9 */ \ + "ld 3,72(11)\n\t" \ + "std 3,112(1)\n\t" \ + /* args1-8 */ \ + "ld 3, 8(11)\n\t" /* arg1->r3 */ \ + "ld 4, 16(11)\n\t" /* arg2->r4 */ \ + "ld 5, 24(11)\n\t" /* arg3->r5 */ \ + "ld 6, 32(11)\n\t" /* arg4->r6 */ \ + "ld 7, 40(11)\n\t" /* arg5->r7 */ \ + "ld 8, 48(11)\n\t" /* arg6->r8 */ \ + "ld 9, 56(11)\n\t" /* arg7->r9 */ \ + "ld 10, 64(11)\n\t" /* arg8->r10 */ \ + "ld 11, 0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + "mr 11,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(11)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_10W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9,arg10) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+10]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + _argvec[2+1] = (unsigned long)arg1; \ + _argvec[2+2] = (unsigned long)arg2; \ + _argvec[2+3] = (unsigned long)arg3; \ + _argvec[2+4] = (unsigned long)arg4; \ + _argvec[2+5] = (unsigned long)arg5; \ + _argvec[2+6] = (unsigned long)arg6; \ + _argvec[2+7] = (unsigned long)arg7; \ + _argvec[2+8] = (unsigned long)arg8; \ + _argvec[2+9] = (unsigned long)arg9; \ + _argvec[2+10] = (unsigned long)arg10; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "std 2,-16(11)\n\t" /* save tocptr */ \ + "ld 2,-8(11)\n\t" /* use nraddr's tocptr */ \ + "addi 1,1,-128\n\t" /* expand stack frame */ \ + /* arg10 */ \ + "ld 3,80(11)\n\t" \ + "std 3,120(1)\n\t" \ + /* arg9 */ \ + "ld 3,72(11)\n\t" \ + "std 3,112(1)\n\t" \ + /* args1-8 */ \ + "ld 3, 8(11)\n\t" /* arg1->r3 */ \ + "ld 4, 16(11)\n\t" /* arg2->r4 */ \ + "ld 5, 24(11)\n\t" /* arg3->r5 */ \ + "ld 6, 32(11)\n\t" /* arg4->r6 */ \ + "ld 7, 40(11)\n\t" /* arg5->r7 */ \ + "ld 8, 48(11)\n\t" /* arg6->r8 */ \ + "ld 9, 56(11)\n\t" /* arg7->r9 */ \ + "ld 10, 64(11)\n\t" /* arg8->r10 */ \ + "ld 11, 0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + "mr 11,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(11)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_11W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9,arg10,arg11) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+11]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + _argvec[2+1] = (unsigned long)arg1; \ + _argvec[2+2] = (unsigned long)arg2; \ + _argvec[2+3] = (unsigned long)arg3; \ + _argvec[2+4] = (unsigned long)arg4; \ + _argvec[2+5] = (unsigned long)arg5; \ + _argvec[2+6] = (unsigned long)arg6; \ + _argvec[2+7] = (unsigned long)arg7; \ + _argvec[2+8] = (unsigned long)arg8; \ + _argvec[2+9] = (unsigned long)arg9; \ + _argvec[2+10] = (unsigned long)arg10; \ + _argvec[2+11] = (unsigned long)arg11; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "std 2,-16(11)\n\t" /* save tocptr */ \ + "ld 2,-8(11)\n\t" /* use nraddr's tocptr */ \ + "addi 1,1,-144\n\t" /* expand stack frame */ \ + /* arg11 */ \ + "ld 3,88(11)\n\t" \ + "std 3,128(1)\n\t" \ + /* arg10 */ \ + "ld 3,80(11)\n\t" \ + "std 3,120(1)\n\t" \ + /* arg9 */ \ + "ld 3,72(11)\n\t" \ + "std 3,112(1)\n\t" \ + /* args1-8 */ \ + "ld 3, 8(11)\n\t" /* arg1->r3 */ \ + "ld 4, 16(11)\n\t" /* arg2->r4 */ \ + "ld 5, 24(11)\n\t" /* arg3->r5 */ \ + "ld 6, 32(11)\n\t" /* arg4->r6 */ \ + "ld 7, 40(11)\n\t" /* arg5->r7 */ \ + "ld 8, 48(11)\n\t" /* arg6->r8 */ \ + "ld 9, 56(11)\n\t" /* arg7->r9 */ \ + "ld 10, 64(11)\n\t" /* arg8->r10 */ \ + "ld 11, 0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + "mr 11,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(11)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_12W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9,arg10,arg11,arg12) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+12]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + _argvec[2+1] = (unsigned long)arg1; \ + _argvec[2+2] = (unsigned long)arg2; \ + _argvec[2+3] = (unsigned long)arg3; \ + _argvec[2+4] = (unsigned long)arg4; \ + _argvec[2+5] = (unsigned long)arg5; \ + _argvec[2+6] = (unsigned long)arg6; \ + _argvec[2+7] = (unsigned long)arg7; \ + _argvec[2+8] = (unsigned long)arg8; \ + _argvec[2+9] = (unsigned long)arg9; \ + _argvec[2+10] = (unsigned long)arg10; \ + _argvec[2+11] = (unsigned long)arg11; \ + _argvec[2+12] = (unsigned long)arg12; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 11,%1\n\t" \ + "std 2,-16(11)\n\t" /* save tocptr */ \ + "ld 2,-8(11)\n\t" /* use nraddr's tocptr */ \ + "addi 1,1,-144\n\t" /* expand stack frame */ \ + /* arg12 */ \ + "ld 3,96(11)\n\t" \ + "std 3,136(1)\n\t" \ + /* arg11 */ \ + "ld 3,88(11)\n\t" \ + "std 3,128(1)\n\t" \ + /* arg10 */ \ + "ld 3,80(11)\n\t" \ + "std 3,120(1)\n\t" \ + /* arg9 */ \ + "ld 3,72(11)\n\t" \ + "std 3,112(1)\n\t" \ + /* args1-8 */ \ + "ld 3, 8(11)\n\t" /* arg1->r3 */ \ + "ld 4, 16(11)\n\t" /* arg2->r4 */ \ + "ld 5, 24(11)\n\t" /* arg3->r5 */ \ + "ld 6, 32(11)\n\t" /* arg4->r6 */ \ + "ld 7, 40(11)\n\t" /* arg5->r7 */ \ + "ld 8, 48(11)\n\t" /* arg6->r8 */ \ + "ld 9, 56(11)\n\t" /* arg7->r9 */ \ + "ld 10, 64(11)\n\t" /* arg8->r10 */ \ + "ld 11, 0(11)\n\t" /* target->r11 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R11 \ + "mr 11,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(11)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#endif /* PLAT_ppc64be_linux */ + +/* ------------------------- ppc64le-linux ----------------------- */ +#if defined(PLAT_ppc64le_linux) + +/* ARGREGS: r3 r4 r5 r6 r7 r8 r9 r10 (the rest on stack somewhere) */ + +/* These regs are trashed by the hidden call. */ +#define __CALLER_SAVED_REGS \ + "lr", "ctr", "xer", \ + "cr0", "cr1", "cr2", "cr3", "cr4", "cr5", "cr6", "cr7", \ + "r0", "r3", "r4", "r5", "r6", "r7", "r8", "r9", "r10", \ + "r11", "r12", "r13" + +/* Macros to save and align the stack before making a function + call and restore it afterwards as gcc may not keep the stack + pointer aligned if it doesn't realise calls are being made + to other functions. */ + +#define VALGRIND_ALIGN_STACK \ + "mr 28,1\n\t" \ + "rldicr 1,1,0,59\n\t" +#define VALGRIND_RESTORE_STACK \ + "mr 1,28\n\t" + +/* These CALL_FN_ macros assume that on ppc64-linux, sizeof(unsigned + long) == 8. */ + +#define CALL_FN_W_v(lval, orig) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+0]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 12,%1\n\t" \ + "std 2,-16(12)\n\t" /* save tocptr */ \ + "ld 2,-8(12)\n\t" /* use nraddr's tocptr */ \ + "ld 12, 0(12)\n\t" /* target->r12 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R12 \ + "mr 12,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(12)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_W(lval, orig, arg1) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+1]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + _argvec[2+1] = (unsigned long)arg1; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 12,%1\n\t" \ + "std 2,-16(12)\n\t" /* save tocptr */ \ + "ld 2,-8(12)\n\t" /* use nraddr's tocptr */ \ + "ld 3, 8(12)\n\t" /* arg1->r3 */ \ + "ld 12, 0(12)\n\t" /* target->r12 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R12 \ + "mr 12,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(12)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WW(lval, orig, arg1,arg2) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+2]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + _argvec[2+1] = (unsigned long)arg1; \ + _argvec[2+2] = (unsigned long)arg2; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 12,%1\n\t" \ + "std 2,-16(12)\n\t" /* save tocptr */ \ + "ld 2,-8(12)\n\t" /* use nraddr's tocptr */ \ + "ld 3, 8(12)\n\t" /* arg1->r3 */ \ + "ld 4, 16(12)\n\t" /* arg2->r4 */ \ + "ld 12, 0(12)\n\t" /* target->r12 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R12 \ + "mr 12,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(12)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WWW(lval, orig, arg1,arg2,arg3) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+3]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + _argvec[2+1] = (unsigned long)arg1; \ + _argvec[2+2] = (unsigned long)arg2; \ + _argvec[2+3] = (unsigned long)arg3; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 12,%1\n\t" \ + "std 2,-16(12)\n\t" /* save tocptr */ \ + "ld 2,-8(12)\n\t" /* use nraddr's tocptr */ \ + "ld 3, 8(12)\n\t" /* arg1->r3 */ \ + "ld 4, 16(12)\n\t" /* arg2->r4 */ \ + "ld 5, 24(12)\n\t" /* arg3->r5 */ \ + "ld 12, 0(12)\n\t" /* target->r12 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R12 \ + "mr 12,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(12)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WWWW(lval, orig, arg1,arg2,arg3,arg4) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+4]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + _argvec[2+1] = (unsigned long)arg1; \ + _argvec[2+2] = (unsigned long)arg2; \ + _argvec[2+3] = (unsigned long)arg3; \ + _argvec[2+4] = (unsigned long)arg4; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 12,%1\n\t" \ + "std 2,-16(12)\n\t" /* save tocptr */ \ + "ld 2,-8(12)\n\t" /* use nraddr's tocptr */ \ + "ld 3, 8(12)\n\t" /* arg1->r3 */ \ + "ld 4, 16(12)\n\t" /* arg2->r4 */ \ + "ld 5, 24(12)\n\t" /* arg3->r5 */ \ + "ld 6, 32(12)\n\t" /* arg4->r6 */ \ + "ld 12, 0(12)\n\t" /* target->r12 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R12 \ + "mr 12,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(12)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_5W(lval, orig, arg1,arg2,arg3,arg4,arg5) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+5]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + _argvec[2+1] = (unsigned long)arg1; \ + _argvec[2+2] = (unsigned long)arg2; \ + _argvec[2+3] = (unsigned long)arg3; \ + _argvec[2+4] = (unsigned long)arg4; \ + _argvec[2+5] = (unsigned long)arg5; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 12,%1\n\t" \ + "std 2,-16(12)\n\t" /* save tocptr */ \ + "ld 2,-8(12)\n\t" /* use nraddr's tocptr */ \ + "ld 3, 8(12)\n\t" /* arg1->r3 */ \ + "ld 4, 16(12)\n\t" /* arg2->r4 */ \ + "ld 5, 24(12)\n\t" /* arg3->r5 */ \ + "ld 6, 32(12)\n\t" /* arg4->r6 */ \ + "ld 7, 40(12)\n\t" /* arg5->r7 */ \ + "ld 12, 0(12)\n\t" /* target->r12 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R12 \ + "mr 12,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(12)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_6W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+6]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + _argvec[2+1] = (unsigned long)arg1; \ + _argvec[2+2] = (unsigned long)arg2; \ + _argvec[2+3] = (unsigned long)arg3; \ + _argvec[2+4] = (unsigned long)arg4; \ + _argvec[2+5] = (unsigned long)arg5; \ + _argvec[2+6] = (unsigned long)arg6; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 12,%1\n\t" \ + "std 2,-16(12)\n\t" /* save tocptr */ \ + "ld 2,-8(12)\n\t" /* use nraddr's tocptr */ \ + "ld 3, 8(12)\n\t" /* arg1->r3 */ \ + "ld 4, 16(12)\n\t" /* arg2->r4 */ \ + "ld 5, 24(12)\n\t" /* arg3->r5 */ \ + "ld 6, 32(12)\n\t" /* arg4->r6 */ \ + "ld 7, 40(12)\n\t" /* arg5->r7 */ \ + "ld 8, 48(12)\n\t" /* arg6->r8 */ \ + "ld 12, 0(12)\n\t" /* target->r12 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R12 \ + "mr 12,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(12)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_7W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+7]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + _argvec[2+1] = (unsigned long)arg1; \ + _argvec[2+2] = (unsigned long)arg2; \ + _argvec[2+3] = (unsigned long)arg3; \ + _argvec[2+4] = (unsigned long)arg4; \ + _argvec[2+5] = (unsigned long)arg5; \ + _argvec[2+6] = (unsigned long)arg6; \ + _argvec[2+7] = (unsigned long)arg7; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 12,%1\n\t" \ + "std 2,-16(12)\n\t" /* save tocptr */ \ + "ld 2,-8(12)\n\t" /* use nraddr's tocptr */ \ + "ld 3, 8(12)\n\t" /* arg1->r3 */ \ + "ld 4, 16(12)\n\t" /* arg2->r4 */ \ + "ld 5, 24(12)\n\t" /* arg3->r5 */ \ + "ld 6, 32(12)\n\t" /* arg4->r6 */ \ + "ld 7, 40(12)\n\t" /* arg5->r7 */ \ + "ld 8, 48(12)\n\t" /* arg6->r8 */ \ + "ld 9, 56(12)\n\t" /* arg7->r9 */ \ + "ld 12, 0(12)\n\t" /* target->r12 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R12 \ + "mr 12,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(12)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_8W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+8]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + _argvec[2+1] = (unsigned long)arg1; \ + _argvec[2+2] = (unsigned long)arg2; \ + _argvec[2+3] = (unsigned long)arg3; \ + _argvec[2+4] = (unsigned long)arg4; \ + _argvec[2+5] = (unsigned long)arg5; \ + _argvec[2+6] = (unsigned long)arg6; \ + _argvec[2+7] = (unsigned long)arg7; \ + _argvec[2+8] = (unsigned long)arg8; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 12,%1\n\t" \ + "std 2,-16(12)\n\t" /* save tocptr */ \ + "ld 2,-8(12)\n\t" /* use nraddr's tocptr */ \ + "ld 3, 8(12)\n\t" /* arg1->r3 */ \ + "ld 4, 16(12)\n\t" /* arg2->r4 */ \ + "ld 5, 24(12)\n\t" /* arg3->r5 */ \ + "ld 6, 32(12)\n\t" /* arg4->r6 */ \ + "ld 7, 40(12)\n\t" /* arg5->r7 */ \ + "ld 8, 48(12)\n\t" /* arg6->r8 */ \ + "ld 9, 56(12)\n\t" /* arg7->r9 */ \ + "ld 10, 64(12)\n\t" /* arg8->r10 */ \ + "ld 12, 0(12)\n\t" /* target->r12 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R12 \ + "mr 12,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(12)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_9W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+9]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + _argvec[2+1] = (unsigned long)arg1; \ + _argvec[2+2] = (unsigned long)arg2; \ + _argvec[2+3] = (unsigned long)arg3; \ + _argvec[2+4] = (unsigned long)arg4; \ + _argvec[2+5] = (unsigned long)arg5; \ + _argvec[2+6] = (unsigned long)arg6; \ + _argvec[2+7] = (unsigned long)arg7; \ + _argvec[2+8] = (unsigned long)arg8; \ + _argvec[2+9] = (unsigned long)arg9; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 12,%1\n\t" \ + "std 2,-16(12)\n\t" /* save tocptr */ \ + "ld 2,-8(12)\n\t" /* use nraddr's tocptr */ \ + "addi 1,1,-128\n\t" /* expand stack frame */ \ + /* arg9 */ \ + "ld 3,72(12)\n\t" \ + "std 3,96(1)\n\t" \ + /* args1-8 */ \ + "ld 3, 8(12)\n\t" /* arg1->r3 */ \ + "ld 4, 16(12)\n\t" /* arg2->r4 */ \ + "ld 5, 24(12)\n\t" /* arg3->r5 */ \ + "ld 6, 32(12)\n\t" /* arg4->r6 */ \ + "ld 7, 40(12)\n\t" /* arg5->r7 */ \ + "ld 8, 48(12)\n\t" /* arg6->r8 */ \ + "ld 9, 56(12)\n\t" /* arg7->r9 */ \ + "ld 10, 64(12)\n\t" /* arg8->r10 */ \ + "ld 12, 0(12)\n\t" /* target->r12 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R12 \ + "mr 12,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(12)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_10W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9,arg10) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+10]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + _argvec[2+1] = (unsigned long)arg1; \ + _argvec[2+2] = (unsigned long)arg2; \ + _argvec[2+3] = (unsigned long)arg3; \ + _argvec[2+4] = (unsigned long)arg4; \ + _argvec[2+5] = (unsigned long)arg5; \ + _argvec[2+6] = (unsigned long)arg6; \ + _argvec[2+7] = (unsigned long)arg7; \ + _argvec[2+8] = (unsigned long)arg8; \ + _argvec[2+9] = (unsigned long)arg9; \ + _argvec[2+10] = (unsigned long)arg10; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 12,%1\n\t" \ + "std 2,-16(12)\n\t" /* save tocptr */ \ + "ld 2,-8(12)\n\t" /* use nraddr's tocptr */ \ + "addi 1,1,-128\n\t" /* expand stack frame */ \ + /* arg10 */ \ + "ld 3,80(12)\n\t" \ + "std 3,104(1)\n\t" \ + /* arg9 */ \ + "ld 3,72(12)\n\t" \ + "std 3,96(1)\n\t" \ + /* args1-8 */ \ + "ld 3, 8(12)\n\t" /* arg1->r3 */ \ + "ld 4, 16(12)\n\t" /* arg2->r4 */ \ + "ld 5, 24(12)\n\t" /* arg3->r5 */ \ + "ld 6, 32(12)\n\t" /* arg4->r6 */ \ + "ld 7, 40(12)\n\t" /* arg5->r7 */ \ + "ld 8, 48(12)\n\t" /* arg6->r8 */ \ + "ld 9, 56(12)\n\t" /* arg7->r9 */ \ + "ld 10, 64(12)\n\t" /* arg8->r10 */ \ + "ld 12, 0(12)\n\t" /* target->r12 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R12 \ + "mr 12,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(12)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_11W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9,arg10,arg11) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+11]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + _argvec[2+1] = (unsigned long)arg1; \ + _argvec[2+2] = (unsigned long)arg2; \ + _argvec[2+3] = (unsigned long)arg3; \ + _argvec[2+4] = (unsigned long)arg4; \ + _argvec[2+5] = (unsigned long)arg5; \ + _argvec[2+6] = (unsigned long)arg6; \ + _argvec[2+7] = (unsigned long)arg7; \ + _argvec[2+8] = (unsigned long)arg8; \ + _argvec[2+9] = (unsigned long)arg9; \ + _argvec[2+10] = (unsigned long)arg10; \ + _argvec[2+11] = (unsigned long)arg11; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 12,%1\n\t" \ + "std 2,-16(12)\n\t" /* save tocptr */ \ + "ld 2,-8(12)\n\t" /* use nraddr's tocptr */ \ + "addi 1,1,-144\n\t" /* expand stack frame */ \ + /* arg11 */ \ + "ld 3,88(12)\n\t" \ + "std 3,112(1)\n\t" \ + /* arg10 */ \ + "ld 3,80(12)\n\t" \ + "std 3,104(1)\n\t" \ + /* arg9 */ \ + "ld 3,72(12)\n\t" \ + "std 3,96(1)\n\t" \ + /* args1-8 */ \ + "ld 3, 8(12)\n\t" /* arg1->r3 */ \ + "ld 4, 16(12)\n\t" /* arg2->r4 */ \ + "ld 5, 24(12)\n\t" /* arg3->r5 */ \ + "ld 6, 32(12)\n\t" /* arg4->r6 */ \ + "ld 7, 40(12)\n\t" /* arg5->r7 */ \ + "ld 8, 48(12)\n\t" /* arg6->r8 */ \ + "ld 9, 56(12)\n\t" /* arg7->r9 */ \ + "ld 10, 64(12)\n\t" /* arg8->r10 */ \ + "ld 12, 0(12)\n\t" /* target->r12 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R12 \ + "mr 12,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(12)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_12W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9,arg10,arg11,arg12) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3+12]; \ + volatile unsigned long _res; \ + /* _argvec[0] holds current r2 across the call */ \ + _argvec[1] = (unsigned long)_orig.r2; \ + _argvec[2] = (unsigned long)_orig.nraddr; \ + _argvec[2+1] = (unsigned long)arg1; \ + _argvec[2+2] = (unsigned long)arg2; \ + _argvec[2+3] = (unsigned long)arg3; \ + _argvec[2+4] = (unsigned long)arg4; \ + _argvec[2+5] = (unsigned long)arg5; \ + _argvec[2+6] = (unsigned long)arg6; \ + _argvec[2+7] = (unsigned long)arg7; \ + _argvec[2+8] = (unsigned long)arg8; \ + _argvec[2+9] = (unsigned long)arg9; \ + _argvec[2+10] = (unsigned long)arg10; \ + _argvec[2+11] = (unsigned long)arg11; \ + _argvec[2+12] = (unsigned long)arg12; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "mr 12,%1\n\t" \ + "std 2,-16(12)\n\t" /* save tocptr */ \ + "ld 2,-8(12)\n\t" /* use nraddr's tocptr */ \ + "addi 1,1,-144\n\t" /* expand stack frame */ \ + /* arg12 */ \ + "ld 3,96(12)\n\t" \ + "std 3,120(1)\n\t" \ + /* arg11 */ \ + "ld 3,88(12)\n\t" \ + "std 3,112(1)\n\t" \ + /* arg10 */ \ + "ld 3,80(12)\n\t" \ + "std 3,104(1)\n\t" \ + /* arg9 */ \ + "ld 3,72(12)\n\t" \ + "std 3,96(1)\n\t" \ + /* args1-8 */ \ + "ld 3, 8(12)\n\t" /* arg1->r3 */ \ + "ld 4, 16(12)\n\t" /* arg2->r4 */ \ + "ld 5, 24(12)\n\t" /* arg3->r5 */ \ + "ld 6, 32(12)\n\t" /* arg4->r6 */ \ + "ld 7, 40(12)\n\t" /* arg5->r7 */ \ + "ld 8, 48(12)\n\t" /* arg6->r8 */ \ + "ld 9, 56(12)\n\t" /* arg7->r9 */ \ + "ld 10, 64(12)\n\t" /* arg8->r10 */ \ + "ld 12, 0(12)\n\t" /* target->r12 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R12 \ + "mr 12,%1\n\t" \ + "mr %0,3\n\t" \ + "ld 2,-16(12)\n\t" /* restore tocptr */ \ + VALGRIND_RESTORE_STACK \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[2]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r28" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#endif /* PLAT_ppc64le_linux */ + +/* ------------------------- arm-linux ------------------------- */ + +#if defined(PLAT_arm_linux) + +/* These regs are trashed by the hidden call. */ +#define __CALLER_SAVED_REGS "r0", "r1", "r2", "r3","r4", "r12", "r14" + +/* Macros to save and align the stack before making a function + call and restore it afterwards as gcc may not keep the stack + pointer aligned if it doesn't realise calls are being made + to other functions. */ + +/* This is a bit tricky. We store the original stack pointer in r10 + as it is callee-saves. gcc doesn't allow the use of r11 for some + reason. Also, we can't directly "bic" the stack pointer in thumb + mode since r13 isn't an allowed register number in that context. + So use r4 as a temporary, since that is about to get trashed + anyway, just after each use of this macro. Side effect is we need + to be very careful about any future changes, since + VALGRIND_ALIGN_STACK simply assumes r4 is usable. */ +#define VALGRIND_ALIGN_STACK \ + "mov r10, sp\n\t" \ + "mov r4, sp\n\t" \ + "bic r4, r4, #7\n\t" \ + "mov sp, r4\n\t" +#define VALGRIND_RESTORE_STACK \ + "mov sp, r10\n\t" + +/* These CALL_FN_ macros assume that on arm-linux, sizeof(unsigned + long) == 4. */ + +#define CALL_FN_W_v(lval, orig) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[1]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "ldr r4, [%1] \n\t" /* target->r4 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R4 \ + VALGRIND_RESTORE_STACK \ + "mov %0, r0\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r10" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_W(lval, orig, arg1) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[2]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "ldr r0, [%1, #4] \n\t" \ + "ldr r4, [%1] \n\t" /* target->r4 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R4 \ + VALGRIND_RESTORE_STACK \ + "mov %0, r0\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r10" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WW(lval, orig, arg1,arg2) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "ldr r0, [%1, #4] \n\t" \ + "ldr r1, [%1, #8] \n\t" \ + "ldr r4, [%1] \n\t" /* target->r4 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R4 \ + VALGRIND_RESTORE_STACK \ + "mov %0, r0\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r10" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WWW(lval, orig, arg1,arg2,arg3) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[4]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "ldr r0, [%1, #4] \n\t" \ + "ldr r1, [%1, #8] \n\t" \ + "ldr r2, [%1, #12] \n\t" \ + "ldr r4, [%1] \n\t" /* target->r4 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R4 \ + VALGRIND_RESTORE_STACK \ + "mov %0, r0\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r10" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WWWW(lval, orig, arg1,arg2,arg3,arg4) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[5]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "ldr r0, [%1, #4] \n\t" \ + "ldr r1, [%1, #8] \n\t" \ + "ldr r2, [%1, #12] \n\t" \ + "ldr r3, [%1, #16] \n\t" \ + "ldr r4, [%1] \n\t" /* target->r4 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R4 \ + VALGRIND_RESTORE_STACK \ + "mov %0, r0" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r10" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_5W(lval, orig, arg1,arg2,arg3,arg4,arg5) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[6]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "sub sp, sp, #4 \n\t" \ + "ldr r0, [%1, #20] \n\t" \ + "push {r0} \n\t" \ + "ldr r0, [%1, #4] \n\t" \ + "ldr r1, [%1, #8] \n\t" \ + "ldr r2, [%1, #12] \n\t" \ + "ldr r3, [%1, #16] \n\t" \ + "ldr r4, [%1] \n\t" /* target->r4 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R4 \ + VALGRIND_RESTORE_STACK \ + "mov %0, r0" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r10" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_6W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[7]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "ldr r0, [%1, #20] \n\t" \ + "ldr r1, [%1, #24] \n\t" \ + "push {r0, r1} \n\t" \ + "ldr r0, [%1, #4] \n\t" \ + "ldr r1, [%1, #8] \n\t" \ + "ldr r2, [%1, #12] \n\t" \ + "ldr r3, [%1, #16] \n\t" \ + "ldr r4, [%1] \n\t" /* target->r4 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R4 \ + VALGRIND_RESTORE_STACK \ + "mov %0, r0" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r10" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_7W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[8]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "sub sp, sp, #4 \n\t" \ + "ldr r0, [%1, #20] \n\t" \ + "ldr r1, [%1, #24] \n\t" \ + "ldr r2, [%1, #28] \n\t" \ + "push {r0, r1, r2} \n\t" \ + "ldr r0, [%1, #4] \n\t" \ + "ldr r1, [%1, #8] \n\t" \ + "ldr r2, [%1, #12] \n\t" \ + "ldr r3, [%1, #16] \n\t" \ + "ldr r4, [%1] \n\t" /* target->r4 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R4 \ + VALGRIND_RESTORE_STACK \ + "mov %0, r0" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r10" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_8W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[9]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "ldr r0, [%1, #20] \n\t" \ + "ldr r1, [%1, #24] \n\t" \ + "ldr r2, [%1, #28] \n\t" \ + "ldr r3, [%1, #32] \n\t" \ + "push {r0, r1, r2, r3} \n\t" \ + "ldr r0, [%1, #4] \n\t" \ + "ldr r1, [%1, #8] \n\t" \ + "ldr r2, [%1, #12] \n\t" \ + "ldr r3, [%1, #16] \n\t" \ + "ldr r4, [%1] \n\t" /* target->r4 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R4 \ + VALGRIND_RESTORE_STACK \ + "mov %0, r0" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r10" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_9W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[10]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + _argvec[9] = (unsigned long)(arg9); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "sub sp, sp, #4 \n\t" \ + "ldr r0, [%1, #20] \n\t" \ + "ldr r1, [%1, #24] \n\t" \ + "ldr r2, [%1, #28] \n\t" \ + "ldr r3, [%1, #32] \n\t" \ + "ldr r4, [%1, #36] \n\t" \ + "push {r0, r1, r2, r3, r4} \n\t" \ + "ldr r0, [%1, #4] \n\t" \ + "ldr r1, [%1, #8] \n\t" \ + "ldr r2, [%1, #12] \n\t" \ + "ldr r3, [%1, #16] \n\t" \ + "ldr r4, [%1] \n\t" /* target->r4 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R4 \ + VALGRIND_RESTORE_STACK \ + "mov %0, r0" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r10" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_10W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9,arg10) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[11]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + _argvec[9] = (unsigned long)(arg9); \ + _argvec[10] = (unsigned long)(arg10); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "ldr r0, [%1, #40] \n\t" \ + "push {r0} \n\t" \ + "ldr r0, [%1, #20] \n\t" \ + "ldr r1, [%1, #24] \n\t" \ + "ldr r2, [%1, #28] \n\t" \ + "ldr r3, [%1, #32] \n\t" \ + "ldr r4, [%1, #36] \n\t" \ + "push {r0, r1, r2, r3, r4} \n\t" \ + "ldr r0, [%1, #4] \n\t" \ + "ldr r1, [%1, #8] \n\t" \ + "ldr r2, [%1, #12] \n\t" \ + "ldr r3, [%1, #16] \n\t" \ + "ldr r4, [%1] \n\t" /* target->r4 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R4 \ + VALGRIND_RESTORE_STACK \ + "mov %0, r0" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r10" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_11W(lval, orig, arg1,arg2,arg3,arg4,arg5, \ + arg6,arg7,arg8,arg9,arg10, \ + arg11) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[12]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + _argvec[9] = (unsigned long)(arg9); \ + _argvec[10] = (unsigned long)(arg10); \ + _argvec[11] = (unsigned long)(arg11); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "sub sp, sp, #4 \n\t" \ + "ldr r0, [%1, #40] \n\t" \ + "ldr r1, [%1, #44] \n\t" \ + "push {r0, r1} \n\t" \ + "ldr r0, [%1, #20] \n\t" \ + "ldr r1, [%1, #24] \n\t" \ + "ldr r2, [%1, #28] \n\t" \ + "ldr r3, [%1, #32] \n\t" \ + "ldr r4, [%1, #36] \n\t" \ + "push {r0, r1, r2, r3, r4} \n\t" \ + "ldr r0, [%1, #4] \n\t" \ + "ldr r1, [%1, #8] \n\t" \ + "ldr r2, [%1, #12] \n\t" \ + "ldr r3, [%1, #16] \n\t" \ + "ldr r4, [%1] \n\t" /* target->r4 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R4 \ + VALGRIND_RESTORE_STACK \ + "mov %0, r0" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r10" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_12W(lval, orig, arg1,arg2,arg3,arg4,arg5, \ + arg6,arg7,arg8,arg9,arg10, \ + arg11,arg12) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[13]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + _argvec[9] = (unsigned long)(arg9); \ + _argvec[10] = (unsigned long)(arg10); \ + _argvec[11] = (unsigned long)(arg11); \ + _argvec[12] = (unsigned long)(arg12); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "ldr r0, [%1, #40] \n\t" \ + "ldr r1, [%1, #44] \n\t" \ + "ldr r2, [%1, #48] \n\t" \ + "push {r0, r1, r2} \n\t" \ + "ldr r0, [%1, #20] \n\t" \ + "ldr r1, [%1, #24] \n\t" \ + "ldr r2, [%1, #28] \n\t" \ + "ldr r3, [%1, #32] \n\t" \ + "ldr r4, [%1, #36] \n\t" \ + "push {r0, r1, r2, r3, r4} \n\t" \ + "ldr r0, [%1, #4] \n\t" \ + "ldr r1, [%1, #8] \n\t" \ + "ldr r2, [%1, #12] \n\t" \ + "ldr r3, [%1, #16] \n\t" \ + "ldr r4, [%1] \n\t" /* target->r4 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_R4 \ + VALGRIND_RESTORE_STACK \ + "mov %0, r0" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "r10" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#endif /* PLAT_arm_linux */ + +/* ------------------------ arm64-linux ------------------------ */ + +#if defined(PLAT_arm64_linux) + +/* These regs are trashed by the hidden call. */ +#define __CALLER_SAVED_REGS \ + "x0", "x1", "x2", "x3","x4", "x5", "x6", "x7", "x8", "x9", \ + "x10", "x11", "x12", "x13", "x14", "x15", "x16", "x17", \ + "x18", "x19", "x20", "x30", \ + "v0", "v1", "v2", "v3", "v4", "v5", "v6", "v7", "v8", "v9", \ + "v10", "v11", "v12", "v13", "v14", "v15", "v16", "v17", \ + "v18", "v19", "v20", "v21", "v22", "v23", "v24", "v25", \ + "v26", "v27", "v28", "v29", "v30", "v31" + +/* x21 is callee-saved, so we can use it to save and restore SP around + the hidden call. */ +#define VALGRIND_ALIGN_STACK \ + "mov x21, sp\n\t" \ + "bic sp, x21, #15\n\t" +#define VALGRIND_RESTORE_STACK \ + "mov sp, x21\n\t" + +/* These CALL_FN_ macros assume that on arm64-linux, + sizeof(unsigned long) == 8. */ + +#define CALL_FN_W_v(lval, orig) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[1]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "ldr x8, [%1] \n\t" /* target->x8 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_X8 \ + VALGRIND_RESTORE_STACK \ + "mov %0, x0\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "x21" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_W(lval, orig, arg1) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[2]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "ldr x0, [%1, #8] \n\t" \ + "ldr x8, [%1] \n\t" /* target->x8 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_X8 \ + VALGRIND_RESTORE_STACK \ + "mov %0, x0\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "x21" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WW(lval, orig, arg1,arg2) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "ldr x0, [%1, #8] \n\t" \ + "ldr x1, [%1, #16] \n\t" \ + "ldr x8, [%1] \n\t" /* target->x8 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_X8 \ + VALGRIND_RESTORE_STACK \ + "mov %0, x0\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "x21" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WWW(lval, orig, arg1,arg2,arg3) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[4]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "ldr x0, [%1, #8] \n\t" \ + "ldr x1, [%1, #16] \n\t" \ + "ldr x2, [%1, #24] \n\t" \ + "ldr x8, [%1] \n\t" /* target->x8 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_X8 \ + VALGRIND_RESTORE_STACK \ + "mov %0, x0\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "x21" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WWWW(lval, orig, arg1,arg2,arg3,arg4) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[5]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "ldr x0, [%1, #8] \n\t" \ + "ldr x1, [%1, #16] \n\t" \ + "ldr x2, [%1, #24] \n\t" \ + "ldr x3, [%1, #32] \n\t" \ + "ldr x8, [%1] \n\t" /* target->x8 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_X8 \ + VALGRIND_RESTORE_STACK \ + "mov %0, x0" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "x21" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_5W(lval, orig, arg1,arg2,arg3,arg4,arg5) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[6]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "ldr x0, [%1, #8] \n\t" \ + "ldr x1, [%1, #16] \n\t" \ + "ldr x2, [%1, #24] \n\t" \ + "ldr x3, [%1, #32] \n\t" \ + "ldr x4, [%1, #40] \n\t" \ + "ldr x8, [%1] \n\t" /* target->x8 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_X8 \ + VALGRIND_RESTORE_STACK \ + "mov %0, x0" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "x21" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_6W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[7]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "ldr x0, [%1, #8] \n\t" \ + "ldr x1, [%1, #16] \n\t" \ + "ldr x2, [%1, #24] \n\t" \ + "ldr x3, [%1, #32] \n\t" \ + "ldr x4, [%1, #40] \n\t" \ + "ldr x5, [%1, #48] \n\t" \ + "ldr x8, [%1] \n\t" /* target->x8 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_X8 \ + VALGRIND_RESTORE_STACK \ + "mov %0, x0" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "x21" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_7W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[8]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "ldr x0, [%1, #8] \n\t" \ + "ldr x1, [%1, #16] \n\t" \ + "ldr x2, [%1, #24] \n\t" \ + "ldr x3, [%1, #32] \n\t" \ + "ldr x4, [%1, #40] \n\t" \ + "ldr x5, [%1, #48] \n\t" \ + "ldr x6, [%1, #56] \n\t" \ + "ldr x8, [%1] \n\t" /* target->x8 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_X8 \ + VALGRIND_RESTORE_STACK \ + "mov %0, x0" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "x21" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_8W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[9]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "ldr x0, [%1, #8] \n\t" \ + "ldr x1, [%1, #16] \n\t" \ + "ldr x2, [%1, #24] \n\t" \ + "ldr x3, [%1, #32] \n\t" \ + "ldr x4, [%1, #40] \n\t" \ + "ldr x5, [%1, #48] \n\t" \ + "ldr x6, [%1, #56] \n\t" \ + "ldr x7, [%1, #64] \n\t" \ + "ldr x8, [%1] \n\t" /* target->x8 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_X8 \ + VALGRIND_RESTORE_STACK \ + "mov %0, x0" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "x21" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_9W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[10]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + _argvec[9] = (unsigned long)(arg9); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "sub sp, sp, #0x20 \n\t" \ + "ldr x0, [%1, #8] \n\t" \ + "ldr x1, [%1, #16] \n\t" \ + "ldr x2, [%1, #24] \n\t" \ + "ldr x3, [%1, #32] \n\t" \ + "ldr x4, [%1, #40] \n\t" \ + "ldr x5, [%1, #48] \n\t" \ + "ldr x6, [%1, #56] \n\t" \ + "ldr x7, [%1, #64] \n\t" \ + "ldr x8, [%1, #72] \n\t" \ + "str x8, [sp, #0] \n\t" \ + "ldr x8, [%1] \n\t" /* target->x8 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_X8 \ + VALGRIND_RESTORE_STACK \ + "mov %0, x0" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "x21" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_10W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9,arg10) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[11]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + _argvec[9] = (unsigned long)(arg9); \ + _argvec[10] = (unsigned long)(arg10); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "sub sp, sp, #0x20 \n\t" \ + "ldr x0, [%1, #8] \n\t" \ + "ldr x1, [%1, #16] \n\t" \ + "ldr x2, [%1, #24] \n\t" \ + "ldr x3, [%1, #32] \n\t" \ + "ldr x4, [%1, #40] \n\t" \ + "ldr x5, [%1, #48] \n\t" \ + "ldr x6, [%1, #56] \n\t" \ + "ldr x7, [%1, #64] \n\t" \ + "ldr x8, [%1, #72] \n\t" \ + "str x8, [sp, #0] \n\t" \ + "ldr x8, [%1, #80] \n\t" \ + "str x8, [sp, #8] \n\t" \ + "ldr x8, [%1] \n\t" /* target->x8 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_X8 \ + VALGRIND_RESTORE_STACK \ + "mov %0, x0" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "x21" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_11W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9,arg10,arg11) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[12]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + _argvec[9] = (unsigned long)(arg9); \ + _argvec[10] = (unsigned long)(arg10); \ + _argvec[11] = (unsigned long)(arg11); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "sub sp, sp, #0x30 \n\t" \ + "ldr x0, [%1, #8] \n\t" \ + "ldr x1, [%1, #16] \n\t" \ + "ldr x2, [%1, #24] \n\t" \ + "ldr x3, [%1, #32] \n\t" \ + "ldr x4, [%1, #40] \n\t" \ + "ldr x5, [%1, #48] \n\t" \ + "ldr x6, [%1, #56] \n\t" \ + "ldr x7, [%1, #64] \n\t" \ + "ldr x8, [%1, #72] \n\t" \ + "str x8, [sp, #0] \n\t" \ + "ldr x8, [%1, #80] \n\t" \ + "str x8, [sp, #8] \n\t" \ + "ldr x8, [%1, #88] \n\t" \ + "str x8, [sp, #16] \n\t" \ + "ldr x8, [%1] \n\t" /* target->x8 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_X8 \ + VALGRIND_RESTORE_STACK \ + "mov %0, x0" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "x21" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_12W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9,arg10,arg11, \ + arg12) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[13]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + _argvec[9] = (unsigned long)(arg9); \ + _argvec[10] = (unsigned long)(arg10); \ + _argvec[11] = (unsigned long)(arg11); \ + _argvec[12] = (unsigned long)(arg12); \ + __asm__ volatile( \ + VALGRIND_ALIGN_STACK \ + "sub sp, sp, #0x30 \n\t" \ + "ldr x0, [%1, #8] \n\t" \ + "ldr x1, [%1, #16] \n\t" \ + "ldr x2, [%1, #24] \n\t" \ + "ldr x3, [%1, #32] \n\t" \ + "ldr x4, [%1, #40] \n\t" \ + "ldr x5, [%1, #48] \n\t" \ + "ldr x6, [%1, #56] \n\t" \ + "ldr x7, [%1, #64] \n\t" \ + "ldr x8, [%1, #72] \n\t" \ + "str x8, [sp, #0] \n\t" \ + "ldr x8, [%1, #80] \n\t" \ + "str x8, [sp, #8] \n\t" \ + "ldr x8, [%1, #88] \n\t" \ + "str x8, [sp, #16] \n\t" \ + "ldr x8, [%1, #96] \n\t" \ + "str x8, [sp, #24] \n\t" \ + "ldr x8, [%1] \n\t" /* target->x8 */ \ + VALGRIND_BRANCH_AND_LINK_TO_NOREDIR_X8 \ + VALGRIND_RESTORE_STACK \ + "mov %0, x0" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS, "x21" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#endif /* PLAT_arm64_linux */ + +/* ------------------------- s390x-linux ------------------------- */ + +#if defined(PLAT_s390x_linux) + +/* Similar workaround as amd64 (see above), but we use r11 as frame + pointer and save the old r11 in r7. r11 might be used for + argvec, therefore we copy argvec in r1 since r1 is clobbered + after the call anyway. */ +#if defined(__GNUC__) && defined(__GCC_HAVE_DWARF2_CFI_ASM) +# define __FRAME_POINTER \ + ,"d"(__builtin_dwarf_cfa()) +# define VALGRIND_CFI_PROLOGUE \ + ".cfi_remember_state\n\t" \ + "lgr 1,%1\n\t" /* copy the argvec pointer in r1 */ \ + "lgr 7,11\n\t" \ + "lgr 11,%2\n\t" \ + ".cfi_def_cfa r11, 0\n\t" +# define VALGRIND_CFI_EPILOGUE \ + "lgr 11, 7\n\t" \ + ".cfi_restore_state\n\t" +#else +# define __FRAME_POINTER +# define VALGRIND_CFI_PROLOGUE \ + "lgr 1,%1\n\t" +# define VALGRIND_CFI_EPILOGUE +#endif + +/* Nb: On s390 the stack pointer is properly aligned *at all times* + according to the s390 GCC maintainer. (The ABI specification is not + precise in this regard.) Therefore, VALGRIND_ALIGN_STACK and + VALGRIND_RESTORE_STACK are not defined here. */ + +/* These regs are trashed by the hidden call. Note that we overwrite + r14 in s390_irgen_noredir (VEX/priv/guest_s390_irgen.c) to give the + function a proper return address. All others are ABI defined call + clobbers. */ +#if defined(__VX__) || defined(__S390_VX__) +#define __CALLER_SAVED_REGS "0", "1", "2", "3", "4", "5", "14", \ + "v0", "v1", "v2", "v3", "v4", "v5", "v6", "v7", \ + "v8", "v9", "v10", "v11", "v12", "v13", "v14", "v15", \ + "v16", "v17", "v18", "v19", "v20", "v21", "v22", "v23", \ + "v24", "v25", "v26", "v27", "v28", "v29", "v30", "v31" +#else +#define __CALLER_SAVED_REGS "0", "1", "2", "3", "4", "5", "14", \ + "f0", "f1", "f2", "f3", "f4", "f5", "f6", "f7" +#endif + +/* Nb: Although r11 is modified in the asm snippets below (inside + VALGRIND_CFI_PROLOGUE) it is not listed in the clobber section, for + two reasons: + (1) r11 is restored in VALGRIND_CFI_EPILOGUE, so effectively it is not + modified + (2) GCC will complain that r11 cannot appear inside a clobber section, + when compiled with -O -fno-omit-frame-pointer + */ + +#define CALL_FN_W_v(lval, orig) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[1]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + "aghi 15,-160\n\t" \ + "lg 1, 0(1)\n\t" /* target->r1 */ \ + VALGRIND_CALL_NOREDIR_R1 \ + "aghi 15,160\n\t" \ + VALGRIND_CFI_EPILOGUE \ + "lgr %0, 2\n\t" \ + : /*out*/ "=d" (_res) \ + : /*in*/ "d" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS,"7" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +/* The call abi has the arguments in r2-r6 and stack */ +#define CALL_FN_W_W(lval, orig, arg1) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[2]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)arg1; \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + "aghi 15,-160\n\t" \ + "lg 2, 8(1)\n\t" \ + "lg 1, 0(1)\n\t" \ + VALGRIND_CALL_NOREDIR_R1 \ + "aghi 15,160\n\t" \ + VALGRIND_CFI_EPILOGUE \ + "lgr %0, 2\n\t" \ + : /*out*/ "=d" (_res) \ + : /*in*/ "a" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS,"7" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WW(lval, orig, arg1, arg2) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)arg1; \ + _argvec[2] = (unsigned long)arg2; \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + "aghi 15,-160\n\t" \ + "lg 2, 8(1)\n\t" \ + "lg 3,16(1)\n\t" \ + "lg 1, 0(1)\n\t" \ + VALGRIND_CALL_NOREDIR_R1 \ + "aghi 15,160\n\t" \ + VALGRIND_CFI_EPILOGUE \ + "lgr %0, 2\n\t" \ + : /*out*/ "=d" (_res) \ + : /*in*/ "a" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS,"7" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WWW(lval, orig, arg1, arg2, arg3) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[4]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)arg1; \ + _argvec[2] = (unsigned long)arg2; \ + _argvec[3] = (unsigned long)arg3; \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + "aghi 15,-160\n\t" \ + "lg 2, 8(1)\n\t" \ + "lg 3,16(1)\n\t" \ + "lg 4,24(1)\n\t" \ + "lg 1, 0(1)\n\t" \ + VALGRIND_CALL_NOREDIR_R1 \ + "aghi 15,160\n\t" \ + VALGRIND_CFI_EPILOGUE \ + "lgr %0, 2\n\t" \ + : /*out*/ "=d" (_res) \ + : /*in*/ "a" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS,"7" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WWWW(lval, orig, arg1, arg2, arg3, arg4) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[5]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)arg1; \ + _argvec[2] = (unsigned long)arg2; \ + _argvec[3] = (unsigned long)arg3; \ + _argvec[4] = (unsigned long)arg4; \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + "aghi 15,-160\n\t" \ + "lg 2, 8(1)\n\t" \ + "lg 3,16(1)\n\t" \ + "lg 4,24(1)\n\t" \ + "lg 5,32(1)\n\t" \ + "lg 1, 0(1)\n\t" \ + VALGRIND_CALL_NOREDIR_R1 \ + "aghi 15,160\n\t" \ + VALGRIND_CFI_EPILOGUE \ + "lgr %0, 2\n\t" \ + : /*out*/ "=d" (_res) \ + : /*in*/ "a" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS,"7" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_5W(lval, orig, arg1, arg2, arg3, arg4, arg5) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[6]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)arg1; \ + _argvec[2] = (unsigned long)arg2; \ + _argvec[3] = (unsigned long)arg3; \ + _argvec[4] = (unsigned long)arg4; \ + _argvec[5] = (unsigned long)arg5; \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + "aghi 15,-160\n\t" \ + "lg 2, 8(1)\n\t" \ + "lg 3,16(1)\n\t" \ + "lg 4,24(1)\n\t" \ + "lg 5,32(1)\n\t" \ + "lg 6,40(1)\n\t" \ + "lg 1, 0(1)\n\t" \ + VALGRIND_CALL_NOREDIR_R1 \ + "aghi 15,160\n\t" \ + VALGRIND_CFI_EPILOGUE \ + "lgr %0, 2\n\t" \ + : /*out*/ "=d" (_res) \ + : /*in*/ "a" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS,"6","7" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_6W(lval, orig, arg1, arg2, arg3, arg4, arg5, \ + arg6) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[7]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)arg1; \ + _argvec[2] = (unsigned long)arg2; \ + _argvec[3] = (unsigned long)arg3; \ + _argvec[4] = (unsigned long)arg4; \ + _argvec[5] = (unsigned long)arg5; \ + _argvec[6] = (unsigned long)arg6; \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + "aghi 15,-168\n\t" \ + "lg 2, 8(1)\n\t" \ + "lg 3,16(1)\n\t" \ + "lg 4,24(1)\n\t" \ + "lg 5,32(1)\n\t" \ + "lg 6,40(1)\n\t" \ + "mvc 160(8,15), 48(1)\n\t" \ + "lg 1, 0(1)\n\t" \ + VALGRIND_CALL_NOREDIR_R1 \ + "aghi 15,168\n\t" \ + VALGRIND_CFI_EPILOGUE \ + "lgr %0, 2\n\t" \ + : /*out*/ "=d" (_res) \ + : /*in*/ "a" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS,"6","7" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_7W(lval, orig, arg1, arg2, arg3, arg4, arg5, \ + arg6, arg7) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[8]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)arg1; \ + _argvec[2] = (unsigned long)arg2; \ + _argvec[3] = (unsigned long)arg3; \ + _argvec[4] = (unsigned long)arg4; \ + _argvec[5] = (unsigned long)arg5; \ + _argvec[6] = (unsigned long)arg6; \ + _argvec[7] = (unsigned long)arg7; \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + "aghi 15,-176\n\t" \ + "lg 2, 8(1)\n\t" \ + "lg 3,16(1)\n\t" \ + "lg 4,24(1)\n\t" \ + "lg 5,32(1)\n\t" \ + "lg 6,40(1)\n\t" \ + "mvc 160(8,15), 48(1)\n\t" \ + "mvc 168(8,15), 56(1)\n\t" \ + "lg 1, 0(1)\n\t" \ + VALGRIND_CALL_NOREDIR_R1 \ + "aghi 15,176\n\t" \ + VALGRIND_CFI_EPILOGUE \ + "lgr %0, 2\n\t" \ + : /*out*/ "=d" (_res) \ + : /*in*/ "a" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS,"6","7" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_8W(lval, orig, arg1, arg2, arg3, arg4, arg5, \ + arg6, arg7 ,arg8) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[9]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)arg1; \ + _argvec[2] = (unsigned long)arg2; \ + _argvec[3] = (unsigned long)arg3; \ + _argvec[4] = (unsigned long)arg4; \ + _argvec[5] = (unsigned long)arg5; \ + _argvec[6] = (unsigned long)arg6; \ + _argvec[7] = (unsigned long)arg7; \ + _argvec[8] = (unsigned long)arg8; \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + "aghi 15,-184\n\t" \ + "lg 2, 8(1)\n\t" \ + "lg 3,16(1)\n\t" \ + "lg 4,24(1)\n\t" \ + "lg 5,32(1)\n\t" \ + "lg 6,40(1)\n\t" \ + "mvc 160(8,15), 48(1)\n\t" \ + "mvc 168(8,15), 56(1)\n\t" \ + "mvc 176(8,15), 64(1)\n\t" \ + "lg 1, 0(1)\n\t" \ + VALGRIND_CALL_NOREDIR_R1 \ + "aghi 15,184\n\t" \ + VALGRIND_CFI_EPILOGUE \ + "lgr %0, 2\n\t" \ + : /*out*/ "=d" (_res) \ + : /*in*/ "a" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS,"6","7" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_9W(lval, orig, arg1, arg2, arg3, arg4, arg5, \ + arg6, arg7 ,arg8, arg9) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[10]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)arg1; \ + _argvec[2] = (unsigned long)arg2; \ + _argvec[3] = (unsigned long)arg3; \ + _argvec[4] = (unsigned long)arg4; \ + _argvec[5] = (unsigned long)arg5; \ + _argvec[6] = (unsigned long)arg6; \ + _argvec[7] = (unsigned long)arg7; \ + _argvec[8] = (unsigned long)arg8; \ + _argvec[9] = (unsigned long)arg9; \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + "aghi 15,-192\n\t" \ + "lg 2, 8(1)\n\t" \ + "lg 3,16(1)\n\t" \ + "lg 4,24(1)\n\t" \ + "lg 5,32(1)\n\t" \ + "lg 6,40(1)\n\t" \ + "mvc 160(8,15), 48(1)\n\t" \ + "mvc 168(8,15), 56(1)\n\t" \ + "mvc 176(8,15), 64(1)\n\t" \ + "mvc 184(8,15), 72(1)\n\t" \ + "lg 1, 0(1)\n\t" \ + VALGRIND_CALL_NOREDIR_R1 \ + "aghi 15,192\n\t" \ + VALGRIND_CFI_EPILOGUE \ + "lgr %0, 2\n\t" \ + : /*out*/ "=d" (_res) \ + : /*in*/ "a" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS,"6","7" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_10W(lval, orig, arg1, arg2, arg3, arg4, arg5, \ + arg6, arg7 ,arg8, arg9, arg10) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[11]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)arg1; \ + _argvec[2] = (unsigned long)arg2; \ + _argvec[3] = (unsigned long)arg3; \ + _argvec[4] = (unsigned long)arg4; \ + _argvec[5] = (unsigned long)arg5; \ + _argvec[6] = (unsigned long)arg6; \ + _argvec[7] = (unsigned long)arg7; \ + _argvec[8] = (unsigned long)arg8; \ + _argvec[9] = (unsigned long)arg9; \ + _argvec[10] = (unsigned long)arg10; \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + "aghi 15,-200\n\t" \ + "lg 2, 8(1)\n\t" \ + "lg 3,16(1)\n\t" \ + "lg 4,24(1)\n\t" \ + "lg 5,32(1)\n\t" \ + "lg 6,40(1)\n\t" \ + "mvc 160(8,15), 48(1)\n\t" \ + "mvc 168(8,15), 56(1)\n\t" \ + "mvc 176(8,15), 64(1)\n\t" \ + "mvc 184(8,15), 72(1)\n\t" \ + "mvc 192(8,15), 80(1)\n\t" \ + "lg 1, 0(1)\n\t" \ + VALGRIND_CALL_NOREDIR_R1 \ + "aghi 15,200\n\t" \ + VALGRIND_CFI_EPILOGUE \ + "lgr %0, 2\n\t" \ + : /*out*/ "=d" (_res) \ + : /*in*/ "a" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS,"6","7" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_11W(lval, orig, arg1, arg2, arg3, arg4, arg5, \ + arg6, arg7 ,arg8, arg9, arg10, arg11) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[12]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)arg1; \ + _argvec[2] = (unsigned long)arg2; \ + _argvec[3] = (unsigned long)arg3; \ + _argvec[4] = (unsigned long)arg4; \ + _argvec[5] = (unsigned long)arg5; \ + _argvec[6] = (unsigned long)arg6; \ + _argvec[7] = (unsigned long)arg7; \ + _argvec[8] = (unsigned long)arg8; \ + _argvec[9] = (unsigned long)arg9; \ + _argvec[10] = (unsigned long)arg10; \ + _argvec[11] = (unsigned long)arg11; \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + "aghi 15,-208\n\t" \ + "lg 2, 8(1)\n\t" \ + "lg 3,16(1)\n\t" \ + "lg 4,24(1)\n\t" \ + "lg 5,32(1)\n\t" \ + "lg 6,40(1)\n\t" \ + "mvc 160(8,15), 48(1)\n\t" \ + "mvc 168(8,15), 56(1)\n\t" \ + "mvc 176(8,15), 64(1)\n\t" \ + "mvc 184(8,15), 72(1)\n\t" \ + "mvc 192(8,15), 80(1)\n\t" \ + "mvc 200(8,15), 88(1)\n\t" \ + "lg 1, 0(1)\n\t" \ + VALGRIND_CALL_NOREDIR_R1 \ + "aghi 15,208\n\t" \ + VALGRIND_CFI_EPILOGUE \ + "lgr %0, 2\n\t" \ + : /*out*/ "=d" (_res) \ + : /*in*/ "a" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS,"6","7" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_12W(lval, orig, arg1, arg2, arg3, arg4, arg5, \ + arg6, arg7 ,arg8, arg9, arg10, arg11, arg12)\ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[13]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)arg1; \ + _argvec[2] = (unsigned long)arg2; \ + _argvec[3] = (unsigned long)arg3; \ + _argvec[4] = (unsigned long)arg4; \ + _argvec[5] = (unsigned long)arg5; \ + _argvec[6] = (unsigned long)arg6; \ + _argvec[7] = (unsigned long)arg7; \ + _argvec[8] = (unsigned long)arg8; \ + _argvec[9] = (unsigned long)arg9; \ + _argvec[10] = (unsigned long)arg10; \ + _argvec[11] = (unsigned long)arg11; \ + _argvec[12] = (unsigned long)arg12; \ + __asm__ volatile( \ + VALGRIND_CFI_PROLOGUE \ + "aghi 15,-216\n\t" \ + "lg 2, 8(1)\n\t" \ + "lg 3,16(1)\n\t" \ + "lg 4,24(1)\n\t" \ + "lg 5,32(1)\n\t" \ + "lg 6,40(1)\n\t" \ + "mvc 160(8,15), 48(1)\n\t" \ + "mvc 168(8,15), 56(1)\n\t" \ + "mvc 176(8,15), 64(1)\n\t" \ + "mvc 184(8,15), 72(1)\n\t" \ + "mvc 192(8,15), 80(1)\n\t" \ + "mvc 200(8,15), 88(1)\n\t" \ + "mvc 208(8,15), 96(1)\n\t" \ + "lg 1, 0(1)\n\t" \ + VALGRIND_CALL_NOREDIR_R1 \ + "aghi 15,216\n\t" \ + VALGRIND_CFI_EPILOGUE \ + "lgr %0, 2\n\t" \ + : /*out*/ "=d" (_res) \ + : /*in*/ "a" (&_argvec[0]) __FRAME_POINTER \ + : /*trash*/ "cc", "memory", __CALLER_SAVED_REGS,"6","7" \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + + +#endif /* PLAT_s390x_linux */ + +/* ------------------------- mips32-linux ----------------------- */ + +#if defined(PLAT_mips32_linux) + +/* These regs are trashed by the hidden call. */ +#define __CALLER_SAVED_REGS "$2", "$3", "$4", "$5", "$6", \ +"$7", "$8", "$9", "$10", "$11", "$12", "$13", "$14", "$15", "$24", \ +"$25", "$31" + +/* These CALL_FN_ macros assume that on mips-linux, sizeof(unsigned + long) == 4. */ + +#define CALL_FN_W_v(lval, orig) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[1]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + __asm__ volatile( \ + "subu $29, $29, 8 \n\t" \ + "sw $28, 0($29) \n\t" \ + "sw $31, 4($29) \n\t" \ + "subu $29, $29, 16 \n\t" \ + "lw $25, 0(%1) \n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "addu $29, $29, 16\n\t" \ + "lw $28, 0($29) \n\t" \ + "lw $31, 4($29) \n\t" \ + "addu $29, $29, 8 \n\t" \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_W(lval, orig, arg1) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[2]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + __asm__ volatile( \ + "subu $29, $29, 8 \n\t" \ + "sw $28, 0($29) \n\t" \ + "sw $31, 4($29) \n\t" \ + "subu $29, $29, 16 \n\t" \ + "lw $4, 4(%1) \n\t" /* arg1*/ \ + "lw $25, 0(%1) \n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "addu $29, $29, 16 \n\t" \ + "lw $28, 0($29) \n\t" \ + "lw $31, 4($29) \n\t" \ + "addu $29, $29, 8 \n\t" \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WW(lval, orig, arg1,arg2) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + __asm__ volatile( \ + "subu $29, $29, 8 \n\t" \ + "sw $28, 0($29) \n\t" \ + "sw $31, 4($29) \n\t" \ + "subu $29, $29, 16 \n\t" \ + "lw $4, 4(%1) \n\t" \ + "lw $5, 8(%1) \n\t" \ + "lw $25, 0(%1) \n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "addu $29, $29, 16 \n\t" \ + "lw $28, 0($29) \n\t" \ + "lw $31, 4($29) \n\t" \ + "addu $29, $29, 8 \n\t" \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WWW(lval, orig, arg1,arg2,arg3) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[4]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + __asm__ volatile( \ + "subu $29, $29, 8 \n\t" \ + "sw $28, 0($29) \n\t" \ + "sw $31, 4($29) \n\t" \ + "subu $29, $29, 16 \n\t" \ + "lw $4, 4(%1) \n\t" \ + "lw $5, 8(%1) \n\t" \ + "lw $6, 12(%1) \n\t" \ + "lw $25, 0(%1) \n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "addu $29, $29, 16 \n\t" \ + "lw $28, 0($29) \n\t" \ + "lw $31, 4($29) \n\t" \ + "addu $29, $29, 8 \n\t" \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WWWW(lval, orig, arg1,arg2,arg3,arg4) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[5]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + __asm__ volatile( \ + "subu $29, $29, 8 \n\t" \ + "sw $28, 0($29) \n\t" \ + "sw $31, 4($29) \n\t" \ + "subu $29, $29, 16 \n\t" \ + "lw $4, 4(%1) \n\t" \ + "lw $5, 8(%1) \n\t" \ + "lw $6, 12(%1) \n\t" \ + "lw $7, 16(%1) \n\t" \ + "lw $25, 0(%1) \n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "addu $29, $29, 16 \n\t" \ + "lw $28, 0($29) \n\t" \ + "lw $31, 4($29) \n\t" \ + "addu $29, $29, 8 \n\t" \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_5W(lval, orig, arg1,arg2,arg3,arg4,arg5) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[6]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + __asm__ volatile( \ + "subu $29, $29, 8 \n\t" \ + "sw $28, 0($29) \n\t" \ + "sw $31, 4($29) \n\t" \ + "lw $4, 20(%1) \n\t" \ + "subu $29, $29, 24\n\t" \ + "sw $4, 16($29) \n\t" \ + "lw $4, 4(%1) \n\t" \ + "lw $5, 8(%1) \n\t" \ + "lw $6, 12(%1) \n\t" \ + "lw $7, 16(%1) \n\t" \ + "lw $25, 0(%1) \n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "addu $29, $29, 24 \n\t" \ + "lw $28, 0($29) \n\t" \ + "lw $31, 4($29) \n\t" \ + "addu $29, $29, 8 \n\t" \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) +#define CALL_FN_W_6W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[7]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + __asm__ volatile( \ + "subu $29, $29, 8 \n\t" \ + "sw $28, 0($29) \n\t" \ + "sw $31, 4($29) \n\t" \ + "lw $4, 20(%1) \n\t" \ + "subu $29, $29, 32\n\t" \ + "sw $4, 16($29) \n\t" \ + "lw $4, 24(%1) \n\t" \ + "nop\n\t" \ + "sw $4, 20($29) \n\t" \ + "lw $4, 4(%1) \n\t" \ + "lw $5, 8(%1) \n\t" \ + "lw $6, 12(%1) \n\t" \ + "lw $7, 16(%1) \n\t" \ + "lw $25, 0(%1) \n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "addu $29, $29, 32 \n\t" \ + "lw $28, 0($29) \n\t" \ + "lw $31, 4($29) \n\t" \ + "addu $29, $29, 8 \n\t" \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_7W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[8]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + __asm__ volatile( \ + "subu $29, $29, 8 \n\t" \ + "sw $28, 0($29) \n\t" \ + "sw $31, 4($29) \n\t" \ + "lw $4, 20(%1) \n\t" \ + "subu $29, $29, 32\n\t" \ + "sw $4, 16($29) \n\t" \ + "lw $4, 24(%1) \n\t" \ + "sw $4, 20($29) \n\t" \ + "lw $4, 28(%1) \n\t" \ + "sw $4, 24($29) \n\t" \ + "lw $4, 4(%1) \n\t" \ + "lw $5, 8(%1) \n\t" \ + "lw $6, 12(%1) \n\t" \ + "lw $7, 16(%1) \n\t" \ + "lw $25, 0(%1) \n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "addu $29, $29, 32 \n\t" \ + "lw $28, 0($29) \n\t" \ + "lw $31, 4($29) \n\t" \ + "addu $29, $29, 8 \n\t" \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_8W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[9]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + __asm__ volatile( \ + "subu $29, $29, 8 \n\t" \ + "sw $28, 0($29) \n\t" \ + "sw $31, 4($29) \n\t" \ + "lw $4, 20(%1) \n\t" \ + "subu $29, $29, 40\n\t" \ + "sw $4, 16($29) \n\t" \ + "lw $4, 24(%1) \n\t" \ + "sw $4, 20($29) \n\t" \ + "lw $4, 28(%1) \n\t" \ + "sw $4, 24($29) \n\t" \ + "lw $4, 32(%1) \n\t" \ + "sw $4, 28($29) \n\t" \ + "lw $4, 4(%1) \n\t" \ + "lw $5, 8(%1) \n\t" \ + "lw $6, 12(%1) \n\t" \ + "lw $7, 16(%1) \n\t" \ + "lw $25, 0(%1) \n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "addu $29, $29, 40 \n\t" \ + "lw $28, 0($29) \n\t" \ + "lw $31, 4($29) \n\t" \ + "addu $29, $29, 8 \n\t" \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_9W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[10]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + _argvec[9] = (unsigned long)(arg9); \ + __asm__ volatile( \ + "subu $29, $29, 8 \n\t" \ + "sw $28, 0($29) \n\t" \ + "sw $31, 4($29) \n\t" \ + "lw $4, 20(%1) \n\t" \ + "subu $29, $29, 40\n\t" \ + "sw $4, 16($29) \n\t" \ + "lw $4, 24(%1) \n\t" \ + "sw $4, 20($29) \n\t" \ + "lw $4, 28(%1) \n\t" \ + "sw $4, 24($29) \n\t" \ + "lw $4, 32(%1) \n\t" \ + "sw $4, 28($29) \n\t" \ + "lw $4, 36(%1) \n\t" \ + "sw $4, 32($29) \n\t" \ + "lw $4, 4(%1) \n\t" \ + "lw $5, 8(%1) \n\t" \ + "lw $6, 12(%1) \n\t" \ + "lw $7, 16(%1) \n\t" \ + "lw $25, 0(%1) \n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "addu $29, $29, 40 \n\t" \ + "lw $28, 0($29) \n\t" \ + "lw $31, 4($29) \n\t" \ + "addu $29, $29, 8 \n\t" \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_10W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9,arg10) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[11]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + _argvec[9] = (unsigned long)(arg9); \ + _argvec[10] = (unsigned long)(arg10); \ + __asm__ volatile( \ + "subu $29, $29, 8 \n\t" \ + "sw $28, 0($29) \n\t" \ + "sw $31, 4($29) \n\t" \ + "lw $4, 20(%1) \n\t" \ + "subu $29, $29, 48\n\t" \ + "sw $4, 16($29) \n\t" \ + "lw $4, 24(%1) \n\t" \ + "sw $4, 20($29) \n\t" \ + "lw $4, 28(%1) \n\t" \ + "sw $4, 24($29) \n\t" \ + "lw $4, 32(%1) \n\t" \ + "sw $4, 28($29) \n\t" \ + "lw $4, 36(%1) \n\t" \ + "sw $4, 32($29) \n\t" \ + "lw $4, 40(%1) \n\t" \ + "sw $4, 36($29) \n\t" \ + "lw $4, 4(%1) \n\t" \ + "lw $5, 8(%1) \n\t" \ + "lw $6, 12(%1) \n\t" \ + "lw $7, 16(%1) \n\t" \ + "lw $25, 0(%1) \n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "addu $29, $29, 48 \n\t" \ + "lw $28, 0($29) \n\t" \ + "lw $31, 4($29) \n\t" \ + "addu $29, $29, 8 \n\t" \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_11W(lval, orig, arg1,arg2,arg3,arg4,arg5, \ + arg6,arg7,arg8,arg9,arg10, \ + arg11) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[12]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + _argvec[9] = (unsigned long)(arg9); \ + _argvec[10] = (unsigned long)(arg10); \ + _argvec[11] = (unsigned long)(arg11); \ + __asm__ volatile( \ + "subu $29, $29, 8 \n\t" \ + "sw $28, 0($29) \n\t" \ + "sw $31, 4($29) \n\t" \ + "lw $4, 20(%1) \n\t" \ + "subu $29, $29, 48\n\t" \ + "sw $4, 16($29) \n\t" \ + "lw $4, 24(%1) \n\t" \ + "sw $4, 20($29) \n\t" \ + "lw $4, 28(%1) \n\t" \ + "sw $4, 24($29) \n\t" \ + "lw $4, 32(%1) \n\t" \ + "sw $4, 28($29) \n\t" \ + "lw $4, 36(%1) \n\t" \ + "sw $4, 32($29) \n\t" \ + "lw $4, 40(%1) \n\t" \ + "sw $4, 36($29) \n\t" \ + "lw $4, 44(%1) \n\t" \ + "sw $4, 40($29) \n\t" \ + "lw $4, 4(%1) \n\t" \ + "lw $5, 8(%1) \n\t" \ + "lw $6, 12(%1) \n\t" \ + "lw $7, 16(%1) \n\t" \ + "lw $25, 0(%1) \n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "addu $29, $29, 48 \n\t" \ + "lw $28, 0($29) \n\t" \ + "lw $31, 4($29) \n\t" \ + "addu $29, $29, 8 \n\t" \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_12W(lval, orig, arg1,arg2,arg3,arg4,arg5, \ + arg6,arg7,arg8,arg9,arg10, \ + arg11,arg12) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[13]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + _argvec[9] = (unsigned long)(arg9); \ + _argvec[10] = (unsigned long)(arg10); \ + _argvec[11] = (unsigned long)(arg11); \ + _argvec[12] = (unsigned long)(arg12); \ + __asm__ volatile( \ + "subu $29, $29, 8 \n\t" \ + "sw $28, 0($29) \n\t" \ + "sw $31, 4($29) \n\t" \ + "lw $4, 20(%1) \n\t" \ + "subu $29, $29, 56\n\t" \ + "sw $4, 16($29) \n\t" \ + "lw $4, 24(%1) \n\t" \ + "sw $4, 20($29) \n\t" \ + "lw $4, 28(%1) \n\t" \ + "sw $4, 24($29) \n\t" \ + "lw $4, 32(%1) \n\t" \ + "sw $4, 28($29) \n\t" \ + "lw $4, 36(%1) \n\t" \ + "sw $4, 32($29) \n\t" \ + "lw $4, 40(%1) \n\t" \ + "sw $4, 36($29) \n\t" \ + "lw $4, 44(%1) \n\t" \ + "sw $4, 40($29) \n\t" \ + "lw $4, 48(%1) \n\t" \ + "sw $4, 44($29) \n\t" \ + "lw $4, 4(%1) \n\t" \ + "lw $5, 8(%1) \n\t" \ + "lw $6, 12(%1) \n\t" \ + "lw $7, 16(%1) \n\t" \ + "lw $25, 0(%1) \n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "addu $29, $29, 56 \n\t" \ + "lw $28, 0($29) \n\t" \ + "lw $31, 4($29) \n\t" \ + "addu $29, $29, 8 \n\t" \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#endif /* PLAT_mips32_linux */ + +/* ------------------------- nanomips-linux -------------------- */ + +#if defined(PLAT_nanomips_linux) + +/* These regs are trashed by the hidden call. */ +#define __CALLER_SAVED_REGS "$t4", "$t5", "$a0", "$a1", "$a2", \ +"$a3", "$a4", "$a5", "$a6", "$a7", "$t0", "$t1", "$t2", "$t3", \ +"$t8","$t9", "$at" + +/* These CALL_FN_ macros assume that on mips-linux, sizeof(unsigned + long) == 4. */ + +#define CALL_FN_W_v(lval, orig) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[1]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + __asm__ volatile( \ + "lw $t9, 0(%1)\n\t" \ + VALGRIND_CALL_NOREDIR_T9 \ + "move %0, $a0\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_W(lval, orig, arg1) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[2]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + __asm__ volatile( \ + "lw $t9, 0(%1)\n\t" \ + "lw $a0, 4(%1)\n\t" \ + VALGRIND_CALL_NOREDIR_T9 \ + "move %0, $a0\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WW(lval, orig, arg1,arg2) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[3]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + __asm__ volatile( \ + "lw $t9, 0(%1)\n\t" \ + "lw $a0, 4(%1)\n\t" \ + "lw $a1, 8(%1)\n\t" \ + VALGRIND_CALL_NOREDIR_T9 \ + "move %0, $a0\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WWW(lval, orig, arg1,arg2,arg3) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[4]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + __asm__ volatile( \ + "lw $t9, 0(%1)\n\t" \ + "lw $a0, 4(%1)\n\t" \ + "lw $a1, 8(%1)\n\t" \ + "lw $a2,12(%1)\n\t" \ + VALGRIND_CALL_NOREDIR_T9 \ + "move %0, $a0\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_WWWW(lval, orig, arg1,arg2,arg3,arg4) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[5]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + __asm__ volatile( \ + "lw $t9, 0(%1)\n\t" \ + "lw $a0, 4(%1)\n\t" \ + "lw $a1, 8(%1)\n\t" \ + "lw $a2,12(%1)\n\t" \ + "lw $a3,16(%1)\n\t" \ + VALGRIND_CALL_NOREDIR_T9 \ + "move %0, $a0\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_5W(lval, orig, arg1,arg2,arg3,arg4,arg5) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[6]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + __asm__ volatile( \ + "lw $t9, 0(%1)\n\t" \ + "lw $a0, 4(%1)\n\t" \ + "lw $a1, 8(%1)\n\t" \ + "lw $a2,12(%1)\n\t" \ + "lw $a3,16(%1)\n\t" \ + "lw $a4,20(%1)\n\t" \ + VALGRIND_CALL_NOREDIR_T9 \ + "move %0, $a0\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) +#define CALL_FN_W_6W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[7]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + __asm__ volatile( \ + "lw $t9, 0(%1)\n\t" \ + "lw $a0, 4(%1)\n\t" \ + "lw $a1, 8(%1)\n\t" \ + "lw $a2,12(%1)\n\t" \ + "lw $a3,16(%1)\n\t" \ + "lw $a4,20(%1)\n\t" \ + "lw $a5,24(%1)\n\t" \ + VALGRIND_CALL_NOREDIR_T9 \ + "move %0, $a0\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_7W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[8]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + __asm__ volatile( \ + "lw $t9, 0(%1)\n\t" \ + "lw $a0, 4(%1)\n\t" \ + "lw $a1, 8(%1)\n\t" \ + "lw $a2,12(%1)\n\t" \ + "lw $a3,16(%1)\n\t" \ + "lw $a4,20(%1)\n\t" \ + "lw $a5,24(%1)\n\t" \ + "lw $a6,28(%1)\n\t" \ + VALGRIND_CALL_NOREDIR_T9 \ + "move %0, $a0\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_8W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[9]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + __asm__ volatile( \ + "lw $t9, 0(%1)\n\t" \ + "lw $a0, 4(%1)\n\t" \ + "lw $a1, 8(%1)\n\t" \ + "lw $a2,12(%1)\n\t" \ + "lw $a3,16(%1)\n\t" \ + "lw $a4,20(%1)\n\t" \ + "lw $a5,24(%1)\n\t" \ + "lw $a6,28(%1)\n\t" \ + "lw $a7,32(%1)\n\t" \ + VALGRIND_CALL_NOREDIR_T9 \ + "move %0, $a0\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_9W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[10]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + _argvec[9] = (unsigned long)(arg9); \ + __asm__ volatile( \ + "addiu $sp, $sp, -16 \n\t" \ + "lw $t9,36(%1) \n\t" \ + "sw $t9, 0($sp) \n\t" \ + "lw $t9, 0(%1) \n\t" \ + "lw $a0, 4(%1) \n\t" \ + "lw $a1, 8(%1) \n\t" \ + "lw $a2,12(%1) \n\t" \ + "lw $a3,16(%1) \n\t" \ + "lw $a4,20(%1) \n\t" \ + "lw $a5,24(%1) \n\t" \ + "lw $a6,28(%1) \n\t" \ + "lw $a7,32(%1) \n\t" \ + VALGRIND_CALL_NOREDIR_T9 \ + "move %0, $a0 \n\t" \ + "addiu $sp, $sp, 16 \n\t" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_10W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9,arg10) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[11]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + _argvec[9] = (unsigned long)(arg9); \ + _argvec[10] = (unsigned long)(arg10); \ + __asm__ volatile( \ + "addiu $sp, $sp, -16 \n\t" \ + "lw $t9,36(%1) \n\t" \ + "sw $t9, 0($sp) \n\t" \ + "lw $t9,40(%1) \n\t" \ + "sw $t9, 4($sp) \n\t" \ + "lw $t9, 0(%1) \n\t" \ + "lw $a0, 4(%1) \n\t" \ + "lw $a1, 8(%1) \n\t" \ + "lw $a2,12(%1) \n\t" \ + "lw $a3,16(%1) \n\t" \ + "lw $a4,20(%1) \n\t" \ + "lw $a5,24(%1) \n\t" \ + "lw $a6,28(%1) \n\t" \ + "lw $a7,32(%1) \n\t" \ + VALGRIND_CALL_NOREDIR_T9 \ + "move %0, $a0 \n\t" \ + "addiu $sp, $sp, 16 \n\t" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_11W(lval, orig, arg1,arg2,arg3,arg4,arg5, \ + arg6,arg7,arg8,arg9,arg10, \ + arg11) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[12]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + _argvec[9] = (unsigned long)(arg9); \ + _argvec[10] = (unsigned long)(arg10); \ + _argvec[11] = (unsigned long)(arg11); \ + __asm__ volatile( \ + "addiu $sp, $sp, -16 \n\t" \ + "lw $t9,36(%1) \n\t" \ + "sw $t9, 0($sp) \n\t" \ + "lw $t9,40(%1) \n\t" \ + "sw $t9, 4($sp) \n\t" \ + "lw $t9,44(%1) \n\t" \ + "sw $t9, 8($sp) \n\t" \ + "lw $t9, 0(%1) \n\t" \ + "lw $a0, 4(%1) \n\t" \ + "lw $a1, 8(%1) \n\t" \ + "lw $a2,12(%1) \n\t" \ + "lw $a3,16(%1) \n\t" \ + "lw $a4,20(%1) \n\t" \ + "lw $a5,24(%1) \n\t" \ + "lw $a6,28(%1) \n\t" \ + "lw $a7,32(%1) \n\t" \ + VALGRIND_CALL_NOREDIR_T9 \ + "move %0, $a0 \n\t" \ + "addiu $sp, $sp, 16 \n\t" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#define CALL_FN_W_12W(lval, orig, arg1,arg2,arg3,arg4,arg5, \ + arg6,arg7,arg8,arg9,arg10, \ + arg11,arg12) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long _argvec[13]; \ + volatile unsigned long _res; \ + _argvec[0] = (unsigned long)_orig.nraddr; \ + _argvec[1] = (unsigned long)(arg1); \ + _argvec[2] = (unsigned long)(arg2); \ + _argvec[3] = (unsigned long)(arg3); \ + _argvec[4] = (unsigned long)(arg4); \ + _argvec[5] = (unsigned long)(arg5); \ + _argvec[6] = (unsigned long)(arg6); \ + _argvec[7] = (unsigned long)(arg7); \ + _argvec[8] = (unsigned long)(arg8); \ + _argvec[9] = (unsigned long)(arg9); \ + _argvec[10] = (unsigned long)(arg10); \ + _argvec[11] = (unsigned long)(arg11); \ + _argvec[12] = (unsigned long)(arg12); \ + __asm__ volatile( \ + "addiu $sp, $sp, -16 \n\t" \ + "lw $t9,36(%1) \n\t" \ + "sw $t9, 0($sp) \n\t" \ + "lw $t9,40(%1) \n\t" \ + "sw $t9, 4($sp) \n\t" \ + "lw $t9,44(%1) \n\t" \ + "sw $t9, 8($sp) \n\t" \ + "lw $t9,48(%1) \n\t" \ + "sw $t9,12($sp) \n\t" \ + "lw $t9, 0(%1) \n\t" \ + "lw $a0, 4(%1) \n\t" \ + "lw $a1, 8(%1) \n\t" \ + "lw $a2,12(%1) \n\t" \ + "lw $a3,16(%1) \n\t" \ + "lw $a4,20(%1) \n\t" \ + "lw $a5,24(%1) \n\t" \ + "lw $a6,28(%1) \n\t" \ + "lw $a7,32(%1) \n\t" \ + VALGRIND_CALL_NOREDIR_T9 \ + "move %0, $a0 \n\t" \ + "addiu $sp, $sp, 16 \n\t" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) _res; \ + } while (0) + +#endif /* PLAT_nanomips_linux */ + +/* ------------------------- mips64-linux ------------------------- */ + +#if defined(PLAT_mips64_linux) + +/* These regs are trashed by the hidden call. */ +#define __CALLER_SAVED_REGS "$2", "$3", "$4", "$5", "$6", \ +"$7", "$8", "$9", "$10", "$11", "$12", "$13", "$14", "$15", "$24", \ +"$25", "$31" + +/* These CALL_FN_ macros assume that on mips64-linux, + sizeof(long long) == 8. */ + +#define MIPS64_LONG2REG_CAST(x) ((long long)(long)x) + +#define CALL_FN_W_v(lval, orig) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long long _argvec[1]; \ + volatile unsigned long long _res; \ + _argvec[0] = MIPS64_LONG2REG_CAST(_orig.nraddr); \ + __asm__ volatile( \ + "ld $25, 0(%1)\n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "0" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) (long)_res; \ + } while (0) + +#define CALL_FN_W_W(lval, orig, arg1) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long long _argvec[2]; \ + volatile unsigned long long _res; \ + _argvec[0] = MIPS64_LONG2REG_CAST(_orig.nraddr); \ + _argvec[1] = MIPS64_LONG2REG_CAST(arg1); \ + __asm__ volatile( \ + "ld $4, 8(%1)\n\t" /* arg1*/ \ + "ld $25, 0(%1)\n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) (long)_res; \ + } while (0) + +#define CALL_FN_W_WW(lval, orig, arg1,arg2) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long long _argvec[3]; \ + volatile unsigned long long _res; \ + _argvec[0] = _orig.nraddr; \ + _argvec[1] = MIPS64_LONG2REG_CAST(arg1); \ + _argvec[2] = MIPS64_LONG2REG_CAST(arg2); \ + __asm__ volatile( \ + "ld $4, 8(%1)\n\t" \ + "ld $5, 16(%1)\n\t" \ + "ld $25, 0(%1)\n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) (long)_res; \ + } while (0) + + +#define CALL_FN_W_WWW(lval, orig, arg1,arg2,arg3) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long long _argvec[4]; \ + volatile unsigned long long _res; \ + _argvec[0] = _orig.nraddr; \ + _argvec[1] = MIPS64_LONG2REG_CAST(arg1); \ + _argvec[2] = MIPS64_LONG2REG_CAST(arg2); \ + _argvec[3] = MIPS64_LONG2REG_CAST(arg3); \ + __asm__ volatile( \ + "ld $4, 8(%1)\n\t" \ + "ld $5, 16(%1)\n\t" \ + "ld $6, 24(%1)\n\t" \ + "ld $25, 0(%1)\n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) (long)_res; \ + } while (0) + +#define CALL_FN_W_WWWW(lval, orig, arg1,arg2,arg3,arg4) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long long _argvec[5]; \ + volatile unsigned long long _res; \ + _argvec[0] = MIPS64_LONG2REG_CAST(_orig.nraddr); \ + _argvec[1] = MIPS64_LONG2REG_CAST(arg1); \ + _argvec[2] = MIPS64_LONG2REG_CAST(arg2); \ + _argvec[3] = MIPS64_LONG2REG_CAST(arg3); \ + _argvec[4] = MIPS64_LONG2REG_CAST(arg4); \ + __asm__ volatile( \ + "ld $4, 8(%1)\n\t" \ + "ld $5, 16(%1)\n\t" \ + "ld $6, 24(%1)\n\t" \ + "ld $7, 32(%1)\n\t" \ + "ld $25, 0(%1)\n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) (long)_res; \ + } while (0) + +#define CALL_FN_W_5W(lval, orig, arg1,arg2,arg3,arg4,arg5) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long long _argvec[6]; \ + volatile unsigned long long _res; \ + _argvec[0] = MIPS64_LONG2REG_CAST(_orig.nraddr); \ + _argvec[1] = MIPS64_LONG2REG_CAST(arg1); \ + _argvec[2] = MIPS64_LONG2REG_CAST(arg2); \ + _argvec[3] = MIPS64_LONG2REG_CAST(arg3); \ + _argvec[4] = MIPS64_LONG2REG_CAST(arg4); \ + _argvec[5] = MIPS64_LONG2REG_CAST(arg5); \ + __asm__ volatile( \ + "ld $4, 8(%1)\n\t" \ + "ld $5, 16(%1)\n\t" \ + "ld $6, 24(%1)\n\t" \ + "ld $7, 32(%1)\n\t" \ + "ld $8, 40(%1)\n\t" \ + "ld $25, 0(%1)\n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) (long)_res; \ + } while (0) + +#define CALL_FN_W_6W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long long _argvec[7]; \ + volatile unsigned long long _res; \ + _argvec[0] = MIPS64_LONG2REG_CAST(_orig.nraddr); \ + _argvec[1] = MIPS64_LONG2REG_CAST(arg1); \ + _argvec[2] = MIPS64_LONG2REG_CAST(arg2); \ + _argvec[3] = MIPS64_LONG2REG_CAST(arg3); \ + _argvec[4] = MIPS64_LONG2REG_CAST(arg4); \ + _argvec[5] = MIPS64_LONG2REG_CAST(arg5); \ + _argvec[6] = MIPS64_LONG2REG_CAST(arg6); \ + __asm__ volatile( \ + "ld $4, 8(%1)\n\t" \ + "ld $5, 16(%1)\n\t" \ + "ld $6, 24(%1)\n\t" \ + "ld $7, 32(%1)\n\t" \ + "ld $8, 40(%1)\n\t" \ + "ld $9, 48(%1)\n\t" \ + "ld $25, 0(%1)\n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) (long)_res; \ + } while (0) + +#define CALL_FN_W_7W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long long _argvec[8]; \ + volatile unsigned long long _res; \ + _argvec[0] = MIPS64_LONG2REG_CAST(_orig.nraddr); \ + _argvec[1] = MIPS64_LONG2REG_CAST(arg1); \ + _argvec[2] = MIPS64_LONG2REG_CAST(arg2); \ + _argvec[3] = MIPS64_LONG2REG_CAST(arg3); \ + _argvec[4] = MIPS64_LONG2REG_CAST(arg4); \ + _argvec[5] = MIPS64_LONG2REG_CAST(arg5); \ + _argvec[6] = MIPS64_LONG2REG_CAST(arg6); \ + _argvec[7] = MIPS64_LONG2REG_CAST(arg7); \ + __asm__ volatile( \ + "ld $4, 8(%1)\n\t" \ + "ld $5, 16(%1)\n\t" \ + "ld $6, 24(%1)\n\t" \ + "ld $7, 32(%1)\n\t" \ + "ld $8, 40(%1)\n\t" \ + "ld $9, 48(%1)\n\t" \ + "ld $10, 56(%1)\n\t" \ + "ld $25, 0(%1) \n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) (long)_res; \ + } while (0) + +#define CALL_FN_W_8W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long long _argvec[9]; \ + volatile unsigned long long _res; \ + _argvec[0] = MIPS64_LONG2REG_CAST(_orig.nraddr); \ + _argvec[1] = MIPS64_LONG2REG_CAST(arg1); \ + _argvec[2] = MIPS64_LONG2REG_CAST(arg2); \ + _argvec[3] = MIPS64_LONG2REG_CAST(arg3); \ + _argvec[4] = MIPS64_LONG2REG_CAST(arg4); \ + _argvec[5] = MIPS64_LONG2REG_CAST(arg5); \ + _argvec[6] = MIPS64_LONG2REG_CAST(arg6); \ + _argvec[7] = MIPS64_LONG2REG_CAST(arg7); \ + _argvec[8] = MIPS64_LONG2REG_CAST(arg8); \ + __asm__ volatile( \ + "ld $4, 8(%1)\n\t" \ + "ld $5, 16(%1)\n\t" \ + "ld $6, 24(%1)\n\t" \ + "ld $7, 32(%1)\n\t" \ + "ld $8, 40(%1)\n\t" \ + "ld $9, 48(%1)\n\t" \ + "ld $10, 56(%1)\n\t" \ + "ld $11, 64(%1)\n\t" \ + "ld $25, 0(%1) \n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) (long)_res; \ + } while (0) + +#define CALL_FN_W_9W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long long _argvec[10]; \ + volatile unsigned long long _res; \ + _argvec[0] = MIPS64_LONG2REG_CAST(_orig.nraddr); \ + _argvec[1] = MIPS64_LONG2REG_CAST(arg1); \ + _argvec[2] = MIPS64_LONG2REG_CAST(arg2); \ + _argvec[3] = MIPS64_LONG2REG_CAST(arg3); \ + _argvec[4] = MIPS64_LONG2REG_CAST(arg4); \ + _argvec[5] = MIPS64_LONG2REG_CAST(arg5); \ + _argvec[6] = MIPS64_LONG2REG_CAST(arg6); \ + _argvec[7] = MIPS64_LONG2REG_CAST(arg7); \ + _argvec[8] = MIPS64_LONG2REG_CAST(arg8); \ + _argvec[9] = MIPS64_LONG2REG_CAST(arg9); \ + __asm__ volatile( \ + "dsubu $29, $29, 8\n\t" \ + "ld $4, 72(%1)\n\t" \ + "sd $4, 0($29)\n\t" \ + "ld $4, 8(%1)\n\t" \ + "ld $5, 16(%1)\n\t" \ + "ld $6, 24(%1)\n\t" \ + "ld $7, 32(%1)\n\t" \ + "ld $8, 40(%1)\n\t" \ + "ld $9, 48(%1)\n\t" \ + "ld $10, 56(%1)\n\t" \ + "ld $11, 64(%1)\n\t" \ + "ld $25, 0(%1)\n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "daddu $29, $29, 8\n\t" \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) (long)_res; \ + } while (0) + +#define CALL_FN_W_10W(lval, orig, arg1,arg2,arg3,arg4,arg5,arg6, \ + arg7,arg8,arg9,arg10) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long long _argvec[11]; \ + volatile unsigned long long _res; \ + _argvec[0] = MIPS64_LONG2REG_CAST(_orig.nraddr); \ + _argvec[1] = MIPS64_LONG2REG_CAST(arg1); \ + _argvec[2] = MIPS64_LONG2REG_CAST(arg2); \ + _argvec[3] = MIPS64_LONG2REG_CAST(arg3); \ + _argvec[4] = MIPS64_LONG2REG_CAST(arg4); \ + _argvec[5] = MIPS64_LONG2REG_CAST(arg5); \ + _argvec[6] = MIPS64_LONG2REG_CAST(arg6); \ + _argvec[7] = MIPS64_LONG2REG_CAST(arg7); \ + _argvec[8] = MIPS64_LONG2REG_CAST(arg8); \ + _argvec[9] = MIPS64_LONG2REG_CAST(arg9); \ + _argvec[10] = MIPS64_LONG2REG_CAST(arg10); \ + __asm__ volatile( \ + "dsubu $29, $29, 16\n\t" \ + "ld $4, 72(%1)\n\t" \ + "sd $4, 0($29)\n\t" \ + "ld $4, 80(%1)\n\t" \ + "sd $4, 8($29)\n\t" \ + "ld $4, 8(%1)\n\t" \ + "ld $5, 16(%1)\n\t" \ + "ld $6, 24(%1)\n\t" \ + "ld $7, 32(%1)\n\t" \ + "ld $8, 40(%1)\n\t" \ + "ld $9, 48(%1)\n\t" \ + "ld $10, 56(%1)\n\t" \ + "ld $11, 64(%1)\n\t" \ + "ld $25, 0(%1)\n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "daddu $29, $29, 16\n\t" \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) (long)_res; \ + } while (0) + +#define CALL_FN_W_11W(lval, orig, arg1,arg2,arg3,arg4,arg5, \ + arg6,arg7,arg8,arg9,arg10, \ + arg11) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long long _argvec[12]; \ + volatile unsigned long long _res; \ + _argvec[0] = MIPS64_LONG2REG_CAST(_orig.nraddr); \ + _argvec[1] = MIPS64_LONG2REG_CAST(arg1); \ + _argvec[2] = MIPS64_LONG2REG_CAST(arg2); \ + _argvec[3] = MIPS64_LONG2REG_CAST(arg3); \ + _argvec[4] = MIPS64_LONG2REG_CAST(arg4); \ + _argvec[5] = MIPS64_LONG2REG_CAST(arg5); \ + _argvec[6] = MIPS64_LONG2REG_CAST(arg6); \ + _argvec[7] = MIPS64_LONG2REG_CAST(arg7); \ + _argvec[8] = MIPS64_LONG2REG_CAST(arg8); \ + _argvec[9] = MIPS64_LONG2REG_CAST(arg9); \ + _argvec[10] = MIPS64_LONG2REG_CAST(arg10); \ + _argvec[11] = MIPS64_LONG2REG_CAST(arg11); \ + __asm__ volatile( \ + "dsubu $29, $29, 24\n\t" \ + "ld $4, 72(%1)\n\t" \ + "sd $4, 0($29)\n\t" \ + "ld $4, 80(%1)\n\t" \ + "sd $4, 8($29)\n\t" \ + "ld $4, 88(%1)\n\t" \ + "sd $4, 16($29)\n\t" \ + "ld $4, 8(%1)\n\t" \ + "ld $5, 16(%1)\n\t" \ + "ld $6, 24(%1)\n\t" \ + "ld $7, 32(%1)\n\t" \ + "ld $8, 40(%1)\n\t" \ + "ld $9, 48(%1)\n\t" \ + "ld $10, 56(%1)\n\t" \ + "ld $11, 64(%1)\n\t" \ + "ld $25, 0(%1)\n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "daddu $29, $29, 24\n\t" \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) (long)_res; \ + } while (0) + +#define CALL_FN_W_12W(lval, orig, arg1,arg2,arg3,arg4,arg5, \ + arg6,arg7,arg8,arg9,arg10, \ + arg11,arg12) \ + do { \ + volatile OrigFn _orig = (orig); \ + volatile unsigned long long _argvec[13]; \ + volatile unsigned long long _res; \ + _argvec[0] = MIPS64_LONG2REG_CAST(_orig.nraddr); \ + _argvec[1] = MIPS64_LONG2REG_CAST(arg1); \ + _argvec[2] = MIPS64_LONG2REG_CAST(arg2); \ + _argvec[3] = MIPS64_LONG2REG_CAST(arg3); \ + _argvec[4] = MIPS64_LONG2REG_CAST(arg4); \ + _argvec[5] = MIPS64_LONG2REG_CAST(arg5); \ + _argvec[6] = MIPS64_LONG2REG_CAST(arg6); \ + _argvec[7] = MIPS64_LONG2REG_CAST(arg7); \ + _argvec[8] = MIPS64_LONG2REG_CAST(arg8); \ + _argvec[9] = MIPS64_LONG2REG_CAST(arg9); \ + _argvec[10] = MIPS64_LONG2REG_CAST(arg10); \ + _argvec[11] = MIPS64_LONG2REG_CAST(arg11); \ + _argvec[12] = MIPS64_LONG2REG_CAST(arg12); \ + __asm__ volatile( \ + "dsubu $29, $29, 32\n\t" \ + "ld $4, 72(%1)\n\t" \ + "sd $4, 0($29)\n\t" \ + "ld $4, 80(%1)\n\t" \ + "sd $4, 8($29)\n\t" \ + "ld $4, 88(%1)\n\t" \ + "sd $4, 16($29)\n\t" \ + "ld $4, 96(%1)\n\t" \ + "sd $4, 24($29)\n\t" \ + "ld $4, 8(%1)\n\t" \ + "ld $5, 16(%1)\n\t" \ + "ld $6, 24(%1)\n\t" \ + "ld $7, 32(%1)\n\t" \ + "ld $8, 40(%1)\n\t" \ + "ld $9, 48(%1)\n\t" \ + "ld $10, 56(%1)\n\t" \ + "ld $11, 64(%1)\n\t" \ + "ld $25, 0(%1)\n\t" /* target->t9 */ \ + VALGRIND_CALL_NOREDIR_T9 \ + "daddu $29, $29, 32\n\t" \ + "move %0, $2\n" \ + : /*out*/ "=r" (_res) \ + : /*in*/ "r" (&_argvec[0]) \ + : /*trash*/ "memory", __CALLER_SAVED_REGS \ + ); \ + lval = (__typeof__(lval)) (long)_res; \ + } while (0) + +#endif /* PLAT_mips64_linux */ + +/* ------------------------------------------------------------------ */ +/* ARCHITECTURE INDEPENDENT MACROS for CLIENT REQUESTS. */ +/* */ +/* ------------------------------------------------------------------ */ + +/* Some request codes. There are many more of these, but most are not + exposed to end-user view. These are the public ones, all of the + form 0x1000 + small_number. + + Core ones are in the range 0x00000000--0x0000ffff. The non-public + ones start at 0x2000. +*/ + +/* These macros are used by tools -- they must be public, but don't + embed them into other programs. */ +#define VG_USERREQ_TOOL_BASE(a,b) \ + ((unsigned int)(((a)&0xff) << 24 | ((b)&0xff) << 16)) +#define VG_IS_TOOL_USERREQ(a, b, v) \ + (VG_USERREQ_TOOL_BASE(a,b) == ((v) & 0xffff0000)) + +/* !! ABIWARNING !! ABIWARNING !! ABIWARNING !! ABIWARNING !! + This enum comprises an ABI exported by Valgrind to programs + which use client requests. DO NOT CHANGE THE NUMERIC VALUES OF THESE + ENTRIES, NOR DELETE ANY -- add new ones at the end of the most + relevant group. */ +typedef + enum { VG_USERREQ__RUNNING_ON_VALGRIND = 0x1001, + VG_USERREQ__DISCARD_TRANSLATIONS = 0x1002, + + /* These allow any function to be called from the simulated + CPU but run on the real CPU. Nb: the first arg passed to + the function is always the ThreadId of the running + thread! So CLIENT_CALL0 actually requires a 1 arg + function, etc. */ + VG_USERREQ__CLIENT_CALL0 = 0x1101, + VG_USERREQ__CLIENT_CALL1 = 0x1102, + VG_USERREQ__CLIENT_CALL2 = 0x1103, + VG_USERREQ__CLIENT_CALL3 = 0x1104, + + /* Can be useful in regression testing suites -- eg. can + send Valgrind's output to /dev/null and still count + errors. */ + VG_USERREQ__COUNT_ERRORS = 0x1201, + + /* Allows the client program and/or gdbserver to execute a monitor + command. */ + VG_USERREQ__GDB_MONITOR_COMMAND = 0x1202, + + /* Allows the client program to change a dynamic command line + option. */ + VG_USERREQ__CLO_CHANGE = 0x1203, + + /* These are useful and can be interpreted by any tool that + tracks malloc() et al, by using vg_replace_malloc.c. */ + VG_USERREQ__MALLOCLIKE_BLOCK = 0x1301, + VG_USERREQ__RESIZEINPLACE_BLOCK = 0x130b, + VG_USERREQ__FREELIKE_BLOCK = 0x1302, + /* Memory pool support. */ + VG_USERREQ__CREATE_MEMPOOL = 0x1303, + VG_USERREQ__DESTROY_MEMPOOL = 0x1304, + VG_USERREQ__MEMPOOL_ALLOC = 0x1305, + VG_USERREQ__MEMPOOL_FREE = 0x1306, + VG_USERREQ__MEMPOOL_TRIM = 0x1307, + VG_USERREQ__MOVE_MEMPOOL = 0x1308, + VG_USERREQ__MEMPOOL_CHANGE = 0x1309, + VG_USERREQ__MEMPOOL_EXISTS = 0x130a, + + /* Allow printfs to valgrind log. */ + /* The first two pass the va_list argument by value, which + assumes it is the same size as or smaller than a UWord, + which generally isn't the case. Hence are deprecated. + The second two pass the vargs by reference and so are + immune to this problem. */ + /* both :: char* fmt, va_list vargs (DEPRECATED) */ + VG_USERREQ__PRINTF = 0x1401, + VG_USERREQ__PRINTF_BACKTRACE = 0x1402, + /* both :: char* fmt, va_list* vargs */ + VG_USERREQ__PRINTF_VALIST_BY_REF = 0x1403, + VG_USERREQ__PRINTF_BACKTRACE_VALIST_BY_REF = 0x1404, + + /* Stack support. */ + VG_USERREQ__STACK_REGISTER = 0x1501, + VG_USERREQ__STACK_DEREGISTER = 0x1502, + VG_USERREQ__STACK_CHANGE = 0x1503, + + /* Wine support */ + VG_USERREQ__LOAD_PDB_DEBUGINFO = 0x1601, + + /* Querying of debug info. */ + VG_USERREQ__MAP_IP_TO_SRCLOC = 0x1701, + + /* Disable/enable error reporting level. Takes a single + Word arg which is the delta to this thread's error + disablement indicator. Hence 1 disables or further + disables errors, and -1 moves back towards enablement. + Other values are not allowed. */ + VG_USERREQ__CHANGE_ERR_DISABLEMENT = 0x1801, + + /* Some requests used for Valgrind internal, such as + self-test or self-hosting. */ + /* Initialise IR injection */ + VG_USERREQ__VEX_INIT_FOR_IRI = 0x1901, + /* Used by Inner Valgrind to inform Outer Valgrind where to + find the list of inner guest threads */ + VG_USERREQ__INNER_THREADS = 0x1902 + } Vg_ClientRequest; + +#if !defined(__GNUC__) +# define __extension__ /* */ +#endif + + +/* Returns the number of Valgrinds this code is running under. That + is, 0 if running natively, 1 if running under Valgrind, 2 if + running under Valgrind which is running under another Valgrind, + etc. */ +#define RUNNING_ON_VALGRIND \ + (unsigned)VALGRIND_DO_CLIENT_REQUEST_EXPR(0 /* if not */, \ + VG_USERREQ__RUNNING_ON_VALGRIND, \ + 0, 0, 0, 0, 0) \ + + +/* Discard translation of code in the range [_qzz_addr .. _qzz_addr + + _qzz_len - 1]. Useful if you are debugging a JITter or some such, + since it provides a way to make sure valgrind will retranslate the + invalidated area. Returns no value. */ +#define VALGRIND_DISCARD_TRANSLATIONS(_qzz_addr,_qzz_len) \ + VALGRIND_DO_CLIENT_REQUEST_STMT(VG_USERREQ__DISCARD_TRANSLATIONS, \ + _qzz_addr, _qzz_len, 0, 0, 0) + +#define VALGRIND_INNER_THREADS(_qzz_addr) \ + VALGRIND_DO_CLIENT_REQUEST_STMT(VG_USERREQ__INNER_THREADS, \ + _qzz_addr, 0, 0, 0, 0) + + +/* These requests are for getting Valgrind itself to print something. + Possibly with a backtrace. This is a really ugly hack. The return value + is the number of characters printed, excluding the "**<pid>** " part at the + start and the backtrace (if present). */ + +#if defined(__GNUC__) || defined(__INTEL_COMPILER) && !defined(_MSC_VER) +/* Modern GCC will optimize the static routine out if unused, + and unused attribute will shut down warnings about it. */ +static int VALGRIND_PRINTF(const char *format, ...) + __attribute__((format(__printf__, 1, 2), __unused__)); +#endif +static int +#if defined(_MSC_VER) +__inline +#endif +VALGRIND_PRINTF(const char *format, ...) +{ +#if !IS_ENABLED(CONFIG_VALGRIND) + (void)format; + return 0; +#else /* CONFIG_VALGRIND */ +#if defined(_MSC_VER) || defined(__MINGW64__) + uintptr_t _qzz_res; +#else + unsigned long _qzz_res; +#endif + va_list vargs; + va_start(vargs, format); +#if defined(_MSC_VER) || defined(__MINGW64__) + _qzz_res = VALGRIND_DO_CLIENT_REQUEST_EXPR(0, + VG_USERREQ__PRINTF_VALIST_BY_REF, + (uintptr_t)format, + (uintptr_t)&vargs, + 0, 0, 0); +#else + _qzz_res = VALGRIND_DO_CLIENT_REQUEST_EXPR(0, + VG_USERREQ__PRINTF_VALIST_BY_REF, + (unsigned long)format, + (unsigned long)&vargs, + 0, 0, 0); +#endif + va_end(vargs); + return (int)_qzz_res; +#endif /* CONFIG_VALGRIND */ +} + +#if defined(__GNUC__) || defined(__INTEL_COMPILER) && !defined(_MSC_VER) +static int VALGRIND_PRINTF_BACKTRACE(const char *format, ...) + __attribute__((format(__printf__, 1, 2), __unused__)); +#endif +static int +#if defined(_MSC_VER) +__inline +#endif +VALGRIND_PRINTF_BACKTRACE(const char *format, ...) +{ +#if !IS_ENABLED(CONFIG_VALGRIND) + (void)format; + return 0; +#else /* CONFIG_VALGRIND */ +#if defined(_MSC_VER) || defined(__MINGW64__) + uintptr_t _qzz_res; +#else + unsigned long _qzz_res; +#endif + va_list vargs; + va_start(vargs, format); +#if defined(_MSC_VER) || defined(__MINGW64__) + _qzz_res = VALGRIND_DO_CLIENT_REQUEST_EXPR(0, + VG_USERREQ__PRINTF_BACKTRACE_VALIST_BY_REF, + (uintptr_t)format, + (uintptr_t)&vargs, + 0, 0, 0); +#else + _qzz_res = VALGRIND_DO_CLIENT_REQUEST_EXPR(0, + VG_USERREQ__PRINTF_BACKTRACE_VALIST_BY_REF, + (unsigned long)format, + (unsigned long)&vargs, + 0, 0, 0); +#endif + va_end(vargs); + return (int)_qzz_res; +#endif /* CONFIG_VALGRIND */ +} + + +/* These requests allow control to move from the simulated CPU to the + real CPU, calling an arbitrary function. + + Note that the current ThreadId is inserted as the first argument. + So this call: + + VALGRIND_NON_SIMD_CALL2(f, arg1, arg2) + + requires f to have this signature: + + Word f(Word tid, Word arg1, Word arg2) + + where "Word" is a word-sized type. + + Note that these client requests are not entirely reliable. For example, + if you call a function with them that subsequently calls printf(), + there's a high chance Valgrind will crash. Generally, your prospects of + these working are made higher if the called function does not refer to + any global variables, and does not refer to any libc or other functions + (printf et al). Any kind of entanglement with libc or dynamic linking is + likely to have a bad outcome, for tricky reasons which we've grappled + with a lot in the past. +*/ +#define VALGRIND_NON_SIMD_CALL0(_qyy_fn) \ + VALGRIND_DO_CLIENT_REQUEST_EXPR(0 /* default return */, \ + VG_USERREQ__CLIENT_CALL0, \ + _qyy_fn, \ + 0, 0, 0, 0) + +#define VALGRIND_NON_SIMD_CALL1(_qyy_fn, _qyy_arg1) \ + VALGRIND_DO_CLIENT_REQUEST_EXPR(0 /* default return */, \ + VG_USERREQ__CLIENT_CALL1, \ + _qyy_fn, \ + _qyy_arg1, 0, 0, 0) + +#define VALGRIND_NON_SIMD_CALL2(_qyy_fn, _qyy_arg1, _qyy_arg2) \ + VALGRIND_DO_CLIENT_REQUEST_EXPR(0 /* default return */, \ + VG_USERREQ__CLIENT_CALL2, \ + _qyy_fn, \ + _qyy_arg1, _qyy_arg2, 0, 0) + +#define VALGRIND_NON_SIMD_CALL3(_qyy_fn, _qyy_arg1, _qyy_arg2, _qyy_arg3) \ + VALGRIND_DO_CLIENT_REQUEST_EXPR(0 /* default return */, \ + VG_USERREQ__CLIENT_CALL3, \ + _qyy_fn, \ + _qyy_arg1, _qyy_arg2, \ + _qyy_arg3, 0) + + +/* Counts the number of errors that have been recorded by a tool. Nb: + the tool must record the errors with VG_(maybe_record_error)() or + VG_(unique_error)() for them to be counted. */ +#define VALGRIND_COUNT_ERRORS \ + (unsigned)VALGRIND_DO_CLIENT_REQUEST_EXPR( \ + 0 /* default return */, \ + VG_USERREQ__COUNT_ERRORS, \ + 0, 0, 0, 0, 0) + +/* Several Valgrind tools (Memcheck, Massif, Helgrind, DRD) rely on knowing + when heap blocks are allocated in order to give accurate results. This + happens automatically for the standard allocator functions such as + malloc(), calloc(), realloc(), memalign(), new, new[], free(), delete, + delete[], etc. + + But if your program uses a custom allocator, this doesn't automatically + happen, and Valgrind will not do as well. For example, if you allocate + superblocks with mmap() and then allocates chunks of the superblocks, all + Valgrind's observations will be at the mmap() level and it won't know that + the chunks should be considered separate entities. In Memcheck's case, + that means you probably won't get heap block overrun detection (because + there won't be redzones marked as unaddressable) and you definitely won't + get any leak detection. + + The following client requests allow a custom allocator to be annotated so + that it can be handled accurately by Valgrind. + + VALGRIND_MALLOCLIKE_BLOCK marks a region of memory as having been allocated + by a malloc()-like function. For Memcheck (an illustrative case), this + does two things: + + - It records that the block has been allocated. This means any addresses + within the block mentioned in error messages will be + identified as belonging to the block. It also means that if the block + isn't freed it will be detected by the leak checker. + + - It marks the block as being addressable and undefined (if 'is_zeroed' is + not set), or addressable and defined (if 'is_zeroed' is set). This + controls how accesses to the block by the program are handled. + + 'addr' is the start of the usable block (ie. after any + redzone), 'sizeB' is its size. 'rzB' is the redzone size if the allocator + can apply redzones -- these are blocks of padding at the start and end of + each block. Adding redzones is recommended as it makes it much more likely + Valgrind will spot block overruns. `is_zeroed' indicates if the memory is + zeroed (or filled with another predictable value), as is the case for + calloc(). + + VALGRIND_MALLOCLIKE_BLOCK should be put immediately after the point where a + heap block -- that will be used by the client program -- is allocated. + It's best to put it at the outermost level of the allocator if possible; + for example, if you have a function my_alloc() which calls + internal_alloc(), and the client request is put inside internal_alloc(), + stack traces relating to the heap block will contain entries for both + my_alloc() and internal_alloc(), which is probably not what you want. + + For Memcheck users: if you use VALGRIND_MALLOCLIKE_BLOCK to carve out + custom blocks from within a heap block, B, that has been allocated with + malloc/calloc/new/etc, then block B will be *ignored* during leak-checking + -- the custom blocks will take precedence. + + VALGRIND_FREELIKE_BLOCK is the partner to VALGRIND_MALLOCLIKE_BLOCK. For + Memcheck, it does two things: + + - It records that the block has been deallocated. This assumes that the + block was annotated as having been allocated via + VALGRIND_MALLOCLIKE_BLOCK. Otherwise, an error will be issued. + + - It marks the block as being unaddressable. + + VALGRIND_FREELIKE_BLOCK should be put immediately after the point where a + heap block is deallocated. + + VALGRIND_RESIZEINPLACE_BLOCK informs a tool about reallocation. For + Memcheck, it does four things: + + - It records that the size of a block has been changed. This assumes that + the block was annotated as having been allocated via + VALGRIND_MALLOCLIKE_BLOCK. Otherwise, an error will be issued. + + - If the block shrunk, it marks the freed memory as being unaddressable. + + - If the block grew, it marks the new area as undefined and defines a red + zone past the end of the new block. + + - The V-bits of the overlap between the old and the new block are preserved. + + VALGRIND_RESIZEINPLACE_BLOCK should be put after allocation of the new block + and before deallocation of the old block. + + In many cases, these three client requests will not be enough to get your + allocator working well with Memcheck. More specifically, if your allocator + writes to freed blocks in any way then a VALGRIND_MAKE_MEM_UNDEFINED call + will be necessary to mark the memory as addressable just before the zeroing + occurs, otherwise you'll get a lot of invalid write errors. For example, + you'll need to do this if your allocator recycles freed blocks, but it + zeroes them before handing them back out (via VALGRIND_MALLOCLIKE_BLOCK). + Alternatively, if your allocator reuses freed blocks for allocator-internal + data structures, VALGRIND_MAKE_MEM_UNDEFINED calls will also be necessary. + + Really, what's happening is a blurring of the lines between the client + program and the allocator... after VALGRIND_FREELIKE_BLOCK is called, the + memory should be considered unaddressable to the client program, but the + allocator knows more than the rest of the client program and so may be able + to safely access it. Extra client requests are necessary for Valgrind to + understand the distinction between the allocator and the rest of the + program. + + Ignored if addr == 0. +*/ +#define VALGRIND_MALLOCLIKE_BLOCK(addr, sizeB, rzB, is_zeroed) \ + VALGRIND_DO_CLIENT_REQUEST_STMT(VG_USERREQ__MALLOCLIKE_BLOCK, \ + addr, sizeB, rzB, is_zeroed, 0) + +/* See the comment for VALGRIND_MALLOCLIKE_BLOCK for details. + Ignored if addr == 0. +*/ +#define VALGRIND_RESIZEINPLACE_BLOCK(addr, oldSizeB, newSizeB, rzB) \ + VALGRIND_DO_CLIENT_REQUEST_STMT(VG_USERREQ__RESIZEINPLACE_BLOCK, \ + addr, oldSizeB, newSizeB, rzB, 0) + +/* See the comment for VALGRIND_MALLOCLIKE_BLOCK for details. + Ignored if addr == 0. +*/ +#define VALGRIND_FREELIKE_BLOCK(addr, rzB) \ + VALGRIND_DO_CLIENT_REQUEST_STMT(VG_USERREQ__FREELIKE_BLOCK, \ + addr, rzB, 0, 0, 0) + +/* Create a memory pool. */ +#define VALGRIND_CREATE_MEMPOOL(pool, rzB, is_zeroed) \ + VALGRIND_DO_CLIENT_REQUEST_STMT(VG_USERREQ__CREATE_MEMPOOL, \ + pool, rzB, is_zeroed, 0, 0) + +/* Create a memory pool with some flags specifying extended behaviour. + When flags is zero, the behaviour is identical to VALGRIND_CREATE_MEMPOOL. + + The flag VALGRIND_MEMPOOL_METAPOOL specifies that the pieces of memory + associated with the pool using VALGRIND_MEMPOOL_ALLOC will be used + by the application as superblocks to dole out MALLOC_LIKE blocks using + VALGRIND_MALLOCLIKE_BLOCK. In other words, a meta pool is a "2 levels" + pool : first level is the blocks described by VALGRIND_MEMPOOL_ALLOC. + The second level blocks are described using VALGRIND_MALLOCLIKE_BLOCK. + Note that the association between the pool and the second level blocks + is implicit : second level blocks will be located inside first level + blocks. It is necessary to use the VALGRIND_MEMPOOL_METAPOOL flag + for such 2 levels pools, as otherwise valgrind will detect overlapping + memory blocks, and will abort execution (e.g. during leak search). + + Such a meta pool can also be marked as an 'auto free' pool using the flag + VALGRIND_MEMPOOL_AUTO_FREE, which must be OR-ed together with the + VALGRIND_MEMPOOL_METAPOOL. For an 'auto free' pool, VALGRIND_MEMPOOL_FREE + will automatically free the second level blocks that are contained + inside the first level block freed with VALGRIND_MEMPOOL_FREE. + In other words, calling VALGRIND_MEMPOOL_FREE will cause implicit calls + to VALGRIND_FREELIKE_BLOCK for all the second level blocks included + in the first level block. + Note: it is an error to use the VALGRIND_MEMPOOL_AUTO_FREE flag + without the VALGRIND_MEMPOOL_METAPOOL flag. +*/ +#define VALGRIND_MEMPOOL_AUTO_FREE 1 +#define VALGRIND_MEMPOOL_METAPOOL 2 +#define VALGRIND_CREATE_MEMPOOL_EXT(pool, rzB, is_zeroed, flags) \ + VALGRIND_DO_CLIENT_REQUEST_STMT(VG_USERREQ__CREATE_MEMPOOL, \ + pool, rzB, is_zeroed, flags, 0) + +/* Destroy a memory pool. */ +#define VALGRIND_DESTROY_MEMPOOL(pool) \ + VALGRIND_DO_CLIENT_REQUEST_STMT(VG_USERREQ__DESTROY_MEMPOOL, \ + pool, 0, 0, 0, 0) + +/* Associate a piece of memory with a memory pool. */ +#define VALGRIND_MEMPOOL_ALLOC(pool, addr, size) \ + VALGRIND_DO_CLIENT_REQUEST_STMT(VG_USERREQ__MEMPOOL_ALLOC, \ + pool, addr, size, 0, 0) + +/* Disassociate a piece of memory from a memory pool. */ +#define VALGRIND_MEMPOOL_FREE(pool, addr) \ + VALGRIND_DO_CLIENT_REQUEST_STMT(VG_USERREQ__MEMPOOL_FREE, \ + pool, addr, 0, 0, 0) + +/* Disassociate any pieces outside a particular range. */ +#define VALGRIND_MEMPOOL_TRIM(pool, addr, size) \ + VALGRIND_DO_CLIENT_REQUEST_STMT(VG_USERREQ__MEMPOOL_TRIM, \ + pool, addr, size, 0, 0) + +/* Resize and/or move a piece associated with a memory pool. */ +#define VALGRIND_MOVE_MEMPOOL(poolA, poolB) \ + VALGRIND_DO_CLIENT_REQUEST_STMT(VG_USERREQ__MOVE_MEMPOOL, \ + poolA, poolB, 0, 0, 0) + +/* Resize and/or move a piece associated with a memory pool. */ +#define VALGRIND_MEMPOOL_CHANGE(pool, addrA, addrB, size) \ + VALGRIND_DO_CLIENT_REQUEST_STMT(VG_USERREQ__MEMPOOL_CHANGE, \ + pool, addrA, addrB, size, 0) + +/* Return 1 if a mempool exists, else 0. */ +#define VALGRIND_MEMPOOL_EXISTS(pool) \ + (unsigned)VALGRIND_DO_CLIENT_REQUEST_EXPR(0, \ + VG_USERREQ__MEMPOOL_EXISTS, \ + pool, 0, 0, 0, 0) + +/* Mark a piece of memory as being a stack. Returns a stack id. + start is the lowest addressable stack byte, end is the highest + addressable stack byte. */ +#define VALGRIND_STACK_REGISTER(start, end) \ + (unsigned)VALGRIND_DO_CLIENT_REQUEST_EXPR(0, \ + VG_USERREQ__STACK_REGISTER, \ + start, end, 0, 0, 0) + +/* Unmark the piece of memory associated with a stack id as being a + stack. */ +#define VALGRIND_STACK_DEREGISTER(id) \ + VALGRIND_DO_CLIENT_REQUEST_STMT(VG_USERREQ__STACK_DEREGISTER, \ + id, 0, 0, 0, 0) + +/* Change the start and end address of the stack id. + start is the new lowest addressable stack byte, end is the new highest + addressable stack byte. */ +#define VALGRIND_STACK_CHANGE(id, start, end) \ + VALGRIND_DO_CLIENT_REQUEST_STMT(VG_USERREQ__STACK_CHANGE, \ + id, start, end, 0, 0) + +/* Load PDB debug info for Wine PE image_map. */ +#define VALGRIND_LOAD_PDB_DEBUGINFO(fd, ptr, total_size, delta) \ + VALGRIND_DO_CLIENT_REQUEST_STMT(VG_USERREQ__LOAD_PDB_DEBUGINFO, \ + fd, ptr, total_size, delta, 0) + +/* Map a code address to a source file name and line number. buf64 + must point to a 64-byte buffer in the caller's address space. The + result will be dumped in there and is guaranteed to be zero + terminated. If no info is found, the first byte is set to zero. */ +#define VALGRIND_MAP_IP_TO_SRCLOC(addr, buf64) \ + (unsigned)VALGRIND_DO_CLIENT_REQUEST_EXPR(0, \ + VG_USERREQ__MAP_IP_TO_SRCLOC, \ + addr, buf64, 0, 0, 0) + +/* Disable error reporting for this thread. Behaves in a stack like + way, so you can safely call this multiple times provided that + VALGRIND_ENABLE_ERROR_REPORTING is called the same number of times + to re-enable reporting. The first call of this macro disables + reporting. Subsequent calls have no effect except to increase the + number of VALGRIND_ENABLE_ERROR_REPORTING calls needed to re-enable + reporting. Child threads do not inherit this setting from their + parents -- they are always created with reporting enabled. */ +#define VALGRIND_DISABLE_ERROR_REPORTING \ + VALGRIND_DO_CLIENT_REQUEST_STMT(VG_USERREQ__CHANGE_ERR_DISABLEMENT, \ + 1, 0, 0, 0, 0) + +/* Re-enable error reporting, as per comments on + VALGRIND_DISABLE_ERROR_REPORTING. */ +#define VALGRIND_ENABLE_ERROR_REPORTING \ + VALGRIND_DO_CLIENT_REQUEST_STMT(VG_USERREQ__CHANGE_ERR_DISABLEMENT, \ + -1, 0, 0, 0, 0) + +/* Execute a monitor command from the client program. + If a connection is opened with GDB, the output will be sent + according to the output mode set for vgdb. + If no connection is opened, output will go to the log output. + Returns 1 if command not recognised, 0 otherwise. */ +#define VALGRIND_MONITOR_COMMAND(command) \ + VALGRIND_DO_CLIENT_REQUEST_EXPR(0, VG_USERREQ__GDB_MONITOR_COMMAND, \ + command, 0, 0, 0, 0) + + +/* Change the value of a dynamic command line option. + Note that unknown or not dynamically changeable options + will cause a warning message to be output. */ +#define VALGRIND_CLO_CHANGE(option) \ + VALGRIND_DO_CLIENT_REQUEST_STMT(VG_USERREQ__CLO_CHANGE, \ + option, 0, 0, 0, 0) + + +#undef PLAT_x86_darwin +#undef PLAT_amd64_darwin +#undef PLAT_x86_win32 +#undef PLAT_amd64_win64 +#undef PLAT_x86_linux +#undef PLAT_amd64_linux +#undef PLAT_ppc32_linux +#undef PLAT_ppc64be_linux +#undef PLAT_ppc64le_linux +#undef PLAT_arm_linux +#undef PLAT_s390x_linux +#undef PLAT_mips32_linux +#undef PLAT_mips64_linux +#undef PLAT_nanomips_linux +#undef PLAT_x86_solaris +#undef PLAT_amd64_solaris + +#endif /* __VALGRIND_H */
On Wed, May 05, 2021 at 04:08:18PM -0400, Sean Anderson wrote:
Valgrind uses magic code sequences to define an ABI that the client may use to request behavior from the host. In particular, this may be used to inform valgrind about custom allocators, such as the one used in U-Boot.
This adds headers defining these sequences to U-Boot. It also adds a config option to disable emission of these sequences entirely, in the (likely) event that the user does not wish to use valgrind. Note that this option was originally called NVALGRIND, but was renamed (and inverted) to CONFIG_VALGRIND.
These headers were copied from valgrind 3.16.1-4 as distributed in Arch Linux. They are licensed with the bzip2 1.16 license. This appears to be a BSD license with some clauses from Zlib.
Signed-off-by: Sean Anderson seanga2@gmail.com Reviewed-by: Simon Glass sjg@chromium.org
I'm not sure which part of the series breaks building without valgrind installed for everything, but some part of this does, please re-test. Thanks.
Is this due to warnings? I noticed that compiling without CONFIG_VALGRIND set resulted in a bunch of "This statement has no effect" warnings after I had sent out this series. If this is it, I can investigate for v4.
--Sean
Yes, those warnings. CI builds with -Werror on.
Hi Sean,
Did this patch get resent in the end?
Regards, SImon
On 3/21/22 2:06 PM, Simon Glass wrote:
Hi Sean,
No. I can have another look at this series later this week.
--Sean
This annotates malloc and friends so that valgrind can track the heap. To do this, we need to follow a few rules:
* Call VALGRIND_MALLOCLIKE_BLOCK whenever we malloc something * Call VALGRIND_FREELIKE_BLOCK whenever we free something (generally after we have done our bookkeeping) * Call VALGRIND_RESIZEINPLACE_BLOCK whenever we change the size of an allocation. Generally this just needs to happen in realloc, but only if the address stays the same.
In addition to the above, dlmalloc itself tends to make a lot of accesses which we know are safe, but which would be unsafe outside of dlmalloc. For this reason, we provide a suppression file which ignores errors ocurring in dlmalloc.c
Signed-off-by: Sean Anderson seanga2@gmail.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v2: - Fix one branch of rEALLOc missing a VALGRING_*_BLOCK call - Add some additional suppressions for cALLOc and rEALLOc - Simplify calloc clearing logic
common/dlmalloc.c | 35 +++++++++++++++++++++++++++- common/malloc_simple.c | 10 ++++++++ include/malloc.h | 4 ++++ scripts/u-boot.supp | 53 ++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 101 insertions(+), 1 deletion(-) create mode 100644 scripts/u-boot.supp
diff --git a/common/dlmalloc.c b/common/dlmalloc.c index cf0270a9c1..cb311b5846 100644 --- a/common/dlmalloc.c +++ b/common/dlmalloc.c @@ -8,6 +8,7 @@
#include <malloc.h> #include <asm/io.h> +#include <valgrind/memcheck.h>
#ifdef DEBUG #if __STD_C @@ -1329,6 +1330,7 @@ Void_t* mALLOc(bytes) size_t bytes; unlink(victim, bck, fwd); set_inuse_bit_at_offset(victim, victim_size); check_malloced_chunk(victim, nb); + VALGRIND_MALLOCLIKE_BLOCK(chunk2mem(victim), bytes, SIZE_SZ, false); return chunk2mem(victim); }
@@ -1356,6 +1358,7 @@ Void_t* mALLOc(bytes) size_t bytes; unlink(victim, bck, fwd); set_inuse_bit_at_offset(victim, victim_size); check_malloced_chunk(victim, nb); + VALGRIND_MALLOCLIKE_BLOCK(chunk2mem(victim), bytes, SIZE_SZ, false); return chunk2mem(victim); } } @@ -1379,6 +1382,7 @@ Void_t* mALLOc(bytes) size_t bytes; set_head(remainder, remainder_size | PREV_INUSE); set_foot(remainder, remainder_size); check_malloced_chunk(victim, nb); + VALGRIND_MALLOCLIKE_BLOCK(chunk2mem(victim), bytes, SIZE_SZ, false); return chunk2mem(victim); }
@@ -1388,6 +1392,7 @@ Void_t* mALLOc(bytes) size_t bytes; { set_inuse_bit_at_offset(victim, victim_size); check_malloced_chunk(victim, nb); + VALGRIND_MALLOCLIKE_BLOCK(chunk2mem(victim), bytes, SIZE_SZ, false); return chunk2mem(victim); }
@@ -1443,6 +1448,7 @@ Void_t* mALLOc(bytes) size_t bytes; set_head(remainder, remainder_size | PREV_INUSE); set_foot(remainder, remainder_size); check_malloced_chunk(victim, nb); + VALGRIND_MALLOCLIKE_BLOCK(chunk2mem(victim), bytes, SIZE_SZ, false); return chunk2mem(victim); }
@@ -1451,6 +1457,7 @@ Void_t* mALLOc(bytes) size_t bytes; set_inuse_bit_at_offset(victim, victim_size); unlink(victim, bck, fwd); check_malloced_chunk(victim, nb); + VALGRIND_MALLOCLIKE_BLOCK(chunk2mem(victim), bytes, SIZE_SZ, false); return chunk2mem(victim); }
@@ -1499,6 +1506,7 @@ Void_t* mALLOc(bytes) size_t bytes; /* If big and would otherwise need to extend, try to use mmap instead */ if ((unsigned long)nb >= (unsigned long)mmap_threshold && (victim = mmap_chunk(nb))) + VALGRIND_MALLOCLIKE_BLOCK(chunk2mem(victim), bytes, SIZE_SZ, false); return chunk2mem(victim); #endif
@@ -1513,6 +1521,7 @@ Void_t* mALLOc(bytes) size_t bytes; top = chunk_at_offset(victim, nb); set_head(top, remainder_size | PREV_INUSE); check_malloced_chunk(victim, nb); + VALGRIND_MALLOCLIKE_BLOCK(chunk2mem(victim), bytes, SIZE_SZ, false); return chunk2mem(victim);
} @@ -1561,8 +1570,10 @@ void fREe(mem) Void_t* mem;
#if CONFIG_VAL(SYS_MALLOC_F_LEN) /* free() is a no-op - all the memory will be freed on relocation */ - if (!(gd->flags & GD_FLG_FULL_MALLOC_INIT)) + if (!(gd->flags & GD_FLG_FULL_MALLOC_INIT)) { + VALGRIND_FREELIKE_BLOCK(mem, SIZE_SZ); return; + } #endif
if (mem == NULL) /* free(0) has no effect */ @@ -1584,6 +1595,7 @@ void fREe(mem) Void_t* mem; sz = hd & ~PREV_INUSE; next = chunk_at_offset(p, sz); nextsz = chunksize(next); + VALGRIND_FREELIKE_BLOCK(mem, SIZE_SZ);
if (next == top) /* merge with top */ { @@ -1772,6 +1784,8 @@ Void_t* rEALLOc(oldmem, bytes) Void_t* oldmem; size_t bytes; top = chunk_at_offset(oldp, nb); set_head(top, (newsize - nb) | PREV_INUSE); set_head_size(oldp, nb); + VALGRIND_RESIZEINPLACE_BLOCK(chunk2mem(oldp), oldsize, bytes, + SIZE_SZ); return chunk2mem(oldp); } } @@ -1810,10 +1824,12 @@ Void_t* rEALLOc(oldmem, bytes) Void_t* oldmem; size_t bytes; newp = prev; newsize += prevsize + nextsize; newmem = chunk2mem(newp); + VALGRIND_MALLOCLIKE_BLOCK(newmem, bytes, SIZE_SZ, false); MALLOC_COPY(newmem, oldmem, oldsize - SIZE_SZ); top = chunk_at_offset(newp, nb); set_head(top, (newsize - nb) | PREV_INUSE); set_head_size(newp, nb); + VALGRIND_FREELIKE_BLOCK(oldmem, SIZE_SZ); return newmem; } } @@ -1826,6 +1842,7 @@ Void_t* rEALLOc(oldmem, bytes) Void_t* oldmem; size_t bytes; newp = prev; newsize += nextsize + prevsize; newmem = chunk2mem(newp); + VALGRIND_MALLOCLIKE_BLOCK(newmem, bytes, SIZE_SZ, false); MALLOC_COPY(newmem, oldmem, oldsize - SIZE_SZ); goto split; } @@ -1838,6 +1855,7 @@ Void_t* rEALLOc(oldmem, bytes) Void_t* oldmem; size_t bytes; newp = prev; newsize += prevsize; newmem = chunk2mem(newp); + VALGRIND_MALLOCLIKE_BLOCK(newmem, bytes, SIZE_SZ, false); MALLOC_COPY(newmem, oldmem, oldsize - SIZE_SZ); goto split; } @@ -1864,6 +1882,14 @@ Void_t* rEALLOc(oldmem, bytes) Void_t* oldmem; size_t bytes; MALLOC_COPY(newmem, oldmem, oldsize - SIZE_SZ); fREe(oldmem); return newmem; + } else { + /* + * This marks the whole allocation as undefined, but we don't keep around + * the original request, so we don't know what the actual change is + */ + VALGRIND_RESIZEINPLACE_BLOCK(oldmem, 0, bytes, SIZE_SZ); + /* so just make everything defined again */ + VALGRIND_MAKE_MEM_DEFINED(oldmem, bytes); }
@@ -1876,6 +1902,8 @@ Void_t* rEALLOc(oldmem, bytes) Void_t* oldmem; size_t bytes; set_head_size(newp, nb); set_head(remainder, remainder_size | PREV_INUSE); set_inuse_bit_at_offset(remainder, remainder_size); + VALGRIND_MALLOCLIKE_BLOCK(chunk2mem(remainder), remainder_size, SIZE_SZ, + false); fREe(chunk2mem(remainder)); /* let free() deal with it */ } else @@ -2033,6 +2061,7 @@ Void_t* mEMALIGn(alignment, bytes) size_t alignment; size_t bytes; set_head_size(p, leadsize); fREe(chunk2mem(p)); p = newp; + VALGRIND_MALLOCLIKE_BLOCK(chunk2mem(p), bytes, SIZE_SZ, false);
assert (newsize >= nb && (((unsigned long)(chunk2mem(p))) % alignment) == 0); } @@ -2046,6 +2075,8 @@ Void_t* mEMALIGn(alignment, bytes) size_t alignment; size_t bytes; remainder = chunk_at_offset(p, nb); set_head(remainder, remainder_size | PREV_INUSE); set_head_size(p, nb); + VALGRIND_MALLOCLIKE_BLOCK(chunk2mem(remainder), remainder_size, SIZE_SZ, + false); fREe(chunk2mem(remainder)); }
@@ -2148,7 +2179,9 @@ Void_t* cALLOc(n, elem_size) size_t n; size_t elem_size; #endif #endif
+ /* Prevent valgrind complaining that we're zeroing unallocated space */ MALLOC_ZERO(mem, csz - SIZE_SZ); + VALGRIND_MAKE_MEM_DEFINED(mem, sz); return mem; } } diff --git a/common/malloc_simple.c b/common/malloc_simple.c index 0267fb6bec..205e2c3c11 100644 --- a/common/malloc_simple.c +++ b/common/malloc_simple.c @@ -13,6 +13,7 @@ #include <mapmem.h> #include <asm/global_data.h> #include <asm/io.h> +#include <valgrind/valgrind.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -45,6 +46,7 @@ void *malloc_simple(size_t bytes) return ptr;
log_debug("%lx\n", (ulong)ptr); + VALGRIND_MALLOCLIKE_BLOCK(ptr, bytes, 0, false);
return ptr; } @@ -57,6 +59,7 @@ void *memalign_simple(size_t align, size_t bytes) if (!ptr) return ptr; log_debug("aligned to %lx\n", (ulong)ptr); + VALGRIND_MALLOCLIKE_BLOCK(ptr, bytes, 0, false);
return ptr; } @@ -74,6 +77,13 @@ void *calloc(size_t nmemb, size_t elem_size)
return ptr; } + +#if IS_ENABLED(CONFIG_VALGRIND) +void free_simple(void *ptr) +{ + VALGRIND_FREELIKE_BLOCK(ptr, 0); +} +#endif #endif
void malloc_simple_info(void) diff --git a/include/malloc.h b/include/malloc.h index 024b18be00..6f6087571b 100644 --- a/include/malloc.h +++ b/include/malloc.h @@ -886,7 +886,11 @@ void malloc_simple_info(void); #define malloc malloc_simple #define realloc realloc_simple #define memalign memalign_simple +#if IS_ENABLED(CONFIG_VALGRIND) +#define free free_simple +#else static inline void free(void *ptr) {} +#endif void *calloc(size_t nmemb, size_t size); void *realloc_simple(void *ptr, size_t size); #else diff --git a/scripts/u-boot.supp b/scripts/u-boot.supp new file mode 100644 index 0000000000..9562b27a61 --- /dev/null +++ b/scripts/u-boot.supp @@ -0,0 +1,53 @@ +{ + dlmalloc + Memcheck:Addr1 + src:dlmalloc.c +} +{ + dlmalloc + Memcheck:Addr4 + src:dlmalloc.c +} +{ + dlmalloc + Memcheck:Addr8 + src:dlmalloc.c +} +{ + dlmalloc + Memcheck:Addr1 + fun:* + src:dlmalloc.c +} +{ + dlmalloc + Memcheck:Addr4 + fun:* + src:dlmalloc.c +} +{ + dlmalloc + Memcheck:Addr8 + fun:* + src:dlmalloc.c +} +{ + dlmalloc + Memcheck:Value4 + src:dlmalloc.c +} +{ + dlmalloc + Memcheck:Value8 + src:dlmalloc.c +} +{ + dlmalloc + Memcheck:Cond + src:dlmalloc.c +} +{ + dlmalloc + Memcheck:Free + src:dlmalloc.c +}
This documents how to get more detailed results from valgrind made possible by the last two commits.
(no changes since v1)
doc/arch/sandbox.rst | 14 ++++++++++---- 1 file changed, 10 insertions(+), 4 deletions(-)
diff --git a/doc/arch/sandbox.rst b/doc/arch/sandbox.rst index e052b6bdb0..9bc4fec5fe 100644 --- a/doc/arch/sandbox.rst +++ b/doc/arch/sandbox.rst @@ -481,14 +481,20 @@ Using valgrind / memcheck
It is possible to run U-Boot under valgrind to check memory allocations::
- valgrind u-boot + valgrind ./u-boot + +For more detailed results, enable `CONFIG_VALGRIND`. There are many false +positives due to `malloc` itself. Suppress these with:: + + valgrind --suppressions=scripts/u-boot.supp ./u-boot
If you are running sandbox SPL or TPL, then valgrind will not by default notice when U-Boot jumps from TPL to SPL, or from SPL to U-Boot proper. To -fix this, use:: - - valgrind --trace-children=yes u-boot +fix this, use `--trace-children=yes`. To show who alloc'd some troublesome +memory, use `--track-origins=yes`. To uncover possible errors, try running all +unit tests with::
+ valgrind --track-origins=yes --suppressions=scripts/u-boot.supp ./u-boot -Tc 'ut all'
Testing -------
Sean Anderson
