[PATCH v2 0/8] Add DFU, emmc and usb boot for TI am62x
This series adds more boot sources for the TI am62x. For that the dts' are synced from the upstream ti-next git tree (to add usb nodes), some dwc3 glue is and finally the default configuration is tuned to add support for DFU and USB (host and gadget)
Changes in v2: - Update dts sync to v6.3-rc5 - Switch dwc3 glue to a seperate driver rather then in dwc-generic - Minimize config changes to just DFU configuration - Only enable usb port 0 DFU in SPL - Create a seperate defconfig for R5
Sjoerd Simons (8): omap: timer: add ti,am654-timer compatibility arm: mach-k3: am62: Add timer0 id to the dev list arm: dts: k3-am62: Bump dtsi from linux arm: dts: k3-am625-sk: Enable emmc in SPL usb: dwc3: Add dwc3 glue driver for am62 configs: am62: Add configs for enabling USB in U-Boot arm: dts: k3-am625-sk: Enable usb ports in u-boot configs: am62x_evm_*: Enable USB and DFU support
arch/arm/dts/k3-am62-main.dtsi | 259 +++++++++++++++++++++++--- arch/arm/dts/k3-am62-mcu.dtsi | 49 +++++ arch/arm/dts/k3-am62-wakeup.dtsi | 4 +- arch/arm/dts/k3-am625-r5-sk.dts | 2 +- arch/arm/dts/k3-am625-sk-u-boot.dtsi | 27 ++- arch/arm/dts/k3-am625-sk.dts | 95 +++++----- arch/arm/dts/k3-am625.dtsi | 52 ++++++ arch/arm/mach-k3/am62x/dev-data.c | 1 + configs/am62x_evm_a53_defconfig | 35 +++- configs/am62x_evm_r5_usbdfu_defconfig | 116 ++++++++++++ drivers/timer/omap-timer.c | 1 + drivers/usb/dwc3/Kconfig | 14 ++ drivers/usb/dwc3/Makefile | 1 + drivers/usb/dwc3/dwc3-am62.c | 127 +++++++++++++ include/configs/am62x_evm.h | 10 +- 15 files changed, 701 insertions(+), 92 deletions(-) create mode 100644 configs/am62x_evm_r5_usbdfu_defconfig create mode 100644 drivers/usb/dwc3/dwc3-am62.c
THe TI AM654 timer is compatible with the omap-timer implementation, so add it to the id list
Signed-off-by: Sjoerd Simons sjoerd@collabora.com Reviewed-by: Tom Rini trini@konsulko.com ---
(no changes since v1)
drivers/timer/omap-timer.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/timer/omap-timer.c b/drivers/timer/omap-timer.c index aa2e4360c1b..9b6d97dae67 100644 --- a/drivers/timer/omap-timer.c +++ b/drivers/timer/omap-timer.c @@ -114,6 +114,7 @@ static const struct udevice_id omap_timer_ids[] = { { .compatible = "ti,am335x-timer" }, { .compatible = "ti,am4372-timer" }, { .compatible = "ti,omap5430-timer" }, + { .compatible = "ti,am654-timer" }, {} };
Timer0 is used by u-boot as the tick timer; Add it to the soc devices list so it can be enabled via the k3 power controller.
arch/arm/mach-k3/am62x/dev-data.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-k3/am62x/dev-data.c b/arch/arm/mach-k3/am62x/dev-data.c index 616d0650b9c..140dca4bd1d 100644 --- a/arch/arm/mach-k3/am62x/dev-data.c +++ b/arch/arm/mach-k3/am62x/dev-data.c @@ -58,6 +58,7 @@ static struct ti_dev soc_dev_list[] = { PSC_DEV(161, &soc_lpsc_list[8]), PSC_DEV(162, &soc_lpsc_list[9]), PSC_DEV(75, &soc_lpsc_list[10]), + PSC_DEV(36, &soc_lpsc_list[11]), PSC_DEV(102, &soc_lpsc_list[11]), PSC_DEV(146, &soc_lpsc_list[11]), PSC_DEV(13, &soc_lpsc_list[12]),
Update the am62 and am625 device-trees from linux v6.3-rc5 This needed the following tweaks to the u-boot specific dtsi as well: - Switch tick-timer to the main_timer as it's now defined in the main dtsi - Add mdio pins to the cpsw3g pinctrl. It moved to a subnode in the linux dtsi that u-boot doesn't use/support
arch/arm/dts/k3-am62-main.dtsi | 259 ++++++++++++++++++++++++--- arch/arm/dts/k3-am62-mcu.dtsi | 49 +++++ arch/arm/dts/k3-am62-wakeup.dtsi | 4 +- arch/arm/dts/k3-am625-r5-sk.dts | 2 +- arch/arm/dts/k3-am625-sk-u-boot.dtsi | 8 +- arch/arm/dts/k3-am625-sk.dts | 95 +++++----- arch/arm/dts/k3-am625.dtsi | 52 ++++++ 7 files changed, 381 insertions(+), 88 deletions(-)
diff --git a/arch/arm/dts/k3-am62-main.dtsi b/arch/arm/dts/k3-am62-main.dtsi index 4a42f1b2e31..ea683fd77d6 100644 --- a/arch/arm/dts/k3-am62-main.dtsi +++ b/arch/arm/dts/k3-am62-main.dtsi @@ -54,6 +54,12 @@ reg = <0x4044 0x8>; #phy-cells = <1>; }; + + epwm_tbclk: clock@4130 { + compatible = "ti,am62-epwm-tbclk", "syscon"; + reg = <0x4130 0x4>; + #clock-cells = <1>; + }; };
dmss: bus@48000000 { @@ -144,8 +150,8 @@ compatible = "ti,k2g-sci"; ti,host-id = <12>; mbox-names = "rx", "tx"; - mboxes= <&secure_proxy_main 12>, - <&secure_proxy_main 13>; + mboxes = <&secure_proxy_main 12>, + <&secure_proxy_main 13>; reg-names = "debug_messages"; reg = <0x00 0x44043000 0x00 0xfe0>;
@@ -186,6 +192,102 @@ pinctrl-single,function-mask = <0xffffffff>; };
+ main_timer0: timer@2400000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2400000 0x00 0x400>; + interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 36 2>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 36 2>; + assigned-clock-parents = <&k3_clks 36 3>; + power-domains = <&k3_pds 36 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer1: timer@2410000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2410000 0x00 0x400>; + interrupts = <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 37 2>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 37 2>; + assigned-clock-parents = <&k3_clks 37 3>; + power-domains = <&k3_pds 37 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer2: timer@2420000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2420000 0x00 0x400>; + interrupts = <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 38 2>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 38 2>; + assigned-clock-parents = <&k3_clks 38 3>; + power-domains = <&k3_pds 38 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer3: timer@2430000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2430000 0x00 0x400>; + interrupts = <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 39 2>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 39 2>; + assigned-clock-parents = <&k3_clks 39 3>; + power-domains = <&k3_pds 39 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer4: timer@2440000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2440000 0x00 0x400>; + interrupts = <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 40 2>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 40 2>; + assigned-clock-parents = <&k3_clks 40 3>; + power-domains = <&k3_pds 40 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer5: timer@2450000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2450000 0x00 0x400>; + interrupts = <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 41 2>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 41 2>; + assigned-clock-parents = <&k3_clks 41 3>; + power-domains = <&k3_pds 41 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer6: timer@2460000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2460000 0x00 0x400>; + interrupts = <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 42 2>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 42 2>; + assigned-clock-parents = <&k3_clks 42 3>; + power-domains = <&k3_pds 42 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer7: timer@2470000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2470000 0x00 0x400>; + interrupts = <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 43 2>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 43 2>; + assigned-clock-parents = <&k3_clks 43 3>; + power-domains = <&k3_pds 43 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + main_uart0: serial@2800000 { compatible = "ti,am64-uart", "ti,am654-uart"; reg = <0x00 0x02800000 0x00 0x100>; @@ -193,6 +295,7 @@ power-domains = <&k3_pds 146 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 146 0>; clock-names = "fclk"; + status = "disabled"; };
main_uart1: serial@2810000 { @@ -202,6 +305,7 @@ power-domains = <&k3_pds 152 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 152 0>; clock-names = "fclk"; + status = "disabled"; };
main_uart2: serial@2820000 { @@ -211,6 +315,7 @@ power-domains = <&k3_pds 153 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 153 0>; clock-names = "fclk"; + status = "disabled"; };
main_uart3: serial@2830000 { @@ -220,6 +325,7 @@ power-domains = <&k3_pds 154 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 154 0>; clock-names = "fclk"; + status = "disabled"; };
main_uart4: serial@2840000 { @@ -229,6 +335,7 @@ power-domains = <&k3_pds 155 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 155 0>; clock-names = "fclk"; + status = "disabled"; };
main_uart5: serial@2850000 { @@ -238,6 +345,7 @@ power-domains = <&k3_pds 156 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 156 0>; clock-names = "fclk"; + status = "disabled"; };
main_uart6: serial@2860000 { @@ -247,6 +355,7 @@ power-domains = <&k3_pds 158 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 158 0>; clock-names = "fclk"; + status = "disabled"; };
main_i2c0: i2c@20000000 { @@ -258,6 +367,7 @@ power-domains = <&k3_pds 102 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 102 2>; clock-names = "fck"; + status = "disabled"; };
main_i2c1: i2c@20010000 { @@ -269,6 +379,7 @@ power-domains = <&k3_pds 103 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 103 2>; clock-names = "fck"; + status = "disabled"; };
main_i2c2: i2c@20020000 { @@ -280,6 +391,7 @@ power-domains = <&k3_pds 104 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 104 2>; clock-names = "fck"; + status = "disabled"; };
main_i2c3: i2c@20030000 { @@ -291,6 +403,7 @@ power-domains = <&k3_pds 105 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 105 2>; clock-names = "fck"; + status = "disabled"; };
main_spi0: spi@20100000 { @@ -300,7 +413,8 @@ #address-cells = <1>; #size-cells = <0>; power-domains = <&k3_pds 141 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 172 0>; + clocks = <&k3_clks 141 0>; + status = "disabled"; };
main_spi1: spi@20110000 { @@ -310,7 +424,8 @@ #address-cells = <1>; #size-cells = <0>; power-domains = <&k3_pds 142 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 173 0>; + clocks = <&k3_clks 142 0>; + status = "disabled"; };
main_spi2: spi@20120000 { @@ -320,7 +435,8 @@ #address-cells = <1>; #size-cells = <0>; power-domains = <&k3_pds 143 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 174 0>; + clocks = <&k3_clks 143 0>; + status = "disabled"; };
main_gpio_intr: interrupt-controller@a00000 { @@ -385,8 +501,11 @@ ti,clkbuf-sel = <0x7>; ti,otap-del-sel-legacy = <0x0>; ti,otap-del-sel-mmc-hs = <0x0>; - ti,otap-del-sel-ddr52 = <0x9>; - ti,otap-del-sel-hs200 = <0x6>; + ti,otap-del-sel-ddr52 = <0x5>; + ti,otap-del-sel-hs200 = <0x5>; + ti,itap-del-sel-legacy = <0xa>; + ti,itap-del-sel-mmc-hs = <0x1>; + status = "disabled"; };
sdhci1: mmc@fa00000 { @@ -397,19 +516,20 @@ clocks = <&k3_clks 58 5>, <&k3_clks 58 6>; clock-names = "clk_ahb", "clk_xin"; ti,trm-icp = <0x2>; - ti,otap-del-sel-legacy = <0x0>; + ti,otap-del-sel-legacy = <0x8>; ti,otap-del-sel-sd-hs = <0x0>; - ti,otap-del-sel-sdr12 = <0xf>; - ti,otap-del-sel-sdr25 = <0xf>; - ti,otap-del-sel-sdr50 = <0xc>; - ti,otap-del-sel-sdr104 = <0x6>; - ti,otap-del-sel-ddr50 = <0x9>; - ti,itap-del-sel-legacy = <0x0>; - ti,itap-del-sel-sd-hs = <0x0>; - ti,itap-del-sel-sdr12 = <0x0>; - ti,itap-del-sel-sdr25 = <0x0>; + ti,otap-del-sel-sdr12 = <0x0>; + ti,otap-del-sel-sdr25 = <0x0>; + ti,otap-del-sel-sdr50 = <0x8>; + ti,otap-del-sel-sdr104 = <0x7>; + ti,otap-del-sel-ddr50 = <0x4>; + ti,itap-del-sel-legacy = <0xa>; + ti,itap-del-sel-sd-hs = <0x1>; + ti,itap-del-sel-sdr12 = <0xa>; + ti,itap-del-sel-sdr25 = <0x1>; ti,clkbuf-sel = <0x7>; bus-width = <4>; + status = "disabled"; };
sdhci2: mmc@fa20000 { @@ -420,18 +540,65 @@ clocks = <&k3_clks 184 5>, <&k3_clks 184 6>; clock-names = "clk_ahb", "clk_xin"; ti,trm-icp = <0x2>; - ti,otap-del-sel-legacy = <0x0>; + ti,otap-del-sel-legacy = <0x8>; ti,otap-del-sel-sd-hs = <0x0>; - ti,otap-del-sel-sdr12 = <0xf>; - ti,otap-del-sel-sdr25 = <0xf>; - ti,otap-del-sel-sdr50 = <0xc>; - ti,otap-del-sel-sdr104 = <0x6>; - ti,otap-del-sel-ddr50 = <0x9>; - ti,itap-del-sel-legacy = <0x0>; - ti,itap-del-sel-sd-hs = <0x0>; - ti,itap-del-sel-sdr12 = <0x0>; - ti,itap-del-sel-sdr25 = <0x0>; + ti,otap-del-sel-sdr12 = <0x0>; + ti,otap-del-sel-sdr25 = <0x0>; + ti,otap-del-sel-sdr50 = <0x8>; + ti,otap-del-sel-sdr104 = <0x7>; + ti,otap-del-sel-ddr50 = <0x8>; + ti,itap-del-sel-legacy = <0xa>; + ti,itap-del-sel-sd-hs = <0xa>; + ti,itap-del-sel-sdr12 = <0xa>; + ti,itap-del-sel-sdr25 = <0x1>; ti,clkbuf-sel = <0x7>; + status = "disabled"; + }; + + usbss0: dwc3-usb@f900000 { + compatible = "ti,am62-usb"; + reg = <0x00 0x0f900000 0x00 0x800>; + clocks = <&k3_clks 161 3>; + clock-names = "ref"; + ti,syscon-phy-pll-refclk = <&wkup_conf 0x4008>; + #address-cells = <2>; + #size-cells = <2>; + power-domains = <&k3_pds 178 TI_SCI_PD_EXCLUSIVE>; + ranges; + status = "disabled"; + + usb0: usb@31000000 { + compatible = "snps,dwc3"; + reg =<0x00 0x31000000 0x00 0x50000>; + interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>, /* irq.0 */ + <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; /* irq.0 */ + interrupt-names = "host", "peripheral"; + maximum-speed = "high-speed"; + dr_mode = "otg"; + }; + }; + + usbss1: dwc3-usb@f910000 { + compatible = "ti,am62-usb"; + reg = <0x00 0x0f910000 0x00 0x800>; + clocks = <&k3_clks 162 3>; + clock-names = "ref"; + ti,syscon-phy-pll-refclk = <&wkup_conf 0x4018>; + #address-cells = <2>; + #size-cells = <2>; + power-domains = <&k3_pds 179 TI_SCI_PD_EXCLUSIVE>; + ranges; + status = "disabled"; + + usb1: usb@31100000 { + compatible = "snps,dwc3"; + reg =<0x00 0x31100000 0x00 0x50000>; + interrupts = <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>, /* irq.0 */ + <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>; /* irq.0 */ + interrupt-names = "host", "peripheral"; + maximum-speed = "high-speed"; + dr_mode = "otg"; + }; };
fss: bus@fc00000 { @@ -456,6 +623,7 @@ power-domains = <&k3_pds 75 TI_SCI_PD_EXCLUSIVE>; #address-cells = <1>; #size-cells = <0>; + status = "disabled"; }; };
@@ -514,12 +682,13 @@ clocks = <&k3_clks 13 0>; clock-names = "fck"; bus_freq = <1000000>; + status = "disabled"; };
cpts@3d000 { compatible = "ti,j721e-cpts"; reg = <0x00 0x3d000 0x00 0x400>; - clocks = <&k3_clks 13 1>; + clocks = <&k3_clks 13 3>; clock-names = "cpts"; interrupts-extended = <&gic500 GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "cpts"; @@ -551,6 +720,7 @@ power-domains = <&k3_pds 51 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 51 0>; clock-names = "fck"; + status = "disabled"; };
ecap1: pwm@23110000 { @@ -560,6 +730,7 @@ power-domains = <&k3_pds 52 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 52 0>; clock-names = "fck"; + status = "disabled"; };
ecap2: pwm@23120000 { @@ -569,6 +740,7 @@ power-domains = <&k3_pds 53 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 53 0>; clock-names = "fck"; + status = "disabled"; };
main_mcan0: can@20701000 { @@ -583,5 +755,36 @@ <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "int0", "int1"; bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; + status = "disabled"; + }; + + epwm0: pwm@23000000 { + compatible = "ti,am64-epwm", "ti,am3352-ehrpwm"; + #pwm-cells = <3>; + reg = <0x00 0x23000000 0x00 0x100>; + power-domains = <&k3_pds 86 TI_SCI_PD_EXCLUSIVE>; + clocks = <&epwm_tbclk 0>, <&k3_clks 86 0>; + clock-names = "tbclk", "fck"; + status = "disabled"; + }; + + epwm1: pwm@23010000 { + compatible = "ti,am64-epwm", "ti,am3352-ehrpwm"; + #pwm-cells = <3>; + reg = <0x00 0x23010000 0x00 0x100>; + power-domains = <&k3_pds 87 TI_SCI_PD_EXCLUSIVE>; + clocks = <&epwm_tbclk 1>, <&k3_clks 87 0>; + clock-names = "tbclk", "fck"; + status = "disabled"; + }; + + epwm2: pwm@23020000 { + compatible = "ti,am64-epwm", "ti,am3352-ehrpwm"; + #pwm-cells = <3>; + reg = <0x00 0x23020000 0x00 0x100>; + power-domains = <&k3_pds 88 TI_SCI_PD_EXCLUSIVE>; + clocks = <&epwm_tbclk 2>, <&k3_clks 88 0>; + clock-names = "tbclk", "fck"; + status = "disabled"; }; }; diff --git a/arch/arm/dts/k3-am62-mcu.dtsi b/arch/arm/dts/k3-am62-mcu.dtsi index f56c803560f..a427231527c 100644 --- a/arch/arm/dts/k3-am62-mcu.dtsi +++ b/arch/arm/dts/k3-am62-mcu.dtsi @@ -14,6 +14,51 @@ pinctrl-single,function-mask = <0xffffffff>; };
+ /* + * The MCU domain timer interrupts are routed only to the ESM module, + * and not currently available for Linux. The MCU domain timers are + * of limited use without interrupts, and likely reserved by the ESM. + */ + mcu_timer0: timer@4800000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x4800000 0x00 0x400>; + clocks = <&k3_clks 35 2>; + clock-names = "fck"; + power-domains = <&k3_pds 35 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + status = "reserved"; + }; + + mcu_timer1: timer@4810000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x4810000 0x00 0x400>; + clocks = <&k3_clks 48 2>; + clock-names = "fck"; + power-domains = <&k3_pds 48 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + status = "reserved"; + }; + + mcu_timer2: timer@4820000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x4820000 0x00 0x400>; + clocks = <&k3_clks 49 2>; + clock-names = "fck"; + power-domains = <&k3_pds 49 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + status = "reserved"; + }; + + mcu_timer3: timer@4830000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x4830000 0x00 0x400>; + clocks = <&k3_clks 50 2>; + clock-names = "fck"; + power-domains = <&k3_pds 50 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + status = "reserved"; + }; + mcu_uart0: serial@4a00000 { compatible = "ti,am64-uart", "ti,am654-uart"; reg = <0x00 0x04a00000 0x00 0x100>; @@ -21,6 +66,7 @@ power-domains = <&k3_pds 149 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 149 0>; clock-names = "fclk"; + status = "disabled"; };
mcu_i2c0: i2c@4900000 { @@ -32,6 +78,7 @@ power-domains = <&k3_pds 106 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 106 2>; clock-names = "fck"; + status = "disabled"; };
mcu_spi0: spi@4b00000 { @@ -42,6 +89,7 @@ #size-cells = <0>; power-domains = <&k3_pds 147 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 147 0>; + status = "disabled"; };
mcu_spi1: spi@4b10000 { @@ -52,6 +100,7 @@ #size-cells = <0>; power-domains = <&k3_pds 148 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 148 0>; + status = "disabled"; };
mcu_gpio_intr: interrupt-controller@4210000 { diff --git a/arch/arm/dts/k3-am62-wakeup.dtsi b/arch/arm/dts/k3-am62-wakeup.dtsi index 4090134676c..38dced6b4fe 100644 --- a/arch/arm/dts/k3-am62-wakeup.dtsi +++ b/arch/arm/dts/k3-am62-wakeup.dtsi @@ -26,16 +26,18 @@ power-domains = <&k3_pds 114 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 114 0>; clock-names = "fclk"; + status = "disabled"; };
wkup_i2c0: i2c@2b200000 { compatible = "ti,am64-i2c", "ti,omap4-i2c"; - reg = <0x00 0x02b200000 0x00 0x100>; + reg = <0x00 0x2b200000 0x00 0x100>; interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; power-domains = <&k3_pds 107 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 107 4>; clock-names = "fck"; + status = "disabled"; }; }; diff --git a/arch/arm/dts/k3-am625-r5-sk.dts b/arch/arm/dts/k3-am625-r5-sk.dts index dad46704a2d..59ce1a1d70e 100644 --- a/arch/arm/dts/k3-am625-r5-sk.dts +++ b/arch/arm/dts/k3-am625-r5-sk.dts @@ -20,7 +20,7 @@
chosen { stdout-path = "serial2:115200n8"; - tick-timer = &timer1; + tick-timer = &main_timer0; };
memory@80000000 { diff --git a/arch/arm/dts/k3-am625-sk-u-boot.dtsi b/arch/arm/dts/k3-am625-sk-u-boot.dtsi index 249155733a2..0def84b4cf0 100644 --- a/arch/arm/dts/k3-am625-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am625-sk-u-boot.dtsi @@ -7,7 +7,7 @@ / { chosen { stdout-path = "serial2:115200n8"; - tick-timer = &timer1; + tick-timer = &main_timer0; };
aliases { @@ -22,10 +22,7 @@ &cbass_main{ bootph-pre-ram;
- timer1: timer@2400000 { - compatible = "ti,omap5430-timer"; - reg = <0x00 0x2400000 0x00 0x80>; - ti,timer-alwon; + timer@2400000 { clock-frequency = <25000000>; bootph-pre-ram; }; @@ -133,6 +130,7 @@ reg-names = "cpsw_nuss", "mac_efuse"; /delete-property/ ranges; bootph-pre-ram; + pinctrl-0 = <&main_mdio1_pins_default &main_rgmii1_pins_default>;
cpsw-phy-sel@04044 { compatible = "ti,am64-phy-gmii-sel"; diff --git a/arch/arm/dts/k3-am625-sk.dts b/arch/arm/dts/k3-am625-sk.dts index af5617ff44d..6bc7d63cf52 100644 --- a/arch/arm/dts/k3-am625-sk.dts +++ b/arch/arm/dts/k3-am625-sk.dts @@ -13,7 +13,7 @@ #include "k3-am625.dtsi"
/ { - compatible = "ti,am625-sk", "ti,am625"; + compatible = "ti,am625-sk", "ti,am625"; model = "Texas Instruments AM625 SK";
aliases { @@ -24,6 +24,8 @@ spi0 = &ospi0; ethernet0 = &cpsw_port1; ethernet1 = &cpsw_port2; + usb0 = &usb0; + usb1 = &usb1; };
chosen { @@ -31,6 +33,15 @@ bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000"; };
+ opp-table { + /* Add 1.4GHz OPP for am625-sk board. Requires VDD_CORE to be at 0.85V */ + opp-1400000000 { + opp-hz = /bits/ 64 <1400000000>; + opp-supported-hw = <0x01 0x0004>; + clock-latency-ns = <6000000>; + }; + }; + memory@80000000 { device_type = "memory"; /* 2G RAM */ @@ -275,6 +286,12 @@ AM62X_IOPAD(0x01d4, PIN_INPUT, 7) /* (B15) UART0_RTSn.GPIO1_23 */ >; }; + + main_usb1_pins_default: main-usb1-pins-default { + pinctrl-single,pins = < + AM62X_IOPAD(0x0258, PIN_OUTPUT, 0) /* (F18) USB1_DRVVBUS */ + >; + }; };
&wkup_uart0 { @@ -282,11 +299,8 @@ status = "reserved"; };
-&mcu_uart0 { - status = "disabled"; -}; - &main_uart0 { + status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_uart0_pins_default>; }; @@ -296,42 +310,16 @@ status = "reserved"; };
-&main_uart2 { - status = "disabled"; -}; - -&main_uart3 { - status = "disabled"; -}; - -&main_uart4 { - status = "disabled"; -}; - -&main_uart5 { - status = "disabled"; -}; - -&main_uart6 { - status = "disabled"; -}; - -&mcu_i2c0 { - status = "disabled"; -}; - -&wkup_i2c0 { - status = "disabled"; -}; - &main_i2c0 { - status = "disabled"; + status = "okay"; + pinctrl-names = "default"; pinctrl-0 = <&main_i2c0_pins_default>; clock-frequency = <400000>; };
&main_i2c1 { - status = "disabled"; + status = "okay"; + pinctrl-names = "default"; pinctrl-0 = <&main_i2c1_pins_default>; clock-frequency = <400000>;
@@ -363,15 +351,8 @@ }; };
-&main_i2c2 { - status = "disabled"; -}; - -&main_i2c3 { - status = "disabled"; -}; - &sdhci0 { + status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_mmc0_pins_default>; ti,driver-strength-ohm = <50>; @@ -380,6 +361,7 @@
&sdhci1 { /* SD/MMC */ + status = "okay"; vmmc-supply = <&vdd_mmc1>; vqmmc-supply = <&vdd_sd_dv>; pinctrl-names = "default"; @@ -390,8 +372,7 @@
&cpsw3g { pinctrl-names = "default"; - pinctrl-0 = <&main_mdio1_pins_default - &main_rgmii1_pins_default + pinctrl-0 = <&main_rgmii1_pins_default &main_rgmii2_pins_default>; };
@@ -406,6 +387,10 @@ };
&cpsw3g_mdio { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&main_mdio1_pins_default>; + cpsw3g_phy0: ethernet-phy@0 { reg = <0>; ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; @@ -429,6 +414,7 @@ };
&ospi0 { + status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&ospi0_pins_default>;
@@ -487,18 +473,21 @@ }; };
-&ecap0 { - status = "disabled"; +&usbss0 { + status = "okay"; + ti,vbus-divider; };
-&ecap1 { - status = "disabled"; +&usbss1 { + status = "okay"; };
-&ecap2 { - status = "disabled"; +&usb0 { + dr_mode = "peripheral"; };
-&main_mcan0 { - status = "disabled"; +&usb1 { + dr_mode = "host"; + pinctrl-names = "default"; + pinctrl-0 = <&main_usb1_pins_default>; }; diff --git a/arch/arm/dts/k3-am625.dtsi b/arch/arm/dts/k3-am625.dtsi index 887f31c23fe..acc7f8ab642 100644 --- a/arch/arm/dts/k3-am625.dtsi +++ b/arch/arm/dts/k3-am625.dtsi @@ -48,6 +48,8 @@ d-cache-line-size = <64>; d-cache-sets = <128>; next-level-cache = <&L2_0>; + operating-points-v2 = <&a53_opp_table>; + clocks = <&k3_clks 135 0>; };
cpu1: cpu@1 { @@ -62,6 +64,8 @@ d-cache-line-size = <64>; d-cache-sets = <128>; next-level-cache = <&L2_0>; + operating-points-v2 = <&a53_opp_table>; + clocks = <&k3_clks 136 0>; };
cpu2: cpu@2 { @@ -76,6 +80,8 @@ d-cache-line-size = <64>; d-cache-sets = <128>; next-level-cache = <&L2_0>; + operating-points-v2 = <&a53_opp_table>; + clocks = <&k3_clks 137 0>; };
cpu3: cpu@3 { @@ -90,11 +96,57 @@ d-cache-line-size = <64>; d-cache-sets = <128>; next-level-cache = <&L2_0>; + operating-points-v2 = <&a53_opp_table>; + clocks = <&k3_clks 138 0>; + }; + }; + + a53_opp_table: opp-table { + compatible = "operating-points-v2-ti-cpu"; + opp-shared; + syscon = <&wkup_conf>; + + opp-200000000 { + opp-hz = /bits/ 64 <200000000>; + opp-supported-hw = <0x01 0x0007>; + clock-latency-ns = <6000000>; + }; + + opp-400000000 { + opp-hz = /bits/ 64 <400000000>; + opp-supported-hw = <0x01 0x0007>; + clock-latency-ns = <6000000>; + }; + + opp-600000000 { + opp-hz = /bits/ 64 <600000000>; + opp-supported-hw = <0x01 0x0007>; + clock-latency-ns = <6000000>; + }; + + opp-800000000 { + opp-hz = /bits/ 64 <800000000>; + opp-supported-hw = <0x01 0x0007>; + clock-latency-ns = <6000000>; + }; + + opp-1000000000 { + opp-hz = /bits/ 64 <1000000000>; + opp-supported-hw = <0x01 0x0006>; + clock-latency-ns = <6000000>; + }; + + opp-1250000000 { + opp-hz = /bits/ 64 <1250000000>; + opp-supported-hw = <0x01 0x0004>; + clock-latency-ns = <6000000>; + opp-suspend; }; };
L2_0: l2-cache0 { compatible = "cache"; + cache-unified; cache-level = <2>; cache-size = <0x40000>; cache-line-size = <64>;
Changes in v2:
Reviewed-by: Nishanth Menon nm@ti.com
Note to self: I think we should probably refactor r5-sk.dtsi to make the common pieces to be included from a common soc-r5.dtsi.
reg = <0x4130 0x4>;
#clock-cells = <1>;
reg-names = "debug_messages"; reg = <0x00 0x44043000 0x00 0xfe0>;<&secure_proxy_main 13>;
- main_timer0: timer@2400000 {
ti,timer-pwm;
- main_timer1: timer@2410000 {
ti,timer-pwm;
- main_timer2: timer@2420000 {
ti,timer-pwm;
- main_timer3: timer@2430000 {
ti,timer-pwm;
- main_timer4: timer@2440000 {
ti,timer-pwm;
- main_timer5: timer@2450000 {
ti,timer-pwm;
- main_timer6: timer@2460000 {
ti,timer-pwm;
- main_timer7: timer@2470000 {
ti,timer-pwm;
- main_uart0: serial@2800000 { compatible = "ti,am64-uart", "ti,am654-uart"; reg = <0x00 0x02800000 0x00 0x100>;
ti,otap-del-sel-sd-hs = <0x0>;ti,otap-del-sel-legacy = <0x8>;
#size-cells = <2>;
ranges;
dr_mode = "otg";
#size-cells = <2>;
ranges;
dr_mode = "otg";
fss: bus@fc00000 {
}; };status = "disabled";
- epwm0: pwm@23000000 {
#pwm-cells = <3>;
- epwm1: pwm@23010000 {
#pwm-cells = <3>;
- epwm2: pwm@23020000 {
#pwm-cells = <3>;
- mcu_timer0: timer@4800000 {
ti,timer-pwm;
- mcu_timer1: timer@4810000 {
ti,timer-pwm;
- mcu_timer2: timer@4820000 {
ti,timer-pwm;
- mcu_timer3: timer@4830000 {
ti,timer-pwm;
- mcu_uart0: serial@4a00000 { compatible = "ti,am64-uart", "ti,am654-uart"; reg = <0x00 0x04a00000 0x00 0x100>;
interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; power-domains = <&k3_pds 107 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 107 4>; clock-names = "fck";reg = <0x00 0x2b200000 0x00 0x100>;
memory@80000000 {
aliases {
ti,timer-alwon;
- timer@2400000 { clock-frequency = <25000000>; bootph-pre-ram; };
aliases {
usb0 = &usb0;
usb1 = &usb1;
chosen {
- opp-table {
opp-1400000000 {
- memory@80000000 { device_type = "memory"; /* 2G RAM */
- main_usb1_pins_default: main-usb1-pins-default {
-&mcu_uart0 {
&main_uart0 {
- status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_uart0_pins_default>;
-&main_uart2 {
-&main_uart3 {
-&main_uart4 {
-&main_uart5 {
-&main_uart6 {
-&mcu_i2c0 {
-&wkup_i2c0 {
&main_i2c0 {
- status = "okay";
- pinctrl-names = "default"; pinctrl-0 = <&main_i2c0_pins_default>; clock-frequency = <400000>;
&main_i2c1 {
- status = "okay";
- pinctrl-names = "default"; pinctrl-0 = <&main_i2c1_pins_default>; clock-frequency = <400000>;
-&main_i2c2 {
-&main_i2c3 {
&sdhci0 {
- status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_mmc0_pins_default>; ti,driver-strength-ohm = <50>;
@@ -380,6 +361,7 @@
- status = "okay"; vmmc-supply = <&vdd_mmc1>; vqmmc-supply = <&vdd_sd_dv>; pinctrl-names = "default";
@@ -390,8 +372,7 @@
- pinctrl-0 = <&main_rgmii1_pins_default &main_rgmii2_pins_default>;
&cpsw3g_mdio {
- status = "okay";
- pinctrl-0 = <&main_mdio1_pins_default>;
- cpsw3g_phy0: ethernet-phy@0 { reg = <0>; ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>;
&ospi0 {
- status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&ospi0_pins_default>;
-&ecap0 {
+&usbss0 {
- status = "okay";
- ti,vbus-divider;
-&ecap1 {
+&usbss1 {
- status = "okay";
-&ecap2 {
+&usb0 {
- dr_mode = "peripheral";
-&main_mcan0 {
+&usb1 {
- dr_mode = "host";
- pinctrl-0 = <&main_usb1_pins_default>;
cpu1: cpu@1 {
cpu2: cpu@2 {
cpu3: cpu@3 {
opp-shared;
opp-200000000 {
opp-400000000 {
opp-600000000 {
opp-800000000 {
opp-1000000000 {
opp-1250000000 {
opp-suspend;
cache-unified;
-- 2.40.0
sdhci0 on the k3-am625-sk is the emmc, enable this in SPL as well to allow booting from that media.
arch/arm/dts/k3-am625-sk-u-boot.dtsi | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/arm/dts/k3-am625-sk-u-boot.dtsi b/arch/arm/dts/k3-am625-sk-u-boot.dtsi index 0def84b4cf0..5f90a4b56f1 100644 --- a/arch/arm/dts/k3-am625-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am625-sk-u-boot.dtsi @@ -92,6 +92,14 @@ bootph-pre-ram; };
+&sdhci0 { + bootph-pre-ram; +}; + +&main_mmc0_pins_default { + bootph-pre-ram; +}; + &sdhci1 { bootph-pre-ram; };
Hello Sjoerd,
thanks for the patch! I've tested the eMMC boot on AM625 SK and this was exactly the missing piece, with the patch it boots fine:
Tested-by: Alexander Sverdlin alexander.sverdlin@siemens.com
diff --git a/arch/arm/dts/k3-am625-sk-u-boot.dtsi b/arch/arm/dts/k3-am625-sk-u-boot.dtsi index 0def84b4cf0..5f90a4b56f1 100644 --- a/arch/arm/dts/k3-am625-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am625-sk-u-boot.dtsi @@ -92,6 +92,14 @@ bootph-pre-ram; }; +&sdhci0 { + bootph-pre-ram; +};
On 07:35-20230919, Sverdlin, Alexander wrote:
Hello Sjoerd,
note: I have also posted https://lore.kernel.org/r/20230911162535.1044560-4-nm@ti.com
That should take care of this in the kernel sync next time around.
But, for next:
-- Alexander Sverdlin Siemens AG www.siemens.com
Hello Sjoerd,
But, for next:
Reviewed-by: Dhruva Gole d-gole@ti.com
-- Regards, Nishanth Menon Key (0xDDB5849D1736249D) / Fingerprint: F8A2 8693 54EB 8232 17A3 1A34 DDB5 849D 1736 249D
Add glue code for TI AM62 to the dwc3 driver; Most code adopted from TI vendor u-boot code.
Changes in v2: - Switch dwc3 glue to a seperate driver rather then in dwc-generic
drivers/usb/dwc3/Kconfig | 14 ++++ drivers/usb/dwc3/Makefile | 1 + drivers/usb/dwc3/dwc3-am62.c | 127 +++++++++++++++++++++++++++++++++++ 3 files changed, 142 insertions(+) create mode 100644 drivers/usb/dwc3/dwc3-am62.c
diff --git a/drivers/usb/dwc3/Kconfig b/drivers/usb/dwc3/Kconfig index c0c8c16fd9c..26a1e1770c5 100644 --- a/drivers/usb/dwc3/Kconfig +++ b/drivers/usb/dwc3/Kconfig @@ -37,6 +37,20 @@ config SPL_USB_DWC3_GENERIC Select this for Xilinx ZynqMP and similar Platforms. This wrapper supports Host and Peripheral operation modes.
+config SPL_USB_DWC3_AM62 + bool "TI AM62 USB wrapper" + depends on SPL_DM_USB && SPL_USB_DWC3_GENERIC + help + Select this for TI AM62 Platforms. + This wrapper supports Host and Peripheral operation modes. + +config USB_DWC3_AM62 + bool "TI AM62 USB wrapper" + depends on DM_USB && USB_DWC3_GENERIC + help + Select this for TI AM62 Platforms. + This wrapper supports Host and Peripheral operation modes. + config USB_DWC3_MESON_G12A bool "Amlogic Meson G12A USB wrapper" depends on DM_USB && USB_DWC3 && ARCH_MESON diff --git a/drivers/usb/dwc3/Makefile b/drivers/usb/dwc3/Makefile index 97b4f7191ca..a46b6824ab7 100644 --- a/drivers/usb/dwc3/Makefile +++ b/drivers/usb/dwc3/Makefile @@ -6,6 +6,7 @@ dwc3-y := core.o
obj-$(CONFIG_USB_DWC3_GADGET) += gadget.o ep0.o
+obj-$(CONFIG_$(SPL_)USB_DWC3_AM62) += dwc3-am62.o obj-$(CONFIG_USB_DWC3_OMAP) += dwc3-omap.o obj-$(CONFIG_USB_DWC3_MESON_G12A) += dwc3-meson-g12a.o obj-$(CONFIG_USB_DWC3_MESON_GXL) += dwc3-meson-gxl.o diff --git a/drivers/usb/dwc3/dwc3-am62.c b/drivers/usb/dwc3/dwc3-am62.c new file mode 100644 index 00000000000..20d99758b4f --- /dev/null +++ b/drivers/usb/dwc3/dwc3-am62.c @@ -0,0 +1,127 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * TI AM62 specific glue layer for DWC3 + */ + +#include <common.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <regmap.h> +#include <syscon.h> +#include <asm/io.h> + +#include "dwc3-generic.h" + +void dwc3_ti_am62_glue_configure(struct udevice *dev, int index, + enum usb_dr_mode mode) +{ +#define USBSS_MODE_CONTROL 0x1c +#define USBSS_PHY_CONFIG 0x8 +#define USBSS_PHY_VBUS_SEL_MASK GENMASK(2, 1) +#define USBSS_PHY_VBUS_SEL_SHIFT 1 +#define USBSS_MODE_VALID BIT(0) +#define PHY_PLL_REFCLK_MASK GENMASK(3, 0) +static const int dwc3_ti_am62_rate_table[] = { /* in KHZ */ + 9600, + 10000, + 12000, + 19200, + 20000, + 24000, + 25000, + 26000, + 38400, + 40000, + 58000, + 50000, + 52000, +}; + + struct clk usb2_refclk; + int rate_code, i, ret; + unsigned long rate; + u32 reg; + void *usbss; + bool vbus_divider; + struct regmap *syscon; + struct ofnode_phandle_args args; + + usbss = dev_remap_addr_index(dev, 0); + if (IS_ERR(usbss)) { + dev_err(dev, "can't map IOMEM resource\n"); + return; + } + + ret = clk_get_by_name(dev, "ref", &usb2_refclk); + if (ret) { + dev_err(dev, "can't get usb2_refclk\n"); + return; + } + + /* Calcuate the rate code */ + rate = clk_get_rate(&usb2_refclk); + rate /= 1000; /* To KHz */ + for (i = 0; i < ARRAY_SIZE(dwc3_ti_am62_rate_table); i++) { + if (dwc3_ti_am62_rate_table[i] == rate) + break; + } + + if (i == ARRAY_SIZE(dwc3_ti_am62_rate_table)) { + dev_err(dev, "unsupported usb2_refclk rate: %lu KHz\n", rate); + return; + } + + rate_code = i; + + /* Read the syscon property */ + syscon = syscon_regmap_lookup_by_phandle(dev, "ti,syscon-phy-pll-refclk"); + if (IS_ERR(syscon)) { + dev_err(dev, "unable to get ti,syscon-phy-pll-refclk regmap\n"); + return; + } + + ret = ofnode_parse_phandle_with_args(dev_ofnode(dev), "ti,syscon-phy-pll-refclk", NULL, 1, + 0, &args); + if (ret) + return; + + /* Program PHY PLL refclk by reading syscon property */ + ret = regmap_update_bits(syscon, args.args[0], PHY_PLL_REFCLK_MASK, rate_code); + if (ret) { + dev_err(dev, "failed to set phy pll reference clock rate\n"); + return; + } + + /* VBUS divider select */ + reg = readl(usbss + USBSS_PHY_CONFIG); + vbus_divider = dev_read_bool(dev, "ti,vbus-divider"); + if (vbus_divider) + reg |= 1 << USBSS_PHY_VBUS_SEL_SHIFT; + + writel(reg, usbss + USBSS_PHY_CONFIG); + + /* Set mode valid */ + reg = readl(usbss + USBSS_MODE_CONTROL); + reg |= USBSS_MODE_VALID; + writel(reg, usbss + USBSS_MODE_CONTROL); +} + +struct dwc3_glue_ops ti_am62_ops = { + .glue_configure = dwc3_ti_am62_glue_configure, +}; + +static const struct udevice_id dwc3_am62_match[] = { + { .compatible = "ti,am62-usb", .data = (ulong)&ti_am62_ops }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(dwc3_am62_wrapper) = { + .name = "dwc3-am62", + .id = UCLASS_SIMPLE_BUS, + .of_match = dwc3_am62_match, + .bind = dwc3_glue_bind, + .probe = dwc3_glue_probe, + .remove = dwc3_glue_remove, + .plat_auto = sizeof(struct dwc3_glue_data), + +};
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com
nitpick (comment typo) below
Changes in v2:
- bool "TI AM62 USB wrapper"
- depends on SPL_DM_USB && SPL_USB_DWC3_GENERIC
- help
- depends on DM_USB && USB_DWC3_GENERIC
- help
- TI AM62 specific glue layer for DWC3
- 9600,
- 10000,
- 12000,
- 19200,
- 20000,
- 24000,
- 25000,
- 26000,
- 38400,
- 40000,
- 58000,
- 50000,
- 52000,
- struct clk usb2_refclk;
- int rate_code, i, ret;
- unsigned long rate;
- u32 reg;
- void *usbss;
- bool vbus_divider;
- struct regmap *syscon;
- struct ofnode_phandle_args args;
- usbss = dev_remap_addr_index(dev, 0);
- if (IS_ERR(usbss)) {
return;
- ret = clk_get_by_name(dev, "ref", &usb2_refclk);
- if (ret) {
return;
- /* Calcuate the rate code */
s/Calcuate/Calculate
- rate = clk_get_rate(&usb2_refclk);
- rate /= 1000; /* To KHz */
- for (i = 0; i < ARRAY_SIZE(dwc3_ti_am62_rate_table); i++) {
break;
- if (i == ARRAY_SIZE(dwc3_ti_am62_rate_table)) {
return;
- rate_code = i;
- /* Read the syscon property */
- syscon = syscon_regmap_lookup_by_phandle(dev, "ti,syscon-phy-pll-refclk");
- if (IS_ERR(syscon)) {
return;
- ret = ofnode_parse_phandle_with_args(dev_ofnode(dev), "ti,syscon-phy-pll-refclk", NULL, 1,
0, &args);
- if (ret)
return;
- /* Program PHY PLL refclk by reading syscon property */
- ret = regmap_update_bits(syscon, args.args[0], PHY_PLL_REFCLK_MASK, rate_code);
- if (ret) {
return;
- /* VBUS divider select */
- reg = readl(usbss + USBSS_PHY_CONFIG);
- vbus_divider = dev_read_bool(dev, "ti,vbus-divider");
- if (vbus_divider)
- writel(reg, usbss + USBSS_PHY_CONFIG);
- /* Set mode valid */
- reg = readl(usbss + USBSS_MODE_CONTROL);
- reg |= USBSS_MODE_VALID;
- writel(reg, usbss + USBSS_MODE_CONTROL);
- .glue_configure = dwc3_ti_am62_glue_configure,
- { .compatible = "ti,am62-usb", .data = (ulong)&ti_am62_ops },
- { /* sentinel */ }
- .name = "dwc3-am62",
- .id = UCLASS_SIMPLE_BUS,
- .of_match = dwc3_am62_match,
- .bind = dwc3_glue_bind,
- .probe = dwc3_glue_probe,
- .remove = dwc3_glue_remove,
- .plat_auto = sizeof(struct dwc3_glue_data),
2.40.0
Hi Sjoerd,
Changes in v2:
Thanks for helping separate the glue code to avoid dwc-generic complications.
- help
- help
- config USB_DWC3_MESON_G12A bool "Amlogic Meson G12A USB wrapper" depends on DM_USB && USB_DWC3 && ARCH_MESON
Should this function be static?
- 9600,
- 10000,
- 12000,
- 19200,
- 20000,
- 24000,
- 25000,
- 26000,
- 38400,
- 40000,
- 58000,
- 50000,
- 52000,
It's trivial but I think "#define" and the table are better outside of the function.
- u32 reg;
- void *usbss;
return;
- if (ret) {
return;
break;
rate);
return;
- rate_code = i;
regmap\n");
return;
0, &args);
- if (ret)
return;
- if (ret) {
rate\n");
return;
- if (vbus_divider)
The pointless blank line.
Thank you,
--- Best Regards Kunihiko Hayashi
Add configs for enabling USB DFU in U-Boot.
Changes in v2: - Minimize config changes to just DFU configuration
include/configs/am62x_evm.h | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/include/configs/am62x_evm.h b/include/configs/am62x_evm.h index 7bf07809b05..d07da4ebae4 100644 --- a/include/configs/am62x_evm.h +++ b/include/configs/am62x_evm.h @@ -11,6 +11,7 @@
#include <config_distro_bootcmd.h> #include <environment/ti/mmc.h> +#include <environment/ti/k3_dfu.h>
/* DDR Configuration */ #define CFG_SYS_SDRAM_BASE1 0x880000000 @@ -38,9 +39,16 @@ DISTRO_BOOT_DEV_PXE(func) \ DISTRO_BOOT_DEV_DHCP(func)
+#define EXTRA_ENV_DFUARGS \ + DFU_ALT_INFO_MMC \ + DFU_ALT_INFO_EMMC \ + DFU_ALT_INFO_RAM \ + DFU_ALT_INFO_OSPI + /* Incorporate settings into the U-Boot environment */ #define CFG_EXTRA_ENV_SETTINGS \ - BOOTENV + BOOTENV \ + EXTRA_ENV_DFUARGS
/* Now for the remaining common defines */ #include <configs/ti_armv7_common.h>
Enable both usb0 as a peripheral for use with DFU and
Changes in v2: - Only enable usb port 0 DFU in SPL
arch/arm/dts/k3-am625-sk-u-boot.dtsi | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/arch/arm/dts/k3-am625-sk-u-boot.dtsi b/arch/arm/dts/k3-am625-sk-u-boot.dtsi index 5f90a4b56f1..2746451572d 100644 --- a/arch/arm/dts/k3-am625-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am625-sk-u-boot.dtsi @@ -154,3 +154,14 @@ &cpsw_port2 { status = "disabled"; }; + +&usbss0 { + bootph-pre-ram; +}; + +&usb0 { + dr_mode = "peripheral"; + /* Since role switching is not supported in U-Boot */ + /delete-property/ extcon; + bootph-pre-ram; +};
Enable USB host as well as USB gadget and DFU support for a53; For the r5 due to the smaller available size create a new config just for DFU support
Changes in v2: - Create a seperate defconfig for R5
configs/am62x_evm_a53_defconfig | 35 +++++++- configs/am62x_evm_r5_usbdfu_defconfig | 116 ++++++++++++++++++++++++++ 2 files changed, 148 insertions(+), 3 deletions(-) create mode 100644 configs/am62x_evm_r5_usbdfu_defconfig
diff --git a/configs/am62x_evm_a53_defconfig b/configs/am62x_evm_a53_defconfig index cc9c8eab3e3..7dbf2f54050 100644 --- a/configs/am62x_evm_a53_defconfig +++ b/configs/am62x_evm_a53_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y +CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y @@ -9,9 +10,11 @@ CONFIG_K3_ATF_LOAD_ADDR=0x9e780000 CONFIG_TARGET_AM625_A53_EVM=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80480000 +CONFIG_SF_DEFAULT_SPEED=25000000 CONFIG_SPL_DM_SPI=y CONFIG_DEFAULT_DEVICE_TREE="k3-am625-sk" CONFIG_SPL_TEXT_BASE=0x80080000 +CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y @@ -33,17 +36,23 @@ CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 +CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" CONFIG_SPL_DM_MAILBOX=y CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_POWER_DOMAIN=y +CONFIG_SPL_RAM_SUPPORT=y +CONFIG_SPL_RAM_DEVICE=y # CONFIG_SPL_SPI_FLASH_TINY is not set CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x280000 +CONFIG_SPL_USB_GADGET=y +CONFIG_SPL_DFU=y CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_SYS_BOOTM_LEN=0x800000 +CONFIG_CMD_DFU=y CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_MULTI_DTB_FIT=y @@ -54,10 +63,17 @@ CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_CLK_TI_SCI=y +CONFIG_DFU_MMC=y +CONFIG_DFU_RAM=y +CONFIG_DFU_SF=y +CONFIG_SYS_DFU_DATA_BUF_SIZE=0x5000 +CONFIG_SYS_DFU_MAX_FILE_SIZE=0x800000 CONFIG_DMA_CHANNELS=y CONFIG_TI_K3_NAVSS_UDMA=y CONFIG_TI_SCI_PROTOCOL=y @@ -68,7 +84,6 @@ CONFIG_MMC_SDHCI_ADMA=y CONFIG_SPL_MMC_SDHCI_ADMA=y CONFIG_MMC_SDHCI_AM654=y CONFIG_DM_SPI_FLASH=y -CONFIG_SF_DEFAULT_SPEED=25000000 CONFIG_SPI_FLASH_SFDP_SUPPORT=y CONFIG_SPI_FLASH_SOFT_RESET=y CONFIG_SPI_FLASH_SOFT_RESET_ON_BOOT=y @@ -96,5 +111,19 @@ CONFIG_CADENCE_QSPI=y CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y CONFIG_SYSRESET_TI_SCI=y +CONFIG_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_SPL_DM_USB_GADGET=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_SPL_USB_DWC3_GENERIC=y +CONFIG_SPL_USB_DWC3_AM62=y +CONFIG_USB_DWC3_AM62=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0x6165 +CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 -CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/am62x_evm_r5_usbdfu_defconfig b/configs/am62x_evm_r5_usbdfu_defconfig new file mode 100644 index 00000000000..00a0821b6df --- /dev/null +++ b/configs/am62x_evm_r5_usbdfu_defconfig @@ -0,0 +1,116 @@ +CONFIG_ARM=y +CONFIG_ARCH_K3=y +CONFIG_SYS_MALLOC_LEN=0x08000000 +CONFIG_SYS_MALLOC_F_LEN=0x9000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_SOC_K3_AM625=y +CONFIG_TARGET_AM625_R5_EVM=y +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x43c3a7f0 +CONFIG_ENV_SIZE=0x20000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="k3-am625-r5-sk" +CONFIG_SPL_TEXT_BASE=0x43c00000 +CONFIG_DM_RESET=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL_STACK_R_ADDR=0x82000000 +CONFIG_SPL_SYS_MALLOC_F_LEN=0x7000 +CONFIG_SPL_SIZE_LIMIT=0x3A7F0 +CONFIG_SPL_SIZE_LIMIT_PROVIDE_STACK=0x3500 +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 +CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_SIZE_LIMIT_SUBTRACT_GD=y +CONFIG_SPL_SIZE_LIMIT_SUBTRACT_MALLOC=y +CONFIG_SPL_MAX_SIZE=0x3B000 +CONFIG_SPL_PAD_TO=0x0 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x43c3b000 +CONFIG_SPL_BSS_MAX_SIZE=0x3000 +CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SYS_SPL_MALLOC=y +CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y +CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x84000000 +CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 +CONFIG_SPL_EARLY_BSS=y +CONFIG_SPL_ENV_SUPPORT=y +CONFIG_SPL_DM_MAILBOX=y +CONFIG_SPL_DM_RESET=y +CONFIG_SPL_POWER_DOMAIN=y +CONFIG_SPL_RAM_SUPPORT=y +CONFIG_SPL_RAM_DEVICE=y +CONFIG_SPL_REMOTEPROC=y +CONFIG_SPL_USB_GADGET=y +CONFIG_SPL_DFU=y +CONFIG_SPL_YMODEM_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_DFU=y +CONFIG_CMD_REMOTEPROC=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_SPL_MULTI_DTB_FIT=y +CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_SPL_OF_TRANSLATE=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_SPL_CLK_CCF=y +CONFIG_SPL_CLK_K3_PLL=y +CONFIG_SPL_CLK_K3=y +CONFIG_SYS_DFU_DATA_BUF_SIZE=0x5000 +CONFIG_TI_SCI_PROTOCOL=y +CONFIG_DA8XX_GPIO=y +CONFIG_DM_MAILBOX=y +CONFIG_K3_SEC_PROXY=y +CONFIG_MISC=y +CONFIG_ESM_K3=y +CONFIG_PINCTRL=y +# CONFIG_PINCTRL_GENERIC is not set +CONFIG_SPL_PINCTRL=y +# CONFIG_SPL_PINCTRL_GENERIC is not set +CONFIG_PINCTRL_SINGLE=y +CONFIG_POWER_DOMAIN=y +CONFIG_TI_POWER_DOMAIN=y +CONFIG_K3_SYSTEM_CONTROLLER=y +CONFIG_REMOTEPROC_TI_K3_ARM64=y +CONFIG_RESET_TI_SCI=y +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_DM_SERIAL=y +CONFIG_SOC_DEVICE=y +CONFIG_SOC_DEVICE_TI_K3=y +CONFIG_SOC_TI=y +CONFIG_TIMER=y +CONFIG_SPL_TIMER=y +CONFIG_OMAP_TIMER=y +CONFIG_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_SPL_DM_USB_GADGET=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_SPL_USB_DWC3_GENERIC=y +CONFIG_SPL_USB_DWC3_AM62=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0x6165 +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_LIB_RATIONAL=y +CONFIG_SPL_LIB_RATIONAL=y
Hi Sjoerd
Thanks for this series.
With the nitpick about CONFIG_USB_XHCI_DWC3 (needs to be removed) below.
Tested-by: Marcel Ziswiler marcel.ziswiler@toradex.com
I tested both USB device aka gadget (with DFU and UMS) as well as USB host on both the TI AM625 EVM aka SK as well as the Toradex Verdin AM62 [1] (plus USB integration analogous to EVM/SK to be posted later).
[1] https://lore.kernel.org/all/20230607120639.82087-1-marcel@ziswiler.com/
Changes in v2:
I believe the above got superseded by CONFIG_USB_DWC3_AM62 further below, not?
At least in my testing it always crashed as follows unless I removed CONFIG_USB_XHCI_DWC3:
=> usb start starting USB... Bus usb@31000000: generic_phy_get_bulk : no phys property Register 1000840 NbrPorts 1 Starting the controller USB XHCI 1.10 Bus usb@31100000: generic_phy_get_bulk : no phys property Register 1000840 NbrPorts 1 Starting the controller USB XHCI 1.10 Bus usb@31100000: generic_phy_get_bulk : no phys property Register 1000840 NbrPorts 1 Starting the controller USB XHCI 1.10 scanning bus usb@31000000 for devices... 1 USB Device(s) found scanning bus usb@31100000 for devices... XHCI timeout on event type 33... cannot recover. BUG at drivers/usb/host/xhci-ring.c:496/xhci_wait_for_event()! BUG! resetting ... System reset not supported on this platform ### ERROR ### Please RESET the board ###
The same applies here.
Cheers
Marcel
Changes in v2:
I tested USB DFU boot on AM62 and it works fine.
Tested-by: Ravi Gunasekaran r-gunasekaran@ti.com
Hi Sjoerd,
Thank you for this series.
Changes in v2:
I've tested USB support on AM62x SK EVM for this whole series based on a public TI integration branch:
https://git.ti.com/cgit/ti-u-boot/ti-u-boot/log/?h=ti-u-boot-2023.04-next
I did not test DFU, however with some small config changes I could test fastboot support using:
=> fastboot usb 0
Then from host: $ fastboot devices $ fastboot flash <partition_label> <image_file>
Tested-by: Mattijs Korpershoek mkorpershoek@baylibre.com
-- 2.40.0
Changes in v2:
arch/arm/dts/k3-am62-main.dtsi | 259 +++++++++++++++++++++++--- arch/arm/dts/k3-am62-mcu.dtsi | 49 +++++ arch/arm/dts/k3-am62-wakeup.dtsi | 4 +- arch/arm/dts/k3-am625-r5-sk.dts | 2 +- arch/arm/dts/k3-am625-sk-u-boot.dtsi | 27 ++- arch/arm/dts/k3-am625-sk.dts | 95 +++++----- arch/arm/dts/k3-am625.dtsi | 52 ++++++ arch/arm/mach-k3/am62x/dev-data.c | 1 + configs/am62x_evm_a53_defconfig | 35 +++- configs/am62x_evm_r5_usbdfu_defconfig | 116 ++++++++++++ drivers/timer/omap-timer.c | 1 + drivers/usb/dwc3/Kconfig | 14 ++ drivers/usb/dwc3/Makefile | 1 + drivers/usb/dwc3/dwc3-am62.c | 127 +++++++++++++ include/configs/am62x_evm.h | 10 +- 15 files changed, 701 insertions(+), 92 deletions(-) create mode 100644 configs/am62x_evm_r5_usbdfu_defconfig create mode 100644 drivers/usb/dwc3/dwc3-am62.c Tested-by: Ravi Gunasekaran r-gunasekaran@ti.com Tested-by: Mattijs Korpershoek mkorpershoek@baylibre.com
This seems, conceptually, fine. But as we're getting the TI dts files in sync with the kernel, I'm deferring this version and you'll want to rebase and re-post once everything has settled.
Thanks for the update/hint ;) I also got a few review comments so the plan is to include those and repost.. Just my may has been stupidly busy causing me to not get around it in the first place, so maybe that turned into good timing in the end.
Hi Sjoerd
Any progress on this?
I still carry your re-based series on top of latest master [1] and USB DFU is working very well on Verdin AM62.
Thanks!
[1] https://github.com/ziswiler/u-boot/tree/verdin-am62-usb-support
Cheers
Marcel
On Mon, Aug 21, 2023 at 04:13:32PM +0000, Marcel Ziswiler wrote:
Hi Sjoerd
Thanks!
As the am62 files have been re-synced, re-basing this and re-posting for next would be appropriate at this point.
Hi Sjoerd,
Hi Sjoerd
Thanks!
Any updates on this? Do you have plans to rebase and resend this series?
Hi Dhruva,
On mer., mai 29, 2024 at 11:39, Dhruva Gole d-gole@ti.com wrote:
Hi Sjoerd,
Hi Sjoerd
Thanks!
A part of this (USB DFU) has been taken over by Martyn and has been merged:
https://lore.kernel.org/all/171581573300.812585.12291710364879103682.b4-ty@k...
-- Best regards, Dhruva Gole d-gole@ti.com
participants (9)
Dhruva Gole
Kunihiko Hayashi
Marcel Ziswiler
Mattijs Korpershoek
Nishanth Menon
Ravi Gunasekaran
Sjoerd Simons
Sverdlin, Alexander
