[U-Boot] flash the images to NAND automatically with SD Boot in uboot?
Hi Guys,
i need little help, i have to auto update nand every time i put my sd card.
i can get which register[pin mux] decides NAND or SD boot. I'm using 2010 uboot code.
what i'm looking is
1. This should run only when the SD boot is happening 2. I have to create auto upgrade function in uboot source code. 3. In this function, check whether ‘u-boot.min.nand’, ‘u-boot.bin’ files are available in the SD Card[FAT partition][fatls mmc 0] If available: Do the flashing u-boot.min.nand to nand flash. Flash u-boot.bin to NAND. 4. then exit.
uboot source code
http://arago-project.org/git/projects/?p=u-boot-ipnc-rdk-dm81xx.git;a=tree
regards, grbesd1
-- View this message in context: http://u-boot.10912.n7.nabble.com/flash-the-images-to-NAND-automatically-wit... Sent from the U-Boot mailing list archive at Nabble.com.
On 12/01/2016 05:30 PM, grbesd1 wrote:
Hi Guys,
what i'm looking is
- This should run only when the SD boot is happening
- I have to create auto upgrade function in uboot source code.
- In this function, check whether ‘u-boot.min.nand’, ‘u-boot.bin’ files are
Sorry, i don't know exactly what is your question. Your question is those sequences is right or not?
Best Regards, Jaehoon Chung
uboot source code
regards, grbesd1
-- View this message in context: http://u-boot.10912.n7.nabble.com/flash-the-images-to-NAND-automatically-wit... Sent from the U-Boot mailing list archive at Nabble.com. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Actually i need to know how to add the functionality. has anyone done before because i tried to look more information on these i didn't find much help.
I have to add a function in uboot source code, which perform all the listed operation step by step.
regards, grbesd1
Hi Guys,
what i'm looking is
uboot source code
regards, grbesd1
U-Boot@.denx
U-Boot mailing list
U-Boot@.denx
Well, you need to implement this in your local..I think it can use the magic-number as some hex value. When you make the u-boot.bin, add the hex magic number at fixed offest.
Then when read that offest, bootloader can know that it's which image is. It's for only local testing.
And auto flashing function might call when boot from SD.. (I'm not sure but you know how to distinguish with SD and NAND. e.g some register bit or OM Pin)
regards, grbesd1
Hi Guys,
what i'm looking is
uboot source code
regards, grbesd1
U-Boot@.denx
U-Boot mailing list
U-Boot@.denx
grbesd1
Jaehoon Chung
