Help with u-boot when using the eMMC card in DDR mode
I have been trying recently to optimize the boot time on a customized board based on the IMX6DP.
For the time being, I succeeded in enabling the DDR (dual data rate) mode for the emmc to speed up the data rate for read and write cycles in u-boot.
By reading a file from the emmc using the "load" command (e.g. load mmc 2:1 0x12000000 file), I can see that the data rate has doubled, confirming that the DDR mode is enabled.
However, the problem I have is that when I execute the u-boot command "mmc dev 2" to switch the current device to the onboard eMMC, the command fails with the output below : (with DEBUG enabled)
U-Boot >mmc dev 2 blk_find_device: if_type=6, devnum=2: usdhc@02198000.blk, 6, 2 ofnode_read_u32: vmmc-supply: 0x33 (51) ofnode_read_u32: vqmmc-supply: 0x33 (51) clock is disabled (0Hz) fixed_regulator_set_enable: dev='3p3v', enable=1, delay=0, has_gpio=0 clock is enabled (400000Hz) Command failed, result=1 U-Boot >
and after this command, any attempt to interact with the emmc (e.g. fatls mmc 2:1 ) ends with failure.
To enable the DDR mode, all I did was define the macro CONFIG_SYS_FSL_ESDHC_HAS_DDR_MODE in the header of my board.
Any help is greatly appreciated !
Abder,
If you can enable CONFIG_MMC_TRACE, then you can get more information relevant to MMC. Could you also share log after enabled MMC_TRACE?
Best Regards, Jaehoon Chung
Abder,
Hi Jaehoon, This is the output with MMC_TRACE enabled
U-Boot >mmc dev 2 blk_find_device: if_type=6, devnum=2: usdhc@02198000.blk, 6, 2 ofnode_read_u32: vmmc-supply: 0x33 (51) ofnode_read_u32: vqmmc-supply: 0x33 (51) clock is disabled (0Hz) fixed_regulator_set_enable: dev='3p3v', enable=1, delay=0, has_gpio=0 clock is enabled (400000Hz) CMD_SEND:0 ARG 0x00000000 MMC_RSP_NONE CMD_SEND:8 ARG 0x000001aa RET -110 CMD_SEND:55 ARG 0x00000000 RET -110 CMD_SEND:0 ARG 0x00000000 MMC_RSP_NONE CMD_SEND:1 ARG 0x00000000 MMC_RSP_R3,4 0x00ff8080 CMD_SEND:1 ARG 0x40300000 MMC_RSP_R3,4 0x00ff8080 CMD_SEND:0 ARG 0x00000000 MMC_RSP_NONE CMD_SEND:1 ARG 0x40300000 MMC_RSP_R3,4 0x00ff8080 CMD_SEND:1 ARG 0x40300000 MMC_RSP_R3,4 0x00ff8080 CMD_SEND:1 ARG 0x40300000 MMC_RSP_R3,4 0x00ff8080 CMD_SEND:1 ARG 0x40300000 MMC_RSP_R3,4 0xc0ff8080 CMD_SEND:2 ARG 0x00000000 RET -70 CMD_SEND:2 ARG 0x00000000 RET -70 CMD_SEND:2 ARG 0x00000000 RET -70 CMD_SEND:2 ARG 0x00000000 RET -70 CMD_SEND:2 ARG 0x00000000 RET -70 CMD_SEND:2 ARG 0x00000000 RET -70 Command failed, result=1 U-Boot >
I believe the -70 error is an ECOM error (Communication error on send). However this does not occur when eMMC is in HS mode for example. and even in DDR mode, before executing the "mmc dev 2" cmd, the communication with the emmc with "load" works without a hitch.
board
u-boot.
2:1
that
"mmc
fails
Abder,
Sorry. I didn't understand clearly. Does DDR mode work fine before "mmc dev 2" command? Did you try to run other command? e,g) mmcinfo or mmc rescan?
It seems that error is returned in fsl_esdhc_imx.c. Well, it seems that not cleared something after some operation. It needs to check full log and sequence.
board
u-boot.
2:1
that
"mmc
fails
Abder,
Hi Jaehoon, yes, DDR mode works fine before executing "mmc dev 2" command. However, for "mmc rescan" command or "mmc info" to work, I need to first select the correct mmc device using the "mmc dev 2" command, cuz the default one is device 0 in my case which is empty.
OTOH, after hours of debugging I found the origin of the issue. In fact, the "mmc dev 2" command forces a reinitialization of the emmc, and if the emmc was already initialized in DDR mode at boot up, the implemented re-init flow leads to bad clock settings. (basicly the host tries to set the clock of the emmc to 400KHz (identification mode), but as the DDR mode is still enabled, the configured clock corresponds to the half of that = 200KHz). The mismatch in frequency is what caused the -70 ECOM error. and as the command fails, the emmc stays at 200KHz, which leads any attempt to interact with the emmc afterwards to failure.
I found out that this bug was patched recently in 390f9bddb9c84f75649024b41b8cf2a766379ce0 in the main u-boot.
Anyhow.. Thanks for your replies.
Best regards, Abder
board
mode
u-boot.
2:1
that
"mmc
fails
fatls
Abder,
The previously mentioned commit didn't resolve the issue. When testing I made a mistake.
The workaround I'm using to resolve the issue is by disabling the DDR mode juste before re-init happens (DDR mode will be automatically enabled later in the init process).
Now I don't know if this is really a bug in the mmc driver, or I'm just missing some additional configuration to work with the eMMC in DDR mode !
Best regards, Abder
board
mode
u-boot.
mmc
2:1
that
"mmc
fails
fatls
Abder,
Hi
It seems that it has a bug in fsl_esdhc_imx.c. I don't have any boards to use its driver. But when i have checked a code, there is a bit relevant to DDR enable bit in esdhc_set_timing(). If it doesn't clear its bit when it's re-initializing, it's possible to fail.
Best regards, Abder
board
mode
u-boot.
mmc
2:1
that
"mmc
fails
fatls
Abder,
Abder
Jaehoon Chung
