Re: [U-Boot] [PATCH] power: rk8xx: fix auto-allocation of priv
The recent changes to the RK808 driver caused our BSP to sync-abort in the regulator framework, when setting (or rather 'auto-setting') some of the LDOs.
Turns out that the auto-allocation of the priv-structure in the rk8xx driver was never properly wired up... this commit fixes this issue by setting the .priv_auto_alloc_size-field in the driver structure.
X-AffectedPlatforms: RK3399-Q7 Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Also fixes the Firefly-RK3399.
Reviewed-by: Mark Kettenis kettenis@openbsd.org Tested-by: Mark Kettenis kettenis@openbsd.org
drivers/power/pmic/rk8xx.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/power/pmic/rk8xx.c b/drivers/power/pmic/rk8xx.c index 394e2ff..ff3bff0 100644 --- a/drivers/power/pmic/rk8xx.c +++ b/drivers/power/pmic/rk8xx.c @@ -115,4 +115,5 @@ U_BOOT_DRIVER(pmic_rk8xx) = { #endif .probe = rk8xx_probe, .ops = &rk8xx_ops,
- .priv_auto_alloc_size = sizeof(struct rk8xx_priv),
1.9.1
Mark Kettenis
