[U-Boot] [PATCH v3] autoboot: add CONFIG_AUTOBOOT to allow to not compile autoboot.c
Since commit bb597c0eeb7e ("common: bootdelay: move CONFIG_BOOTDELAY into a Kconfig option"), CONFIG_BOOTDELAY is defined for all boards.
Prior to that commit, it was allowed to unset CONFIG_BOOTDELAY to not compile common/autoboot.c, as described in common/Makefile:
# This option is not just y/n - it can have a numeric value ifdef CONFIG_BOOTDELAY obj-y += autoboot.o endif
It was a bit odd to enable/disable code with an integer type option, but it was how this option worked before that commit, and several boards actually unset it to opt out of the autoboot feature.
This commit adds a new bool option, CONFIG_AUTOBOOT, and makes CONFIG_BOOTDELAY depend on it.
I chose "default y" for this option because most boards use the autoboot. I added "# CONFIG_AUTOBOOT is not set" for the boards that had not set CONFIG_BOOTDELAY prior to the bad commit.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com --- Hi Tom,
The problem of BOOTDELAY migration has not been fixed completely.
This is the last portion of the migration fixes.
Changes in v3: - Rebase onto 7c8ef0feb97586d35b0296b48903daef8c06ab21
cmd/Kconfig | 6 ++++++ common/Kconfig | 1 + common/Makefile | 5 +---- configs/10m50_defconfig | 1 + configs/3c120_defconfig | 1 + configs/M5249EVB_defconfig | 1 + configs/am335x_sl50_defconfig | 1 + configs/bcm11130_defconfig | 1 + configs/bcm11130_nand_defconfig | 1 + configs/bcm28155_ap_defconfig | 1 + configs/bcm28155_w1d_defconfig | 1 + configs/bcm911360_entphn-ns_defconfig | 1 + configs/bcm911360_entphn_defconfig | 1 + configs/bcm911360k_defconfig | 1 + configs/bcm958300k-ns_defconfig | 1 + configs/bcm958300k_defconfig | 1 + configs/bcm958305k_defconfig | 1 + configs/bcm958622hr_defconfig | 1 + configs/bf506f-ezkit_defconfig | 1 + configs/dnp5370_defconfig | 1 + configs/espresso7420_defconfig | 1 + configs/malta64_defconfig | 1 + configs/malta64el_defconfig | 1 + configs/malta_defconfig | 1 + configs/maltael_defconfig | 1 + configs/mpr2_defconfig | 1 + configs/ms7720se_defconfig | 1 + configs/openrisc-generic_defconfig | 1 + configs/rsk7203_defconfig | 1 + configs/s5p_goni_defconfig | 1 + configs/shmin_defconfig | 1 + include/autoboot.h | 2 +- 32 files changed, 37 insertions(+), 5 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index d51645c..42e0e39 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -38,6 +38,12 @@ config SYS_PROMPT
menu "Autoboot options"
+config AUTOBOOT + bool "Autoboot" + default y + help + This enables the autoboot. See doc/README.autoboot for detail. + config AUTOBOOT_KEYED bool "Stop autobooting via specific input key / string" default n diff --git a/common/Kconfig b/common/Kconfig index e691145..ada4ddb 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -100,6 +100,7 @@ endmenu config BOOTDELAY int "delay in seconds before automatically booting" default 2 + depends on AUTOBOOT help Delay before automatically running bootcmd; set to -1 to disable autoboot. diff --git a/common/Makefile b/common/Makefile index 97c59fe..34cb898 100644 --- a/common/Makefile +++ b/common/Makefile @@ -15,10 +15,7 @@ ifdef CONFIG_SYS_HUSH_PARSER obj-y += cli_hush.o endif
-# This option is not just y/n - it can have a numeric value -ifdef CONFIG_BOOTDELAY -obj-y += autoboot.o -endif +obj-$(CONFIG_AUTOBOOT) += autoboot.o
# This option is not just y/n - it can have a numeric value ifdef CONFIG_BOOT_RETRY_TIME diff --git a/configs/10m50_defconfig b/configs/10m50_defconfig index 4f85c22..15952af 100644 --- a/configs/10m50_defconfig +++ b/configs/10m50_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="10m50_devboard" CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +# CONFIG_AUTOBOOT is not set CONFIG_CMD_CPU=y # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/3c120_defconfig b/configs/3c120_defconfig index c145caf..b19c956 100644 --- a/configs/3c120_defconfig +++ b/configs/3c120_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="3c120_devboard" CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +# CONFIG_AUTOBOOT is not set CONFIG_CMD_CPU=y # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/M5249EVB_defconfig b/configs/M5249EVB_defconfig index f06379f..1588c52 100644 --- a/configs/M5249EVB_defconfig +++ b/configs/M5249EVB_defconfig @@ -1,6 +1,7 @@ CONFIG_M68K=y CONFIG_TARGET_M5249EVB=y CONFIG_SYS_TEXT_BASE=0xffe00000 +# CONFIG_AUTOBOOT is not set CONFIG_LOOPW=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set diff --git a/configs/am335x_sl50_defconfig b/configs/am335x_sl50_defconfig index c227ef4..01c1eeb 100644 --- a/configs/am335x_sl50_defconfig +++ b/configs/am335x_sl50_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT" CONFIG_HUSH_PARSER=y +# CONFIG_AUTOBOOT is not set CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y diff --git a/configs/bcm11130_defconfig b/configs/bcm11130_defconfig index 2716868..d2a3b73 100644 --- a/configs/bcm11130_defconfig +++ b/configs/bcm11130_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCM28155_AP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_MMC_ENV_DEV=0" CONFIG_HUSH_PARSER=y +# CONFIG_AUTOBOOT is not set CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y diff --git a/configs/bcm11130_nand_defconfig b/configs/bcm11130_nand_defconfig index 8e01c52..5fc501f 100644 --- a/configs/bcm11130_nand_defconfig +++ b/configs/bcm11130_nand_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCM28155_AP=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_HUSH_PARSER=y +# CONFIG_AUTOBOOT is not set CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y diff --git a/configs/bcm28155_ap_defconfig b/configs/bcm28155_ap_defconfig index 4c0f3b3..70eb44a 100644 --- a/configs/bcm28155_ap_defconfig +++ b/configs/bcm28155_ap_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y CONFIG_TARGET_BCM28155_AP=y CONFIG_HUSH_PARSER=y +# CONFIG_AUTOBOOT is not set CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y diff --git a/configs/bcm28155_w1d_defconfig b/configs/bcm28155_w1d_defconfig index e9d13b9..b849074 100644 --- a/configs/bcm28155_w1d_defconfig +++ b/configs/bcm28155_w1d_defconfig @@ -3,6 +3,7 @@ CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y CONFIG_TARGET_BCM28155_AP=y CONFIG_SYS_EXTRA_OPTIONS="BCM_SF2_ETH,BCM_SF2_ETH_GMAC" CONFIG_HUSH_PARSER=y +# CONFIG_AUTOBOOT is not set CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y diff --git a/configs/bcm911360_entphn-ns_defconfig b/configs/bcm911360_entphn-ns_defconfig index d8a30d1..a9403a8 100644 --- a/configs/bcm911360_entphn-ns_defconfig +++ b/configs/bcm911360_entphn-ns_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x20000000,ARMV7_NONSEC" CONFIG_HUSH_PARSER=y +# CONFIG_AUTOBOOT is not set CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y diff --git a/configs/bcm911360_entphn_defconfig b/configs/bcm911360_entphn_defconfig index 205db1e..aee2e2e 100644 --- a/configs/bcm911360_entphn_defconfig +++ b/configs/bcm911360_entphn_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x20000000" CONFIG_HUSH_PARSER=y +# CONFIG_AUTOBOOT is not set CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y diff --git a/configs/bcm911360k_defconfig b/configs/bcm911360k_defconfig index bcb24b4..df76dac 100644 --- a/configs/bcm911360k_defconfig +++ b/configs/bcm911360k_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000" CONFIG_HUSH_PARSER=y +# CONFIG_AUTOBOOT is not set CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y diff --git a/configs/bcm958300k-ns_defconfig b/configs/bcm958300k-ns_defconfig index 527f4a5..0b00ce3 100644 --- a/configs/bcm958300k-ns_defconfig +++ b/configs/bcm958300k-ns_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000,ARMV7_NONSEC" CONFIG_HUSH_PARSER=y +# CONFIG_AUTOBOOT is not set CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y diff --git a/configs/bcm958300k_defconfig b/configs/bcm958300k_defconfig index bcb24b4..df76dac 100644 --- a/configs/bcm958300k_defconfig +++ b/configs/bcm958300k_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000" CONFIG_HUSH_PARSER=y +# CONFIG_AUTOBOOT is not set CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y diff --git a/configs/bcm958305k_defconfig b/configs/bcm958305k_defconfig index bcb24b4..df76dac 100644 --- a/configs/bcm958305k_defconfig +++ b/configs/bcm958305k_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000" CONFIG_HUSH_PARSER=y +# CONFIG_AUTOBOOT is not set CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y diff --git a/configs/bcm958622hr_defconfig b/configs/bcm958622hr_defconfig index 6d06b4e..99e5452 100644 --- a/configs/bcm958622hr_defconfig +++ b/configs/bcm958622hr_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMNSP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x01000000" CONFIG_HUSH_PARSER=y +# CONFIG_AUTOBOOT is not set CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y diff --git a/configs/bf506f-ezkit_defconfig b/configs/bf506f-ezkit_defconfig index 0decb53..c36fc5f 100644 --- a/configs/bf506f-ezkit_defconfig +++ b/configs/bf506f-ezkit_defconfig @@ -1,5 +1,6 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF506F_EZKIT=y +# CONFIG_AUTOBOOT is not set # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set diff --git a/configs/dnp5370_defconfig b/configs/dnp5370_defconfig index b6d3b74..782cc88 100644 --- a/configs/dnp5370_defconfig +++ b/configs/dnp5370_defconfig @@ -1,5 +1,6 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_DNP5370=y +# CONFIG_AUTOBOOT is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y diff --git a/configs/espresso7420_defconfig b/configs/espresso7420_defconfig index 8d0bace..c50da0c 100644 --- a/configs/espresso7420_defconfig +++ b/configs/espresso7420_defconfig @@ -4,5 +4,6 @@ CONFIG_ARCH_EXYNOS7=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_DEFAULT_DEVICE_TREE="exynos7420-espresso7420" CONFIG_SYS_PROMPT="ESPRESSO7420 # " +# CONFIG_AUTOBOOT is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/malta64_defconfig b/configs/malta64_defconfig index 590f9b5..fcce6c7 100644 --- a/configs/malta64_defconfig +++ b/configs/malta64_defconfig @@ -4,6 +4,7 @@ CONFIG_CPU_MIPS64_R2=y CONFIG_DEFAULT_DEVICE_TREE="mti,malta" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="malta # " +# CONFIG_AUTOBOOT is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/malta64el_defconfig b/configs/malta64el_defconfig index ff93931..002633b 100644 --- a/configs/malta64el_defconfig +++ b/configs/malta64el_defconfig @@ -5,6 +5,7 @@ CONFIG_CPU_MIPS64_R2=y CONFIG_DEFAULT_DEVICE_TREE="mti,malta" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="maltael # " +# CONFIG_AUTOBOOT is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/malta_defconfig b/configs/malta_defconfig index 3a87586..e74f23d 100644 --- a/configs/malta_defconfig +++ b/configs/malta_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_MALTA=y CONFIG_DEFAULT_DEVICE_TREE="mti,malta" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="malta # " +# CONFIG_AUTOBOOT is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/maltael_defconfig b/configs/maltael_defconfig index 11ff259..3c4c1fe 100644 --- a/configs/maltael_defconfig +++ b/configs/maltael_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_LITTLE_ENDIAN=y CONFIG_DEFAULT_DEVICE_TREE="mti,malta" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="maltael # " +# CONFIG_AUTOBOOT is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/mpr2_defconfig b/configs/mpr2_defconfig index a8dbfc5..606b942 100644 --- a/configs/mpr2_defconfig +++ b/configs/mpr2_defconfig @@ -1,5 +1,6 @@ CONFIG_SH=y CONFIG_TARGET_MPR2=y +# CONFIG_AUTOBOOT is not set # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set diff --git a/configs/ms7720se_defconfig b/configs/ms7720se_defconfig index 2ef3105..537ea7c 100644 --- a/configs/ms7720se_defconfig +++ b/configs/ms7720se_defconfig @@ -1,5 +1,6 @@ CONFIG_SH=y CONFIG_TARGET_MS7720SE=y +# CONFIG_AUTOBOOT is not set # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set diff --git a/configs/openrisc-generic_defconfig b/configs/openrisc-generic_defconfig index a476ba7..14923c0 100644 --- a/configs/openrisc-generic_defconfig +++ b/configs/openrisc-generic_defconfig @@ -7,3 +7,4 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y +# CONFIG_AUTOBOOT is not set diff --git a/configs/rsk7203_defconfig b/configs/rsk7203_defconfig index b63ad4e..f2e9deb 100644 --- a/configs/rsk7203_defconfig +++ b/configs/rsk7203_defconfig @@ -1,5 +1,6 @@ CONFIG_SH=y CONFIG_TARGET_RSK7203=y +# CONFIG_AUTOBOOT is not set # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set diff --git a/configs/s5p_goni_defconfig b/configs/s5p_goni_defconfig index c35287d..b381e21 100644 --- a/configs/s5p_goni_defconfig +++ b/configs/s5p_goni_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_S5P_GONI=y CONFIG_DEFAULT_DEVICE_TREE="s5pc1xx-goni" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Goni # " +# CONFIG_AUTOBOOT is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/shmin_defconfig b/configs/shmin_defconfig index 1749f13..65b4525 100644 --- a/configs/shmin_defconfig +++ b/configs/shmin_defconfig @@ -1,5 +1,6 @@ CONFIG_SH=y CONFIG_TARGET_SHMIN=y +# CONFIG_AUTOBOOT is not set # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set diff --git a/include/autoboot.h b/include/autoboot.h index 3a9059a..c175f91c 100644 --- a/include/autoboot.h +++ b/include/autoboot.h @@ -12,7 +12,7 @@ #ifndef __AUTOBOOT_H #define __AUTOBOOT_H
-#ifdef CONFIG_BOOTDELAY +#ifdef CONFIG_AUTOBOOT /** * bootdelay_process() - process the bootd delay *
Masahiro Yamada
