[PATCH v2 00/12] sunxi: Migrate to DM_I2C
This series does the initial work to migrate sunxi boards to DM_I2C. Version 1 of this series bitrotted quite a bit, so there is some reorganization in version 2.
First it takes care of the PMIC: - Patches 1-2 clean up the PMIC Kconfig, though they are not strictly necessary after 7abf178b, and are independent from the other patches. - Patch 3 then adds a DM_PMIC driver. - Patches 4-6 prepare to move the P2WI/RSB bus drivers to drivers/i2c. - Patches 7-8 move and add DM_I2C versions of those two drivers. - Patches 9-10 migrate the "pmic_bus" functions to use the DM_I2C bus and DM_PMIC driver when possible. Then it takes care of the LCD panels: - Patch 11 converts those drivers to use DM_I2C. Finally, patch 12 switches all sunxi boards over to DM_I2C.
I have build-tested each commit on all sunxi boards.
There is some remaining work to clean up uses of pmic_bus in U-Boot proper and replace them with DM_PMIC functions: - drivers/gpio/axp_gpio.c - I have a series for this. - do_poweroff() in drivers/gpio/axp???.c - I have a series for this. - axp_get_sid() in drivers/power/axp221.c - Not sure what to do here. - axp_set_eldo() in drivers/video/sunxi/sunxi_display.c - This will need a DM_REGULATOR driver.
Changes in v2: - Rebase to pick up 7abf178b ("power: Tidy up #undef of CONFIG_DM_PMIC") - Rebase to pick up 7abf178b ("power: Tidy up #undef of CONFIG_DM_PMIC") - Replace axp_pmic_bind() with `.bind = dm_scan_fdt_dev` - New patch to account for I2C Kconfig changes - Renamed Kconfig symbol to SYS_I2C_SUN6I_P2WI - Moved entire P2WI driver source to drivers/i2c - Renamed Kconfig symbol to SYS_I2C_SUN8I_RSB - Moved entire RSB driver source to drivers/i2c - Update IS_ENABLEDs in pmic_bus.c to match chages to previous patches
Samuel Holland (12): power: pmic: Consistently depend on DM_PMIC power: pmic: Consistently depend on SPL_DM_PMIC power: pmic: Add a driver for X-Powers AXP PMICs sunxi: Only initialize legacy I2C when enabled sunxi: Select SUN8I_RSB more carefully sunxi: pmic_bus: Fix Kconfig dependencies i2c: Add a DM_I2C driver for the sun6i P2WI controller i2c: Add a DM_I2C driver for the sun8i RSB controller sunxi: pmic_bus: Clean up preprocessor conditions sunxi: pmic_bus: Use the DM PMIC interface when possible sunxi: video: Convert panel I2C to use DM_I2C sunxi: Enable DM_I2C for all sunxi boards
arch/arm/Kconfig | 1 + arch/arm/mach-sunxi/Kconfig | 59 ++---- arch/arm/mach-sunxi/Makefile | 2 - arch/arm/mach-sunxi/board.c | 2 +- arch/arm/mach-sunxi/p2wi.c | 117 ------------ arch/arm/mach-sunxi/pmic_bus.c | 109 +++++------ arch/arm/mach-sunxi/rsb.c | 175 ----------------- board/sunxi/board.c | 44 +---- configs/Colombus_defconfig | 6 - configs/UTOO_P66_defconfig | 3 - drivers/i2c/Kconfig | 16 ++ drivers/i2c/Makefile | 2 + drivers/i2c/sun6i_p2wi.c | 220 ++++++++++++++++++++++ drivers/i2c/sun8i_rsb.c | 281 ++++++++++++++++++++++++++++ drivers/power/pmic/Kconfig | 69 ++++--- drivers/power/pmic/Makefile | 1 + drivers/power/pmic/axp.c | 38 ++++ drivers/video/anx9804.c | 103 +++++----- drivers/video/anx9804.h | 5 +- drivers/video/sunxi/sunxi_display.c | 55 ++++-- include/axp_pmic.h | 12 ++ include/configs/sunxi-common.h | 17 -- 22 files changed, 773 insertions(+), 564 deletions(-) delete mode 100644 arch/arm/mach-sunxi/p2wi.c delete mode 100644 arch/arm/mach-sunxi/rsb.c create mode 100644 drivers/i2c/sun6i_p2wi.c create mode 100644 drivers/i2c/sun8i_rsb.c create mode 100644 drivers/power/pmic/axp.c
Kconfig symbols for two PMIC drivers (PMIC_AS3722 and DM_PMIC_MC34708) were missing a dependency on DM_PMIC. To fix this inconsistency, and to keep it from happening again, wrap the driver section with "if DM_PMIC" instead of using a "depends on DM_PMIC" clause for each driver.
Reviewed-by: Igor Opaniuk igor.opaniuk@foundries.io Reviewed-by: Jaehoon Chung jh80.chung@samsung.com Signed-off-by: Samuel Holland samuel@sholland.org ---
drivers/power/pmic/Kconfig | 46 ++++++++------------------------------ 1 file changed, 9 insertions(+), 37 deletions(-)
diff --git a/drivers/power/pmic/Kconfig b/drivers/power/pmic/Kconfig index cf2a9b2c17e..2472555a3ff 100644 --- a/drivers/power/pmic/Kconfig +++ b/drivers/power/pmic/Kconfig @@ -10,10 +10,12 @@ config DM_PMIC - 'drivers/power/pmic/pmic-uclass.c' - 'include/power/pmic.h'
+if DM_PMIC + config SPL_DM_PMIC bool "Enable Driver Model for PMIC drivers (UCLASS_PMIC) in SPL" depends on SPL_DM - default y if DM_PMIC + default y ---help--- This config enables the driver-model PMIC support in SPL. UCLASS_PMIC - designed to provide an I/O interface for PMIC devices. @@ -25,7 +27,6 @@ config SPL_DM_PMIC
config PMIC_CHILDREN bool "Allow child devices for PMICs" - depends on DM_PMIC default y ---help--- This allows PMICs to support child devices (such as regulators) in @@ -35,7 +36,6 @@ config PMIC_CHILDREN
config SPL_PMIC_CHILDREN bool "Allow child devices for PMICs in SPL" - depends on DM_PMIC default y ---help--- This allows PMICs to support child devices (such as regulators) in @@ -46,7 +46,6 @@ config SPL_PMIC_CHILDREN
config PMIC_AB8500 bool "Enable driver for ST-Ericsson AB8500 PMIC via PRCMU" - depends on DM_PMIC select REGMAP select SYSCON help @@ -56,7 +55,7 @@ config PMIC_AB8500
config PMIC_ACT8846 bool "Enable support for the active-semi 8846 PMIC" - depends on DM_PMIC && DM_I2C + depends on DM_I2C ---help--- This PMIC includes 4 DC/DC step-down buck regulators and 8 low-dropout regulators (LDOs). It also provides some GPIO, reset and battery @@ -65,14 +64,13 @@ config PMIC_ACT8846
config DM_PMIC_DA9063 bool "Enable Driver Model for the Dialog DA9063 PMIC" - depends on DM_PMIC help This config enables implementation of driver-model pmic uclass features for PMIC DA9063. The driver implements read/write operations.
config SPL_DM_PMIC_DA9063 bool "Enable Driver Model for the Dialog DA9063 PMIC in SPL" - depends on DM_PMIC && SPL + depends on SPL help This config enables implementation of driver-model pmic uclass features for PMIC DA9063. The driver implements read/write operations. @@ -87,14 +85,12 @@ config PMIC_AS3722
config DM_PMIC_BD71837 bool "Enable Driver Model for PMIC BD71837" - depends on DM_PMIC help This config enables implementation of driver-model pmic uclass features for PMIC BD71837. The driver implements read/write operations.
config SPL_DM_PMIC_BD71837 bool "Enable Driver Model for PMIC BD71837 in SPL stage" - depends on DM_PMIC help This config enables implementation of driver-model pmic uclass features for PMIC BD71837. The driver implements read/write @@ -102,7 +98,7 @@ config SPL_DM_PMIC_BD71837
config DM_PMIC_FAN53555 bool "Enable support for OnSemi FAN53555" - depends on DM_PMIC && DM_REGULATOR && DM_I2C + depends on DM_REGULATOR && DM_I2C select DM_REGULATOR_FAN53555 help This config enables implementation of driver-model PMIC @@ -116,14 +112,12 @@ config DM_PMIC_FAN53555
config DM_PMIC_MP5416 bool "Enable Driver Model for PMIC MP5416" - depends on DM_PMIC help This config enables implementation of driver-model pmic uclass features for PMIC MP5416. The driver implements read/write operations.
config SPL_DM_PMIC_MP5416 bool "Enable Driver Model for PMIC MP5416 in SPL stage" - depends on DM_PMIC help This config enables implementation of driver-model pmic uclass features for PMIC MP5416. The driver implements read/write @@ -131,56 +125,48 @@ config SPL_DM_PMIC_MP5416
config DM_PMIC_PCA9450 bool "Enable Driver Model for PMIC PCA9450" - depends on DM_PMIC help This config enables implementation of driver-model pmic uclass features for PMIC PCA9450. The driver implements read/write operations.
config SPL_DM_PMIC_PCA9450 bool "Enable Driver Model for PMIC PCA9450" - depends on DM_PMIC help This config enables implementation of driver-model pmic uclass features for PMIC PCA9450 in SPL. The driver implements read/write operations.
config DM_PMIC_PFUZE100 bool "Enable Driver Model for PMIC PFUZE100" - depends on DM_PMIC ---help--- This config enables implementation of driver-model pmic uclass features for PMIC PFUZE100. The driver implements read/write operations.
config SPL_DM_PMIC_PFUZE100 bool "Enable Driver Model for PMIC PFUZE100 in SPL" - depends on DM_PMIC ---help--- This config enables implementation of driver-model pmic uclass features for PMIC PFUZE100 in SPL. The driver implements read/write operations.
config DM_PMIC_MAX77686 bool "Enable Driver Model for PMIC MAX77686" - depends on DM_PMIC ---help--- This config enables implementation of driver-model pmic uclass features for PMIC MAX77686. The driver implements read/write operations.
config DM_PMIC_MAX8998 bool "Enable Driver Model for PMIC MAX8998" - depends on DM_PMIC ---help--- This config enables implementation of driver-model pmic uclass features for PMIC MAX8998. The driver implements read/write operations.
config DM_PMIC_MC34708 bool "Enable Driver Model for PMIC MC34708" - depends on DM_PMIC help This config enables implementation of driver-model pmic uclass features for PMIC MC34708. The driver implements read/write operations.
config PMIC_MAX8997 bool "Enable Driver Model for PMIC MAX8997" - depends on DM_PMIC ---help--- This config enables implementation of driver-model pmic uclass features for PMIC MAX8997. The driver implements read/write operations. @@ -195,7 +181,6 @@ config PMIC_MAX8997
config PMIC_PM8916 bool "Enable Driver Model for Qualcomm PM8916 PMIC" - depends on DM_PMIC ---help--- The PM8916 is a PMIC connected to one (or several) processors with SPMI bus. It has 2 slaves with several peripherals: @@ -211,7 +196,6 @@ config PMIC_PM8916
config PMIC_RK8XX bool "Enable support for Rockchip PMIC RK8XX" - depends on DM_PMIC ---help--- The Rockchip RK808 PMIC provides four buck DC-DC convertors, 8 LDOs, an RTC and two low Rds (resistance (drain to source)) switches. It is @@ -220,7 +204,6 @@ config PMIC_RK8XX
config SPL_PMIC_RK8XX bool "Enable support for Rockchip PMIC RK8XX" - depends on DM_PMIC ---help--- The Rockchip RK808 PMIC provides four buck DC-DC convertors, 8 LDOs, an RTC and two low Rds (resistance (drain to source)) switches. It is @@ -229,7 +212,6 @@ config SPL_PMIC_RK8XX
config PMIC_S2MPS11 bool "Enable Driver Model for PMIC Samsung S2MPS11" - depends on DM_PMIC ---help--- The Samsung S2MPS11 PMIC provides: - 38 adjustable LDO regulators @@ -243,7 +225,6 @@ config PMIC_S2MPS11
config DM_PMIC_SANDBOX bool "Enable Driver Model for emulated Sandbox PMIC" - depends on DM_PMIC ---help--- Enable the driver for Sandbox PMIC emulation. The emulated PMIC device depends on two drivers: @@ -268,7 +249,6 @@ config DM_PMIC_SANDBOX
config PMIC_S5M8767 bool "Enable Driver Model for the Samsung S5M8767 PMIC" - depends on DM_PMIC ---help--- The S5M8767 PMIC provides a large array of LDOs and BUCKs for use as a SoC power controller. It also provides 32KHz clock outputs. This @@ -277,7 +257,6 @@ config PMIC_S5M8767
config PMIC_RN5T567 bool "Enable driver for Ricoh RN5T567 PMIC" - depends on DM_PMIC ---help--- The RN5T567 is a PMIC with 4 step-down DC/DC converters, 5 LDO regulators Real-Time Clock and 4 GPIOs. This driver provides @@ -285,7 +264,6 @@ config PMIC_RN5T567
config PMIC_TPS65090 bool "Enable driver for Texas Instruments TPS65090 PMIC" - depends on DM_PMIC ---help--- The TPS65090 is a PMIC containing several LDOs, DC to DC convertors, FETs and a battery charger. This driver provides register access @@ -294,21 +272,18 @@ config PMIC_TPS65090
config PMIC_PALMAS bool "Enable driver for Texas Instruments PALMAS PMIC" - depends on DM_PMIC ---help--- The PALMAS is a PMIC containing several LDOs, SMPS. This driver binds the pmic children.
config PMIC_LP873X bool "Enable driver for Texas Instruments LP873X PMIC" - depends on DM_PMIC ---help--- The LP873X is a PMIC containing couple of LDOs and couple of SMPS. This driver binds the pmic children.
config PMIC_LP87565 bool "Enable driver for Texas Instruments LP87565 PMIC" - depends on DM_PMIC ---help--- The LP87565 is a PMIC containing a bunch of SMPS. This driver binds the pmic children. @@ -322,7 +297,6 @@ config POWER_MC34VR500
config DM_PMIC_TPS65910 bool "Enable driver for Texas Instruments TPS65910 PMIC" - depends on DM_PMIC ---help--- The TPS65910 is a PMIC containing 3 buck DC-DC converters, one boost DC-DC converter, 8 LDOs and a RTC. This driver binds the SMPS and LDO @@ -330,7 +304,7 @@ config DM_PMIC_TPS65910
config PMIC_STPMIC1 bool "Enable support for STMicroelectronics STPMIC1 PMIC" - depends on DM_PMIC && DM_I2C + depends on DM_I2C select SYSRESET_CMD_POWEROFF if CMD_POWEROFF && !ARM_PSCI_FW ---help--- The STPMIC1 PMIC provides 4 BUCKs, 6 LDOs, 1 VREF and 2 power switches. @@ -339,28 +313,26 @@ config PMIC_STPMIC1
config SPL_PMIC_PALMAS bool "Enable driver for Texas Instruments PALMAS PMIC" - depends on DM_PMIC help The PALMAS is a PMIC containing several LDOs, SMPS. This driver binds the pmic children in SPL.
config SPL_PMIC_LP873X bool "Enable driver for Texas Instruments LP873X PMIC" - depends on DM_PMIC help The LP873X is a PMIC containing couple of LDOs and couple of SMPS. This driver binds the pmic children in SPL.
config SPL_PMIC_LP87565 bool "Enable driver for Texas Instruments LP87565 PMIC" - depends on DM_PMIC help The LP87565 is a PMIC containing a bunch of SMPS. This driver binds the pmic children in SPL.
config PMIC_TPS65941 bool "Enable driver for Texas Instruments TPS65941 PMIC" - depends on DM_PMIC help The TPS65941 is a PMIC containing a bunch of SMPS & LDOs. This driver binds the pmic children. + +endif
Now that there is a separate symbol to enable DM_PMIC in SPL, update the the SPL-specific driver symbols to depend on this new option.
drivers/power/pmic/Kconfig | 11 ++++++++++- 1 file changed, 10 insertions(+), 1 deletion(-)
diff --git a/drivers/power/pmic/Kconfig b/drivers/power/pmic/Kconfig index 2472555a3ff..e8a04325f85 100644 --- a/drivers/power/pmic/Kconfig +++ b/drivers/power/pmic/Kconfig @@ -36,6 +36,7 @@ config PMIC_CHILDREN
config SPL_PMIC_CHILDREN bool "Allow child devices for PMICs in SPL" + depends on SPL_DM_PMIC default y ---help--- This allows PMICs to support child devices (such as regulators) in @@ -70,7 +71,7 @@ config DM_PMIC_DA9063
config SPL_DM_PMIC_DA9063 bool "Enable Driver Model for the Dialog DA9063 PMIC in SPL" - depends on SPL + depends on SPL_DM_PMIC help This config enables implementation of driver-model pmic uclass features for PMIC DA9063. The driver implements read/write operations. @@ -91,6 +92,7 @@ config DM_PMIC_BD71837
config SPL_DM_PMIC_BD71837 bool "Enable Driver Model for PMIC BD71837 in SPL stage" + depends on SPL_DM_PMIC help This config enables implementation of driver-model pmic uclass features for PMIC BD71837. The driver implements read/write @@ -118,6 +120,7 @@ config DM_PMIC_MP5416
config SPL_DM_PMIC_MP5416 bool "Enable Driver Model for PMIC MP5416 in SPL stage" + depends on SPL_DM_PMIC help This config enables implementation of driver-model pmic uclass features for PMIC MP5416. The driver implements read/write @@ -131,6 +134,7 @@ config DM_PMIC_PCA9450
config SPL_DM_PMIC_PCA9450 bool "Enable Driver Model for PMIC PCA9450" + depends on SPL_DM_PMIC help This config enables implementation of driver-model pmic uclass features for PMIC PCA9450 in SPL. The driver implements read/write operations. @@ -143,6 +147,7 @@ config DM_PMIC_PFUZE100
config SPL_DM_PMIC_PFUZE100 bool "Enable Driver Model for PMIC PFUZE100 in SPL" + depends on SPL_DM_PMIC ---help--- This config enables implementation of driver-model pmic uclass features for PMIC PFUZE100 in SPL. The driver implements read/write operations. @@ -204,6 +209,7 @@ config PMIC_RK8XX
config SPL_PMIC_RK8XX bool "Enable support for Rockchip PMIC RK8XX" + depends on SPL_DM_PMIC ---help--- The Rockchip RK808 PMIC provides four buck DC-DC convertors, 8 LDOs, an RTC and two low Rds (resistance (drain to source)) switches. It is @@ -313,18 +319,21 @@ config PMIC_STPMIC1
config SPL_PMIC_PALMAS bool "Enable driver for Texas Instruments PALMAS PMIC" + depends on SPL_DM_PMIC help The PALMAS is a PMIC containing several LDOs, SMPS. This driver binds the pmic children in SPL.
config SPL_PMIC_LP873X bool "Enable driver for Texas Instruments LP873X PMIC" + depends on SPL_DM_PMIC help The LP873X is a PMIC containing couple of LDOs and couple of SMPS. This driver binds the pmic children in SPL.
config SPL_PMIC_LP87565 bool "Enable driver for Texas Instruments LP87565 PMIC" + depends on SPL_DM_PMIC help The LP87565 is a PMIC containing a bunch of SMPS. This driver binds the pmic children in SPL.
Yes, confirmed that this covers all SPL DM_PMIC drivers. Also checked that those who didn't have DM in their Kconfig symbol name, are indeed DM style drivers.
Reviewed-by: Andre Przywara andre.przywara@arm.com
Cheers, Andre
Changes in v2:
- depends on SPL_DM_PMIC default y ---help--- This allows PMICs to support child devices (such as regulators)
- depends on SPL
- depends on SPL_DM_PMIC help This config enables implementation of driver-model pmic
- depends on SPL_DM_PMIC help This config enables implementation of driver-model pmic uclass features for PMIC BD71837. The driver implements read/write
- depends on SPL_DM_PMIC help This config enables implementation of driver-model pmic uclass features for PMIC MP5416. The driver implements read/write
- depends on SPL_DM_PMIC ---help--- This config enables implementation of driver-model pmic uclass
- depends on SPL_DM_PMIC ---help--- The Rockchip RK808 PMIC provides four buck DC-DC convertors, 8
- depends on SPL_DM_PMIC help The PALMAS is a PMIC containing several LDOs, SMPS. This driver binds the pmic children in SPL.
- depends on SPL_DM_PMIC help The LP873X is a PMIC containing couple of LDOs and couple of
- depends on SPL_DM_PMIC help The LP87565 is a PMIC containing a bunch of SMPS. This driver binds the pmic children in SPL.
These PMICs provide some combination of battery charger, fuel gauge, GPIOs, regulators, and VBUS routing. These functions are represented as child nodes in the device tree. Add the minimal driver needed to probe these child devices and provide the DM_PMIC ops.
Enable the driver by default for SoCs that normally pair with a PMIC.
Changes in v2: - Replace axp_pmic_bind() with `.bind = dm_scan_fdt_dev`
drivers/power/pmic/Kconfig | 14 ++++++++++++++ drivers/power/pmic/Makefile | 1 + drivers/power/pmic/axp.c | 38 +++++++++++++++++++++++++++++++++++++ 3 files changed, 53 insertions(+) create mode 100644 drivers/power/pmic/axp.c
diff --git a/drivers/power/pmic/Kconfig b/drivers/power/pmic/Kconfig index e8a04325f85..fcb517f1044 100644 --- a/drivers/power/pmic/Kconfig +++ b/drivers/power/pmic/Kconfig @@ -63,6 +63,20 @@ config PMIC_ACT8846 functions. It uses an I2C interface and is designed for use with tablets and smartphones.
+config PMIC_AXP + bool "Enable Driver Model for X-Powers AXP PMICs" + depends on DM_I2C + help + This config enables driver-model PMIC uclass features for + X-Powers AXP152, AXP2xx, and AXP8xx PMICs. + +config SPL_PMIC_AXP + bool "Enable Driver Model for X-Powers AXP PMICs in SPL" + depends on SPL_DM_I2C && SPL_DM_PMIC + help + This config enables driver-model PMIC uclass features in the SPL for + X-Powers AXP152, AXP2xx, and AXP8xx PMICs. + config DM_PMIC_DA9063 bool "Enable Driver Model for the Dialog DA9063 PMIC" help diff --git a/drivers/power/pmic/Makefile b/drivers/power/pmic/Makefile index 5250eac12f2..e1922df00f8 100644 --- a/drivers/power/pmic/Makefile +++ b/drivers/power/pmic/Makefile @@ -18,6 +18,7 @@ obj-$(CONFIG_DM_PMIC_SANDBOX) += sandbox.o i2c_pmic_emul.o obj-$(CONFIG_PMIC_AB8500) += ab8500.o obj-$(CONFIG_PMIC_ACT8846) += act8846.o obj-$(CONFIG_PMIC_AS3722) += as3722.o as3722_gpio.o +obj-$(CONFIG_$(SPL_)PMIC_AXP) += axp.o obj-$(CONFIG_PMIC_MAX8997) += max8997.o obj-$(CONFIG_PMIC_PM8916) += pm8916.o obj-$(CONFIG_$(SPL_TPL_)PMIC_RK8XX) += rk8xx.o diff --git a/drivers/power/pmic/axp.c b/drivers/power/pmic/axp.c new file mode 100644 index 00000000000..74c94bdb47b --- /dev/null +++ b/drivers/power/pmic/axp.c @@ -0,0 +1,38 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <dm.h> +#include <i2c.h> +#include <power/pmic.h> + +static int axp_pmic_reg_count(struct udevice *dev) +{ + /* TODO: Get the specific value from driver data. */ + return 0x100; +} + +static struct dm_pmic_ops axp_pmic_ops = { + .reg_count = axp_pmic_reg_count, + .read = dm_i2c_read, + .write = dm_i2c_write, +}; + +static const struct udevice_id axp_pmic_ids[] = { + { .compatible = "x-powers,axp152" }, + { .compatible = "x-powers,axp202" }, + { .compatible = "x-powers,axp209" }, + { .compatible = "x-powers,axp221" }, + { .compatible = "x-powers,axp223" }, + { .compatible = "x-powers,axp803" }, + { .compatible = "x-powers,axp806" }, + { .compatible = "x-powers,axp809" }, + { .compatible = "x-powers,axp813" }, + { } +}; + +U_BOOT_DRIVER(axp_pmic) = { + .name = "axp_pmic", + .id = UCLASS_PMIC, + .of_match = axp_pmic_ids, + .bind = dm_scan_fdt_dev, + .ops = &axp_pmic_ops, +};
Looks indeed like a minimal I2C passthrough DM driver.
Cheers, Andre
Changes in v2:
+config PMIC_AXP
- bool "Enable Driver Model for X-Powers AXP PMICs"
- depends on DM_I2C
- help
- bool "Enable Driver Model for X-Powers AXP PMICs in SPL"
- depends on SPL_DM_I2C && SPL_DM_PMIC
- help
- /* TODO: Get the specific value from driver data. */
- return 0x100;
- .reg_count = axp_pmic_reg_count,
- .read = dm_i2c_read,
- .write = dm_i2c_write,
- { .compatible = "x-powers,axp152" },
- { .compatible = "x-powers,axp202" },
- { .compatible = "x-powers,axp209" },
- { .compatible = "x-powers,axp221" },
- { .compatible = "x-powers,axp223" },
- { .compatible = "x-powers,axp803" },
- { .compatible = "x-powers,axp806" },
- { .compatible = "x-powers,axp809" },
- { .compatible = "x-powers,axp813" },
- .name = "axp_pmic",
- .id = UCLASS_PMIC,
- .of_match = axp_pmic_ids,
- .bind = dm_scan_fdt_dev,
- .ops = &axp_pmic_ops,
CONFIG_SPL_I2C is the wrong symbol to use here. It is the top-level Kconfig symbol (not specific to either legacy or DM I2C), whereas the i2c_init() function is specific to legacy I2C. This change fixes a build failure when enabling SPL_I2C but not SPL_SYS_I2C_LEGACY.
Signed-off-by: Samuel Holland samuel@sholland.org --- Actually, I think this commit raises a larger issue:
For some reason, SPL_SYS_I2C_LEGACY does not depend on SPL_I2C. When SPL_SYS_I2C_LEGACY was added in commit 55dabcc8f245 ("Convert CONFIG_SYS_I2C_LEGACY to Kconfig and add CONFIG_[ST]PL_SYS_I2C_LEGACY"), SPL_I2C wasn't added to the board configs.
But since commit 537892065ac1 ("Makefile: Move drivers/i2c/ into drivers/Makefile"), drivers/i2c is only compiled if SPL_I2C is enabled.
So the combination of these two commits appears to have accidentally removed I2C support from SPL for many boards.
The impact here is that checking CONFIG_IS_ENABLED(SYS_I2C_LEGACY) is not always enough, even though it should be. Because if CONFIG_SPL_I2C=n then i2c_init is undefined because drivers/i2c/i2c_core.c is not built.
Changes in v2: - New patch to account for I2C Kconfig changes
arch/arm/mach-sunxi/board.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index d9b04f75fc4..b74ad4074df 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -339,7 +339,7 @@ void board_init_f(ulong dummy) spl_init(); preloader_console_init();
-#ifdef CONFIG_SPL_I2C +#if CONFIG_IS_ENABLED(I2C) && CONFIG_IS_ENABLED(SYS_I2C_LEGACY) /* Needed early by sunxi_board_init if PMU is enabled */ i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); #endif
I don't have the brain capacity right now to comment on the issue below, but just for the sake of this patch:
Cheers, Andre
Changes in v2:
SUN8I_RSB should not be selected by MACH_SUN8I, because the hardware is not present in half of those SoCs (H3/H5, R40, and V3s). Move the selection to the SoCs where the hardware actually exists.
Reviewed-by: Andre Przywara andre.przywara@arm.com Signed-off-by: Samuel Holland samuel@sholland.org ---
Changes in v2: - No changes
arch/arm/mach-sunxi/Kconfig | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 1d4a4fdd0c5..677d4554173 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -260,6 +260,7 @@ config MACH_SUN8I_A23 select ARCH_SUPPORT_PSCI select DRAM_SUN8I_A23 select PHY_SUN4I_USB + select SUN8I_RSB select SUNXI_GEN_SUN6I select SUPPORT_SPL select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT @@ -273,6 +274,7 @@ config MACH_SUN8I_A33 select ARCH_SUPPORT_PSCI select DRAM_SUN8I_A33 select PHY_SUN4I_USB + select SUN8I_RSB select SUNXI_GEN_SUN6I select SUPPORT_SPL select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT @@ -283,6 +285,7 @@ config MACH_SUN8I_A83T select CPU_V7A select DRAM_SUN8I_A83T select PHY_SUN4I_USB + select SUN8I_RSB select SUNXI_GEN_SUN6I select MMC_SUNXI_HAS_NEW_MODE select MMC_SUNXI_HAS_MODE_SWITCH @@ -377,7 +380,6 @@ endchoice # The sun8i SoCs share a lot, this helps to avoid a lot of "if A23 || A33" config MACH_SUN8I bool - select SUN8I_RSB select SUN6I_PRCM default y if MACH_SUN8I_A23 default y if MACH_SUN8I_A33
For the records, as per our IRC discussion, I removed the blanket select from MACH_SUN9I, and added it to the defconfig of the two affected boards. This fixes the compiler warnings for Sunchip_CX-A99.
Cheers, Andre.
Changes in v2:
- No changes
- select SUN8I_RSB select SUNXI_GEN_SUN6I select SUPPORT_SPL select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT
- select SUN8I_RSB select SUNXI_GEN_SUN6I select MMC_SUNXI_HAS_NEW_MODE select MMC_SUNXI_HAS_MODE_SWITCH
AXP_PMIC_BUS enables communication with a specific AXP PMIC at a PMIC-dependent I2C/P2WI/RSB bus address. It is automatically selected as a dependency of the PMIC driver. It should not be selectable by the user when no PMIC is chosen.
AXP_GPIO uses the pmic_bus functions, and also depends on a specific PMIC header to pick up register definitions.
Both of these changes have no impact on any existing configs, since the code does not compile if the dependencies are not met.
arch/arm/mach-sunxi/Kconfig | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 677d4554173..4d8f0e17d40 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -106,7 +106,7 @@ config SUN6I_PRCM in A31 SoC.
config AXP_PMIC_BUS - bool "Sunxi AXP PMIC bus access helpers" + bool help Select this PMIC bus access helpers for Sunxi platform PRCM or other AXP family PMIC devices. @@ -809,6 +809,7 @@ endif
config AXP_GPIO bool "Enable support for gpio-s on axp PMICs" + depends on AXP_PMIC_BUS ---help--- Say Y here to enable support for the gpio pins of the axp PMIC ICs.
This bus controller is used to communicate with an X-Powers AXP PMIC. Currently, various drivers access PMIC registers through a platform- specific non-DM "pmic_bus" interface, which depends on the legacy I2C framework. In order to convert those drivers to use DM_PMIC, this bus needs a DM_I2C driver.
Refactor the p2wi functions to take the base address as a parameter, and implement both the existing interface (which is still needed in SPL) and the DM_I2C interface on top of them.
The register for switching between I2C/P2WI/RSB mode is the same across all PMIC variants. Move that to the common header, so it can be used by both interface implementations.
Changes in v2: - Renamed Kconfig symbol to SYS_I2C_SUN6I_P2WI - Moved entire P2WI driver source to drivers/i2c
arch/arm/mach-sunxi/Kconfig | 14 +-- arch/arm/mach-sunxi/Makefile | 1 - arch/arm/mach-sunxi/p2wi.c | 117 ------------------ arch/arm/mach-sunxi/pmic_bus.c | 7 +- drivers/i2c/Kconfig | 8 ++ drivers/i2c/Makefile | 1 + drivers/i2c/sun6i_p2wi.c | 220 +++++++++++++++++++++++++++++++++ include/axp_pmic.h | 6 + 8 files changed, 240 insertions(+), 134 deletions(-) delete mode 100644 arch/arm/mach-sunxi/p2wi.c create mode 100644 drivers/i2c/sun6i_p2wi.c
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 4d8f0e17d40..ae3b7974f09 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -88,17 +88,6 @@ config DRAM_SUN50I_H616_UNKNOWN_FEATURE feature. endif
-config SUN6I_P2WI - bool "Allwinner sun6i internal P2WI controller" - help - If you say yes to this option, support will be included for the - P2WI (Push/Pull 2 Wire Interface) controller embedded in some sunxi - SOCs. - The P2WI looks like an SMBus controller (which supports only byte - accesses), except that it only supports one slave device. - This interface is used to connect to specific PMIC devices (like the - AXP221). - config SUN6I_PRCM bool help @@ -232,10 +221,11 @@ config MACH_SUN6I select ARCH_SUPPORT_PSCI select DRAM_SUN6I select PHY_SUN4I_USB - select SUN6I_P2WI + select SPL_I2C select SUN6I_PRCM select SUNXI_GEN_SUN6I select SUPPORT_SPL + select SYS_I2C_SUN6I_P2WI select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT
config MACH_SUN7I diff --git a/arch/arm/mach-sunxi/Makefile b/arch/arm/mach-sunxi/Makefile index 3f081d92f37..c9312bb3934 100644 --- a/arch/arm/mach-sunxi/Makefile +++ b/arch/arm/mach-sunxi/Makefile @@ -11,7 +11,6 @@ obj-y += clock.o obj-y += cpu_info.o obj-y += dram_helpers.o obj-y += pinmux.o -obj-$(CONFIG_SUN6I_P2WI) += p2wi.o obj-$(CONFIG_SUN6I_PRCM) += prcm.o obj-$(CONFIG_AXP_PMIC_BUS) += pmic_bus.o obj-$(CONFIG_SUN8I_RSB) += rsb.o diff --git a/arch/arm/mach-sunxi/p2wi.c b/arch/arm/mach-sunxi/p2wi.c deleted file mode 100644 index 7c5c12254ea..00000000000 --- a/arch/arm/mach-sunxi/p2wi.c +++ /dev/null @@ -1,117 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Sunxi A31 Power Management Unit - * - * (C) Copyright 2013 Oliver Schinagl oliver@schinagl.nl - * http://linux-sunxi.org - * - * Based on sun6i sources and earlier U-Boot Allwinner A10 SPL work - * - * (C) Copyright 2006-2013 - * Allwinner Technology Co., Ltd. <www.allwinnertech.com> - * Berg Xing bergxing@allwinnertech.com - * Tom Cubie tangliang@allwinnertech.com - */ - -#include <common.h> -#include <errno.h> -#include <time.h> -#include <asm/io.h> -#include <asm/arch/cpu.h> -#include <asm/arch/gpio.h> -#include <asm/arch/p2wi.h> -#include <asm/arch/prcm.h> -#include <asm/arch/clock.h> -#include <asm/arch/sys_proto.h> - -void p2wi_init(void) -{ - struct sunxi_p2wi_reg *p2wi = (struct sunxi_p2wi_reg *)SUN6I_P2WI_BASE; - - /* Enable p2wi and PIO clk, and de-assert their resets */ - prcm_apb0_enable(PRCM_APB0_GATE_PIO | PRCM_APB0_GATE_P2WI); - - sunxi_gpio_set_cfgpin(SUNXI_GPL(0), SUN6I_GPL0_R_P2WI_SCK); - sunxi_gpio_set_cfgpin(SUNXI_GPL(1), SUN6I_GPL1_R_P2WI_SDA); - - /* Reset p2wi controller and set clock to CLKIN(12)/8 = 1.5 MHz */ - writel(P2WI_CTRL_RESET, &p2wi->ctrl); - sdelay(0x100); - writel(P2WI_CC_SDA_OUT_DELAY(1) | P2WI_CC_CLK_DIV(8), - &p2wi->cc); -} - -int p2wi_change_to_p2wi_mode(u8 slave_addr, u8 ctrl_reg, u8 init_data) -{ - struct sunxi_p2wi_reg *p2wi = (struct sunxi_p2wi_reg *)SUN6I_P2WI_BASE; - unsigned long tmo = timer_get_us() + 1000000; - - writel(P2WI_PM_DEV_ADDR(slave_addr) | - P2WI_PM_CTRL_ADDR(ctrl_reg) | - P2WI_PM_INIT_DATA(init_data) | - P2WI_PM_INIT_SEND, - &p2wi->pm); - - while ((readl(&p2wi->pm) & P2WI_PM_INIT_SEND)) { - if (timer_get_us() > tmo) - return -ETIME; - } - - return 0; -} - -static int p2wi_await_trans(void) -{ - struct sunxi_p2wi_reg *p2wi = (struct sunxi_p2wi_reg *)SUN6I_P2WI_BASE; - unsigned long tmo = timer_get_us() + 1000000; - int ret; - u8 reg; - - while (1) { - reg = readl(&p2wi->status); - if (reg & P2WI_STAT_TRANS_ERR) { - ret = -EIO; - break; - } - if (reg & P2WI_STAT_TRANS_DONE) { - ret = 0; - break; - } - if (timer_get_us() > tmo) { - ret = -ETIME; - break; - } - } - writel(reg, &p2wi->status); /* Clear status bits */ - return ret; -} - -int p2wi_read(const u8 addr, u8 *data) -{ - struct sunxi_p2wi_reg *p2wi = (struct sunxi_p2wi_reg *)SUN6I_P2WI_BASE; - int ret; - - writel(P2WI_DATADDR_BYTE_1(addr), &p2wi->dataddr0); - writel(P2WI_DATA_NUM_BYTES(1) | - P2WI_DATA_NUM_BYTES_READ, &p2wi->numbytes); - writel(P2WI_STAT_TRANS_DONE, &p2wi->status); - writel(P2WI_CTRL_TRANS_START, &p2wi->ctrl); - - ret = p2wi_await_trans(); - - *data = readl(&p2wi->data0) & P2WI_DATA_BYTE_1_MASK; - return ret; -} - -int p2wi_write(const u8 addr, u8 data) -{ - struct sunxi_p2wi_reg *p2wi = (struct sunxi_p2wi_reg *)SUN6I_P2WI_BASE; - - writel(P2WI_DATADDR_BYTE_1(addr), &p2wi->dataddr0); - writel(P2WI_DATA_BYTE_1(data), &p2wi->data0); - writel(P2WI_DATA_NUM_BYTES(1), &p2wi->numbytes); - writel(P2WI_STAT_TRANS_DONE, &p2wi->status); - writel(P2WI_CTRL_TRANS_START, &p2wi->ctrl); - - return p2wi_await_trans(); -} diff --git a/arch/arm/mach-sunxi/pmic_bus.c b/arch/arm/mach-sunxi/pmic_bus.c index 0394ce85644..673a05fdd16 100644 --- a/arch/arm/mach-sunxi/pmic_bus.c +++ b/arch/arm/mach-sunxi/pmic_bus.c @@ -8,6 +8,7 @@ * axp223 uses the rsb bus, these functions abstract this. */
+#include <axp_pmic.h> #include <common.h> #include <asm/arch/p2wi.h> #include <asm/arch/rsb.h> @@ -21,8 +22,6 @@ #define AXP305_I2C_ADDR 0x36
#define AXP221_CHIP_ADDR 0x68 -#define AXP221_CTRL_ADDR 0x3e -#define AXP221_INIT_DATA 0x3e
/* AXP818 device and runtime addresses are same as AXP223 */ #define AXP223_DEVICE_ADDR 0x3a3 @@ -40,8 +39,8 @@ int pmic_bus_init(void) #if defined CONFIG_AXP221_POWER || defined CONFIG_AXP809_POWER || defined CONFIG_AXP818_POWER # ifdef CONFIG_MACH_SUN6I p2wi_init(); - ret = p2wi_change_to_p2wi_mode(AXP221_CHIP_ADDR, AXP221_CTRL_ADDR, - AXP221_INIT_DATA); + ret = p2wi_change_to_p2wi_mode(AXP221_CHIP_ADDR, AXP_PMIC_MODE_REG, + AXP_PMIC_MODE_P2WI); # elif defined CONFIG_MACH_SUN8I_R40 /* Nothing. R40 uses the AXP221s in I2C mode */ ret = 0; diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index 57cac4483f0..0adf143abfd 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -575,6 +575,14 @@ config SYS_I2C_STM32F7 _ Optional clock stretching _ Software reset
+config SYS_I2C_SUN6I_P2WI + bool "Allwinner sun6i P2WI controller" + depends on ARCH_SUNXI + help + Support for the P2WI (Push/Pull 2 Wire Interface) controller embedded + in the Allwinner A31 and A31s SOCs. This interface is used to connect + to specific devices like the X-Powers AXP221 PMIC. + config SYS_I2C_SYNQUACER bool "Socionext SynQuacer I2C controller" depends on ARCH_SYNQUACER && DM_I2C diff --git a/drivers/i2c/Makefile b/drivers/i2c/Makefile index 67841bf3e02..0a2cc641930 100644 --- a/drivers/i2c/Makefile +++ b/drivers/i2c/Makefile @@ -43,6 +43,7 @@ obj-$(CONFIG_SYS_I2C_SANDBOX) += sandbox_i2c.o i2c-emul-uclass.o obj-$(CONFIG_SYS_I2C_SH) += sh_i2c.o obj-$(CONFIG_SYS_I2C_SOFT) += soft_i2c.o obj-$(CONFIG_SYS_I2C_STM32F7) += stm32f7_i2c.o +obj-$(CONFIG_SYS_I2C_SUN6I_P2WI) += sun6i_p2wi.o obj-$(CONFIG_SYS_I2C_SYNQUACER) += synquacer_i2c.o obj-$(CONFIG_SYS_I2C_TEGRA) += tegra_i2c.o obj-$(CONFIG_SYS_I2C_UNIPHIER) += i2c-uniphier.o diff --git a/drivers/i2c/sun6i_p2wi.c b/drivers/i2c/sun6i_p2wi.c new file mode 100644 index 00000000000..c9e1b3fcd5f --- /dev/null +++ b/drivers/i2c/sun6i_p2wi.c @@ -0,0 +1,220 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Sunxi A31 Power Management Unit + * + * (C) Copyright 2013 Oliver Schinagl oliver@schinagl.nl + * http://linux-sunxi.org + * + * Based on sun6i sources and earlier U-Boot Allwinner A10 SPL work + * + * (C) Copyright 2006-2013 + * Allwinner Technology Co., Ltd. <www.allwinnertech.com> + * Berg Xing bergxing@allwinnertech.com + * Tom Cubie tangliang@allwinnertech.com + */ + +#include <axp_pmic.h> +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <i2c.h> +#include <time.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/gpio.h> +#include <asm/arch/p2wi.h> +#include <asm/arch/prcm.h> +#include <asm/arch/sys_proto.h> + +static int sun6i_p2wi_await_trans(struct sunxi_p2wi_reg *base) +{ + unsigned long tmo = timer_get_us() + 1000000; + int ret; + u8 reg; + + while (1) { + reg = readl(&base->status); + if (reg & P2WI_STAT_TRANS_ERR) { + ret = -EIO; + break; + } + if (reg & P2WI_STAT_TRANS_DONE) { + ret = 0; + break; + } + if (timer_get_us() > tmo) { + ret = -ETIME; + break; + } + } + writel(reg, &base->status); /* Clear status bits */ + + return ret; +} + +static int sun6i_p2wi_read(struct sunxi_p2wi_reg *base, const u8 addr, u8 *data) +{ + int ret; + + writel(P2WI_DATADDR_BYTE_1(addr), &base->dataddr0); + writel(P2WI_DATA_NUM_BYTES(1) | + P2WI_DATA_NUM_BYTES_READ, &base->numbytes); + writel(P2WI_STAT_TRANS_DONE, &base->status); + writel(P2WI_CTRL_TRANS_START, &base->ctrl); + + ret = sun6i_p2wi_await_trans(base); + + *data = readl(&base->data0) & P2WI_DATA_BYTE_1_MASK; + + return ret; +} + +static int sun6i_p2wi_write(struct sunxi_p2wi_reg *base, const u8 addr, u8 data) +{ + writel(P2WI_DATADDR_BYTE_1(addr), &base->dataddr0); + writel(P2WI_DATA_BYTE_1(data), &base->data0); + writel(P2WI_DATA_NUM_BYTES(1), &base->numbytes); + writel(P2WI_STAT_TRANS_DONE, &base->status); + writel(P2WI_CTRL_TRANS_START, &base->ctrl); + + return sun6i_p2wi_await_trans(base); +} + +static int sun6i_p2wi_change_to_p2wi_mode(struct sunxi_p2wi_reg *base, + u8 slave_addr, u8 ctrl_reg, + u8 init_data) +{ + unsigned long tmo = timer_get_us() + 1000000; + + writel(P2WI_PM_DEV_ADDR(slave_addr) | + P2WI_PM_CTRL_ADDR(ctrl_reg) | + P2WI_PM_INIT_DATA(init_data) | + P2WI_PM_INIT_SEND, + &base->pm); + + while ((readl(&base->pm) & P2WI_PM_INIT_SEND)) { + if (timer_get_us() > tmo) + return -ETIME; + } + + return 0; +} + +static void sun6i_p2wi_init(struct sunxi_p2wi_reg *base) +{ + /* Enable p2wi and PIO clk, and de-assert their resets */ + prcm_apb0_enable(PRCM_APB0_GATE_PIO | PRCM_APB0_GATE_P2WI); + + sunxi_gpio_set_cfgpin(SUNXI_GPL(0), SUN6I_GPL0_R_P2WI_SCK); + sunxi_gpio_set_cfgpin(SUNXI_GPL(1), SUN6I_GPL1_R_P2WI_SDA); + + /* Reset p2wi controller and set clock to CLKIN(12)/8 = 1.5 MHz */ + writel(P2WI_CTRL_RESET, &base->ctrl); + sdelay(0x100); + writel(P2WI_CC_SDA_OUT_DELAY(1) | P2WI_CC_CLK_DIV(8), + &base->cc); +} + +#if IS_ENABLED(CONFIG_AXP_PMIC_BUS) +int p2wi_read(const u8 addr, u8 *data) +{ + struct sunxi_p2wi_reg *base = (struct sunxi_p2wi_reg *)SUN6I_P2WI_BASE; + + return sun6i_p2wi_read(base, addr, data); +} + +int p2wi_write(const u8 addr, u8 data) +{ + struct sunxi_p2wi_reg *base = (struct sunxi_p2wi_reg *)SUN6I_P2WI_BASE; + + return sun6i_p2wi_write(base, addr, data); +} + +int p2wi_change_to_p2wi_mode(u8 slave_addr, u8 ctrl_reg, u8 init_data) +{ + struct sunxi_p2wi_reg *base = (struct sunxi_p2wi_reg *)SUN6I_P2WI_BASE; + + return sun6i_p2wi_change_to_p2wi_mode(base, slave_addr, ctrl_reg, + init_data); +} + +void p2wi_init(void) +{ + struct sunxi_p2wi_reg *base = (struct sunxi_p2wi_reg *)SUN6I_P2WI_BASE; + + sun6i_p2wi_init(base); +} +#endif + +#if CONFIG_IS_ENABLED(DM_I2C) +struct sun6i_p2wi_priv { + struct sunxi_p2wi_reg *base; +}; + +static int sun6i_p2wi_xfer(struct udevice *bus, struct i2c_msg *msg, int nmsgs) +{ + struct sun6i_p2wi_priv *priv = dev_get_priv(bus); + + /* The hardware only supports SMBus-style transfers. */ + if (nmsgs == 2 && msg[1].flags == I2C_M_RD && msg[1].len == 1) + return sun6i_p2wi_read(priv->base, + msg[0].buf[0], &msg[1].buf[0]); + + if (nmsgs == 1 && msg[0].len == 2) + return sun6i_p2wi_write(priv->base, + msg[0].buf[0], msg[0].buf[1]); + + return -EINVAL; +} + +static int sun6i_p2wi_probe_chip(struct udevice *bus, uint chip_addr, + uint chip_flags) +{ + struct sun6i_p2wi_priv *priv = dev_get_priv(bus); + + return sun6i_p2wi_change_to_p2wi_mode(priv->base, chip_addr, + AXP_PMIC_MODE_REG, + AXP_PMIC_MODE_P2WI); +} + +static int sun6i_p2wi_probe(struct udevice *bus) +{ + struct sun6i_p2wi_priv *priv = dev_get_priv(bus); + + priv->base = dev_read_addr_ptr(bus); + + sun6i_p2wi_init(priv->base); + + return 0; +} + +static int sun6i_p2wi_child_pre_probe(struct udevice *child) +{ + struct dm_i2c_chip *chip = dev_get_parent_plat(child); + + /* Ensure each transfer is for a single register. */ + chip->flags |= DM_I2C_CHIP_RD_ADDRESS | DM_I2C_CHIP_WR_ADDRESS; + + return 0; +} + +static const struct dm_i2c_ops sun6i_p2wi_ops = { + .xfer = sun6i_p2wi_xfer, + .probe_chip = sun6i_p2wi_probe_chip, +}; + +static const struct udevice_id sun6i_p2wi_ids[] = { + { .compatible = "allwinner,sun6i-a31-p2wi" }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(sun6i_p2wi) = { + .name = "sun6i_p2wi", + .id = UCLASS_I2C, + .of_match = sun6i_p2wi_ids, + .probe = sun6i_p2wi_probe, + .child_pre_probe = sun6i_p2wi_child_pre_probe, + .priv_auto = sizeof(struct sun6i_p2wi_priv), + .ops = &sun6i_p2wi_ops, +}; +#endif /* CONFIG_IS_ENABLED(DM_I2C) */ diff --git a/include/axp_pmic.h b/include/axp_pmic.h index 405044c3a32..0db3e143eda 100644 --- a/include/axp_pmic.h +++ b/include/axp_pmic.h @@ -6,6 +6,8 @@ */ #ifndef _AXP_PMIC_H_
+#include <stdbool.h> + #ifdef CONFIG_AXP152_POWER #include <axp152.h> #endif @@ -25,6 +27,10 @@ #include <axp818.h> #endif
+#define AXP_PMIC_MODE_REG 0x3e +#define AXP_PMIC_MODE_I2C 0x00 +#define AXP_PMIC_MODE_P2WI 0x3e + int axp_set_dcdc1(unsigned int mvolt); int axp_set_dcdc2(unsigned int mvolt); int axp_set_dcdc3(unsigned int mvolt);
I compared the old and new file (with some tweaks), and can indeed confirm that it's a conversion that preserves the actual functionality. The new DM wrappers look good as well.
Thanks! Andre
Changes in v2:
-config SUN6I_P2WI
- help
the
sunxi
SOCs.
byte
(like the
AXP221).
- select SUN6I_P2WI
- select SPL_I2C select SUN6I_PRCM select SUNXI_GEN_SUN6I select SUPPORT_SPL
- select SYS_I2C_SUN6I_P2WI select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT
- Sunxi A31 Power Management Unit
- (C) Copyright 2013 Oliver Schinagl oliver@schinagl.nl
- Based on sun6i sources and earlier U-Boot Allwinner A10 SPL work
- (C) Copyright 2006-2013
- Allwinner Technology Co., Ltd. <www.allwinnertech.com>
- Berg Xing bergxing@allwinnertech.com
- Tom Cubie tangliang@allwinnertech.com
- sdelay(0x100);
&p2wi->cc);
*)SUN6I_P2WI_BASE;
P2WI_PM_INIT_SEND,
&p2wi->pm);
return -ETIME;
*)SUN6I_P2WI_BASE;
- int ret;
- u8 reg;
- while (1) {
ret = -EIO;
break;
ret = 0;
break;
ret = -ETIME;
break;
- return ret;
*)SUN6I_P2WI_BASE;
- int ret;
- return ret;
- axp223 uses the rsb bus, these functions abstract this.
AXP221_CTRL_ADDR,
AXP221_INIT_DATA);
AXP_PMIC_MODE_REG,
- bool "Allwinner sun6i P2WI controller"
- depends on ARCH_SUNXI
- help
embedded
connect
- int ret;
- u8 reg;
- while (1) {
ret = -EIO;
break;
ret = 0;
break;
ret = -ETIME;
break;
- writel(reg, &base->status); /* Clear status bits */
- return ret;
- int ret;
- writel(P2WI_DATADDR_BYTE_1(addr), &base->dataddr0);
- writel(P2WI_STAT_TRANS_DONE, &base->status);
- writel(P2WI_CTRL_TRANS_START, &base->ctrl);
- ret = sun6i_p2wi_await_trans(base);
- *data = readl(&base->data0) & P2WI_DATA_BYTE_1_MASK;
- return ret;
- writel(P2WI_DATA_BYTE_1(data), &base->data0);
- writel(P2WI_DATA_NUM_BYTES(1), &base->numbytes);
- return sun6i_p2wi_await_trans(base);
u8 init_data)
P2WI_PM_INIT_SEND,
&base->pm);
- while ((readl(&base->pm) & P2WI_PM_INIT_SEND)) {
return -ETIME;
- writel(P2WI_CTRL_RESET, &base->ctrl);
- sdelay(0x100);
&base->cc);
- struct sunxi_p2wi_reg *base = (struct sunxi_p2wi_reg
- return sun6i_p2wi_read(base, addr, data);
- return sun6i_p2wi_write(base, addr, data);
- return sun6i_p2wi_change_to_p2wi_mode(base, slave_addr,
ctrl_reg,
init_data);
- sun6i_p2wi_init(base);
+} +#endif
- struct sunxi_p2wi_reg *base;
- struct sun6i_p2wi_priv *priv = dev_get_priv(bus);
- /* The hardware only supports SMBus-style transfers. */
- if (nmsgs == 2 && msg[1].flags == I2C_M_RD && msg[1].len == 1)
- if (nmsgs == 1 && msg[0].len == 2)
- return -EINVAL;
uint chip_flags)
- return sun6i_p2wi_change_to_p2wi_mode(priv->base, chip_addr,
AXP_PMIC_MODE_REG,
- priv->base = dev_read_addr_ptr(bus);
- sun6i_p2wi_init(priv->base);
- struct dm_i2c_chip *chip = dev_get_parent_plat(child);
- /* Ensure each transfer is for a single register. */
- chip->flags |= DM_I2C_CHIP_RD_ADDRESS | DM_I2C_CHIP_WR_ADDRESS;
- .xfer = sun6i_p2wi_xfer,
- .probe_chip = sun6i_p2wi_probe_chip,
- { .compatible = "allwinner,sun6i-a31-p2wi" },
- { /* sentinel */ }
- .name = "sun6i_p2wi",
- .id = UCLASS_I2C,
- .of_match = sun6i_p2wi_ids,
- .probe = sun6i_p2wi_probe,
- .child_pre_probe = sun6i_p2wi_child_pre_probe,
- .priv_auto = sizeof(struct sun6i_p2wi_priv),
- .ops = &sun6i_p2wi_ops,
Refactor the rsb functions to take the base address as a parameter, and implement both the existing interface (which is still needed in SPL) and the DM_I2C interface on top of them.
The register for switching between I2C/P2WI/RSB mode is the same across all PMIC variants, so move that to the common header.
There are only a couple of pairs of hardware/runtime addresses used across all PMIC variants. So far the code expected only the "primary" pair, but some PMICs like the AXP305 and AXP805 use the secondary pair, so add support for that to the DM driver as well.
Changes in v2: - Renamed Kconfig symbol to SYS_I2C_SUN8I_RSB - Moved entire RSB driver source to drivers/i2c
arch/arm/mach-sunxi/Kconfig | 20 +-- arch/arm/mach-sunxi/Makefile | 1 - arch/arm/mach-sunxi/pmic_bus.c | 11 +- arch/arm/mach-sunxi/rsb.c | 175 -------------------- drivers/i2c/Kconfig | 8 + drivers/i2c/Makefile | 1 + drivers/i2c/sun8i_rsb.c | 281 +++++++++++++++++++++++++++++++++ include/axp_pmic.h | 6 + 8 files changed, 308 insertions(+), 195 deletions(-) delete mode 100644 arch/arm/mach-sunxi/rsb.c create mode 100644 drivers/i2c/sun8i_rsb.c
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index ae3b7974f09..df160c9a775 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -100,14 +100,6 @@ config AXP_PMIC_BUS Select this PMIC bus access helpers for Sunxi platform PRCM or other AXP family PMIC devices.
-config SUN8I_RSB - bool "Allwinner sunXi Reduced Serial Bus Driver" - help - Say y here to enable support for Allwinner's Reduced Serial Bus - (RSB) support. This controller is responsible for communicating - with various RSB based devices, such as AXP223, AXP8XX PMICs, - and AC100/AC200 ICs. - config SUNXI_SRAM_ADDRESS hex default 0x10000 if MACH_SUN9I || MACH_SUN50I || MACH_SUN50I_H5 @@ -250,9 +242,10 @@ config MACH_SUN8I_A23 select ARCH_SUPPORT_PSCI select DRAM_SUN8I_A23 select PHY_SUN4I_USB - select SUN8I_RSB + select SPL_I2C select SUNXI_GEN_SUN6I select SUPPORT_SPL + select SYS_I2C_SUN8I_RSB select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT imply CONS_INDEX_5 if !DM_SERIAL
@@ -264,9 +257,10 @@ config MACH_SUN8I_A33 select ARCH_SUPPORT_PSCI select DRAM_SUN8I_A33 select PHY_SUN4I_USB - select SUN8I_RSB + select SPL_I2C select SUNXI_GEN_SUN6I select SUPPORT_SPL + select SYS_I2C_SUN8I_RSB select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT imply CONS_INDEX_5 if !DM_SERIAL
@@ -275,11 +269,12 @@ config MACH_SUN8I_A83T select CPU_V7A select DRAM_SUN8I_A83T select PHY_SUN4I_USB - select SUN8I_RSB + select SPL_I2C select SUNXI_GEN_SUN6I select MMC_SUNXI_HAS_NEW_MODE select MMC_SUNXI_HAS_MODE_SWITCH select SUPPORT_SPL + select SYS_I2C_SUN8I_RSB
config MACH_SUN8I_H3 bool "sun8i (Allwinner H3)" @@ -320,10 +315,11 @@ config MACH_SUN9I bool "sun9i (Allwinner A80)" select CPU_V7A select DRAM_SUN9I + select SPL_I2C select SUN6I_PRCM select SUNXI_GEN_SUN6I - select SUN8I_RSB select SUPPORT_SPL + select SYS_I2C_SUN8I_RSB
config MACH_SUN50I bool "sun50i (Allwinner A64)" diff --git a/arch/arm/mach-sunxi/Makefile b/arch/arm/mach-sunxi/Makefile index c9312bb3934..5d3fd70f749 100644 --- a/arch/arm/mach-sunxi/Makefile +++ b/arch/arm/mach-sunxi/Makefile @@ -13,7 +13,6 @@ obj-y += dram_helpers.o obj-y += pinmux.o obj-$(CONFIG_SUN6I_PRCM) += prcm.o obj-$(CONFIG_AXP_PMIC_BUS) += pmic_bus.o -obj-$(CONFIG_SUN8I_RSB) += rsb.o obj-$(CONFIG_MACH_SUN4I) += clock_sun4i.o obj-$(CONFIG_MACH_SUN5I) += clock_sun4i.o obj-$(CONFIG_MACH_SUN6I) += clock_sun6i.o diff --git a/arch/arm/mach-sunxi/pmic_bus.c b/arch/arm/mach-sunxi/pmic_bus.c index 673a05fdd16..827797249ea 100644 --- a/arch/arm/mach-sunxi/pmic_bus.c +++ b/arch/arm/mach-sunxi/pmic_bus.c @@ -23,10 +23,6 @@
-/* AXP818 device and runtime addresses are same as AXP223 */ -#define AXP223_DEVICE_ADDR 0x3a3 -#define AXP223_RUNTIME_ADDR 0x2d - int pmic_bus_init(void) { /* This cannot be 0 because it is used in SPL before BSS is ready */ @@ -49,7 +45,8 @@ int pmic_bus_init(void) if (ret) return ret;
- ret = rsb_set_device_address(AXP223_DEVICE_ADDR, AXP223_RUNTIME_ADDR); + ret = rsb_set_device_address(AXP_PMIC_PRI_DEVICE_ADDR, + AXP_PMIC_PRI_RUNTIME_ADDR); # endif if (ret) return ret; @@ -73,7 +70,7 @@ int pmic_bus_read(u8 reg, u8 *data) # elif defined CONFIG_MACH_SUN8I_R40 return i2c_read(AXP209_I2C_ADDR, reg, 1, data, 1); # else - return rsb_read(AXP223_RUNTIME_ADDR, reg, data); + return rsb_read(AXP_PMIC_PRI_RUNTIME_ADDR, reg, data); # endif #endif } @@ -92,7 +89,7 @@ int pmic_bus_write(u8 reg, u8 data) # elif defined CONFIG_MACH_SUN8I_R40 return i2c_write(AXP209_I2C_ADDR, reg, 1, &data, 1); # else - return rsb_write(AXP223_RUNTIME_ADDR, reg, data); + return rsb_write(AXP_PMIC_PRI_RUNTIME_ADDR, reg, data); # endif #endif } diff --git a/arch/arm/mach-sunxi/rsb.c b/arch/arm/mach-sunxi/rsb.c deleted file mode 100644 index 01bb09b7478..00000000000 --- a/arch/arm/mach-sunxi/rsb.c +++ /dev/null @@ -1,175 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2014 Hans de Goede hdegoede@redhat.com - * - * Based on allwinner u-boot sources rsb code which is: - * (C) Copyright 2007-2013 - * Allwinner Technology Co., Ltd. <www.allwinnertech.com> - * lixiang lixiang@allwinnertech.com - */ - -#include <common.h> -#include <errno.h> -#include <time.h> -#include <asm/arch/cpu.h> -#include <asm/arch/gpio.h> -#include <asm/arch/prcm.h> -#include <asm/arch/rsb.h> - -static int rsb_set_device_mode(void); - -static void rsb_cfg_io(void) -{ -#ifdef CONFIG_MACH_SUN8I - sunxi_gpio_set_cfgpin(SUNXI_GPL(0), SUN8I_GPL_R_RSB); - sunxi_gpio_set_cfgpin(SUNXI_GPL(1), SUN8I_GPL_R_RSB); - sunxi_gpio_set_pull(SUNXI_GPL(0), 1); - sunxi_gpio_set_pull(SUNXI_GPL(1), 1); - sunxi_gpio_set_drv(SUNXI_GPL(0), 2); - sunxi_gpio_set_drv(SUNXI_GPL(1), 2); -#elif defined CONFIG_MACH_SUN9I - sunxi_gpio_set_cfgpin(SUNXI_GPN(0), SUN9I_GPN_R_RSB); - sunxi_gpio_set_cfgpin(SUNXI_GPN(1), SUN9I_GPN_R_RSB); - sunxi_gpio_set_pull(SUNXI_GPN(0), 1); - sunxi_gpio_set_pull(SUNXI_GPN(1), 1); - sunxi_gpio_set_drv(SUNXI_GPN(0), 2); - sunxi_gpio_set_drv(SUNXI_GPN(1), 2); -#else -#error unsupported MACH_SUNXI -#endif -} - -static void rsb_set_clk(void) -{ - struct sunxi_rsb_reg * const rsb = - (struct sunxi_rsb_reg *)SUNXI_RSB_BASE; - u32 div = 0; - u32 cd_odly = 0; - - /* Source is Hosc24M, set RSB clk to 3Mhz */ - div = 24000000 / 3000000 / 2 - 1; - cd_odly = div >> 1; - if (!cd_odly) - cd_odly = 1; - - writel((cd_odly << 8) | div, &rsb->ccr); -} - -int rsb_init(void) -{ - struct sunxi_rsb_reg * const rsb = - (struct sunxi_rsb_reg *)SUNXI_RSB_BASE; - - /* Enable RSB and PIO clk, and de-assert their resets */ - prcm_apb0_enable(PRCM_APB0_GATE_PIO | PRCM_APB0_GATE_RSB); - - /* Setup external pins */ - rsb_cfg_io(); - - writel(RSB_CTRL_SOFT_RST, &rsb->ctrl); - rsb_set_clk(); - - return rsb_set_device_mode(); -} - -static int rsb_await_trans(void) -{ - struct sunxi_rsb_reg * const rsb = - (struct sunxi_rsb_reg *)SUNXI_RSB_BASE; - unsigned long tmo = timer_get_us() + 1000000; - u32 stat; - int ret; - - while (1) { - stat = readl(&rsb->stat); - if (stat & RSB_STAT_LBSY_INT) { - ret = -EBUSY; - break; - } - if (stat & RSB_STAT_TERR_INT) { - ret = -EIO; - break; - } - if (stat & RSB_STAT_TOVER_INT) { - ret = 0; - break; - } - if (timer_get_us() > tmo) { - ret = -ETIME; - break; - } - } - writel(stat, &rsb->stat); /* Clear status bits */ - - return ret; -} - -static int rsb_set_device_mode(void) -{ - struct sunxi_rsb_reg * const rsb = - (struct sunxi_rsb_reg *)SUNXI_RSB_BASE; - unsigned long tmo = timer_get_us() + 1000000; - - writel(RSB_DMCR_DEVICE_MODE_START | RSB_DMCR_DEVICE_MODE_DATA, - &rsb->dmcr); - - while (readl(&rsb->dmcr) & RSB_DMCR_DEVICE_MODE_START) { - if (timer_get_us() > tmo) - return -ETIME; - } - - return rsb_await_trans(); -} - -static int rsb_do_trans(void) -{ - struct sunxi_rsb_reg * const rsb = - (struct sunxi_rsb_reg *)SUNXI_RSB_BASE; - - setbits_le32(&rsb->ctrl, RSB_CTRL_START_TRANS); - return rsb_await_trans(); -} - -int rsb_set_device_address(u16 device_addr, u16 runtime_addr) -{ - struct sunxi_rsb_reg * const rsb = - (struct sunxi_rsb_reg *)SUNXI_RSB_BASE; - - writel(RSB_DEVADDR_RUNTIME_ADDR(runtime_addr) | - RSB_DEVADDR_DEVICE_ADDR(device_addr), &rsb->devaddr); - writel(RSB_CMD_SET_RTSADDR, &rsb->cmd); - - return rsb_do_trans(); -} - -int rsb_write(const u16 runtime_device_addr, const u8 reg_addr, u8 data) -{ - struct sunxi_rsb_reg * const rsb = - (struct sunxi_rsb_reg *)SUNXI_RSB_BASE; - - writel(RSB_DEVADDR_RUNTIME_ADDR(runtime_device_addr), &rsb->devaddr); - writel(reg_addr, &rsb->addr); - writel(data, &rsb->data); - writel(RSB_CMD_BYTE_WRITE, &rsb->cmd); - - return rsb_do_trans(); -} - -int rsb_read(const u16 runtime_device_addr, const u8 reg_addr, u8 *data) -{ - struct sunxi_rsb_reg * const rsb = - (struct sunxi_rsb_reg *)SUNXI_RSB_BASE; - int ret; - - writel(RSB_DEVADDR_RUNTIME_ADDR(runtime_device_addr), &rsb->devaddr); - writel(reg_addr, &rsb->addr); - writel(RSB_CMD_BYTE_READ, &rsb->cmd); - - ret = rsb_do_trans(); - if (ret) - return ret; - - *data = readl(&rsb->data) & 0xff; - - return 0; -} diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index 0adf143abfd..66bd6fe2f34 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -583,6 +583,14 @@ config SYS_I2C_SUN6I_P2WI in the Allwinner A31 and A31s SOCs. This interface is used to connect to specific devices like the X-Powers AXP221 PMIC.
+config SYS_I2C_SUN8I_RSB + bool "Allwinner sun8i Reduced Serial Bus controller" + depends on ARCH_SUNXI + help + Support for Allwinner's Reduced Serial Bus (RSB) controller. This + controller is responsible for communicating with various RSB based + devices, such as X-Powers AXPxxx PMICs and AC100/AC200 CODEC ICs. + config SYS_I2C_SYNQUACER bool "Socionext SynQuacer I2C controller" depends on ARCH_SYNQUACER && DM_I2C diff --git a/drivers/i2c/Makefile b/drivers/i2c/Makefile index 0a2cc641930..916427452a5 100644 --- a/drivers/i2c/Makefile +++ b/drivers/i2c/Makefile @@ -44,6 +44,7 @@ obj-$(CONFIG_SYS_I2C_SH) += sh_i2c.o obj-$(CONFIG_SYS_I2C_SOFT) += soft_i2c.o obj-$(CONFIG_SYS_I2C_STM32F7) += stm32f7_i2c.o obj-$(CONFIG_SYS_I2C_SUN6I_P2WI) += sun6i_p2wi.o +obj-$(CONFIG_SYS_I2C_SUN8I_RSB) += sun8i_rsb.o obj-$(CONFIG_SYS_I2C_SYNQUACER) += synquacer_i2c.o obj-$(CONFIG_SYS_I2C_TEGRA) += tegra_i2c.o obj-$(CONFIG_SYS_I2C_UNIPHIER) += i2c-uniphier.o diff --git a/drivers/i2c/sun8i_rsb.c b/drivers/i2c/sun8i_rsb.c new file mode 100644 index 00000000000..716b245a003 --- /dev/null +++ b/drivers/i2c/sun8i_rsb.c @@ -0,0 +1,281 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2014 Hans de Goede hdegoede@redhat.com + * + * Based on allwinner u-boot sources rsb code which is: + * (C) Copyright 2007-2013 + * Allwinner Technology Co., Ltd. <www.allwinnertech.com> + * lixiang lixiang@allwinnertech.com + */ + +#include <axp_pmic.h> +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <i2c.h> +#include <time.h> +#include <asm/arch/cpu.h> +#include <asm/arch/gpio.h> +#include <asm/arch/prcm.h> +#include <asm/arch/rsb.h> + +static int sun8i_rsb_await_trans(struct sunxi_rsb_reg *base) +{ + unsigned long tmo = timer_get_us() + 1000000; + u32 stat; + int ret; + + while (1) { + stat = readl(&base->stat); + if (stat & RSB_STAT_LBSY_INT) { + ret = -EBUSY; + break; + } + if (stat & RSB_STAT_TERR_INT) { + ret = -EIO; + break; + } + if (stat & RSB_STAT_TOVER_INT) { + ret = 0; + break; + } + if (timer_get_us() > tmo) { + ret = -ETIME; + break; + } + } + writel(stat, &base->stat); /* Clear status bits */ + + return ret; +} + +static int sun8i_rsb_do_trans(struct sunxi_rsb_reg *base) +{ + setbits_le32(&base->ctrl, RSB_CTRL_START_TRANS); + + return sun8i_rsb_await_trans(base); +} + +static int sun8i_rsb_read(struct sunxi_rsb_reg *base, u16 runtime_addr, + u8 reg_addr, u8 *data) +{ + int ret; + + writel(RSB_DEVADDR_RUNTIME_ADDR(runtime_addr), &base->devaddr); + writel(reg_addr, &base->addr); + writel(RSB_CMD_BYTE_READ, &base->cmd); + + ret = sun8i_rsb_do_trans(base); + if (ret) + return ret; + + *data = readl(&base->data) & 0xff; + + return 0; +} + +static int sun8i_rsb_write(struct sunxi_rsb_reg *base, u16 runtime_addr, + u8 reg_addr, u8 data) +{ + writel(RSB_DEVADDR_RUNTIME_ADDR(runtime_addr), &base->devaddr); + writel(reg_addr, &base->addr); + writel(data, &base->data); + writel(RSB_CMD_BYTE_WRITE, &base->cmd); + + return sun8i_rsb_do_trans(base); +} + +static int sun8i_rsb_set_device_address(struct sunxi_rsb_reg *base, + u16 device_addr, u16 runtime_addr) +{ + writel(RSB_DEVADDR_RUNTIME_ADDR(runtime_addr) | + RSB_DEVADDR_DEVICE_ADDR(device_addr), &base->devaddr); + writel(RSB_CMD_SET_RTSADDR, &base->cmd); + + return sun8i_rsb_do_trans(base); +} + +static void sun8i_rsb_cfg_io(void) +{ +#ifdef CONFIG_MACH_SUN8I + sunxi_gpio_set_cfgpin(SUNXI_GPL(0), SUN8I_GPL_R_RSB); + sunxi_gpio_set_cfgpin(SUNXI_GPL(1), SUN8I_GPL_R_RSB); + sunxi_gpio_set_pull(SUNXI_GPL(0), 1); + sunxi_gpio_set_pull(SUNXI_GPL(1), 1); + sunxi_gpio_set_drv(SUNXI_GPL(0), 2); + sunxi_gpio_set_drv(SUNXI_GPL(1), 2); +#elif defined CONFIG_MACH_SUN9I + sunxi_gpio_set_cfgpin(SUNXI_GPN(0), SUN9I_GPN_R_RSB); + sunxi_gpio_set_cfgpin(SUNXI_GPN(1), SUN9I_GPN_R_RSB); + sunxi_gpio_set_pull(SUNXI_GPN(0), 1); + sunxi_gpio_set_pull(SUNXI_GPN(1), 1); + sunxi_gpio_set_drv(SUNXI_GPN(0), 2); + sunxi_gpio_set_drv(SUNXI_GPN(1), 2); +#else +#error unsupported MACH_SUNXI +#endif +} + +static void sun8i_rsb_set_clk(struct sunxi_rsb_reg *base) +{ + u32 div = 0; + u32 cd_odly = 0; + + /* Source is Hosc24M, set RSB clk to 3Mhz */ + div = 24000000 / 3000000 / 2 - 1; + cd_odly = div >> 1; + if (!cd_odly) + cd_odly = 1; + + writel((cd_odly << 8) | div, &base->ccr); +} + +static int sun8i_rsb_set_device_mode(struct sunxi_rsb_reg *base) +{ + unsigned long tmo = timer_get_us() + 1000000; + + writel(RSB_DMCR_DEVICE_MODE_START | RSB_DMCR_DEVICE_MODE_DATA, + &base->dmcr); + + while (readl(&base->dmcr) & RSB_DMCR_DEVICE_MODE_START) { + if (timer_get_us() > tmo) + return -ETIME; + } + + return sun8i_rsb_await_trans(base); +} + +static int sun8i_rsb_init(struct sunxi_rsb_reg *base) +{ + /* Enable RSB and PIO clk, and de-assert their resets */ + prcm_apb0_enable(PRCM_APB0_GATE_PIO | PRCM_APB0_GATE_RSB); + + /* Setup external pins */ + sun8i_rsb_cfg_io(); + + writel(RSB_CTRL_SOFT_RST, &base->ctrl); + sun8i_rsb_set_clk(base); + + return sun8i_rsb_set_device_mode(base); +} + +#if IS_ENABLED(CONFIG_AXP_PMIC_BUS) +int rsb_read(const u16 runtime_addr, const u8 reg_addr, u8 *data) +{ + struct sunxi_rsb_reg *base = (struct sunxi_rsb_reg *)SUNXI_RSB_BASE; + + return sun8i_rsb_read(base, runtime_addr, reg_addr, data); +} + +int rsb_write(const u16 runtime_addr, const u8 reg_addr, u8 data) +{ + struct sunxi_rsb_reg *base = (struct sunxi_rsb_reg *)SUNXI_RSB_BASE; + + return sun8i_rsb_write(base, runtime_addr, reg_addr, data); +} + +int rsb_set_device_address(u16 device_addr, u16 runtime_addr) +{ + struct sunxi_rsb_reg *base = (struct sunxi_rsb_reg *)SUNXI_RSB_BASE; + + return sun8i_rsb_set_device_address(base, device_addr, runtime_addr); +} + +int rsb_init(void) +{ + struct sunxi_rsb_reg *base = (struct sunxi_rsb_reg *)SUNXI_RSB_BASE; + + return sun8i_rsb_init(base); +} +#endif + +#if CONFIG_IS_ENABLED(DM_I2C) +struct sun8i_rsb_priv { + struct sunxi_rsb_reg *base; +}; + +/* + * The mapping from hardware address to runtime address is fixed, and shared + * among all RSB drivers. See the comment in drivers/bus/sunxi-rsb.c in Linux. + */ +static int sun8i_rsb_get_runtime_address(u16 device_addr) +{ + if (device_addr == AXP_PMIC_PRI_DEVICE_ADDR) + return AXP_PMIC_PRI_RUNTIME_ADDR; + if (device_addr == AXP_PMIC_SEC_DEVICE_ADDR) + return AXP_PMIC_SEC_RUNTIME_ADDR; + + return -ENXIO; +} + +static int sun8i_rsb_xfer(struct udevice *bus, struct i2c_msg *msg, int nmsgs) +{ + int runtime_addr = sun8i_rsb_get_runtime_address(msg->addr); + struct sun8i_rsb_priv *priv = dev_get_priv(bus); + + if (runtime_addr < 0) + return runtime_addr; + + /* The hardware only supports SMBus-style transfers. */ + if (nmsgs == 2 && msg[1].flags == I2C_M_RD && msg[1].len == 1) + return sun8i_rsb_read(priv->base, runtime_addr, + msg[0].buf[0], &msg[1].buf[0]); + + if (nmsgs == 1 && msg[0].len == 2) + return sun8i_rsb_write(priv->base, runtime_addr, + msg[0].buf[0], msg[0].buf[1]); + + return -EINVAL; +} + +static int sun8i_rsb_probe_chip(struct udevice *bus, uint chip_addr, + uint chip_flags) +{ + int runtime_addr = sun8i_rsb_get_runtime_address(chip_addr); + struct sun8i_rsb_priv *priv = dev_get_priv(bus); + + if (runtime_addr < 0) + return runtime_addr; + + return sun8i_rsb_set_device_address(priv->base, chip_addr, runtime_addr); +} + +static int sun8i_rsb_probe(struct udevice *bus) +{ + struct sun8i_rsb_priv *priv = dev_get_priv(bus); + + priv->base = dev_read_addr_ptr(bus); + + return sun8i_rsb_init(priv->base); +} + +static int sun8i_rsb_child_pre_probe(struct udevice *child) +{ + struct dm_i2c_chip *chip = dev_get_parent_plat(child); + + /* Ensure each transfer is for a single register. */ + chip->flags |= DM_I2C_CHIP_RD_ADDRESS | DM_I2C_CHIP_WR_ADDRESS; + + return 0; +} + +static const struct dm_i2c_ops sun8i_rsb_ops = { + .xfer = sun8i_rsb_xfer, + .probe_chip = sun8i_rsb_probe_chip, +}; + +static const struct udevice_id sun8i_rsb_ids[] = { + { .compatible = "allwinner,sun8i-a23-rsb" }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(sun8i_rsb) = { + .name = "sun8i_rsb", + .id = UCLASS_I2C, + .of_match = sun8i_rsb_ids, + .probe = sun8i_rsb_probe, + .child_pre_probe = sun8i_rsb_child_pre_probe, + .priv_auto = sizeof(struct sun8i_rsb_priv), + .ops = &sun8i_rsb_ops, +}; +#endif /* CONFIG_IS_ENABLED(DM_I2C) */ diff --git a/include/axp_pmic.h b/include/axp_pmic.h index 0db3e143eda..46a017d2efa 100644 --- a/include/axp_pmic.h +++ b/include/axp_pmic.h @@ -30,6 +30,12 @@ #define AXP_PMIC_MODE_REG 0x3e #define AXP_PMIC_MODE_I2C 0x00 #define AXP_PMIC_MODE_P2WI 0x3e +#define AXP_PMIC_MODE_RSB 0x7c + +#define AXP_PMIC_PRI_DEVICE_ADDR 0x3a3 +#define AXP_PMIC_PRI_RUNTIME_ADDR 0x2d +#define AXP_PMIC_SEC_DEVICE_ADDR 0x745 +#define AXP_PMIC_SEC_RUNTIME_ADDR 0x3a
I diff'ed the (slightly tweaked) old version and the new file, and can indeed confirm that it's a conversion that preserves the actual functionality. The new DM wrappers look good as well.
Cheers, Andre
Changes in v2:
-config SUN8I_RSB
- help
- select SUN8I_RSB
- select SPL_I2C select SUNXI_GEN_SUN6I select SUPPORT_SPL
- select SYS_I2C_SUN8I_RSB select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT imply CONS_INDEX_5 if !DM_SERIAL
- select SUN8I_RSB
- select SUN8I_RSB
- select SPL_I2C select SUNXI_GEN_SUN6I select MMC_SUNXI_HAS_NEW_MODE select MMC_SUNXI_HAS_MODE_SWITCH select SUPPORT_SPL
- ret = rsb_set_device_address(AXP_PMIC_PRI_DEVICE_ADDR,
- return rsb_read(AXP_PMIC_PRI_RUNTIME_ADDR, reg, data);
- return rsb_write(AXP_PMIC_PRI_RUNTIME_ADDR, reg, data);
- (C) Copyright 2014 Hans de Goede hdegoede@redhat.com
- Based on allwinner u-boot sources rsb code which is:
- (C) Copyright 2007-2013
- lixiang lixiang@allwinnertech.com
- u32 div = 0;
- u32 cd_odly = 0;
- if (!cd_odly)
cd_odly = 1;
- rsb_cfg_io();
- rsb_set_clk();
- u32 stat;
- int ret;
- while (1) {
ret = -EBUSY;
break;
ret = -EIO;
break;
ret = 0;
break;
ret = -ETIME;
break;
- return ret;
&rsb->dmcr);
return -ETIME;
- int ret;
- if (ret)
return ret;
- bool "Allwinner sun8i Reduced Serial Bus controller"
- help
- u32 stat;
- int ret;
- while (1) {
ret = -EBUSY;
break;
ret = -EIO;
break;
ret = 0;
break;
ret = -ETIME;
break;
- writel(stat, &base->stat); /* Clear status bits */
- return ret;
- setbits_le32(&base->ctrl, RSB_CTRL_START_TRANS);
- return sun8i_rsb_await_trans(base);
- int ret;
- writel(RSB_DEVADDR_RUNTIME_ADDR(runtime_addr), &base->devaddr);
- writel(reg_addr, &base->addr);
- writel(RSB_CMD_BYTE_READ, &base->cmd);
- ret = sun8i_rsb_do_trans(base);
- if (ret)
return ret;
- *data = readl(&base->data) & 0xff;
- writel(data, &base->data);
- writel(RSB_CMD_BYTE_WRITE, &base->cmd);
- return sun8i_rsb_do_trans(base);
- writel(RSB_CMD_SET_RTSADDR, &base->cmd);
- u32 div = 0;
- u32 cd_odly = 0;
- if (!cd_odly)
cd_odly = 1;
- writel((cd_odly << 8) | div, &base->ccr);
&base->dmcr);
- while (readl(&base->dmcr) & RSB_DMCR_DEVICE_MODE_START) {
return -ETIME;
- sun8i_rsb_cfg_io();
- writel(RSB_CTRL_SOFT_RST, &base->ctrl);
- sun8i_rsb_set_clk(base);
- return sun8i_rsb_set_device_mode(base);
- struct sunxi_rsb_reg *base = (struct sunxi_rsb_reg *)SUNXI_RSB_BASE;
- return sun8i_rsb_read(base, runtime_addr, reg_addr, data);
- return sun8i_rsb_write(base, runtime_addr, reg_addr, data);
- return sun8i_rsb_set_device_address(base, device_addr, runtime_addr);
- return sun8i_rsb_init(base);
+} +#endif
- struct sunxi_rsb_reg *base;
- The mapping from hardware address to runtime address is fixed, and shared
- among all RSB drivers. See the comment in drivers/bus/sunxi-rsb.c in Linux.
- if (device_addr == AXP_PMIC_PRI_DEVICE_ADDR)
- if (device_addr == AXP_PMIC_SEC_DEVICE_ADDR)
- return -ENXIO;
- int runtime_addr = sun8i_rsb_get_runtime_address(msg->addr);
- struct sun8i_rsb_priv *priv = dev_get_priv(bus);
- if (runtime_addr < 0)
- return -EINVAL;
uint chip_flags)
- int runtime_addr = sun8i_rsb_get_runtime_address(chip_addr);
- return sun8i_rsb_set_device_address(priv->base, chip_addr, runtime_addr);
- return sun8i_rsb_init(priv->base);
- .xfer = sun8i_rsb_xfer,
- .probe_chip = sun8i_rsb_probe_chip,
- { .compatible = "allwinner,sun8i-a23-rsb" },
- .name = "sun8i_rsb",
- .id = UCLASS_I2C,
- .of_match = sun8i_rsb_ids,
- .probe = sun8i_rsb_probe,
- .child_pre_probe = sun8i_rsb_child_pre_probe,
- .priv_auto = sizeof(struct sun8i_rsb_priv),
- .ops = &sun8i_rsb_ops,
Instead of using the SoC symbols to decide the bus type, use whichever bus driver is actually enabled. This allows collapsing all of the AXP2xx and AXP8xx variants into one "else" case. It also has the advantage of falling back to I2C when the other bus drivers are disabled; this works because all of the PMICs support I2C in addition to other interfaces.
Changes in v2: - Update IS_ENABLEDs in pmic_bus.c to match chages to previous patches
arch/arm/mach-sunxi/pmic_bus.c | 90 +++++++++++++++------------------- 1 file changed, 39 insertions(+), 51 deletions(-)
diff --git a/arch/arm/mach-sunxi/pmic_bus.c b/arch/arm/mach-sunxi/pmic_bus.c index 827797249ea..20ded436cd2 100644 --- a/arch/arm/mach-sunxi/pmic_bus.c +++ b/arch/arm/mach-sunxi/pmic_bus.c @@ -23,75 +23,63 @@
+static int pmic_i2c_address(void) +{ + if (IS_ENABLED(CONFIG_AXP152_POWER)) + return AXP152_I2C_ADDR; + if (IS_ENABLED(CONFIG_AXP305_POWER)) + return AXP305_I2C_ADDR; + + /* Other AXP2xx and AXP8xx variants */ + return AXP209_I2C_ADDR; +} + int pmic_bus_init(void) { /* This cannot be 0 because it is used in SPL before BSS is ready */ static int needs_init = 1; - __maybe_unused int ret; + int ret = 0;
if (!needs_init) return 0;
-#if defined CONFIG_AXP221_POWER || defined CONFIG_AXP809_POWER || defined CONFIG_AXP818_POWER -# ifdef CONFIG_MACH_SUN6I - p2wi_init(); - ret = p2wi_change_to_p2wi_mode(AXP221_CHIP_ADDR, AXP_PMIC_MODE_REG, - AXP_PMIC_MODE_P2WI); -# elif defined CONFIG_MACH_SUN8I_R40 - /* Nothing. R40 uses the AXP221s in I2C mode */ - ret = 0; -# else - ret = rsb_init(); - if (ret) - return ret; + if (IS_ENABLED(CONFIG_SYS_I2C_SUN6I_P2WI)) { + p2wi_init(); + ret = p2wi_change_to_p2wi_mode(AXP221_CHIP_ADDR, + AXP_PMIC_MODE_REG, + AXP_PMIC_MODE_P2WI); + } else if (IS_ENABLED(CONFIG_SYS_I2C_SUN8I_RSB)) { + ret = rsb_init(); + if (ret) + return ret;
- ret = rsb_set_device_address(AXP_PMIC_PRI_DEVICE_ADDR, - AXP_PMIC_PRI_RUNTIME_ADDR); -# endif - if (ret) - return ret; -#endif + ret = rsb_set_device_address(AXP_PMIC_PRI_DEVICE_ADDR, + AXP_PMIC_PRI_RUNTIME_ADDR); + } + + needs_init = ret;
- needs_init = 0; - return 0; + return ret; }
int pmic_bus_read(u8 reg, u8 *data) { -#ifdef CONFIG_AXP152_POWER - return i2c_read(AXP152_I2C_ADDR, reg, 1, data, 1); -#elif defined CONFIG_AXP209_POWER - return i2c_read(AXP209_I2C_ADDR, reg, 1, data, 1); -#elif defined CONFIG_AXP305_POWER - return i2c_read(AXP305_I2C_ADDR, reg, 1, data, 1); -#elif defined CONFIG_AXP221_POWER || defined CONFIG_AXP809_POWER || defined CONFIG_AXP818_POWER -# ifdef CONFIG_MACH_SUN6I - return p2wi_read(reg, data); -# elif defined CONFIG_MACH_SUN8I_R40 - return i2c_read(AXP209_I2C_ADDR, reg, 1, data, 1); -# else - return rsb_read(AXP_PMIC_PRI_RUNTIME_ADDR, reg, data); -# endif -#endif + if (IS_ENABLED(CONFIG_SYS_I2C_SUN6I_P2WI)) + return p2wi_read(reg, data); + if (IS_ENABLED(CONFIG_SYS_I2C_SUN8I_RSB)) + return rsb_read(AXP_PMIC_PRI_RUNTIME_ADDR, reg, data); + + return i2c_read(pmic_i2c_address(), reg, 1, data, 1); }
int pmic_bus_write(u8 reg, u8 data) { -#ifdef CONFIG_AXP152_POWER - return i2c_write(AXP152_I2C_ADDR, reg, 1, &data, 1); -#elif defined CONFIG_AXP209_POWER - return i2c_write(AXP209_I2C_ADDR, reg, 1, &data, 1); -#elif defined CONFIG_AXP305_POWER - return i2c_write(AXP305_I2C_ADDR, reg, 1, &data, 1); -#elif defined CONFIG_AXP221_POWER || defined CONFIG_AXP809_POWER || defined CONFIG_AXP818_POWER -# ifdef CONFIG_MACH_SUN6I - return p2wi_write(reg, data); -# elif defined CONFIG_MACH_SUN8I_R40 - return i2c_write(AXP209_I2C_ADDR, reg, 1, &data, 1); -# else - return rsb_write(AXP_PMIC_PRI_RUNTIME_ADDR, reg, data); -# endif -#endif + if (IS_ENABLED(CONFIG_SYS_I2C_SUN6I_P2WI)) + return p2wi_write(reg, data); + if (IS_ENABLED(CONFIG_SYS_I2C_SUN8I_RSB)) + return rsb_write(AXP_PMIC_PRI_RUNTIME_ADDR, reg, data); + + return i2c_write(pmic_i2c_address(), reg, 1, &data, 1); }
int pmic_bus_setbits(u8 reg, u8 bits)
Many many thanks for cleaning up this #ifdef mess! I couldn't be bothered to double check all variants (did I mention that it's a mess?), but I glanced over it, and it looks alright.
Cheers, Andre
Changes in v2:
- if (IS_ENABLED(CONFIG_AXP152_POWER))
- if (IS_ENABLED(CONFIG_AXP305_POWER))
- /* Other AXP2xx and AXP8xx variants */
- return AXP209_I2C_ADDR;
int ret = 0;
- p2wi_init();
AXP_PMIC_MODE_REG,
- ret = 0;
-# else
- ret = rsb_init();
- if (ret)
return ret;
- if (IS_ENABLED(CONFIG_SYS_I2C_SUN6I_P2WI)) {
p2wi_init();
AXP_PMIC_MODE_REG,
- } else if (IS_ENABLED(CONFIG_SYS_I2C_SUN8I_RSB)) {
ret = rsb_init();
if (ret)
return ret;
-# endif
- if (ret)
return ret;
-#endif
- needs_init = ret;
- needs_init = 0;
- return ret;
-# else
-# endif -#endif
- if (IS_ENABLED(CONFIG_SYS_I2C_SUN8I_RSB))
- return i2c_read(pmic_i2c_address(), reg, 1, data, 1);
-# else
-# endif -#endif
- return i2c_write(pmic_i2c_address(), reg, 1, &data, 1);
The pmic_bus functions are used in both SPL (for regulator setup) and U-Boot proper (for regulator setup, SID access, GPIO, and poweroff).
Currently, pmic_bus conflicts with DM_I2C because it uses the legacy I2C interface. This commit makes pmic_bus dual-compatible with either the legacy I2C functions or the newly-added PMIC_AXP driver (which uses DM_I2C). In turn, this allows platforms to start transitioning to DM_I2C in U-Boot proper, without breaking boards that still depend on the legacy I2C interface for other reasons.
arch/arm/mach-sunxi/Kconfig | 2 ++ arch/arm/mach-sunxi/pmic_bus.c | 19 +++++++++++++++++++ 2 files changed, 21 insertions(+)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index df160c9a775..cfd95b09498 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -96,6 +96,8 @@ config SUN6I_PRCM
config AXP_PMIC_BUS bool + select DM_PMIC if DM_I2C + select PMIC_AXP if DM_I2C help Select this PMIC bus access helpers for Sunxi platform PRCM or other AXP family PMIC devices. diff --git a/arch/arm/mach-sunxi/pmic_bus.c b/arch/arm/mach-sunxi/pmic_bus.c index 20ded436cd2..c0908406370 100644 --- a/arch/arm/mach-sunxi/pmic_bus.c +++ b/arch/arm/mach-sunxi/pmic_bus.c @@ -10,9 +10,11 @@
#include <axp_pmic.h> #include <common.h> +#include <dm.h> #include <asm/arch/p2wi.h> #include <asm/arch/rsb.h> #include <i2c.h> +#include <power/pmic.h> #include <asm/arch/pmic_bus.h>
#define AXP152_I2C_ADDR 0x30 @@ -23,6 +25,9 @@
+#if CONFIG_IS_ENABLED(PMIC_AXP) +static struct udevice *pmic; +#else static int pmic_i2c_address(void) { if (IS_ENABLED(CONFIG_AXP152_POWER)) @@ -33,6 +38,7 @@ static int pmic_i2c_address(void) /* Other AXP2xx and AXP8xx variants */ return AXP209_I2C_ADDR; } +#endif
int pmic_bus_init(void) { @@ -43,6 +49,10 @@ int pmic_bus_init(void) if (!needs_init) return 0;
+#if CONFIG_IS_ENABLED(PMIC_AXP) + ret = uclass_get_device_by_driver(UCLASS_PMIC, DM_DRIVER_GET(axp_pmic), + &pmic); +#else if (IS_ENABLED(CONFIG_SYS_I2C_SUN6I_P2WI)) { p2wi_init(); ret = p2wi_change_to_p2wi_mode(AXP221_CHIP_ADDR, @@ -56,6 +66,7 @@ int pmic_bus_init(void) ret = rsb_set_device_address(AXP_PMIC_PRI_DEVICE_ADDR, AXP_PMIC_PRI_RUNTIME_ADDR); } +#endif
needs_init = ret;
@@ -64,22 +75,30 @@ int pmic_bus_init(void)
int pmic_bus_read(u8 reg, u8 *data) { +#if CONFIG_IS_ENABLED(PMIC_AXP) + return pmic_read(pmic, reg, data, 1); +#else if (IS_ENABLED(CONFIG_SYS_I2C_SUN6I_P2WI)) return p2wi_read(reg, data); if (IS_ENABLED(CONFIG_SYS_I2C_SUN8I_RSB)) return rsb_read(AXP_PMIC_PRI_RUNTIME_ADDR, reg, data);
return i2c_read(pmic_i2c_address(), reg, 1, data, 1); +#endif }
int pmic_bus_write(u8 reg, u8 data) { +#if CONFIG_IS_ENABLED(PMIC_AXP) + return pmic_write(pmic, reg, &data, 1); +#else if (IS_ENABLED(CONFIG_SYS_I2C_SUN6I_P2WI)) return p2wi_write(reg, data); if (IS_ENABLED(CONFIG_SYS_I2C_SUN8I_RSB)) return rsb_write(AXP_PMIC_PRI_RUNTIME_ADDR, reg, data);
return i2c_write(pmic_i2c_address(), reg, 1, &data, 1); +#endif }
Cheers, Andre
Changes in v2:
- No changes
- select DM_PMIC if DM_I2C
- select PMIC_AXP if DM_I2C help Select this PMIC bus access helpers for Sunxi platform PRCM or other AXP family PMIC devices.
- ret = uclass_get_device_by_driver(UCLASS_PMIC, DM_DRIVER_GET(axp_pmic),
&pmic);
needs_init = ret;
- return pmic_read(pmic, reg, data, 1);
- return pmic_write(pmic, reg, &data, 1);
Two displays supported by the sunxi display driver (each one used by a single board) require initialization over I2C. Both previously used i2c_soft; replace this with the i2c-gpio instance that already exists in those boards' device trees (sun5i-a13-utoo-p66 and sun6i-a31-colombus).
Since the i2c-gpio nodes are not referenced by any other node in the device trees (the device trees have no panel node), the I2C bus is selected by its node name.
This panel initialization code was the only i2c_soft user, so the i2c_soft GPIO setup code can be removed now as well.
Reviewed-by: Heiko Schocher hs@denx.de Signed-off-by: Samuel Holland samuel@sholland.org ---
arch/arm/mach-sunxi/Kconfig | 21 ++---- board/sunxi/board.c | 44 +----------- configs/Colombus_defconfig | 6 -- configs/UTOO_P66_defconfig | 3 - drivers/video/anx9804.c | 103 ++++++++++++++-------------- drivers/video/anx9804.h | 5 +- drivers/video/sunxi/sunxi_display.c | 55 ++++++++++----- include/configs/sunxi-common.h | 17 ----- 8 files changed, 100 insertions(+), 154 deletions(-)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index cfd95b09498..99928821673 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -923,27 +923,18 @@ config VIDEO_LCD_BL_PWM_ACTIVE_LOW config VIDEO_LCD_PANEL_I2C bool "LCD panel needs to be configured via i2c" depends on VIDEO_SUNXI - select CMD_I2C + select DM_I2C + select DM_I2C_GPIO ---help--- Say y here if the LCD panel needs to be configured via i2c. This will add a bitbang i2c controller using gpios to talk to the LCD.
-config VIDEO_LCD_PANEL_I2C_SDA - string "LCD panel i2c interface SDA pin" - depends on VIDEO_LCD_PANEL_I2C - default "PG12" - ---help--- - Set the SDA pin for the LCD i2c interface. This takes a string in the - format understood by sunxi_name_to_gpio, e.g. PH1 for pin 1 of port H. - -config VIDEO_LCD_PANEL_I2C_SCL - string "LCD panel i2c interface SCL pin" +config VIDEO_LCD_PANEL_I2C_NAME + string "LCD panel i2c interface node name" depends on VIDEO_LCD_PANEL_I2C - default "PG10" + default "i2c@0" ---help--- - Set the SCL pin for the LCD i2c interface. This takes a string in the - format understood by sunxi_name_to_gpio, e.g. PH1 for pin 1 of port H. - + Set the device tree node name for the LCD i2c interface.
# Note only one of these may be selected at a time! But hidden choices are # not supported by Kconfig diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 2b7d655678d..dabe6734b81 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -47,47 +47,6 @@ #include <sy8106a.h> #include <asm/setup.h>
-#if defined(CONFIG_VIDEO_LCD_PANEL_I2C) -/* So that we can use pin names in Kconfig and sunxi_name_to_gpio() */ -int soft_i2c_gpio_sda; -int soft_i2c_gpio_scl; - -static int soft_i2c_board_init(void) -{ - int ret; - - soft_i2c_gpio_sda = sunxi_name_to_gpio(CONFIG_VIDEO_LCD_PANEL_I2C_SDA); - if (soft_i2c_gpio_sda < 0) { - printf("Error invalid soft i2c sda pin: '%s', err %d\n", - CONFIG_VIDEO_LCD_PANEL_I2C_SDA, soft_i2c_gpio_sda); - return soft_i2c_gpio_sda; - } - ret = gpio_request(soft_i2c_gpio_sda, "soft-i2c-sda"); - if (ret) { - printf("Error requesting soft i2c sda pin: '%s', err %d\n", - CONFIG_VIDEO_LCD_PANEL_I2C_SDA, ret); - return ret; - } - - soft_i2c_gpio_scl = sunxi_name_to_gpio(CONFIG_VIDEO_LCD_PANEL_I2C_SCL); - if (soft_i2c_gpio_scl < 0) { - printf("Error invalid soft i2c scl pin: '%s', err %d\n", - CONFIG_VIDEO_LCD_PANEL_I2C_SCL, soft_i2c_gpio_scl); - return soft_i2c_gpio_scl; - } - ret = gpio_request(soft_i2c_gpio_scl, "soft-i2c-scl"); - if (ret) { - printf("Error requesting soft i2c scl pin: '%s', err %d\n", - CONFIG_VIDEO_LCD_PANEL_I2C_SCL, ret); - return ret; - } - - return 0; -} -#else -static int soft_i2c_board_init(void) { return 0; } -#endif - DECLARE_GLOBAL_DATA_PTR;
void i2c_init_board(void) @@ -312,8 +271,7 @@ int board_init(void) #endif #endif /* CONFIG_DM_MMC */
- /* Uses dm gpio code so do this here and not in i2c_init_board() */ - return soft_i2c_board_init(); + return 0; }
/* diff --git a/configs/Colombus_defconfig b/configs/Colombus_defconfig index 31541f898d4..270bd7d351a 100644 --- a/configs/Colombus_defconfig +++ b/configs/Colombus_defconfig @@ -13,15 +13,9 @@ CONFIG_VIDEO_LCD_DCLK_PHASE=0 CONFIG_VIDEO_LCD_POWER="PH27" CONFIG_VIDEO_LCD_BL_EN="PM1" CONFIG_VIDEO_LCD_BL_PWM="PH13" -CONFIG_VIDEO_LCD_PANEL_I2C_SDA="PA23" -CONFIG_VIDEO_LCD_PANEL_I2C_SCL="PA24" CONFIG_VIDEO_LCD_PANEL_EDP_4_LANE_1620M_VIA_ANX9804=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_I2C_LEGACY=y CONFIG_SPL_SYS_I2C_LEGACY=y -CONFIG_SYS_I2C_SOFT=y -CONFIG_SYS_I2C_SOFT_SPEED=50000 -CONFIG_SYS_I2C_SOFT_SLAVE=0x00 CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 diff --git a/configs/UTOO_P66_defconfig b/configs/UTOO_P66_defconfig index b5728073086..b021b0a8865 100644 --- a/configs/UTOO_P66_defconfig +++ b/configs/UTOO_P66_defconfig @@ -21,9 +21,6 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_TL059WV5C0=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C=y -CONFIG_SYS_I2C_SOFT=y -CONFIG_SYS_I2C_SOFT_SPEED=50000 -CONFIG_SYS_I2C_SOFT_SLAVE=0x00 CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 diff --git a/drivers/video/anx9804.c b/drivers/video/anx9804.c index 3037ff39b41..52b5988ba5f 100644 --- a/drivers/video/anx9804.c +++ b/drivers/video/anx9804.c @@ -21,18 +21,23 @@ * This function will init an anx9804 parallel lcd to dp bridge chip * using the passed in parameters. * - * @i2c_bus: Number of the i2c bus to which the anx9804 is connected. + * @i2c_bus: Device of the i2c bus to which the anx9804 is connected. * @lanes: Number of displayport lanes to use * @data_rate: Register value for the bandwidth reg 0x06: 1.62G, 0x0a: 2.7G * @bpp: Bits per pixel, must be 18 or 24 */ -void anx9804_init(unsigned int i2c_bus, u8 lanes, u8 data_rate, int bpp) +void anx9804_init(struct udevice *i2c_bus, u8 lanes, u8 data_rate, int bpp) { - unsigned int orig_i2c_bus = i2c_get_bus_num(); - u8 c, colordepth; - int i; + struct udevice *chip0, *chip1; + int c, colordepth, i, ret;
- i2c_set_bus_num(i2c_bus); + ret = i2c_get_chip(i2c_bus, 0x38, 1, &chip0); + if (ret) + return; + + ret = i2c_get_chip(i2c_bus, 0x39, 1, &chip1); + if (ret) + return;
if (bpp == 18) colordepth = 0x00; /* 6 bit */ @@ -40,24 +45,23 @@ void anx9804_init(unsigned int i2c_bus, u8 lanes, u8 data_rate, int bpp) colordepth = 0x10; /* 8 bit */
/* Reset */ - i2c_reg_write(0x39, ANX9804_RST_CTRL_REG, 1); + dm_i2c_reg_write(chip1, ANX9804_RST_CTRL_REG, 1); mdelay(100); - i2c_reg_write(0x39, ANX9804_RST_CTRL_REG, 0); + dm_i2c_reg_write(chip1, ANX9804_RST_CTRL_REG, 0);
/* Write 0 to the powerdown reg (powerup everything) */ - i2c_reg_write(0x39, ANX9804_POWERD_CTRL_REG, 0); + dm_i2c_reg_write(chip1, ANX9804_POWERD_CTRL_REG, 0);
- c = i2c_reg_read(0x39, ANX9804_DEV_IDH_REG); + c = dm_i2c_reg_read(chip1, ANX9804_DEV_IDH_REG); if (c != 0x98) { printf("Error anx9804 chipid mismatch\n"); - i2c_set_bus_num(orig_i2c_bus); return; }
for (i = 0; i < 100; i++) { - c = i2c_reg_read(0x38, ANX9804_SYS_CTRL2_REG); - i2c_reg_write(0x38, ANX9804_SYS_CTRL2_REG, c); - c = i2c_reg_read(0x38, ANX9804_SYS_CTRL2_REG); + c = dm_i2c_reg_read(chip0, ANX9804_SYS_CTRL2_REG); + dm_i2c_reg_write(chip0, ANX9804_SYS_CTRL2_REG, c); + c = dm_i2c_reg_read(chip0, ANX9804_SYS_CTRL2_REG); if ((c & ANX9804_SYS_CTRL2_CHA_STA) == 0) break;
@@ -66,51 +70,51 @@ void anx9804_init(unsigned int i2c_bus, u8 lanes, u8 data_rate, int bpp) if (i == 100) printf("Error anx9804 clock is not stable\n");
- i2c_reg_write(0x39, ANX9804_VID_CTRL2_REG, colordepth); + dm_i2c_reg_write(chip1, ANX9804_VID_CTRL2_REG, colordepth);
/* Set a bunch of analog related register values */ - i2c_reg_write(0x38, ANX9804_PLL_CTRL_REG, 0x07); - i2c_reg_write(0x39, ANX9804_PLL_FILTER_CTRL3, 0x19); - i2c_reg_write(0x39, ANX9804_PLL_CTRL3, 0xd9); - i2c_reg_write(0x39, ANX9804_RST_CTRL2_REG, ANX9804_RST_CTRL2_AC_MODE); - i2c_reg_write(0x39, ANX9804_ANALOG_DEBUG_REG1, 0xf0); - i2c_reg_write(0x39, ANX9804_ANALOG_DEBUG_REG3, 0x99); - i2c_reg_write(0x39, ANX9804_PLL_FILTER_CTRL1, 0x7b); - i2c_reg_write(0x38, ANX9804_LINK_DEBUG_REG, 0x30); - i2c_reg_write(0x39, ANX9804_PLL_FILTER_CTRL, 0x06); + dm_i2c_reg_write(chip0, ANX9804_PLL_CTRL_REG, 0x07); + dm_i2c_reg_write(chip1, ANX9804_PLL_FILTER_CTRL3, 0x19); + dm_i2c_reg_write(chip1, ANX9804_PLL_CTRL3, 0xd9); + dm_i2c_reg_write(chip1, ANX9804_RST_CTRL2_REG, ANX9804_RST_CTRL2_AC_MODE); + dm_i2c_reg_write(chip1, ANX9804_ANALOG_DEBUG_REG1, 0xf0); + dm_i2c_reg_write(chip1, ANX9804_ANALOG_DEBUG_REG3, 0x99); + dm_i2c_reg_write(chip1, ANX9804_PLL_FILTER_CTRL1, 0x7b); + dm_i2c_reg_write(chip0, ANX9804_LINK_DEBUG_REG, 0x30); + dm_i2c_reg_write(chip1, ANX9804_PLL_FILTER_CTRL, 0x06);
/* Force HPD */ - i2c_reg_write(0x38, ANX9804_SYS_CTRL3_REG, - ANX9804_SYS_CTRL3_F_HPD | ANX9804_SYS_CTRL3_HPD_CTRL); + dm_i2c_reg_write(chip0, ANX9804_SYS_CTRL3_REG, + ANX9804_SYS_CTRL3_F_HPD | ANX9804_SYS_CTRL3_HPD_CTRL);
/* Power up and configure lanes */ - i2c_reg_write(0x38, ANX9804_ANALOG_POWER_DOWN_REG, 0x00); - i2c_reg_write(0x38, ANX9804_TRAINING_LANE0_SET_REG, 0x00); - i2c_reg_write(0x38, ANX9804_TRAINING_LANE1_SET_REG, 0x00); - i2c_reg_write(0x38, ANX9804_TRAINING_LANE2_SET_REG, 0x00); - i2c_reg_write(0x38, ANX9804_TRAINING_LANE3_SET_REG, 0x00); + dm_i2c_reg_write(chip0, ANX9804_ANALOG_POWER_DOWN_REG, 0x00); + dm_i2c_reg_write(chip0, ANX9804_TRAINING_LANE0_SET_REG, 0x00); + dm_i2c_reg_write(chip0, ANX9804_TRAINING_LANE1_SET_REG, 0x00); + dm_i2c_reg_write(chip0, ANX9804_TRAINING_LANE2_SET_REG, 0x00); + dm_i2c_reg_write(chip0, ANX9804_TRAINING_LANE3_SET_REG, 0x00);
/* Reset AUX CH */ - i2c_reg_write(0x39, ANX9804_RST_CTRL2_REG, - ANX9804_RST_CTRL2_AC_MODE | ANX9804_RST_CTRL2_AUX); - i2c_reg_write(0x39, ANX9804_RST_CTRL2_REG, - ANX9804_RST_CTRL2_AC_MODE); + dm_i2c_reg_write(chip1, ANX9804_RST_CTRL2_REG, + ANX9804_RST_CTRL2_AC_MODE | ANX9804_RST_CTRL2_AUX); + dm_i2c_reg_write(chip1, ANX9804_RST_CTRL2_REG, + ANX9804_RST_CTRL2_AC_MODE);
/* Powerdown audio and some other unused bits */ - i2c_reg_write(0x39, ANX9804_POWERD_CTRL_REG, ANX9804_POWERD_AUDIO); - i2c_reg_write(0x38, ANX9804_HDCP_CONTROL_0_REG, 0x00); - i2c_reg_write(0x38, 0xa7, 0x00); + dm_i2c_reg_write(chip1, ANX9804_POWERD_CTRL_REG, ANX9804_POWERD_AUDIO); + dm_i2c_reg_write(chip0, ANX9804_HDCP_CONTROL_0_REG, 0x00); + dm_i2c_reg_write(chip0, 0xa7, 0x00);
/* Set data-rate / lanes */ - i2c_reg_write(0x38, ANX9804_LINK_BW_SET_REG, data_rate); - i2c_reg_write(0x38, ANX9804_LANE_COUNT_SET_REG, lanes); + dm_i2c_reg_write(chip0, ANX9804_LINK_BW_SET_REG, data_rate); + dm_i2c_reg_write(chip0, ANX9804_LANE_COUNT_SET_REG, lanes);
/* Link training */ - i2c_reg_write(0x38, ANX9804_LINK_TRAINING_CTRL_REG, - ANX9804_LINK_TRAINING_CTRL_EN); + dm_i2c_reg_write(chip0, ANX9804_LINK_TRAINING_CTRL_REG, + ANX9804_LINK_TRAINING_CTRL_EN); mdelay(5); for (i = 0; i < 100; i++) { - c = i2c_reg_read(0x38, ANX9804_LINK_TRAINING_CTRL_REG); + c = dm_i2c_reg_read(chip0, ANX9804_LINK_TRAINING_CTRL_REG); if ((c & 0x01) == 0) break;
@@ -118,17 +122,14 @@ void anx9804_init(unsigned int i2c_bus, u8 lanes, u8 data_rate, int bpp) } if(i == 100) { printf("Error anx9804 link training timeout\n"); - i2c_set_bus_num(orig_i2c_bus); return; }
/* Enable */ - i2c_reg_write(0x39, ANX9804_VID_CTRL1_REG, - ANX9804_VID_CTRL1_VID_EN | ANX9804_VID_CTRL1_EDGE); + dm_i2c_reg_write(chip1, ANX9804_VID_CTRL1_REG, + ANX9804_VID_CTRL1_VID_EN | ANX9804_VID_CTRL1_EDGE); /* Force stream valid */ - i2c_reg_write(0x38, ANX9804_SYS_CTRL3_REG, - ANX9804_SYS_CTRL3_F_HPD | ANX9804_SYS_CTRL3_HPD_CTRL | - ANX9804_SYS_CTRL3_F_VALID | ANX9804_SYS_CTRL3_VALID_CTRL); - - i2c_set_bus_num(orig_i2c_bus); + dm_i2c_reg_write(chip0, ANX9804_SYS_CTRL3_REG, + ANX9804_SYS_CTRL3_F_HPD | ANX9804_SYS_CTRL3_HPD_CTRL | + ANX9804_SYS_CTRL3_F_VALID | ANX9804_SYS_CTRL3_VALID_CTRL); } diff --git a/drivers/video/anx9804.h b/drivers/video/anx9804.h index c0fe3b393b4..ea6c9f2d558 100644 --- a/drivers/video/anx9804.h +++ b/drivers/video/anx9804.h @@ -16,9 +16,10 @@ #define ANX9804_DATA_RATE_2700M 0x0a
#ifdef CONFIG_VIDEO_LCD_PANEL_EDP_4_LANE_1620M_VIA_ANX9804 -void anx9804_init(unsigned int i2c_bus, u8 lanes, u8 data_rate, int bpp); +void anx9804_init(struct udevice *i2c_bus, u8 lanes, u8 data_rate, int bpp); #else -static inline void anx9804_init(unsigned int i2c_bus, u8 lanes, u8 data_rate, +static inline void anx9804_init(struct udevice *i2c_bus, u8 lanes, u8 data_rate, int bpp) {} #endif + #endif diff --git a/drivers/video/sunxi/sunxi_display.c b/drivers/video/sunxi/sunxi_display.c index 4361a58cd7e..6d3914c2aeb 100644 --- a/drivers/video/sunxi/sunxi_display.c +++ b/drivers/video/sunxi/sunxi_display.c @@ -902,6 +902,42 @@ static int sunxi_ssd2828_init(const struct ctfb_res_modes *mode) } #endif /* CONFIG_VIDEO_LCD_SSD2828 */
+#ifdef CONFIG_VIDEO_LCD_PANEL_I2C +static void sunxi_panel_i2c_init(struct sunxi_display_priv *sunxi_display) +{ + const char *name = CONFIG_VIDEO_LCD_PANEL_I2C_NAME; + struct udevice *i2c_bus; + int ret; + + ret = uclass_get_device_by_name(UCLASS_I2C, name, &i2c_bus); + if (ret) + return; + + if (IS_ENABLED(CONFIG_VIDEO_LCD_PANEL_EDP_4_LANE_1620M_VIA_ANX9804)) { + /* + * The anx9804 needs 1.8V from eldo3, we do this here + * and not via CONFIG_AXP_ELDO3_VOLT from board_init() + * to avoid turning this on when using hdmi output. + */ + axp_set_eldo(3, 1800); + anx9804_init(i2c_bus, 4, + ANX9804_DATA_RATE_1620M, + sunxi_display->depth); + } + if (IS_ENABLED(CONFIG_VIDEO_LCD_TL059WV5C0)) { + struct udevice *chip; + + ret = i2c_get_chip(i2c_bus, 0x5c, 1, &chip); + if (ret) + return; + + dm_i2c_reg_write(chip, 0x04, 0x42); /* Turn on the LCD */ + } +} +#else +static void sunxi_panel_i2c_init(struct sunxi_display_priv *sunxi_display) {} +#endif + static void sunxi_engines_init(void) { sunxi_composer_init(); @@ -936,27 +972,12 @@ static void sunxi_mode_set(struct sunxi_display_priv *sunxi_display, break; case sunxi_monitor_lcd: sunxi_lcdc_panel_enable(); - if (IS_ENABLED(CONFIG_VIDEO_LCD_PANEL_EDP_4_LANE_1620M_VIA_ANX9804)) { - /* - * The anx9804 needs 1.8V from eldo3, we do this here - * and not via CONFIG_AXP_ELDO3_VOLT from board_init() - * to avoid turning this on when using hdmi output. - */ - axp_set_eldo(3, 1800); - anx9804_init(CONFIG_VIDEO_LCD_I2C_BUS, 4, - ANX9804_DATA_RATE_1620M, - sunxi_display->depth); - } if (IS_ENABLED(CONFIG_VIDEO_LCD_HITACHI_TX18D42VM)) { mdelay(50); /* Wait for lcd controller power on */ hitachi_tx18d42vm_init(); } - if (IS_ENABLED(CONFIG_VIDEO_LCD_TL059WV5C0)) { - unsigned int orig_i2c_bus = i2c_get_bus_num(); - i2c_set_bus_num(CONFIG_VIDEO_LCD_I2C_BUS); - i2c_reg_write(0x5c, 0x04, 0x42); /* Turn on the LCD */ - i2c_set_bus_num(orig_i2c_bus); - } + if (IS_ENABLED(CONFIG_VIDEO_LCD_PANEL_I2C)) + sunxi_panel_i2c_init(sunxi_display); sunxi_composer_mode_set(mode, address, monitor); sunxi_lcdc_tcon0_mode_set(sunxi_display, mode, false); sunxi_composer_enable(); diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 5d8b6052e4f..c576d65efaf 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -160,23 +160,6 @@ #define CONFIG_SPL_PAD_TO 32768 /* decimal for 'dd' */ #endif
- -/* I2C */ -#if defined(CONFIG_VIDEO_LCD_PANEL_I2C) -/* We use pin names in Kconfig and sunxi_name_to_gpio() */ -#define CONFIG_SOFT_I2C_GPIO_SDA soft_i2c_gpio_sda -#define CONFIG_SOFT_I2C_GPIO_SCL soft_i2c_gpio_scl -#ifndef __ASSEMBLY__ -extern int soft_i2c_gpio_sda; -extern int soft_i2c_gpio_scl; -#endif -#define CONFIG_VIDEO_LCD_I2C_BUS 0 /* The lcd panel soft i2c is bus 0 */ -#define CONFIG_SYS_SPD_BUS_NUM 1 /* And the axp209 i2c bus is bus 1 */ -#else -#define CONFIG_SYS_SPD_BUS_NUM 0 /* The axp209 i2c bus is bus 0 */ -#define CONFIG_VIDEO_LCD_I2C_BUS -1 /* NA, but necessary to compile */ -#endif - /* Ethernet support */
#ifdef CONFIG_USB_EHCI_HCD
Now that the last users of legacy I2C (outside of SPL) have been resolved, we can enable DM_I2C at the sunxi architecture level.
Changes in v2: - No changes
arch/arm/Kconfig | 1 + arch/arm/mach-sunxi/Kconfig | 3 --- 2 files changed, 1 insertion(+), 3 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index ebb19272708..d8c041a8773 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1028,6 +1028,7 @@ config ARCH_SUNXI select DM select DM_ETH select DM_GPIO + select DM_I2C if I2C select DM_KEYBOARD select DM_MMC if MMC select DM_SCSI if SCSI diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 99928821673..9047a88c9da 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -165,7 +165,6 @@ endif
config MACH_SUNXI_H3_H5 bool - select DM_I2C select PHY_SUN4I_USB select SUNXI_DE2 select SUNXI_DRAM_DW @@ -327,7 +326,6 @@ config MACH_SUN50I bool "sun50i (Allwinner A64)" select ARM64 select SPI - select DM_I2C select DM_SPI if SPI select DM_SPI_FLASH select PHY_SUN4I_USB @@ -923,7 +921,6 @@ config VIDEO_LCD_BL_PWM_ACTIVE_LOW config VIDEO_LCD_PANEL_I2C bool "LCD panel needs to be configured via i2c" depends on VIDEO_SUNXI - select DM_I2C select DM_I2C_GPIO ---help--- Say y here if the LCD panel needs to be configured via i2c. This
On Fri, 8 Oct 2021 00:17:13 -0500 Samuel Holland samuel@sholland.org wrote:
Hi Samuel,
This series does the initial work to migrate sunxi boards to DM_I2C. Version 1 of this series bitrotted quite a bit, so there is some reorganization in version 2.
First it takes care of the PMIC:
- Patches 1-2 clean up the PMIC Kconfig, though they are not strictly necessary after 7abf178b, and are independent from the other patches.
- Patch 3 then adds a DM_PMIC driver.
- Patches 4-6 prepare to move the P2WI/RSB bus drivers to drivers/i2c.
- Patches 7-8 move and add DM_I2C versions of those two drivers.
- Patches 9-10 migrate the "pmic_bus" functions to use the DM_I2C bus and DM_PMIC driver when possible.
Then it takes care of the LCD panels:
- Patch 11 converts those drivers to use DM_I2C.
Finally, patch 12 switches all sunxi boards over to DM_I2C.
I have build-tested each commit on all sunxi boards.
I am fine with this, and this removes the deprecation warnings for many older boards, so I applied it to sunxi/master and will send a PR for this. This looks like it has the potential to break boards, but I guess we will never find out without applying it and waiting for bug reports.
Thanks! Andre
There is some remaining work to clean up uses of pmic_bus in U-Boot proper and replace them with DM_PMIC functions:
- drivers/gpio/axp_gpio.c - I have a series for this.
- do_poweroff() in drivers/gpio/axp???.c - I have a series for this.
- axp_get_sid() in drivers/power/axp221.c - Not sure what to do here.
- axp_set_eldo() in drivers/video/sunxi/sunxi_display.c - This will need a DM_REGULATOR driver.
Changes in v2:
- Rebase to pick up 7abf178b ("power: Tidy up #undef of CONFIG_DM_PMIC")
- Replace axp_pmic_bind() with `.bind = dm_scan_fdt_dev`
- New patch to account for I2C Kconfig changes
- Renamed Kconfig symbol to SYS_I2C_SUN6I_P2WI
- Moved entire P2WI driver source to drivers/i2c
Samuel Holland (12): power: pmic: Consistently depend on DM_PMIC power: pmic: Consistently depend on SPL_DM_PMIC power: pmic: Add a driver for X-Powers AXP PMICs sunxi: Only initialize legacy I2C when enabled sunxi: Select SUN8I_RSB more carefully sunxi: pmic_bus: Fix Kconfig dependencies i2c: Add a DM_I2C driver for the sun6i P2WI controller i2c: Add a DM_I2C driver for the sun8i RSB controller sunxi: pmic_bus: Clean up preprocessor conditions sunxi: pmic_bus: Use the DM PMIC interface when possible sunxi: video: Convert panel I2C to use DM_I2C sunxi: Enable DM_I2C for all sunxi boards
arch/arm/Kconfig | 1 + arch/arm/mach-sunxi/Kconfig | 59 ++---- arch/arm/mach-sunxi/Makefile | 2 - arch/arm/mach-sunxi/board.c | 2 +- arch/arm/mach-sunxi/p2wi.c | 117 ------------ arch/arm/mach-sunxi/pmic_bus.c | 109 +++++------ arch/arm/mach-sunxi/rsb.c | 175 ----------------- board/sunxi/board.c | 44 +---- configs/Colombus_defconfig | 6 - configs/UTOO_P66_defconfig | 3 - drivers/i2c/Kconfig | 16 ++ drivers/i2c/Makefile | 2 + drivers/i2c/sun6i_p2wi.c | 220 ++++++++++++++++++++++ drivers/i2c/sun8i_rsb.c | 281 ++++++++++++++++++++++++++++ drivers/power/pmic/Kconfig | 69 ++++--- drivers/power/pmic/Makefile | 1 + drivers/power/pmic/axp.c | 38 ++++ drivers/video/anx9804.c | 103 +++++----- drivers/video/anx9804.h | 5 +- drivers/video/sunxi/sunxi_display.c | 55 ++++-- include/axp_pmic.h | 12 ++ include/configs/sunxi-common.h | 17 -- 22 files changed, 773 insertions(+), 564 deletions(-) delete mode 100644 arch/arm/mach-sunxi/p2wi.c delete mode 100644 arch/arm/mach-sunxi/rsb.c create mode 100644 drivers/i2c/sun6i_p2wi.c create mode 100644 drivers/i2c/sun8i_rsb.c create mode 100644 drivers/power/pmic/axp.c
Andre Przywara
Samuel Holland
