[U-Boot] [PATCH] ARM: am3517_evm: Enable Falcon Mode
The other OMAP3 based Logic PD boards have Falcon Mode enabled, so this patch makes it possible on the AM3517-evm as well.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 7a74e9e90d..9ba518f3d2 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -15,6 +15,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_FS_EXT4 is not set CONFIG_SPL_MTD_SUPPORT=y +CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="AM3517_EVM # " # CONFIG_CMD_IMI is not set CONFIG_CMD_SPL=y diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index eb50012ff7..300f56541e 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -71,6 +71,7 @@ #define CONFIG_SYS_NAND_MAX_ECCPOS 56 #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 +#define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x2a0000 /* NAND block size is 128 KiB. Synchronize these values with * corresponding Device Tree entries in Linux: * MLO(SPL) 4 * NAND_BLOCK_SIZE = 512 KiB @ 0x000000
Adam Ford
