[U-Boot] [PATCH v2 1/7] arm: rmobile: rcar: Move module control register to header file of SoC
Module control registers of R-Car ARM SoC (r8a7790, r8a7791, r8a7793 and r8a7794) are same address. This moves these to header file of SoC.
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- arch/arm/include/asm/arch-rmobile/rcar-base.h | 39 +++++++++++++++++++++++++++ board/renesas/alt/alt.c | 11 -------- board/renesas/gose/gose.c | 8 ------ board/renesas/koelsch/koelsch.c | 8 ------ board/renesas/lager/lager.c | 8 ------ 5 files changed, 39 insertions(+), 35 deletions(-)
diff --git a/arch/arm/include/asm/arch-rmobile/rcar-base.h b/arch/arm/include/asm/arch-rmobile/rcar-base.h index dbbebcf..23c4bba 100644 --- a/arch/arm/include/asm/arch-rmobile/rcar-base.h +++ b/arch/arm/include/asm/arch-rmobile/rcar-base.h @@ -29,6 +29,45 @@ #define SCIF4_BASE 0xE6EE0000 #define SCIF5_BASE 0xE6EE8000
+/* Module stop status register */ +#define MSTPSR0 0xE6150030 +#define MSTPSR1 0xE6150038 +#define MSTPSR2 0xE6150040 +#define MSTPSR3 0xE6150048 +#define MSTPSR4 0xE615004C +#define MSTPSR5 0xE615003C +#define MSTPSR7 0xE61501C4 +#define MSTPSR8 0xE61509A0 +#define MSTPSR9 0xE61509A4 +#define MSTPSR10 0xE61509A8 +#define MSTPSR11 0xE61509AC + +/* Realtime module stop control register */ +#define RMSTPCR0 0xE6150110 +#define RMSTPCR1 0xE6150114 +#define RMSTPCR2 0xE6150118 +#define RMSTPCR3 0xE615011C +#define RMSTPCR4 0xE6150120 +#define RMSTPCR5 0xE6150124 +#define RMSTPCR7 0xE615012C +#define RMSTPCR8 0xE6150980 +#define RMSTPCR9 0xE6150984 +#define RMSTPCR10 0xE6150988 +#define RMSTPCR11 0xE615098C + +/* System module stop control register */ +#define SMSTPCR0 0xE6150130 +#define SMSTPCR1 0xE6150134 +#define SMSTPCR2 0xE6150138 +#define SMSTPCR3 0xE615013C +#define SMSTPCR4 0xE6150140 +#define SMSTPCR5 0xE6150144 +#define SMSTPCR7 0xE615014C +#define SMSTPCR8 0xE6150990 +#define SMSTPCR9 0xE6150994 +#define SMSTPCR10 0xE6150998 +#define SMSTPCR11 0xE615099C + /* * SH-I2C * Ch2 and ch3 are different address. These are defined diff --git a/board/renesas/alt/alt.c b/board/renesas/alt/alt.c index 523c5f1..bf90f2e 100644 --- a/board/renesas/alt/alt.c +++ b/board/renesas/alt/alt.c @@ -37,20 +37,9 @@ void s_init(void) qos_init(); }
-#define MSTPSR1 0xE6150038 -#define SMSTPCR1 0xE6150134 #define TMU0_MSTP125 (1 << 25) - -#define MSTPSR7 0xE61501C4 -#define SMSTPCR7 0xE615014C #define SCIF2_MSTP719 (1 << 19) - -#define MSTPSR8 0xE61509A0 -#define SMSTPCR8 0xE6150990 #define ETHER_MSTP813 (1 << 13) - -#define MSTPSR3 0xE6150048 -#define SMSTPCR3 0xE615013C #define IIC1_MSTP323 (1 << 23)
#define mstp_setbits(type, addr, saddr, set) \ diff --git a/board/renesas/gose/gose.c b/board/renesas/gose/gose.c index 715fba0..bb6849e 100644 --- a/board/renesas/gose/gose.c +++ b/board/renesas/gose/gose.c @@ -41,16 +41,8 @@ void s_init(void) qos_init(); }
-#define MSTPSR1 0xE6150038 -#define SMSTPCR1 0xE6150134 #define TMU0_MSTP125 (1 << 25) - -#define MSTPSR7 0xE61501C4 -#define SMSTPCR7 0xE615014C #define SCIF0_MSTP721 (1 << 21) - -#define MSTPSR8 0xE61509A0 -#define SMSTPCR8 0xE6150990 #define ETHER_MSTP813 (1 << 13)
#define mstp_setbits(type, addr, saddr, set) \ diff --git a/board/renesas/koelsch/koelsch.c b/board/renesas/koelsch/koelsch.c index 244bc58..14d1770 100644 --- a/board/renesas/koelsch/koelsch.c +++ b/board/renesas/koelsch/koelsch.c @@ -43,16 +43,8 @@ void s_init(void) qos_init(); }
#define mstp_setbits(type, addr, saddr, set) \ diff --git a/board/renesas/lager/lager.c b/board/renesas/lager/lager.c index 93273b2..23ef194 100644 --- a/board/renesas/lager/lager.c +++ b/board/renesas/lager/lager.c @@ -50,16 +50,8 @@ void s_init(void) qos_init(); }
Control macro of mstp is common in R-Car ARM SoC (r8a7790, r8a7791, r8a7793 and r8a7794). This moves these to arch-rmobile/rcar-mstp.h
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- arch/arm/include/asm/arch-rmobile/rcar-mstp.h | 22 ++++++++++++++++++++++ board/renesas/alt/alt.c | 10 +--------- board/renesas/gose/gose.c | 10 +--------- board/renesas/koelsch/koelsch.c | 10 +--------- board/renesas/lager/lager.c | 10 +--------- 5 files changed, 26 insertions(+), 36 deletions(-) create mode 100644 arch/arm/include/asm/arch-rmobile/rcar-mstp.h
diff --git a/arch/arm/include/asm/arch-rmobile/rcar-mstp.h b/arch/arm/include/asm/arch-rmobile/rcar-mstp.h new file mode 100644 index 0000000..bf9a2cf --- /dev/null +++ b/arch/arm/include/asm/arch-rmobile/rcar-mstp.h @@ -0,0 +1,22 @@ +/* + * arch/arm/include/asm/arch-rmobile/rcar-mstp.h + * + * Copyright (C) 2013, 2014 Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com + * Copyright (C) 2013, 2014 Renesas Electronics Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef __ASM_ARCH_RCAR_MSTP_H +#define __ASM_ARCH_RCAR_MSTP_H + +#define mstp_setbits(type, addr, saddr, set) \ + out_##type((saddr), in_##type(addr) | (set)) +#define mstp_clrbits(type, addr, saddr, clear) \ + out_##type((saddr), in_##type(addr) & ~(clear)) +#define mstp_setbits_le32(addr, saddr, set) \ + mstp_setbits(le32, addr, saddr, set) +#define mstp_clrbits_le32(addr, saddr, clear) \ + mstp_clrbits(le32, addr, saddr, clear) + +#endif /* __ASM_ARCH_RCAR_MSTP_H */ diff --git a/board/renesas/alt/alt.c b/board/renesas/alt/alt.c index bf90f2e..e3cfe54 100644 --- a/board/renesas/alt/alt.c +++ b/board/renesas/alt/alt.c @@ -15,6 +15,7 @@ #include <asm/arch/sys_proto.h> #include <asm/gpio.h> #include <asm/arch/rmobile.h> +#include <asm/arch/rcar-mstp.h> #include <netdev.h> #include <miiphy.h> #include <i2c.h> @@ -42,15 +43,6 @@ void s_init(void) #define ETHER_MSTP813 (1 << 13) #define IIC1_MSTP323 (1 << 23)
-#define mstp_setbits(type, addr, saddr, set) \ - out_##type((saddr), in_##type(addr) | (set)) -#define mstp_clrbits(type, addr, saddr, clear) \ - out_##type((saddr), in_##type(addr) & ~(clear)) -#define mstp_setbits_le32(addr, saddr, set) \ - mstp_setbits(le32, addr, saddr, set) -#define mstp_clrbits_le32(addr, saddr, clear) \ - mstp_clrbits(le32, addr, saddr, clear) - int board_early_init_f(void) { /* TMU */ diff --git a/board/renesas/gose/gose.c b/board/renesas/gose/gose.c index bb6849e..0b2d904 100644 --- a/board/renesas/gose/gose.c +++ b/board/renesas/gose/gose.c @@ -15,6 +15,7 @@ #include <asm/arch/sys_proto.h> #include <asm/gpio.h> #include <asm/arch/rmobile.h> +#include <asm/arch/rcar-mstp.h> #include <netdev.h> #include <miiphy.h> #include <i2c.h> @@ -45,15 +46,6 @@ void s_init(void) #define SCIF0_MSTP721 (1 << 21) #define ETHER_MSTP813 (1 << 13)
-#define mstp_setbits(type, addr, saddr, set) \ - out_##type((saddr), in_##type(addr) | (set)) -#define mstp_clrbits(type, addr, saddr, clear) \ - out_##type((saddr), in_##type(addr) & ~(clear)) -#define mstp_setbits_le32(addr, saddr, set) \ - mstp_setbits(le32, addr, saddr, set) -#define mstp_clrbits_le32(addr, saddr, clear) \ - mstp_clrbits(le32, addr, saddr, clear) - int board_early_init_f(void) { /* TMU0 */ diff --git a/board/renesas/koelsch/koelsch.c b/board/renesas/koelsch/koelsch.c index 14d1770..5ebbfcf 100644 --- a/board/renesas/koelsch/koelsch.c +++ b/board/renesas/koelsch/koelsch.c @@ -16,6 +16,7 @@ #include <asm/arch/sys_proto.h> #include <asm/gpio.h> #include <asm/arch/rmobile.h> +#include <asm/arch/rcar-mstp.h> #include <netdev.h> #include <miiphy.h> #include <i2c.h> @@ -47,15 +48,6 @@ void s_init(void) #define SCIF0_MSTP721 (1 << 21) #define ETHER_MSTP813 (1 << 13)
-#define mstp_setbits(type, addr, saddr, set) \ - out_##type((saddr), in_##type(addr) | (set)) -#define mstp_clrbits(type, addr, saddr, clear) \ - out_##type((saddr), in_##type(addr) & ~(clear)) -#define mstp_setbits_le32(addr, saddr, set) \ - mstp_setbits(le32, addr, saddr, set) -#define mstp_clrbits_le32(addr, saddr, clear) \ - mstp_clrbits(le32, addr, saddr, clear) - int board_early_init_f(void) { mstp_clrbits_le32(MSTPSR1, SMSTPCR1, TMU0_MSTP125); diff --git a/board/renesas/lager/lager.c b/board/renesas/lager/lager.c index 23ef194..47cf51b 100644 --- a/board/renesas/lager/lager.c +++ b/board/renesas/lager/lager.c @@ -18,6 +18,7 @@ #include <asm/arch/sys_proto.h> #include <asm/gpio.h> #include <asm/arch/rmobile.h> +#include <asm/arch/rcar-mstp.h> #include <miiphy.h> #include <i2c.h> #include "qos.h" @@ -54,15 +55,6 @@ void s_init(void) #define SCIF0_MSTP721 (1 << 21) #define ETHER_MSTP813 (1 << 13)
The arch_preboot_os function used in boards using R-Car ARM SoC (r8a7790, r8a7791, r8a7793 and r8a7794) is common. This makes rcar-gen2-common/common.c file providing common function for R-Car ARM SoC, and moves this function to this file.
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- board/renesas/alt/Makefile | 2 +- board/renesas/alt/alt.c | 6 ------ board/renesas/gose/Makefile | 2 +- board/renesas/gose/gose.c | 10 ---------- board/renesas/koelsch/Makefile | 2 +- board/renesas/koelsch/koelsch.c | 6 ------ board/renesas/lager/Makefile | 2 +- board/renesas/lager/lager.c | 6 ------ board/renesas/rcar-gen2-common/common.c | 27 +++++++++++++++++++++++++++ 9 files changed, 31 insertions(+), 32 deletions(-) create mode 100644 board/renesas/rcar-gen2-common/common.c
diff --git a/board/renesas/alt/Makefile b/board/renesas/alt/Makefile index 9ed12bd..6904e39 100644 --- a/board/renesas/alt/Makefile +++ b/board/renesas/alt/Makefile @@ -6,4 +6,4 @@ # SPDX-License-Identifier: GPL-2.0 #
-obj-y := alt.o qos.o +obj-y := alt.o qos.o ../rcar-gen2-common/common.o diff --git a/board/renesas/alt/alt.c b/board/renesas/alt/alt.c index e3cfe54..c794d43 100644 --- a/board/renesas/alt/alt.c +++ b/board/renesas/alt/alt.c @@ -60,12 +60,6 @@ int board_early_init_f(void) return 0; }
-void arch_preboot_os(void) -{ - /* Disable TMU0 */ - mstp_setbits_le32(MSTPSR1, SMSTPCR1, TMU0_MSTP125); -} - int board_init(void) { /* adress of boot parameters */ diff --git a/board/renesas/gose/Makefile b/board/renesas/gose/Makefile index a4fb6cc..2dac748 100644 --- a/board/renesas/gose/Makefile +++ b/board/renesas/gose/Makefile @@ -6,4 +6,4 @@ # SPDX-License-Identifier: GPL-2.0 #
-obj-y := gose.o qos.o +obj-y := gose.o qos.o ../rcar-gen2-common/common.o diff --git a/board/renesas/gose/gose.c b/board/renesas/gose/gose.c index 0b2d904..677b976 100644 --- a/board/renesas/gose/gose.c +++ b/board/renesas/gose/gose.c @@ -60,16 +60,6 @@ int board_early_init_f(void) return 0; }
-#define TSTR0 0x04 -#define TSTR0_STR0 0x01 -void arch_preboot_os(void) -{ - /* stop TMU0 */ - mstp_clrbits_le32(TMU_BASE + TSTR0, TMU_BASE + TSTR0, TSTR0_STR0); - /* Disable TMU0 */ - mstp_setbits_le32(MSTPSR1, SMSTPCR1, TMU0_MSTP125); -} - #define PUPR5 0xE6060114 #define PUPR5_ETH 0x3FFC0000 #define PUPR5_ETH_MAGIC (1 << 27) diff --git a/board/renesas/koelsch/Makefile b/board/renesas/koelsch/Makefile index b4d0183..c10bba5 100644 --- a/board/renesas/koelsch/Makefile +++ b/board/renesas/koelsch/Makefile @@ -6,4 +6,4 @@ # SPDX-License-Identifier: GPL-2.0 #
-obj-y := koelsch.o qos.o +obj-y := koelsch.o qos.o ../rcar-gen2-common/common.o diff --git a/board/renesas/koelsch/koelsch.c b/board/renesas/koelsch/koelsch.c index 5ebbfcf..10fa571 100644 --- a/board/renesas/koelsch/koelsch.c +++ b/board/renesas/koelsch/koelsch.c @@ -61,12 +61,6 @@ int board_early_init_f(void) return 0; }
-void arch_preboot_os(void) -{ - /* Disable TMU0 */ - mstp_setbits_le32(MSTPSR1, SMSTPCR1, TMU0_MSTP125); -} - /* LSI pin pull-up control */ #define PUPR5 0xe6060114 #define PUPR5_ETH 0x3FFC0000 diff --git a/board/renesas/lager/Makefile b/board/renesas/lager/Makefile index 034c6f8..8d03461 100644 --- a/board/renesas/lager/Makefile +++ b/board/renesas/lager/Makefile @@ -6,4 +6,4 @@ # SPDX-License-Identifier: GPL-2.0 #
-obj-y := lager.o qos.o +obj-y := lager.o qos.o ../rcar-gen2-common/common.o diff --git a/board/renesas/lager/lager.c b/board/renesas/lager/lager.c index 47cf51b..4afb1ac 100644 --- a/board/renesas/lager/lager.c +++ b/board/renesas/lager/lager.c @@ -67,12 +67,6 @@ int board_early_init_f(void) return 0; }
-void arch_preboot_os(void) -{ - /* Disable TMU0 */ - mstp_setbits_le32(MSTPSR1, SMSTPCR1, TMU0_MSTP125); -} - DECLARE_GLOBAL_DATA_PTR; int board_init(void) { diff --git a/board/renesas/rcar-gen2-common/common.c b/board/renesas/rcar-gen2-common/common.c new file mode 100644 index 0000000..23010ee --- /dev/null +++ b/board/renesas/rcar-gen2-common/common.c @@ -0,0 +1,27 @@ +/* + * board/renesas/rcar-gen2-common/common.c + * + * Copyright (C) 2013 Renesas Electronics Corporation + * Copyright (C) 2013 Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/rmobile.h> +#include <asm/arch/rcar-mstp.h> + +#define TSTR0 0x04 +#define TSTR0_STR0 0x01 + +#define TMU0_MSTP125 (1 << 25) +void arch_preboot_os(void) +{ + /* stop TMU0 */ + mstp_clrbits_le32(TMU_BASE + TSTR0, TMU_BASE + TSTR0, TSTR0_STR0); + + /* Disable TMU0 */ + mstp_setbits_le32(MSTPSR1, SMSTPCR1, TMU0_MSTP125); +}
This addes macro for set and clear bit control for module control register. This is used when user want to disable the function of the devices corresponding to register.
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- arch/arm/include/asm/arch-rmobile/rcar-mstp.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/include/asm/arch-rmobile/rcar-mstp.h b/arch/arm/include/asm/arch-rmobile/rcar-mstp.h index bf9a2cf..c3df11f 100644 --- a/arch/arm/include/asm/arch-rmobile/rcar-mstp.h +++ b/arch/arm/include/asm/arch-rmobile/rcar-mstp.h @@ -14,9 +14,13 @@ out_##type((saddr), in_##type(addr) | (set)) #define mstp_clrbits(type, addr, saddr, clear) \ out_##type((saddr), in_##type(addr) & ~(clear)) +#define mstp_setclrbits(type, addr, set, clear) \ + out_##type((addr), (in_##type(addr) | (set)) & ~(clear)) #define mstp_setbits_le32(addr, saddr, set) \ mstp_setbits(le32, addr, saddr, set) #define mstp_clrbits_le32(addr, saddr, clear) \ mstp_clrbits(le32, addr, saddr, clear) +#define mstp_setclrbits_le32(addr, set, clear) \ + mstp_setclrbits(le32, addr, set, clear)
This adds infomation of bits for module control register. This is used to control modules on ARM R-Car SoCs.
Signed-off-by: Hisashi Nakamura hisashi.nakamura.ak@renesas.com Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- arch/arm/include/asm/arch-rmobile/r8a7790.h | 13 +++++++++++++ arch/arm/include/asm/arch-rmobile/r8a7791.h | 13 +++++++++++++ arch/arm/include/asm/arch-rmobile/r8a7793.h | 14 ++++++++++++++ arch/arm/include/asm/arch-rmobile/r8a7794.h | 13 +++++++++++++ 4 files changed, 53 insertions(+)
diff --git a/arch/arm/include/asm/arch-rmobile/r8a7790.h b/arch/arm/include/asm/arch-rmobile/r8a7790.h index de14869..132d58c 100644 --- a/arch/arm/include/asm/arch-rmobile/r8a7790.h +++ b/arch/arm/include/asm/arch-rmobile/r8a7790.h @@ -15,6 +15,19 @@ #define CONFIG_SYS_I2C_SH_BASE2 0xE6520000 #define CONFIG_SYS_I2C_SH_BASE3 0xE60B0000
+/* Module stop control/status register bits */ +#define MSTP0_BITS 0x00640801 +#define MSTP1_BITS 0xDB6E9BDF +#define MSTP2_BITS 0x300DA1FC +#define MSTP3_BITS 0xF08CF831 +#define MSTP4_BITS 0x80000184 +#define MSTP5_BITS 0x44C00046 +#define MSTP7_BITS 0x07F30718 +#define MSTP8_BITS 0x01F0FF84 +#define MSTP9_BITS 0xF5979FCF +#define MSTP10_BITS 0xFFFEFFE0 +#define MSTP11_BITS 0x00000000 + #define R8A7790_CUT_ES2X 2 #define IS_R8A7790_ES2() \ (rmobile_get_cpu_rev_integer() == R8A7790_CUT_ES2X) diff --git a/arch/arm/include/asm/arch-rmobile/r8a7791.h b/arch/arm/include/asm/arch-rmobile/r8a7791.h index 26a0bd5..d2cbcd7 100644 --- a/arch/arm/include/asm/arch-rmobile/r8a7791.h +++ b/arch/arm/include/asm/arch-rmobile/r8a7791.h @@ -51,6 +51,19 @@ #define DBSC3_1_QOS_W15_BASE 0xE67A2F00 #define DBSC3_1_DBADJ2 0xE67A00C8
+/* Module stop control/status register bits */ +#define MSTP0_BITS 0x00640801 +#define MSTP1_BITS 0x9B6C9B5A +#define MSTP2_BITS 0x100D21FC +#define MSTP3_BITS 0xF08CD810 +#define MSTP4_BITS 0x800001C4 +#define MSTP5_BITS 0x44C00046 +#define MSTP7_BITS 0x05BFE618 +#define MSTP8_BITS 0x40C0FE85 +#define MSTP9_BITS 0xFF979FFF +#define MSTP10_BITS 0xFFFEFFE0 +#define MSTP11_BITS 0x000001C0 + #define R8A7791_CUT_ES2X 2 #define IS_R8A7791_ES2() \ (rmobile_get_cpu_rev_integer() == R8A7791_CUT_ES2X) diff --git a/arch/arm/include/asm/arch-rmobile/r8a7793.h b/arch/arm/include/asm/arch-rmobile/r8a7793.h index 778812e..1abdeb7 100644 --- a/arch/arm/include/asm/arch-rmobile/r8a7793.h +++ b/arch/arm/include/asm/arch-rmobile/r8a7793.h @@ -56,6 +56,20 @@ /* * R8A7793 I/O Product Information */ + +/* Module stop control/status register bits */ +#define MSTP0_BITS 0x00640801 +#define MSTP1_BITS 0x9B6C9B5A +#define MSTP2_BITS 0x100D21FC +#define MSTP3_BITS 0xF08CD810 +#define MSTP4_BITS 0x800001C4 +#define MSTP5_BITS 0x44C00046 +#define MSTP7_BITS 0x05BFE618 +#define MSTP8_BITS 0x40C0FE85 +#define MSTP9_BITS 0xFF979FFF +#define MSTP10_BITS 0xFFFEFFE0 +#define MSTP11_BITS 0x000001C0 + #define R8A7793_CUT_ES2X 2 #define IS_R8A7793_ES2() \ (rmobile_get_cpu_rev_integer() == R8A7793_CUT_ES2X) diff --git a/arch/arm/include/asm/arch-rmobile/r8a7794.h b/arch/arm/include/asm/arch-rmobile/r8a7794.h index 66d5a29..d7c9004 100644 --- a/arch/arm/include/asm/arch-rmobile/r8a7794.h +++ b/arch/arm/include/asm/arch-rmobile/r8a7794.h @@ -14,4 +14,17 @@ /* SH-I2C */ #define CONFIG_SYS_I2C_SH_BASE2 0xE60B0000
+/* Module stop control/status register bits */ +#define MSTP0_BITS 0x00440801 +#define MSTP1_BITS 0x936899DA +#define MSTP2_BITS 0x100D21FC +#define MSTP3_BITS 0xE084D810 +#define MSTP4_BITS 0x800001C4 +#define MSTP5_BITS 0x40C00044 +#define MSTP7_BITS 0x013FE618 +#define MSTP8_BITS 0x40803C05 +#define MSTP9_BITS 0xFB879FEE +#define MSTP10_BITS 0xFFFEFFE0 +#define MSTP11_BITS 0x000001C0 + #endif /* __ASM_ARCH_R8A7794_H */
The infomation of module control register for R-Car ARM SoC (r8a7790, r8a7791, r8a7793 and r8a7794) are almost the same, they can be combined into one structure. This provides structure that summarizes infomation of module control register and default register values. And this structure is the module control use of the kernel at boot time.
Signed-off-by: Hisashi Nakamura hisashi.nakamura.ak@renesas.com Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- arch/arm/include/asm/arch-rmobile/rcar-mstp.h | 83 +++++++++++++++++++++++++++ 1 file changed, 83 insertions(+)
diff --git a/arch/arm/include/asm/arch-rmobile/rcar-mstp.h b/arch/arm/include/asm/arch-rmobile/rcar-mstp.h index c3df11f..9a564f8 100644 --- a/arch/arm/include/asm/arch-rmobile/rcar-mstp.h +++ b/arch/arm/include/asm/arch-rmobile/rcar-mstp.h @@ -23,4 +23,87 @@ #define mstp_setclrbits_le32(addr, set, clear) \ mstp_setclrbits(le32, addr, set, clear)
+#ifndef CONFIG_SMSTP0_ENA +#define CONFIG_SMSTP0_ENA 0x00 +#endif +#ifndef CONFIG_SMSTP1_ENA +#define CONFIG_SMSTP1_ENA 0x00 +#endif +#ifndef CONFIG_SMSTP2_ENA +#define CONFIG_SMSTP2_ENA 0x00 +#endif +#ifndef CONFIG_SMSTP3_ENA +#define CONFIG_SMSTP3_ENA 0x00 +#endif +#ifndef CONFIG_SMSTP4_ENA +#define CONFIG_SMSTP4_ENA 0x00 +#endif +#ifndef CONFIG_SMSTP5_ENA +#define CONFIG_SMSTP5_ENA 0x00 +#endif +#ifndef CONFIG_SMSTP6_ENA +#define CONFIG_SMSTP6_ENA 0x00 +#endif +#ifndef CONFIG_SMSTP7_ENA +#define CONFIG_SMSTP7_ENA 0x00 +#endif +#ifndef CONFIG_SMSTP8_ENA +#define CONFIG_SMSTP8_ENA 0x00 +#endif +#ifndef CONFIG_SMSTP9_ENA +#define CONFIG_SMSTP9_ENA 0x00 +#endif +#ifndef CONFIG_SMSTP10_ENA +#define CONFIG_SMSTP10_ENA 0x00 +#endif +#ifndef CONFIG_SMSTP11_ENA +#define CONFIG_SMSTP11_ENA 0x00 +#endif + +#ifndef CONFIG_RMSTP0_ENA +#define CONFIG_RMSTP0_ENA 0x00 +#endif +#ifndef CONFIG_RMSTP1_ENA +#define CONFIG_RMSTP1_ENA 0x00 +#endif +#ifndef CONFIG_RMSTP2_ENA +#define CONFIG_RMSTP2_ENA 0x00 +#endif +#ifndef CONFIG_RMSTP3_ENA +#define CONFIG_RMSTP3_ENA 0x00 +#endif +#ifndef CONFIG_RMSTP4_ENA +#define CONFIG_RMSTP4_ENA 0x00 +#endif +#ifndef CONFIG_RMSTP5_ENA +#define CONFIG_RMSTP5_ENA 0x00 +#endif +#ifndef CONFIG_RMSTP6_ENA +#define CONFIG_RMSTP6_ENA 0x00 +#endif +#ifndef CONFIG_RMSTP7_ENA +#define CONFIG_RMSTP7_ENA 0x00 +#endif +#ifndef CONFIG_RMSTP8_ENA +#define CONFIG_RMSTP8_ENA 0x00 +#endif +#ifndef CONFIG_RMSTP9_ENA +#define CONFIG_RMSTP9_ENA 0x00 +#endif +#ifndef CONFIG_RMSTP10_ENA +#define CONFIG_RMSTP10_ENA 0x00 +#endif +#ifndef CONFIG_RMSTP11_ENA +#define CONFIG_RMSTP11_ENA 0x00 +#endif + +struct mstp_ctl { + u32 s_addr; + u32 s_dis; + u32 s_ena; + u32 r_addr; + u32 r_dis; + u32 r_ena; +}; + #endif /* __ASM_ARCH_RCAR_MSTP_H */
This stops clock except INTC-RT, MSIF, INTC-SYS, IRQC and SCIF before kernel boots.
Signed-off-by: Hisashi Nakamura hisashi.nakamura.ak@renesas.com Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- board/renesas/rcar-gen2-common/common.c | 38 ++++++++++++++++++++++++++++++--- include/configs/alt.h | 10 +++++++++ include/configs/gose.h | 10 +++++++++ include/configs/koelsch.h | 11 ++++++++++ include/configs/lager.h | 10 +++++++++ 5 files changed, 76 insertions(+), 3 deletions(-)
diff --git a/board/renesas/rcar-gen2-common/common.c b/board/renesas/rcar-gen2-common/common.c index 23010ee..0103f42 100644 --- a/board/renesas/rcar-gen2-common/common.c +++ b/board/renesas/rcar-gen2-common/common.c @@ -16,12 +16,44 @@ #define TSTR0 0x04 #define TSTR0_STR0 0x01
-#define TMU0_MSTP125 (1 << 25) +static struct mstp_ctl mstptbl[] = { + { SMSTPCR0, MSTP0_BITS, CONFIG_SMSTP0_ENA, + RMSTPCR0, MSTP0_BITS, CONFIG_RMSTP0_ENA }, + { SMSTPCR1, MSTP1_BITS, CONFIG_SMSTP1_ENA, + RMSTPCR1, MSTP1_BITS, CONFIG_RMSTP1_ENA }, + { SMSTPCR2, MSTP2_BITS, CONFIG_SMSTP2_ENA, + RMSTPCR2, MSTP2_BITS, CONFIG_RMSTP2_ENA }, + { SMSTPCR3, MSTP3_BITS, CONFIG_SMSTP3_ENA, + RMSTPCR3, MSTP3_BITS, CONFIG_RMSTP3_ENA }, + { SMSTPCR4, MSTP4_BITS, CONFIG_SMSTP4_ENA, + RMSTPCR4, MSTP4_BITS, CONFIG_RMSTP4_ENA }, + { SMSTPCR5, MSTP5_BITS, CONFIG_SMSTP5_ENA, + RMSTPCR5, MSTP5_BITS, CONFIG_RMSTP5_ENA }, + /* No MSTP6 */ + { SMSTPCR7, MSTP7_BITS, CONFIG_SMSTP7_ENA, + RMSTPCR7, MSTP7_BITS, CONFIG_RMSTP7_ENA }, + { SMSTPCR8, MSTP8_BITS, CONFIG_SMSTP8_ENA, + RMSTPCR8, MSTP8_BITS, CONFIG_RMSTP8_ENA }, + { SMSTPCR9, MSTP9_BITS, CONFIG_SMSTP9_ENA, + RMSTPCR9, MSTP9_BITS, CONFIG_RMSTP9_ENA }, + { SMSTPCR10, MSTP10_BITS, CONFIG_SMSTP10_ENA, + RMSTPCR10, MSTP10_BITS, CONFIG_RMSTP10_ENA }, + { SMSTPCR11, MSTP11_BITS, CONFIG_SMSTP1_ENA, + RMSTPCR11, MSTP11_BITS, CONFIG_RMSTP11_ENA }, +}; + void arch_preboot_os(void) { + int i; + /* stop TMU0 */ mstp_clrbits_le32(TMU_BASE + TSTR0, TMU_BASE + TSTR0, TSTR0_STR0);
- /* Disable TMU0 */ - mstp_setbits_le32(MSTPSR1, SMSTPCR1, TMU0_MSTP125); + /* Stop module clock */ + for (i = 0; i < ARRAY_SIZE(mstptbl); i++) { + mstp_setclrbits_le32(mstptbl[i].s_addr, mstptbl[i].s_dis, + mstptbl[i].s_ena); + mstp_setclrbits_le32(mstptbl[i].r_addr, mstptbl[i].r_dis, + mstptbl[i].r_ena); + } } diff --git a/include/configs/alt.h b/include/configs/alt.h index cd60d07..a0ed608 100644 --- a/include/configs/alt.h +++ b/include/configs/alt.h @@ -92,4 +92,14 @@ #define CONFIG_USB_EHCI_RMOBILE #define CONFIG_USB_MAX_CONTROLLER_COUNT 2
+/* Module stop status bits */ +/* INTC-RT */ +#define CONFIG_SMSTP0_ENA 0x00400000 +/* MSIF */ +#define CONFIG_SMSTP2_ENA 0x00002000 +/* INTC-SYS, IRQC */ +#define CONFIG_SMSTP4_ENA 0x00000180 +/* SCIF2 */ +#define CONFIG_SMSTP7_ENA 0x00080000 + #endif /* __ALT_H */ diff --git a/include/configs/gose.h b/include/configs/gose.h index 77f4fd0..df9d63f 100644 --- a/include/configs/gose.h +++ b/include/configs/gose.h @@ -88,4 +88,14 @@ #define CONFIG_USB_EHCI_RMOBILE #define CONFIG_USB_MAX_CONTROLLER_COUNT 2
+/* Module stop status bits */ +/* INTC-RT */ +#define CONFIG_SMSTP0_ENA 0x00400000 +/* MSIF */ +#define CONFIG_SMSTP2_ENA 0x00002000 +/* INTC-SYS, IRQC */ +#define CONFIG_SMSTP4_ENA 0x00000180 +/* SCIF0 */ +#define CONFIG_SMSTP7_ENA 0x00200000 + #endif /* __GOSE_H */ diff --git a/include/configs/koelsch.h b/include/configs/koelsch.h index b6fb1dc..97c2321 100644 --- a/include/configs/koelsch.h +++ b/include/configs/koelsch.h @@ -89,4 +89,15 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_USB_STORAGE
+ +/* Module stop status bits */ +/* INTC-RT */ +#define CONFIG_SMSTP0_ENA 0x00400000 +/* MSIF*/ +#define CONFIG_SMSTP2_ENA 0x00002000 +/* INTC-SYS, IRQC */ +#define CONFIG_SMSTP4_ENA 0x00000180 +/* SCIF0 */ +#define CONFIG_SMSTP7_ENA 0x00200000 + #endif /* __KOELSCH_H */ diff --git a/include/configs/lager.h b/include/configs/lager.h index 37be38f..9c89b16 100644 --- a/include/configs/lager.h +++ b/include/configs/lager.h @@ -93,4 +93,14 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 3 #define CONFIG_USB_STORAGE
+/* Module stop status bits */ +/* INTC-RT */ +#define CONFIG_SMSTP0_ENA 0x00400000 +/* MSIF */ +#define CONFIG_SMSTP2_ENA 0x00002000 +/* INTC-SYS, IRQC */ +#define CONFIG_SMSTP4_ENA 0x00000180 +/* SCIF0 */ +#define CONFIG_SMSTP7_ENA 0x00200000 + #endif /* __LAGER_H */
Nobuhiro Iwamatsu
