[PATCH] armv8: layerscape: use memalign() to allocate spintable code
Don't use efi_allocate_pages(). The allocated memory isn't carved out of the lmb allocations. The memory might then be allocated twice. Particulary, this might happened with the fdt_high/initrd_high feature which will relocate the fdt/ramdisk. This might then overlap with the spin table.
Instead use memalign() which allocates on memory on the heap which is correctly carved out by lmb.
Please note, that the memory is later reserved in the device tree as well as in the EFI memory map in ft_fixup_cpu() (in arch/arm/cpu/armv8/fsl-layerscape/fdt.c).
Signed-off-by: Michael Walle michael@walle.cc --- arch/arm/cpu/armv8/fsl-layerscape/mp.c | 29 +++++++++++++------------- 1 file changed, 14 insertions(+), 15 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/mp.c b/arch/arm/cpu/armv8/fsl-layerscape/mp.c index 730d7663d0..d28ab26533 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/mp.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/mp.c @@ -14,11 +14,12 @@ #include <asm/system.h> #include <asm/arch/mp.h> #include <asm/arch/soc.h> +#include <linux/compat.h> #include <linux/delay.h> #include <linux/psci.h> +#include <malloc.h> #include "cpu.h" #include <asm/arch-fsl-layerscape/soc.h> -#include <efi_loader.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -83,8 +84,7 @@ int fsl_layerscape_wake_seconday_cores(void) int i, timeout = 10; u64 *table; #ifdef CONFIG_EFI_LOADER - u64 reloc_addr = U32_MAX; - efi_status_t ret; + void *reloc_addr; #endif
#ifdef COUNTER_FREQUENCY_REAL @@ -102,27 +102,26 @@ int fsl_layerscape_wake_seconday_cores(void) * Keep this after the __real_cntfrq update, so we have it when we * copy the complete section here. */ - ret = efi_allocate_pages(EFI_ALLOCATE_MAX_ADDRESS, - EFI_RESERVED_MEMORY_TYPE, - efi_size_in_pages(secondary_boot_code_size), - &reloc_addr); - if (ret == EFI_SUCCESS) { - debug("Relocating spin table from %llx to %llx (size %lx)\n", - (u64)secondary_boot_code_start, reloc_addr, + reloc_addr = memalign(PAGE_SIZE, + round_up(secondary_boot_code_size, PAGE_SIZE)); + if (reloc_addr) { + debug("Relocating spin table from %p to %p (size %lx)\n", + secondary_boot_code_start, reloc_addr, secondary_boot_code_size); - memcpy((void *)reloc_addr, secondary_boot_code_start, + memcpy(reloc_addr, secondary_boot_code_start, secondary_boot_code_size); - flush_dcache_range(reloc_addr, - reloc_addr + secondary_boot_code_size); + flush_dcache_range((unsigned long)reloc_addr, + (unsigned long)reloc_addr + + secondary_boot_code_size);
/* set new entry point for secondary cores */ - secondary_boot_addr += (void *)reloc_addr - + secondary_boot_addr += reloc_addr - secondary_boot_code_start; flush_dcache_range((unsigned long)&secondary_boot_addr, (unsigned long)&secondary_boot_addr + 8);
/* this will be used to reserve the memory */ - secondary_boot_code_start = (void *)reloc_addr; + secondary_boot_code_start = reloc_addr; } #endif
Michael Walle
