[U-Boot] [PATCH 1/2 v2] FSL/eSDHC: enable the peripheral clock to detect the card
According to the card detection of p1/p2 platform RM, we should set SYSCTL[PEREN] to enable the clock. Otherwise, after booting the u-boot, and then inserting the SD card, the SD card can't be detected.
Signed-off-by: Jerry Huang Chang-Ming.Huang@freescale.com CC: Andy Fleming afleming@gmail.com --- changes for v2: - correct the typo
drivers/mmc/fsl_esdhc.c | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index a2f35e3..1682a79 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -491,6 +491,8 @@ int fsl_esdhc_initialize(bd_t *bis, struct fsl_esdhc_cfg *cfg) /* First reset the eSDHC controller */ esdhc_reset(regs);
+ esdhc_write32(®s->sysctl, SYSCTL_PEREN); + mmc->priv = cfg; mmc->send_cmd = esdhc_send_cmd; mmc->set_ios = esdhc_set_ios;
Hi, Do you have any comment about this patch? It can be merged into next version?
Best Regards Jerry Huang
-----Original Message----- From: Huang Changming-R66093 Sent: Thursday, March 29, 2012 10:11 AM To: u-boot@lists.denx.de Cc: Huang Changming-R66093; Andy Fleming Subject: [PATCH 1/2 v2] FSL/eSDHC: enable the peripheral clock to detect the card
changes for v2:
- correct the typo
- esdhc_write32(®s->sysctl, SYSCTL_PEREN);
- mmc->priv = cfg; mmc->send_cmd = esdhc_send_cmd; mmc->set_ios = esdhc_set_ios;
-- 1.7.5.4
