[PATCH] pmic: pca9450: permit config on all bucks and LDOs
In order to have the possibility to configure the regulators at system startup through DM support, all LDOs and bucks must be able to be changeable. Currently there is a limitation to change the values when the output is enabled. Since the driver is based on the ROHM BD71837 and a comment that describes a limitation about switching while the output is enabled can also be found there, the limitation probably comes from this type.
Signed-off-by: Heiko Thiery heiko.thiery@gmail.com --- drivers/power/regulator/pca9450.c | 42 ++++++++++--------------------- 1 file changed, 13 insertions(+), 29 deletions(-)
diff --git a/drivers/power/regulator/pca9450.c b/drivers/power/regulator/pca9450.c index 23badaa332..fe1869397c 100644 --- a/drivers/power/regulator/pca9450.c +++ b/drivers/power/regulator/pca9450.c @@ -44,7 +44,6 @@ struct pca9450_vrange { * @ranges: pointer to ranges of regulator voltages and matching register * values * @numranges: number of voltage ranges pointed by ranges - * @dvs: whether the voltage can be changed when regulator is enabled */ struct pca9450_plat { const char *name; @@ -54,7 +53,6 @@ struct pca9450_plat { u8 volt_mask; struct pca9450_vrange *ranges; unsigned int numranges; - bool dvs; };
#define PCA_RANGE(_min, _vstep, _sel_low, _sel_hi) \ @@ -63,11 +61,11 @@ struct pca9450_plat { .min_sel = (_sel_low), .max_sel = (_sel_hi), \ }
-#define PCA_DATA(_name, enreg, enmask, vreg, vmask, _range, _dvs) \ +#define PCA_DATA(_name, enreg, enmask, vreg, vmask, _range) \ { \ .name = (_name), .enable_reg = (enreg), .enablemask = (enmask), \ .volt_reg = (vreg), .volt_mask = (vmask), .ranges = (_range), \ - .numranges = ARRAY_SIZE(_range), .dvs = (_dvs), \ + .numranges = ARRAY_SIZE(_range) \ }
static struct pca9450_vrange pca9450_buck123_vranges[] = { @@ -107,39 +105,39 @@ static struct pca9450_plat pca9450_reg_data[] = { /* Bucks 1-3 which support dynamic voltage scaling */ PCA_DATA("BUCK1", PCA9450_BUCK1CTRL, HW_STATE_CONTROL, PCA9450_BUCK1OUT_DVS0, PCA9450_DVS_BUCK_RUN_MASK, - pca9450_buck123_vranges, true), + pca9450_buck123_vranges), PCA_DATA("BUCK2", PCA9450_BUCK2CTRL, HW_STATE_CONTROL, PCA9450_BUCK2OUT_DVS0, PCA9450_DVS_BUCK_RUN_MASK, - pca9450_buck123_vranges, true), + pca9450_buck123_vranges), PCA_DATA("BUCK3", PCA9450_BUCK3CTRL, HW_STATE_CONTROL, PCA9450_BUCK3OUT_DVS0, PCA9450_DVS_BUCK_RUN_MASK, - pca9450_buck123_vranges, true), + pca9450_buck123_vranges), /* Bucks 4-6 which do not support dynamic voltage scaling */ PCA_DATA("BUCK4", PCA9450_BUCK4CTRL, HW_STATE_CONTROL, PCA9450_BUCK4OUT, PCA9450_DVS_BUCK_RUN_MASK, - pca9450_buck456_vranges, false), + pca9450_buck456_vranges), PCA_DATA("BUCK5", PCA9450_BUCK5CTRL, HW_STATE_CONTROL, PCA9450_BUCK5OUT, PCA9450_DVS_BUCK_RUN_MASK, - pca9450_buck456_vranges, false), + pca9450_buck456_vranges), PCA_DATA("BUCK6", PCA9450_BUCK6CTRL, HW_STATE_CONTROL, PCA9450_BUCK6OUT, PCA9450_DVS_BUCK_RUN_MASK, - pca9450_buck456_vranges, false), + pca9450_buck456_vranges), /* LDOs */ PCA_DATA("LDO1", PCA9450_LDO1CTRL, HW_STATE_CONTROL, PCA9450_LDO1CTRL, PCA9450_LDO12_MASK, - pca9450_ldo1_vranges, false), + pca9450_ldo1_vranges), PCA_DATA("LDO2", PCA9450_LDO2CTRL, HW_STATE_CONTROL, PCA9450_LDO2CTRL, PCA9450_LDO12_MASK, - pca9450_ldo2_vranges, false), + pca9450_ldo2_vranges), PCA_DATA("LDO3", PCA9450_LDO3CTRL, HW_STATE_CONTROL, PCA9450_LDO3CTRL, PCA9450_LDO34_MASK, - pca9450_ldo34_vranges, false), + pca9450_ldo34_vranges), PCA_DATA("LDO4", PCA9450_LDO4CTRL, HW_STATE_CONTROL, PCA9450_LDO4CTRL, PCA9450_LDO34_MASK, - pca9450_ldo34_vranges, false), + pca9450_ldo34_vranges), PCA_DATA("LDO5", PCA9450_LDO5CTRL_H, HW_STATE_CONTROL, PCA9450_LDO5CTRL_H, PCA9450_LDO5_MASK, - pca9450_ldo5_vranges, false), + pca9450_ldo5_vranges), };
static int vrange_find_value(struct pca9450_vrange *r, unsigned int sel, @@ -246,20 +244,6 @@ static int pca9450_set_value(struct udevice *dev, int uvolt) unsigned int sel; int i, found = 0;
- /* - * An under/overshooting may occur if voltage is changed for other - * regulators but buck 1,2,3 or 4 when regulator is enabled. Prevent - * change to protect the HW - */ - if (!plat->dvs) - if (pca9450_get_enable(dev)) { - /* If the value is already set, skip the warning. */ - if (pca9450_get_value(dev) == uvolt) - return 0; - pr_err("Only DVS bucks can be changed when enabled\n"); - return -EINVAL; - } - for (i = 0; i < plat->numranges; i++) { struct pca9450_vrange *r = &plat->ranges[i];
Reviewed-by: Fabio Estevam festevam@denx.de
Signed-off-by: Heiko Thiery heiko.thiery@gmail.com Reviewed-by: Fabio Estevam festevam@denx.de
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
- @ranges: pointer to ranges of regulator voltages and matching register
values
- @numranges: number of voltage ranges pointed by ranges
- @dvs: whether the voltage can be changed when regulator is enabled
- bool dvs;
- .numranges = ARRAY_SIZE(_range) \
PCA_DATA("BUCK2", PCA9450_BUCK2CTRL, HW_STATE_CONTROL, PCA9450_BUCK2OUT_DVS0, PCA9450_DVS_BUCK_RUN_MASK,pca9450_buck123_vranges),
PCA_DATA("BUCK3", PCA9450_BUCK3CTRL, HW_STATE_CONTROL, PCA9450_BUCK3OUT_DVS0, PCA9450_DVS_BUCK_RUN_MASK,pca9450_buck123_vranges),
/* Bucks 4-6 which do not support dynamic voltage scaling */ PCA_DATA("BUCK4", PCA9450_BUCK4CTRL, HW_STATE_CONTROL, PCA9450_BUCK4OUT, PCA9450_DVS_BUCK_RUN_MASK,pca9450_buck123_vranges),
PCA_DATA("BUCK5", PCA9450_BUCK5CTRL, HW_STATE_CONTROL, PCA9450_BUCK5OUT, PCA9450_DVS_BUCK_RUN_MASK,pca9450_buck456_vranges),
PCA_DATA("BUCK6", PCA9450_BUCK6CTRL, HW_STATE_CONTROL, PCA9450_BUCK6OUT, PCA9450_DVS_BUCK_RUN_MASK,pca9450_buck456_vranges),
/* LDOs */ PCA_DATA("LDO1", PCA9450_LDO1CTRL, HW_STATE_CONTROL, PCA9450_LDO1CTRL, PCA9450_LDO12_MASK,pca9450_buck456_vranges),
PCA_DATA("LDO2", PCA9450_LDO2CTRL, HW_STATE_CONTROL, PCA9450_LDO2CTRL, PCA9450_LDO12_MASK,pca9450_ldo1_vranges),
PCA_DATA("LDO3", PCA9450_LDO3CTRL, HW_STATE_CONTROL, PCA9450_LDO3CTRL, PCA9450_LDO34_MASK,pca9450_ldo2_vranges),
PCA_DATA("LDO4", PCA9450_LDO4CTRL, HW_STATE_CONTROL, PCA9450_LDO4CTRL, PCA9450_LDO34_MASK,pca9450_ldo34_vranges),
PCA_DATA("LDO5", PCA9450_LDO5CTRL_H, HW_STATE_CONTROL, PCA9450_LDO5CTRL_H, PCA9450_LDO5_MASK,pca9450_ldo34_vranges),
- if (!plat->dvs)
return -EINVAL;
Hi Heiko
I think that this can be valid even for bd71837. Are you agree?
Michael
values
bool dvs;
if (!plat->dvs)
return -EINVAL;
Fabio Estevam
Heiko Thiery
Jaehoon Chung
Michael Nazzareno Trimarchi
