[U-Boot] [PATCH] arm926ejs: add NXP LPC32x0 cpu series support
This change adds initial support for NXP LPC32x0 SoC series.
Signed-off-by: Vladimir Zapolskiy vz@mleia.com --- arch/arm/cpu/arm926ejs/lpc32xx/Makefile | 45 +++++++ arch/arm/cpu/arm926ejs/lpc32xx/clkpwr.c | 95 ++++++++++++++ arch/arm/cpu/arm926ejs/lpc32xx/cpu.c | 44 +++++++ arch/arm/cpu/arm926ejs/lpc32xx/timer.c | 127 +++++++++++++++++++ arch/arm/include/asm/arch-lpc32xx/clk.h | 156 +++++++++++++++++++++++ arch/arm/include/asm/arch-lpc32xx/config.h | 39 ++++++ arch/arm/include/asm/arch-lpc32xx/cpu.h | 65 ++++++++++ arch/arm/include/asm/arch-lpc32xx/timer.h | 74 +++++++++++ arch/arm/include/asm/arch-lpc32xx/uart.h | 190 ++++++++++++++++++++++++++++ arch/arm/include/asm/arch-lpc32xx/wdt.h | 51 ++++++++ 10 files changed, 886 insertions(+), 0 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/Makefile create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/clkpwr.c create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/cpu.c create mode 100644 arch/arm/cpu/arm926ejs/lpc32xx/timer.c create mode 100644 arch/arm/include/asm/arch-lpc32xx/clk.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/config.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/cpu.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/timer.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/uart.h create mode 100644 arch/arm/include/asm/arch-lpc32xx/wdt.h
diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/Makefile b/arch/arm/cpu/arm926ejs/lpc32xx/Makefile new file mode 100644 index 0000000..f2badb6 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/lpc32xx/Makefile @@ -0,0 +1,45 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).o + +COBJS = cpu.o clkpwr.o timer.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/clkpwr.c b/arch/arm/cpu/arm926ejs/lpc32xx/clkpwr.c new file mode 100644 index 0000000..451543b --- /dev/null +++ b/arch/arm/cpu/arm926ejs/lpc32xx/clkpwr.c @@ -0,0 +1,95 @@ +/* + * Copyright (C) 2011 by Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ + +#include <common.h> +#include <div64.h> +#include <asm/arch/cpu.h> +#include <asm/arch/clk.h> +#include <asm/io.h> + +static clk_t *clk = (clk_t *)CLK_PM_BASE; + +unsigned int get_sys_clk_rate(void) +{ + if (readl(&clk->sysclk_ctrl) & CLK_SYSCLK_PLL397) + return RTC_CLK_FREQUENCY * 397; + else + return OSC_CLK_FREQUENCY; +} + +unsigned int get_hclk_pll_rate(void) +{ + unsigned long long fin, fref, fcco, fout; + u32 val, m_div, n_div, p_div; + + /* + * Valid frequency ranges: + * 1 * 10^6 <= Fin <= 20 * 10^6 + * 1 * 10^6 <= Fref <= 27 * 10^6 + * 156 * 10^6 <= Fcco <= 320 * 10^6 + * + * Due to these frequency constraints and divider values it could be + * shown that 32bit values used here for operations are not overflowed + */ + + fref = fin = get_sys_clk_rate(); + if (fin > 20000000ULL || fin < 1000000ULL) + return 0; + + val = readl(&clk->hclkpll_ctrl); + m_div = ((val & CLK_HCLK_PLL_FEEDBACK_DIV_MASK) >> 1) + 1; + n_div = ((val & CLK_HCLK_PLL_PREDIV_MASK) >> 9) + 1; + if (val & CLK_HCLK_PLL_DIRECT) + p_div = 0; + else + p_div = ((val & CLK_HCLK_PLL_POSTDIV_MASK) >> 11) + 1; + p_div = 1 << p_div; + + if (val & CLK_HCLK_PLL_BYPASS) { + do_div(fin, p_div); + return fin; + } + + do_div(fref, n_div); + if (fref > 27000000ULL || fref < 1000000ULL) + return 0; + + if (val & CLK_HCLK_PLL_FEEDBACK) { + fout = fcco = fref * m_div; + do_div(fout, p_div); + } else { + fout = fref * m_div; + fcco = fout * p_div; + } + + if (fcco > 320000000ULL || fcco < 156000000ULL) + return 0; + + return fout; +} + +unsigned int get_periph_clk_rate(void) +{ + u32 val; + + if (!(readl(&clk->pwr_ctrl) & CLK_PWR_NORMAL_RUN)) + return get_sys_clk_rate(); + + val = (readl(&clk->hclkdiv_ctrl) & CLK_HCLK_PERIPH_DIV_MASK) >> 2; + return get_hclk_pll_rate() / (val + 1); +} diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/cpu.c b/arch/arm/cpu/arm926ejs/lpc32xx/cpu.c new file mode 100644 index 0000000..1f6c964 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/lpc32xx/cpu.c @@ -0,0 +1,44 @@ +/* + * Copyright (C) 2011 by Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/cpu.h> +#include <asm/arch/clk.h> +#include <asm/arch/wdt.h> +#include <asm/io.h> + +void reset_cpu(ulong addr) +{ + clk_t *clk = (clk_t *)CLK_PM_BASE; + wdtim_t *wdt = (wdtim_t *)WDT_BASE; + u32 val; + + /* Enable watchdog clock */ + val = readl(&clk->timclk_ctrl); + writel(val | CLKPWR_TIMCLK_WATCHDOG, &clk->timclk_ctrl); + + /* Reset pulse length is 13005 PERIPH_CLKs */ + writel(13000, &wdt->pulse); + + /* Force WDOG_RESET2 and RESOUT_N signal active */ + writel(WDTIM_MCTRL_RESFRC2 | WDTIM_MCTRL_RESFRC1 | WDTIM_MCTRL_M_RES2, + &wdt->mctrl); + + while (1) {} +} diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/timer.c b/arch/arm/cpu/arm926ejs/lpc32xx/timer.c new file mode 100644 index 0000000..4563ee9 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/lpc32xx/timer.c @@ -0,0 +1,127 @@ +/* + * Copyright (C) 2011 Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/cpu.h> +#include <asm/arch/clk.h> +#include <asm/arch/timer.h> +#include <asm/io.h> + +static timer_t *timer0 = (timer_t *)TIMER0_BASE; +static timer_t *timer1 = (timer_t *)TIMER1_BASE; +static clk_t *clk = (clk_t *)CLK_PM_BASE; + +static void lpc32xx_timer_clock(u32 bit, int enable) +{ + u32 val = readl(&clk->timclk_ctrl1); + + if (enable) + val |= bit; + else + val &= ~bit; + + writel(val, &clk->timclk_ctrl1); +} + +static void lpc32xx_timer_setup_interrupt(timer_t *timer, int match, int count) +{ + /* match should be in range 0..4 */ + + /* Clear match interrupt */ + writel(TIMER_IR_MR(match), &timer->ir); + + /* Set match count */ + writel(count, &timer->mr[match]); + + /* Interrupt on match */ + writel(TIMER_MCR_INTERRUPT(match), &timer->mcr); + +} + +static void lpc32xx_timer_wait_for_interrupt(timer_t *timer, int match) +{ + /* Loop until interrupt happens */ + while (!(readl(&timer->ir) & TIMER_IR_MR(match))) {} +} + +static void lpc32xx_timer_reset(timer_t *timer, u32 freq) +{ + /* Reset timer */ + writel(TIMER_TCR_COUNTER_RESET, &timer->tcr); + writel(TIMER_TCR_COUNTER_DISABLE, &timer->tcr); + writel(0, &timer->tc); + writel(0, &timer->pr); + +#if defined(EXPERIMENTAL) + /* Clear match */ + writel(TIMER_IR_MR(0), &timer->ir); +#endif + + /* Count mode is every rising PCLK edge */ + writel(TIMER_CTCR_MODE_TIMER, &timer->ctcr); + + /* Set prescale counter value */ + writel((get_periph_clk_rate() / freq) - 1, &timer->pr); +} + +static void lpc32xx_timer_count(timer_t *timer, int enable) +{ + if (enable) + writel(TIMER_TCR_COUNTER_ENABLE, &timer->tcr); + else + writel(TIMER_TCR_COUNTER_DISABLE, &timer->tcr); +} + +void reset_timer(void) +{ + lpc32xx_timer_reset(timer0, CONFIG_SYS_HZ); + lpc32xx_timer_count(timer0, 1); +} + +int timer_init(void) +{ + lpc32xx_timer_clock(CLKPWR_TIMCLK_TIMER0, 1); + reset_timer(); + + return 0; +} + +ulong get_timer(ulong base) +{ + return readl(&timer0->tc) - base; +} + +void __udelay(unsigned long usec) +{ + lpc32xx_timer_clock(CLKPWR_TIMCLK_TIMER1, 1); + lpc32xx_timer_reset(timer1, CONFIG_SYS_HZ * 1000); + + lpc32xx_timer_setup_interrupt(timer1, 0, usec); + lpc32xx_timer_count(timer1, 1); + + lpc32xx_timer_wait_for_interrupt(timer1, 0); + + lpc32xx_timer_count(timer1, 0); + lpc32xx_timer_clock(CLKPWR_TIMCLK_TIMER1, 0); +} + +ulong get_tbclk(void) +{ + return CONFIG_SYS_HZ; +} diff --git a/arch/arm/include/asm/arch-lpc32xx/clk.h b/arch/arm/include/asm/arch-lpc32xx/clk.h new file mode 100644 index 0000000..506bf43 --- /dev/null +++ b/arch/arm/include/asm/arch-lpc32xx/clk.h @@ -0,0 +1,156 @@ +/* + * Copyright (C) 2011 by Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ + +#ifndef _LPC32XX_CLK_H +#define _LPC32XX_CLK_H + +#include <asm/types.h> +#include <asm/arch/cpu.h> + +#define OSC_CLK_FREQUENCY 13000000 +#define RTC_CLK_FREQUENCY 32768 + +/* Clocking and Power Control Registers */ +typedef struct { + u32 reserved0[5]; + u32 boot_map; /* Boot Map Control Register */ + u32 p0_intr_er; /* Port 0/1 Start and interrupt Enable Register */ + u32 usbdiv_ctrl; /* USB Clock Pre-Divide Register */ + /* Internal Start Signal Sources Registers */ + u32 start_er_int; /* Start Enable Register */ + u32 start_rsr_int; /* Start Raw Status Register */ + u32 start_sr_int; /* Start Status Register */ + u32 start_apr_int; /* Start Activation Polarity Register */ + /* Device Pin Start Signal Sources Registers */ + u32 start_er_pin; /* Start Enable Register */ + u32 start_rsr_pin; /* Start Raw Status Register */ + u32 start_sr_pin; /* Start Status Register */ + u32 start_apr_pin; /* Start Activation Polarity Register */ + /* Clock Control Registers */ + u32 hclkdiv_ctrl; /* HCLK Divider Control Register */ + u32 pwr_ctrl; /* Power Control Register */ + u32 pll397_ctrl; /* PLL397 Control Register */ + u32 osc_ctrl; /* Main Oscillator Control Register */ + u32 sysclk_ctrl; /* SYSCLK Control Register */ + u32 lcdclk_ctrl; /* LCD Clock Control Register */ + u32 hclkpll_ctrl; /* HCLK PLL Control Register */ + u32 reserved1; + u32 adclk_ctrl1; /* ADC Clock Control1 Register */ + u32 usb_ctrl; /* USB Control Register */ + u32 sdramclk_ctrl; /* SDRAM Clock Control Register */ + u32 ddr_lap_nom; /* DDR Calibration Nominal Value */ + u32 ddr_lap_count; /* DDR Calibration Measured Value */ + u32 ddr_cal_delay; /* DDR Calibration Delay Value */ + u32 ssp_ctrl; /* SSP Control Register */ + u32 i2s_ctrl; /* I2S Clock Control Register */ + u32 ms_ctrl; /* Memory Card Control Register */ + u32 reserved2[3]; + u32 macclk_ctrl; /* Ethernet MAC Clock Control Register */ + u32 reserved3[4]; + u32 test_clk; /* Test Clock Selection Register */ + u32 sw_int; /* Software Interrupt Register */ + u32 i2cclk_ctrl; /* I2C Clock Control Register */ + u32 keyclk_ctrl; /* Keyboard Scan Clock Control Register */ + u32 adclk_ctrl; /* ADC Clock Control Register */ + u32 pwmclk_ctrl; /* PWM Clock Control Register */ + u32 timclk_ctrl; /* Timer Clock Control Register */ + u32 timclk_ctrl1; /* Timer Clock Control1 and MCPWM Register */ + u32 spi_ctrl; /* SPI Control Register */ + u32 flashclk_ctrl; /* NAND Flash Clock Control Register */ + u32 reserved4; + u32 u3clk; /* UART 3 Clock Control Register */ + u32 u4clk; /* UART 4 Clock Control Register */ + u32 u5clk; /* UART 5 Clock Control Register */ + u32 u6clk; /* UART 6 Clock Control Register */ + u32 irdaclk; /* IrDA Clock Control Register */ + u32 uartclk_ctrl; /* UART Clock Control Register */ + u32 dmaclk_ctrl; /* DMA Clock Control Register */ + u32 autoclk_ctrl; /* Autoclock Control Register */ +} clk_t; + +/* HCLK Divider Control Register bits */ +#define CLK_HCLK_DDRAM_HALF SBF(7, 0x2) +#define CLK_HCLK_DDRAM_NOMINAL SBF(7, 0x1) +#define CLK_HCLK_DDRAM_STOPPED SBF(7, 0x0) +#define CLK_HCLK_PERIPH_DIV_MASK SBF(2, 0x1F) +#define CLK_HCLK_PERIPH_DIV(n) SBF(2, (n - 1) & 0x1F) +#define CLK_HCLK_ARM_PLL_DIV_4 SBF(0, 0x2) +#define CLK_HCLK_ARM_PLL_DIV_2 SBF(0, 0x1) +#define CLK_HCLK_ARM_PLL_DIV_1 SBF(0, 0x0) + +/* Power Control Register bits */ +#define CLK_PWR_HCLK_RUN_PERIPH BIT(10) +#define CLK_PWR_EMC_SREFREQ BIT(9) +#define CLK_PWR_EMC_SREFREQ_UPDATE BIT(8) +#define CLK_PWR_SDRAM_SREFREQ BIT(7) +#define CLK_PWR_HIGHCORE_LEVEL BIT(5) +#define CLK_PWR_SYSCLKEN_LEVEL BIT(4) +#define CLK_PWR_SYSCLKEN_CTRL BIT(3) +#define CLK_PWR_NORMAL_RUN BIT(2) +#define CLK_PWR_HIGHCORE_CTRL BIT(1) +#define CLK_PWR_STOP_MODE BIT(0) + +/* SYSCLK Control Register bits */ +#define CLK_SYSCLK_PLL397 BIT(1) +#define CLK_SYSCLK_MUX BIT(0) + +/* HCLK PLL Control Register bits */ +#define CLK_HCLK_PLL_OPERATING BIT(16) +#define CLK_HCLK_PLL_BYPASS BIT(15) +#define CLK_HCLK_PLL_DIRECT BIT(14) +#define CLK_HCLK_PLL_FEEDBACK BIT(13) +#define CLK_HCLK_PLL_POSTDIV_MASK SBF(11, 0x3) +#define CLK_HCLK_PLL_POSTDIV_16 SBF(11, 0x3) +#define CLK_HCLK_PLL_POSTDIV_8 SBF(11, 0x2) +#define CLK_HCLK_PLL_POSTDIV_4 SBF(11, 0x1) +#define CLK_HCLK_PLL_POSTDIV_2 SBF(11, 0x0) +#define CLK_HCLK_PLL_PREDIV_MASK SBF(9, 0x3) +#define CLK_HCLK_PLL_PREDIV_4 SBF(9, 0x3) +#define CLK_HCLK_PLL_PREDIV_3 SBF(9, 0x2) +#define CLK_HCLK_PLL_PREDIV_2 SBF(9, 0x1) +#define CLK_HCLK_PLL_PREDIV_1 SBF(9, 0x0) +#define CLK_HCLK_PLL_FEEDBACK_DIV_MASK SBF(1, 0xFF) +#define CLK_HCLK_PLL_FEEDBACK_DIV(n) SBF(1, (n - 1) & 0xFF) +#define CLK_HCLK_PLL_LOCKED BIT(0) + +/* Timer Clock Control1 Register bits */ +#define CLKPWR_TIMCLK_MOTOR BIT(5) +#define CLKPWR_TIMCLK_TIMER3 BIT(5) +#define CLKPWR_TIMCLK_TIMER2 BIT(4) +#define CLKPWR_TIMCLK_TIMER1 BIT(3) +#define CLKPWR_TIMCLK_TIMER0 BIT(2) +#define CLKPWR_TIMCLK_TIMER5 BIT(1) +#define CLKPWR_TIMCLK_TIMER4 BIT(0) + +/* Timer Clock Control Register bits */ +#define CLKPWR_TIMCLK_HSTIMER BIT(1) +#define CLKPWR_TIMCLK_WATCHDOG BIT(0) + +/* UART Clock Control Register bits */ +#define CLKPWR_UART(n) BIT((n) - 3) + +/* UARTn Clock Select Registers bits */ +#define CLKPWR_UART_HCLK BIT(16) +#define CLKPWR_UART_X_DIV(n) SBF(8, (n) & 0xFF) +#define CLKPWR_UART_Y_DIV(n) SBF(0, (n) & 0xFF) + +unsigned int get_sys_clk_rate(void); +unsigned int get_hclk_pll_rate(void); +unsigned int get_periph_clk_rate(void); + +#endif /* _LPC32XX_CLK_H */ diff --git a/arch/arm/include/asm/arch-lpc32xx/config.h b/arch/arm/include/asm/arch-lpc32xx/config.h new file mode 100644 index 0000000..9ecdcc9 --- /dev/null +++ b/arch/arm/include/asm/arch-lpc32xx/config.h @@ -0,0 +1,39 @@ +/* + * (C) Copyright 2011 by Vladimir Zapolskiy vz@mleia.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +/* + * This file should be included in board config header file. + * + * It supports common definitions for LPC32XX platforms + */ + +#ifndef _LPC32XX_CONFIG_H +#define _LPC32XX_CONFIG_H + +#define CONFIG_ARM926EJS 1 /* Basic Architecture */ + +#define CONFIG_NR_DRAM_BANKS_MAX 2 + +/* 1KHz clock tick */ +#define CONFIG_SYS_HZ 1000 + +#endif /* _LPC32XX_CONFIG_H */ diff --git a/arch/arm/include/asm/arch-lpc32xx/cpu.h b/arch/arm/include/asm/arch-lpc32xx/cpu.h new file mode 100644 index 0000000..b66e221 --- /dev/null +++ b/arch/arm/include/asm/arch-lpc32xx/cpu.h @@ -0,0 +1,65 @@ +/* + * Copyright (C) 2011 by Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _LPC32XX_CPU_H +#define _LPC32XX_CPU_H + +#define SBF(s, v) (((unsigned long)(v)) << (s)) +#define BIT(b) SBF(b, 0x01) + +/* LPC32XX Memory map */ + +/* AHB physical base addresses */ +#define SLC_NAND_BASE 0x20020000 /* SLC NAND Flash registers base */ +#define SSP0_BASE 0x20084000 /* SSP0 registers base */ +#define SD_CARD_BASE 0x20098000 /* SD card interface registers base */ +#define MLC_NAND_BASE 0x200A8000 /* MLC NAND Flash registers base */ +#define DMA_BASE 0x31000000 /* DMA controller registers base */ +#define USB_BASE 0x31020000 /* USB registers base */ +#define ETHERNET_BASE 0x31060000 /* Ethernet registers base */ +#define EMC_BASE 0x31080000 /* EMC configuration registers base */ + +/* FAB peripherals base addresses */ +#define CLK_PM_BASE 0x40004000 /* System control registers base */ +#define HS_UART1_BASE 0x40014000 /* High speed UART 1 registers base */ +#define HS_UART2_BASE 0x40018000 /* High speed UART 2 registers base */ +#define HS_UART7_BASE 0x4001C000 /* High speed UART 7 registers base */ +#define GPIO_BASE 0x40028000 /* GPIO registers base */ +#define WDT_BASE 0x4003C000 /* Watchdog timer registers base */ +#define TIMER0_BASE 0x40044000 /* Timer0 registers base */ +#define TIMER1_BASE 0x4004C000 /* Timer1 registers base */ +#define UART_CTRL_BASE 0x40054000 /* UART control regsisters base */ + +/* APB peripherals base addresses */ +#define UART3_BASE 0x40080000 /* UART 3 registers base */ +#define UART4_BASE 0x40088000 /* UART 4 registers base */ +#define UART5_BASE 0x40090000 /* UART 5 registers base */ +#define UART6_BASE 0x40098000 /* UART 6 registers base */ + +/* External SDRAM Memory Bank base addresses */ +#define EMC_DYCS0_BASE 0x80000000 /* SDRAM DYCS0 base address */ +#define EMC_DYCS1_BASE 0xA0000000 /* SDRAM DYCS1 base address */ + +/* External Static Memory Bank base addresses */ +#define EMC_CS0_BASE 0xE0000000 +#define EMC_CS1_BASE 0xE1000000 +#define EMC_CS2_BASE 0xE2000000 +#define EMC_CS3_BASE 0xE3000000 + +#endif /* _LPC32XX_CPU_H */ diff --git a/arch/arm/include/asm/arch-lpc32xx/timer.h b/arch/arm/include/asm/arch-lpc32xx/timer.h new file mode 100644 index 0000000..de5e84c --- /dev/null +++ b/arch/arm/include/asm/arch-lpc32xx/timer.h @@ -0,0 +1,74 @@ +/* + * Copyright (C) 2011 by Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _LPC32XX_TIMER_H +#define _LPC32XX_TIMER_H + +#include <asm/types.h> + +/* Timer/Counter Registers */ +typedef struct { + u32 ir; /* Interrupt Register */ + u32 tcr; /* Timer Control Register */ + u32 tc; /* Timer Counter */ + u32 pr; /* Prescale Register */ + u32 pc; /* Prescale Counter */ + u32 mcr; /* Match Control Register */ + u32 mr[4]; /* Match Registers */ + u32 ccr; /* Capture Control Register */ + u32 cr[4]; /* Capture Registers */ + u32 emr; /* External Match Register */ + u32 reserved[12]; + u32 ctcr; /* Count Control Register */ +} timer_t; + +/* Timer/Counter Interrupt Register bits */ +#define TIMER_IR_CR(n) BIT((n) + 4) +#define TIMER_IR_MR(n) BIT((n)) + +/* Timer/Counter Timer Control Register bits */ +#define TIMER_TCR_COUNTER_RESET BIT(1) +#define TIMER_TCR_COUNTER_ENABLE BIT(0) +#define TIMER_TCR_COUNTER_DISABLE 0x0000 + +/* Timer/Counter Match Control Register bits */ +#define TIMER_MCR_STOP(n) BIT(3 * (n) + 2) +#define TIMER_MCR_RESET(n) BIT(3 * (n) + 1) +#define TIMER_MCR_INTERRUPT(n) BIT(3 * (n)) + +/* Timer/Counter Capture Control Register bits */ +#define TIMER_CCR_INTERRUPT(n) BIT(3 * (n) + 2) +#define TIMER_CCR_FALLING_EDGE(n) BIT(3 * (n) + 1) +#define TIMER_CCR_RISING_EDGE(n) BIT(3 * (n)) + +/* Timer/Counter External Match Register bits */ +#define TIMER_EMR_EMC_TOGGLE(n) SBF(2 * (n) + 4, 0x3) +#define TIMER_EMR_EMC_SET(n) SBF(2 * (n) + 4, 0x2) +#define TIMER_EMR_EMC_CLEAR(n) SBF(2 * (n) + 4, 0x1) +#define TIMER_EMR_EMC_NOTHING(n) SBF(2 * (n) + 4, 0x0) +#define TIMER_EMR_EM(n) BIT((n)) + +/* Timer/Counter Count Control Register bits */ +#define TIMER_CTCR_INPUT(n) SBF(2, (n)) +#define TIMER_CTCR_MODE_COUNTER_BOTH SBF(0, 0x3) +#define TIMER_CTCR_MODE_COUNTER_FALLING SBF(0, 0x2) +#define TIMER_CTCR_MODE_COUNTER_RISING SBF(0, 0x1) +#define TIMER_CTCR_MODE_TIMER SBF(0, 0x0) + +#endif /* _LPC32XX_TIMER_H */ diff --git a/arch/arm/include/asm/arch-lpc32xx/uart.h b/arch/arm/include/asm/arch-lpc32xx/uart.h new file mode 100644 index 0000000..4a55eb9 --- /dev/null +++ b/arch/arm/include/asm/arch-lpc32xx/uart.h @@ -0,0 +1,190 @@ +/* + * Copyright (C) 2011 by Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _LPC32XX_UART_H +#define _LPC32XX_UART_H + +#include <asm/types.h> + +/* Standard UART Registers */ +typedef struct { + union { + u32 rbr; /* Receiver Buffer Register */ + u32 thr; /* Transmit Holding Register */ + u32 dll; /* Divisor Latch Lower Byte */ + }; + union { + u32 dlm; /* Divisor Latch Higher Byte */ + u32 ier; /* Interrupt Enable Register */ + }; + union { + u32 iir; /* Interrupt ID Register */ + u32 fcr; /* FIFO Control Register */ + }; + u32 lcr; /* Line Control Register */ + u32 mcr; /* Modem Control Register */ + u32 lsr; /* Line Status Register */ + u32 msr; /* Modem Status Register */ + u32 rxlev; /* Receive FIFO Level Register */ +} uart_t; + +/* UART Interrupt Enable Register bits */ +#define UART_IER_MODEM_STATUS BIT(3) +#define UART_IER_RX_LINE_STATUS BIT(2) +#define UART_IER_THRE BIT(1) +#define UART_IER_RDA BIT(0) + +/* UART Interrupt Identification Register bits */ +#define UART_IIR_FIFO_ENABLE SBF(6, 0x0) +#define UART_IIR_ID_MASK SBF(1, 0x7) +#define UART_IIR_ID_CTI SBF(1, 0x6) +#define UART_IIR_ID_RLS SBF(1, 0x3) +#define UART_IIR_ID_RDA SBF(1, 0x2) +#define UART_IIR_ID_THR SBF(1, 0x1) +#define UART_IIR_ID_MS SBF(1, 0x0) +#define UART_IIR_nPENDING BIT(0) + +/* UART FIFO Control Register bits */ +#define UART_FCR_RX_TL60 SBF(6, 0x3) +#define UART_FCR_RX_TL48 SBF(6, 0x2) +#define UART_FCR_RX_TL32 SBF(6, 0x1) +#define UART_FCR_RX_TL16 SBF(6, 0x0) +#define UART_FCR_TX_TL16 SBF(4, 0x3) +#define UART_FCR_TX_TL8 SBF(4, 0x2) +#define UART_FCR_TX_TL4 SBF(4, 0x1) +#define UART_FCR_TX_TL0 SBF(4, 0x0) +#define UART_FCR_FIFO_CONTROL BIT(3) +#define UART_FCR_TX_RESET BIT(2) +#define UART_FCR_RX_RESET BIT(1) +#define UART_FCR_FIFO_ENABLE BIT(0) + +/* UART Line Control Register bits */ +#define UART_LCR_DLA BIT(7) +#define UART_LCR_BREAK BIT(6) +#define UART_LCR_PARITY_0 SBF(4, 0x3) +#define UART_LCR_PARITY_1 SBF(4, 0x2) +#define UART_LCR_PARITY_EVEN SBF(4, 0x1) +#define UART_LCR_PARITY_ODD SBF(4, 0x0) +#define UART_LCR_PARITY_ENABLE BIT(3) +#define UART_LCR_STOPBIT_2 BIT(2) +#define UART_LCR_WORD_8BIT SBF(0, 0x3) +#define UART_LCR_WORD_7BIT SBF(0, 0x2) +#define UART_LCR_WORD_6BIT SBF(0, 0x1) +#define UART_LCR_WORD_5BIT SBF(0, 0x0) + +/* UART Line Status Register bits */ +#define UART_LSR_RX_ERROR BIT(7) +#define UART_LSR_TEMT BIT(6) +#define UART_LSR_THRE BIT(5) +#define UART_LSR_BI BIT(4) +#define UART_LSR_FE BIT(3) +#define UART_LSR_PE BIT(2) +#define UART_LSR_OE BIT(1) +#define UART_LSR_RDR BIT(0) + +/* 14-clock UART Registers */ +typedef struct { + union { + u32 rx; /* Receiver FIFO */ + u32 tx; /* Transmitter FIFO */ + }; + u32 level; /* FIFO Level Register */ + u32 iir; /* Interrupt ID Register */ + u32 ctrl; /* Control Register */ + u32 rate; /* Rate Control Register */ +} hsuart_t; + +/* 14-clock UART Receiver FIFO Register bits */ +#define HSUART_RX_BREAK BIT(10) +#define HSUART_RX_ERROR BIT(9) +#define HSUART_RX_EMPTY BIT(8) +#define HSUART_RX_DATA SBF(0, 0xff) + +/* 14-clock UART Level Register bits */ +#define HSUART_LEVEL_TX SBF(8, 0xff) +#define HSUART_LEVEL_RX SBF(0, 0xff) + +/* 14-clock UART Interrupt Identification Register bits */ +#define HSUART_IIR_TX_INTERRUPT_SET BIT(6) +#define HSUART_IIR_RX_OVERRUN BIT(5) +#define HSUART_IIR_BREAK BIT(4) +#define HSUART_IIR_FRAMING BIT(3) +#define HSUART_IIR_RX_TIMEOUT BIT(2) +#define HSUART_IIR_RX_TRIG BIT(1) +#define HSUART_IIR_TX BIT(0) + +/* 14-clock UART Control Register bits */ +#define HSUART_CTRL_HRTS_INV BIT(21) +#define HSUART_CTRL_HRTS_TRIG_48 SBF(19, 0x3) +#define HSUART_CTRL_HRTS_TRIG_32 SBF(19, 0x2) +#define HSUART_CTRL_HRTS_TRIG_16 SBF(19, 0x1) +#define HSUART_CTRL_HRTS_TRIG_8 SBF(19, 0x0) +#define HSUART_CTRL_HRTS_EN BIT(18) +#define HSUART_CTRL_TMO_16 SBF(16, 0x3) +#define HSUART_CTRL_TMO_8 SBF(16, 0x2) +#define HSUART_CTRL_TMO_4 SBF(16, 0x1) +#define HSUART_CTRL_TMO_DISABLED SBF(16, 0x0) +#define HSUART_CTRL_HCTS_INV BIT(15) +#define HSUART_CTRL_HCTS_EN BIT(14) +#define HSUART_CTRL_HSU_OFFSET(n) SBF(9, (n)) +#define HSUART_CTRL_HSU_BREAK BIT(8) +#define HSUART_CTRL_HSU_ERR_INT_EN BIT(7) +#define HSUART_CTRL_HSU_RX_INT_EN BIT(6) +#define HSUART_CTRL_HSU_TX_INT_EN BIT(5) +#define HSUART_CTRL_HSU_RX_TRIG_48 SBF(2, 0x5) +#define HSUART_CTRL_HSU_RX_TRIG_32 SBF(2, 0x4) +#define HSUART_CTRL_HSU_RX_TRIG_16 SBF(2, 0x3) +#define HSUART_CTRL_HSU_RX_TRIG_8 SBF(2, 0x2) +#define HSUART_CTRL_HSU_RX_TRIG_4 SBF(2, 0x1) +#define HSUART_CTRL_HSU_RX_TRIG_1 SBF(2, 0x0) +#define HSUART_CTRL_HSU_TX_TRIG_16 SBF(0, 0x3) +#define HSUART_CTRL_HSU_TX_TRIG_8 SBF(0, 0x2) +#define HSUART_CTRL_HSU_TX_TRIG_4 SBF(0, 0x1) +#define HSUART_CTRL_HSU_TX_TRIG_0 SBF(0, 0x0) + +/* UART Control Registers */ +typedef struct { + u32 ctrl; /* Control Register */ + u32 clkmode; /* Clock Mode Register */ + u32 loop; /* Loopback Control Register */ +} uart_control_t; + +/* UART Control Register bits */ +#define UART_CTRL_UART3_MD_CTRL BIT(11) +#define UART_CTRL_HDPX_INV BIT(10) +#define UART_CTRL_HDPX_EN BIT(9) +#define UART_CTRL_UART6_IRDA BIT(5) +#define UART_CTRL_IR_TX6_INV BIT(4) +#define UART_CTRL_IR_RX6_INV BIT(3) +#define UART_CTRL_IR_RX_LENGTH BIT(2) +#define UART_CTRL_IR_TX_LENGTH BIT(1) +#define UART_CTRL_UART5_USB_MODE BIT(0) + +/* UART Clock Mode Register bits */ +#define UART_CLKMODE_STATX(n) BIT((n) + 16) +#define UART_CLKMODE_STAT BIT(14) +#define UART_CLKMODE_MASK(n) SBF(2 * (n) - 2, 0x3) +#define UART_CLKMODE_AUTO(n) SBF(2 * (n) - 2, 0x2) +#define UART_CLKMODE_ON(n) SBF(2 * (n) - 2, 0x1) +#define UART_CLKMODE_OFF(n) SBF(2 * (n) - 2, 0x0) + +/* UART Loopback Control Register bits */ +#define UART_LOOPBACK(n) BIT((n) - 1) + +#endif /* _LPC32XX_UART_H */ diff --git a/arch/arm/include/asm/arch-lpc32xx/wdt.h b/arch/arm/include/asm/arch-lpc32xx/wdt.h new file mode 100644 index 0000000..670ba01 --- /dev/null +++ b/arch/arm/include/asm/arch-lpc32xx/wdt.h @@ -0,0 +1,51 @@ +/* + * Copyright (C) 2011 by Vladimir Zapolskiy vz@mleia.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _LPC32XX_WDT_H +#define _LPC32XX_WDT_H + +#include <asm/types.h> + +/* Watchdog Timer Registers */ +typedef struct { + u32 isr; /* Interrupt Status Register */ + u32 ctrl; /* Control Register */ + u32 counter; /* Counter Value Register */ + u32 mctrl; /* Match Control Register */ + u32 match0; /* Match 0 Register */ + u32 emr; /* External Match Control Register */ + u32 pulse; /* Reset Pulse Length Register */ + u32 res; /* Reset Source Register */ +} wdtim_t; + +/* Watchdog Timer Control Register bits */ +#define WDTIM_CTRL_PAUSE_EN BIT(2) +#define WDTIM_CTRL_RESET_COUNT BIT(1) +#define WDTIM_CTRL_COUNT_ENAB BIT(0) + +/* Watchdog Timer Match Control Register bits */ +#define WDTIM_MCTRL_RESFRC2 BIT(6) +#define WDTIM_MCTRL_RESFRC1 BIT(5) +#define WDTIM_MCTRL_M_RES2 BIT(4) +#define WDTIM_MCTRL_M_RES1 BIT(3) +#define WDTIM_MCTRL_STOP_COUNT0 BIT(2) +#define WDTIM_MCTRL_RESET_COUNT0 BIT(1) +#define WDTIM_MCTRL_MR0_INT BIT(0) + +#endif /* _LPC32XX_WDT_H */
Hi Vladimir,
Signed-off-by: Vladimir Zapolskiyvz@mleia.com
Are you sure about the date and owner of the copyright?
+$(LIB): $(OBJS)
- $(call cmd_link_o_target, $(OBJS))
- Copyright (C) 2011 by Vladimir Zapolskiyvz@mleia.com
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
- Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
+#include<common.h> +#include<div64.h> +#include<asm/arch/cpu.h> +#include<asm/arch/clk.h> +#include<asm/io.h>
- if (readl(&clk->sysclk_ctrl)& CLK_SYSCLK_PLL397)
- else
- unsigned long long fin, fref, fcco, fout;
- u32 val, m_div, n_div, p_div;
* 1 * 10^6<= Fin<= 20 * 10^6
* 1 * 10^6<= Fref<= 27 * 10^6
* 156 * 10^6<= Fcco<= 320 * 10^6
- fref = fin = get_sys_clk_rate();
- if (fin> 20000000ULL || fin< 1000000ULL)
- val = readl(&clk->hclkpll_ctrl);
- m_div = ((val& CLK_HCLK_PLL_FEEDBACK_DIV_MASK)>> 1) + 1;
- n_div = ((val& CLK_HCLK_PLL_PREDIV_MASK)>> 9) + 1;
- if (val& CLK_HCLK_PLL_DIRECT)
p_div = 0;
- else
p_div = ((val& CLK_HCLK_PLL_POSTDIV_MASK)>> 11) + 1;
- p_div = 1<< p_div;
- if (val& CLK_HCLK_PLL_BYPASS) {
do_div(fin, p_div);
return fin;
- do_div(fref, n_div);
- if (fref> 27000000ULL || fref< 1000000ULL)
- if (val& CLK_HCLK_PLL_FEEDBACK) {
- } else {
- if (fcco> 320000000ULL || fcco< 156000000ULL)
- return fout;
- u32 val;
- if (!(readl(&clk->pwr_ctrl)& CLK_PWR_NORMAL_RUN))
- val = (readl(&clk->hclkdiv_ctrl)& CLK_HCLK_PERIPH_DIV_MASK)>> 2;
- return get_hclk_pll_rate() / (val + 1);
- MA 02111-1307 USA
+#include<common.h> +#include<asm/arch/cpu.h> +#include<asm/arch/clk.h> +#include<asm/arch/wdt.h> +#include<asm/io.h>
- clk_t *clk = (clk_t *)CLK_PM_BASE;
- wdtim_t *wdt = (wdtim_t *)WDT_BASE;
- u32 val;
- /* Enable watchdog clock */
- val = readl(&clk->timclk_ctrl);
- writel(val | CLKPWR_TIMCLK_WATCHDOG,&clk->timclk_ctrl);
- /* Reset pulse length is 13005 PERIPH_CLKs */
- writel(13000,&wdt->pulse);
- /* Force WDOG_RESET2 and RESOUT_N signal active */
- writel(WDTIM_MCTRL_RESFRC2 | WDTIM_MCTRL_RESFRC1 | WDTIM_MCTRL_M_RES2,
- &wdt->mctrl);
- while (1) {}
- Copyright (C) 2011 Vladimir Zapolskiyvz@mleia.com
- MA 02111-1307 USA
+#include<common.h> +#include<asm/arch/cpu.h> +#include<asm/arch/clk.h> +#include<asm/arch/timer.h> +#include<asm/io.h>
- u32 val = readl(&clk->timclk_ctrl1);
- if (enable)
val |= bit;
- else
val&= ~bit;
- writel(val,&clk->timclk_ctrl1);
- /* match should be in range 0..4 */
- /* Clear match interrupt */
- writel(TIMER_IR_MR(match),&timer->ir);
- /* Set match count */
- writel(count,&timer->mr[match]);
- /* Interrupt on match */
- writel(TIMER_MCR_INTERRUPT(match),&timer->mcr);
- /* Loop until interrupt happens */
- while (!(readl(&timer->ir)& TIMER_IR_MR(match))) {}
- /* Reset timer */
- writel(TIMER_TCR_COUNTER_RESET,&timer->tcr);
- writel(TIMER_TCR_COUNTER_DISABLE,&timer->tcr);
- writel(0,&timer->tc);
- writel(0,&timer->pr);
- /* Clear match */
- writel(TIMER_IR_MR(0),&timer->ir);
- /* Count mode is every rising PCLK edge */
- writel(TIMER_CTCR_MODE_TIMER,&timer->ctcr);
- /* Set prescale counter value */
- writel((get_periph_clk_rate() / freq) - 1,&timer->pr);
- if (enable)
writel(TIMER_TCR_COUNTER_ENABLE,&timer->tcr);
- else
- lpc32xx_timer_reset(timer0, CONFIG_SYS_HZ);
- lpc32xx_timer_count(timer0, 1);
Do we need a reset_timer? I was under the impression that we should never reset any timer in U-Boot.
- lpc32xx_timer_clock(CLKPWR_TIMCLK_TIMER0, 1);
- reset_timer();
- return readl(&timer0->tc) - base;
- lpc32xx_timer_clock(CLKPWR_TIMCLK_TIMER1, 1);
- lpc32xx_timer_reset(timer1, CONFIG_SYS_HZ * 1000);
- lpc32xx_timer_setup_interrupt(timer1, 0, usec);
- lpc32xx_timer_count(timer1, 1);
- lpc32xx_timer_wait_for_interrupt(timer1, 0);
- lpc32xx_timer_count(timer1, 0);
- lpc32xx_timer_clock(CLKPWR_TIMCLK_TIMER1, 0);
Do you need interrupts to get udelay() working?
- return CONFIG_SYS_HZ;
+#include<asm/types.h> +#include<asm/arch/cpu.h>
- u32 reserved0[5];
- u32 boot_map; /* Boot Map Control Register */
- u32 p0_intr_er; /* Port 0/1 Start and interrupt Enable Register */
- u32 usbdiv_ctrl; /* USB Clock Pre-Divide Register */
- u32 start_er_int; /* Start Enable Register */
- u32 start_rsr_int; /* Start Raw Status Register */
- u32 start_sr_int; /* Start Status Register */
- u32 start_apr_int; /* Start Activation Polarity Register */
- u32 start_er_pin; /* Start Enable Register */
- u32 start_rsr_pin; /* Start Raw Status Register */
- u32 start_sr_pin; /* Start Status Register */
- u32 start_apr_pin; /* Start Activation Polarity Register */
- u32 hclkdiv_ctrl; /* HCLK Divider Control Register */
- u32 pwr_ctrl; /* Power Control Register */
- u32 pll397_ctrl; /* PLL397 Control Register */
- u32 osc_ctrl; /* Main Oscillator Control Register */
- u32 sysclk_ctrl; /* SYSCLK Control Register */
- u32 lcdclk_ctrl; /* LCD Clock Control Register */
- u32 hclkpll_ctrl; /* HCLK PLL Control Register */
- u32 reserved1;
- u32 adclk_ctrl1; /* ADC Clock Control1 Register */
- u32 usb_ctrl; /* USB Control Register */
- u32 sdramclk_ctrl; /* SDRAM Clock Control Register */
- u32 ddr_lap_nom; /* DDR Calibration Nominal Value */
- u32 ddr_lap_count; /* DDR Calibration Measured Value */
- u32 ddr_cal_delay; /* DDR Calibration Delay Value */
- u32 ssp_ctrl; /* SSP Control Register */
- u32 i2s_ctrl; /* I2S Clock Control Register */
- u32 ms_ctrl; /* Memory Card Control Register */
- u32 reserved2[3];
- u32 macclk_ctrl; /* Ethernet MAC Clock Control Register */
- u32 reserved3[4];
- u32 test_clk; /* Test Clock Selection Register */
- u32 sw_int; /* Software Interrupt Register */
- u32 i2cclk_ctrl; /* I2C Clock Control Register */
- u32 keyclk_ctrl; /* Keyboard Scan Clock Control Register */
- u32 adclk_ctrl; /* ADC Clock Control Register */
- u32 pwmclk_ctrl; /* PWM Clock Control Register */
- u32 timclk_ctrl; /* Timer Clock Control Register */
- u32 timclk_ctrl1; /* Timer Clock Control1 and MCPWM Register */
- u32 spi_ctrl; /* SPI Control Register */
- u32 flashclk_ctrl; /* NAND Flash Clock Control Register */
- u32 reserved4;
- u32 u3clk; /* UART 3 Clock Control Register */
- u32 u4clk; /* UART 4 Clock Control Register */
- u32 u5clk; /* UART 5 Clock Control Register */
- u32 u6clk; /* UART 6 Clock Control Register */
- u32 irdaclk; /* IrDA Clock Control Register */
- u32 uartclk_ctrl; /* UART Clock Control Register */
- u32 dmaclk_ctrl; /* DMA Clock Control Register */
- u32 autoclk_ctrl; /* Autoclock Control Register */
+} clk_t;
+/* HCLK Divider Control Register bits */ +#define CLK_HCLK_DDRAM_HALF SBF(7, 0x2) +#define CLK_HCLK_DDRAM_NOMINAL SBF(7, 0x1) +#define CLK_HCLK_DDRAM_STOPPED SBF(7, 0x0) +#define CLK_HCLK_PERIPH_DIV_MASK SBF(2, 0x1F) +#define CLK_HCLK_PERIPH_DIV(n) SBF(2, (n - 1)& 0x1F) +#define CLK_HCLK_ARM_PLL_DIV_4 SBF(0, 0x2) +#define CLK_HCLK_ARM_PLL_DIV_2 SBF(0, 0x1) +#define CLK_HCLK_ARM_PLL_DIV_1 SBF(0, 0x0)
+/* HCLK PLL Control Register bits */ +#define CLK_HCLK_PLL_OPERATING BIT(16) +#define CLK_HCLK_PLL_BYPASS BIT(15) +#define CLK_HCLK_PLL_DIRECT BIT(14) +#define CLK_HCLK_PLL_FEEDBACK BIT(13) +#define CLK_HCLK_PLL_POSTDIV_MASK SBF(11, 0x3) +#define CLK_HCLK_PLL_POSTDIV_16 SBF(11, 0x3) +#define CLK_HCLK_PLL_POSTDIV_8 SBF(11, 0x2) +#define CLK_HCLK_PLL_POSTDIV_4 SBF(11, 0x1) +#define CLK_HCLK_PLL_POSTDIV_2 SBF(11, 0x0) +#define CLK_HCLK_PLL_PREDIV_MASK SBF(9, 0x3) +#define CLK_HCLK_PLL_PREDIV_4 SBF(9, 0x3) +#define CLK_HCLK_PLL_PREDIV_3 SBF(9, 0x2) +#define CLK_HCLK_PLL_PREDIV_2 SBF(9, 0x1) +#define CLK_HCLK_PLL_PREDIV_1 SBF(9, 0x0) +#define CLK_HCLK_PLL_FEEDBACK_DIV_MASK SBF(1, 0xFF) +#define CLK_HCLK_PLL_FEEDBACK_DIV(n) SBF(1, (n - 1)& 0xFF) +#define CLK_HCLK_PLL_LOCKED BIT(0)
+/* UARTn Clock Select Registers bits */ +#define CLKPWR_UART_HCLK BIT(16) +#define CLKPWR_UART_X_DIV(n) SBF(8, (n)& 0xFF) +#define CLKPWR_UART_Y_DIV(n) SBF(0, (n)& 0xFF)
- (C) Copyright 2011 by Vladimir Zapolskiyvz@mleia.com
- project.
- Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston,
- MA 02110-1301 USA
- This file should be included in board config header file.
- It supports common definitions for LPC32XX platforms
- MA 02111-1307 USA
+#define SBF(s, v) (((unsigned long)(v))<< (s)) +#define BIT(b) SBF(b, 0x01)
Those names are not really self-explanatory.
Besides, I don't think a macro is justified for just shifting values -- I prefer the shift to be explicit, or even to be precomputed.
- MA 02111-1307 USA
- u32 ir; /* Interrupt Register */
- u32 tcr; /* Timer Control Register */
- u32 tc; /* Timer Counter */
- u32 pr; /* Prescale Register */
- u32 pc; /* Prescale Counter */
- u32 mcr; /* Match Control Register */
- u32 mr[4]; /* Match Registers */
- u32 ccr; /* Capture Control Register */
- u32 cr[4]; /* Capture Registers */
- u32 emr; /* External Match Register */
- u32 reserved[12];
- u32 ctcr; /* Count Control Register */
+} timer_t;
- MA 02111-1307 USA
- union {
- union {
- union {
- u32 lcr; /* Line Control Register */
- u32 mcr; /* Modem Control Register */
- u32 lsr; /* Line Status Register */
- u32 msr; /* Modem Status Register */
- u32 rxlev; /* Receive FIFO Level Register */
+} uart_t;
Isn't this a 16550? If so, you should ise the existing 16550 driver.
14-clock? What does that mean?
+typedef struct {
- union {
- u32 level; /* FIFO Level Register */
- u32 iir; /* Interrupt ID Register */
- u32 ctrl; /* Control Register */
- u32 rate; /* Rate Control Register */
+} hsuart_t;
- u32 clkmode; /* Clock Mode Register */
- u32 loop; /* Loopback Control Register */
+} uart_control_t;
- MA 02111-1307 USA
- u32 isr; /* Interrupt Status Register */
- u32 counter; /* Counter Value Register */
- u32 mctrl; /* Match Control Register */
- u32 match0; /* Match 0 Register */
- u32 emr; /* External Match Control Register */
- u32 pulse; /* Reset Pulse Length Register */
- u32 res; /* Reset Source Register */
+} wdtim_t;
Amicalement,
Hi Albert,
thank you for reviewing this.
On 16.10.2011 19:27, Albert ARIBAUD wrote:
Hi Vladimir,
This Makefile was copied and adjusted from one of arch/arm/cpu/arm926ejs/*/Makefile
Because my contribution to it is only one line, it could be still granted to Wolfgang completely, at least no objections from my side.
+$(LIB): $(OBJS)
02111-1307 USA
- return RTC_CLK_FREQUENCY * 397;
- else
- return OSC_CLK_FREQUENCY;
- Valid frequency ranges:
- 1 * 10^6<= Fin<= 20 * 10^6
- 1 * 10^6<= Fref<= 27 * 10^6
- 156 * 10^6<= Fcco<= 320 * 10^6
- Due to these frequency constraints and divider values it could be
- shown that 32bit values used here for operations are not overflowed
- p_div = 0;
- else
- p_div = ((val& CLK_HCLK_PLL_POSTDIV_MASK)>> 11) + 1;
- do_div(fin, p_div);
- return fin;
- fout = fcco = fref * m_div;
- do_div(fout, p_div);
- } else {
- fout = fref * m_div;
- fcco = fout * p_div;
- return fout;
- u32 val;
- return get_sys_clk_rate();
- MA 02111-1307 USA
- u32 val;
- &wdt->mctrl);
- while (1) {}
- MA 02111-1307 USA
- if (enable)
- val |= bit;
- else
- val&= ~bit;
- /* Reset timer */
- /* Clear match */
- if (enable)
- writel(TIMER_TCR_COUNTER_ENABLE,&timer->tcr);
- else
Right, the body of reset_timer() shall be included into timer_init() directly.
- reset_timer();
Good point, potentially udelay() can be implemented reading values from Timer Counter register. I'll refine this part.
02111-1307 USA
- u32 reserved0[5];
- /* Internal Start Signal Sources Registers */
- /* Device Pin Start Signal Sources Registers */
- /* Clock Control Registers */
- u32 reserved1;
- u32 reserved2[3];
- u32 reserved3[4];
- u32 reserved4;
+} clk_t;
- project.
- MA 02110-1301 USA
- MA 02111-1307 USA
BIT is a one-bit field, and SBF stands for shifted bit field.
These macro are quite commonly used in the Linux kernel, so I had a hope that it could be appropriate to have them in U-boot.
In my humble opinion two functions of macro definitions are to save code space in bytes and to improve code readability, and both of them there are fulfilled.
For driver developers or additional functionality writers there are provided human-readable macro, and these two macro are merely defined for supplementary purposes. Maybe I'd be happy to find them defined in include/common.h one day, but for a moment I would like to define and expoit them in the code, which I'm going to maintain.
- MA 02111-1307 USA
- u32 reserved[12];
+} timer_t;
- MA 02111-1307 USA
- union {
- u32 rbr; /* Receiver Buffer Register */
- u32 thr; /* Transmit Holding Register */
- u32 dll; /* Divisor Latch Lower Byte */
- union {
- u32 dlm; /* Divisor Latch Higher Byte */
- u32 ier; /* Interrupt Enable Register */
- union {
- u32 fcr; /* FIFO Control Register */
+} uart_t;
According to the SoC specification LPC32xx has 4 standard UARTs, which are compatible with INS16Cx50 and in the Linux kernel it is mentioned that these UARTs are compatible with standard 8250/16550.
From my side I've already prepared a simple LPC32xx serial driver realization, but I'll review it from the perspective of your hint and probably some parts related to UART can be removed in the next patch version.
This is the second variant of UARTs found on LPC32xx, namely UART1, UART2 and UART7. Across the User manual they're referenced either as 14-clock UARTs or high-speed UARTs, see chapter 20 for details, and literally "the three 14-clock UARTs use 14 times over-sampling instead of 16 times, which is the typical over-sampling rate for a UART."
+typedef struct {
- union {
- u32 rx; /* Receiver FIFO */
- u32 tx; /* Transmitter FIFO */
+} hsuart_t;
+} uart_control_t;
- MA 02111-1307 USA
+} wdtim_t;
Thanks for review again.
Dear Vladimir Zapolskiy,
s/can/must/
Sorry, but we don't accept such macros.
No.
The code size actually remains the same. We're talking about the size of the compiled code, aren't we?
Regarding readibility: This is, at least to some extend, a matter of taste. In our opinion these macros are bad, last but not least because they hide what the code is doing, and because they are inherently unportable.
No chance. Please understand that such macros simply don't work well across architectures.
Actually the whole custom driver should be removed then.
Albert ARIBAUD
Vladimir Zapolskiy
