[U-Boot] [GIT PULL] Pull request: u-boot-imx
Hi Albert,
please pull from u-boot-imx (this time rebased on u-boot-arm/master..)
The following changes since commit d4870a914b73884f2f3e8fb082ae50f75fc01ebc:
arm, arm926ejs: Fix clear bss loop for zero length bss (2011-12-05 18:03:51 +0100)
are available in the git repository at: git://www.denx.de/git/u-boot-imx.git master
Fabio Estevam (5): mx53loco: Configure the pins as GPIOs prior to using gpio_get_value mx53ard: Configure the pins as GPIOs prior to using gpio_get_value mx53evk: Configure the pins as GPIOs prior to using gpio_get_value mx53smd: Configure the pins as GPIOs prior to using gpio_get_value mx51evk: Configure the pins as GPIOs prior to using gpio_get_value
Marek Vasut (3): MC13892: Add REGMODE0 bits definitions Efika: Configure additional regulators for HDMI output MXS: Add static annotations to dma driver
Robert Deliën (1): M28: Fix OB1 bug in GPIO driver
Simon Glass (1): mx5: Correct a warning in clock.c
Stefano Babic (2): MX: serial_mxc: cleanup removing nasty #ifdef MX35: flea3: changes due to hardware revision B
Wolfram Sang (1): apbh_dma: return error value on timeout
arch/arm/cpu/arm1136/mx31/devices.c | 4 - arch/arm/cpu/armv7/mx5/clock.c | 2 +- arch/arm/include/asm/arch-mx25/imx-regs.h | 10 +- arch/arm/include/asm/arch-mx27/imx-regs.h | 8 +- arch/arm/include/asm/arch-mx28/dma.h | 25 ---- arch/arm/include/asm/arch-mx31/imx-regs.h | 6 + arch/arm/include/asm/arch-mx35/imx-regs.h | 6 +- arch/arm/include/asm/arch-mx5/imx-regs.h | 6 +- board/CarMediaLab/flea3/flea3.c | 4 +- board/efikamx/efikamx.c | 15 ++- board/freescale/mx51evk/mx51evk.c | 3 + board/freescale/mx53ard/mx53ard.c | 3 + board/freescale/mx53evk/mx53evk.c | 3 + board/freescale/mx53loco/mx53loco.c | 3 + board/freescale/mx53smd/mx53smd.c | 1 + drivers/dma/apbh_dma.c | 211 +++++++---------------------- drivers/gpio/mxs_gpio.c | 2 +- drivers/serial/serial_mxc.c | 37 +----- include/configs/efikamx.h | 2 +- include/configs/flea3.h | 22 ++-- include/configs/imx27lite-common.h | 2 +- include/configs/imx31_litekit.h | 4 +- include/configs/imx31_phycore.h | 2 +- include/configs/mx25pdk.h | 2 +- include/configs/mx31ads.h | 4 +- include/configs/mx31pdk.h | 2 +- include/configs/mx35pdk.h | 2 +- include/configs/mx51evk.h | 2 +- include/configs/mx53ard.h | 2 +- include/configs/mx53evk.h | 2 +- include/configs/mx53loco.h | 2 +- include/configs/mx53smd.h | 2 +- include/configs/qong.h | 4 +- include/configs/tt01.h | 2 +- include/configs/tx25.h | 2 +- include/configs/vision2.h | 2 +- include/configs/zmx25.h | 2 +- include/mc13892.h | 16 +++ 38 files changed, 153 insertions(+), 276 deletions(-)
Hi Stefano,
Le 05/12/2011 18:22, Stefano Babic a écrit :
Hi Albert,
Applied tu u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Stefano Babic
