[U-Boot] [PATCH] gw_ventana: Use the generic spl_sd.cfg
gw_ventana can boot from SPI or NAND and both of these interfaces boot from the same 0x400 offset.
This means that we could simplify the code and replace the custom gw_ventana.cfg with the generic spl_sd.cfg, as it provides the same boot offset of 0x400.
Cc: Tim Harvey tharvey@gateworks.com Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/gateworks/gw_ventana/gw_ventana.cfg | 23 ----------------------- configs/gwventana_defconfig | 2 +- 2 files changed, 1 insertion(+), 24 deletions(-) delete mode 100644 board/gateworks/gw_ventana/gw_ventana.cfg
diff --git a/board/gateworks/gw_ventana/gw_ventana.cfg b/board/gateworks/gw_ventana/gw_ventana.cfg deleted file mode 100644 index dd8aa61..0000000 --- a/board/gateworks/gw_ventana/gw_ventana.cfg +++ /dev/null @@ -1,23 +0,0 @@ -/* - * Copyright (C) 2013 Gateworks Corporation - * - * SPDX-License-Identifier: GPL-2.0+ - * - * Refer doc/README.imximage for more details about how-to configure - * and create imximage boot image - * - * The syntax is taken as close as possible with the kwbimage - */ - -/* image version */ -IMAGE_VERSION 2 - -/* - * Boot Device : one of - * spi, sd, nand, sata - */ -#ifdef CONFIG_SPI_FLASH -BOOT_FROM spi -#else -BOOT_FROM nand -#endif diff --git a/configs/gwventana_defconfig b/configs/gwventana_defconfig index f185329..4cddbdd 100644 --- a/configs/gwventana_defconfig +++ b/configs/gwventana_defconfig @@ -1,4 +1,4 @@ CONFIG_SPL=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/gateworks/gw_ventana/gw_ventana.cfg,MX6QDL" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" +S:CONFIG_ARM=y +S:CONFIG_TARGET_GW_VENTANA=y
Hi Fabio, Tim
Tim, this factorize common code - I think it can harmless flow into mainline.
Best regards, Stefano Babic
Fabio Estevam
Stefano Babic
