[U-Boot] [PATCH][v3]powerpc/8xxx:Add MPH controller support in USB device-tree fixup
Add support for fixing usb mode and phy type for MPH(Multi Port Host) USB controllers in device-tree nodes. Required for socs like P3060, P5020, etc having MPH USB controller
Signed-off-by: Ramneek Mehresh ramneek.mehresh@freescale.com --- Changes for v3: - removed const* type cast for node_type - used CONFIG_HAS_FSL_MPH_USB in condition for including fdt_fixup_dr_usb()
arch/powerpc/cpu/mpc8xxx/fdt.c | 29 +++++++++++++++++++---------- include/fdt_support.h | 4 ++-- 2 files changed, 21 insertions(+), 12 deletions(-)
diff --git a/arch/powerpc/cpu/mpc8xxx/fdt.c b/arch/powerpc/cpu/mpc8xxx/fdt.c index bc1c30e..09810be 100644 --- a/arch/powerpc/cpu/mpc8xxx/fdt.c +++ b/arch/powerpc/cpu/mpc8xxx/fdt.c @@ -86,30 +86,39 @@ void ft_fixup_num_cores(void *blob) { } #endif /* defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) */
-#ifdef CONFIG_HAS_FSL_DR_USB +#if defined(CONFIG_HAS_FSL_DR_USB) || defined(CONFIG_HAS_FSL_MPH_USB) static int fdt_fixup_usb_mode_phy_type(void *blob, const char *mode, const char *phy_type, int start_offset) { - const char *compat = "fsl-usb2-dr"; + const char *compat_dr = "fsl-usb2-dr"; + const char *compat_mph = "fsl-usb2-mph"; const char *prop_mode = "dr_mode"; const char *prop_type = "phy_type"; + const char *node_type = NULL; int node_offset; int err;
node_offset = fdt_node_offset_by_compatible(blob, - start_offset, compat); + start_offset, compat_mph); if (node_offset < 0) { - printf("WARNING: could not find compatible node %s: %s.\n", - compat, fdt_strerror(node_offset)); - return -1; - } + node_offset = fdt_node_offset_by_compatible(blob, + start_offset, compat_dr); + if (node_offset < 0) { + printf("WARNING: could not find compatible" + " node %s or %s: %s.\n", compat_mph, + compat_dr, fdt_strerror(node_offset)); + return -1; + } else + node_type = compat_dr; + } else + node_type = compat_mph;
if (mode) { err = fdt_setprop(blob, node_offset, prop_mode, mode, strlen(mode) + 1); if (err < 0) printf("WARNING: could not set %s for %s: %s.\n", - prop_mode, compat, fdt_strerror(err)); + prop_mode, node_type, fdt_strerror(err)); }
if (phy_type) { @@ -117,7 +126,7 @@ static int fdt_fixup_usb_mode_phy_type(void *blob, const char *mode, strlen(phy_type) + 1); if (err < 0) printf("WARNING: could not set %s for %s: %s.\n", - prop_type, compat, fdt_strerror(err)); + prop_type, node_type, fdt_strerror(err)); }
return node_offset; @@ -180,7 +189,7 @@ void fdt_fixup_dr_usb(void *blob, bd_t *bd) fdt_fixup_usb_mode_phy_type(blob, mode, phy_type, usb_off); } } -#endif /* CONFIG_HAS_FSL_DR_USB */ +#endif /* defined(CONFIG_HAS_FSL_DR_USB) || defined(CONFIG_HAS_FSL_MPH_USB) */
/* * update crypto node properties to a specified revision of the SEC diff --git a/include/fdt_support.h b/include/fdt_support.h index cef3c65..4b9f84a 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -61,11 +61,11 @@ int fdt_find_and_setprop(void *fdt, const char *node, const char *prop, const void *val, int len, int create); void fdt_fixup_qe_firmware(void *fdt);
-#ifdef CONFIG_HAS_FSL_DR_USB +#if defined(CONFIG_HAS_FSL_DR_USB) || defined(CONFIG_HAS_FSL_MPH_USB) void fdt_fixup_dr_usb(void *blob, bd_t *bd); #else static inline void fdt_fixup_dr_usb(void *blob, bd_t *bd) {} -#endif /* CONFIG_HAS_FSL_DR_USB */ +#endif /* defined(CONFIG_HAS_FSL_DR_USB) || defined(CONFIG_HAS_FSL_MPH_USB) */
#if defined(CONFIG_SYS_FSL_SEC_COMPAT) void fdt_fixup_crypto_node(void *blob, int sec_rev);
Ramneek Mehresh
