[PATCH v2 1/2] phy: zynqmp: Add support for sata and DP phy initialization
DP is untested but just c&p from Linux driver. Sata is tested on kv260-revA board which has SATA connector populated.
Signed-off-by: Michal Simek michal.simek@xilinx.com
Changes in v2: Revoke default case - reported by T Karthik Reddy
drivers/phy/phy-zynqmp.c | 30 ++++++++++++++++++++++++++++-- 1 file changed, 28 insertions(+), 2 deletions(-)
diff --git a/drivers/phy/phy-zynqmp.c b/drivers/phy/phy-zynqmp.c index 9dc3d426a3d3..08c1b6efcfdc 100644 --- a/drivers/phy/phy-zynqmp.c +++ b/drivers/phy/phy-zynqmp.c @@ -373,6 +373,29 @@ static void xpsgtr_bypass_scrambler_8b10b(struct xpsgtr_phy *gtr_phy) xpsgtr_write_phy(gtr_phy, L0_TX_DIG_61, L0_TM_DISABLE_SCRAMBLE_ENCODER); }
+/* DP-specific initialization. */ +static void xpsgtr_phy_init_dp(struct xpsgtr_phy *gtr_phy) +{ + xpsgtr_write_phy(gtr_phy, L0_TXPMD_TM_45, + L0_TXPMD_TM_45_OVER_DP_MAIN | + L0_TXPMD_TM_45_ENABLE_DP_MAIN | + L0_TXPMD_TM_45_OVER_DP_POST1 | + L0_TXPMD_TM_45_OVER_DP_POST2 | + L0_TXPMD_TM_45_ENABLE_DP_POST2); + xpsgtr_write_phy(gtr_phy, L0_TX_ANA_TM_118, + L0_TX_ANA_TM_118_FORCE_17_0); +} + +/* SATA-specific initialization. */ +static void xpsgtr_phy_init_sata(struct xpsgtr_phy *gtr_phy) +{ + struct xpsgtr_dev *gtr_dev = gtr_phy->dev; + + xpsgtr_bypass_scrambler_8b10b(gtr_phy); + + writel(gtr_phy->lane, gtr_dev->siou + SATA_CONTROL_OFFSET); +} + /* SGMII-specific initialization. */ static void xpsgtr_phy_init_sgmii(struct xpsgtr_phy *gtr_phy) { @@ -427,9 +450,12 @@ static int xpsgtr_init(struct phy *x) case ICM_PROTOCOL_SGMII: xpsgtr_phy_init_sgmii(gtr_phy); break; - case ICM_PROTOCOL_DP: case ICM_PROTOCOL_SATA: - return -EINVAL; + xpsgtr_phy_init_sata(gtr_phy); + break; + case ICM_PROTOCOL_DP: + xpsgtr_phy_init_dp(gtr_phy); + break; }
dev_dbg(gtr_dev->dev, "lane %u (type %u, protocol %u): init done\n",
Add phy and reset support for ceva sata IP. Phy and reset are optional properties that's why detect if description is available. If not just continue with operation. This code was tested on Xilinx Kria SOM kv260-revA with sata connector populated.
Signed-off-by: Michal Simek michal.simek@xilinx.com Reviewed-by: Vladimir Oltean vladimir.oltean@nxp.com ---
Changes in v2: - Add Vladimir's tag
drivers/ata/sata_ceva.c | 44 +++++++++++++++++++++++++++++++++++++++++ 1 file changed, 44 insertions(+)
diff --git a/drivers/ata/sata_ceva.c b/drivers/ata/sata_ceva.c index b71f10223da8..43bcc59cd282 100644 --- a/drivers/ata/sata_ceva.c +++ b/drivers/ata/sata_ceva.c @@ -6,9 +6,12 @@ #include <common.h> #include <dm.h> #include <ahci.h> +#include <generic-phy.h> #include <log.h> +#include <reset.h> #include <scsi.h> #include <asm/io.h> +#include <dm/device_compat.h> #include <linux/ioport.h>
/* Vendor Specific Register Offsets */ @@ -181,6 +184,47 @@ static int sata_ceva_bind(struct udevice *dev) static int sata_ceva_probe(struct udevice *dev) { struct ceva_sata_priv *priv = dev_get_priv(dev); + struct phy phy; + int ret; + struct reset_ctl_bulk resets; + + ret = generic_phy_get_by_index(dev, 0, &phy); + if (!ret) { + dev_dbg(dev, "Perform PHY initialization\n"); + ret = generic_phy_init(&phy); + if (ret) + return ret; + } else if (ret != -ENOENT) { + dev_dbg(dev, "could not get phy (err %d)\n", ret); + return ret; + } + + /* reset is optional */ + ret = reset_get_bulk(dev, &resets); + if (ret && ret != -ENOTSUPP && ret != -ENOENT) { + dev_dbg(dev, "Getting reset fails (err %d)\n", ret); + return ret; + } + + /* Just trigger reset when reset is specified */ + if (!ret) { + dev_dbg(dev, "Perform IP reset\n"); + ret = reset_deassert_bulk(&resets); + if (ret) { + dev_dbg(dev, "Reset fails (err %d)\n", ret); + reset_release_bulk(&resets); + return ret; + } + } + + if (phy.dev) { + dev_dbg(dev, "Perform PHY power on\n"); + ret = generic_phy_power_on(&phy); + if (ret) { + dev_dbg(dev, "PHY power on failed (err %d)\n", ret); + return ret; + } + }
ceva_init_sata(priv);
po 7. 2. 2022 v 10:36 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
return -EINVAL;
break;
break; } dev_dbg(gtr_dev->dev, "lane %u (type %u, protocol %u): init done\n",
-- 2.35.0
applied. M
Michal Simek
Michal Simek
