[PATCH v3 00/20] TI/Cadence: Add Sierra/Torrent SERDES driver
Patch series adds Sierra and Torrent SERDES driver for the SERDES used in TI's K3 platforms. This SERDES is used by USB3, PCIe and Ethernet. This series is mostly an adaptation of drivers added in upstream Linux kernel.
Changes from v2: 1) Re-worked "Handle gracefully NULL pointers" to fix Simons comments 2) Ported the part that allows creating clocks without explicit sub-nodes in DT from the upstream linux kernel.
Changes from v1: 1) Fixed string comparison strncmp() to remove "==" 2) Added a test for node name comparison to ignore unit address in test/dm 3) Added better commit message in "drivers: reset: Handle gracefully NULL pointers"
Alan Douglas (1): phy: cadence: Add driver for Sierra PHY
Aswath Govindraju (7): dt-bindings: phy: Add definitions for additional phy types phy: cadence: Add driver for Torrent SERDES board: ti: j721e: Add support for probing and configuring Torrent serdes on J7200 arm: dts: k3-j7200-main: Add DT node for torrent serdes arm: dts: k3-j7200-common-proc-board: Enable SERDES DT arm: dts: k3-j7200-common-proc-board-u-boot: Add u-boot tags for torrent serdes configs: j7200_evm_a72_defconfig: Add config for torrent serdes and common clock framework
Jean-Jacques Hiblot (2): phy: ti: j721e-wiz: Add support for WIZ module present in TI J721E SoC configs: j721e_evm_a72: Enable the drivers required for the USB3 support
Kishon Vijay Abraham I (10): dm: core: Add helper to compare node names dm: test: Add test case to check node name ignoring unit address drivers: reset: Handle gracefully NULL pointers dt-bindings: phy: Add defines for AM64 SERDES Wrapper dt-bindings: phy: cadence-torrent: Add defines for refclk driver dt-bindings: ti-serdes-mux: Add defines for AM64 SoC usb: cdns3: cdns3-ti: Fix clk_get_by_name() to get the correct name ARM: dts: k3-j721e: Add the entries required for USB3 support on USB0 env: ti: j721e-evm: Add env variable to power on & reset QSGMII PHY in J7200 EVM configs: j7200_evm_a72: Enhance bootcmd to configure ethernet PHY
.../k3-j7200-common-proc-board-u-boot.dtsi | 12 + arch/arm/dts/k3-j7200-common-proc-board.dts | 23 + arch/arm/dts/k3-j7200-main.dtsi | 63 + .../k3-j721e-common-proc-board-u-boot.dtsi | 19 +- board/ti/j721e/evm.c | 34 +- configs/j7200_evm_a72_defconfig | 9 +- configs/j721e_evm_a72_defconfig | 6 + drivers/core/ofnode.c | 13 + drivers/phy/Kconfig | 3 + drivers/phy/Makefile | 2 + drivers/phy/cadence/Kconfig | 11 + drivers/phy/cadence/Makefile | 2 + drivers/phy/cadence/phy-cadence-sierra.c | 757 +++++ drivers/phy/cadence/phy-cadence-torrent.c | 2468 +++++++++++++++++ drivers/phy/ti/Kconfig | 9 + drivers/phy/ti/Makefile | 1 + drivers/phy/ti/phy-j721e-wiz.c | 1154 ++++++++ drivers/reset/reset-uclass.c | 35 +- drivers/usb/cdns3/cdns3-ti.c | 2 +- include/configs/j721e_evm.h | 16 +- include/dm/ofnode.h | 10 + include/dt-bindings/mux/ti-serdes.h | 5 + include/dt-bindings/phy/phy-cadence.h | 20 + include/dt-bindings/phy/phy-ti.h | 21 + include/dt-bindings/phy/phy.h | 1 + test/dm/core.c | 14 + 26 files changed, 4700 insertions(+), 10 deletions(-) create mode 100644 drivers/phy/cadence/Kconfig create mode 100644 drivers/phy/cadence/Makefile create mode 100644 drivers/phy/cadence/phy-cadence-sierra.c create mode 100644 drivers/phy/cadence/phy-cadence-torrent.c create mode 100644 drivers/phy/ti/Kconfig create mode 100644 drivers/phy/ti/Makefile create mode 100644 drivers/phy/ti/phy-j721e-wiz.c create mode 100644 include/dt-bindings/phy/phy-cadence.h create mode 100644 include/dt-bindings/phy/phy-ti.h
Add helper to compare node names.
Signed-off-by: Kishon Vijay Abraham I kishon@ti.com --- drivers/core/ofnode.c | 13 +++++++++++++ include/dm/ofnode.h | 10 ++++++++++ 2 files changed, 23 insertions(+)
diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index d50533338e..2a5b12040c 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -18,6 +18,19 @@ #include <linux/ioport.h> #include <asm/global_data.h>
+bool ofnode_name_eq(ofnode node, const char *name) +{ + const char *node_name; + size_t len; + + assert(ofnode_valid(node)); + + node_name = ofnode_get_name(node); + len = strchrnul(node_name, '@') - node_name; + + return (strlen(name) == len) && !strncmp(node_name, name, len); +} + int ofnode_read_u32(ofnode node, const char *propname, u32 *outp) { return ofnode_read_u32_index(node, propname, 0, outp); diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index 8a69fd87da..ca98f7237c 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -231,6 +231,16 @@ static inline ofnode ofnode_root(void) return node; }
+/** + * ofnode_name_eq() - Check if the node name is equivalent to a given name + * ignoring the unit address + * + * @node: valid node reference that has to be compared + * @name: name that has to be compared with the node name + * @return true if matches, false if it doesn't match + */ +bool ofnode_name_eq(ofnode node, const char *name); + /** * ofnode_read_u32() - Read a 32-bit integer from a property *
Is there no change to last time?
Add test to check node name ignoring unit address.
Signed-off-by: Kishon Vijay Abraham I kishon@ti.com Reviewed-by: Simon Glass sjg@chromium.org --- test/dm/core.c | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/test/dm/core.c b/test/dm/core.c index 2210345dd1..e83f71f767 100644 --- a/test/dm/core.c +++ b/test/dm/core.c @@ -177,6 +177,20 @@ static int dm_test_autobind_uclass_pdata_alloc(struct unit_test_state *uts) } DM_TEST(dm_test_autobind_uclass_pdata_alloc, UT_TESTF_SCAN_PDATA);
+/* compare node names ignoring the unit address */ +static int dm_test_compare_node_name(struct unit_test_state *uts) +{ + ofnode node; + + node = ofnode_path("/mmio-bus@0"); + ut_assert(ofnode_valid(node)); + ut_assert(ofnode_name_eq(node, "mmio-bus")); + + return 0; +} + +DM_TEST(dm_test_compare_node_name, UT_TESTF_SCAN_PDATA); + /* Test that binding with uclass plat setting occurs correctly */ static int dm_test_autobind_uclass_pdata_valid(struct unit_test_state *uts) {
The reset framework provides devm_reset_control_get_optional() which can return NULL (not an error case). So all the other reset_ops should handle NULL gracefully. Prepare the way for a managed reset API by handling NULL pointers without crashing nor failing.
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com Signed-off-by: Kishon Vijay Abraham I kishon@ti.com --- drivers/reset/reset-uclass.c | 35 ++++++++++++++++++++++++++++++----- 1 file changed, 30 insertions(+), 5 deletions(-)
diff --git a/drivers/reset/reset-uclass.c b/drivers/reset/reset-uclass.c index ac89eaf098..18dfe06d1c 100644 --- a/drivers/reset/reset-uclass.c +++ b/drivers/reset/reset-uclass.c @@ -162,7 +162,12 @@ int reset_get_by_name(struct udevice *dev, const char *name,
int reset_request(struct reset_ctl *reset_ctl) { - struct reset_ops *ops = reset_dev_ops(reset_ctl->dev); + struct reset_ops *ops; + + if (!reset_ctl) + return 0; + + ops = reset_dev_ops(reset_ctl->dev);
debug("%s(reset_ctl=%p)\n", __func__, reset_ctl);
@@ -171,7 +176,12 @@ int reset_request(struct reset_ctl *reset_ctl)
int reset_free(struct reset_ctl *reset_ctl) { - struct reset_ops *ops = reset_dev_ops(reset_ctl->dev); + struct reset_ops *ops; + + if (!reset_ctl) + return 0; + + ops = reset_dev_ops(reset_ctl->dev);
@@ -180,7 +190,12 @@ int reset_free(struct reset_ctl *reset_ctl)
int reset_assert(struct reset_ctl *reset_ctl) { - struct reset_ops *ops = reset_dev_ops(reset_ctl->dev); + struct reset_ops *ops; + + if (!reset_ctl) + return 0; + + ops = reset_dev_ops(reset_ctl->dev);
@@ -202,7 +217,12 @@ int reset_assert_bulk(struct reset_ctl_bulk *bulk)
int reset_deassert(struct reset_ctl *reset_ctl) { - struct reset_ops *ops = reset_dev_ops(reset_ctl->dev); + struct reset_ops *ops; + + if (!reset_ctl) + return 0; + + ops = reset_dev_ops(reset_ctl->dev);
@@ -224,7 +244,12 @@ int reset_deassert_bulk(struct reset_ctl_bulk *bulk)
int reset_status(struct reset_ctl *reset_ctl) { - struct reset_ops *ops = reset_dev_ops(reset_ctl->dev); + struct reset_ops *ops; + + if (!reset_ctl) + return 0; + + ops = reset_dev_ops(reset_ctl->dev);
Hi Kishon,
I am still not a fan of this. There is no way to know whether the reset API call actually did anything. Normally we return -EINVAL or something like that when the value is invalid (e.g. see GPIO uclass).
The function you mention says: * Returns a struct reset_ctl or a dummy reset controller if it failed.
But it does not appear to do that?
Hi Simon,
On 04/05/21 10:28 pm, Simon Glass wrote:
Hi Kishon,
The reset modification is more in-line with how clk uclass is designed.
There every API first checks if the clock is valid and returns 0 (will be the case for optional clocks) if (!clk_valid(clk)) return 0;
If you don't prefer this approach, I'll drop this patch and handle it appropriately in the client driver (serdes driver). Please let me know.
Right, looks like it's incorrect from when the patch was actually introduced. It was returning "NULL" for optional resets.
commit 139e4a1cbe60de96d4febbc6db5882929801ca46 Author: Jean-Jacques Hiblot jjhiblot@ti.com Date: Wed Sep 9 15:37:03 2020 +0530
drivers: reset: Add a managed API to get reset controllers from the DT
Thanks Kishon
Hi Kishon,
On Tue, 4 May 2021 at 21:25, Kishon Vijay Abraham I kishon@ti.com wrote:
Hi Simon,
Hi Kishon,
Yes I see that with clk. IMO the return code is incorrect there also, since it should be -ENOENT or something like that, to indicate that there is actually no clock.
The clk.h header gives no indication that it accepts a NULL clock. So here is what I think:
1. Update clk_valid() to require clk to be a valid pointer, so it is considered invalid only if clk-dev.
2. Update the reset 'managed API' to return an empty reset record instead of NULL.
3. Your problem goes away, and (I think) we are still compatible with the linux API.
OK. So what should it be?
Hi Simon,
On 06/05/21 5:07 am, Simon Glass wrote:
Hi Kishon,
Hi Simon,
Hi Kishon,
- Update clk_valid() to require clk to be a valid pointer, so it is
So for API's like clk_enable(), clk_disable(), should it return 0 or -ENOENT; i.e if clk is valid and clk->dev is NULL?
- Update the reset 'managed API' to return an empty reset record
instead of NULL.
Okay, something like below?
--- a/drivers/reset/reset-uclass.c +++ b/drivers/reset/reset-uclass.c @@ -326,9 +326,6 @@ struct reset_ctl *devm_reset_control_get_optional(struct udevice *dev, { struct reset_ctl *r = devm_reset_control_get(dev, id);
- if (IS_ERR(r)) - return NULL; - return r; }
The only thing to note here is _get_optional() is a wrapper to _get() with no modification.
- Your problem goes away, and (I think) we are still compatible with
the linux API.
I meant the comment in header is incorrect since it was returning NULL if it failed.
Thanks, Kishon
Hi Kishon,
On Thu, 6 May 2021 at 07:09, Kishon Vijay Abraham I kishon@ti.com wrote:
Hi Simon,
Hi Kishon,
Hi Simon,
Hi Kishon,
instead of NULL.
if (IS_ERR(r))
return NULL;
return r;
OK.
the linux API.
OK, well then you could add a patch for it. The problem with a pointer value is that you cannot both communicate an error and return a valid pointer.
Add definitions for additional phy types that's used specifically for Torrent SERDES.
Signed-off-by: Aswath Govindraju a-govindraju@ti.com Signed-off-by: Kishon Vijay Abraham I kishon@ti.com --- include/dt-bindings/phy/phy.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/dt-bindings/phy/phy.h b/include/dt-bindings/phy/phy.h index 7e657da454..d3714edd4b 100644 --- a/include/dt-bindings/phy/phy.h +++ b/include/dt-bindings/phy/phy.h @@ -19,5 +19,6 @@ #define PHY_TYPE_DP 6 #define PHY_TYPE_XPCS 7 #define PHY_TYPE_SGMII 8 +#define PHY_TYPE_QSGMII 9
#endif /* _DT_BINDINGS_PHY */
Add defines for AM64 SERDES Wrapper.
Signed-off-by: Kishon Vijay Abraham I kishon@ti.com --- include/dt-bindings/phy/phy-ti.h | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+) create mode 100644 include/dt-bindings/phy/phy-ti.h
diff --git a/include/dt-bindings/phy/phy-ti.h b/include/dt-bindings/phy/phy-ti.h new file mode 100644 index 0000000000..ad955d3a56 --- /dev/null +++ b/include/dt-bindings/phy/phy-ti.h @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * This header provides constants for TI SERDES. + */ + +#ifndef _DT_BINDINGS_TI_SERDES +#define _DT_BINDINGS_TI_SERDES + +/* Clock index for output clocks from WIZ */ + +/* MUX Clocks */ +#define TI_WIZ_PLL0_REFCLK 0 +#define TI_WIZ_PLL1_REFCLK 1 +#define TI_WIZ_REFCLK_DIG 2 + +/* Reserve index here for future additions */ + +/* MISC Clocks */ +#define TI_WIZ_PHY_EN_REFCLK 16 + +#endif /* _DT_BINDINGS_TI_SERDES */
Add defines for refclk driver used to route the refclk out of torrent SERDES.
Signed-off-by: Kishon Vijay Abraham I kishon@ti.com --- include/dt-bindings/phy/phy-cadence.h | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+) create mode 100644 include/dt-bindings/phy/phy-cadence.h
diff --git a/include/dt-bindings/phy/phy-cadence.h b/include/dt-bindings/phy/phy-cadence.h new file mode 100644 index 0000000000..4652bcb862 --- /dev/null +++ b/include/dt-bindings/phy/phy-cadence.h @@ -0,0 +1,20 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * This header provides constants for Cadence SERDES. + */ + +#ifndef _DT_BINDINGS_CADENCE_SERDES_H +#define _DT_BINDINGS_CADENCE_SERDES_H + +/* Torrent */ +#define TORRENT_SERDES_NO_SSC 0 +#define TORRENT_SERDES_EXTERNAL_SSC 1 +#define TORRENT_SERDES_INTERNAL_SSC 2 + +#define CDNS_TORRENT_REFCLK_DRIVER 0 + +/* Sierra */ +#define CDNS_SIERRA_PLL_CMNLC 0 +#define CDNS_SIERRA_PLL_CMNLC1 1 + +#endif /* _DT_BINDINGS_CADENCE_SERDES_H */
AM64 has a single lane SERDES which can be configured to be used with either PCIe or USB. Define the possilbe values for the SERDES function in AM64 SoC here.
Signed-off-by: Kishon Vijay Abraham I kishon@ti.com --- include/dt-bindings/mux/ti-serdes.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/include/dt-bindings/mux/ti-serdes.h b/include/dt-bindings/mux/ti-serdes.h index 9047ec6bd3..d417b9268b 100644 --- a/include/dt-bindings/mux/ti-serdes.h +++ b/include/dt-bindings/mux/ti-serdes.h @@ -90,4 +90,9 @@ #define J7200_SERDES0_LANE3_USB 0x2 #define J7200_SERDES0_LANE3_IP4_UNUSED 0x3
+/* AM64 */ + +#define AM64_SERDES0_LANE0_PCIE0 0x0 +#define AM64_SERDES0_LANE0_USB 0x1 + #endif /* _DT_BINDINGS_MUX_TI_SERDES */
Add a Sierra PHY driver with PCIe and USB support. This driver is a port from the mainline linux driver.
The PHY has multiple lanes, which can be configured into groups, and a generic PHY device is created for each group.
There are two resets controlling the overall PHY block, one to enable the APB interface for programming registers, and another to enable the PHY itself. Additionally there are resets for each PHY lane.
The PHY can be configured in hardware to read register settings from ROM, or they can be written by the driver.
The sequence of operation on startup is to enable the APB bus, write the PHY registers (if required) for each lane group, and then enable the PHY. Each group of lanes can then be individually controlled using the power_on()/ power_off() function for that generic PHY
One difference with the linux driver is that the PHY is always reset after it is powered-on. This is because role switching is not supported in u-boot and the cable orientation is handled by the PHY reset.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Signed-off-by: Alan Douglas adouglas@cadence.com Signed-off-by: Kishon Vijay Abraham I kishon@ti.com Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- drivers/phy/Kconfig | 2 + drivers/phy/Makefile | 1 + drivers/phy/cadence/Kconfig | 5 + drivers/phy/cadence/Makefile | 1 + drivers/phy/cadence/phy-cadence-sierra.c | 757 +++++++++++++++++++++++ 5 files changed, 766 insertions(+) create mode 100644 drivers/phy/cadence/Kconfig create mode 100644 drivers/phy/cadence/Makefile create mode 100644 drivers/phy/cadence/phy-cadence-sierra.c
diff --git a/drivers/phy/Kconfig b/drivers/phy/Kconfig index 008186a10d..9208e430a6 100644 --- a/drivers/phy/Kconfig +++ b/drivers/phy/Kconfig @@ -269,4 +269,6 @@ config PHY_MTK_TPHY so you can easily distinguish them by banks layout.
source "drivers/phy/rockchip/Kconfig" +source "drivers/phy/cadence/Kconfig" + endmenu diff --git a/drivers/phy/Makefile b/drivers/phy/Makefile index 3c4a673a83..4736c5eadb 100644 --- a/drivers/phy/Makefile +++ b/drivers/phy/Makefile @@ -31,3 +31,4 @@ obj-$(CONFIG_MT7620_USB_PHY) += mt7620-usb-phy.o obj-$(CONFIG_MT76X8_USB_PHY) += mt76x8-usb-phy.o obj-$(CONFIG_PHY_DA8XX_USB) += phy-da8xx-usb.o obj-$(CONFIG_PHY_MTK_TPHY) += phy-mtk-tphy.o +obj-y += cadence/ diff --git a/drivers/phy/cadence/Kconfig b/drivers/phy/cadence/Kconfig new file mode 100644 index 0000000000..18a04819f5 --- /dev/null +++ b/drivers/phy/cadence/Kconfig @@ -0,0 +1,5 @@ +config PHY_CADENCE_SIERRA + tristate "Cadence Sierra PHY Driver" + depends on DM_RESET + help + Enable this to support the Cadence Sierra PHY driver diff --git a/drivers/phy/cadence/Makefile b/drivers/phy/cadence/Makefile new file mode 100644 index 0000000000..d57856152a --- /dev/null +++ b/drivers/phy/cadence/Makefile @@ -0,0 +1 @@ +obj-$(CONFIG_$(SPL_)PHY_CADENCE_SIERRA) += phy-cadence-sierra.o diff --git a/drivers/phy/cadence/phy-cadence-sierra.c b/drivers/phy/cadence/phy-cadence-sierra.c new file mode 100644 index 0000000000..66c671aded --- /dev/null +++ b/drivers/phy/cadence/phy-cadence-sierra.c @@ -0,0 +1,757 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Cadence Sierra PHY Driver + * + * Based on the linux driver provided by Cadence + * + * Copyright (c) 2018 Cadence Design Systems + * Author: Alan Douglas adouglas@cadence.com + * + * Copyright (C) 2019 Texas Instruments Incorporated - http://www.ti.com/ + * Jean-Jacques Hiblot jjhiblot@ti.com + * + */ +#include <common.h> +#include <clk.h> +#include <generic-phy.h> +#include <reset.h> +#include <dm/device.h> +#include <dm/device-internal.h> +#include <dm/device_compat.h> +#include <dm/lists.h> +#include <dm/read.h> +#include <dm/uclass.h> +#include <dm/devres.h> +#include <linux/io.h> +#include <dt-bindings/phy/phy.h> +#include <regmap.h> + +/* PHY register offsets */ +#define SIERRA_COMMON_CDB_OFFSET 0x0 +#define SIERRA_MACRO_ID_REG 0x0 +#define SIERRA_CMN_PLLLC_MODE_PREG 0x48 +#define SIERRA_CMN_PLLLC_LF_COEFF_MODE1_PREG 0x49 +#define SIERRA_CMN_PLLLC_LF_COEFF_MODE0_PREG 0x4A +#define SIERRA_CMN_PLLLC_LOCK_CNTSTART_PREG 0x4B +#define SIERRA_CMN_PLLLC_BWCAL_MODE1_PREG 0x4F +#define SIERRA_CMN_PLLLC_BWCAL_MODE0_PREG 0x50 +#define SIERRA_CMN_PLLLC_SS_TIME_STEPSIZE_MODE_PREG 0x62 + +#define SIERRA_LANE_CDB_OFFSET(ln, offset) \ + (0x4000 + ((ln) * (0x800 >> (2 - (offset))))) + +#define SIERRA_DET_STANDEC_A_PREG 0x000 +#define SIERRA_DET_STANDEC_B_PREG 0x001 +#define SIERRA_DET_STANDEC_C_PREG 0x002 +#define SIERRA_DET_STANDEC_D_PREG 0x003 +#define SIERRA_DET_STANDEC_E_PREG 0x004 +#define SIERRA_PSM_LANECAL_DLY_A1_RESETS_PREG 0x008 +#define SIERRA_PSM_A0IN_TMR_PREG 0x009 +#define SIERRA_PSM_DIAG_PREG 0x015 +#define SIERRA_PSC_TX_A0_PREG 0x028 +#define SIERRA_PSC_TX_A1_PREG 0x029 +#define SIERRA_PSC_TX_A2_PREG 0x02A +#define SIERRA_PSC_TX_A3_PREG 0x02B +#define SIERRA_PSC_RX_A0_PREG 0x030 +#define SIERRA_PSC_RX_A1_PREG 0x031 +#define SIERRA_PSC_RX_A2_PREG 0x032 +#define SIERRA_PSC_RX_A3_PREG 0x033 +#define SIERRA_PLLCTRL_SUBRATE_PREG 0x03A +#define SIERRA_PLLCTRL_GEN_D_PREG 0x03E +#define SIERRA_PLLCTRL_CPGAIN_MODE_PREG 0x03F +#define SIERRA_PLLCTRL_STATUS_PREG 0x044 +#define SIERRA_CLKPATH_BIASTRIM_PREG 0x04B +#define SIERRA_DFE_BIASTRIM_PREG 0x04C +#define SIERRA_DRVCTRL_ATTEN_PREG 0x06A +#define SIERRA_CLKPATHCTRL_TMR_PREG 0x081 +#define SIERRA_RX_CREQ_FLTR_A_MODE3_PREG 0x085 +#define SIERRA_RX_CREQ_FLTR_A_MODE2_PREG 0x086 +#define SIERRA_RX_CREQ_FLTR_A_MODE1_PREG 0x087 +#define SIERRA_RX_CREQ_FLTR_A_MODE0_PREG 0x088 +#define SIERRA_CREQ_CCLKDET_MODE01_PREG 0x08E +#define SIERRA_RX_CTLE_MAINTENANCE_PREG 0x091 +#define SIERRA_CREQ_FSMCLK_SEL_PREG 0x092 +#define SIERRA_CREQ_EQ_CTRL_PREG 0x093 +#define SIERRA_CREQ_SPARE_PREG 0x096 +#define SIERRA_CREQ_EQ_OPEN_EYE_THRESH_PREG 0x097 +#define SIERRA_CTLELUT_CTRL_PREG 0x098 +#define SIERRA_DFE_ECMP_RATESEL_PREG 0x0C0 +#define SIERRA_DFE_SMP_RATESEL_PREG 0x0C1 +#define SIERRA_DEQ_PHALIGN_CTRL 0x0C4 +#define SIERRA_DEQ_CONCUR_CTRL1_PREG 0x0C8 +#define SIERRA_DEQ_CONCUR_CTRL2_PREG 0x0C9 +#define SIERRA_DEQ_EPIPWR_CTRL2_PREG 0x0CD +#define SIERRA_DEQ_FAST_MAINT_CYCLES_PREG 0x0CE +#define SIERRA_DEQ_ERRCMP_CTRL_PREG 0x0D0 +#define SIERRA_DEQ_OFFSET_CTRL_PREG 0x0D8 +#define SIERRA_DEQ_GAIN_CTRL_PREG 0x0E0 +#define SIERRA_DEQ_VGATUNE_CTRL_PREG 0x0E1 +#define SIERRA_DEQ_GLUT0 0x0E8 +#define SIERRA_DEQ_GLUT1 0x0E9 +#define SIERRA_DEQ_GLUT2 0x0EA +#define SIERRA_DEQ_GLUT3 0x0EB +#define SIERRA_DEQ_GLUT4 0x0EC +#define SIERRA_DEQ_GLUT5 0x0ED +#define SIERRA_DEQ_GLUT6 0x0EE +#define SIERRA_DEQ_GLUT7 0x0EF +#define SIERRA_DEQ_GLUT8 0x0F0 +#define SIERRA_DEQ_GLUT9 0x0F1 +#define SIERRA_DEQ_GLUT10 0x0F2 +#define SIERRA_DEQ_GLUT11 0x0F3 +#define SIERRA_DEQ_GLUT12 0x0F4 +#define SIERRA_DEQ_GLUT13 0x0F5 +#define SIERRA_DEQ_GLUT14 0x0F6 +#define SIERRA_DEQ_GLUT15 0x0F7 +#define SIERRA_DEQ_GLUT16 0x0F8 +#define SIERRA_DEQ_ALUT0 0x108 +#define SIERRA_DEQ_ALUT1 0x109 +#define SIERRA_DEQ_ALUT2 0x10A +#define SIERRA_DEQ_ALUT3 0x10B +#define SIERRA_DEQ_ALUT4 0x10C +#define SIERRA_DEQ_ALUT5 0x10D +#define SIERRA_DEQ_ALUT6 0x10E +#define SIERRA_DEQ_ALUT7 0x10F +#define SIERRA_DEQ_ALUT8 0x110 +#define SIERRA_DEQ_ALUT9 0x111 +#define SIERRA_DEQ_ALUT10 0x112 +#define SIERRA_DEQ_ALUT11 0x113 +#define SIERRA_DEQ_ALUT12 0x114 +#define SIERRA_DEQ_ALUT13 0x115 +#define SIERRA_DEQ_DFETAP_CTRL_PREG 0x128 +#define SIERRA_DFE_EN_1010_IGNORE_PREG 0x134 +#define SIERRA_DEQ_TAU_CTRL1_SLOW_MAINT_PREG 0x150 +#define SIERRA_DEQ_TAU_CTRL2_PREG 0x151 +#define SIERRA_DEQ_PICTRL_PREG 0x161 +#define SIERRA_CPICAL_TMRVAL_MODE1_PREG 0x170 +#define SIERRA_CPICAL_TMRVAL_MODE0_PREG 0x171 +#define SIERRA_CPICAL_PICNT_MODE1_PREG 0x174 +#define SIERRA_CPI_OUTBUF_RATESEL_PREG 0x17C +#define SIERRA_CPICAL_RES_STARTCODE_MODE23_PREG 0x183 +#define SIERRA_LFPSDET_SUPPORT_PREG 0x188 +#define SIERRA_LFPSFILT_NS_PREG 0x18A +#define SIERRA_LFPSFILT_RD_PREG 0x18B +#define SIERRA_LFPSFILT_MP_PREG 0x18C +#define SIERRA_SIGDET_SUPPORT_PREG 0x190 +#define SIERRA_SDFILT_H2L_A_PREG 0x191 +#define SIERRA_SDFILT_L2H_PREG 0x193 +#define SIERRA_RXBUFFER_CTLECTRL_PREG 0x19E +#define SIERRA_RXBUFFER_RCDFECTRL_PREG 0x19F +#define SIERRA_RXBUFFER_DFECTRL_PREG 0x1A0 +#define SIERRA_DEQ_TAU_CTRL1_FAST_MAINT_PREG 0x14F +#define SIERRA_DEQ_TAU_CTRL1_SLOW_MAINT_PREG 0x150 + +#define SIERRA_PHY_CONFIG_CTRL_OFFSET 0xc000 +#define SIERRA_PHY_PLL_CFG 0xe + +#define SIERRA_MACRO_ID 0x00007364 +#define SIERRA_MAX_LANES 16 +#define PLL_LOCK_TIME 100 + +static const struct reg_field macro_id_type = + REG_FIELD(SIERRA_MACRO_ID_REG, 0, 15); +static const struct reg_field phy_pll_cfg_1 = + REG_FIELD(SIERRA_PHY_PLL_CFG, 1, 1); +static const struct reg_field pllctrl_lock = + REG_FIELD(SIERRA_PLLCTRL_STATUS_PREG, 0, 0); + +#define reset_control_assert(rst) cdns_reset_assert(rst) +#define reset_control_deassert(rst) cdns_reset_deassert(rst) +#define reset_control reset_ctl + +struct cdns_sierra_inst { + u32 phy_type; + u32 num_lanes; + u32 mlane; + struct reset_ctl_bulk *lnk_rst; +}; + +struct cdns_reg_pairs { + u16 val; + u32 off; +}; + +struct cdns_sierra_data { + u32 id_value; + u8 block_offset_shift; + u8 reg_offset_shift; + u32 pcie_cmn_regs; + u32 pcie_ln_regs; + u32 usb_cmn_regs; + u32 usb_ln_regs; + struct cdns_reg_pairs *pcie_cmn_vals; + struct cdns_reg_pairs *pcie_ln_vals; + struct cdns_reg_pairs *usb_cmn_vals; + struct cdns_reg_pairs *usb_ln_vals; +}; + +struct cdns_regmap_cdb_context { + struct udevice *dev; + void __iomem *base; + u8 reg_offset_shift; +}; + +struct cdns_sierra_phy { + struct udevice *dev; + void *base; + size_t size; + struct regmap *regmap; + struct cdns_sierra_data *init_data; + struct cdns_sierra_inst phys[SIERRA_MAX_LANES]; + struct reset_control *phy_rst; + struct reset_control *apb_rst; + struct regmap *regmap_lane_cdb[SIERRA_MAX_LANES]; + struct regmap *regmap_phy_config_ctrl; + struct regmap *regmap_common_cdb; + struct regmap_field *macro_id_type; + struct regmap_field *phy_pll_cfg_1; + struct regmap_field *pllctrl_lock[SIERRA_MAX_LANES]; + struct clk *clk; + struct clk *cmn_refclk; + struct clk *cmn_refclk1; + int nsubnodes; + u32 num_lanes; + bool autoconf; +}; + +static inline int cdns_reset_assert(struct reset_control *rst) +{ + if (rst) + return reset_assert(rst); + else + return 0; +} + +static inline int cdns_reset_deassert(struct reset_control *rst) +{ + if (rst) + return reset_deassert(rst); + else + return 0; +} + +static inline struct cdns_sierra_inst *phy_get_drvdata(struct phy *phy) +{ + struct cdns_sierra_phy *sp = dev_get_priv(phy->dev); + + if (phy->id < sp->nsubnodes) + return &sp->phys[phy->id]; + else + return NULL; +} + +static int cdns_sierra_phy_init(struct phy *gphy) +{ + struct cdns_sierra_inst *ins = phy_get_drvdata(gphy); + struct cdns_sierra_phy *phy = dev_get_priv(gphy->dev); + struct regmap *regmap = phy->regmap; + int i, j; + struct cdns_reg_pairs *cmn_vals, *ln_vals; + u32 num_cmn_regs, num_ln_regs; + + /* Initialise the PHY registers, unless auto configured */ + if (phy->autoconf) + return 0; + + clk_set_rate(phy->cmn_refclk, 25000000); + clk_set_rate(phy->cmn_refclk1, 25000000); + + if (ins->phy_type == PHY_TYPE_PCIE) { + num_cmn_regs = phy->init_data->pcie_cmn_regs; + num_ln_regs = phy->init_data->pcie_ln_regs; + cmn_vals = phy->init_data->pcie_cmn_vals; + ln_vals = phy->init_data->pcie_ln_vals; + } else if (ins->phy_type == PHY_TYPE_USB3) { + num_cmn_regs = phy->init_data->usb_cmn_regs; + num_ln_regs = phy->init_data->usb_ln_regs; + cmn_vals = phy->init_data->usb_cmn_vals; + ln_vals = phy->init_data->usb_ln_vals; + } else { + return -EINVAL; + } + + regmap = phy->regmap_common_cdb; + for (j = 0; j < num_cmn_regs ; j++) + regmap_write(regmap, cmn_vals[j].off, cmn_vals[j].val); + + for (i = 0; i < ins->num_lanes; i++) { + for (j = 0; j < num_ln_regs ; j++) { + regmap = phy->regmap_lane_cdb[i + ins->mlane]; + regmap_write(regmap, ln_vals[j].off, ln_vals[j].val); + } + } + + return 0; +} + +static int cdns_sierra_phy_on(struct phy *gphy) +{ + struct cdns_sierra_inst *ins = phy_get_drvdata(gphy); + struct cdns_sierra_phy *sp = dev_get_priv(gphy->dev); + struct udevice *dev = gphy->dev; + u32 val; + int ret; + + /* Take the PHY lane group out of reset */ + ret = reset_deassert_bulk(ins->lnk_rst); + if (ret) { + dev_err(dev, "Failed to take the PHY lane out of reset\n"); + return ret; + } + + ret = regmap_field_read_poll_timeout(sp->pllctrl_lock[ins->mlane], + val, val, 1000, PLL_LOCK_TIME); + if (ret < 0) + dev_err(dev, "PLL lock of lane failed\n"); + + reset_control_assert(sp->phy_rst); + reset_control_deassert(sp->phy_rst); + + return ret; +} + +static int cdns_sierra_phy_off(struct phy *gphy) +{ + struct cdns_sierra_inst *ins = phy_get_drvdata(gphy); + + return reset_assert_bulk(ins->lnk_rst); +} + +static int cdns_sierra_phy_reset(struct phy *gphy) +{ + struct cdns_sierra_phy *sp = dev_get_priv(gphy->dev); + + reset_control_assert(sp->phy_rst); + reset_control_deassert(sp->phy_rst); + return 0; +}; + +static const struct phy_ops ops = { + .init = cdns_sierra_phy_init, + .power_on = cdns_sierra_phy_on, + .power_off = cdns_sierra_phy_off, + .reset = cdns_sierra_phy_reset, +}; + +static int cdns_sierra_get_optional(struct cdns_sierra_inst *inst, + ofnode child) +{ + if (ofnode_read_u32(child, "reg", &inst->mlane)) + return -EINVAL; + + if (ofnode_read_u32(child, "cdns,num-lanes", &inst->num_lanes)) + return -EINVAL; + + if (ofnode_read_u32(child, "cdns,phy-type", &inst->phy_type)) + return -EINVAL; + + return 0; +} + +static struct regmap *cdns_regmap_init(struct udevice *dev, void __iomem *base, + u32 block_offset, u8 block_offset_shift, + u8 reg_offset_shift) +{ + struct cdns_sierra_phy *sp = dev_get_priv(dev); + struct regmap_config config; + + config.r_start = (ulong)(base + (block_offset << block_offset_shift)); + config.r_size = sp->size - (block_offset << block_offset_shift); + config.reg_offset_shift = reg_offset_shift; + config.width = REGMAP_SIZE_16; + + return devm_regmap_init(dev, NULL, NULL, &config); +} + +static int cdns_regfield_init(struct cdns_sierra_phy *sp) +{ + struct udevice *dev = sp->dev; + struct regmap_field *field; + struct regmap *regmap; + int i; + + regmap = sp->regmap_common_cdb; + field = devm_regmap_field_alloc(dev, regmap, macro_id_type); + if (IS_ERR(field)) { + dev_err(dev, "MACRO_ID_TYPE reg field init failed\n"); + return PTR_ERR(field); + } + sp->macro_id_type = field; + + regmap = sp->regmap_phy_config_ctrl; + field = devm_regmap_field_alloc(dev, regmap, phy_pll_cfg_1); + if (IS_ERR(field)) { + dev_err(dev, "PHY_PLL_CFG_1 reg field init failed\n"); + return PTR_ERR(field); + } + sp->phy_pll_cfg_1 = field; + + for (i = 0; i < SIERRA_MAX_LANES; i++) { + regmap = sp->regmap_lane_cdb[i]; + field = devm_regmap_field_alloc(dev, regmap, pllctrl_lock); + if (IS_ERR(field)) { + dev_err(dev, "P%d_ENABLE reg field init failed\n", i); + return PTR_ERR(field); + } + sp->pllctrl_lock[i] = field; + } + + return 0; +} + +static int cdns_regmap_init_blocks(struct cdns_sierra_phy *sp, + void __iomem *base, u8 block_offset_shift, + u8 reg_offset_shift) +{ + struct udevice *dev = sp->dev; + struct regmap *regmap; + u32 block_offset; + int i; + + for (i = 0; i < SIERRA_MAX_LANES; i++) { + block_offset = SIERRA_LANE_CDB_OFFSET(i, reg_offset_shift); + regmap = cdns_regmap_init(dev, base, block_offset, + block_offset_shift, reg_offset_shift); + if (IS_ERR(regmap)) { + dev_err(dev, "Failed to init lane CDB regmap\n"); + return PTR_ERR(regmap); + } + sp->regmap_lane_cdb[i] = regmap; + } + + regmap = cdns_regmap_init(dev, base, SIERRA_COMMON_CDB_OFFSET, + block_offset_shift, reg_offset_shift); + if (IS_ERR(regmap)) { + dev_err(dev, "Failed to init common CDB regmap\n"); + return PTR_ERR(regmap); + } + sp->regmap_common_cdb = regmap; + + regmap = cdns_regmap_init(dev, base, SIERRA_PHY_CONFIG_CTRL_OFFSET, + block_offset_shift, reg_offset_shift); + if (IS_ERR(regmap)) { + dev_err(dev, "Failed to init PHY config and control regmap\n"); + return PTR_ERR(regmap); + } + sp->regmap_phy_config_ctrl = regmap; + + return 0; +} + +static int cdns_sierra_phy_probe(struct udevice *dev) +{ + struct cdns_sierra_phy *sp = dev_get_priv(dev); + struct cdns_sierra_data *data; + int ret, node = 0; + ofnode child; + unsigned int id_value; + struct clk *clk; + + sp->dev = dev; + + sp->base = devfdt_remap_addr_index(dev, 0); + if (!sp->base) { + dev_err(dev, "unable to map regs\n"); + return -ENOMEM; + } + devfdt_get_addr_size_index(dev, 0, (fdt_size_t *)&sp->size); + + /* Get init data for this PHY */ + data = (struct cdns_sierra_data *)dev_get_driver_data(dev); + sp->init_data = data; + + ret = cdns_regmap_init_blocks(sp, sp->base, data->block_offset_shift, + data->reg_offset_shift); + if (ret) + return ret; + + ret = cdns_regfield_init(sp); + if (ret) + return ret; + + sp->clk = devm_clk_get_optional(dev, "phy_clk"); + if (IS_ERR(sp->clk)) { + dev_err(dev, "failed to get clock phy_clk\n"); + return PTR_ERR(sp->clk); + } + + sp->phy_rst = devm_reset_control_get(dev, "sierra_reset"); + if (IS_ERR(sp->phy_rst)) { + dev_err(dev, "failed to get reset\n"); + return PTR_ERR(sp->phy_rst); + } + + sp->apb_rst = devm_reset_control_get_optional(dev, "sierra_apb"); + if (IS_ERR(sp->apb_rst)) { + dev_err(dev, "failed to get apb reset\n"); + return PTR_ERR(sp->apb_rst); + } + + clk = devm_clk_get_optional(dev, "cmn_refclk_dig_div"); + if (IS_ERR(clk)) { + dev_err(dev, "cmn_refclk clock not found\n"); + ret = PTR_ERR(clk); + return ret; + } + sp->cmn_refclk = clk; + + clk = devm_clk_get_optional(dev, "cmn_refclk1_dig_div"); + if (IS_ERR(clk)) { + dev_err(dev, "cmn_refclk1 clock not found\n"); + ret = PTR_ERR(clk); + return ret; + } + sp->cmn_refclk1 = clk; + + ret = clk_prepare_enable(sp->clk); + if (ret) + return ret; + + /* Enable APB */ + reset_control_deassert(sp->apb_rst); + + /* Check that PHY is present */ + regmap_field_read(sp->macro_id_type, &id_value); + if (sp->init_data->id_value != id_value) { + dev_err(dev, "PHY not found 0x%x vs 0x%x\n", + sp->init_data->id_value, id_value); + ret = -EINVAL; + goto clk_disable; + } + + sp->autoconf = dev_read_bool(dev, "cdns,autoconf"); + + ofnode_for_each_subnode(child, dev_ofnode(dev)) { + sp->phys[node].lnk_rst = devm_reset_bulk_get_by_node(dev, + child); + if (IS_ERR(sp->phys[node].lnk_rst)) { + ret = PTR_ERR(sp->phys[node].lnk_rst); + dev_err(dev, "failed to get reset %s\n", + ofnode_get_name(child)); + goto put_child2; + } + + if (!sp->autoconf) { + ret = cdns_sierra_get_optional(&sp->phys[node], child); + if (ret) { + dev_err(dev, "missing property in node %s\n", + ofnode_get_name(child)); + goto put_child; + } + } + sp->num_lanes += sp->phys[node].num_lanes; + + node++; + } + sp->nsubnodes = node; + + /* If more than one subnode, configure the PHY as multilink */ + if (!sp->autoconf && sp->nsubnodes > 1) + regmap_field_write(sp->phy_pll_cfg_1, 0x1); + + reset_control_deassert(sp->phy_rst); + dev_info(dev, "sierra probed\n"); + return 0; + +put_child: + node++; +put_child2: + +clk_disable: + clk_disable_unprepare(sp->clk); + reset_control_assert(sp->apb_rst); + return ret; +} + +static int cdns_sierra_phy_remove(struct udevice *dev) +{ + struct cdns_sierra_phy *phy = dev_get_priv(dev); + int i; + + reset_control_assert(phy->phy_rst); + reset_control_assert(phy->apb_rst); + + /* + * The device level resets will be put automatically. + * Need to put the subnode resets here though. + */ + for (i = 0; i < phy->nsubnodes; i++) + reset_assert_bulk(phy->phys[i].lnk_rst); + + return 0; +} + +/* refclk100MHz_32b_PCIe_cmn_pll_ext_ssc */ +static struct cdns_reg_pairs cdns_pcie_cmn_regs_ext_ssc[] = { + {0x2106, SIERRA_CMN_PLLLC_LF_COEFF_MODE1_PREG}, + {0x2106, SIERRA_CMN_PLLLC_LF_COEFF_MODE0_PREG}, + {0x8A06, SIERRA_CMN_PLLLC_BWCAL_MODE1_PREG}, + {0x8A06, SIERRA_CMN_PLLLC_BWCAL_MODE0_PREG}, + {0x1B1B, SIERRA_CMN_PLLLC_SS_TIME_STEPSIZE_MODE_PREG} +}; + +/* refclk100MHz_32b_PCIe_ln_ext_ssc */ +static struct cdns_reg_pairs cdns_pcie_ln_regs_ext_ssc[] = { + {0x813E, SIERRA_CLKPATHCTRL_TMR_PREG}, + {0x8047, SIERRA_RX_CREQ_FLTR_A_MODE3_PREG}, + {0x808F, SIERRA_RX_CREQ_FLTR_A_MODE2_PREG}, + {0x808F, SIERRA_RX_CREQ_FLTR_A_MODE1_PREG}, + {0x808F, SIERRA_RX_CREQ_FLTR_A_MODE0_PREG}, + {0x033C, SIERRA_RX_CTLE_MAINTENANCE_PREG}, + {0x44CC, SIERRA_CREQ_EQ_OPEN_EYE_THRESH_PREG} +}; + +/* refclk100MHz_20b_USB_cmn_pll_ext_ssc */ +static struct cdns_reg_pairs cdns_usb_cmn_regs_ext_ssc[] = { + {0x2085, SIERRA_CMN_PLLLC_LF_COEFF_MODE1_PREG}, + {0x2085, SIERRA_CMN_PLLLC_LF_COEFF_MODE0_PREG}, + {0x0000, SIERRA_CMN_PLLLC_BWCAL_MODE0_PREG}, + {0x0000, SIERRA_CMN_PLLLC_SS_TIME_STEPSIZE_MODE_PREG} +}; + +/* refclk100MHz_20b_USB_ln_ext_ssc */ +static struct cdns_reg_pairs cdns_usb_ln_regs_ext_ssc[] = { + {0xFE0A, SIERRA_DET_STANDEC_A_PREG}, + {0x000F, SIERRA_DET_STANDEC_B_PREG}, + {0x00A5, SIERRA_DET_STANDEC_C_PREG}, + {0x69ad, SIERRA_DET_STANDEC_D_PREG}, + {0x0241, SIERRA_DET_STANDEC_E_PREG}, + {0x0010, SIERRA_PSM_LANECAL_DLY_A1_RESETS_PREG}, + {0x0014, SIERRA_PSM_A0IN_TMR_PREG}, + {0xCF00, SIERRA_PSM_DIAG_PREG}, + {0x001F, SIERRA_PSC_TX_A0_PREG}, + {0x0007, SIERRA_PSC_TX_A1_PREG}, + {0x0003, SIERRA_PSC_TX_A2_PREG}, + {0x0003, SIERRA_PSC_TX_A3_PREG}, + {0x0FFF, SIERRA_PSC_RX_A0_PREG}, + {0x0619, SIERRA_PSC_RX_A1_PREG}, + {0x0003, SIERRA_PSC_RX_A2_PREG}, + {0x0001, SIERRA_PSC_RX_A3_PREG}, + {0x0001, SIERRA_PLLCTRL_SUBRATE_PREG}, + {0x0406, SIERRA_PLLCTRL_GEN_D_PREG}, + {0x5233, SIERRA_PLLCTRL_CPGAIN_MODE_PREG}, + {0x00CA, SIERRA_CLKPATH_BIASTRIM_PREG}, + {0x2512, SIERRA_DFE_BIASTRIM_PREG}, + {0x0000, SIERRA_DRVCTRL_ATTEN_PREG}, + {0x873E, SIERRA_CLKPATHCTRL_TMR_PREG}, + {0x03CF, SIERRA_RX_CREQ_FLTR_A_MODE1_PREG}, + {0x01CE, SIERRA_RX_CREQ_FLTR_A_MODE0_PREG}, + {0x7B3C, SIERRA_CREQ_CCLKDET_MODE01_PREG}, + {0x033F, SIERRA_RX_CTLE_MAINTENANCE_PREG}, + {0x3232, SIERRA_CREQ_FSMCLK_SEL_PREG}, + {0x0000, SIERRA_CREQ_EQ_CTRL_PREG}, + {0x8000, SIERRA_CREQ_SPARE_PREG}, + {0xCC44, SIERRA_CREQ_EQ_OPEN_EYE_THRESH_PREG}, + {0x8453, SIERRA_CTLELUT_CTRL_PREG}, + {0x4110, SIERRA_DFE_ECMP_RATESEL_PREG}, + {0x4110, SIERRA_DFE_SMP_RATESEL_PREG}, + {0x0002, SIERRA_DEQ_PHALIGN_CTRL}, + {0x3200, SIERRA_DEQ_CONCUR_CTRL1_PREG}, + {0x5064, SIERRA_DEQ_CONCUR_CTRL2_PREG}, + {0x0030, SIERRA_DEQ_EPIPWR_CTRL2_PREG}, + {0x0048, SIERRA_DEQ_FAST_MAINT_CYCLES_PREG}, + {0x5A5A, SIERRA_DEQ_ERRCMP_CTRL_PREG}, + {0x02F5, SIERRA_DEQ_OFFSET_CTRL_PREG}, + {0x02F5, SIERRA_DEQ_GAIN_CTRL_PREG}, + {0x9A8A, SIERRA_DEQ_VGATUNE_CTRL_PREG}, + {0x0014, SIERRA_DEQ_GLUT0}, + {0x0014, SIERRA_DEQ_GLUT1}, + {0x0014, SIERRA_DEQ_GLUT2}, + {0x0014, SIERRA_DEQ_GLUT3}, + {0x0014, SIERRA_DEQ_GLUT4}, + {0x0014, SIERRA_DEQ_GLUT5}, + {0x0014, SIERRA_DEQ_GLUT6}, + {0x0014, SIERRA_DEQ_GLUT7}, + {0x0014, SIERRA_DEQ_GLUT8}, + {0x0014, SIERRA_DEQ_GLUT9}, + {0x0014, SIERRA_DEQ_GLUT10}, + {0x0014, SIERRA_DEQ_GLUT11}, + {0x0014, SIERRA_DEQ_GLUT12}, + {0x0014, SIERRA_DEQ_GLUT13}, + {0x0014, SIERRA_DEQ_GLUT14}, + {0x0014, SIERRA_DEQ_GLUT15}, + {0x0014, SIERRA_DEQ_GLUT16}, + {0x0BAE, SIERRA_DEQ_ALUT0}, + {0x0AEB, SIERRA_DEQ_ALUT1}, + {0x0A28, SIERRA_DEQ_ALUT2}, + {0x0965, SIERRA_DEQ_ALUT3}, + {0x08A2, SIERRA_DEQ_ALUT4}, + {0x07DF, SIERRA_DEQ_ALUT5}, + {0x071C, SIERRA_DEQ_ALUT6}, + {0x0659, SIERRA_DEQ_ALUT7}, + {0x0596, SIERRA_DEQ_ALUT8}, + {0x0514, SIERRA_DEQ_ALUT9}, + {0x0492, SIERRA_DEQ_ALUT10}, + {0x0410, SIERRA_DEQ_ALUT11}, + {0x038E, SIERRA_DEQ_ALUT12}, + {0x030C, SIERRA_DEQ_ALUT13}, + {0x03F4, SIERRA_DEQ_DFETAP_CTRL_PREG}, + {0x0001, SIERRA_DFE_EN_1010_IGNORE_PREG}, + {0x3C01, SIERRA_DEQ_TAU_CTRL1_FAST_MAINT_PREG}, + {0x3C40, SIERRA_DEQ_TAU_CTRL1_SLOW_MAINT_PREG}, + {0x1C08, SIERRA_DEQ_TAU_CTRL2_PREG}, + {0x0033, SIERRA_DEQ_PICTRL_PREG}, + {0x0400, SIERRA_CPICAL_TMRVAL_MODE1_PREG}, + {0x0330, SIERRA_CPICAL_TMRVAL_MODE0_PREG}, + {0x01FF, SIERRA_CPICAL_PICNT_MODE1_PREG}, + {0x0009, SIERRA_CPI_OUTBUF_RATESEL_PREG}, + {0x3232, SIERRA_CPICAL_RES_STARTCODE_MODE23_PREG}, + {0x0005, SIERRA_LFPSDET_SUPPORT_PREG}, + {0x000F, SIERRA_LFPSFILT_NS_PREG}, + {0x0009, SIERRA_LFPSFILT_RD_PREG}, + {0x0001, SIERRA_LFPSFILT_MP_PREG}, + {0x8013, SIERRA_SDFILT_H2L_A_PREG}, + {0x8009, SIERRA_SDFILT_L2H_PREG}, + {0x0024, SIERRA_RXBUFFER_CTLECTRL_PREG}, + {0x0020, SIERRA_RXBUFFER_RCDFECTRL_PREG}, + {0x4243, SIERRA_RXBUFFER_DFECTRL_PREG} +}; + +static const struct cdns_sierra_data cdns_map_sierra = { + SIERRA_MACRO_ID, + 0x2, + 0x2, + ARRAY_SIZE(cdns_pcie_cmn_regs_ext_ssc), + ARRAY_SIZE(cdns_pcie_ln_regs_ext_ssc), + ARRAY_SIZE(cdns_usb_cmn_regs_ext_ssc), + ARRAY_SIZE(cdns_usb_ln_regs_ext_ssc), + cdns_pcie_cmn_regs_ext_ssc, + cdns_pcie_ln_regs_ext_ssc, + cdns_usb_cmn_regs_ext_ssc, + cdns_usb_ln_regs_ext_ssc, +}; + +static const struct cdns_sierra_data cdns_ti_map_sierra = { + SIERRA_MACRO_ID, + 0x0, + 0x1, + ARRAY_SIZE(cdns_pcie_cmn_regs_ext_ssc), + ARRAY_SIZE(cdns_pcie_ln_regs_ext_ssc), + ARRAY_SIZE(cdns_usb_cmn_regs_ext_ssc), + ARRAY_SIZE(cdns_usb_ln_regs_ext_ssc), + cdns_pcie_cmn_regs_ext_ssc, + cdns_pcie_ln_regs_ext_ssc, + cdns_usb_cmn_regs_ext_ssc, + cdns_usb_ln_regs_ext_ssc, +}; + +static const struct udevice_id cdns_sierra_id_table[] = { + { + .compatible = "cdns,sierra-phy-t0", + .data = (ulong)&cdns_map_sierra, + }, + { + .compatible = "ti,sierra-phy-t0", + .data = (ulong)&cdns_ti_map_sierra, + }, + {} +}; + +U_BOOT_DRIVER(sierra_phy_provider) = { + .name = "cdns,sierra", + .id = UCLASS_PHY, + .of_match = cdns_sierra_id_table, + .probe = cdns_sierra_phy_probe, + .remove = cdns_sierra_phy_remove, + .ops = &ops, + .priv_auto = sizeof(struct cdns_sierra_phy), +};
Add driver for Torrent SERDES.
Signed-off-by: Aswath Govindraju a-govindraju@ti.com Signed-off-by: Kishon Vijay Abraham I kishon@ti.com --- drivers/phy/cadence/Kconfig | 6 + drivers/phy/cadence/Makefile | 1 + drivers/phy/cadence/phy-cadence-torrent.c | 2468 +++++++++++++++++++++ 3 files changed, 2475 insertions(+) create mode 100644 drivers/phy/cadence/phy-cadence-torrent.c
diff --git a/drivers/phy/cadence/Kconfig b/drivers/phy/cadence/Kconfig index 18a04819f5..549ddbf504 100644 --- a/drivers/phy/cadence/Kconfig +++ b/drivers/phy/cadence/Kconfig @@ -3,3 +3,9 @@ config PHY_CADENCE_SIERRA depends on DM_RESET help Enable this to support the Cadence Sierra PHY driver + +config PHY_CADENCE_TORRENT + tristate "Cadence Torrent PHY Driver" + depends on DM_RESET + help + Enable this to support the Cadence Torrent PHY driver diff --git a/drivers/phy/cadence/Makefile b/drivers/phy/cadence/Makefile index d57856152a..af63b32d9f 100644 --- a/drivers/phy/cadence/Makefile +++ b/drivers/phy/cadence/Makefile @@ -1 +1,2 @@ obj-$(CONFIG_$(SPL_)PHY_CADENCE_SIERRA) += phy-cadence-sierra.o +obj-$(CONFIG_$(SPL_)PHY_CADENCE_TORRENT) += phy-cadence-torrent.o diff --git a/drivers/phy/cadence/phy-cadence-torrent.c b/drivers/phy/cadence/phy-cadence-torrent.c new file mode 100644 index 0000000000..f959703e80 --- /dev/null +++ b/drivers/phy/cadence/phy-cadence-torrent.c @@ -0,0 +1,2468 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Cadence Torrent SD0801 PHY driver. + * + * Based on the linux driver provided by Cadence + * + * Copyright (c) 2018 Cadence Design Systems + * + * Copyright (C) 2020 Texas Instruments Incorporated - https://www.ti.com/ + * + */ + +#include <common.h> +#include <clk.h> +#include <generic-phy.h> +#include <reset.h> +#include <dm/device.h> +#include <dm/device_compat.h> +#include <dm/device-internal.h> +#include <dm/lists.h> +#include <dm/read.h> +#include <dm/uclass.h> +#include <linux/io.h> +#include <dt-bindings/phy/phy.h> +#include <regmap.h> +#include <linux/delay.h> +#include <linux/string.h> + +#define REF_CLK_19_2MHz 19200000 +#define REF_CLK_25MHz 25000000 + +#define MAX_NUM_LANES 4 +#define DEFAULT_MAX_BIT_RATE 8100 /* in Mbps*/ + +#define NUM_SSC_MODE 3 +#define NUM_PHY_TYPE 6 + +#define POLL_TIMEOUT_US 5000 +#define PLL_LOCK_TIMEOUT 100000 + +#define TORRENT_COMMON_CDB_OFFSET 0x0 + +#define TORRENT_TX_LANE_CDB_OFFSET(ln, block_offset, reg_offset) \ + ((0x4000 << (block_offset)) + \ + (((ln) << 9) << (reg_offset))) +#define TORRENT_RX_LANE_CDB_OFFSET(ln, block_offset, reg_offset) \ + ((0x8000 << (block_offset)) + \ + (((ln) << 9) << (reg_offset))) + +#define TORRENT_PHY_PCS_COMMON_OFFSET(block_offset) \ + (0xC000 << (block_offset)) + +#define TORRENT_PHY_PMA_COMMON_OFFSET(block_offset) \ + (0xE000 << (block_offset)) + +/* + * register offsets from SD0801 PHY register block base (i.e MHDP + * register base + 0x500000) + */ +#define CMN_SSM_BANDGAP_TMR 0x0021U +#define CMN_SSM_BIAS_TMR 0x0022U +#define CMN_PLLSM0_PLLPRE_TMR 0x002AU +#define CMN_PLLSM0_PLLLOCK_TMR 0x002CU +#define CMN_PLLSM1_PLLPRE_TMR 0x0032U +#define CMN_PLLSM1_PLLLOCK_TMR 0x0034U +#define CMN_CDIAG_CDB_PWRI_OVRD 0x0041U +#define CMN_CDIAG_XCVRC_PWRI_OVRD 0x0047U +#define CMN_BGCAL_INIT_TMR 0x0064U +#define CMN_BGCAL_ITER_TMR 0x0065U +#define CMN_IBCAL_INIT_TMR 0x0074U +#define CMN_PLL0_VCOCAL_TCTRL 0x0082U +#define CMN_PLL0_VCOCAL_INIT_TMR 0x0084U +#define CMN_PLL0_VCOCAL_ITER_TMR 0x0085U +#define CMN_PLL0_VCOCAL_REFTIM_START 0x0086U +#define CMN_PLL0_VCOCAL_PLLCNT_START 0x0088U +#define CMN_PLL0_INTDIV_M0 0x0090U +#define CMN_PLL0_FRACDIVL_M0 0x0091U +#define CMN_PLL0_FRACDIVH_M0 0x0092U +#define CMN_PLL0_HIGH_THR_M0 0x0093U +#define CMN_PLL0_DSM_DIAG_M0 0x0094U +#define CMN_PLL0_SS_CTRL1_M0 0x0098U +#define CMN_PLL0_SS_CTRL2_M0 0x0099U +#define CMN_PLL0_SS_CTRL3_M0 0x009AU +#define CMN_PLL0_SS_CTRL4_M0 0x009BU +#define CMN_PLL0_LOCK_REFCNT_START 0x009CU +#define CMN_PLL0_LOCK_PLLCNT_START 0x009EU +#define CMN_PLL0_LOCK_PLLCNT_THR 0x009FU +#define CMN_PLL0_INTDIV_M1 0x00A0U +#define CMN_PLL0_FRACDIVH_M1 0x00A2U +#define CMN_PLL0_HIGH_THR_M1 0x00A3U +#define CMN_PLL0_DSM_DIAG_M1 0x00A4U +#define CMN_PLL0_SS_CTRL1_M1 0x00A8U +#define CMN_PLL0_SS_CTRL2_M1 0x00A9U +#define CMN_PLL0_SS_CTRL3_M1 0x00AAU +#define CMN_PLL0_SS_CTRL4_M1 0x00ABU +#define CMN_PLL1_VCOCAL_TCTRL 0x00C2U +#define CMN_PLL1_VCOCAL_INIT_TMR 0x00C4U +#define CMN_PLL1_VCOCAL_ITER_TMR 0x00C5U +#define CMN_PLL1_VCOCAL_REFTIM_START 0x00C6U +#define CMN_PLL1_VCOCAL_PLLCNT_START 0x00C8U +#define CMN_PLL1_INTDIV_M0 0x00D0U +#define CMN_PLL1_FRACDIVL_M0 0x00D1U +#define CMN_PLL1_FRACDIVH_M0 0x00D2U +#define CMN_PLL1_HIGH_THR_M0 0x00D3U +#define CMN_PLL1_DSM_DIAG_M0 0x00D4U +#define CMN_PLL1_DSM_FBH_OVRD_M0 0x00D5U +#define CMN_PLL1_DSM_FBL_OVRD_M0 0x00D6U +#define CMN_PLL1_SS_CTRL1_M0 0x00D8U +#define CMN_PLL1_SS_CTRL2_M0 0x00D9U +#define CMN_PLL1_SS_CTRL3_M0 0x00DAU +#define CMN_PLL1_SS_CTRL4_M0 0x00DBU +#define CMN_PLL1_LOCK_REFCNT_START 0x00DCU +#define CMN_PLL1_LOCK_PLLCNT_START 0x00DEU +#define CMN_PLL1_LOCK_PLLCNT_THR 0x00DFU +#define CMN_TXPUCAL_TUNE 0x0103U +#define CMN_TXPUCAL_INIT_TMR 0x0104U +#define CMN_TXPUCAL_ITER_TMR 0x0105U +#define CMN_CMN_TXPDCAL_OVRD 0x0109U +#define CMN_TXPDCAL_TUNE 0x010BU +#define CMN_TXPDCAL_INIT_TMR 0x010CU +#define CMN_TXPDCAL_ITER_TMR 0x010DU +#define CMN_RXCAL_INIT_TMR 0x0114U +#define CMN_RXCAL_ITER_TMR 0x0115U +#define CMN_SD_CAL_INIT_TMR 0x0124U +#define CMN_SD_CAL_ITER_TMR 0x0125U +#define CMN_SD_CAL_REFTIM_START 0x0126U +#define CMN_SD_CAL_PLLCNT_START 0x0128U +#define CMN_PDIAG_PLL0_CTRL_M0 0x01A0U +#define CMN_PDIAG_PLL0_CLK_SEL_M0 0x01A1U +#define CMN_PDIAG_PLL0_CP_PADJ_M0 0x01A4U +#define CMN_PDIAG_PLL0_CP_IADJ_M0 0x01A5U +#define CMN_PDIAG_PLL0_FILT_PADJ_M0 0x01A6U +#define CMN_PDIAG_PLL0_CTRL_M1 0x01B0U +#define CMN_PDIAG_PLL0_CLK_SEL_M1 0x01B1U +#define CMN_PDIAG_PLL0_CP_PADJ_M1 0x01B4U +#define CMN_PDIAG_PLL0_CP_IADJ_M1 0x01B5U +#define CMN_PDIAG_PLL0_FILT_PADJ_M1 0x01B6U +#define CMN_PDIAG_PLL1_CTRL_M0 0x01C0U +#define CMN_PDIAG_PLL1_CLK_SEL_M0 0x01C1U +#define CMN_PDIAG_PLL1_CP_PADJ_M0 0x01C4U +#define CMN_PDIAG_PLL1_CP_IADJ_M0 0x01C5U +#define CMN_PDIAG_PLL1_FILT_PADJ_M0 0x01C6U +#define CMN_DIAG_BIAS_OVRD1 0x01E1U + +/* PMA TX Lane registers */ +#define TX_TXCC_CTRL 0x0040U +#define TX_TXCC_CPOST_MULT_00 0x004CU +#define TX_TXCC_CPOST_MULT_01 0x004DU +#define TX_TXCC_MGNFS_MULT_000 0x0050U +#define TX_TXCC_MGNFS_MULT_100 0x0054U +#define DRV_DIAG_TX_DRV 0x00C6U +#define XCVR_DIAG_PLLDRC_CTRL 0x00E5U +#define XCVR_DIAG_HSCLK_SEL 0x00E6U +#define XCVR_DIAG_HSCLK_DIV 0x00E7U +#define XCVR_DIAG_RXCLK_CTRL 0x00E9U +#define XCVR_DIAG_BIDI_CTRL 0x00EAU +#define XCVR_DIAG_PSC_OVRD 0x00EBU +#define TX_PSC_A0 0x0100U +#define TX_PSC_A1 0x0101U +#define TX_PSC_A2 0x0102U +#define TX_PSC_A3 0x0103U +#define TX_RCVDET_ST_TMR 0x0123U +#define TX_DIAG_ACYA 0x01E7U +#define TX_DIAG_ACYA_HBDC_MASK 0x0001U + +/* PMA RX Lane registers */ +#define RX_PSC_A0 0x0000U +#define RX_PSC_A1 0x0001U +#define RX_PSC_A2 0x0002U +#define RX_PSC_A3 0x0003U +#define RX_PSC_CAL 0x0006U +#define RX_CDRLF_CNFG 0x0080U +#define RX_CDRLF_CNFG3 0x0082U +#define RX_SIGDET_HL_FILT_TMR 0x0090U +#define RX_REE_GCSM1_CTRL 0x0108U +#define RX_REE_GCSM1_EQENM_PH1 0x0109U +#define RX_REE_GCSM1_EQENM_PH2 0x010AU +#define RX_REE_GCSM2_CTRL 0x0110U +#define RX_REE_PERGCSM_CTRL 0x0118U +#define RX_REE_ATTEN_THR 0x0149U +#define RX_REE_TAP1_CLIP 0x0171U +#define RX_REE_TAP2TON_CLIP 0x0172U +#define RX_REE_SMGM_CTRL1 0x0177U +#define RX_REE_SMGM_CTRL2 0x0178U +#define RX_DIAG_DFE_CTRL 0x01E0U +#define RX_DIAG_DFE_AMP_TUNE_2 0x01E2U +#define RX_DIAG_DFE_AMP_TUNE_3 0x01E3U +#define RX_DIAG_NQST_CTRL 0x01E5U +#define RX_DIAG_SIGDET_TUNE 0x01E8U +#define RX_DIAG_PI_RATE 0x01F4U +#define RX_DIAG_PI_CAP 0x01F5U +#define RX_DIAG_ACYA 0x01FFU + +/* PHY PCS common registers */ +#define PHY_PLL_CFG 0x000EU +#define PHY_PIPE_USB3_GEN2_PRE_CFG0 0x0020U +#define PHY_PIPE_USB3_GEN2_POST_CFG0 0x0022U +#define PHY_PIPE_USB3_GEN2_POST_CFG1 0x0023U + +/* PHY PMA common registers */ +#define PHY_PMA_CMN_CTRL1 0x0000U +#define PHY_PMA_CMN_CTRL2 0x0001U +#define PHY_PMA_PLL_RAW_CTRL 0x0003U + +static const struct reg_field phy_pll_cfg = REG_FIELD(PHY_PLL_CFG, 0, 1); +static const struct reg_field phy_pma_cmn_ctrl_1 = + REG_FIELD(PHY_PMA_CMN_CTRL1, 0, 0); +static const struct reg_field phy_pma_cmn_ctrl_2 = + REG_FIELD(PHY_PMA_CMN_CTRL2, 0, 7); +static const struct reg_field phy_pma_pll_raw_ctrl = + REG_FIELD(PHY_PMA_PLL_RAW_CTRL, 0, 1); + +#define reset_control_assert reset_assert +#define reset_control_deassert reset_deassert +#define reset_control reset_ctl +#define reset_control_put reset_free + +enum cdns_torrent_phy_type { + TYPE_NONE, + TYPE_DP, + TYPE_PCIE, + TYPE_SGMII, + TYPE_QSGMII, + TYPE_USB, +}; + +enum cdns_torrent_ssc_mode { + NO_SSC, + EXTERNAL_SSC, + INTERNAL_SSC +}; + +struct cdns_torrent_inst { + struct phy *phy; + u32 mlane; + enum cdns_torrent_phy_type phy_type; + u32 num_lanes; + struct reset_ctl_bulk *lnk_rst; + enum cdns_torrent_ssc_mode ssc_mode; +}; + +struct cdns_torrent_phy { + void __iomem *sd_base; /* SD0801 register base */ + size_t size; + struct reset_control *phy_rst; + struct reset_control *apb_rst; + struct udevice *dev; + struct cdns_torrent_inst phys[MAX_NUM_LANES]; + int nsubnodes; + const struct cdns_torrent_data *init_data; + struct regmap *regmap; + struct regmap *regmap_common_cdb; + struct regmap *regmap_phy_pcs_common_cdb; + struct regmap *regmap_phy_pma_common_cdb; + struct regmap *regmap_tx_lane_cdb[MAX_NUM_LANES]; + struct regmap *regmap_rx_lane_cdb[MAX_NUM_LANES]; + struct regmap_field *phy_pll_cfg; + struct regmap_field *phy_pma_cmn_ctrl_1; + struct regmap_field *phy_pma_cmn_ctrl_2; + struct regmap_field *phy_pma_pll_raw_ctrl; +}; + +struct cdns_reg_pairs { + u32 val; + u32 off; +}; + +struct cdns_torrent_vals { + struct cdns_reg_pairs *reg_pairs; + u32 num_regs; +}; + +struct cdns_torrent_data { + u8 block_offset_shift; + u8 reg_offset_shift; + struct cdns_torrent_vals *link_cmn_vals[NUM_PHY_TYPE][NUM_PHY_TYPE] + [NUM_SSC_MODE]; + struct cdns_torrent_vals *xcvr_diag_vals[NUM_PHY_TYPE][NUM_PHY_TYPE] + [NUM_SSC_MODE]; + struct cdns_torrent_vals *pcs_cmn_vals[NUM_PHY_TYPE][NUM_PHY_TYPE] + [NUM_SSC_MODE]; + struct cdns_torrent_vals *cmn_vals[NUM_PHY_TYPE][NUM_PHY_TYPE] + [NUM_SSC_MODE]; + struct cdns_torrent_vals *tx_ln_vals[NUM_PHY_TYPE][NUM_PHY_TYPE] + [NUM_SSC_MODE]; + struct cdns_torrent_vals *rx_ln_vals[NUM_PHY_TYPE][NUM_PHY_TYPE] + [NUM_SSC_MODE]; +}; + +static inline struct cdns_torrent_inst *phy_get_drvdata(struct phy *phy) +{ + struct cdns_torrent_phy *sp = dev_get_priv(phy->dev); + + if (phy->id < sp->nsubnodes) + return &sp->phys[phy->id]; + return NULL; +} + +static struct regmap *cdns_regmap_init(struct udevice *dev, void __iomem *base, + u32 block_offset, + u8 reg_offset_shift) +{ + struct cdns_torrent_phy *sp = dev_get_priv(dev); + struct regmap_config config; + + config.r_start = (ulong)(base + block_offset); + config.r_size = sp->size - block_offset; + config.reg_offset_shift = reg_offset_shift; + config.width = REGMAP_SIZE_16; + + return devm_regmap_init(dev, NULL, NULL, &config); +} + +static int cdns_torrent_regfield_init(struct cdns_torrent_phy *cdns_phy) +{ + struct udevice *dev = cdns_phy->dev; + struct regmap_field *field; + struct regmap *regmap; + + regmap = cdns_phy->regmap_phy_pcs_common_cdb; + field = devm_regmap_field_alloc(dev, regmap, phy_pll_cfg); + if (IS_ERR(field)) { + dev_err(dev, "PHY_PLL_CFG reg field init failed\n"); + return PTR_ERR(field); + } + cdns_phy->phy_pll_cfg = field; + + regmap = cdns_phy->regmap_phy_pma_common_cdb; + field = devm_regmap_field_alloc(dev, regmap, phy_pma_cmn_ctrl_1); + if (IS_ERR(field)) { + dev_err(dev, "PHY_PMA_CMN_CTRL1 reg field init failed\n"); + return PTR_ERR(field); + } + cdns_phy->phy_pma_cmn_ctrl_1 = field; + + regmap = cdns_phy->regmap_phy_pma_common_cdb; + field = devm_regmap_field_alloc(dev, regmap, phy_pma_cmn_ctrl_2); + if (IS_ERR(field)) { + dev_err(dev, "PHY_PMA_CMN_CTRL2 reg field init failed\n"); + return PTR_ERR(field); + } + cdns_phy->phy_pma_cmn_ctrl_2 = field; + + regmap = cdns_phy->regmap_phy_pma_common_cdb; + field = devm_regmap_field_alloc(dev, regmap, phy_pma_pll_raw_ctrl); + if (IS_ERR(field)) { + dev_err(dev, "PHY_PMA_PLL_RAW_CTRL reg field init failed\n"); + return PTR_ERR(field); + } + cdns_phy->phy_pma_pll_raw_ctrl = field; + + return 0; +} + +static int cdns_torrent_regmap_init(struct cdns_torrent_phy *cdns_phy) +{ + void __iomem *sd_base = cdns_phy->sd_base; + u8 block_offset_shift, reg_offset_shift; + struct udevice *dev = cdns_phy->dev; + struct regmap *regmap; + u32 block_offset; + int i; + + block_offset_shift = cdns_phy->init_data->block_offset_shift; + reg_offset_shift = cdns_phy->init_data->reg_offset_shift; + + for (i = 0; i < MAX_NUM_LANES; i++) { + block_offset = TORRENT_TX_LANE_CDB_OFFSET(i, block_offset_shift, + reg_offset_shift); + + regmap = cdns_regmap_init(dev, sd_base, block_offset, + reg_offset_shift); + if (IS_ERR(regmap)) { + dev_err(dev, "Failed to init tx lane CDB regmap\n"); + return PTR_ERR(regmap); + } + cdns_phy->regmap_tx_lane_cdb[i] = regmap; + block_offset = TORRENT_RX_LANE_CDB_OFFSET(i, block_offset_shift, + reg_offset_shift); + regmap = cdns_regmap_init(dev, sd_base, block_offset, + reg_offset_shift); + if (IS_ERR(regmap)) { + dev_err(dev, "Failed to init rx lane CDB regmap"); + return PTR_ERR(regmap); + } + cdns_phy->regmap_rx_lane_cdb[i] = regmap; + } + + block_offset = TORRENT_COMMON_CDB_OFFSET; + regmap = cdns_regmap_init(dev, sd_base, block_offset, + reg_offset_shift); + if (IS_ERR(regmap)) { + dev_err(dev, "Failed to init common CDB regmap\n"); + return PTR_ERR(regmap); + } + cdns_phy->regmap_common_cdb = regmap; + + block_offset = TORRENT_PHY_PCS_COMMON_OFFSET(block_offset_shift); + regmap = cdns_regmap_init(dev, sd_base, block_offset, + reg_offset_shift); + if (IS_ERR(regmap)) { + dev_err(dev, "Failed to init PHY PCS common CDB regmap\n"); + return PTR_ERR(regmap); + } + cdns_phy->regmap_phy_pcs_common_cdb = regmap; + + block_offset = TORRENT_PHY_PMA_COMMON_OFFSET(block_offset_shift); + regmap = cdns_regmap_init(dev, sd_base, block_offset, + reg_offset_shift); + if (IS_ERR(regmap)) { + dev_err(dev, "Failed to init PHY PMA common CDB regmap\n"); + return PTR_ERR(regmap); + } + cdns_phy->regmap_phy_pma_common_cdb = regmap; + + return 0; +} + +static int cdns_torrent_phy_configure_multilink(struct cdns_torrent_phy *cdns_phy) +{ + const struct cdns_torrent_data *init_data = cdns_phy->init_data; + struct cdns_torrent_vals *cmn_vals, *tx_ln_vals, *rx_ln_vals; + struct cdns_torrent_vals *link_cmn_vals, *xcvr_diag_vals; + enum cdns_torrent_phy_type phy_t1, phy_t2, tmp_phy_type; + struct cdns_torrent_vals *pcs_cmn_vals; + int i, j, node, mlane, num_lanes, ret; + struct cdns_reg_pairs *reg_pairs; + enum cdns_torrent_ssc_mode ssc; + struct regmap *regmap; + u32 num_regs; + + /* Maximum 2 links (subnodes) are supported */ + if (cdns_phy->nsubnodes != 2) + return -EINVAL; + + phy_t1 = cdns_phy->phys[0].phy_type; + phy_t2 = cdns_phy->phys[1].phy_type; + + /* + * First configure the PHY for first link with phy_t1. Geth the array + * values are [phy_t1][phy_t2][ssc]. + */ + for (node = 0; node < cdns_phy->nsubnodes; node++) { + if (node == 1) { + /* + * If fist link with phy_t1 is configured, then + * configure the PHY for second link with phy_t2. + * Get the array values as [phy_t2][phy_t1][ssc] + */ + tmp_phy_type = phy_t1; + phy_t1 = phy_t2; + phy_t2 = tmp_phy_type; + } + + mlane = cdns_phy->phys[node].mlane; + ssc = cdns_phy->phys[node].ssc_mode; + num_lanes = cdns_phy->phys[node].num_lanes; + + /** + * PHY configuration specific registers: + * link_cmn_vals depend on combination of PHY types being + * configured and are common for both PHY types, so array + * values should be same for [phy_t1][phy_t2][ssc] and + * [phy_t2][phy_t1][ssc]. + * xcvr_diag_vals also depend on combination of PHY types + * being configured, but these can be different for particular + * PHY type and are per lane. + */ + link_cmn_vals = init_data->link_cmn_vals[phy_t1][phy_t2][ssc]; + if (link_cmn_vals) { + reg_pairs = link_cmn_vals->reg_pairs; + num_regs = link_cmn_vals->num_regs; + regmap = cdns_phy->regmap_common_cdb; + + /** + * First array value in link_cmn_vals must be of + * PHY_PLL_CFG register + */ + regmap_field_write(cdns_phy->phy_pll_cfg, + reg_pairs[0].val); + + for (i = 1; i < num_regs; i++) + regmap_write(regmap, reg_pairs[i].off, + reg_pairs[i].val); + } + + xcvr_diag_vals = init_data->xcvr_diag_vals[phy_t1][phy_t2][ssc]; + if (xcvr_diag_vals) { + reg_pairs = xcvr_diag_vals->reg_pairs; + num_regs = xcvr_diag_vals->num_regs; + for (i = 0; i < num_lanes; i++) { + regmap = cdns_phy->regmap_tx_lane_cdb[i + mlane]; + for (j = 0; j < num_regs; j++) + regmap_write(regmap, reg_pairs[j].off, + reg_pairs[j].val); + } + } + + /* PHY PCS common registers configurations */ + pcs_cmn_vals = init_data->pcs_cmn_vals[phy_t1][phy_t2][ssc]; + if (pcs_cmn_vals) { + reg_pairs = pcs_cmn_vals->reg_pairs; + num_regs = pcs_cmn_vals->num_regs; + regmap = cdns_phy->regmap_phy_pcs_common_cdb; + for (i = 0; i < num_regs; i++) + regmap_write(regmap, reg_pairs[i].off, + reg_pairs[i].val); + } + + /* PMA common registers configurations */ + cmn_vals = init_data->cmn_vals[phy_t1][phy_t2][ssc]; + if (cmn_vals) { + reg_pairs = cmn_vals->reg_pairs; + num_regs = cmn_vals->num_regs; + regmap = cdns_phy->regmap_common_cdb; + for (i = 0; i < num_regs; i++) + regmap_write(regmap, reg_pairs[i].off, + reg_pairs[i].val); + } + + /* PMA TX lane registers configurations */ + tx_ln_vals = init_data->tx_ln_vals[phy_t1][phy_t2][ssc]; + if (tx_ln_vals) { + reg_pairs = tx_ln_vals->reg_pairs; + num_regs = tx_ln_vals->num_regs; + for (i = 0; i < num_lanes; i++) { + regmap = cdns_phy->regmap_tx_lane_cdb[i + mlane]; + for (j = 0; j < num_regs; j++) + regmap_write(regmap, reg_pairs[j].off, + reg_pairs[j].val); + } + } + + /* PMA RX lane registers configurations */ + rx_ln_vals = init_data->rx_ln_vals[phy_t1][phy_t2][ssc]; + if (rx_ln_vals) { + reg_pairs = rx_ln_vals->reg_pairs; + num_regs = rx_ln_vals->num_regs; + for (i = 0; i < num_lanes; i++) { + regmap = cdns_phy->regmap_rx_lane_cdb[i + mlane]; + for (j = 0; j < num_regs; j++) + regmap_write(regmap, reg_pairs[j].off, + reg_pairs[j].val); + } + } + + reset_deassert_bulk(cdns_phy->phys[node].lnk_rst); + } + + /* Take the PHY out of reset */ + ret = reset_control_deassert(cdns_phy->phy_rst); + if (ret) + return ret; + + return 0; +} + +static int cdns_torrent_phy_probe(struct udevice *dev) +{ + struct cdns_torrent_phy *cdns_phy = dev_get_priv(dev); + struct cdns_torrent_data *data; + int ret, subnodes = 0, node = 0, i; + struct clk *clk; + ofnode child; + u32 total_num_lanes = 0; + u32 phy_type; + + cdns_phy->dev = dev; + + /* Get init data for this phy */ + data = (struct cdns_torrent_data *)dev_get_driver_data(dev); + cdns_phy->init_data = data; + + cdns_phy->phy_rst = devm_reset_control_get_by_index(dev, 0); + if (IS_ERR(cdns_phy->phy_rst)) { + dev_err(dev, "failed to get reset\n"); + return PTR_ERR(cdns_phy->phy_rst); + } + + cdns_phy->apb_rst = devm_reset_control_get_optional(dev, "torrent_apb"); + if (IS_ERR(cdns_phy->apb_rst)) { + dev_err(dev, "failed to get apb reset\n"); + return PTR_ERR(cdns_phy->apb_rst); + } + + clk = devm_clk_get(dev, "refclk"); + if (IS_ERR(clk)) { + dev_err(dev, "phy ref clock not found\n"); + return PTR_ERR(clk); + } + + ret = clk_prepare_enable(clk); + if (ret) { + dev_err(cdns_phy->dev, "Failed to prepare ref clock\n"); + return ret; + } + + cdns_phy->sd_base = devfdt_remap_addr_index(dev, 0); + if (IS_ERR(cdns_phy->sd_base)) + return PTR_ERR(cdns_phy->sd_base); + devfdt_get_addr_size_index(dev, 0, (fdt_size_t *)&cdns_phy->size); + + dev_for_each_subnode(child, dev) + subnodes++; + if (subnodes == 0) { + dev_err(dev, "No available link subnodes found\n"); + return -EINVAL; + } + ret = cdns_torrent_regmap_init(cdns_phy); + if (ret) + return ret; + + ret = cdns_torrent_regfield_init(cdns_phy); + if (ret) + return ret; + + /* Enable APB */ + reset_control_deassert(cdns_phy->apb_rst); + + /* Going through all the available subnodes or children*/ + ofnode_for_each_subnode(child, dev_ofnode(dev)) { + /* PHY subnode name must be a 'link' */ + if (!ofnode_name_eq(child, "link")) + continue; + cdns_phy->phys[node].lnk_rst = + devm_reset_bulk_get_by_node(dev, child); + if (IS_ERR(cdns_phy->phys[node].lnk_rst)) { + dev_err(dev, "%s: failed to get reset\n", + ofnode_get_name(child)); + ret = PTR_ERR(cdns_phy->phys[node].lnk_rst); + goto put_lnk_rst; + } + + if (ofnode_read_u32(child, "reg", + &cdns_phy->phys[node].mlane)) { + dev_err(dev, "%s: No "reg " - property.\n", + ofnode_get_name(child)); + ret = -EINVAL; + goto put_child; + } + + if (ofnode_read_u32(child, "cdns,phy-type", &phy_type)) { + dev_err(dev, "%s: No "cdns,phy-type " - property.\n", + ofnode_get_name(child)); + ret = -EINVAL; + goto put_child; + } + + switch (phy_type) { + case PHY_TYPE_PCIE: + cdns_phy->phys[node].phy_type = TYPE_PCIE; + break; + case PHY_TYPE_DP: + cdns_phy->phys[node].phy_type = TYPE_DP; + break; + case PHY_TYPE_SGMII: + cdns_phy->phys[node].phy_type = TYPE_SGMII; + break; + case PHY_TYPE_QSGMII: + cdns_phy->phys[node].phy_type = TYPE_QSGMII; + break; + case PHY_TYPE_USB3: + cdns_phy->phys[node].phy_type = TYPE_USB; + break; + default: + dev_err(dev, "Unsupported protocol\n"); + ret = -EINVAL; + goto put_child; + } + + if (ofnode_read_u32(child, "cdns,num-lanes", + &cdns_phy->phys[node].num_lanes)) { + dev_err(dev, "%s: No "cdns,num-lanes " - property.\n", + ofnode_get_name(child)); + ret = -EINVAL; + goto put_child; + } + + total_num_lanes += cdns_phy->phys[node].num_lanes; + + /* Get SSC mode */ + ofnode_read_u32(child, "cdns,ssc-mode", + &cdns_phy->phys[node].ssc_mode); + node++; + } + + cdns_phy->nsubnodes = node; + + if (total_num_lanes > MAX_NUM_LANES) { + dev_err(dev, "Invalid lane configuration\n"); + goto put_lnk_rst; + } + + if (cdns_phy->nsubnodes > 1) { + ret = cdns_torrent_phy_configure_multilink(cdns_phy); + if (ret) + goto put_lnk_rst; + } + + reset_control_deassert(cdns_phy->phy_rst); + return 0; + +put_child: + node++; +put_lnk_rst: + for (i = 0; i < node; i++) + reset_release_bulk(cdns_phy->phys[i].lnk_rst); + reset_control_assert(cdns_phy->apb_rst); + return ret; +} + +static int cdns_torrent_phy_on(struct phy *gphy) +{ + struct cdns_torrent_inst *inst = phy_get_drvdata(gphy); + struct cdns_torrent_phy *cdns_phy = dev_get_priv(gphy->dev); + u32 read_val; + int ret; + + if (cdns_phy->nsubnodes == 1) { + /* Take the PHY lane group out of reset */ + reset_deassert_bulk(inst->lnk_rst); + + /* Take the PHY out of reset */ + ret = reset_control_deassert(cdns_phy->phy_rst); + if (ret) + return ret; + } + + /* + * Wait for cmn_ready assertion + * PHY_PMA_CMN_CTRL1[0] == 1 + */ + ret = regmap_field_read_poll_timeout(cdns_phy->phy_pma_cmn_ctrl_1, + read_val, read_val, 1000, + PLL_LOCK_TIMEOUT); + if (ret) { + dev_err(cdns_phy->dev, "Timeout waiting for CMN ready\n"); + return ret; + } + mdelay(10); + + return 0; +} + +static int cdns_torrent_phy_init(struct phy *phy) +{ + struct cdns_torrent_phy *cdns_phy = dev_get_priv(phy->dev); + const struct cdns_torrent_data *init_data = cdns_phy->init_data; + struct cdns_torrent_vals *cmn_vals, *tx_ln_vals, *rx_ln_vals; + struct cdns_torrent_vals *link_cmn_vals, *xcvr_diag_vals; + struct cdns_torrent_inst *inst = phy_get_drvdata(phy); + enum cdns_torrent_phy_type phy_type = inst->phy_type; + enum cdns_torrent_ssc_mode ssc = inst->ssc_mode; + struct cdns_torrent_vals *pcs_cmn_vals; + struct cdns_reg_pairs *reg_pairs; + struct regmap *regmap; + u32 num_regs; + int i, j; + + if (cdns_phy->nsubnodes > 1) + return 0; + + /** + * Spread spectrum generation is not required or supported + * for SGMII/QSGMII + */ + if (phy_type == TYPE_SGMII || phy_type == TYPE_QSGMII) + ssc = NO_SSC; + + /* PHY configuration specific registers for single link */ + link_cmn_vals = init_data->link_cmn_vals[phy_type][TYPE_NONE][ssc]; + if (link_cmn_vals) { + reg_pairs = link_cmn_vals->reg_pairs; + num_regs = link_cmn_vals->num_regs; + regmap = cdns_phy->regmap_common_cdb; + + /** + * First array value in link_cmn_vals must be of + * PHY_PLL_CFG register + */ + regmap_field_write(cdns_phy->phy_pll_cfg, reg_pairs[0].val); + + for (i = 1; i < num_regs; i++) + regmap_write(regmap, reg_pairs[i].off, + reg_pairs[i].val); + } + + xcvr_diag_vals = init_data->xcvr_diag_vals[phy_type][TYPE_NONE][ssc]; + if (xcvr_diag_vals) { + reg_pairs = xcvr_diag_vals->reg_pairs; + num_regs = xcvr_diag_vals->num_regs; + for (i = 0; i < inst->num_lanes; i++) { + regmap = cdns_phy->regmap_tx_lane_cdb[i + inst->mlane]; + for (j = 0; j < num_regs; j++) + regmap_write(regmap, reg_pairs[j].off, + reg_pairs[j].val); + } + } + + /* PHY PCS common registers configurations */ + pcs_cmn_vals = init_data->pcs_cmn_vals[phy_type][TYPE_NONE][ssc]; + if (pcs_cmn_vals) { + reg_pairs = pcs_cmn_vals->reg_pairs; + num_regs = pcs_cmn_vals->num_regs; + regmap = cdns_phy->regmap_phy_pcs_common_cdb; + for (i = 0; i < num_regs; i++) + regmap_write(regmap, reg_pairs[i].off, + reg_pairs[i].val); + } + + /* PMA common registers configurations */ + cmn_vals = init_data->cmn_vals[phy_type][TYPE_NONE][ssc]; + if (cmn_vals) { + reg_pairs = cmn_vals->reg_pairs; + num_regs = cmn_vals->num_regs; + regmap = cdns_phy->regmap_common_cdb; + for (i = 0; i < num_regs; i++) + regmap_write(regmap, reg_pairs[i].off, + reg_pairs[i].val); + } + + /* PMA TX lane registers configurations */ + tx_ln_vals = init_data->tx_ln_vals[phy_type][TYPE_NONE][ssc]; + if (tx_ln_vals) { + reg_pairs = tx_ln_vals->reg_pairs; + num_regs = tx_ln_vals->num_regs; + for (i = 0; i < inst->num_lanes; i++) { + regmap = cdns_phy->regmap_tx_lane_cdb[i + inst->mlane]; + for (j = 0; j < num_regs; j++) + regmap_write(regmap, reg_pairs[j].off, + reg_pairs[j].val); + } + } + + /* PMA RX lane registers configurations */ + rx_ln_vals = init_data->rx_ln_vals[phy_type][TYPE_NONE][ssc]; + if (rx_ln_vals) { + reg_pairs = rx_ln_vals->reg_pairs; + num_regs = rx_ln_vals->num_regs; + for (i = 0; i < inst->num_lanes; i++) { + regmap = cdns_phy->regmap_rx_lane_cdb[i + inst->mlane]; + for (j = 0; j < num_regs; j++) + regmap_write(regmap, reg_pairs[j].off, + reg_pairs[j].val); + } + } + + return 0; +} + +static int cdns_torrent_phy_off(struct phy *gphy) +{ + struct cdns_torrent_inst *inst = phy_get_drvdata(gphy); + struct cdns_torrent_phy *cdns_phy = dev_get_priv(gphy->dev); + int ret; + + if (cdns_phy->nsubnodes != 1) + return 0; + + ret = reset_control_assert(cdns_phy->phy_rst); + if (ret) + return ret; + + return reset_assert_bulk(inst->lnk_rst); +} + +static int cdns_torrent_phy_remove(struct udevice *dev) +{ + struct cdns_torrent_phy *cdns_phy = dev_get_priv(dev); + int i; + + reset_control_assert(cdns_phy->phy_rst); + reset_control_assert(cdns_phy->apb_rst); + for (i = 0; i < cdns_phy->nsubnodes; i++) + reset_release_bulk(cdns_phy->phys[i].lnk_rst); + + return 0; +} + +/* USB and SGMII/QSGMII link configuration */ +static struct cdns_reg_pairs usb_sgmii_link_cmn_regs[] = { + {0x0002, PHY_PLL_CFG}, + {0x8600, CMN_PDIAG_PLL0_CLK_SEL_M0}, + {0x0601, CMN_PDIAG_PLL1_CLK_SEL_M0} +}; + +static struct cdns_reg_pairs usb_sgmii_xcvr_diag_ln_regs[] = { + {0x0000, XCVR_DIAG_HSCLK_SEL}, + {0x0001, XCVR_DIAG_HSCLK_DIV}, + {0x0041, XCVR_DIAG_PLLDRC_CTRL} +}; + +static struct cdns_reg_pairs sgmii_usb_xcvr_diag_ln_regs[] = { + {0x0011, XCVR_DIAG_HSCLK_SEL}, + {0x0003, XCVR_DIAG_HSCLK_DIV}, + {0x009B, XCVR_DIAG_PLLDRC_CTRL} +}; + +static struct cdns_torrent_vals usb_sgmii_link_cmn_vals = { + .reg_pairs = usb_sgmii_link_cmn_regs, + .num_regs = ARRAY_SIZE(usb_sgmii_link_cmn_regs), +}; + +static struct cdns_torrent_vals usb_sgmii_xcvr_diag_ln_vals = { + .reg_pairs = usb_sgmii_xcvr_diag_ln_regs, + .num_regs = ARRAY_SIZE(usb_sgmii_xcvr_diag_ln_regs), +}; + +static struct cdns_torrent_vals sgmii_usb_xcvr_diag_ln_vals = { + .reg_pairs = sgmii_usb_xcvr_diag_ln_regs, + .num_regs = ARRAY_SIZE(sgmii_usb_xcvr_diag_ln_regs), +}; + +/* PCIe and USB Unique SSC link configuration */ +static struct cdns_reg_pairs pcie_usb_link_cmn_regs[] = { + {0x0003, PHY_PLL_CFG}, + {0x0601, CMN_PDIAG_PLL0_CLK_SEL_M0}, + {0x0400, CMN_PDIAG_PLL0_CLK_SEL_M1}, + {0x8600, CMN_PDIAG_PLL1_CLK_SEL_M0} +}; + +static struct cdns_reg_pairs pcie_usb_xcvr_diag_ln_regs[] = { + {0x0000, XCVR_DIAG_HSCLK_SEL}, + {0x0001, XCVR_DIAG_HSCLK_DIV}, + {0x0012, XCVR_DIAG_PLLDRC_CTRL} +}; + +static struct cdns_reg_pairs usb_pcie_xcvr_diag_ln_regs[] = { + {0x0011, XCVR_DIAG_HSCLK_SEL}, + {0x0001, XCVR_DIAG_HSCLK_DIV}, + {0x00C9, XCVR_DIAG_PLLDRC_CTRL} +}; + +static struct cdns_torrent_vals pcie_usb_link_cmn_vals = { + .reg_pairs = pcie_usb_link_cmn_regs, + .num_regs = ARRAY_SIZE(pcie_usb_link_cmn_regs), +}; + +static struct cdns_torrent_vals pcie_usb_xcvr_diag_ln_vals = { + .reg_pairs = pcie_usb_xcvr_diag_ln_regs, + .num_regs = ARRAY_SIZE(pcie_usb_xcvr_diag_ln_regs), +}; + +static struct cdns_torrent_vals usb_pcie_xcvr_diag_ln_vals = { + .reg_pairs = usb_pcie_xcvr_diag_ln_regs, + .num_regs = ARRAY_SIZE(usb_pcie_xcvr_diag_ln_regs), +}; + +/* USB 100 MHz Ref clk, internal SSC */ +static struct cdns_reg_pairs usb_100_int_ssc_cmn_regs[] = { + {0x0004, CMN_PLL0_DSM_DIAG_M0}, + {0x0004, CMN_PLL0_DSM_DIAG_M1}, + {0x0004, CMN_PLL1_DSM_DIAG_M0}, + {0x0509, CMN_PDIAG_PLL0_CP_PADJ_M0}, + {0x0509, CMN_PDIAG_PLL0_CP_PADJ_M1}, + {0x0509, CMN_PDIAG_PLL1_CP_PADJ_M0}, + {0x0F00, CMN_PDIAG_PLL0_CP_IADJ_M0}, + {0x0F00, CMN_PDIAG_PLL0_CP_IADJ_M1}, + {0x0F00, CMN_PDIAG_PLL1_CP_IADJ_M0}, + {0x0F08, CMN_PDIAG_PLL0_FILT_PADJ_M0}, + {0x0F08, CMN_PDIAG_PLL0_FILT_PADJ_M1}, + {0x0F08, CMN_PDIAG_PLL1_FILT_PADJ_M0}, + {0x0064, CMN_PLL0_INTDIV_M0}, + {0x0050, CMN_PLL0_INTDIV_M1}, + {0x0064, CMN_PLL1_INTDIV_M0}, + {0x0002, CMN_PLL0_FRACDIVH_M0}, + {0x0002, CMN_PLL0_FRACDIVH_M1}, + {0x0002, CMN_PLL1_FRACDIVH_M0}, + {0x0044, CMN_PLL0_HIGH_THR_M0}, + {0x0036, CMN_PLL0_HIGH_THR_M1}, + {0x0044, CMN_PLL1_HIGH_THR_M0}, + {0x0002, CMN_PDIAG_PLL0_CTRL_M0}, + {0x0002, CMN_PDIAG_PLL0_CTRL_M1}, + {0x0002, CMN_PDIAG_PLL1_CTRL_M0}, + {0x0001, CMN_PLL0_SS_CTRL1_M0}, + {0x0001, CMN_PLL0_SS_CTRL1_M1}, + {0x0001, CMN_PLL1_SS_CTRL1_M0}, + {0x011B, CMN_PLL0_SS_CTRL2_M0}, + {0x011B, CMN_PLL0_SS_CTRL2_M1}, + {0x011B, CMN_PLL1_SS_CTRL2_M0}, + {0x006E, CMN_PLL0_SS_CTRL3_M0}, + {0x0058, CMN_PLL0_SS_CTRL3_M1}, + {0x006E, CMN_PLL1_SS_CTRL3_M0}, + {0x000E, CMN_PLL0_SS_CTRL4_M0}, + {0x0012, CMN_PLL0_SS_CTRL4_M1}, + {0x000E, CMN_PLL1_SS_CTRL4_M0}, + {0x0C5E, CMN_PLL0_VCOCAL_REFTIM_START}, + {0x0C5E, CMN_PLL1_VCOCAL_REFTIM_START}, + {0x0C56, CMN_PLL0_VCOCAL_PLLCNT_START}, + {0x0C56, CMN_PLL1_VCOCAL_PLLCNT_START}, + {0x00C7, CMN_PLL0_LOCK_REFCNT_START}, + {0x00C7, CMN_PLL1_LOCK_REFCNT_START}, + {0x00C7, CMN_PLL0_LOCK_PLLCNT_START}, + {0x00C7, CMN_PLL1_LOCK_PLLCNT_START}, + {0x0005, CMN_PLL0_LOCK_PLLCNT_THR}, + {0x0005, CMN_PLL1_LOCK_PLLCNT_THR}, + {0x8200, CMN_CDIAG_CDB_PWRI_OVRD}, + {0x8200, CMN_CDIAG_XCVRC_PWRI_OVRD}, + {0x007F, CMN_TXPUCAL_TUNE}, + {0x007F, CMN_TXPDCAL_TUNE} +}; + +static struct cdns_torrent_vals usb_100_int_ssc_cmn_vals = { + .reg_pairs = usb_100_int_ssc_cmn_regs, + .num_regs = ARRAY_SIZE(usb_100_int_ssc_cmn_regs), +}; + +/* Single USB link configuration */ +static struct cdns_reg_pairs sl_usb_link_cmn_regs[] = { + {0x0000, PHY_PLL_CFG}, + {0x8600, CMN_PDIAG_PLL0_CLK_SEL_M0} +}; + +static struct cdns_reg_pairs sl_usb_xcvr_diag_ln_regs[] = { + {0x0000, XCVR_DIAG_HSCLK_SEL}, + {0x0001, XCVR_DIAG_HSCLK_DIV}, + {0x0041, XCVR_DIAG_PLLDRC_CTRL} +}; + +static struct cdns_torrent_vals sl_usb_link_cmn_vals = { + .reg_pairs = sl_usb_link_cmn_regs, + .num_regs = ARRAY_SIZE(sl_usb_link_cmn_regs), +}; + +static struct cdns_torrent_vals sl_usb_xcvr_diag_ln_vals = { + .reg_pairs = sl_usb_xcvr_diag_ln_regs, + .num_regs = ARRAY_SIZE(sl_usb_xcvr_diag_ln_regs), +}; + +/* USB PHY PCS common configuration */ +static struct cdns_reg_pairs usb_phy_pcs_cmn_regs[] = { + {0x0A0A, PHY_PIPE_USB3_GEN2_PRE_CFG0}, + {0x1000, PHY_PIPE_USB3_GEN2_POST_CFG0}, + {0x0010, PHY_PIPE_USB3_GEN2_POST_CFG1} +}; + +static struct cdns_torrent_vals usb_phy_pcs_cmn_vals = { + .reg_pairs = usb_phy_pcs_cmn_regs, + .num_regs = ARRAY_SIZE(usb_phy_pcs_cmn_regs), +}; + +/* USB 100 MHz Ref clk, no SSC */ +static struct cdns_reg_pairs sl_usb_100_no_ssc_cmn_regs[] = { + {0x0028, CMN_PDIAG_PLL1_CP_PADJ_M0}, + {0x001E, CMN_PLL1_DSM_FBH_OVRD_M0}, + {0x000C, CMN_PLL1_DSM_FBL_OVRD_M0}, + {0x0003, CMN_PLL0_VCOCAL_TCTRL}, + {0x0003, CMN_PLL1_VCOCAL_TCTRL}, + {0x8200, CMN_CDIAG_CDB_PWRI_OVRD}, + {0x8200, CMN_CDIAG_XCVRC_PWRI_OVRD} +}; + +static struct cdns_torrent_vals sl_usb_100_no_ssc_cmn_vals = { + .reg_pairs = sl_usb_100_no_ssc_cmn_regs, + .num_regs = ARRAY_SIZE(sl_usb_100_no_ssc_cmn_regs), +}; + +static struct cdns_reg_pairs usb_100_no_ssc_cmn_regs[] = { + {0x8200, CMN_CDIAG_CDB_PWRI_OVRD}, + {0x8200, CMN_CDIAG_XCVRC_PWRI_OVRD}, + {0x007F, CMN_TXPUCAL_TUNE}, + {0x007F, CMN_TXPDCAL_TUNE} +}; + +static struct cdns_reg_pairs usb_100_no_ssc_tx_ln_regs[] = { + {0x02FF, TX_PSC_A0}, + {0x06AF, TX_PSC_A1}, + {0x06AE, TX_PSC_A2}, + {0x06AE, TX_PSC_A3}, + {0x2A82, TX_TXCC_CTRL}, + {0x0014, TX_TXCC_CPOST_MULT_01}, + {0x0003, XCVR_DIAG_PSC_OVRD} +}; + +static struct cdns_reg_pairs usb_100_no_ssc_rx_ln_regs[] = { + {0x0D1D, RX_PSC_A0}, + {0x0D1D, RX_PSC_A1}, + {0x0D00, RX_PSC_A2}, + {0x0500, RX_PSC_A3}, + {0x0013, RX_SIGDET_HL_FILT_TMR}, + {0x0000, RX_REE_GCSM1_CTRL}, + {0x0C02, RX_REE_ATTEN_THR}, + {0x0330, RX_REE_SMGM_CTRL1}, + {0x0300, RX_REE_SMGM_CTRL2}, + {0x0019, RX_REE_TAP1_CLIP}, + {0x0019, RX_REE_TAP2TON_CLIP}, + {0x1004, RX_DIAG_SIGDET_TUNE}, + {0x00F9, RX_DIAG_NQST_CTRL}, + {0x0C01, RX_DIAG_DFE_AMP_TUNE_2}, + {0x0002, RX_DIAG_DFE_AMP_TUNE_3}, + {0x0000, RX_DIAG_PI_CAP}, + {0x0031, RX_DIAG_PI_RATE}, + {0x0001, RX_DIAG_ACYA}, + {0x018C, RX_CDRLF_CNFG}, + {0x0003, RX_CDRLF_CNFG3} +}; + +static struct cdns_torrent_vals usb_100_no_ssc_cmn_vals = { + .reg_pairs = usb_100_no_ssc_cmn_regs, + .num_regs = ARRAY_SIZE(usb_100_no_ssc_cmn_regs), +}; + +static struct cdns_torrent_vals usb_100_no_ssc_tx_ln_vals = { + .reg_pairs = usb_100_no_ssc_tx_ln_regs, + .num_regs = ARRAY_SIZE(usb_100_no_ssc_tx_ln_regs), +}; + +static struct cdns_torrent_vals usb_100_no_ssc_rx_ln_vals = { + .reg_pairs = usb_100_no_ssc_rx_ln_regs, + .num_regs = ARRAY_SIZE(usb_100_no_ssc_rx_ln_regs), +}; + +/* Single link USB, 100 MHz Ref clk, internal SSC */ +static struct cdns_reg_pairs sl_usb_100_int_ssc_cmn_regs[] = { + {0x0004, CMN_PLL0_DSM_DIAG_M0}, + {0x0004, CMN_PLL1_DSM_DIAG_M0}, + {0x0509, CMN_PDIAG_PLL0_CP_PADJ_M0}, + {0x0509, CMN_PDIAG_PLL1_CP_PADJ_M0}, + {0x0F00, CMN_PDIAG_PLL0_CP_IADJ_M0}, + {0x0F00, CMN_PDIAG_PLL1_CP_IADJ_M0}, + {0x0F08, CMN_PDIAG_PLL0_FILT_PADJ_M0}, + {0x0F08, CMN_PDIAG_PLL1_FILT_PADJ_M0}, + {0x0064, CMN_PLL0_INTDIV_M0}, + {0x0064, CMN_PLL1_INTDIV_M0}, + {0x0002, CMN_PLL0_FRACDIVH_M0}, + {0x0002, CMN_PLL1_FRACDIVH_M0}, + {0x0044, CMN_PLL0_HIGH_THR_M0}, + {0x0044, CMN_PLL1_HIGH_THR_M0}, + {0x0002, CMN_PDIAG_PLL0_CTRL_M0}, + {0x0002, CMN_PDIAG_PLL1_CTRL_M0}, + {0x0001, CMN_PLL0_SS_CTRL1_M0}, + {0x0001, CMN_PLL1_SS_CTRL1_M0}, + {0x011B, CMN_PLL0_SS_CTRL2_M0}, + {0x011B, CMN_PLL1_SS_CTRL2_M0}, + {0x006E, CMN_PLL0_SS_CTRL3_M0}, + {0x006E, CMN_PLL1_SS_CTRL3_M0}, + {0x000E, CMN_PLL0_SS_CTRL4_M0}, + {0x000E, CMN_PLL1_SS_CTRL4_M0}, + {0x0C5E, CMN_PLL0_VCOCAL_REFTIM_START}, + {0x0C5E, CMN_PLL1_VCOCAL_REFTIM_START}, + {0x0C56, CMN_PLL0_VCOCAL_PLLCNT_START}, + {0x0C56, CMN_PLL1_VCOCAL_PLLCNT_START}, + {0x0003, CMN_PLL0_VCOCAL_TCTRL}, + {0x0003, CMN_PLL1_VCOCAL_TCTRL}, + {0x00C7, CMN_PLL0_LOCK_REFCNT_START}, + {0x00C7, CMN_PLL1_LOCK_REFCNT_START}, + {0x00C7, CMN_PLL0_LOCK_PLLCNT_START}, + {0x00C7, CMN_PLL1_LOCK_PLLCNT_START}, + {0x0005, CMN_PLL0_LOCK_PLLCNT_THR}, + {0x0005, CMN_PLL1_LOCK_PLLCNT_THR}, + {0x8200, CMN_CDIAG_CDB_PWRI_OVRD}, + {0x8200, CMN_CDIAG_XCVRC_PWRI_OVRD} +}; + +static struct cdns_torrent_vals sl_usb_100_int_ssc_cmn_vals = { + .reg_pairs = sl_usb_100_int_ssc_cmn_regs, + .num_regs = ARRAY_SIZE(sl_usb_100_int_ssc_cmn_regs), +}; + +/* PCIe and SGMII/QSGMII Unique SSC link configuration */ +static struct cdns_reg_pairs pcie_sgmii_link_cmn_regs[] = { + {0x0003, PHY_PLL_CFG}, + {0x0601, CMN_PDIAG_PLL0_CLK_SEL_M0}, + {0x0400, CMN_PDIAG_PLL0_CLK_SEL_M1}, + {0x0601, CMN_PDIAG_PLL1_CLK_SEL_M0} +}; + +static struct cdns_reg_pairs pcie_sgmii_xcvr_diag_ln_regs[] = { + {0x0000, XCVR_DIAG_HSCLK_SEL}, + {0x0001, XCVR_DIAG_HSCLK_DIV}, + {0x0012, XCVR_DIAG_PLLDRC_CTRL} +}; + +static struct cdns_reg_pairs sgmii_pcie_xcvr_diag_ln_regs[] = { + {0x0011, XCVR_DIAG_HSCLK_SEL}, + {0x0003, XCVR_DIAG_HSCLK_DIV}, + {0x009B, XCVR_DIAG_PLLDRC_CTRL} +}; + +static struct cdns_torrent_vals pcie_sgmii_link_cmn_vals = { + .reg_pairs = pcie_sgmii_link_cmn_regs, + .num_regs = ARRAY_SIZE(pcie_sgmii_link_cmn_regs), +}; + +static struct cdns_torrent_vals pcie_sgmii_xcvr_diag_ln_vals = { + .reg_pairs = pcie_sgmii_xcvr_diag_ln_regs, + .num_regs = ARRAY_SIZE(pcie_sgmii_xcvr_diag_ln_regs), +}; + +static struct cdns_torrent_vals sgmii_pcie_xcvr_diag_ln_vals = { + .reg_pairs = sgmii_pcie_xcvr_diag_ln_regs, + .num_regs = ARRAY_SIZE(sgmii_pcie_xcvr_diag_ln_regs), +}; + +/* SGMII 100 MHz Ref clk, no SSC */ +static struct cdns_reg_pairs sl_sgmii_100_no_ssc_cmn_regs[] = { + {0x0028, CMN_PDIAG_PLL1_CP_PADJ_M0}, + {0x001E, CMN_PLL1_DSM_FBH_OVRD_M0}, + {0x000C, CMN_PLL1_DSM_FBL_OVRD_M0}, + {0x0003, CMN_PLL0_VCOCAL_TCTRL}, + {0x0003, CMN_PLL1_VCOCAL_TCTRL} +}; + +static struct cdns_torrent_vals sl_sgmii_100_no_ssc_cmn_vals = { + .reg_pairs = sl_sgmii_100_no_ssc_cmn_regs, + .num_regs = ARRAY_SIZE(sl_sgmii_100_no_ssc_cmn_regs), +}; + +static struct cdns_reg_pairs sgmii_100_no_ssc_cmn_regs[] = { + {0x007F, CMN_TXPUCAL_TUNE}, + {0x007F, CMN_TXPDCAL_TUNE} +}; + +static struct cdns_reg_pairs sgmii_100_no_ssc_tx_ln_regs[] = { + {0x00F3, TX_PSC_A0}, + {0x04A2, TX_PSC_A2}, + {0x04A2, TX_PSC_A3}, + {0x0000, TX_TXCC_CPOST_MULT_00}, + {0x00B3, DRV_DIAG_TX_DRV} +}; + +static struct cdns_reg_pairs ti_sgmii_100_no_ssc_tx_ln_regs[] = { + {0x00F3, TX_PSC_A0}, + {0x04A2, TX_PSC_A2}, + {0x04A2, TX_PSC_A3}, + {0x0000, TX_TXCC_CPOST_MULT_00}, + {0x00B3, DRV_DIAG_TX_DRV}, + {0x4000, XCVR_DIAG_RXCLK_CTRL}, +}; + +static struct cdns_reg_pairs sgmii_100_no_ssc_rx_ln_regs[] = { + {0x091D, RX_PSC_A0}, + {0x0900, RX_PSC_A2}, + {0x0100, RX_PSC_A3}, + {0x03C7, RX_REE_GCSM1_EQENM_PH1}, + {0x01C7, RX_REE_GCSM1_EQENM_PH2}, + {0x0000, RX_DIAG_DFE_CTRL}, + {0x0019, RX_REE_TAP1_CLIP}, + {0x0019, RX_REE_TAP2TON_CLIP}, + {0x0098, RX_DIAG_NQST_CTRL}, + {0x0C01, RX_DIAG_DFE_AMP_TUNE_2}, + {0x0000, RX_DIAG_DFE_AMP_TUNE_3}, + {0x0000, RX_DIAG_PI_CAP}, + {0x0010, RX_DIAG_PI_RATE}, + {0x0001, RX_DIAG_ACYA}, + {0x018C, RX_CDRLF_CNFG}, +}; + +static struct cdns_torrent_vals sgmii_100_no_ssc_cmn_vals = { + .reg_pairs = sgmii_100_no_ssc_cmn_regs, + .num_regs = ARRAY_SIZE(sgmii_100_no_ssc_cmn_regs), +}; + +static struct cdns_torrent_vals sgmii_100_no_ssc_tx_ln_vals = { + .reg_pairs = sgmii_100_no_ssc_tx_ln_regs, + .num_regs = ARRAY_SIZE(sgmii_100_no_ssc_tx_ln_regs), +}; + +static struct cdns_torrent_vals ti_sgmii_100_no_ssc_tx_ln_vals = { + .reg_pairs = ti_sgmii_100_no_ssc_tx_ln_regs, + .num_regs = ARRAY_SIZE(ti_sgmii_100_no_ssc_tx_ln_regs), +}; + +static struct cdns_torrent_vals sgmii_100_no_ssc_rx_ln_vals = { + .reg_pairs = sgmii_100_no_ssc_rx_ln_regs, + .num_regs = ARRAY_SIZE(sgmii_100_no_ssc_rx_ln_regs), +}; + +/* SGMII 100 MHz Ref clk, internal SSC */ +static struct cdns_reg_pairs sgmii_100_int_ssc_cmn_regs[] = { + {0x0004, CMN_PLL0_DSM_DIAG_M0}, + {0x0004, CMN_PLL0_DSM_DIAG_M1}, + {0x0004, CMN_PLL1_DSM_DIAG_M0}, + {0x0509, CMN_PDIAG_PLL0_CP_PADJ_M0}, + {0x0509, CMN_PDIAG_PLL0_CP_PADJ_M1}, + {0x0509, CMN_PDIAG_PLL1_CP_PADJ_M0}, + {0x0F00, CMN_PDIAG_PLL0_CP_IADJ_M0}, + {0x0F00, CMN_PDIAG_PLL0_CP_IADJ_M1}, + {0x0F00, CMN_PDIAG_PLL1_CP_IADJ_M0}, + {0x0F08, CMN_PDIAG_PLL0_FILT_PADJ_M0}, + {0x0F08, CMN_PDIAG_PLL0_FILT_PADJ_M1}, + {0x0F08, CMN_PDIAG_PLL1_FILT_PADJ_M0}, + {0x0064, CMN_PLL0_INTDIV_M0}, + {0x0050, CMN_PLL0_INTDIV_M1}, + {0x0064, CMN_PLL1_INTDIV_M0}, + {0x0002, CMN_PLL0_FRACDIVH_M0}, + {0x0002, CMN_PLL0_FRACDIVH_M1}, + {0x0002, CMN_PLL1_FRACDIVH_M0}, + {0x0044, CMN_PLL0_HIGH_THR_M0}, + {0x0036, CMN_PLL0_HIGH_THR_M1}, + {0x0044, CMN_PLL1_HIGH_THR_M0}, + {0x0002, CMN_PDIAG_PLL0_CTRL_M0}, + {0x0002, CMN_PDIAG_PLL0_CTRL_M1}, + {0x0002, CMN_PDIAG_PLL1_CTRL_M0}, + {0x0001, CMN_PLL0_SS_CTRL1_M0}, + {0x0001, CMN_PLL0_SS_CTRL1_M1}, + {0x0001, CMN_PLL1_SS_CTRL1_M0}, + {0x011B, CMN_PLL0_SS_CTRL2_M0}, + {0x011B, CMN_PLL0_SS_CTRL2_M1}, + {0x011B, CMN_PLL1_SS_CTRL2_M0}, + {0x006E, CMN_PLL0_SS_CTRL3_M0}, + {0x0058, CMN_PLL0_SS_CTRL3_M1}, + {0x006E, CMN_PLL1_SS_CTRL3_M0}, + {0x000E, CMN_PLL0_SS_CTRL4_M0}, + {0x0012, CMN_PLL0_SS_CTRL4_M1}, + {0x000E, CMN_PLL1_SS_CTRL4_M0}, + {0x0C5E, CMN_PLL0_VCOCAL_REFTIM_START}, + {0x0C5E, CMN_PLL1_VCOCAL_REFTIM_START}, + {0x0C56, CMN_PLL0_VCOCAL_PLLCNT_START}, + {0x0C56, CMN_PLL1_VCOCAL_PLLCNT_START}, + {0x00C7, CMN_PLL0_LOCK_REFCNT_START}, + {0x00C7, CMN_PLL1_LOCK_REFCNT_START}, + {0x00C7, CMN_PLL0_LOCK_PLLCNT_START}, + {0x00C7, CMN_PLL1_LOCK_PLLCNT_START}, + {0x0005, CMN_PLL0_LOCK_PLLCNT_THR}, + {0x0005, CMN_PLL1_LOCK_PLLCNT_THR}, + {0x007F, CMN_TXPUCAL_TUNE}, + {0x007F, CMN_TXPDCAL_TUNE} +}; + +static struct cdns_torrent_vals sgmii_100_int_ssc_cmn_vals = { + .reg_pairs = sgmii_100_int_ssc_cmn_regs, + .num_regs = ARRAY_SIZE(sgmii_100_int_ssc_cmn_regs), +}; + +/* QSGMII 100 MHz Ref clk, no SSC */ +static struct cdns_reg_pairs sl_qsgmii_100_no_ssc_cmn_regs[] = { + {0x0028, CMN_PDIAG_PLL1_CP_PADJ_M0}, + {0x001E, CMN_PLL1_DSM_FBH_OVRD_M0}, + {0x000C, CMN_PLL1_DSM_FBL_OVRD_M0}, + {0x0003, CMN_PLL0_VCOCAL_TCTRL}, + {0x0003, CMN_PLL1_VCOCAL_TCTRL} +}; + +static struct cdns_torrent_vals sl_qsgmii_100_no_ssc_cmn_vals = { + .reg_pairs = sl_qsgmii_100_no_ssc_cmn_regs, + .num_regs = ARRAY_SIZE(sl_qsgmii_100_no_ssc_cmn_regs), +}; + +static struct cdns_reg_pairs qsgmii_100_no_ssc_cmn_regs[] = { + {0x007F, CMN_TXPUCAL_TUNE}, + {0x007F, CMN_TXPDCAL_TUNE} +}; + +static struct cdns_reg_pairs qsgmii_100_no_ssc_tx_ln_regs[] = { + {0x00F3, TX_PSC_A0}, + {0x04A2, TX_PSC_A2}, + {0x04A2, TX_PSC_A3}, + {0x0000, TX_TXCC_CPOST_MULT_00}, + {0x0011, TX_TXCC_MGNFS_MULT_100}, + {0x0003, DRV_DIAG_TX_DRV} +}; + +static struct cdns_reg_pairs ti_qsgmii_100_no_ssc_tx_ln_regs[] = { + {0x00F3, TX_PSC_A0}, + {0x04A2, TX_PSC_A2}, + {0x04A2, TX_PSC_A3}, + {0x0000, TX_TXCC_CPOST_MULT_00}, + {0x0011, TX_TXCC_MGNFS_MULT_100}, + {0x0003, DRV_DIAG_TX_DRV}, + {0x4000, XCVR_DIAG_RXCLK_CTRL}, +}; + +static struct cdns_reg_pairs qsgmii_100_no_ssc_rx_ln_regs[] = { + {0x091D, RX_PSC_A0}, + {0x0900, RX_PSC_A2}, + {0x0100, RX_PSC_A3}, + {0x03C7, RX_REE_GCSM1_EQENM_PH1}, + {0x01C7, RX_REE_GCSM1_EQENM_PH2}, + {0x0000, RX_DIAG_DFE_CTRL}, + {0x0019, RX_REE_TAP1_CLIP}, + {0x0019, RX_REE_TAP2TON_CLIP}, + {0x0098, RX_DIAG_NQST_CTRL}, + {0x0C01, RX_DIAG_DFE_AMP_TUNE_2}, + {0x0000, RX_DIAG_DFE_AMP_TUNE_3}, + {0x0000, RX_DIAG_PI_CAP}, + {0x0010, RX_DIAG_PI_RATE}, + {0x0001, RX_DIAG_ACYA}, + {0x018C, RX_CDRLF_CNFG}, +}; + +static struct cdns_torrent_vals qsgmii_100_no_ssc_cmn_vals = { + .reg_pairs = qsgmii_100_no_ssc_cmn_regs, + .num_regs = ARRAY_SIZE(qsgmii_100_no_ssc_cmn_regs), +}; + +static struct cdns_torrent_vals qsgmii_100_no_ssc_tx_ln_vals = { + .reg_pairs = qsgmii_100_no_ssc_tx_ln_regs, + .num_regs = ARRAY_SIZE(qsgmii_100_no_ssc_tx_ln_regs), +}; + +static struct cdns_torrent_vals ti_qsgmii_100_no_ssc_tx_ln_vals = { + .reg_pairs = ti_qsgmii_100_no_ssc_tx_ln_regs, + .num_regs = ARRAY_SIZE(ti_qsgmii_100_no_ssc_tx_ln_regs), +}; + +static struct cdns_torrent_vals qsgmii_100_no_ssc_rx_ln_vals = { + .reg_pairs = qsgmii_100_no_ssc_rx_ln_regs, + .num_regs = ARRAY_SIZE(qsgmii_100_no_ssc_rx_ln_regs), +}; + +/* QSGMII 100 MHz Ref clk, internal SSC */ +static struct cdns_reg_pairs qsgmii_100_int_ssc_cmn_regs[] = { + {0x0004, CMN_PLL0_DSM_DIAG_M0}, + {0x0004, CMN_PLL0_DSM_DIAG_M1}, + {0x0004, CMN_PLL1_DSM_DIAG_M0}, + {0x0509, CMN_PDIAG_PLL0_CP_PADJ_M0}, + {0x0509, CMN_PDIAG_PLL0_CP_PADJ_M1}, + {0x0509, CMN_PDIAG_PLL1_CP_PADJ_M0}, + {0x0F00, CMN_PDIAG_PLL0_CP_IADJ_M0}, + {0x0F00, CMN_PDIAG_PLL0_CP_IADJ_M1}, + {0x0F00, CMN_PDIAG_PLL1_CP_IADJ_M0}, + {0x0F08, CMN_PDIAG_PLL0_FILT_PADJ_M0}, + {0x0F08, CMN_PDIAG_PLL0_FILT_PADJ_M1}, + {0x0F08, CMN_PDIAG_PLL1_FILT_PADJ_M0}, + {0x0064, CMN_PLL0_INTDIV_M0}, + {0x0050, CMN_PLL0_INTDIV_M1}, + {0x0064, CMN_PLL1_INTDIV_M0}, + {0x0002, CMN_PLL0_FRACDIVH_M0}, + {0x0002, CMN_PLL0_FRACDIVH_M1}, + {0x0002, CMN_PLL1_FRACDIVH_M0}, + {0x0044, CMN_PLL0_HIGH_THR_M0}, + {0x0036, CMN_PLL0_HIGH_THR_M1}, + {0x0044, CMN_PLL1_HIGH_THR_M0}, + {0x0002, CMN_PDIAG_PLL0_CTRL_M0}, + {0x0002, CMN_PDIAG_PLL0_CTRL_M1}, + {0x0002, CMN_PDIAG_PLL1_CTRL_M0}, + {0x0001, CMN_PLL0_SS_CTRL1_M0}, + {0x0001, CMN_PLL0_SS_CTRL1_M1}, + {0x0001, CMN_PLL1_SS_CTRL1_M0}, + {0x011B, CMN_PLL0_SS_CTRL2_M0}, + {0x011B, CMN_PLL0_SS_CTRL2_M1}, + {0x011B, CMN_PLL1_SS_CTRL2_M0}, + {0x006E, CMN_PLL0_SS_CTRL3_M0}, + {0x0058, CMN_PLL0_SS_CTRL3_M1}, + {0x006E, CMN_PLL1_SS_CTRL3_M0}, + {0x000E, CMN_PLL0_SS_CTRL4_M0}, + {0x0012, CMN_PLL0_SS_CTRL4_M1}, + {0x000E, CMN_PLL1_SS_CTRL4_M0}, + {0x0C5E, CMN_PLL0_VCOCAL_REFTIM_START}, + {0x0C5E, CMN_PLL1_VCOCAL_REFTIM_START}, + {0x0C56, CMN_PLL0_VCOCAL_PLLCNT_START}, + {0x0C56, CMN_PLL1_VCOCAL_PLLCNT_START}, + {0x00C7, CMN_PLL0_LOCK_REFCNT_START}, + {0x00C7, CMN_PLL1_LOCK_REFCNT_START}, + {0x00C7, CMN_PLL0_LOCK_PLLCNT_START}, + {0x00C7, CMN_PLL1_LOCK_PLLCNT_START}, + {0x0005, CMN_PLL0_LOCK_PLLCNT_THR}, + {0x0005, CMN_PLL1_LOCK_PLLCNT_THR}, + {0x007F, CMN_TXPUCAL_TUNE}, + {0x007F, CMN_TXPDCAL_TUNE} +}; + +static struct cdns_torrent_vals qsgmii_100_int_ssc_cmn_vals = { + .reg_pairs = qsgmii_100_int_ssc_cmn_regs, + .num_regs = ARRAY_SIZE(qsgmii_100_int_ssc_cmn_regs), +}; + +/* Single SGMII/QSGMII link configuration */ +static struct cdns_reg_pairs sl_sgmii_link_cmn_regs[] = { + {0x0000, PHY_PLL_CFG}, + {0x0601, CMN_PDIAG_PLL0_CLK_SEL_M0} +}; + +static struct cdns_reg_pairs sl_sgmii_xcvr_diag_ln_regs[] = { + {0x0000, XCVR_DIAG_HSCLK_SEL}, + {0x0003, XCVR_DIAG_HSCLK_DIV}, + {0x0013, XCVR_DIAG_PLLDRC_CTRL} +}; + +static struct cdns_torrent_vals sl_sgmii_link_cmn_vals = { + .reg_pairs = sl_sgmii_link_cmn_regs, + .num_regs = ARRAY_SIZE(sl_sgmii_link_cmn_regs), +}; + +static struct cdns_torrent_vals sl_sgmii_xcvr_diag_ln_vals = { + .reg_pairs = sl_sgmii_xcvr_diag_ln_regs, + .num_regs = ARRAY_SIZE(sl_sgmii_xcvr_diag_ln_regs), +}; + +/* Multi link PCIe, 100 MHz Ref clk, internal SSC */ +static struct cdns_reg_pairs pcie_100_int_ssc_cmn_regs[] = { + {0x0004, CMN_PLL0_DSM_DIAG_M0}, + {0x0004, CMN_PLL0_DSM_DIAG_M1}, + {0x0004, CMN_PLL1_DSM_DIAG_M0}, + {0x0509, CMN_PDIAG_PLL0_CP_PADJ_M0}, + {0x0509, CMN_PDIAG_PLL0_CP_PADJ_M1}, + {0x0509, CMN_PDIAG_PLL1_CP_PADJ_M0}, + {0x0F00, CMN_PDIAG_PLL0_CP_IADJ_M0}, + {0x0F00, CMN_PDIAG_PLL0_CP_IADJ_M1}, + {0x0F00, CMN_PDIAG_PLL1_CP_IADJ_M0}, + {0x0F08, CMN_PDIAG_PLL0_FILT_PADJ_M0}, + {0x0F08, CMN_PDIAG_PLL0_FILT_PADJ_M1}, + {0x0F08, CMN_PDIAG_PLL1_FILT_PADJ_M0}, + {0x0064, CMN_PLL0_INTDIV_M0}, + {0x0050, CMN_PLL0_INTDIV_M1}, + {0x0064, CMN_PLL1_INTDIV_M0}, + {0x0002, CMN_PLL0_FRACDIVH_M0}, + {0x0002, CMN_PLL0_FRACDIVH_M1}, + {0x0002, CMN_PLL1_FRACDIVH_M0}, + {0x0044, CMN_PLL0_HIGH_THR_M0}, + {0x0036, CMN_PLL0_HIGH_THR_M1}, + {0x0044, CMN_PLL1_HIGH_THR_M0}, + {0x0002, CMN_PDIAG_PLL0_CTRL_M0}, + {0x0002, CMN_PDIAG_PLL0_CTRL_M1}, + {0x0002, CMN_PDIAG_PLL1_CTRL_M0}, + {0x0001, CMN_PLL0_SS_CTRL1_M0}, + {0x0001, CMN_PLL0_SS_CTRL1_M1}, + {0x0001, CMN_PLL1_SS_CTRL1_M0}, + {0x011B, CMN_PLL0_SS_CTRL2_M0}, + {0x011B, CMN_PLL0_SS_CTRL2_M1}, + {0x011B, CMN_PLL1_SS_CTRL2_M0}, + {0x006E, CMN_PLL0_SS_CTRL3_M0}, + {0x0058, CMN_PLL0_SS_CTRL3_M1}, + {0x006E, CMN_PLL1_SS_CTRL3_M0}, + {0x000E, CMN_PLL0_SS_CTRL4_M0}, + {0x0012, CMN_PLL0_SS_CTRL4_M1}, + {0x000E, CMN_PLL1_SS_CTRL4_M0}, + {0x0C5E, CMN_PLL0_VCOCAL_REFTIM_START}, + {0x0C5E, CMN_PLL1_VCOCAL_REFTIM_START}, + {0x0C56, CMN_PLL0_VCOCAL_PLLCNT_START}, + {0x0C56, CMN_PLL1_VCOCAL_PLLCNT_START}, + {0x00C7, CMN_PLL0_LOCK_REFCNT_START}, + {0x00C7, CMN_PLL1_LOCK_REFCNT_START}, + {0x00C7, CMN_PLL0_LOCK_PLLCNT_START}, + {0x00C7, CMN_PLL1_LOCK_PLLCNT_START}, + {0x0005, CMN_PLL0_LOCK_PLLCNT_THR}, + {0x0005, CMN_PLL1_LOCK_PLLCNT_THR} +}; + +static struct cdns_torrent_vals pcie_100_int_ssc_cmn_vals = { + .reg_pairs = pcie_100_int_ssc_cmn_regs, + .num_regs = ARRAY_SIZE(pcie_100_int_ssc_cmn_regs), +}; + +/* Single link PCIe, 100 MHz Ref clk, internal SSC */ +static struct cdns_reg_pairs sl_pcie_100_int_ssc_cmn_regs[] = { + {0x0004, CMN_PLL0_DSM_DIAG_M0}, + {0x0004, CMN_PLL0_DSM_DIAG_M1}, + {0x0004, CMN_PLL1_DSM_DIAG_M0}, + {0x0509, CMN_PDIAG_PLL0_CP_PADJ_M0}, + {0x0509, CMN_PDIAG_PLL0_CP_PADJ_M1}, + {0x0509, CMN_PDIAG_PLL1_CP_PADJ_M0}, + {0x0F00, CMN_PDIAG_PLL0_CP_IADJ_M0}, + {0x0F00, CMN_PDIAG_PLL0_CP_IADJ_M1}, + {0x0F00, CMN_PDIAG_PLL1_CP_IADJ_M0}, + {0x0F08, CMN_PDIAG_PLL0_FILT_PADJ_M0}, + {0x0F08, CMN_PDIAG_PLL0_FILT_PADJ_M1}, + {0x0F08, CMN_PDIAG_PLL1_FILT_PADJ_M0}, + {0x0064, CMN_PLL0_INTDIV_M0}, + {0x0050, CMN_PLL0_INTDIV_M1}, + {0x0050, CMN_PLL1_INTDIV_M0}, + {0x0002, CMN_PLL0_FRACDIVH_M0}, + {0x0002, CMN_PLL0_FRACDIVH_M1}, + {0x0002, CMN_PLL1_FRACDIVH_M0}, + {0x0044, CMN_PLL0_HIGH_THR_M0}, + {0x0036, CMN_PLL0_HIGH_THR_M1}, + {0x0036, CMN_PLL1_HIGH_THR_M0}, + {0x0002, CMN_PDIAG_PLL0_CTRL_M0}, + {0x0002, CMN_PDIAG_PLL0_CTRL_M1}, + {0x0002, CMN_PDIAG_PLL1_CTRL_M0}, + {0x0001, CMN_PLL0_SS_CTRL1_M0}, + {0x0001, CMN_PLL0_SS_CTRL1_M1}, + {0x0001, CMN_PLL1_SS_CTRL1_M0}, + {0x011B, CMN_PLL0_SS_CTRL2_M0}, + {0x011B, CMN_PLL0_SS_CTRL2_M1}, + {0x011B, CMN_PLL1_SS_CTRL2_M0}, + {0x006E, CMN_PLL0_SS_CTRL3_M0}, + {0x0058, CMN_PLL0_SS_CTRL3_M1}, + {0x0058, CMN_PLL1_SS_CTRL3_M0}, + {0x000E, CMN_PLL0_SS_CTRL4_M0}, + {0x0012, CMN_PLL0_SS_CTRL4_M1}, + {0x0012, CMN_PLL1_SS_CTRL4_M0}, + {0x0C5E, CMN_PLL0_VCOCAL_REFTIM_START}, + {0x0C5E, CMN_PLL1_VCOCAL_REFTIM_START}, + {0x0C56, CMN_PLL0_VCOCAL_PLLCNT_START}, + {0x0C56, CMN_PLL1_VCOCAL_PLLCNT_START}, + {0x00C7, CMN_PLL0_LOCK_REFCNT_START}, + {0x00C7, CMN_PLL1_LOCK_REFCNT_START}, + {0x00C7, CMN_PLL0_LOCK_PLLCNT_START}, + {0x00C7, CMN_PLL1_LOCK_PLLCNT_START}, + {0x0005, CMN_PLL0_LOCK_PLLCNT_THR}, + {0x0005, CMN_PLL1_LOCK_PLLCNT_THR} +}; + +static struct cdns_torrent_vals sl_pcie_100_int_ssc_cmn_vals = { + .reg_pairs = sl_pcie_100_int_ssc_cmn_regs, + .num_regs = ARRAY_SIZE(sl_pcie_100_int_ssc_cmn_regs), +}; + +/* PCIe, 100 MHz Ref clk, no SSC & external SSC */ +static struct cdns_reg_pairs pcie_100_ext_no_ssc_cmn_regs[] = { + {0x0028, CMN_PDIAG_PLL1_CP_PADJ_M0}, + {0x001E, CMN_PLL1_DSM_FBH_OVRD_M0}, + {0x000C, CMN_PLL1_DSM_FBL_OVRD_M0} +}; + +static struct cdns_reg_pairs pcie_100_ext_no_ssc_rx_ln_regs[] = { + {0x0019, RX_REE_TAP1_CLIP}, + {0x0019, RX_REE_TAP2TON_CLIP}, + {0x0001, RX_DIAG_ACYA} +}; + +static struct cdns_torrent_vals pcie_100_no_ssc_cmn_vals = { + .reg_pairs = pcie_100_ext_no_ssc_cmn_regs, + .num_regs = ARRAY_SIZE(pcie_100_ext_no_ssc_cmn_regs), +}; + +static struct cdns_torrent_vals pcie_100_no_ssc_rx_ln_vals = { + .reg_pairs = pcie_100_ext_no_ssc_rx_ln_regs, + .num_regs = ARRAY_SIZE(pcie_100_ext_no_ssc_rx_ln_regs), +}; + +static const struct cdns_torrent_data cdns_map_torrent = { + .block_offset_shift = 0x2, + .reg_offset_shift = 0x2, + .link_cmn_vals = { + [TYPE_PCIE] = { + [TYPE_NONE] = { + [NO_SSC] = NULL, + [EXTERNAL_SSC] = NULL, + [INTERNAL_SSC] = NULL, + }, + [TYPE_SGMII] = { + [NO_SSC] = &pcie_sgmii_link_cmn_vals, + [EXTERNAL_SSC] = &pcie_sgmii_link_cmn_vals, + [INTERNAL_SSC] = &pcie_sgmii_link_cmn_vals, + }, + [TYPE_QSGMII] = { + [NO_SSC] = &pcie_sgmii_link_cmn_vals, + [EXTERNAL_SSC] = &pcie_sgmii_link_cmn_vals, + [INTERNAL_SSC] = &pcie_sgmii_link_cmn_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &pcie_usb_link_cmn_vals, + [EXTERNAL_SSC] = &pcie_usb_link_cmn_vals, + [INTERNAL_SSC] = &pcie_usb_link_cmn_vals, + }, + }, + [TYPE_SGMII] = { + [TYPE_NONE] = { + [NO_SSC] = &sl_sgmii_link_cmn_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &pcie_sgmii_link_cmn_vals, + [EXTERNAL_SSC] = &pcie_sgmii_link_cmn_vals, + [INTERNAL_SSC] = &pcie_sgmii_link_cmn_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &usb_sgmii_link_cmn_vals, + [EXTERNAL_SSC] = &usb_sgmii_link_cmn_vals, + [INTERNAL_SSC] = &usb_sgmii_link_cmn_vals, + }, + }, + [TYPE_QSGMII] = { + [TYPE_NONE] = { + [NO_SSC] = &sl_sgmii_link_cmn_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &pcie_sgmii_link_cmn_vals, + [EXTERNAL_SSC] = &pcie_sgmii_link_cmn_vals, + [INTERNAL_SSC] = &pcie_sgmii_link_cmn_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &usb_sgmii_link_cmn_vals, + [EXTERNAL_SSC] = &usb_sgmii_link_cmn_vals, + [INTERNAL_SSC] = &usb_sgmii_link_cmn_vals, + }, + }, + [TYPE_USB] = { + [TYPE_NONE] = { + [NO_SSC] = &sl_usb_link_cmn_vals, + [EXTERNAL_SSC] = &sl_usb_link_cmn_vals, + [INTERNAL_SSC] = &sl_usb_link_cmn_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &pcie_usb_link_cmn_vals, + [EXTERNAL_SSC] = &pcie_usb_link_cmn_vals, + [INTERNAL_SSC] = &pcie_usb_link_cmn_vals, + }, + [TYPE_SGMII] = { + [NO_SSC] = &usb_sgmii_link_cmn_vals, + [EXTERNAL_SSC] = &usb_sgmii_link_cmn_vals, + [INTERNAL_SSC] = &usb_sgmii_link_cmn_vals, + }, + [TYPE_QSGMII] = { + [NO_SSC] = &usb_sgmii_link_cmn_vals, + [EXTERNAL_SSC] = &usb_sgmii_link_cmn_vals, + [INTERNAL_SSC] = &usb_sgmii_link_cmn_vals, + }, + }, + }, + .xcvr_diag_vals = { + [TYPE_PCIE] = { + [TYPE_NONE] = { + [NO_SSC] = NULL, + [EXTERNAL_SSC] = NULL, + [INTERNAL_SSC] = NULL, + }, + [TYPE_SGMII] = { + [NO_SSC] = &pcie_sgmii_xcvr_diag_ln_vals, + [EXTERNAL_SSC] = &pcie_sgmii_xcvr_diag_ln_vals, + [INTERNAL_SSC] = &pcie_sgmii_xcvr_diag_ln_vals, + }, + [TYPE_QSGMII] = { + [NO_SSC] = &pcie_sgmii_xcvr_diag_ln_vals, + [EXTERNAL_SSC] = &pcie_sgmii_xcvr_diag_ln_vals, + [INTERNAL_SSC] = &pcie_sgmii_xcvr_diag_ln_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &pcie_usb_xcvr_diag_ln_vals, + [EXTERNAL_SSC] = &pcie_usb_xcvr_diag_ln_vals, + [INTERNAL_SSC] = &pcie_usb_xcvr_diag_ln_vals, + }, + }, + [TYPE_SGMII] = { + [TYPE_NONE] = { + [NO_SSC] = &sl_sgmii_xcvr_diag_ln_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &sgmii_pcie_xcvr_diag_ln_vals, + [EXTERNAL_SSC] = &sgmii_pcie_xcvr_diag_ln_vals, + [INTERNAL_SSC] = &sgmii_pcie_xcvr_diag_ln_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &sgmii_usb_xcvr_diag_ln_vals, + [EXTERNAL_SSC] = &sgmii_usb_xcvr_diag_ln_vals, + [INTERNAL_SSC] = &sgmii_usb_xcvr_diag_ln_vals, + }, + }, + [TYPE_QSGMII] = { + [TYPE_NONE] = { + [NO_SSC] = &sl_sgmii_xcvr_diag_ln_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &sgmii_pcie_xcvr_diag_ln_vals, + [EXTERNAL_SSC] = &sgmii_pcie_xcvr_diag_ln_vals, + [INTERNAL_SSC] = &sgmii_pcie_xcvr_diag_ln_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &sgmii_usb_xcvr_diag_ln_vals, + [EXTERNAL_SSC] = &sgmii_usb_xcvr_diag_ln_vals, + [INTERNAL_SSC] = &sgmii_usb_xcvr_diag_ln_vals, + }, + }, + [TYPE_USB] = { + [TYPE_NONE] = { + [NO_SSC] = &sl_usb_xcvr_diag_ln_vals, + [EXTERNAL_SSC] = &sl_usb_xcvr_diag_ln_vals, + [INTERNAL_SSC] = &sl_usb_xcvr_diag_ln_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &usb_pcie_xcvr_diag_ln_vals, + [EXTERNAL_SSC] = &usb_pcie_xcvr_diag_ln_vals, + [INTERNAL_SSC] = &usb_pcie_xcvr_diag_ln_vals, + }, + [TYPE_SGMII] = { + [NO_SSC] = &usb_sgmii_xcvr_diag_ln_vals, + [EXTERNAL_SSC] = &usb_sgmii_xcvr_diag_ln_vals, + [INTERNAL_SSC] = &usb_sgmii_xcvr_diag_ln_vals, + }, + [TYPE_QSGMII] = { + [NO_SSC] = &usb_sgmii_xcvr_diag_ln_vals, + [EXTERNAL_SSC] = &usb_sgmii_xcvr_diag_ln_vals, + [INTERNAL_SSC] = &usb_sgmii_xcvr_diag_ln_vals, + }, + }, + }, + .pcs_cmn_vals = { + [TYPE_USB] = { + [TYPE_NONE] = { + [NO_SSC] = &usb_phy_pcs_cmn_vals, + [EXTERNAL_SSC] = &usb_phy_pcs_cmn_vals, + [INTERNAL_SSC] = &usb_phy_pcs_cmn_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &usb_phy_pcs_cmn_vals, + [EXTERNAL_SSC] = &usb_phy_pcs_cmn_vals, + [INTERNAL_SSC] = &usb_phy_pcs_cmn_vals, + }, + [TYPE_SGMII] = { + [NO_SSC] = &usb_phy_pcs_cmn_vals, + [EXTERNAL_SSC] = &usb_phy_pcs_cmn_vals, + [INTERNAL_SSC] = &usb_phy_pcs_cmn_vals, + }, + [TYPE_QSGMII] = { + [NO_SSC] = &usb_phy_pcs_cmn_vals, + [EXTERNAL_SSC] = &usb_phy_pcs_cmn_vals, + [INTERNAL_SSC] = &usb_phy_pcs_cmn_vals, + }, + }, + }, + .cmn_vals = { + [TYPE_PCIE] = { + [TYPE_NONE] = { + [NO_SSC] = NULL, + [EXTERNAL_SSC] = NULL, + [INTERNAL_SSC] = &sl_pcie_100_int_ssc_cmn_vals, + }, + [TYPE_SGMII] = { + [NO_SSC] = &pcie_100_no_ssc_cmn_vals, + [EXTERNAL_SSC] = &pcie_100_no_ssc_cmn_vals, + [INTERNAL_SSC] = &pcie_100_int_ssc_cmn_vals, + }, + [TYPE_QSGMII] = { + [NO_SSC] = &pcie_100_no_ssc_cmn_vals, + [EXTERNAL_SSC] = &pcie_100_no_ssc_cmn_vals, + [INTERNAL_SSC] = &pcie_100_int_ssc_cmn_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &pcie_100_no_ssc_cmn_vals, + [EXTERNAL_SSC] = &pcie_100_no_ssc_cmn_vals, + [INTERNAL_SSC] = &pcie_100_int_ssc_cmn_vals, + }, + }, + [TYPE_SGMII] = { + [TYPE_NONE] = { + [NO_SSC] = &sl_sgmii_100_no_ssc_cmn_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &sgmii_100_no_ssc_cmn_vals, + [EXTERNAL_SSC] = &sgmii_100_no_ssc_cmn_vals, + [INTERNAL_SSC] = &sgmii_100_int_ssc_cmn_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &sgmii_100_no_ssc_cmn_vals, + [EXTERNAL_SSC] = &sgmii_100_no_ssc_cmn_vals, + [INTERNAL_SSC] = &sgmii_100_no_ssc_cmn_vals, + }, + }, + [TYPE_QSGMII] = { + [TYPE_NONE] = { + [NO_SSC] = &sl_qsgmii_100_no_ssc_cmn_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &qsgmii_100_no_ssc_cmn_vals, + [EXTERNAL_SSC] = &qsgmii_100_no_ssc_cmn_vals, + [INTERNAL_SSC] = &qsgmii_100_int_ssc_cmn_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &qsgmii_100_no_ssc_cmn_vals, + [EXTERNAL_SSC] = &qsgmii_100_no_ssc_cmn_vals, + [INTERNAL_SSC] = &qsgmii_100_no_ssc_cmn_vals, + }, + }, + [TYPE_USB] = { + [TYPE_NONE] = { + [NO_SSC] = &sl_usb_100_no_ssc_cmn_vals, + [EXTERNAL_SSC] = &sl_usb_100_no_ssc_cmn_vals, + [INTERNAL_SSC] = &sl_usb_100_int_ssc_cmn_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &usb_100_no_ssc_cmn_vals, + [EXTERNAL_SSC] = &usb_100_no_ssc_cmn_vals, + [INTERNAL_SSC] = &usb_100_int_ssc_cmn_vals, + }, + [TYPE_SGMII] = { + [NO_SSC] = &sl_usb_100_no_ssc_cmn_vals, + [EXTERNAL_SSC] = &sl_usb_100_no_ssc_cmn_vals, + [INTERNAL_SSC] = &sl_usb_100_int_ssc_cmn_vals, + }, + [TYPE_QSGMII] = { + [NO_SSC] = &sl_usb_100_no_ssc_cmn_vals, + [EXTERNAL_SSC] = &sl_usb_100_no_ssc_cmn_vals, + [INTERNAL_SSC] = &sl_usb_100_int_ssc_cmn_vals, + }, + }, + }, + .tx_ln_vals = { + [TYPE_PCIE] = { + [TYPE_NONE] = { + [NO_SSC] = NULL, + [EXTERNAL_SSC] = NULL, + [INTERNAL_SSC] = NULL, + }, + [TYPE_SGMII] = { + [NO_SSC] = NULL, + [EXTERNAL_SSC] = NULL, + [INTERNAL_SSC] = NULL, + }, + [TYPE_QSGMII] = { + [NO_SSC] = NULL, + [EXTERNAL_SSC] = NULL, + [INTERNAL_SSC] = NULL, + }, + [TYPE_USB] = { + [NO_SSC] = NULL, + [EXTERNAL_SSC] = NULL, + [INTERNAL_SSC] = NULL, + }, + }, + [TYPE_SGMII] = { + [TYPE_NONE] = { + [NO_SSC] = &sgmii_100_no_ssc_tx_ln_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &sgmii_100_no_ssc_tx_ln_vals, + [EXTERNAL_SSC] = &sgmii_100_no_ssc_tx_ln_vals, + [INTERNAL_SSC] = &sgmii_100_no_ssc_tx_ln_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &sgmii_100_no_ssc_tx_ln_vals, + [EXTERNAL_SSC] = &sgmii_100_no_ssc_tx_ln_vals, + [INTERNAL_SSC] = &sgmii_100_no_ssc_tx_ln_vals, + }, + }, + [TYPE_QSGMII] = { + [TYPE_NONE] = { + [NO_SSC] = &qsgmii_100_no_ssc_tx_ln_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &qsgmii_100_no_ssc_tx_ln_vals, + [EXTERNAL_SSC] = &qsgmii_100_no_ssc_tx_ln_vals, + [INTERNAL_SSC] = &qsgmii_100_no_ssc_tx_ln_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &qsgmii_100_no_ssc_tx_ln_vals, + [EXTERNAL_SSC] = &qsgmii_100_no_ssc_tx_ln_vals, + [INTERNAL_SSC] = &qsgmii_100_no_ssc_tx_ln_vals, + }, + }, + [TYPE_USB] = { + [TYPE_NONE] = { + [NO_SSC] = &usb_100_no_ssc_tx_ln_vals, + [EXTERNAL_SSC] = &usb_100_no_ssc_tx_ln_vals, + [INTERNAL_SSC] = &usb_100_no_ssc_tx_ln_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &usb_100_no_ssc_tx_ln_vals, + [EXTERNAL_SSC] = &usb_100_no_ssc_tx_ln_vals, + [INTERNAL_SSC] = &usb_100_no_ssc_tx_ln_vals, + }, + [TYPE_SGMII] = { + [NO_SSC] = &usb_100_no_ssc_tx_ln_vals, + [EXTERNAL_SSC] = &usb_100_no_ssc_tx_ln_vals, + [INTERNAL_SSC] = &usb_100_no_ssc_tx_ln_vals, + }, + [TYPE_QSGMII] = { + [NO_SSC] = &usb_100_no_ssc_tx_ln_vals, + [EXTERNAL_SSC] = &usb_100_no_ssc_tx_ln_vals, + [INTERNAL_SSC] = &usb_100_no_ssc_tx_ln_vals, + }, + }, + }, + .rx_ln_vals = { + [TYPE_PCIE] = { + [TYPE_NONE] = { + [NO_SSC] = &pcie_100_no_ssc_rx_ln_vals, + [EXTERNAL_SSC] = &pcie_100_no_ssc_rx_ln_vals, + [INTERNAL_SSC] = &pcie_100_no_ssc_rx_ln_vals, + }, + [TYPE_SGMII] = { + [NO_SSC] = &pcie_100_no_ssc_rx_ln_vals, + [EXTERNAL_SSC] = &pcie_100_no_ssc_rx_ln_vals, + [INTERNAL_SSC] = &pcie_100_no_ssc_rx_ln_vals, + }, + [TYPE_QSGMII] = { + [NO_SSC] = &pcie_100_no_ssc_rx_ln_vals, + [EXTERNAL_SSC] = &pcie_100_no_ssc_rx_ln_vals, + [INTERNAL_SSC] = &pcie_100_no_ssc_rx_ln_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &pcie_100_no_ssc_rx_ln_vals, + [EXTERNAL_SSC] = &pcie_100_no_ssc_rx_ln_vals, + [INTERNAL_SSC] = &pcie_100_no_ssc_rx_ln_vals, + }, + }, + [TYPE_SGMII] = { + [TYPE_NONE] = { + [NO_SSC] = &sgmii_100_no_ssc_rx_ln_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &sgmii_100_no_ssc_rx_ln_vals, + [EXTERNAL_SSC] = &sgmii_100_no_ssc_rx_ln_vals, + [INTERNAL_SSC] = &sgmii_100_no_ssc_rx_ln_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &sgmii_100_no_ssc_rx_ln_vals, + [EXTERNAL_SSC] = &sgmii_100_no_ssc_rx_ln_vals, + [INTERNAL_SSC] = &sgmii_100_no_ssc_rx_ln_vals, + }, + }, + [TYPE_QSGMII] = { + [TYPE_NONE] = { + [NO_SSC] = &qsgmii_100_no_ssc_rx_ln_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &qsgmii_100_no_ssc_rx_ln_vals, + [EXTERNAL_SSC] = &qsgmii_100_no_ssc_rx_ln_vals, + [INTERNAL_SSC] = &qsgmii_100_no_ssc_rx_ln_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &qsgmii_100_no_ssc_rx_ln_vals, + [EXTERNAL_SSC] = &qsgmii_100_no_ssc_rx_ln_vals, + [INTERNAL_SSC] = &qsgmii_100_no_ssc_rx_ln_vals, + }, + }, + [TYPE_USB] = { + [TYPE_NONE] = { + [NO_SSC] = &usb_100_no_ssc_rx_ln_vals, + [EXTERNAL_SSC] = &usb_100_no_ssc_rx_ln_vals, + [INTERNAL_SSC] = &usb_100_no_ssc_rx_ln_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &usb_100_no_ssc_rx_ln_vals, + [EXTERNAL_SSC] = &usb_100_no_ssc_rx_ln_vals, + [INTERNAL_SSC] = &usb_100_no_ssc_rx_ln_vals, + }, + [TYPE_SGMII] = { + [NO_SSC] = &usb_100_no_ssc_rx_ln_vals, + [EXTERNAL_SSC] = &usb_100_no_ssc_rx_ln_vals, + [INTERNAL_SSC] = &usb_100_no_ssc_rx_ln_vals, + }, + [TYPE_QSGMII] = { + [NO_SSC] = &usb_100_no_ssc_rx_ln_vals, + [EXTERNAL_SSC] = &usb_100_no_ssc_rx_ln_vals, + [INTERNAL_SSC] = &usb_100_no_ssc_rx_ln_vals, + }, + }, + }, +}; + +static const struct cdns_torrent_data ti_j721e_map_torrent = { + .block_offset_shift = 0x0, + .reg_offset_shift = 0x1, + .link_cmn_vals = { + [TYPE_PCIE] = { + [TYPE_NONE] = { + [NO_SSC] = NULL, + [EXTERNAL_SSC] = NULL, + [INTERNAL_SSC] = NULL, + }, + [TYPE_SGMII] = { + [NO_SSC] = &pcie_sgmii_link_cmn_vals, + [EXTERNAL_SSC] = &pcie_sgmii_link_cmn_vals, + [INTERNAL_SSC] = &pcie_sgmii_link_cmn_vals, + }, + [TYPE_QSGMII] = { + [NO_SSC] = &pcie_sgmii_link_cmn_vals, + [EXTERNAL_SSC] = &pcie_sgmii_link_cmn_vals, + [INTERNAL_SSC] = &pcie_sgmii_link_cmn_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &pcie_usb_link_cmn_vals, + [EXTERNAL_SSC] = &pcie_usb_link_cmn_vals, + [INTERNAL_SSC] = &pcie_usb_link_cmn_vals, + }, + }, + [TYPE_SGMII] = { + [TYPE_NONE] = { + [NO_SSC] = &sl_sgmii_link_cmn_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &pcie_sgmii_link_cmn_vals, + [EXTERNAL_SSC] = &pcie_sgmii_link_cmn_vals, + [INTERNAL_SSC] = &pcie_sgmii_link_cmn_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &usb_sgmii_link_cmn_vals, + [EXTERNAL_SSC] = &usb_sgmii_link_cmn_vals, + [INTERNAL_SSC] = &usb_sgmii_link_cmn_vals, + }, + }, + [TYPE_QSGMII] = { + [TYPE_NONE] = { + [NO_SSC] = &sl_sgmii_link_cmn_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &pcie_sgmii_link_cmn_vals, + [EXTERNAL_SSC] = &pcie_sgmii_link_cmn_vals, + [INTERNAL_SSC] = &pcie_sgmii_link_cmn_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &usb_sgmii_link_cmn_vals, + [EXTERNAL_SSC] = &usb_sgmii_link_cmn_vals, + [INTERNAL_SSC] = &usb_sgmii_link_cmn_vals, + }, + }, + [TYPE_USB] = { + [TYPE_NONE] = { + [NO_SSC] = &sl_usb_link_cmn_vals, + [EXTERNAL_SSC] = &sl_usb_link_cmn_vals, + [INTERNAL_SSC] = &sl_usb_link_cmn_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &pcie_usb_link_cmn_vals, + [EXTERNAL_SSC] = &pcie_usb_link_cmn_vals, + [INTERNAL_SSC] = &pcie_usb_link_cmn_vals, + }, + [TYPE_SGMII] = { + [NO_SSC] = &usb_sgmii_link_cmn_vals, + [EXTERNAL_SSC] = &usb_sgmii_link_cmn_vals, + [INTERNAL_SSC] = &usb_sgmii_link_cmn_vals, + }, + [TYPE_QSGMII] = { + [NO_SSC] = &usb_sgmii_link_cmn_vals, + [EXTERNAL_SSC] = &usb_sgmii_link_cmn_vals, + [INTERNAL_SSC] = &usb_sgmii_link_cmn_vals, + }, + }, + }, + .xcvr_diag_vals = { + [TYPE_PCIE] = { + [TYPE_NONE] = { + [NO_SSC] = NULL, + [EXTERNAL_SSC] = NULL, + [INTERNAL_SSC] = NULL, + }, + [TYPE_SGMII] = { + [NO_SSC] = &pcie_sgmii_xcvr_diag_ln_vals, + [EXTERNAL_SSC] = &pcie_sgmii_xcvr_diag_ln_vals, + [INTERNAL_SSC] = &pcie_sgmii_xcvr_diag_ln_vals, + }, + [TYPE_QSGMII] = { + [NO_SSC] = &pcie_sgmii_xcvr_diag_ln_vals, + [EXTERNAL_SSC] = &pcie_sgmii_xcvr_diag_ln_vals, + [INTERNAL_SSC] = &pcie_sgmii_xcvr_diag_ln_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &pcie_usb_xcvr_diag_ln_vals, + [EXTERNAL_SSC] = &pcie_usb_xcvr_diag_ln_vals, + [INTERNAL_SSC] = &pcie_usb_xcvr_diag_ln_vals, + }, + }, + [TYPE_SGMII] = { + [TYPE_NONE] = { + [NO_SSC] = &sl_sgmii_xcvr_diag_ln_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &sgmii_pcie_xcvr_diag_ln_vals, + [EXTERNAL_SSC] = &sgmii_pcie_xcvr_diag_ln_vals, + [INTERNAL_SSC] = &sgmii_pcie_xcvr_diag_ln_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &sgmii_usb_xcvr_diag_ln_vals, + [EXTERNAL_SSC] = &sgmii_usb_xcvr_diag_ln_vals, + [INTERNAL_SSC] = &sgmii_usb_xcvr_diag_ln_vals, + }, + }, + [TYPE_QSGMII] = { + [TYPE_NONE] = { + [NO_SSC] = &sl_sgmii_xcvr_diag_ln_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &sgmii_pcie_xcvr_diag_ln_vals, + [EXTERNAL_SSC] = &sgmii_pcie_xcvr_diag_ln_vals, + [INTERNAL_SSC] = &sgmii_pcie_xcvr_diag_ln_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &sgmii_usb_xcvr_diag_ln_vals, + [EXTERNAL_SSC] = &sgmii_usb_xcvr_diag_ln_vals, + [INTERNAL_SSC] = &sgmii_usb_xcvr_diag_ln_vals, + }, + }, + [TYPE_USB] = { + [TYPE_NONE] = { + [NO_SSC] = &sl_usb_xcvr_diag_ln_vals, + [EXTERNAL_SSC] = &sl_usb_xcvr_diag_ln_vals, + [INTERNAL_SSC] = &sl_usb_xcvr_diag_ln_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &usb_pcie_xcvr_diag_ln_vals, + [EXTERNAL_SSC] = &usb_pcie_xcvr_diag_ln_vals, + [INTERNAL_SSC] = &usb_pcie_xcvr_diag_ln_vals, + }, + [TYPE_SGMII] = { + [NO_SSC] = &usb_sgmii_xcvr_diag_ln_vals, + [EXTERNAL_SSC] = &usb_sgmii_xcvr_diag_ln_vals, + [INTERNAL_SSC] = &usb_sgmii_xcvr_diag_ln_vals, + }, + [TYPE_QSGMII] = { + [NO_SSC] = &usb_sgmii_xcvr_diag_ln_vals, + [EXTERNAL_SSC] = &usb_sgmii_xcvr_diag_ln_vals, + [INTERNAL_SSC] = &usb_sgmii_xcvr_diag_ln_vals, + }, + }, + }, + .pcs_cmn_vals = { + [TYPE_USB] = { + [TYPE_NONE] = { + [NO_SSC] = &usb_phy_pcs_cmn_vals, + [EXTERNAL_SSC] = &usb_phy_pcs_cmn_vals, + [INTERNAL_SSC] = &usb_phy_pcs_cmn_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &usb_phy_pcs_cmn_vals, + [EXTERNAL_SSC] = &usb_phy_pcs_cmn_vals, + [INTERNAL_SSC] = &usb_phy_pcs_cmn_vals, + }, + [TYPE_SGMII] = { + [NO_SSC] = &usb_phy_pcs_cmn_vals, + [EXTERNAL_SSC] = &usb_phy_pcs_cmn_vals, + [INTERNAL_SSC] = &usb_phy_pcs_cmn_vals, + }, + [TYPE_QSGMII] = { + [NO_SSC] = &usb_phy_pcs_cmn_vals, + [EXTERNAL_SSC] = &usb_phy_pcs_cmn_vals, + [INTERNAL_SSC] = &usb_phy_pcs_cmn_vals, + }, + }, + }, + .cmn_vals = { + [TYPE_PCIE] = { + [TYPE_NONE] = { + [NO_SSC] = NULL, + [EXTERNAL_SSC] = NULL, + [INTERNAL_SSC] = &sl_pcie_100_int_ssc_cmn_vals, + }, + [TYPE_SGMII] = { + [NO_SSC] = &pcie_100_no_ssc_cmn_vals, + [EXTERNAL_SSC] = &pcie_100_no_ssc_cmn_vals, + [INTERNAL_SSC] = &pcie_100_int_ssc_cmn_vals, + }, + [TYPE_QSGMII] = { + [NO_SSC] = &pcie_100_no_ssc_cmn_vals, + [EXTERNAL_SSC] = &pcie_100_no_ssc_cmn_vals, + [INTERNAL_SSC] = &pcie_100_int_ssc_cmn_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &pcie_100_no_ssc_cmn_vals, + [EXTERNAL_SSC] = &pcie_100_no_ssc_cmn_vals, + [INTERNAL_SSC] = &pcie_100_int_ssc_cmn_vals, + }, + }, + [TYPE_SGMII] = { + [TYPE_NONE] = { + [NO_SSC] = &sl_sgmii_100_no_ssc_cmn_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &sgmii_100_no_ssc_cmn_vals, + [EXTERNAL_SSC] = &sgmii_100_no_ssc_cmn_vals, + [INTERNAL_SSC] = &sgmii_100_int_ssc_cmn_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &sgmii_100_no_ssc_cmn_vals, + [EXTERNAL_SSC] = &sgmii_100_no_ssc_cmn_vals, + [INTERNAL_SSC] = &sgmii_100_no_ssc_cmn_vals, + }, + }, + [TYPE_QSGMII] = { + [TYPE_NONE] = { + [NO_SSC] = &sl_qsgmii_100_no_ssc_cmn_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &qsgmii_100_no_ssc_cmn_vals, + [EXTERNAL_SSC] = &qsgmii_100_no_ssc_cmn_vals, + [INTERNAL_SSC] = &qsgmii_100_int_ssc_cmn_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &qsgmii_100_no_ssc_cmn_vals, + [EXTERNAL_SSC] = &qsgmii_100_no_ssc_cmn_vals, + [INTERNAL_SSC] = &qsgmii_100_no_ssc_cmn_vals, + }, + }, + [TYPE_USB] = { + [TYPE_NONE] = { + [NO_SSC] = &sl_usb_100_no_ssc_cmn_vals, + [EXTERNAL_SSC] = &sl_usb_100_no_ssc_cmn_vals, + [INTERNAL_SSC] = &sl_usb_100_int_ssc_cmn_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &usb_100_no_ssc_cmn_vals, + [EXTERNAL_SSC] = &usb_100_no_ssc_cmn_vals, + [INTERNAL_SSC] = &usb_100_int_ssc_cmn_vals, + }, + [TYPE_SGMII] = { + [NO_SSC] = &sl_usb_100_no_ssc_cmn_vals, + [EXTERNAL_SSC] = &sl_usb_100_no_ssc_cmn_vals, + [INTERNAL_SSC] = &sl_usb_100_int_ssc_cmn_vals, + }, + [TYPE_QSGMII] = { + [NO_SSC] = &sl_usb_100_no_ssc_cmn_vals, + [EXTERNAL_SSC] = &sl_usb_100_no_ssc_cmn_vals, + [INTERNAL_SSC] = &sl_usb_100_int_ssc_cmn_vals, + }, + }, + }, + .tx_ln_vals = { + [TYPE_PCIE] = { + [TYPE_NONE] = { + [NO_SSC] = NULL, + [EXTERNAL_SSC] = NULL, + [INTERNAL_SSC] = NULL, + }, + [TYPE_SGMII] = { + [NO_SSC] = NULL, + [EXTERNAL_SSC] = NULL, + [INTERNAL_SSC] = NULL, + }, + [TYPE_QSGMII] = { + [NO_SSC] = NULL, + [EXTERNAL_SSC] = NULL, + [INTERNAL_SSC] = NULL, + }, + [TYPE_USB] = { + [NO_SSC] = NULL, + [EXTERNAL_SSC] = NULL, + [INTERNAL_SSC] = NULL, + }, + }, + [TYPE_SGMII] = { + [TYPE_NONE] = { + [NO_SSC] = &ti_sgmii_100_no_ssc_tx_ln_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &ti_sgmii_100_no_ssc_tx_ln_vals, + [EXTERNAL_SSC] = &ti_sgmii_100_no_ssc_tx_ln_vals, + [INTERNAL_SSC] = &ti_sgmii_100_no_ssc_tx_ln_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &ti_sgmii_100_no_ssc_tx_ln_vals, + [EXTERNAL_SSC] = &ti_sgmii_100_no_ssc_tx_ln_vals, + [INTERNAL_SSC] = &ti_sgmii_100_no_ssc_tx_ln_vals, + }, + }, + [TYPE_QSGMII] = { + [TYPE_NONE] = { + [NO_SSC] = &ti_qsgmii_100_no_ssc_tx_ln_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &ti_qsgmii_100_no_ssc_tx_ln_vals, + [EXTERNAL_SSC] = &ti_qsgmii_100_no_ssc_tx_ln_vals, + [INTERNAL_SSC] = &ti_qsgmii_100_no_ssc_tx_ln_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &ti_qsgmii_100_no_ssc_tx_ln_vals, + [EXTERNAL_SSC] = &ti_qsgmii_100_no_ssc_tx_ln_vals, + [INTERNAL_SSC] = &ti_qsgmii_100_no_ssc_tx_ln_vals, + }, + }, + [TYPE_USB] = { + [TYPE_NONE] = { + [NO_SSC] = &usb_100_no_ssc_tx_ln_vals, + [EXTERNAL_SSC] = &usb_100_no_ssc_tx_ln_vals, + [INTERNAL_SSC] = &usb_100_no_ssc_tx_ln_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &usb_100_no_ssc_tx_ln_vals, + [EXTERNAL_SSC] = &usb_100_no_ssc_tx_ln_vals, + [INTERNAL_SSC] = &usb_100_no_ssc_tx_ln_vals, + }, + [TYPE_SGMII] = { + [NO_SSC] = &usb_100_no_ssc_tx_ln_vals, + [EXTERNAL_SSC] = &usb_100_no_ssc_tx_ln_vals, + [INTERNAL_SSC] = &usb_100_no_ssc_tx_ln_vals, + }, + [TYPE_QSGMII] = { + [NO_SSC] = &usb_100_no_ssc_tx_ln_vals, + [EXTERNAL_SSC] = &usb_100_no_ssc_tx_ln_vals, + [INTERNAL_SSC] = &usb_100_no_ssc_tx_ln_vals, + }, + }, + }, + .rx_ln_vals = { + [TYPE_PCIE] = { + [TYPE_NONE] = { + [NO_SSC] = &pcie_100_no_ssc_rx_ln_vals, + [EXTERNAL_SSC] = &pcie_100_no_ssc_rx_ln_vals, + [INTERNAL_SSC] = &pcie_100_no_ssc_rx_ln_vals, + }, + [TYPE_SGMII] = { + [NO_SSC] = &pcie_100_no_ssc_rx_ln_vals, + [EXTERNAL_SSC] = &pcie_100_no_ssc_rx_ln_vals, + [INTERNAL_SSC] = &pcie_100_no_ssc_rx_ln_vals, + }, + [TYPE_QSGMII] = { + [NO_SSC] = &pcie_100_no_ssc_rx_ln_vals, + [EXTERNAL_SSC] = &pcie_100_no_ssc_rx_ln_vals, + [INTERNAL_SSC] = &pcie_100_no_ssc_rx_ln_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &pcie_100_no_ssc_rx_ln_vals, + [EXTERNAL_SSC] = &pcie_100_no_ssc_rx_ln_vals, + [INTERNAL_SSC] = &pcie_100_no_ssc_rx_ln_vals, + }, + }, + [TYPE_SGMII] = { + [TYPE_NONE] = { + [NO_SSC] = &sgmii_100_no_ssc_rx_ln_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &sgmii_100_no_ssc_rx_ln_vals, + [EXTERNAL_SSC] = &sgmii_100_no_ssc_rx_ln_vals, + [INTERNAL_SSC] = &sgmii_100_no_ssc_rx_ln_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &sgmii_100_no_ssc_rx_ln_vals, + [EXTERNAL_SSC] = &sgmii_100_no_ssc_rx_ln_vals, + [INTERNAL_SSC] = &sgmii_100_no_ssc_rx_ln_vals, + }, + }, + [TYPE_QSGMII] = { + [TYPE_NONE] = { + [NO_SSC] = &qsgmii_100_no_ssc_rx_ln_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &qsgmii_100_no_ssc_rx_ln_vals, + [EXTERNAL_SSC] = &qsgmii_100_no_ssc_rx_ln_vals, + [INTERNAL_SSC] = &qsgmii_100_no_ssc_rx_ln_vals, + }, + [TYPE_USB] = { + [NO_SSC] = &qsgmii_100_no_ssc_rx_ln_vals, + [EXTERNAL_SSC] = &qsgmii_100_no_ssc_rx_ln_vals, + [INTERNAL_SSC] = &qsgmii_100_no_ssc_rx_ln_vals, + }, + }, + [TYPE_USB] = { + [TYPE_NONE] = { + [NO_SSC] = &usb_100_no_ssc_rx_ln_vals, + [EXTERNAL_SSC] = &usb_100_no_ssc_rx_ln_vals, + [INTERNAL_SSC] = &usb_100_no_ssc_rx_ln_vals, + }, + [TYPE_PCIE] = { + [NO_SSC] = &usb_100_no_ssc_rx_ln_vals, + [EXTERNAL_SSC] = &usb_100_no_ssc_rx_ln_vals, + [INTERNAL_SSC] = &usb_100_no_ssc_rx_ln_vals, + }, + [TYPE_SGMII] = { + [NO_SSC] = &usb_100_no_ssc_rx_ln_vals, + [EXTERNAL_SSC] = &usb_100_no_ssc_rx_ln_vals, + [INTERNAL_SSC] = &usb_100_no_ssc_rx_ln_vals, + }, + [TYPE_QSGMII] = { + [NO_SSC] = &usb_100_no_ssc_rx_ln_vals, + [EXTERNAL_SSC] = &usb_100_no_ssc_rx_ln_vals, + [INTERNAL_SSC] = &usb_100_no_ssc_rx_ln_vals, + }, + }, + }, +}; + +static int cdns_torrent_phy_reset(struct phy *gphy) +{ + struct cdns_torrent_phy *sp = dev_get_priv(gphy->dev); + + reset_control_assert(sp->phy_rst); + reset_control_deassert(sp->phy_rst); + return 0; +} + +static const struct udevice_id cdns_torrent_id_table[] = { + { + .compatible = "cdns,torrent-phy", + .data = (ulong)&cdns_map_torrent, + }, + { + .compatible = "ti,j721e-serdes-10g", + .data = (ulong)&ti_j721e_map_torrent, + }, + {} +}; + +static const struct phy_ops cdns_torrent_phy_ops = { + .init = cdns_torrent_phy_init, + .power_on = cdns_torrent_phy_on, + .power_off = cdns_torrent_phy_off, + .reset = cdns_torrent_phy_reset, +}; + +U_BOOT_DRIVER(torrent_phy_provider) = { + .name = "cdns,torrent", + .id = UCLASS_PHY, + .of_match = cdns_torrent_id_table, + .probe = cdns_torrent_phy_probe, + .remove = cdns_torrent_phy_remove, + .ops = &cdns_torrent_phy_ops, + .priv_auto = sizeof(struct cdns_torrent_phy), +};
Add support for WIZ module present in TI's J721E SoC. WIZ is a SERDES wrapper used to configure some of the input signals to the SERDES. It is used with both Sierra(16G) and Torrent(10G) SERDES. This driver configures three clock selects (pll0, pll1, dig) and supports resets for each of the lanes.
This is an adaptation of the linux driver.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Signed-off-by: Vignesh Raghavendra vigneshr@ti.com Signed-off-by: Kishon Vijay Abraham I kishon@ti.com --- drivers/phy/Kconfig | 1 + drivers/phy/Makefile | 1 + drivers/phy/ti/Kconfig | 9 + drivers/phy/ti/Makefile | 1 + drivers/phy/ti/phy-j721e-wiz.c | 1154 ++++++++++++++++++++++++++++++++ 5 files changed, 1166 insertions(+) create mode 100644 drivers/phy/ti/Kconfig create mode 100644 drivers/phy/ti/Makefile create mode 100644 drivers/phy/ti/phy-j721e-wiz.c
diff --git a/drivers/phy/Kconfig b/drivers/phy/Kconfig index 9208e430a6..7821161e3c 100644 --- a/drivers/phy/Kconfig +++ b/drivers/phy/Kconfig @@ -270,5 +270,6 @@ config PHY_MTK_TPHY
source "drivers/phy/rockchip/Kconfig" source "drivers/phy/cadence/Kconfig" +source "drivers/phy/ti/Kconfig"
endmenu diff --git a/drivers/phy/Makefile b/drivers/phy/Makefile index 4736c5eadb..2efaa8827b 100644 --- a/drivers/phy/Makefile +++ b/drivers/phy/Makefile @@ -32,3 +32,4 @@ obj-$(CONFIG_MT76X8_USB_PHY) += mt76x8-usb-phy.o obj-$(CONFIG_PHY_DA8XX_USB) += phy-da8xx-usb.o obj-$(CONFIG_PHY_MTK_TPHY) += phy-mtk-tphy.o obj-y += cadence/ +obj-y += ti/ diff --git a/drivers/phy/ti/Kconfig b/drivers/phy/ti/Kconfig new file mode 100644 index 0000000000..111085f235 --- /dev/null +++ b/drivers/phy/ti/Kconfig @@ -0,0 +1,9 @@ +config PHY_J721E_WIZ + tristate "TI J721E WIZ (SERDES Wrapper) support" + depends on ARCH_K3 + help + This option enables support for WIZ module present in TI's J721E + SoC. WIZ is a serdes wrapper used to configure some of the input + signals to the SERDES (Sierra/Torrent). This driver configures + three clock selects (pll0, pll1, dig) and resets for each of the + lanes. diff --git a/drivers/phy/ti/Makefile b/drivers/phy/ti/Makefile new file mode 100644 index 0000000000..873ddbf036 --- /dev/null +++ b/drivers/phy/ti/Makefile @@ -0,0 +1 @@ +obj-$(CONFIG_$(SPL_)PHY_J721E_WIZ) += phy-j721e-wiz.o diff --git a/drivers/phy/ti/phy-j721e-wiz.c b/drivers/phy/ti/phy-j721e-wiz.c new file mode 100644 index 0000000000..cac55c9c80 --- /dev/null +++ b/drivers/phy/ti/phy-j721e-wiz.c @@ -0,0 +1,1154 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2017-2018 Texas Instruments Incorporated - http://www.ti.com/ + * Jean-Jacques Hiblot jjhiblot@ti.com + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <asm/gpio.h> +#include <dm/lists.h> +#include <dm/device-internal.h> +#include <regmap.h> +#include <reset-uclass.h> +#include <dt-bindings/phy/phy.h> + +#include <dt-bindings/phy/phy-ti.h> + +#define WIZ_MAX_INPUT_CLOCKS 4 +/* To include mux clocks, divider clocks and gate clocks */ +#define WIZ_MAX_OUTPUT_CLOCKS 32 + +#define WIZ_MAX_LANES 4 +#define WIZ_MUX_NUM_CLOCKS 3 +#define WIZ_DIV_NUM_CLOCKS_16G 2 +#define WIZ_DIV_NUM_CLOCKS_10G 1 + +#define WIZ_SERDES_CTRL 0x404 +#define WIZ_SERDES_TOP_CTRL 0x408 +#define WIZ_SERDES_RST 0x40c +#define WIZ_SERDES_TYPEC 0x410 +#define WIZ_LANECTL(n) (0x480 + (0x40 * (n))) +#define WIZ_LANEDIV(n) (0x484 + (0x40 * (n))) + +#define WIZ_MAX_LANES 4 +#define WIZ_MUX_NUM_CLOCKS 3 +#define WIZ_DIV_NUM_CLOCKS_16G 2 +#define WIZ_DIV_NUM_CLOCKS_10G 1 + +#define WIZ_SERDES_TYPEC_LN10_SWAP BIT(30) + +enum wiz_lane_standard_mode { + LANE_MODE_GEN1, + LANE_MODE_GEN2, + LANE_MODE_GEN3, + LANE_MODE_GEN4, +}; + +enum wiz_refclk_mux_sel { + PLL0_REFCLK, + PLL1_REFCLK, + REFCLK_DIG, +}; + +enum wiz_refclk_div_sel { + CMN_REFCLK, + CMN_REFCLK1, +}; + +enum wiz_clock_input { + WIZ_CORE_REFCLK, + WIZ_EXT_REFCLK, + WIZ_CORE_REFCLK1, + WIZ_EXT_REFCLK1, +}; + +static const struct reg_field por_en = REG_FIELD(WIZ_SERDES_CTRL, 31, 31); +static const struct reg_field phy_reset_n = REG_FIELD(WIZ_SERDES_RST, 31, 31); +static const struct reg_field pll1_refclk_mux_sel = + REG_FIELD(WIZ_SERDES_RST, 29, 29); +static const struct reg_field pll0_refclk_mux_sel = + REG_FIELD(WIZ_SERDES_RST, 28, 28); +static const struct reg_field refclk_dig_sel_16g = + REG_FIELD(WIZ_SERDES_RST, 24, 25); +static const struct reg_field refclk_dig_sel_10g = + REG_FIELD(WIZ_SERDES_RST, 24, 24); +static const struct reg_field pma_cmn_refclk_int_mode = + REG_FIELD(WIZ_SERDES_TOP_CTRL, 28, 29); +static const struct reg_field pma_cmn_refclk_mode = + REG_FIELD(WIZ_SERDES_TOP_CTRL, 30, 31); +static const struct reg_field pma_cmn_refclk_dig_div = + REG_FIELD(WIZ_SERDES_TOP_CTRL, 26, 27); +static const struct reg_field pma_cmn_refclk1_dig_div = + REG_FIELD(WIZ_SERDES_TOP_CTRL, 24, 25); + +static const struct reg_field p_enable[WIZ_MAX_LANES] = { + REG_FIELD(WIZ_LANECTL(0), 30, 31), + REG_FIELD(WIZ_LANECTL(1), 30, 31), + REG_FIELD(WIZ_LANECTL(2), 30, 31), + REG_FIELD(WIZ_LANECTL(3), 30, 31), +}; + +enum p_enable { P_ENABLE = 2, P_ENABLE_FORCE = 1, P_ENABLE_DISABLE = 0 }; + +static const struct reg_field p_align[WIZ_MAX_LANES] = { + REG_FIELD(WIZ_LANECTL(0), 29, 29), + REG_FIELD(WIZ_LANECTL(1), 29, 29), + REG_FIELD(WIZ_LANECTL(2), 29, 29), + REG_FIELD(WIZ_LANECTL(3), 29, 29), +}; + +static const struct reg_field p_raw_auto_start[WIZ_MAX_LANES] = { + REG_FIELD(WIZ_LANECTL(0), 28, 28), + REG_FIELD(WIZ_LANECTL(1), 28, 28), + REG_FIELD(WIZ_LANECTL(2), 28, 28), + REG_FIELD(WIZ_LANECTL(3), 28, 28), +}; + +static const struct reg_field p_standard_mode[WIZ_MAX_LANES] = { + REG_FIELD(WIZ_LANECTL(0), 24, 25), + REG_FIELD(WIZ_LANECTL(1), 24, 25), + REG_FIELD(WIZ_LANECTL(2), 24, 25), + REG_FIELD(WIZ_LANECTL(3), 24, 25), +}; + +static const struct reg_field p0_fullrt_div[WIZ_MAX_LANES] = { + REG_FIELD(WIZ_LANECTL(0), 22, 23), + REG_FIELD(WIZ_LANECTL(1), 22, 23), + REG_FIELD(WIZ_LANECTL(2), 22, 23), + REG_FIELD(WIZ_LANECTL(3), 22, 23), +}; + +static const struct reg_field p_mac_div_sel0[WIZ_MAX_LANES] = { + REG_FIELD(WIZ_LANEDIV(0), 16, 22), + REG_FIELD(WIZ_LANEDIV(1), 16, 22), + REG_FIELD(WIZ_LANEDIV(2), 16, 22), + REG_FIELD(WIZ_LANEDIV(3), 16, 22), +}; + +static const struct reg_field p_mac_div_sel1[WIZ_MAX_LANES] = { + REG_FIELD(WIZ_LANEDIV(0), 0, 8), + REG_FIELD(WIZ_LANEDIV(1), 0, 8), + REG_FIELD(WIZ_LANEDIV(2), 0, 8), + REG_FIELD(WIZ_LANEDIV(3), 0, 8), +}; + +struct wiz_clk_mux_sel { + enum wiz_refclk_mux_sel mux_sel; + u32 table[WIZ_MAX_INPUT_CLOCKS]; + const char *node_name; + u32 num_parents; + u32 parents[WIZ_MAX_INPUT_CLOCKS]; +}; + +struct wiz_clk_div_sel { + enum wiz_refclk_div_sel div_sel; + const char *node_name; +}; + +static struct wiz_clk_mux_sel clk_mux_sel_16g[] = { + { + /* + * Mux value to be configured for each of the input clocks + * in the order populated in device tree + */ + .num_parents = 2, + .parents = { WIZ_CORE_REFCLK, WIZ_EXT_REFCLK }, + .mux_sel = PLL0_REFCLK, + .table = { 1, 0 }, + .node_name = "pll0-refclk", + }, + { + .num_parents = 2, + .parents = { WIZ_CORE_REFCLK1, WIZ_EXT_REFCLK1 }, + .mux_sel = PLL1_REFCLK, + .table = { 1, 0 }, + .node_name = "pll1-refclk", + }, + { + .num_parents = 4, + .parents = { WIZ_CORE_REFCLK, WIZ_CORE_REFCLK1, WIZ_EXT_REFCLK, WIZ_EXT_REFCLK1 }, + .mux_sel = REFCLK_DIG, + .table = { 1, 3, 0, 2 }, + .node_name = "refclk-dig", + }, +}; + +static struct wiz_clk_mux_sel clk_mux_sel_10g[] = { + { + /* + * Mux value to be configured for each of the input clocks + * in the order populated in device tree + */ + .num_parents = 2, + .parents = { WIZ_CORE_REFCLK, WIZ_EXT_REFCLK }, + .mux_sel = PLL0_REFCLK, + .table = { 1, 0 }, + .node_name = "pll0-refclk", + }, + { + .num_parents = 2, + .parents = { WIZ_CORE_REFCLK, WIZ_EXT_REFCLK }, + .mux_sel = PLL1_REFCLK, + .table = { 1, 0 }, + .node_name = "pll1-refclk", + }, + { + .num_parents = 2, + .parents = { WIZ_CORE_REFCLK, WIZ_EXT_REFCLK }, + .mux_sel = REFCLK_DIG, + .table = { 1, 0 }, + .node_name = "refclk-dig", + }, +}; + +static struct wiz_clk_div_sel clk_div_sel[] = { + { + .div_sel = CMN_REFCLK, + .node_name = "cmn-refclk-dig-div", + }, + { + .div_sel = CMN_REFCLK1, + .node_name = "cmn-refclk1-dig-div", + }, +}; + +enum wiz_type { + J721E_WIZ_16G, + J721E_WIZ_10G, + AM64_WIZ_10G, +}; + +#define WIZ_TYPEC_DIR_DEBOUNCE_MIN 100 /* ms */ +#define WIZ_TYPEC_DIR_DEBOUNCE_MAX 1000 + +struct wiz { + struct regmap *regmap; + enum wiz_type type; + struct wiz_clk_mux_sel *clk_mux_sel; + struct wiz_clk_div_sel *clk_div_sel; + unsigned int clk_div_sel_num; + struct regmap_field *por_en; + struct regmap_field *phy_reset_n; + struct regmap_field *phy_en_refclk; + struct regmap_field *p_enable[WIZ_MAX_LANES]; + struct regmap_field *p_align[WIZ_MAX_LANES]; + struct regmap_field *p_raw_auto_start[WIZ_MAX_LANES]; + struct regmap_field *p_standard_mode[WIZ_MAX_LANES]; + struct regmap_field *p_mac_div_sel0[WIZ_MAX_LANES]; + struct regmap_field *p_mac_div_sel1[WIZ_MAX_LANES]; + struct regmap_field *p0_fullrt_div[WIZ_MAX_LANES]; + struct regmap_field *pma_cmn_refclk_int_mode; + struct regmap_field *pma_cmn_refclk_mode; + struct regmap_field *pma_cmn_refclk_dig_div; + struct regmap_field *pma_cmn_refclk1_dig_div; + struct regmap_field *div_sel_field[WIZ_DIV_NUM_CLOCKS_16G]; + struct regmap_field *mux_sel_field[WIZ_MUX_NUM_CLOCKS]; + + struct udevice *dev; + u32 num_lanes; + struct gpio_desc *gpio_typec_dir; + u32 lane_phy_type[WIZ_MAX_LANES]; + struct clk *input_clks[WIZ_MAX_INPUT_CLOCKS]; + unsigned int id; +}; + +struct wiz_div_clk { + struct clk parent_clk; + struct wiz *wiz; +}; + +struct wiz_mux_clk { + struct clk parent_clks[4]; + struct wiz *wiz; +}; + +struct wiz_clk { + struct wiz *wiz; +}; + +struct wiz_reset { + struct wiz *wiz; +}; + +static ulong wiz_div_clk_get_rate(struct clk *clk) +{ + struct udevice *dev = clk->dev; + struct wiz_div_clk *priv = dev_get_priv(dev); + struct wiz_clk_div_sel *data = dev_get_plat(dev); + struct wiz *wiz = priv->wiz; + ulong parent_rate = clk_get_rate(&priv->parent_clk); + u32 val; + + regmap_field_read(wiz->div_sel_field[data->div_sel], &val); + + return parent_rate >> val; +} + +static ulong wiz_div_clk_set_rate(struct clk *clk, ulong rate) +{ + struct udevice *dev = clk->dev; + struct wiz_div_clk *priv = dev_get_priv(dev); + struct wiz_clk_div_sel *data = dev_get_plat(dev); + struct wiz *wiz = priv->wiz; + ulong parent_rate = clk_get_rate(&priv->parent_clk); + u32 div = parent_rate / rate; + + div = __ffs(div); + regmap_field_write(wiz->div_sel_field[data->div_sel], div); + + return parent_rate >> div; +} + +const struct clk_ops wiz_div_clk_ops = { + .get_rate = wiz_div_clk_get_rate, + .set_rate = wiz_div_clk_set_rate, +}; + +int wiz_div_clk_probe(struct udevice *dev) +{ + struct wiz_div_clk *priv = dev_get_priv(dev); + struct clk parent_clk; + int rc; + + rc = clk_get_by_index(dev, 0, &parent_clk); + if (rc) { + dev_err(dev, "unable to get parent clock. ret %d\n", rc); + return rc; + } + priv->parent_clk = parent_clk; + priv->wiz = dev_get_priv(dev->parent); + return 0; +} + +U_BOOT_DRIVER(wiz_div_clk) = { + .name = "wiz_div_clk", + .id = UCLASS_CLK, + .priv_auto = sizeof(struct wiz_div_clk), + .ops = &wiz_div_clk_ops, + .probe = wiz_div_clk_probe, +}; + +static int wiz_clk_mux_set_parent(struct clk *clk, struct clk *parent) +{ + struct udevice *dev = clk->dev; + struct wiz_mux_clk *priv = dev_get_priv(dev); + struct wiz_clk_mux_sel *data = dev_get_plat(dev); + struct wiz *wiz = priv->wiz; + int i; + + for (i = 0; i < ARRAY_SIZE(priv->parent_clks); i++) + if (parent->dev == priv->parent_clks[i].dev) + break; + + if (i == ARRAY_SIZE(priv->parent_clks)) + return -EINVAL; + + regmap_field_write(wiz->mux_sel_field[data->mux_sel], data->table[i]); + return 0; +} + +static int wiz_clk_xlate(struct clk *clk, struct ofnode_phandle_args *args) +{ + struct udevice *dev = clk->dev; + struct wiz_mux_clk *priv = dev_get_priv(dev); + struct wiz *wiz = priv->wiz; + + clk->id = wiz->id; + + return 0; +} + +static const struct clk_ops wiz_clk_mux_ops = { + .set_parent = wiz_clk_mux_set_parent, + .of_xlate = wiz_clk_xlate, +}; + +int wiz_mux_clk_probe(struct udevice *dev) +{ + struct wiz_mux_clk *priv = dev_get_priv(dev); + int rc; + int i; + + for (i = 0; i < ARRAY_SIZE(priv->parent_clks); i++) { + rc = clk_get_by_index(dev, i, &priv->parent_clks[i]); + if (rc) + priv->parent_clks[i].dev = NULL; + } + priv->wiz = dev_get_priv(dev->parent); + return 0; +} + +U_BOOT_DRIVER(wiz_mux_clk) = { + .name = "wiz_mux_clk", + .id = UCLASS_CLK, + .priv_auto = sizeof(struct wiz_mux_clk), + .ops = &wiz_clk_mux_ops, + .probe = wiz_mux_clk_probe, +}; + +static int wiz_clk_set_parent(struct clk *clk, struct clk *parent) +{ + struct udevice *dev = clk->dev; + struct wiz_clk *priv = dev_get_priv(dev); + const struct wiz_clk_mux_sel *mux_sel; + struct wiz *wiz = priv->wiz; + int num_parents; + int i, j, id; + + id = clk->id >> 10; + + /* set_parent is applicable only for MUX clocks */ + if (id > TI_WIZ_REFCLK_DIG) + return 0; + + for (i = 0; i < WIZ_MAX_INPUT_CLOCKS; i++) + if (wiz->input_clks[i]->dev == parent->dev) + break; + + if (i == WIZ_MAX_INPUT_CLOCKS) + return -EINVAL; + + mux_sel = &wiz->clk_mux_sel[id]; + num_parents = mux_sel->num_parents; + for (j = 0; j < num_parents; j++) + if (mux_sel->parents[j] == i) + break; + + if (j == num_parents) + return -EINVAL; + + regmap_field_write(wiz->mux_sel_field[id], mux_sel->table[j]); + + return 0; +} + +static int wiz_clk_of_xlate(struct clk *clk, struct ofnode_phandle_args *args) +{ + struct udevice *dev = clk->dev; + struct wiz_clk *priv = dev_get_priv(dev); + struct wiz *wiz = priv->wiz; + + clk->id = args->args[0] << 10 | wiz->id; + + return 0; +} + +static const struct clk_ops wiz_clk_ops = { + .set_parent = wiz_clk_set_parent, + .of_xlate = wiz_clk_of_xlate, +}; + +int wiz_clk_probe(struct udevice *dev) +{ + struct wiz_clk *priv = dev_get_priv(dev); + + priv->wiz = dev_get_priv(dev->parent); + + return 0; +} + +U_BOOT_DRIVER(wiz_clk) = { + .name = "wiz_clk", + .id = UCLASS_CLK, + .priv_auto = sizeof(struct wiz_clk), + .ops = &wiz_clk_ops, + .probe = wiz_clk_probe, +}; + +static int wiz_reset_request(struct reset_ctl *reset_ctl) +{ + return 0; +} + +static int wiz_reset_free(struct reset_ctl *reset_ctl) +{ + return 0; +} + +static int wiz_reset_assert(struct reset_ctl *reset_ctl) +{ + struct wiz_reset *priv = dev_get_priv(reset_ctl->dev); + struct wiz *wiz = priv->wiz; + int ret; + int id = reset_ctl->id; + + if (id == 0) { + ret = regmap_field_write(wiz->phy_reset_n, false); + return ret; + } + + ret = regmap_field_write(wiz->p_enable[id - 1], P_ENABLE_DISABLE); + return ret; +} + +static int wiz_phy_fullrt_div(struct wiz *wiz, int lane) +{ + if (wiz->type != AM64_WIZ_10G) + return 0; + + if (wiz->lane_phy_type[lane] == PHY_TYPE_PCIE) + return regmap_field_write(wiz->p0_fullrt_div[lane], 0x1); + + return 0; +} + +static int wiz_reset_deassert(struct reset_ctl *reset_ctl) +{ + struct wiz_reset *priv = dev_get_priv(reset_ctl->dev); + struct wiz *wiz = priv->wiz; + int ret; + int id = reset_ctl->id; + + ret = wiz_phy_fullrt_div(wiz, id - 1); + if (ret) + return ret; + + /* if typec-dir gpio was specified, set LN10 SWAP bit based on that */ + if (id == 0 && wiz->gpio_typec_dir) { + if (dm_gpio_get_value(wiz->gpio_typec_dir)) { + regmap_update_bits(wiz->regmap, WIZ_SERDES_TYPEC, + WIZ_SERDES_TYPEC_LN10_SWAP, + WIZ_SERDES_TYPEC_LN10_SWAP); + } else { + regmap_update_bits(wiz->regmap, WIZ_SERDES_TYPEC, + WIZ_SERDES_TYPEC_LN10_SWAP, 0); + } + } + + if (id == 0) { + ret = regmap_field_write(wiz->phy_reset_n, true); + return ret; + } + + if (wiz->lane_phy_type[id - 1] == PHY_TYPE_PCIE) + ret = regmap_field_write(wiz->p_enable[id - 1], P_ENABLE); + else + ret = regmap_field_write(wiz->p_enable[id - 1], P_ENABLE_FORCE); + + return ret; +} + +static struct reset_ops wiz_reset_ops = { + .request = wiz_reset_request, + .rfree = wiz_reset_free, + .rst_assert = wiz_reset_assert, + .rst_deassert = wiz_reset_deassert, +}; + +int wiz_reset_probe(struct udevice *dev) +{ + struct wiz_reset *priv = dev_get_priv(dev); + + priv->wiz = dev_get_priv(dev->parent); + + return 0; +} + +U_BOOT_DRIVER(wiz_reset) = { + .name = "wiz-reset", + .id = UCLASS_RESET, + .probe = wiz_reset_probe, + .ops = &wiz_reset_ops, +}; + +static int wiz_reset(struct wiz *wiz) +{ + int ret; + + ret = regmap_field_write(wiz->por_en, 0x1); + if (ret) + return ret; + + mdelay(1); + + ret = regmap_field_write(wiz->por_en, 0x0); + if (ret) + return ret; + + return 0; +} + +static int wiz_p_mac_div_sel(struct wiz *wiz) +{ + u32 num_lanes = wiz->num_lanes; + int ret; + int i; + + for (i = 0; i < num_lanes; i++) { + if (wiz->lane_phy_type[i] == PHY_TYPE_QSGMII) { + ret = regmap_field_write(wiz->p_mac_div_sel0[i], 1); + if (ret) + return ret; + + ret = regmap_field_write(wiz->p_mac_div_sel1[i], 2); + if (ret) + return ret; + } + } + + return 0; +} + +static int wiz_mode_select(struct wiz *wiz) +{ + u32 num_lanes = wiz->num_lanes; + int ret; + int i; + + for (i = 0; i < num_lanes; i++) { + if (wiz->lane_phy_type[i] == PHY_TYPE_QSGMII) { + ret = regmap_field_write(wiz->p_standard_mode[i], + LANE_MODE_GEN2); + if (ret) + return ret; + } + } + + return 0; +} + +static int wiz_init_raw_interface(struct wiz *wiz, bool enable) +{ + u32 num_lanes = wiz->num_lanes; + int i; + int ret; + + for (i = 0; i < num_lanes; i++) { + ret = regmap_field_write(wiz->p_align[i], enable); + if (ret) + return ret; + + ret = regmap_field_write(wiz->p_raw_auto_start[i], enable); + if (ret) + return ret; + } + + return 0; +} + +static int wiz_init(struct wiz *wiz) +{ + struct udevice *dev = wiz->dev; + int ret; + + ret = wiz_reset(wiz); + if (ret) { + dev_err(dev, "WIZ reset failed\n"); + return ret; + } + + ret = wiz_mode_select(wiz); + if (ret) { + dev_err(dev, "WIZ mode select failed\n"); + return ret; + } + + ret = wiz_p_mac_div_sel(wiz); + if (ret) { + dev_err(dev, "Configuring P0 MAC DIV SEL failed\n"); + return ret; + } + + ret = wiz_init_raw_interface(wiz, true); + if (ret) { + dev_err(dev, "WIZ interface initialization failed\n"); + return ret; + } + + return 0; +} + +static int wiz_regfield_init(struct wiz *wiz) +{ + struct regmap *regmap = wiz->regmap; + int num_lanes = wiz->num_lanes; + struct udevice *dev = wiz->dev; + enum wiz_type type; + int i; + + wiz->por_en = devm_regmap_field_alloc(dev, regmap, por_en); + if (IS_ERR(wiz->por_en)) { + dev_err(dev, "POR_EN reg field init failed\n"); + return PTR_ERR(wiz->por_en); + } + + wiz->phy_reset_n = devm_regmap_field_alloc(dev, regmap, + phy_reset_n); + if (IS_ERR(wiz->phy_reset_n)) { + dev_err(dev, "PHY_RESET_N reg field init failed\n"); + return PTR_ERR(wiz->phy_reset_n); + } + + wiz->pma_cmn_refclk_int_mode = + devm_regmap_field_alloc(dev, regmap, pma_cmn_refclk_int_mode); + if (IS_ERR(wiz->pma_cmn_refclk_int_mode)) { + dev_err(dev, "PMA_CMN_REFCLK_INT_MODE reg field init failed\n"); + return PTR_ERR(wiz->pma_cmn_refclk_int_mode); + } + + wiz->pma_cmn_refclk_mode = + devm_regmap_field_alloc(dev, regmap, pma_cmn_refclk_mode); + if (IS_ERR(wiz->pma_cmn_refclk_mode)) { + dev_err(dev, "PMA_CMN_REFCLK_MODE reg field init failed\n"); + return PTR_ERR(wiz->pma_cmn_refclk_mode); + } + + wiz->div_sel_field[CMN_REFCLK] = + devm_regmap_field_alloc(dev, regmap, pma_cmn_refclk_dig_div); + if (IS_ERR(wiz->div_sel_field[CMN_REFCLK])) { + dev_err(dev, "PMA_CMN_REFCLK_DIG_DIV reg field init failed\n"); + return PTR_ERR(wiz->div_sel_field[CMN_REFCLK]); + } + + wiz->div_sel_field[CMN_REFCLK1] = + devm_regmap_field_alloc(dev, regmap, pma_cmn_refclk1_dig_div); + if (IS_ERR(wiz->div_sel_field[CMN_REFCLK1])) { + dev_err(dev, "PMA_CMN_REFCLK1_DIG_DIV reg field init failed\n"); + return PTR_ERR(wiz->div_sel_field[CMN_REFCLK1]); + } + + wiz->mux_sel_field[PLL0_REFCLK] = + devm_regmap_field_alloc(dev, regmap, pll0_refclk_mux_sel); + if (IS_ERR(wiz->mux_sel_field[PLL0_REFCLK])) { + dev_err(dev, "PLL0_REFCLK_SEL reg field init failed\n"); + return PTR_ERR(wiz->mux_sel_field[PLL0_REFCLK]); + } + + wiz->mux_sel_field[PLL1_REFCLK] = + devm_regmap_field_alloc(dev, regmap, pll1_refclk_mux_sel); + if (IS_ERR(wiz->mux_sel_field[PLL1_REFCLK])) { + dev_err(dev, "PLL1_REFCLK_SEL reg field init failed\n"); + return PTR_ERR(wiz->mux_sel_field[PLL1_REFCLK]); + } + + type = dev_get_driver_data(dev); + if (type == J721E_WIZ_10G || type == AM64_WIZ_10G) + wiz->mux_sel_field[REFCLK_DIG] = + devm_regmap_field_alloc(dev, regmap, + refclk_dig_sel_10g); + else + wiz->mux_sel_field[REFCLK_DIG] = + devm_regmap_field_alloc(dev, regmap, + refclk_dig_sel_16g); + if (IS_ERR(wiz->mux_sel_field[REFCLK_DIG])) { + dev_err(dev, "REFCLK_DIG_SEL reg field init failed\n"); + return PTR_ERR(wiz->mux_sel_field[REFCLK_DIG]); + } + + for (i = 0; i < num_lanes; i++) { + wiz->p_enable[i] = devm_regmap_field_alloc(dev, regmap, + p_enable[i]); + if (IS_ERR(wiz->p_enable[i])) { + dev_err(dev, "P%d_ENABLE reg field init failed\n", i); + return PTR_ERR(wiz->p_enable[i]); + } + + wiz->p_align[i] = devm_regmap_field_alloc(dev, regmap, + p_align[i]); + if (IS_ERR(wiz->p_align[i])) { + dev_err(dev, "P%d_ALIGN reg field init failed\n", i); + return PTR_ERR(wiz->p_align[i]); + } + + wiz->p_raw_auto_start[i] = + devm_regmap_field_alloc(dev, regmap, p_raw_auto_start[i]); + if (IS_ERR(wiz->p_raw_auto_start[i])) { + dev_err(dev, "P%d_RAW_AUTO_START reg field init fail\n", + i); + return PTR_ERR(wiz->p_raw_auto_start[i]); + } + + wiz->p_standard_mode[i] = + devm_regmap_field_alloc(dev, regmap, p_standard_mode[i]); + if (IS_ERR(wiz->p_standard_mode[i])) { + dev_err(dev, "P%d_STANDARD_MODE reg field init fail\n", + i); + return PTR_ERR(wiz->p_standard_mode[i]); + } + + wiz->p0_fullrt_div[i] = devm_regmap_field_alloc(dev, regmap, p0_fullrt_div[i]); + if (IS_ERR(wiz->p0_fullrt_div[i])) { + dev_err(dev, "P%d_FULLRT_DIV reg field init failed\n", i); + return PTR_ERR(wiz->p0_fullrt_div[i]); + } + + wiz->p_mac_div_sel0[i] = + devm_regmap_field_alloc(dev, regmap, p_mac_div_sel0[i]); + if (IS_ERR(wiz->p_mac_div_sel0[i])) { + dev_err(dev, "P%d_MAC_DIV_SEL0 reg field init fail\n", + i); + return PTR_ERR(wiz->p_mac_div_sel0[i]); + } + + wiz->p_mac_div_sel1[i] = + devm_regmap_field_alloc(dev, regmap, p_mac_div_sel1[i]); + if (IS_ERR(wiz->p_mac_div_sel1[i])) { + dev_err(dev, "P%d_MAC_DIV_SEL1 reg field init fail\n", + i); + return PTR_ERR(wiz->p_mac_div_sel1[i]); + } + } + + return 0; +} + +static int wiz_clock_init(struct wiz *wiz) +{ + struct udevice *dev = wiz->dev; + unsigned long rate; + struct clk *clk; + int ret; + + clk = devm_clk_get(dev, "core_ref_clk"); + if (IS_ERR(clk)) { + dev_err(dev, "core_ref_clk clock not found\n"); + ret = PTR_ERR(clk); + return ret; + } + wiz->input_clks[WIZ_CORE_REFCLK] = clk; + /* Initialize CORE_REFCLK1 to the same clock reference to maintain old DT compatibility */ + wiz->input_clks[WIZ_CORE_REFCLK1] = clk; + + rate = clk_get_rate(clk); + if (rate >= 100000000) + regmap_field_write(wiz->pma_cmn_refclk_int_mode, 0x1); + else + regmap_field_write(wiz->pma_cmn_refclk_int_mode, 0x3); + + clk = devm_clk_get(dev, "ext_ref_clk"); + if (IS_ERR(clk)) { + dev_err(dev, "ext_ref_clk clock not found\n"); + ret = PTR_ERR(clk); + return ret; + } + + wiz->input_clks[WIZ_EXT_REFCLK] = clk; + /* Initialize EXT_REFCLK1 to the same clock reference to maintain old DT compatibility */ + wiz->input_clks[WIZ_EXT_REFCLK1] = clk; + + rate = clk_get_rate(clk); + if (rate >= 100000000) + regmap_field_write(wiz->pma_cmn_refclk_mode, 0x0); + else + regmap_field_write(wiz->pma_cmn_refclk_mode, 0x2); + + return 0; +} + +static ofnode get_child_by_name(struct udevice *dev, const char *name) +{ + int l = strlen(name); + ofnode node = dev_read_first_subnode(dev); + + while (ofnode_valid(node)) { + const char *child_name = ofnode_get_name(node); + + if (!strncmp(child_name, name, l)) { + if (child_name[l] == '\0' || child_name[l] == '@') + return node; + } + node = dev_read_next_subnode(node); + } + return node; +} + +static int j721e_wiz_bind_clocks(struct wiz *wiz) +{ + struct udevice *dev = wiz->dev; + struct driver *wiz_clk_drv; + int i, rc; + + wiz_clk_drv = lists_driver_lookup_name("wiz_clk"); + if (!wiz_clk_drv) { + dev_err(dev, "Cannot find driver 'wiz_clk'\n"); + return -ENOENT; + } + + for (i = 0; i < WIZ_DIV_NUM_CLOCKS_10G; i++) { + rc = device_bind(dev, wiz_clk_drv, clk_div_sel[i].node_name, + &clk_div_sel[i], dev_ofnode(dev), NULL); + if (rc) { + dev_err(dev, "cannot bind driver for clock %s\n", + clk_div_sel[i].node_name); + } + } + + for (i = 0; i < WIZ_MUX_NUM_CLOCKS; i++) { + rc = device_bind(dev, wiz_clk_drv, clk_mux_sel_10g[i].node_name, + &clk_mux_sel_10g[i], dev_ofnode(dev), NULL); + if (rc) { + dev_err(dev, "cannot bind driver for clock %s\n", + clk_mux_sel_10g[i].node_name); + } + } + + return 0; +} + +static int j721e_wiz_bind_of_clocks(struct wiz *wiz) +{ + struct wiz_clk_mux_sel *clk_mux_sel = wiz->clk_mux_sel; + struct udevice *dev = wiz->dev; + enum wiz_type type = wiz->type; + struct driver *div_clk_drv; + struct driver *mux_clk_drv; + ofnode node; + int i, rc; + + if (type == AM64_WIZ_10G) + return j721e_wiz_bind_clocks(wiz); + + div_clk_drv = lists_driver_lookup_name("wiz_div_clk"); + if (!div_clk_drv) { + dev_err(dev, "Cannot find driver 'wiz_div_clk'\n"); + return -ENOENT; + } + + mux_clk_drv = lists_driver_lookup_name("wiz_mux_clk"); + if (!mux_clk_drv) { + dev_err(dev, "Cannot find driver 'wiz_mux_clk'\n"); + return -ENOENT; + } + + for (i = 0; i < wiz->clk_div_sel_num; i++) { + node = get_child_by_name(dev, clk_div_sel[i].node_name); + if (!ofnode_valid(node)) { + dev_err(dev, "cannot find node for clock %s\n", + clk_div_sel[i].node_name); + continue; + } + rc = device_bind(dev, div_clk_drv, clk_div_sel[i].node_name, + &clk_div_sel[i], node, NULL); + if (rc) { + dev_err(dev, "cannot bind driver for clock %s\n", + clk_div_sel[i].node_name); + } + } + + for (i = 0; i < WIZ_MUX_NUM_CLOCKS; i++) { + node = get_child_by_name(dev, clk_mux_sel[i].node_name); + if (!ofnode_valid(node)) { + dev_err(dev, "cannot find node for clock %s\n", + clk_mux_sel[i].node_name); + continue; + } + rc = device_bind(dev, mux_clk_drv, clk_mux_sel[i].node_name, + &clk_mux_sel[i], node, NULL); + if (rc) { + dev_err(dev, "cannot bind driver for clock %s\n", + clk_mux_sel[i].node_name); + } + } + + return 0; +} + +static int j721e_wiz_bind_reset(struct udevice *dev) +{ + int rc; + struct driver *drv; + + drv = lists_driver_lookup_name("wiz-reset"); + if (!drv) { + dev_err(dev, "Cannot find driver 'wiz-reset'\n"); + return -ENOENT; + } + + rc = device_bind(dev, drv, "wiz-reset", NULL, dev_ofnode(dev), NULL); + if (rc) { + dev_err(dev, "cannot bind driver for wiz-reset\n"); + return rc; + } + + return 0; +} + +static int j721e_wiz_bind(struct udevice *dev) +{ + dm_scan_fdt_dev(dev); + + return 0; +} + +static int wiz_get_lane_phy_types(struct udevice *dev, struct wiz *wiz) +{ + ofnode child, serdes; + + serdes = get_child_by_name(dev, "serdes"); + if (!ofnode_valid(serdes)) { + dev_err(dev, "%s: Getting "serdes"-node failed\n", __func__); + return -EINVAL; + } + + ofnode_for_each_subnode(child, serdes) { + u32 reg, num_lanes = 1, phy_type = PHY_NONE; + int ret, i; + + ret = ofnode_read_u32(child, "reg", ®); + if (ret) { + dev_err(dev, "%s: Reading "reg" from failed: %d\n", + __func__, ret); + return ret; + } + ofnode_read_u32(child, "cdns,num-lanes", &num_lanes); + ofnode_read_u32(child, "cdns,phy-type", &phy_type); + + dev_dbg(dev, "%s: Lanes %u-%u have phy-type %u\n", __func__, + reg, reg + num_lanes - 1, phy_type); + + for (i = reg; i < reg + num_lanes; i++) + wiz->lane_phy_type[i] = phy_type; + } + + return 0; +} + +static int j721e_wiz_probe(struct udevice *dev) +{ + struct wiz *wiz = dev_get_priv(dev); + struct ofnode_phandle_args args; + unsigned int val; + int rc, i; + ofnode node; + struct regmap *regmap; + u32 num_lanes; + + node = get_child_by_name(dev, "serdes"); + + if (!ofnode_valid(node)) { + dev_err(dev, "Failed to get SERDES child DT node\n"); + return -ENODEV; + } + + rc = regmap_init_mem(node, ®map); + if (rc) { + dev_err(dev, "Failed to get memory resource\n"); + return rc; + } + rc = dev_read_u32(dev, "num-lanes", &num_lanes); + if (rc) { + dev_err(dev, "Failed to read num-lanes property\n"); + goto err_addr_to_resource; + } + + if (num_lanes > WIZ_MAX_LANES) { + dev_err(dev, "Cannot support %d lanes\n", num_lanes); + goto err_addr_to_resource; + } + + wiz->gpio_typec_dir = devm_gpiod_get_optional(dev, "typec-dir", + GPIOD_IS_IN); + if (IS_ERR(wiz->gpio_typec_dir)) { + rc = PTR_ERR(wiz->gpio_typec_dir); + dev_err(dev, "Failed to request typec-dir gpio: %d\n", rc); + goto err_addr_to_resource; + } + + rc = dev_read_phandle_with_args(dev, "power-domains", "#power-domain-cells", 0, 0, &args); + if (rc) { + dev_err(dev, "Failed to get power domain: %d\n", rc); + goto err_addr_to_resource; + } + + wiz->id = args.args[0]; + wiz->regmap = regmap; + wiz->num_lanes = num_lanes; + wiz->dev = dev; + wiz->clk_div_sel = clk_div_sel; + wiz->type = dev_get_driver_data(dev); + if (wiz->type == J721E_WIZ_10G || wiz->type == AM64_WIZ_10G) { + wiz->clk_mux_sel = clk_mux_sel_10g; + wiz->clk_div_sel_num = WIZ_DIV_NUM_CLOCKS_10G; + } else { + wiz->clk_mux_sel = clk_mux_sel_16g; + wiz->clk_div_sel_num = WIZ_DIV_NUM_CLOCKS_16G; + } + + rc = wiz_get_lane_phy_types(dev, wiz); + if (rc) { + dev_err(dev, "Failed to get lane PHY types\n"); + goto err_addr_to_resource; + } + + rc = wiz_regfield_init(wiz); + if (rc) { + dev_err(dev, "Failed to initialize regfields\n"); + goto err_addr_to_resource; + } + + for (i = 0; i < wiz->num_lanes; i++) { + regmap_field_read(wiz->p_enable[i], &val); + if (val & (P_ENABLE | P_ENABLE_FORCE)) { + dev_err(dev, "SERDES already configured\n"); + rc = -EBUSY; + goto err_addr_to_resource; + } + } + + rc = j721e_wiz_bind_of_clocks(wiz); + if (rc) { + dev_err(dev, "Failed to bind clocks\n"); + goto err_addr_to_resource; + } + + rc = j721e_wiz_bind_reset(dev); + if (rc) { + dev_err(dev, "Failed to bind reset\n"); + goto err_addr_to_resource; + } + + rc = wiz_clock_init(wiz); + if (rc) { + dev_warn(dev, "Failed to initialize clocks\n"); + goto err_addr_to_resource; + } + + rc = wiz_init(wiz); + if (rc) { + dev_err(dev, "WIZ initialization failed\n"); + goto err_addr_to_resource; + } + + return 0; + +err_addr_to_resource: + free(regmap); + + return rc; +} + +static int j721e_wiz_remove(struct udevice *dev) +{ + struct wiz *wiz = dev_get_priv(dev); + + if (wiz->regmap) + free(wiz->regmap); + + return 0; +} + +static const struct udevice_id j721e_wiz_ids[] = { + { + .compatible = "ti,j721e-wiz-16g", .data = J721E_WIZ_16G, + }, + { + .compatible = "ti,j721e-wiz-10g", .data = J721E_WIZ_10G, + }, + { + .compatible = "ti,am64-wiz-10g", .data = AM64_WIZ_10G, + }, + {} +}; + +U_BOOT_DRIVER(phy_j721e_wiz) = { + .name = "phy-j721e-wiz", + .id = UCLASS_NOP, + .of_match = j721e_wiz_ids, + .bind = j721e_wiz_bind, + .probe = j721e_wiz_probe, + .remove = j721e_wiz_remove, + .priv_auto = sizeof(struct wiz), +};
Upstream device tree got updated to use clock name as "ref" instead of "usb2_refclk". Fix cdns3-ti.c to use the correct name.
Signed-off-by: Kishon Vijay Abraham I kishon@ti.com --- drivers/usb/cdns3/cdns3-ti.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/usb/cdns3/cdns3-ti.c b/drivers/usb/cdns3/cdns3-ti.c index 7b205c5656..43171678ee 100644 --- a/drivers/usb/cdns3/cdns3-ti.c +++ b/drivers/usb/cdns3/cdns3-ti.c @@ -101,7 +101,7 @@ static int cdns_ti_probe(struct udevice *dev) if (!data->usbss) return -EINVAL;
- ret = clk_get_by_name(dev, "usb2_refclk", &usb2_refclk); + ret = clk_get_by_name(dev, "ref", &usb2_refclk); if (ret) { dev_err(dev, "Failed to get usb2_refclk\n"); return ret;
Add support for probing and configuring Torrent serdes on J7200.
Signed-off-by: Aswath Govindraju a-govindraju@ti.com Signed-off-by: Kishon Vijay Abraham I kishon@ti.com --- board/ti/j721e/evm.c | 34 +++++++++++++++++++++++++++++++++- 1 file changed, 33 insertions(+), 1 deletion(-)
diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index b9a9f19552..580f13c3ab 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -10,6 +10,7 @@ #include <common.h> #include <env.h> #include <fdt_support.h> +#include <generic-phy.h> #include <image.h> #include <init.h> #include <log.h> @@ -29,7 +30,8 @@ #define board_is_j721e_som() (board_ti_k3_is("J721EX-PM1-SOM") || \ board_ti_k3_is("J721EX-PM2-SOM"))
-#define board_is_j7200_som() board_ti_k3_is("J7200X-PM1-SOM") +#define board_is_j7200_som() (board_ti_k3_is("J7200X-PM1-SOM") || \ + board_ti_k3_is("J7200X-PM2-SOM"))
/* Max number of MAC addresses that are parsed/processed per daughter card */ #define DAUGHTER_CARD_NO_OF_MAC_ADDR 8 @@ -384,6 +386,33 @@ static int probe_daughtercards(void) } #endif
+void configure_serdes_torrent(void) +{ + struct udevice *dev; + struct phy serdes; + int ret; + + if (!IS_ENABLED(CONFIG_PHY_CADENCE_TORRENT)) + return; + + ret = uclass_get_device_by_driver(UCLASS_PHY, + DM_DRIVER_GET(torrent_phy_provider), + &dev); + if (ret) + printf("Torrent init failed:%d\n", ret); + + serdes.dev = dev; + serdes.id = 0; + + ret = generic_phy_init(&serdes); + if (ret) + printf("phy_init failed!!\n"); + + ret = generic_phy_power_on(&serdes); + if (ret) + printf("phy_power_on failed !!\n"); +} + int board_late_init(void) { if (IS_ENABLED(CONFIG_TI_I2C_BOARD_DETECT)) { @@ -394,6 +423,9 @@ int board_late_init(void) probe_daughtercards(); }
+ if (board_is_j7200_som()) + configure_serdes_torrent(); + return 0; }
Partially sync with Linux's dts to add the entries required for USB3 support on USB0. Note that the default mode is still "peripheral" not "host". USB3 is supported only for the host mode.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Signed-off-by: Vignesh Raghavendra vigneshr@ti.com Signed-off-by: Kishon Vijay Abraham I kishon@ti.com --- .../k3-j721e-common-proc-board-u-boot.dtsi | 19 ++++++++++++++++++- 1 file changed, 18 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi index 3384ed9f3a..3b2e40c13d 100644 --- a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi @@ -115,13 +115,17 @@ u-boot,dm-spl; };
+&wiz3_pll1_refclk { + assigned-clocks = <&wiz3_pll1_refclk>, <&wiz3_pll0_refclk>; + assigned-clock-parents = <&k3_clks 295 0>, <&k3_clks 295 9>; +}; + &main_usbss0_pins_default { u-boot,dm-spl; };
&usbss0 { u-boot,dm-spl; - ti,usb2-only; };
&usb0 { @@ -193,3 +197,16 @@ &mcu_fss0_ospi1_pins_default { u-boot,dm-spl; }; + +&wiz3_pll1_refclk { + assigned-clocks = <&wiz3_pll1_refclk>, <&wiz3_pll0_refclk>; + assigned-clock-parents = <&k3_clks 295 0>, <&k3_clks 295 9>; +}; + +&serdes_ln_ctrl { + u-boot,mux-autoprobe; +}; + +&usb_serdes_mux { + u-boot,mux-autoprobe; +};
You're doing a partial sync with Linux in the -u-boot.dtsi file, why?
Hi Tom,
This only changes the part that deals with USB. Other's will be added as when it's getting tested and verified in u-boot.
Thanks Kishon
On Fri, Jul 09, 2021 at 07:36:45PM +0530, Kishon Vijay Abraham I wrote:
Hi Tom,
I would really really like to see the files be fully re-synced. I'm not NAK'ing this, but it's also a bad idea to pass Linux old/mismatched dtb files. Which you can do trivially with `bootefi`. So it's a bad idea.
Add DT node for torrent serdes.
Signed-off-by: Aswath Govindraju a-govindraju@ti.com Signed-off-by: Kishon Vijay Abraham I kishon@ti.com --- arch/arm/dts/k3-j7200-main.dtsi | 63 +++++++++++++++++++++++++++++++++ 1 file changed, 63 insertions(+)
diff --git a/arch/arm/dts/k3-j7200-main.dtsi b/arch/arm/dts/k3-j7200-main.dtsi index 1131464075..138702cf9d 100644 --- a/arch/arm/dts/k3-j7200-main.dtsi +++ b/arch/arm/dts/k3-j7200-main.dtsi @@ -5,6 +5,13 @@ * Copyright (C) 2020 Texas Instruments Incorporated - https://www.ti.com/ */
+/ { + serdes_refclk: serdes-refclk { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; +}; + &cbass_main { msmc_ram: sram@70000000 { compatible = "mmio-sram"; @@ -554,6 +561,62 @@ clock-names = "gpio"; };
+ serdes_wiz0: wiz@5060000 { + compatible = "ti,j721e-wiz-10g"; + #address-cells = <1>; + #size-cells = <1>; + power-domains = <&k3_pds 292 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 292 11>, <&k3_clks 292 85>, <&serdes_refclk>; + clock-names = "fck", "core_ref_clk", "ext_ref_clk"; + num-lanes = <4>; + #reset-cells = <1>; + ranges = <0x5060000 0x0 0x5060000 0x10000>; + + assigned-clocks = <&k3_clks 292 85>; + assigned-clock-parents = <&k3_clks 292 89>; + + wiz0_pll0_refclk: pll0-refclk { + clocks = <&k3_clks 292 85>, <&serdes_refclk>; + clock-output-names = "wiz0_pll0_refclk"; + #clock-cells = <0>; + assigned-clocks = <&wiz0_pll0_refclk>; + assigned-clock-parents = <&k3_clks 292 85>; + }; + + wiz0_pll1_refclk: pll1-refclk { + clocks = <&k3_clks 292 85>, <&serdes_refclk>; + clock-output-names = "wiz0_pll1_refclk"; + #clock-cells = <0>; + assigned-clocks = <&wiz0_pll1_refclk>; + assigned-clock-parents = <&k3_clks 292 85>; + }; + + wiz0_refclk_dig: refclk-dig { + clocks = <&k3_clks 292 85>, <&serdes_refclk>; + clock-output-names = "wiz0_refclk_dig"; + #clock-cells = <0>; + assigned-clocks = <&wiz0_refclk_dig>; + assigned-clock-parents = <&k3_clks 292 85>; + }; + + wiz0_cmn_refclk_dig_div: cmn-refclk-dig-div { + clocks = <&wiz0_refclk_dig>; + #clock-cells = <0>; + }; + + serdes0: serdes@5060000 { + compatible = "ti,j721e-serdes-10g"; + reg = <0x05060000 0x00010000>; + reg-names = "torrent_phy"; + resets = <&serdes_wiz0 0>; + reset-names = "torrent_reset"; + clocks = <&wiz0_pll0_refclk>; + clock-names = "refclk"; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + usbss0: cdns-usb@4104000 { compatible = "ti,j721e-usb"; reg = <0x00 0x4104000 0x00 0x100>;
Add default lane function for torrent serdes.
Signed-off-by: Aswath Govindraju a-govindraju@ti.com Signed-off-by: Kishon Vijay Abraham I kishon@ti.com --- arch/arm/dts/k3-j7200-common-proc-board.dts | 23 +++++++++++++++++++++ 1 file changed, 23 insertions(+)
diff --git a/arch/arm/dts/k3-j7200-common-proc-board.dts b/arch/arm/dts/k3-j7200-common-proc-board.dts index 5120711d4f..f0440cda1a 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-common-proc-board.dts @@ -9,6 +9,7 @@ #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/net/ti-dp83867.h> #include <dt-bindings/mux/ti-serdes.h> +#include <dt-bindings/phy/phy.h>
/ { chosen { @@ -281,3 +282,25 @@ ti,adc-channels = <0 1 2 3 4 5 6 7>; }; }; + +&serdes_refclk { + clock-frequency = <100000000>; +}; + +&serdes0 { + serdes0_pcie_link: link@0 { + reg = <0>; + cdns,num-lanes = <2>; + #phy-cells = <0>; + cdns,phy-type = <PHY_TYPE_PCIE>; + resets = <&serdes_wiz0 1>, <&serdes_wiz0 2>; + }; + + serdes0_qsgmii_link: link@1 { + reg = <2>; + cdns,num-lanes = <1>; + #phy-cells = <0>; + cdns,phy-type = <PHY_TYPE_QSGMII>; + resets = <&serdes_wiz0 3>; + }; +};
Add u-boot tags for torrent serdes.
Signed-off-by: Aswath Govindraju a-govindraju@ti.com Signed-off-by: Kishon Vijay Abraham I kishon@ti.com --- arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi index bd037be350..bfe1ef5409 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi @@ -160,3 +160,15 @@ &hbmc_mux { u-boot,dm-spl; }; + +&serdes_ln_ctrl { + u-boot,mux-autoprobe; +}; + +&usb_serdes_mux { + u-boot,mux-autoprobe; +}; + +&serdes0 { + u-boot,dm-spl; +};
Enable the mmio mux driver, the J721E-wiz PHy driver and the cadence sierra phy driver. All of them are required for USB3 support
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Signed-off-by: Vignesh Raghavendra vigneshr@ti.com Signed-off-by: Kishon Vijay Abraham I kishon@ti.com --- configs/j721e_evm_a72_defconfig | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig index e14005c39d..5b46f2d53f 100644 --- a/configs/j721e_evm_a72_defconfig +++ b/configs/j721e_evm_a72_defconfig @@ -136,9 +136,15 @@ CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_SPI_FLASH_MTD=y CONFIG_PHY_TI_DP83867=y +CONFIG_MULTIPLEXER=y +CONFIG_MUX_MMIO=y CONFIG_PHY_FIXED=y CONFIG_DM_ETH=y CONFIG_TI_AM65_CPSW_NUSS=y +CONFIG_PHY=y +CONFIG_SPL_PHY=y +CONFIG_PHY_CADENCE_SIERRA=y +CONFIG_PHY_J721E_WIZ=y CONFIG_PINCTRL=y # CONFIG_PINCTRL_GENERIC is not set CONFIG_SPL_PINCTRL=y
Add config for torrent serdes and common clock framework.
Signed-off-by: Aswath Govindraju a-govindraju@ti.com Signed-off-by: Kishon Vijay Abraham I kishon@ti.com --- configs/j7200_evm_a72_defconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/configs/j7200_evm_a72_defconfig b/configs/j7200_evm_a72_defconfig index 162bcc8753..bf78b36d22 100644 --- a/configs/j7200_evm_a72_defconfig +++ b/configs/j7200_evm_a72_defconfig @@ -96,6 +96,7 @@ CONFIG_SPL_OF_TRANSLATE=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_CLK_TI_SCI=y +CONFIG_CLK_CCF=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y @@ -138,9 +139,15 @@ CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_SPI_FLASH_MTD=y +CONFIG_MULTIPLEXER=y +CONFIG_MUX_MMIO=y CONFIG_PHY_FIXED=y CONFIG_DM_ETH=y CONFIG_TI_AM65_CPSW_NUSS=y +CONFIG_PHY=y +CONFIG_SPL_PHY=y +CONFIG_PHY_CADENCE_TORRENT=y +CONFIG_PHY_J721E_WIZ=y CONFIG_PINCTRL=y # CONFIG_PINCTRL_GENERIC is not set CONFIG_SPL_PINCTRL=y
MAIN CPSW0 requires the PHY to be powered on and reset for QSGMII operation. Add a env variable to configure driving "0" on ENET_EXP_PWRDN controlled by GPIO EXPANDER2 (I2C Addr: 0x22), PIN: 17 and driving "1" on ENET_EXP_RESETZ controlled by GPIO EXPANDER2 (I2C Addr: 0x22), PIN: 18.
Signed-off-by: Kishon Vijay Abraham I kishon@ti.com Reviewed-by: Suman Anna s-anna@ti.com --- include/configs/j721e_evm.h | 16 +++++++++++++++- 1 file changed, 15 insertions(+), 1 deletion(-)
diff --git a/include/configs/j721e_evm.h b/include/configs/j721e_evm.h index b707fc4e89..00d0a18a68 100644 --- a/include/configs/j721e_evm.h +++ b/include/configs/j721e_evm.h @@ -139,11 +139,24 @@ #endif /* CONFIG_TARGET_J721E_A72_EVM */
#ifdef CONFIG_TARGET_J7200_A72_EVM +#define EXTRA_ENV_CONFIG_MAIN_CPSW0_QSGMII_PHY \ + "do_main_cpsw0_qsgmii_phyinit=1\0" \ + "init_main_cpsw0_qsgmii_phy=gpio set gpio@22_17;" \ + "gpio clear gpio@22_16\0" \ + "main_cpsw0_qsgmii_phyinit=" \ + "if test ${do_main_cpsw0_qsgmii_phyinit} -eq 1 && test ${dorprocboot} -eq 1 && " \ + "test ${boot} = mmc; then " \ + "run init_main_cpsw0_qsgmii_phy;" \ + "fi;\0" #define DEFAULT_RPROCS "" \ "2 /lib/firmware/j7200-main-r5f0_0-fw " \ "3 /lib/firmware/j7200-main-r5f0_1-fw " #endif /* CONFIG_TARGET_J7200_A72_EVM */
+#ifndef EXTRA_ENV_CONFIG_MAIN_CPSW0_QSGMII_PHY +#define EXTRA_ENV_CONFIG_MAIN_CPSW0_QSGMII_PHY +#endif + /* set default dfu_bufsiz to 128KB (sector size of OSPI) */ #define EXTRA_ENV_DFUARGS \ "dfu_bufsiz=0x20000\0" \ @@ -170,7 +183,8 @@ EXTRA_ENV_RPROC_SETTINGS \ EXTRA_ENV_DFUARGS \ DEFAULT_UFS_TI_ARGS \ - EXTRA_ENV_J721E_BOARD_SETTINGS_MTD + EXTRA_ENV_J721E_BOARD_SETTINGS_MTD \ + EXTRA_ENV_CONFIG_MAIN_CPSW0_QSGMII_PHY
/* Now for the remaining common defines */ #include <configs/ti_armv7_common.h>
- "do_main_cpsw0_qsgmii_phyinit=1\0" \
When would this be not true?
- "init_main_cpsw0_qsgmii_phy=gpio set gpio@22_17;" \
- "main_cpsw0_qsgmii_phyinit=" \
- "if test ${do_main_cpsw0_qsgmii_phyinit} -eq 1 && test ${dorprocboot} -eq 1 && " \
And why only on mmc?
- "fi;\0"
Finally, this feels like something we should be doing in CONFIG_PREBOOT, so it's always done, rather than part of seemingly the bootcmd.
Hi Tom,
If the user don't want to use QSGMII, this could be set to false. For instance the SERDES in J7200 can be used such that it can be used with two protocols at a time. So it can be either PCIe + QSGMII or PCIe + USB. So for use cases which require PCIe + USB, this could be set to false.
The current J7200 u-boot code loads firmwares for remote cores only from MMC. So if it's not mmc, it's not going to load ethernet firmware and hence not required to configure the PHY.
- "fi;\0"
I'll check on this.
Thanks for reviewing!
Regards Kishon
On Tue, May 11, 2021 at 07:28:10PM +0530, Kishon Vijay Abraham I wrote:
Hi Tom,
Then we need to create doc/board/ti/j721e_evm.rst with some general content and then document the above in there.
OK. Please make sure this is also part of the documentation. Thanks.
Hi Tom,
Hi Tom,
There is already a document @ board/ti/j721e/README which has some general information. Maybe that could be updated and moved to doc/board/ti/j721e_evm.rst?
Thanks Kishon
On Fri, Jul 09, 2021 at 08:02:03PM +0530, Kishon Vijay Abraham I wrote:
Hi Tom,
Hi Tom,
Yes, board/*/boardname/README should be converted to doc/board/*/boardname.rst in geneal.
Update the default BOOTCOMMAND to provide an automatic and easier way to configure ethernet PHY before loading the firmware.
Signed-off-by: Kishon Vijay Abraham I kishon@ti.com --- configs/j7200_evm_a72_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/j7200_evm_a72_defconfig b/configs/j7200_evm_a72_defconfig index bf78b36d22..5929bba82a 100644 --- a/configs/j7200_evm_a72_defconfig +++ b/configs/j7200_evm_a72_defconfig @@ -30,7 +30,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y -CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" +CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run main_cpsw0_qsgmii_phyinit; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" CONFIG_LOGLEVEL=7 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y
On Tue, May 04, 2021 at 04:11:35PM +0530, Kishon Vijay Abraham I wrote:
Patch series adds Sierra and Torrent SERDES driver for the SERDES used in TI's K3 platforms. This SERDES is used by USB3, PCIe and Ethernet. This series is mostly an adaptation of drivers added in upstream Linux kernel.
Aside from specific comments I've already made, in general there's a lot of dt/binding updates that don't say what Linux kernel rev they're from, and need to. Thanks.
