[U-Boot] [PATCH V3 0/5] Marvell egiga multiple SoC support
NOTES
1) This patchset will only apply above a previously posted and Acked-by patch available on the mailing list archives e.g. at: http://lists.denx.de/pipermail/u-boot/2010-July/073590.html ("kirkwood_egiga: updates: fix DRAM mapping and typo").
2) This patchset will build for edminiv2 but requires a bugfix patch, also Acked-by and available on archives as well at e.g. http://lists.denx.de/pipermail/u-boot/2010-July/073789.html ("kirkwood_egiga: bugfix: add DMA sequence points").
PATCHSET HISTORY
V1: First submission. V2: Reorganization as per Prafulla Wadasakar's suggestion. Used -C in format-patch to render renames correctly. Removal of DRAM patch posted standalone. Removal of unrelated changes. V3: Removal of DMA bugfix patch posted standalone Introduced MAC non-randomization config option Added short description to each patch
SHORT STORY
This patchset separates egiga from kirkwood then adds orion5x support in egiga. It has been duly, and successfully, tested on an OpenRD-Client after each of the four commits and on an EDMini V2 after the last commit.
LONG STORY
This is a set of five atomic commits.
the first commit renames kirkwood_egiga.[ch] to mv_egiga.[ch] in drivers/net/ (also modifies Makefile) to make sur the renaming remains visible in git at 100% similarity.
The second commit makes removes all dependency of mv_egiga on kirkwood. Kirkwood references in all mv_egiga symbols are replaced with mv_egiga references throughout the source tree.
The third commit allows not to randomize local MAC addresses, which orion5x needs because it has no documented or known random generator.
The fourth commit adds orion5x support to mv_egiga.
The fifth commit adds edminiv2 support for the orion5x egiga controller.
All commits were tested on a kirkwood-based OpenRD Client for regression avoidance; the last commit was also tested on an orion5x-based ED Mini V2 for functionality validation.
Albert Aribaud (5): net: rename: kirkwood_egiga as mv_egiga mv_egiga: support SoCs other than kirkwood mv_egiga: CONFIG_SKIP_LOCAL_MAC_RANDOMIZATION mv_egiga: add support for orion5x egiga controller edminiv2: add ethernet support
arch/arm/cpu/arm926ejs/kirkwood/cpu.c | 4 +- arch/arm/cpu/arm926ejs/orion5x/cpu.c | 8 + arch/arm/include/asm/arch-kirkwood/kirkwood.h | 5 + arch/arm/include/asm/arch-orion5x/orion5x.h | 5 + board/LaCie/edminiv2/edminiv2.c | 36 ++ board/LaCie/edminiv2/edminiv2.h | 41 ++ drivers/net/Makefile | 2 +- drivers/net/kirkwood_egiga.h | 505 ------------------------- drivers/net/{kirkwood_egiga.c => mv_egiga.c} | 336 +++++++++-------- drivers/net/mv_egiga.h | 505 +++++++++++++++++++++++++ include/configs/edminiv2.h | 23 +- include/configs/guruplug.h | 4 +- include/configs/km_arm.h | 4 +- include/configs/mv88f6281gtw_ge.h | 4 +- include/configs/openrd_base.h | 4 +- include/configs/rd6281a.h | 4 +- include/configs/sheevaplug.h | 4 +- include/netdev.h | 2 +- 18 files changed, 809 insertions(+), 687 deletions(-) create mode 100644 board/LaCie/edminiv2/edminiv2.h delete mode 100644 drivers/net/kirkwood_egiga.h rename drivers/net/{kirkwood_egiga.c => mv_egiga.c} (60%) create mode 100644 drivers/net/mv_egiga.h
Rename kirkwood_egiga.* to mv_egiga.* and adjust makefile and #include accordingly.
Signed-off-by: Albert Aribaud albert.aribaud@free.fr --- drivers/net/Makefile | 2 +- drivers/net/{kirkwood_egiga.c => mv_egiga.c} | 2 +- drivers/net/{kirkwood_egiga.h => mv_egiga.h} | 0 3 files changed, 2 insertions(+), 2 deletions(-) rename drivers/net/{kirkwood_egiga.c => mv_egiga.c} (99%) rename drivers/net/{kirkwood_egiga.h => mv_egiga.h} (100%)
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index b75c02f..1599c26 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -46,13 +46,13 @@ COBJS-$(CONFIG_FSLDMAFEC) += fsl_mcdmafec.o mcfmii.o COBJS-$(CONFIG_FTMAC100) += ftmac100.o COBJS-$(CONFIG_GRETH) += greth.o COBJS-$(CONFIG_INCA_IP_SWITCH) += inca-ip_sw.o -COBJS-$(CONFIG_KIRKWOOD_EGIGA) += kirkwood_egiga.o COBJS-$(CONFIG_DRIVER_KS8695ETH) += ks8695eth.o COBJS-$(CONFIG_LAN91C96) += lan91c96.o COBJS-$(CONFIG_MACB) += macb.o COBJS-$(CONFIG_MCFFEC) += mcffec.o mcfmii.o COBJS-$(CONFIG_MPC5xxx_FEC) += mpc5xxx_fec.o COBJS-$(CONFIG_MPC512x_FEC) += mpc512x_fec.o +COBJS-$(CONFIG_KIRKWOOD_EGIGA) += mv_egiga.o COBJS-$(CONFIG_NATSEMI) += natsemi.o COBJS-$(CONFIG_DRIVER_NE2000) += ne2000.o ne2000_base.o COBJS-$(CONFIG_DRIVER_AX88796L) += ax88796.o ne2000_base.o diff --git a/drivers/net/kirkwood_egiga.c b/drivers/net/mv_egiga.c similarity index 99% rename from drivers/net/kirkwood_egiga.c rename to drivers/net/mv_egiga.c index dca9f11..b7ecc9d 100644 --- a/drivers/net/kirkwood_egiga.c +++ b/drivers/net/mv_egiga.c @@ -36,7 +36,7 @@ #include <asm/types.h> #include <asm/byteorder.h> #include <asm/arch/kirkwood.h> -#include "kirkwood_egiga.h" +#include "mv_egiga.h"
DECLARE_GLOBAL_DATA_PTR;
diff --git a/drivers/net/kirkwood_egiga.h b/drivers/net/mv_egiga.h similarity index 100% rename from drivers/net/kirkwood_egiga.h rename to drivers/net/mv_egiga.h
Rename all references to kirkwood in mv_egiga symbols throughout the whole codebase.
Signed-off-by: Albert Aribaud albert.aribaud@free.fr --- arch/arm/cpu/arm926ejs/kirkwood/cpu.c | 4 +- arch/arm/include/asm/arch-kirkwood/kirkwood.h | 5 + drivers/net/Makefile | 2 +- drivers/net/mv_egiga.c | 322 +++++++++--------- drivers/net/mv_egiga.h | 466 ++++++++++++------------ include/configs/guruplug.h | 4 +- include/configs/km_arm.h | 4 +- include/configs/mv88f6281gtw_ge.h | 4 +- include/configs/openrd_base.h | 4 +- include/configs/rd6281a.h | 4 +- include/configs/sheevaplug.h | 4 +- include/netdev.h | 2 +- 12 files changed, 418 insertions(+), 407 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/kirkwood/cpu.c b/arch/arm/cpu/arm926ejs/kirkwood/cpu.c index 6fc3902..786ffc6 100644 --- a/arch/arm/cpu/arm926ejs/kirkwood/cpu.c +++ b/arch/arm/cpu/arm926ejs/kirkwood/cpu.c @@ -378,10 +378,10 @@ int arch_misc_init(void) } #endif /* CONFIG_ARCH_MISC_INIT */
-#ifdef CONFIG_KIRKWOOD_EGIGA +#ifdef CONFIG_MV_EGIGA int cpu_eth_init(bd_t *bis) { - kirkwood_egiga_initialize(bis); + mv_egiga_initialize(bis); return 0; } #endif diff --git a/arch/arm/include/asm/arch-kirkwood/kirkwood.h b/arch/arm/include/asm/arch-kirkwood/kirkwood.h index 2470efb..9200605 100644 --- a/arch/arm/include/asm/arch-kirkwood/kirkwood.h +++ b/arch/arm/include/asm/arch-kirkwood/kirkwood.h @@ -60,6 +60,11 @@ #define KW_EGIGA0_BASE (KW_REGISTER(0x72000)) #define KW_EGIGA1_BASE (KW_REGISTER(0x76000))
+#if defined (CONFIG_MV_EGIGA) +#define MV_EGIGA0_BASE KW_EGIGA0_BASE +#define MV_EGIGA1_BASE KW_EGIGA1_BASE +#endif + #if defined (CONFIG_KW88F6281) #include <asm/arch/kw88f6281.h> #elif defined (CONFIG_KW88F6192) diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 1599c26..04f8de0 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -52,7 +52,7 @@ COBJS-$(CONFIG_MACB) += macb.o COBJS-$(CONFIG_MCFFEC) += mcffec.o mcfmii.o COBJS-$(CONFIG_MPC5xxx_FEC) += mpc5xxx_fec.o COBJS-$(CONFIG_MPC512x_FEC) += mpc512x_fec.o -COBJS-$(CONFIG_KIRKWOOD_EGIGA) += mv_egiga.o +COBJS-$(CONFIG_MV_EGIGA) += mv_egiga.o COBJS-$(CONFIG_NATSEMI) += natsemi.o COBJS-$(CONFIG_DRIVER_NE2000) += ne2000.o ne2000_base.o COBJS-$(CONFIG_DRIVER_AX88796L) += ax88796.o ne2000_base.o diff --git a/drivers/net/mv_egiga.c b/drivers/net/mv_egiga.c index b7ecc9d..4fecf1e 100644 --- a/drivers/net/mv_egiga.c +++ b/drivers/net/mv_egiga.c @@ -35,13 +35,17 @@ #include <asm/errno.h> #include <asm/types.h> #include <asm/byteorder.h> + +#if defined (CONFIG_KIRKWOOD) #include <asm/arch/kirkwood.h> +#endif + #include "mv_egiga.h"
-#define KIRKWOOD_PHY_ADR_REQUEST 0xee -#define KWGBE_SMI_REG (((struct kwgbe_registers *)KW_EGIGA0_BASE)->smi) +#define MV_PHY_ADR_REQUEST 0xee +#define MV_EGIGA_SMI_REG (((struct mv_egiga_registers *)MV_EGIGA0_BASE)->smi)
/* * smi_reg_read - miiphy_read callback function. @@ -51,16 +55,16 @@ DECLARE_GLOBAL_DATA_PTR; static int smi_reg_read(char *devname, u8 phy_adr, u8 reg_ofs, u16 * data) { struct eth_device *dev = eth_get_dev_by_name(devname); - struct kwgbe_device *dkwgbe = to_dkwgbe(dev); - struct kwgbe_registers *regs = dkwgbe->regs; + struct mv_egiga_device *dmvegiga = to_mv_egiga(dev); + struct mv_egiga_registers *regs = dmvegiga->regs; u32 smi_reg; u32 timeout;
/* Phyadr read request */ - if (phy_adr == KIRKWOOD_PHY_ADR_REQUEST && - reg_ofs == KIRKWOOD_PHY_ADR_REQUEST) { + if (phy_adr == MV_PHY_ADR_REQUEST && + reg_ofs == MV_PHY_ADR_REQUEST) { /* */ - *data = (u16) (KWGBEREG_RD(regs->phyadr) & PHYADR_MASK); + *data = (u16) (MV_EGIGA_REG_RD(regs->phyadr) & PHYADR_MASK); return 0; } /* check parameters */ @@ -75,42 +79,42 @@ static int smi_reg_read(char *devname, u8 phy_adr, u8 reg_ofs, u16 * data) return -EFAULT; }
- timeout = KWGBE_PHY_SMI_TIMEOUT; + timeout = MV_EGIGA_PHY_SMI_TIMEOUT; /* wait till the SMI is not busy */ do { /* read smi register */ - smi_reg = KWGBEREG_RD(KWGBE_SMI_REG); + smi_reg = MV_EGIGA_REG_RD(MV_EGIGA_SMI_REG); if (timeout-- == 0) { printf("Err..(%s) SMI busy timeout\n", __FUNCTION__); return -EFAULT; } - } while (smi_reg & KWGBE_PHY_SMI_BUSY_MASK); + } while (smi_reg & MV_EGIGA_PHY_SMI_BUSY_MASK);
/* fill the phy address and regiser offset and read opcode */ - smi_reg = (phy_adr << KWGBE_PHY_SMI_DEV_ADDR_OFFS) - | (reg_ofs << KWGBE_SMI_REG_ADDR_OFFS) - | KWGBE_PHY_SMI_OPCODE_READ; + smi_reg = (phy_adr << MV_EGIGA_PHY_SMI_DEV_ADDR_OFFS) + | (reg_ofs << MV_EGIGA_SMI_REG_ADDR_OFFS) + | MV_EGIGA_PHY_SMI_OPCODE_READ;
/* write the smi register */ - KWGBEREG_WR(KWGBE_SMI_REG, smi_reg); + MV_EGIGA_REG_WR(MV_EGIGA_SMI_REG, smi_reg);
/*wait till read value is ready */ - timeout = KWGBE_PHY_SMI_TIMEOUT; + timeout = MV_EGIGA_PHY_SMI_TIMEOUT;
do { /* read smi register */ - smi_reg = KWGBEREG_RD(KWGBE_SMI_REG); + smi_reg = MV_EGIGA_REG_RD(MV_EGIGA_SMI_REG); if (timeout-- == 0) { printf("Err..(%s) SMI read ready timeout\n", __FUNCTION__); return -EFAULT; } - } while (!(smi_reg & KWGBE_PHY_SMI_READ_VALID_MASK)); + } while (!(smi_reg & MV_EGIGA_PHY_SMI_READ_VALID_MASK));
/* Wait for the data to update in the SMI register */ - for (timeout = 0; timeout < KWGBE_PHY_SMI_TIMEOUT; timeout++) ; + for (timeout = 0; timeout < MV_EGIGA_PHY_SMI_TIMEOUT; timeout++) ;
- *data = (u16) (KWGBEREG_RD(KWGBE_SMI_REG) & KWGBE_PHY_SMI_DATA_MASK); + *data = (u16) (MV_EGIGA_REG_RD(MV_EGIGA_SMI_REG) & MV_EGIGA_PHY_SMI_DATA_MASK);
debug("%s:(adr %d, off %d) value= %04x\n", __FUNCTION__, phy_adr, reg_ofs, *data); @@ -127,15 +131,15 @@ static int smi_reg_read(char *devname, u8 phy_adr, u8 reg_ofs, u16 * data) static int smi_reg_write(char *devname, u8 phy_adr, u8 reg_ofs, u16 data) { struct eth_device *dev = eth_get_dev_by_name(devname); - struct kwgbe_device *dkwgbe = to_dkwgbe(dev); - struct kwgbe_registers *regs = dkwgbe->regs; + struct mv_egiga_device *dmvegiga = to_mv_egiga(dev); + struct mv_egiga_registers *regs = dmvegiga->regs; u32 smi_reg; u32 timeout;
/* Phyadr write request*/ - if (phy_adr == KIRKWOOD_PHY_ADR_REQUEST && - reg_ofs == KIRKWOOD_PHY_ADR_REQUEST) { - KWGBEREG_WR(regs->phyadr, data); + if (phy_adr == MV_PHY_ADR_REQUEST && + reg_ofs == MV_PHY_ADR_REQUEST) { + MV_EGIGA_REG_WR(regs->phyadr, data); return 0; }
@@ -150,24 +154,24 @@ static int smi_reg_write(char *devname, u8 phy_adr, u8 reg_ofs, u16 data) }
/* wait till the SMI is not busy */ - timeout = KWGBE_PHY_SMI_TIMEOUT; + timeout = MV_EGIGA_PHY_SMI_TIMEOUT; do { /* read smi register */ - smi_reg = KWGBEREG_RD(KWGBE_SMI_REG); + smi_reg = MV_EGIGA_REG_RD(MV_EGIGA_SMI_REG); if (timeout-- == 0) { printf("Err..(%s) SMI busy timeout\n", __FUNCTION__); return -ETIME; } - } while (smi_reg & KWGBE_PHY_SMI_BUSY_MASK); + } while (smi_reg & MV_EGIGA_PHY_SMI_BUSY_MASK);
/* fill the phy addr and reg offset and write opcode and data */ - smi_reg = (data << KWGBE_PHY_SMI_DATA_OFFS); - smi_reg |= (phy_adr << KWGBE_PHY_SMI_DEV_ADDR_OFFS) - | (reg_ofs << KWGBE_SMI_REG_ADDR_OFFS); - smi_reg &= ~KWGBE_PHY_SMI_OPCODE_READ; + smi_reg = (data << MV_EGIGA_PHY_SMI_DATA_OFFS); + smi_reg |= (phy_adr << MV_EGIGA_PHY_SMI_DEV_ADDR_OFFS) + | (reg_ofs << MV_EGIGA_SMI_REG_ADDR_OFFS); + smi_reg &= ~MV_EGIGA_PHY_SMI_OPCODE_READ;
return 0; } @@ -204,46 +208,46 @@ static void stop_queue(u32 * qreg) * @regs Register struct pointer. * @param Address decode parameter struct. */ -static void set_access_control(struct kwgbe_registers *regs, - struct kwgbe_winparam *param) +static void set_access_control(struct mv_egiga_registers *regs, + struct mv_egiga_winparam *param) { u32 access_prot_reg;
/* Set access control register */ - access_prot_reg = KWGBEREG_RD(regs->epap); + access_prot_reg = MV_EGIGA_REG_RD(regs->epap); /* clear window permission */ access_prot_reg &= (~(3 << (param->win * 2))); access_prot_reg |= (param->access_ctrl << (param->win * 2)); - KWGBEREG_WR(regs->epap, access_prot_reg); + MV_EGIGA_REG_WR(regs->epap, access_prot_reg);
/* Set window Size reg (SR) */ - KWGBEREG_WR(regs->barsz[param->win].size, + MV_EGIGA_REG_WR(regs->barsz[param->win].size, (((param->size / 0x10000) - 1) << 16));
/* Set window Base address reg (BA) */ - KWGBEREG_WR(regs->barsz[param->win].bar, + MV_EGIGA_REG_WR(regs->barsz[param->win].bar, (param->target | param->attrib | param->base_addr)); /* High address remap reg (HARR) */ if (param->win < 4) - KWGBEREG_WR(regs->ha_remap[param->win], param->high_addr); + MV_EGIGA_REG_WR(regs->ha_remap[param->win], param->high_addr);
/* Base address enable reg (BARER) */ if (param->enable == 1) - KWGBEREG_BITS_RESET(regs->bare, (1 << param->win)); + MV_EGIGA_REG_BITS_RESET(regs->bare, (1 << param->win)); else - KWGBEREG_BITS_SET(regs->bare, (1 << param->win)); + MV_EGIGA_REG_BITS_SET(regs->bare, (1 << param->win)); }
-static void set_dram_access(struct kwgbe_registers *regs) +static void set_dram_access(struct mv_egiga_registers *regs) { - struct kwgbe_winparam win_param; + struct mv_egiga_winparam win_param; int i;
for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { /* Set access parameters for DRAM bank i */ win_param.win = i; /* Use Ethernet window i */ /* Window target - DDR */ - win_param.target = KWGBE_TARGET_DRAM; + win_param.target = MV_EGIGA_TARGET_DRAM; /* Enable full access */ win_param.access_ctrl = EWIN_ACCESS_FULL; win_param.high_addr = 0; @@ -286,19 +290,19 @@ static void set_dram_access(struct kwgbe_registers *regs) * Go through all the DA filter tables (Unicast, Special Multicast & Other * Multicast) and set each entry to 0. */ -static void port_init_mac_tables(struct kwgbe_registers *regs) +static void port_init_mac_tables(struct mv_egiga_registers *regs) { int table_index;
/* Clear DA filter unicast table (Ex_dFUT) */ for (table_index = 0; table_index < 4; ++table_index) - KWGBEREG_WR(regs->dfut[table_index], 0); + MV_EGIGA_REG_WR(regs->dfut[table_index], 0);
for (table_index = 0; table_index < 64; ++table_index) { /* Clear DA filter special multicast table (Ex_dFSMT) */ - KWGBEREG_WR(regs->dfsmt[table_index], 0); + MV_EGIGA_REG_WR(regs->dfsmt[table_index], 0); /* Clear DA filter other multicast table (Ex_dFOMT) */ - KWGBEREG_WR(regs->dfomt[table_index], 0); + MV_EGIGA_REG_WR(regs->dfomt[table_index], 0); } }
@@ -316,7 +320,7 @@ static void port_init_mac_tables(struct kwgbe_registers *regs) * * RETURN: 1 if output succeeded. 0 if option parameter is invalid. */ -static int port_uc_addr(struct kwgbe_registers *regs, u8 uc_nibble, +static int port_uc_addr(struct mv_egiga_registers *regs, u8 uc_nibble, int option) { u32 unicast_reg; @@ -336,16 +340,16 @@ static int port_uc_addr(struct kwgbe_registers *regs, u8 uc_nibble, * Clear accepts frame bit at specified unicast * DA table entry */ - unicast_reg = KWGBEREG_RD(regs->dfut[tbl_offset]); + unicast_reg = MV_EGIGA_REG_RD(regs->dfut[tbl_offset]); unicast_reg &= (0xFF << (8 * reg_offset)); - KWGBEREG_WR(regs->dfut[tbl_offset], unicast_reg); + MV_EGIGA_REG_WR(regs->dfut[tbl_offset], unicast_reg); break; case ACCEPT_MAC_ADDR: /* Set accepts frame bit at unicast DA filter table entry */ - unicast_reg = KWGBEREG_RD(regs->dfut[tbl_offset]); + unicast_reg = MV_EGIGA_REG_RD(regs->dfut[tbl_offset]); unicast_reg &= (0xFF << (8 * reg_offset)); unicast_reg |= ((0x01 | (RXUQ << 1)) << (8 * reg_offset)); - KWGBEREG_WR(regs->dfut[tbl_offset], unicast_reg); + MV_EGIGA_REG_WR(regs->dfut[tbl_offset], unicast_reg); break; default: return 0; @@ -356,7 +360,7 @@ static int port_uc_addr(struct kwgbe_registers *regs, u8 uc_nibble, /* * port_uc_addr_set - This function Set the port Unicast address. */ -static void port_uc_addr_set(struct kwgbe_registers *regs, u8 * p_addr) +static void port_uc_addr_set(struct mv_egiga_registers *regs, u8 * p_addr) { u32 mac_h; u32 mac_l; @@ -365,94 +369,94 @@ static void port_uc_addr_set(struct kwgbe_registers *regs, u8 * p_addr) mac_h = (p_addr[0] << 24) | (p_addr[1] << 16) | (p_addr[2] << 8) | (p_addr[3] << 0);
- KWGBEREG_WR(regs->macal, mac_l); - KWGBEREG_WR(regs->macah, mac_h); + MV_EGIGA_REG_WR(regs->macal, mac_l); + MV_EGIGA_REG_WR(regs->macah, mac_h);
/* Accept frames of this address */ port_uc_addr(regs, p_addr[5], ACCEPT_MAC_ADDR); }
/* - * kwgbe_init_rx_desc_ring - Curve a Rx chain desc list and buffer in memory. + * mv_egiga_init_rx_desc_ring - Curve a Rx chain desc list and buffer in memory. */ -static void kwgbe_init_rx_desc_ring(struct kwgbe_device *dkwgbe) +static void mv_egiga_init_rx_desc_ring(struct mv_egiga_device *dmvegiga) { - struct kwgbe_rxdesc *p_rx_desc; + struct mv_egiga_rxdesc *p_rx_desc; int i;
/* initialize the Rx descriptors ring */ - p_rx_desc = dkwgbe->p_rxdesc; + p_rx_desc = dmvegiga->p_rxdesc; for (i = 0; i < RINGSZ; i++) { p_rx_desc->cmd_sts = - KWGBE_BUFFER_OWNED_BY_DMA | KWGBE_RX_EN_INTERRUPT; + MV_EGIGA_BUFFER_OWNED_BY_DMA | MV_EGIGA_RX_EN_INTERRUPT; p_rx_desc->buf_size = PKTSIZE_ALIGN; p_rx_desc->byte_cnt = 0; - p_rx_desc->buf_ptr = dkwgbe->p_rxbuf + i * PKTSIZE_ALIGN; + p_rx_desc->buf_ptr = dmvegiga->p_rxbuf + i * PKTSIZE_ALIGN; if (i == (RINGSZ - 1)) - p_rx_desc->nxtdesc_p = dkwgbe->p_rxdesc; + p_rx_desc->nxtdesc_p = dmvegiga->p_rxdesc; else { - p_rx_desc->nxtdesc_p = (struct kwgbe_rxdesc *) - ((u32) p_rx_desc + KW_RXQ_DESC_ALIGNED_SIZE); + p_rx_desc->nxtdesc_p = (struct mv_egiga_rxdesc *) + ((u32) p_rx_desc + MV_RXQ_DESC_ALIGNED_SIZE); p_rx_desc = p_rx_desc->nxtdesc_p; } } - dkwgbe->p_rxdesc_curr = dkwgbe->p_rxdesc; + dmvegiga->p_rxdesc_curr = dmvegiga->p_rxdesc; }
-static int kwgbe_init(struct eth_device *dev) +static int mv_egiga_init(struct eth_device *dev) { - struct kwgbe_device *dkwgbe = to_dkwgbe(dev); - struct kwgbe_registers *regs = dkwgbe->regs; + struct mv_egiga_device *dmvegiga = to_mv_egiga(dev); + struct mv_egiga_registers *regs = dmvegiga->regs; #if (defined (CONFIG_MII) || defined (CONFIG_CMD_MII)) \ && defined (CONFIG_SYS_FAULT_ECHO_LINK_DOWN) int i; #endif /* setup RX rings */ - kwgbe_init_rx_desc_ring(dkwgbe); + mv_egiga_init_rx_desc_ring(dmvegiga);
/* Clear the ethernet port interrupts */ - KWGBEREG_WR(regs->ic, 0); - KWGBEREG_WR(regs->ice, 0); + MV_EGIGA_REG_WR(regs->ic, 0); + MV_EGIGA_REG_WR(regs->ice, 0); /* Unmask RX buffer and TX end interrupt */ - KWGBEREG_WR(regs->pim, INT_CAUSE_UNMASK_ALL); + MV_EGIGA_REG_WR(regs->pim, INT_CAUSE_UNMASK_ALL); /* Unmask phy and link status changes interrupts */ - KWGBEREG_WR(regs->peim, INT_CAUSE_UNMASK_ALL_EXT); + MV_EGIGA_REG_WR(regs->peim, INT_CAUSE_UNMASK_ALL_EXT);
set_dram_access(regs); port_init_mac_tables(regs); - port_uc_addr_set(regs, dkwgbe->dev.enetaddr); + port_uc_addr_set(regs, dmvegiga->dev.enetaddr);
/* Assign port configuration and command. */ - KWGBEREG_WR(regs->pxc, PRT_CFG_VAL); - KWGBEREG_WR(regs->pxcx, PORT_CFG_EXTEND_VALUE); - KWGBEREG_WR(regs->psc0, PORT_SERIAL_CONTROL_VALUE); + MV_EGIGA_REG_WR(regs->pxc, PRT_CFG_VAL); + MV_EGIGA_REG_WR(regs->pxcx, PORT_CFG_EXTEND_VALUE); + MV_EGIGA_REG_WR(regs->psc0, PORT_SERIAL_CONTROL_VALUE);
/* Assign port SDMA configuration */ - KWGBEREG_WR(regs->sdc, PORT_SDMA_CFG_VALUE); - KWGBEREG_WR(regs->tqx[0].qxttbc, QTKNBKT_DEF_VAL); - KWGBEREG_WR(regs->tqx[0].tqxtbc, (QMTBS_DEF_VAL << 16) | QTKNRT_DEF_VAL); + MV_EGIGA_REG_WR(regs->sdc, PORT_SDMA_CFG_VALUE); + MV_EGIGA_REG_WR(regs->tqx[0].qxttbc, QTKNBKT_DEF_VAL); + MV_EGIGA_REG_WR(regs->tqx[0].tqxtbc, (QMTBS_DEF_VAL << 16) | QTKNRT_DEF_VAL); /* Turn off the port/RXUQ bandwidth limitation */ - KWGBEREG_WR(regs->pmtu, 0); + MV_EGIGA_REG_WR(regs->pmtu, 0);
/* Set maximum receive buffer to 9700 bytes */ - KWGBEREG_WR(regs->psc0, KWGBE_MAX_RX_PACKET_9700BYTE - | (KWGBEREG_RD(regs->psc0) & MRU_MASK)); + MV_EGIGA_REG_WR(regs->psc0, MV_EGIGA_MAX_RX_PACKET_9700BYTE + | (MV_EGIGA_REG_RD(regs->psc0) & MRU_MASK));
/* Enable port initially */ - KWGBEREG_BITS_SET(regs->psc0, KWGBE_SERIAL_PORT_EN); + MV_EGIGA_REG_BITS_SET(regs->psc0, MV_EGIGA_SERIAL_PORT_EN);
/* * Set ethernet MTU for leaky bucket mechanism to 0 - this will * disable the leaky bucket mechanism . */ - KWGBEREG_WR(regs->pmtu, 0); + MV_EGIGA_REG_WR(regs->pmtu, 0);
/* Assignment of Rx CRDB of given RXUQ */ - KWGBEREG_WR(regs->rxcdp[RXUQ], (u32) dkwgbe->p_rxdesc_curr); + MV_EGIGA_REG_WR(regs->rxcdp[RXUQ], (u32) dmvegiga->p_rxdesc_curr); /* ensure previous write is done before enabling Rx DMA */ isb(); /* Enable port Rx. */ - KWGBEREG_WR(regs->rqc, (1 << RXUQ)); + MV_EGIGA_REG_WR(regs->rqc, (1 << RXUQ));
#if (defined (CONFIG_MII) || defined (CONFIG_CMD_MII)) \ && defined (CONFIG_SYS_FAULT_ECHO_LINK_DOWN) @@ -460,8 +464,8 @@ static int kwgbe_init(struct eth_device *dev) for (i = 0; i < 5; i++) { u16 phyadr;
- miiphy_read(dev->name, KIRKWOOD_PHY_ADR_REQUEST, - KIRKWOOD_PHY_ADR_REQUEST, &phyadr); + miiphy_read(dev->name, MV_PHY_ADR_REQUEST, + MV_PHY_ADR_REQUEST, &phyadr); /* Return if we get link up */ if (miiphy_link(dev->name, phyadr)) return 0; @@ -474,50 +478,50 @@ static int kwgbe_init(struct eth_device *dev) return 0; }
-static int kwgbe_halt(struct eth_device *dev) +static int mv_egiga_halt(struct eth_device *dev) { - struct kwgbe_device *dkwgbe = to_dkwgbe(dev); - struct kwgbe_registers *regs = dkwgbe->regs; + struct mv_egiga_device *dmvegiga = to_mv_egiga(dev); + struct mv_egiga_registers *regs = dmvegiga->regs;
/* Disable all gigE address decoder */ - KWGBEREG_WR(regs->bare, 0x3f); + MV_EGIGA_REG_WR(regs->bare, 0x3f);
stop_queue(®s->tqc); stop_queue(®s->rqc);
/* Disable port */ - KWGBEREG_BITS_RESET(regs->psc0, KWGBE_SERIAL_PORT_EN); + MV_EGIGA_REG_BITS_RESET(regs->psc0, MV_EGIGA_SERIAL_PORT_EN); /* Set port is not reset */ - KWGBEREG_BITS_RESET(regs->psc1, 1 << 4); + MV_EGIGA_REG_BITS_RESET(regs->psc1, 1 << 4); #ifdef CONFIG_SYS_MII_MODE /* Set MMI interface up */ - KWGBEREG_BITS_RESET(regs->psc1, 1 << 3); + MV_EGIGA_REG_BITS_RESET(regs->psc1, 1 << 3); #endif /* Disable & mask ethernet port interrupts */ - KWGBEREG_WR(regs->ic, 0); - KWGBEREG_WR(regs->ice, 0); - KWGBEREG_WR(regs->pim, 0); - KWGBEREG_WR(regs->peim, 0); + MV_EGIGA_REG_WR(regs->ic, 0); + MV_EGIGA_REG_WR(regs->ice, 0); + MV_EGIGA_REG_WR(regs->pim, 0); + MV_EGIGA_REG_WR(regs->peim, 0);
return 0; }
-static int kwgbe_write_hwaddr(struct eth_device *dev) +static int mv_egiga_write_hwaddr(struct eth_device *dev) { - struct kwgbe_device *dkwgbe = to_dkwgbe(dev); - struct kwgbe_registers *regs = dkwgbe->regs; + struct mv_egiga_device *dmvegiga = to_mv_egiga(dev); + struct mv_egiga_registers *regs = dmvegiga->regs;
/* Programs net device MAC address after initialization */ - port_uc_addr_set(regs, dkwgbe->dev.enetaddr); + port_uc_addr_set(regs, dmvegiga->dev.enetaddr); return 0; }
-static int kwgbe_send(struct eth_device *dev, volatile void *dataptr, +static int mv_egiga_send(struct eth_device *dev, volatile void *dataptr, int datasize) { - struct kwgbe_device *dkwgbe = to_dkwgbe(dev); - struct kwgbe_registers *regs = dkwgbe->regs; - struct kwgbe_txdesc *p_txdesc = dkwgbe->p_txdesc; + struct mv_egiga_device *dmvegiga = to_mv_egiga(dev); + struct mv_egiga_registers *regs = dmvegiga->regs; + struct mv_egiga_txdesc *p_txdesc = dmvegiga->p_txdesc; void *p = (void *)dataptr; u32 cmd_sts;
@@ -529,35 +533,35 @@ static int kwgbe_send(struct eth_device *dev, volatile void *dataptr, return -1; }
- memcpy(dkwgbe->p_aligned_txbuf, p, datasize); - p = dkwgbe->p_aligned_txbuf; + memcpy(dmvegiga->p_aligned_txbuf, p, datasize); + p = dmvegiga->p_aligned_txbuf; }
- p_txdesc->cmd_sts = KWGBE_ZERO_PADDING | KWGBE_GEN_CRC; - p_txdesc->cmd_sts |= KWGBE_TX_FIRST_DESC | KWGBE_TX_LAST_DESC; - p_txdesc->cmd_sts |= KWGBE_BUFFER_OWNED_BY_DMA; - p_txdesc->cmd_sts |= KWGBE_TX_EN_INTERRUPT; + p_txdesc->cmd_sts = MV_EGIGA_ZERO_PADDING | MV_EGIGA_GEN_CRC; + p_txdesc->cmd_sts |= MV_EGIGA_TX_FIRST_DESC | MV_EGIGA_TX_LAST_DESC; + p_txdesc->cmd_sts |= MV_EGIGA_BUFFER_OWNED_BY_DMA; + p_txdesc->cmd_sts |= MV_EGIGA_TX_EN_INTERRUPT; p_txdesc->buf_ptr = (u8 *) p; p_txdesc->byte_cnt = datasize;
/* Set this tc desc as zeroth TXUQ */ - KWGBEREG_WR(regs->tcqdp[TXUQ], (u32) p_txdesc); + MV_EGIGA_REG_WR(regs->tcqdp[TXUQ], (u32) p_txdesc);
/* ensure tx desc writes above are performed before we start Tx DMA */ isb();
/* Apply send command using zeroth TXUQ */ - KWGBEREG_WR(regs->tqc, (1 << TXUQ)); + MV_EGIGA_REG_WR(regs->tqc, (1 << TXUQ));
/* * wait for packet xmit completion */ cmd_sts = readl(&p_txdesc->cmd_sts); - while (cmd_sts & KWGBE_BUFFER_OWNED_BY_DMA) { + while (cmd_sts & MV_EGIGA_BUFFER_OWNED_BY_DMA) { /* return fail if error is detected */ - if ((cmd_sts & (KWGBE_ERROR_SUMMARY | KWGBE_TX_LAST_FRAME)) == - (KWGBE_ERROR_SUMMARY | KWGBE_TX_LAST_FRAME) && - cmd_sts & (KWGBE_UR_ERROR | KWGBE_RL_ERROR)) { + if ((cmd_sts & (MV_EGIGA_ERROR_SUMMARY | MV_EGIGA_TX_LAST_FRAME)) == + (MV_EGIGA_ERROR_SUMMARY | MV_EGIGA_TX_LAST_FRAME) && + cmd_sts & (MV_EGIGA_UR_ERROR | MV_EGIGA_RL_ERROR)) { printf("Err..(%s) in xmit packet\n", __FUNCTION__); return -1; } @@ -566,22 +570,22 @@ static int kwgbe_send(struct eth_device *dev, volatile void *dataptr, return 0; }
-static int kwgbe_recv(struct eth_device *dev) +static int mv_egiga_recv(struct eth_device *dev) { - struct kwgbe_device *dkwgbe = to_dkwgbe(dev); - struct kwgbe_rxdesc *p_rxdesc_curr = dkwgbe->p_rxdesc_curr; + struct mv_egiga_device *dmvegiga = to_mv_egiga(dev); + struct mv_egiga_rxdesc *p_rxdesc_curr = dmvegiga->p_rxdesc_curr; u32 cmd_sts; u32 timeout = 0;
/* wait untill rx packet available or timeout */ do { - if (timeout < KWGBE_PHY_SMI_TIMEOUT) + if (timeout < MV_EGIGA_PHY_SMI_TIMEOUT) timeout++; else { debug("%s time out...\n", __FUNCTION__); return -1; } - } while (readl(&p_rxdesc_curr->cmd_sts) & KWGBE_BUFFER_OWNED_BY_DMA); + } while (readl(&p_rxdesc_curr->cmd_sts) & MV_EGIGA_BUFFER_OWNED_BY_DMA);
if (p_rxdesc_curr->byte_cnt != 0) { debug("%s: Received %d byte Packet @ 0x%x (cmd_sts= %08x)\n", @@ -598,13 +602,13 @@ static int kwgbe_recv(struct eth_device *dev) cmd_sts = readl(&p_rxdesc_curr->cmd_sts);
if ((cmd_sts & - (KWGBE_RX_FIRST_DESC | KWGBE_RX_LAST_DESC)) - != (KWGBE_RX_FIRST_DESC | KWGBE_RX_LAST_DESC)) { + (MV_EGIGA_RX_FIRST_DESC | MV_EGIGA_RX_LAST_DESC)) + != (MV_EGIGA_RX_FIRST_DESC | MV_EGIGA_RX_LAST_DESC)) {
printf("Err..(%s) Dropping packet spread on" " multiple descriptors\n", __FUNCTION__);
- } else if (cmd_sts & KWGBE_ERROR_SUMMARY) { + } else if (cmd_sts & MV_EGIGA_ERROR_SUMMARY) {
printf("Err..(%s) Dropping packet with errors\n", __FUNCTION__); @@ -622,62 +626,62 @@ static int kwgbe_recv(struct eth_device *dev) * free these descriptors and point next in the ring */ p_rxdesc_curr->cmd_sts = - KWGBE_BUFFER_OWNED_BY_DMA | KWGBE_RX_EN_INTERRUPT; + MV_EGIGA_BUFFER_OWNED_BY_DMA | MV_EGIGA_RX_EN_INTERRUPT; p_rxdesc_curr->buf_size = PKTSIZE_ALIGN; p_rxdesc_curr->byte_cnt = 0;
- writel((unsigned)p_rxdesc_curr->nxtdesc_p, (u32) &dkwgbe->p_rxdesc_curr); + writel((unsigned)p_rxdesc_curr->nxtdesc_p, (u32) &dmvegiga->p_rxdesc_curr);
return 0; }
-int kirkwood_egiga_initialize(bd_t * bis) +int mv_egiga_initialize(bd_t * bis) { - struct kwgbe_device *dkwgbe; + struct mv_egiga_device *dmvegiga; struct eth_device *dev; int devnum; char *s; - u8 used_ports[MAX_KWGBE_DEVS] = CONFIG_KIRKWOOD_EGIGA_PORTS; + u8 used_ports[MAX_MV_EGIGA_DEVS] = CONFIG_MV_EGIGA_PORTS;
- for (devnum = 0; devnum < MAX_KWGBE_DEVS; devnum++) { + for (devnum = 0; devnum < MAX_MV_EGIGA_DEVS; devnum++) { /*skip if port is configured not to use */ if (used_ports[devnum] == 0) continue;
- if (!(dkwgbe = malloc(sizeof(struct kwgbe_device)))) + if (!(dmvegiga = malloc(sizeof(struct mv_egiga_device)))) goto error1;
- memset(dkwgbe, 0, sizeof(struct kwgbe_device)); + memset(dmvegiga, 0, sizeof(struct mv_egiga_device));
- if (!(dkwgbe->p_rxdesc = - (struct kwgbe_rxdesc *)memalign(PKTALIGN, - KW_RXQ_DESC_ALIGNED_SIZE + if (!(dmvegiga->p_rxdesc = + (struct mv_egiga_rxdesc *)memalign(PKTALIGN, + MV_RXQ_DESC_ALIGNED_SIZE * RINGSZ + 1))) goto error2;
- if (!(dkwgbe->p_rxbuf = (u8 *) memalign(PKTALIGN, RINGSZ + if (!(dmvegiga->p_rxbuf = (u8 *) memalign(PKTALIGN, RINGSZ * PKTSIZE_ALIGN + 1))) goto error3;
- if (!(dkwgbe->p_aligned_txbuf = memalign(8, PKTSIZE_ALIGN))) + if (!(dmvegiga->p_aligned_txbuf = memalign(8, PKTSIZE_ALIGN))) goto error4;
- if (!(dkwgbe->p_txdesc = (struct kwgbe_txdesc *) - memalign(PKTALIGN, sizeof(struct kwgbe_txdesc) + 1))) { - free(dkwgbe->p_aligned_txbuf); + if (!(dmvegiga->p_txdesc = (struct mv_egiga_txdesc *) + memalign(PKTALIGN, sizeof(struct mv_egiga_txdesc) + 1))) { + free(dmvegiga->p_aligned_txbuf); error4: - free(dkwgbe->p_rxbuf); + free(dmvegiga->p_rxbuf); error3: - free(dkwgbe->p_rxdesc); + free(dmvegiga->p_rxdesc); error2: - free(dkwgbe); + free(dmvegiga); error1: printf("Err.. %s Failed to allocate memory\n", __FUNCTION__); return -1; }
- dev = &dkwgbe->dev; + dev = &dmvegiga->dev;
/* must be less than NAMESIZE (16) */ sprintf(dev->name, "egiga%d", devnum); @@ -685,13 +689,15 @@ int kirkwood_egiga_initialize(bd_t * bis) /* Extract the MAC address from the environment */ switch (devnum) { case 0: - dkwgbe->regs = (void *)KW_EGIGA0_BASE; + dmvegiga->regs = (void *)MV_EGIGA0_BASE; s = "ethaddr"; break; +#if defined (MV_EGIGA1_BASE) case 1: - dkwgbe->regs = (void *)KW_EGIGA1_BASE; + dmvegiga->regs = (void *)MV_EGIGA1_BASE; s = "eth1addr"; break; +#endif default: /* this should never happen */ printf("Err..(%s) Invalid device number %d\n", __FUNCTION__, devnum); @@ -709,19 +715,19 @@ int kirkwood_egiga_initialize(bd_t * bis) eth_setenv_enetaddr(s, dev->enetaddr); }
- dev->init = (void *)kwgbe_init; - dev->halt = (void *)kwgbe_halt; - dev->send = (void *)kwgbe_send; - dev->recv = (void *)kwgbe_recv; - dev->write_hwaddr = (void *)kwgbe_write_hwaddr; + dev->init = (void *)mv_egiga_init; + dev->halt = (void *)mv_egiga_halt; + dev->send = (void *)mv_egiga_send; + dev->recv = (void *)mv_egiga_recv; + dev->write_hwaddr = (void *)mv_egiga_write_hwaddr;
eth_register(dev);
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) miiphy_register(dev->name, smi_reg_read, smi_reg_write); /* Set phy address of the port */ - miiphy_write(dev->name, KIRKWOOD_PHY_ADR_REQUEST, - KIRKWOOD_PHY_ADR_REQUEST, PHY_BASE_ADR + devnum); + miiphy_write(dev->name, MV_PHY_ADR_REQUEST, + MV_PHY_ADR_REQUEST, PHY_BASE_ADR + devnum); #endif } return 0; diff --git a/drivers/net/mv_egiga.h b/drivers/net/mv_egiga.h index 30c773c..61c3157 100644 --- a/drivers/net/mv_egiga.h +++ b/drivers/net/mv_egiga.h @@ -28,7 +28,7 @@ #ifndef __EGIGA_H__ #define __EGIGA_H__
-#define MAX_KWGBE_DEVS 2 /*controller has two ports */ +#define MAX_MV_EGIGA_DEVS 2 /*controller has two ports */
/* PHY_BASE_ADR is board specific and can be configured */ #if defined (CONFIG_PHY_BASE_ADR) @@ -49,60 +49,60 @@ #define RXUQ 0 /* Used Rx queue */ #define TXUQ 0 /* Used Rx queue */
-#define to_dkwgbe(_kd) container_of(_kd, struct kwgbe_device, dev) -#define KWGBEREG_WR(adr, val) writel(val, &adr) -#define KWGBEREG_RD(adr) readl(&adr) -#define KWGBEREG_BITS_RESET(adr, val) writel(readl(&adr) & ~(val), &adr) -#define KWGBEREG_BITS_SET(adr, val) writel(readl(&adr) | val, &adr) +#define to_mv_egiga(_d) container_of(_d, struct mv_egiga_device, dev) +#define MV_EGIGA_REG_WR(adr, val) writel(val, &adr) +#define MV_EGIGA_REG_RD(adr) readl(&adr) +#define MV_EGIGA_REG_BITS_RESET(adr, val) writel(readl(&adr) & ~(val), &adr) +#define MV_EGIGA_REG_BITS_SET(adr, val) writel(readl(&adr) | val, &adr)
/* Default port configuration value */ #define PRT_CFG_VAL ( \ - KWGBE_UCAST_MOD_NRML | \ - KWGBE_DFLT_RXQ(RXUQ) | \ - KWGBE_DFLT_RX_ARPQ(RXUQ) | \ - KWGBE_RX_BC_IF_NOT_IP_OR_ARP | \ - KWGBE_RX_BC_IF_IP | \ - KWGBE_RX_BC_IF_ARP | \ - KWGBE_CPTR_TCP_FRMS_DIS | \ - KWGBE_CPTR_UDP_FRMS_DIS | \ - KWGBE_DFLT_RX_TCPQ(RXUQ) | \ - KWGBE_DFLT_RX_UDPQ(RXUQ) | \ - KWGBE_DFLT_RX_BPDUQ(RXUQ)) + MV_EGIGA_UCAST_MOD_NRML | \ + MV_EGIGA_DFLT_RXQ(RXUQ) | \ + MV_EGIGA_DFLT_RX_ARPQ(RXUQ) | \ + MV_EGIGA_RX_BC_IF_NOT_IP_OR_ARP | \ + MV_EGIGA_RX_BC_IF_IP | \ + MV_EGIGA_RX_BC_IF_ARP | \ + MV_EGIGA_CPTR_TCP_FRMS_DIS | \ + MV_EGIGA_CPTR_UDP_FRMS_DIS | \ + MV_EGIGA_DFLT_RX_TCPQ(RXUQ) | \ + MV_EGIGA_DFLT_RX_UDPQ(RXUQ) | \ + MV_EGIGA_DFLT_RX_BPDUQ(RXUQ))
/* Default port extend configuration value */ #define PORT_CFG_EXTEND_VALUE \ - KWGBE_SPAN_BPDU_PACKETS_AS_NORMAL | \ - KWGBE_PARTITION_DIS | \ - KWGBE_TX_CRC_GENERATION_EN + MV_EGIGA_SPAN_BPDU_PACKETS_AS_NORMAL | \ + MV_EGIGA_PARTITION_DIS | \ + MV_EGIGA_TX_CRC_GENERATION_EN
-#define GT_KWGBE_IPG_INT_RX(value) ((value & 0x3fff) << 8) +#define GT_MV_EGIGA_IPG_INT_RX(value) ((value & 0x3fff) << 8)
/* Default sdma control value */ #define PORT_SDMA_CFG_VALUE ( \ - KWGBE_RX_BURST_SIZE_16_64BIT | \ - KWGBE_BLM_RX_NO_SWAP | \ - KWGBE_BLM_TX_NO_SWAP | \ - GT_KWGBE_IPG_INT_RX(RXUQ) | \ - KWGBE_TX_BURST_SIZE_16_64BIT) + MV_EGIGA_RX_BURST_SIZE_16_64BIT | \ + MV_EGIGA_BLM_RX_NO_SWAP | \ + MV_EGIGA_BLM_TX_NO_SWAP | \ + GT_MV_EGIGA_IPG_INT_RX(RXUQ) | \ + MV_EGIGA_TX_BURST_SIZE_16_64BIT)
/* Default port serial control value */ #define PORT_SERIAL_CONTROL_VALUE ( \ - KWGBE_FORCE_LINK_PASS | \ - KWGBE_DIS_AUTO_NEG_FOR_DUPLX | \ - KWGBE_DIS_AUTO_NEG_FOR_FLOW_CTRL | \ - KWGBE_ADV_NO_FLOW_CTRL | \ - KWGBE_FORCE_FC_MODE_NO_PAUSE_DIS_TX | \ - KWGBE_FORCE_BP_MODE_NO_JAM | \ + MV_EGIGA_FORCE_LINK_PASS | \ + MV_EGIGA_DIS_AUTO_NEG_FOR_DUPLX | \ + MV_EGIGA_DIS_AUTO_NEG_FOR_FLOW_CTRL | \ + MV_EGIGA_ADV_NO_FLOW_CTRL | \ + MV_EGIGA_FORCE_FC_MODE_NO_PAUSE_DIS_TX | \ + MV_EGIGA_FORCE_BP_MODE_NO_JAM | \ (1 << 9) /* Reserved bit has to be 1 */ | \ - KWGBE_DO_NOT_FORCE_LINK_FAIL | \ - KWGBE_EN_AUTO_NEG_SPEED_GMII | \ - KWGBE_DTE_ADV_0 | \ - KWGBE_MIIPHY_MAC_MODE | \ - KWGBE_AUTO_NEG_NO_CHANGE | \ - KWGBE_MAX_RX_PACKET_1552BYTE | \ - KWGBE_CLR_EXT_LOOPBACK | \ - KWGBE_SET_FULL_DUPLEX_MODE | \ - KWGBE_DIS_FLOW_CTRL_TX_RX_IN_FULL_DUPLEX) + MV_EGIGA_DO_NOT_FORCE_LINK_FAIL | \ + MV_EGIGA_EN_AUTO_NEG_SPEED_GMII | \ + MV_EGIGA_DTE_ADV_0 | \ + MV_EGIGA_MIIPHY_MAC_MODE | \ + MV_EGIGA_AUTO_NEG_NO_CHANGE | \ + MV_EGIGA_MAX_RX_PACKET_1552BYTE | \ + MV_EGIGA_CLR_EXT_LOOPBACK | \ + MV_EGIGA_SET_FULL_DUPLEX_MODE | \ + MV_EGIGA_DIS_FLOW_CTRL_TX_RX_IN_FULL_DUPLEX)
/* Tx WRR confoguration macros */ #define PORT_MAX_TRAN_UNIT 0x24 /* MTU register (default) 9KByte */ @@ -112,187 +112,187 @@ #define ACCEPT_MAC_ADDR 0 #define REJECT_MAC_ADDR 1 /* Size of a Tx/Rx descriptor used in chain list data structure */ -#define KW_RXQ_DESC_ALIGNED_SIZE \ - (((sizeof(struct kwgbe_rxdesc) / PKTALIGN) + 1) * PKTALIGN) +#define MV_RXQ_DESC_ALIGNED_SIZE \ + (((sizeof(struct mv_egiga_rxdesc) / PKTALIGN) + 1) * PKTALIGN) /* Buffer offset from buffer pointer */ #define RX_BUF_OFFSET 0x2
/* Port serial status reg (PSR) */ -#define KWGBE_INTERFACE_GMII_MII 0 -#define KWGBE_INTERFACE_PCM 1 -#define KWGBE_LINK_IS_DOWN 0 -#define KWGBE_LINK_IS_UP (1 << 1) -#define KWGBE_PORT_AT_HALF_DUPLEX 0 -#define KWGBE_PORT_AT_FULL_DUPLEX (1 << 2) -#define KWGBE_RX_FLOW_CTRL_DISD 0 -#define KWGBE_RX_FLOW_CTRL_ENBALED (1 << 3) -#define KWGBE_GMII_SPEED_100_10 0 -#define KWGBE_GMII_SPEED_1000 (1 << 4) -#define KWGBE_MII_SPEED_10 0 -#define KWGBE_MII_SPEED_100 (1 << 5) -#define KWGBE_NO_TX 0 -#define KWGBE_TX_IN_PROGRESS (1 << 7) -#define KWGBE_BYPASS_NO_ACTIVE 0 -#define KWGBE_BYPASS_ACTIVE (1 << 8) -#define KWGBE_PORT_NOT_AT_PARTN_STT 0 -#define KWGBE_PORT_AT_PARTN_STT (1 << 9) -#define KWGBE_PORT_TX_FIFO_NOT_EMPTY 0 -#define KWGBE_PORT_TX_FIFO_EMPTY (1 << 10) +#define MV_EGIGA_INTERFACE_GMII_MII 0 +#define MV_EGIGA_INTERFACE_PCM 1 +#define MV_EGIGA_LINK_IS_DOWN 0 +#define MV_EGIGA_LINK_IS_UP (1 << 1) +#define MV_EGIGA_PORT_AT_HALF_DUPLEX 0 +#define MV_EGIGA_PORT_AT_FULL_DUPLEX (1 << 2) +#define MV_EGIGA_RX_FLOW_CTRL_DISD 0 +#define MV_EGIGA_RX_FLOW_CTRL_ENBALED (1 << 3) +#define MV_EGIGA_GMII_SPEED_100_10 0 +#define MV_EGIGA_GMII_SPEED_1000 (1 << 4) +#define MV_EGIGA_MII_SPEED_10 0 +#define MV_EGIGA_MII_SPEED_100 (1 << 5) +#define MV_EGIGA_NO_TX 0 +#define MV_EGIGA_TX_IN_PROGRESS (1 << 7) +#define MV_EGIGA_BYPASS_NO_ACTIVE 0 +#define MV_EGIGA_BYPASS_ACTIVE (1 << 8) +#define MV_EGIGA_PORT_NOT_AT_PARTN_STT 0 +#define MV_EGIGA_PORT_AT_PARTN_STT (1 << 9) +#define MV_EGIGA_PORT_TX_FIFO_NOT_EMPTY 0 +#define MV_EGIGA_PORT_TX_FIFO_EMPTY (1 << 10)
/* These macros describes the Port configuration reg (Px_cR) bits */ -#define KWGBE_UCAST_MOD_NRML 0 -#define KWGBE_UNICAST_PROMISCUOUS_MODE 1 -#define KWGBE_DFLT_RXQ(_x) (_x << 1) -#define KWGBE_DFLT_RX_ARPQ(_x) (_x << 4) -#define KWGBE_RX_BC_IF_NOT_IP_OR_ARP 0 -#define KWGBE_REJECT_BC_IF_NOT_IP_OR_ARP (1 << 7) -#define KWGBE_RX_BC_IF_IP 0 -#define KWGBE_REJECT_BC_IF_IP (1 << 8) -#define KWGBE_RX_BC_IF_ARP 0 -#define KWGBE_REJECT_BC_IF_ARP (1 << 9) -#define KWGBE_TX_AM_NO_UPDATE_ERR_SMRY (1 << 12) -#define KWGBE_CPTR_TCP_FRMS_DIS 0 -#define KWGBE_CPTR_TCP_FRMS_EN (1 << 14) -#define KWGBE_CPTR_UDP_FRMS_DIS 0 -#define KWGBE_CPTR_UDP_FRMS_EN (1 << 15) -#define KWGBE_DFLT_RX_TCPQ(_x) (_x << 16) -#define KWGBE_DFLT_RX_UDPQ(_x) (_x << 19) -#define KWGBE_DFLT_RX_BPDUQ(_x) (_x << 22) -#define KWGBE_DFLT_RX_TCP_CHKSUM_MODE (1 << 25) +#define MV_EGIGA_UCAST_MOD_NRML 0 +#define MV_EGIGA_UNICAST_PROMISCUOUS_MODE 1 +#define MV_EGIGA_DFLT_RXQ(_x) (_x << 1) +#define MV_EGIGA_DFLT_RX_ARPQ(_x) (_x << 4) +#define MV_EGIGA_RX_BC_IF_NOT_IP_OR_ARP 0 +#define MV_EGIGA_REJECT_BC_IF_NOT_IP_OR_ARP (1 << 7) +#define MV_EGIGA_RX_BC_IF_IP 0 +#define MV_EGIGA_REJECT_BC_IF_IP (1 << 8) +#define MV_EGIGA_RX_BC_IF_ARP 0 +#define MV_EGIGA_REJECT_BC_IF_ARP (1 << 9) +#define MV_EGIGA_TX_AM_NO_UPDATE_ERR_SMRY (1 << 12) +#define MV_EGIGA_CPTR_TCP_FRMS_DIS 0 +#define MV_EGIGA_CPTR_TCP_FRMS_EN (1 << 14) +#define MV_EGIGA_CPTR_UDP_FRMS_DIS 0 +#define MV_EGIGA_CPTR_UDP_FRMS_EN (1 << 15) +#define MV_EGIGA_DFLT_RX_TCPQ(_x) (_x << 16) +#define MV_EGIGA_DFLT_RX_UDPQ(_x) (_x << 19) +#define MV_EGIGA_DFLT_RX_BPDUQ(_x) (_x << 22) +#define MV_EGIGA_DFLT_RX_TCP_CHKSUM_MODE (1 << 25)
/* These macros describes the Port configuration extend reg (Px_cXR) bits*/ -#define KWGBE_CLASSIFY_EN 1 -#define KWGBE_SPAN_BPDU_PACKETS_AS_NORMAL 0 -#define KWGBE_SPAN_BPDU_PACKETS_TO_RX_Q7 (1 << 1) -#define KWGBE_PARTITION_DIS 0 -#define KWGBE_PARTITION_EN (1 << 2) -#define KWGBE_TX_CRC_GENERATION_EN 0 -#define KWGBE_TX_CRC_GENERATION_DIS (1 << 3) +#define MV_EGIGA_CLASSIFY_EN 1 +#define MV_EGIGA_SPAN_BPDU_PACKETS_AS_NORMAL 0 +#define MV_EGIGA_SPAN_BPDU_PACKETS_TO_RX_Q7 (1 << 1) +#define MV_EGIGA_PARTITION_DIS 0 +#define MV_EGIGA_PARTITION_EN (1 << 2) +#define MV_EGIGA_TX_CRC_GENERATION_EN 0 +#define MV_EGIGA_TX_CRC_GENERATION_DIS (1 << 3)
/* These macros describes the Port Sdma configuration reg (SDCR) bits */ -#define KWGBE_RIFB 1 -#define KWGBE_RX_BURST_SIZE_1_64BIT 0 -#define KWGBE_RX_BURST_SIZE_2_64BIT (1 << 1) -#define KWGBE_RX_BURST_SIZE_4_64BIT (1 << 2) -#define KWGBE_RX_BURST_SIZE_8_64BIT ((1 << 2) | (1 << 1)) -#define KWGBE_RX_BURST_SIZE_16_64BIT (1 << 3) -#define KWGBE_BLM_RX_NO_SWAP (1 << 4) -#define KWGBE_BLM_RX_BYTE_SWAP 0 -#define KWGBE_BLM_TX_NO_SWAP (1 << 5) -#define KWGBE_BLM_TX_BYTE_SWAP 0 -#define KWGBE_DESCRIPTORS_BYTE_SWAP (1 << 6) -#define KWGBE_DESCRIPTORS_NO_SWAP 0 -#define KWGBE_TX_BURST_SIZE_1_64BIT 0 -#define KWGBE_TX_BURST_SIZE_2_64BIT (1 << 22) -#define KWGBE_TX_BURST_SIZE_4_64BIT (1 << 23) -#define KWGBE_TX_BURST_SIZE_8_64BIT ((1 << 23) | (1 << 22)) -#define KWGBE_TX_BURST_SIZE_16_64BIT (1 << 24) +#define MV_EGIGA_RIFB 1 +#define MV_EGIGA_RX_BURST_SIZE_1_64BIT 0 +#define MV_EGIGA_RX_BURST_SIZE_2_64BIT (1 << 1) +#define MV_EGIGA_RX_BURST_SIZE_4_64BIT (1 << 2) +#define MV_EGIGA_RX_BURST_SIZE_8_64BIT ((1 << 2) | (1 << 1)) +#define MV_EGIGA_RX_BURST_SIZE_16_64BIT (1 << 3) +#define MV_EGIGA_BLM_RX_NO_SWAP (1 << 4) +#define MV_EGIGA_BLM_RX_BYTE_SWAP 0 +#define MV_EGIGA_BLM_TX_NO_SWAP (1 << 5) +#define MV_EGIGA_BLM_TX_BYTE_SWAP 0 +#define MV_EGIGA_DESCRIPTORS_BYTE_SWAP (1 << 6) +#define MV_EGIGA_DESCRIPTORS_NO_SWAP 0 +#define MV_EGIGA_TX_BURST_SIZE_1_64BIT 0 +#define MV_EGIGA_TX_BURST_SIZE_2_64BIT (1 << 22) +#define MV_EGIGA_TX_BURST_SIZE_4_64BIT (1 << 23) +#define MV_EGIGA_TX_BURST_SIZE_8_64BIT ((1 << 23) | (1 << 22)) +#define MV_EGIGA_TX_BURST_SIZE_16_64BIT (1 << 24)
/* These macros describes the Port serial control reg (PSCR) bits */ -#define KWGBE_SERIAL_PORT_DIS 0 -#define KWGBE_SERIAL_PORT_EN 1 -#define KWGBE_FORCE_LINK_PASS (1 << 1) -#define KWGBE_DO_NOT_FORCE_LINK_PASS 0 -#define KWGBE_EN_AUTO_NEG_FOR_DUPLX 0 -#define KWGBE_DIS_AUTO_NEG_FOR_DUPLX (1 << 2) -#define KWGBE_EN_AUTO_NEG_FOR_FLOW_CTRL 0 -#define KWGBE_DIS_AUTO_NEG_FOR_FLOW_CTRL (1 << 3) -#define KWGBE_ADV_NO_FLOW_CTRL 0 -#define KWGBE_ADV_SYMMETRIC_FLOW_CTRL (1 << 4) -#define KWGBE_FORCE_FC_MODE_NO_PAUSE_DIS_TX 0 -#define KWGBE_FORCE_FC_MODE_TX_PAUSE_DIS (1 << 5) -#define KWGBE_FORCE_BP_MODE_NO_JAM 0 -#define KWGBE_FORCE_BP_MODE_JAM_TX (1 << 7) -#define KWGBE_FORCE_BP_MODE_JAM_TX_ON_RX_ERR (1 << 8) -#define KWGBE_FORCE_LINK_FAIL 0 -#define KWGBE_DO_NOT_FORCE_LINK_FAIL (1 << 10) -#define KWGBE_DIS_AUTO_NEG_SPEED_GMII (1 << 13) -#define KWGBE_EN_AUTO_NEG_SPEED_GMII 0 -#define KWGBE_DTE_ADV_0 0 -#define KWGBE_DTE_ADV_1 (1 << 14) -#define KWGBE_MIIPHY_MAC_MODE 0 -#define KWGBE_MIIPHY_PHY_MODE (1 << 15) -#define KWGBE_AUTO_NEG_NO_CHANGE 0 -#define KWGBE_RESTART_AUTO_NEG (1 << 16) -#define KWGBE_MAX_RX_PACKET_1518BYTE 0 -#define KWGBE_MAX_RX_PACKET_1522BYTE (1 << 17) -#define KWGBE_MAX_RX_PACKET_1552BYTE (1 << 18) -#define KWGBE_MAX_RX_PACKET_9022BYTE ((1 << 18) | (1 << 17)) -#define KWGBE_MAX_RX_PACKET_9192BYTE (1 << 19) -#define KWGBE_MAX_RX_PACKET_9700BYTE ((1 << 19) | (1 << 17)) -#define KWGBE_SET_EXT_LOOPBACK (1 << 20) -#define KWGBE_CLR_EXT_LOOPBACK 0 -#define KWGBE_SET_FULL_DUPLEX_MODE (1 << 21) -#define KWGBE_SET_HALF_DUPLEX_MODE 0 -#define KWGBE_EN_FLOW_CTRL_TX_RX_IN_FULL_DUPLEX (1 << 22) -#define KWGBE_DIS_FLOW_CTRL_TX_RX_IN_FULL_DUPLEX 0 -#define KWGBE_SET_GMII_SPEED_TO_10_100 0 -#define KWGBE_SET_GMII_SPEED_TO_1000 (1 << 23) -#define KWGBE_SET_MII_SPEED_TO_10 0 -#define KWGBE_SET_MII_SPEED_TO_100 (1 << 24) +#define MV_EGIGA_SERIAL_PORT_DIS 0 +#define MV_EGIGA_SERIAL_PORT_EN 1 +#define MV_EGIGA_FORCE_LINK_PASS (1 << 1) +#define MV_EGIGA_DO_NOT_FORCE_LINK_PASS 0 +#define MV_EGIGA_EN_AUTO_NEG_FOR_DUPLX 0 +#define MV_EGIGA_DIS_AUTO_NEG_FOR_DUPLX (1 << 2) +#define MV_EGIGA_EN_AUTO_NEG_FOR_FLOW_CTRL 0 +#define MV_EGIGA_DIS_AUTO_NEG_FOR_FLOW_CTRL (1 << 3) +#define MV_EGIGA_ADV_NO_FLOW_CTRL 0 +#define MV_EGIGA_ADV_SYMMETRIC_FLOW_CTRL (1 << 4) +#define MV_EGIGA_FORCE_FC_MODE_NO_PAUSE_DIS_TX 0 +#define MV_EGIGA_FORCE_FC_MODE_TX_PAUSE_DIS (1 << 5) +#define MV_EGIGA_FORCE_BP_MODE_NO_JAM 0 +#define MV_EGIGA_FORCE_BP_MODE_JAM_TX (1 << 7) +#define MV_EGIGA_FORCE_BP_MODE_JAM_TX_ON_RX_ERR (1 << 8) +#define MV_EGIGA_FORCE_LINK_FAIL 0 +#define MV_EGIGA_DO_NOT_FORCE_LINK_FAIL (1 << 10) +#define MV_EGIGA_DIS_AUTO_NEG_SPEED_GMII (1 << 13) +#define MV_EGIGA_EN_AUTO_NEG_SPEED_GMII 0 +#define MV_EGIGA_DTE_ADV_0 0 +#define MV_EGIGA_DTE_ADV_1 (1 << 14) +#define MV_EGIGA_MIIPHY_MAC_MODE 0 +#define MV_EGIGA_MIIPHY_PHY_MODE (1 << 15) +#define MV_EGIGA_AUTO_NEG_NO_CHANGE 0 +#define MV_EGIGA_RESTART_AUTO_NEG (1 << 16) +#define MV_EGIGA_MAX_RX_PACKET_1518BYTE 0 +#define MV_EGIGA_MAX_RX_PACKET_1522BYTE (1 << 17) +#define MV_EGIGA_MAX_RX_PACKET_1552BYTE (1 << 18) +#define MV_EGIGA_MAX_RX_PACKET_9022BYTE ((1 << 18) | (1 << 17)) +#define MV_EGIGA_MAX_RX_PACKET_9192BYTE (1 << 19) +#define MV_EGIGA_MAX_RX_PACKET_9700BYTE ((1 << 19) | (1 << 17)) +#define MV_EGIGA_SET_EXT_LOOPBACK (1 << 20) +#define MV_EGIGA_CLR_EXT_LOOPBACK 0 +#define MV_EGIGA_SET_FULL_DUPLEX_MODE (1 << 21) +#define MV_EGIGA_SET_HALF_DUPLEX_MODE 0 +#define MV_EGIGA_EN_FLOW_CTRL_TX_RX_IN_FULL_DUPLEX (1 << 22) +#define MV_EGIGA_DIS_FLOW_CTRL_TX_RX_IN_FULL_DUPLEX 0 +#define MV_EGIGA_SET_GMII_SPEED_TO_10_100 0 +#define MV_EGIGA_SET_GMII_SPEED_TO_1000 (1 << 23) +#define MV_EGIGA_SET_MII_SPEED_TO_10 0 +#define MV_EGIGA_SET_MII_SPEED_TO_100 (1 << 24)
/* SMI register fields */ -#define KWGBE_PHY_SMI_TIMEOUT 10000 -#define KWGBE_PHY_SMI_DATA_OFFS 0 /* Data */ -#define KWGBE_PHY_SMI_DATA_MASK (0xffff << KWGBE_PHY_SMI_DATA_OFFS) -#define KWGBE_PHY_SMI_DEV_ADDR_OFFS 16 /* PHY device address */ -#define KWGBE_PHY_SMI_DEV_ADDR_MASK (PHYADR_MASK << KWGBE_PHY_SMI_DEV_ADDR_OFFS) -#define KWGBE_SMI_REG_ADDR_OFFS 21 /* PHY device reg addr */ -#define KWGBE_SMI_REG_ADDR_MASK (PHYADR_MASK << KWGBE_SMI_REG_ADDR_OFFS) -#define KWGBE_PHY_SMI_OPCODE_OFFS 26 /* Write/Read opcode */ -#define KWGBE_PHY_SMI_OPCODE_MASK (3 << KWGBE_PHY_SMI_OPCODE_OFFS) -#define KWGBE_PHY_SMI_OPCODE_WRITE (0 << KWGBE_PHY_SMI_OPCODE_OFFS) -#define KWGBE_PHY_SMI_OPCODE_READ (1 << KWGBE_PHY_SMI_OPCODE_OFFS) -#define KWGBE_PHY_SMI_READ_VALID_MASK (1 << 27) /* Read Valid */ -#define KWGBE_PHY_SMI_BUSY_MASK (1 << 28) /* Busy */ +#define MV_EGIGA_PHY_SMI_TIMEOUT 10000 +#define MV_EGIGA_PHY_SMI_DATA_OFFS 0 /* Data */ +#define MV_EGIGA_PHY_SMI_DATA_MASK (0xffff << MV_EGIGA_PHY_SMI_DATA_OFFS) +#define MV_EGIGA_PHY_SMI_DEV_ADDR_OFFS 16 /* PHY device address */ +#define MV_EGIGA_PHY_SMI_DEV_ADDR_MASK (PHYADR_MASK << MV_EGIGA_PHY_SMI_DEV_ADDR_OFFS) +#define MV_EGIGA_SMI_REG_ADDR_OFFS 21 /* PHY device reg addr */ +#define MV_EGIGA_SMI_REG_ADDR_MASK (PHYADR_MASK << MV_EGIGA_SMI_REG_ADDR_OFFS) +#define MV_EGIGA_PHY_SMI_OPCODE_OFFS 26 /* Write/Read opcode */ +#define MV_EGIGA_PHY_SMI_OPCODE_MASK (3 << MV_EGIGA_PHY_SMI_OPCODE_OFFS) +#define MV_EGIGA_PHY_SMI_OPCODE_WRITE (0 << MV_EGIGA_PHY_SMI_OPCODE_OFFS) +#define MV_EGIGA_PHY_SMI_OPCODE_READ (1 << MV_EGIGA_PHY_SMI_OPCODE_OFFS) +#define MV_EGIGA_PHY_SMI_READ_VALID_MASK (1 << 27) /* Read Valid */ +#define MV_EGIGA_PHY_SMI_BUSY_MASK (1 << 28) /* Busy */
/* SDMA command status fields macros */ /* Tx & Rx descriptors status */ -#define KWGBE_ERROR_SUMMARY 1 +#define MV_EGIGA_ERROR_SUMMARY 1 /* Tx & Rx descriptors command */ -#define KWGBE_BUFFER_OWNED_BY_DMA (1 << 31) +#define MV_EGIGA_BUFFER_OWNED_BY_DMA (1 << 31) /* Tx descriptors status */ -#define KWGBE_LC_ERROR 0 -#define KWGBE_UR_ERROR (1 << 1) -#define KWGBE_RL_ERROR (1 << 2) -#define KWGBE_LLC_SNAP_FORMAT (1 << 9) -#define KWGBE_TX_LAST_FRAME (1 << 20) +#define MV_EGIGA_LC_ERROR 0 +#define MV_EGIGA_UR_ERROR (1 << 1) +#define MV_EGIGA_RL_ERROR (1 << 2) +#define MV_EGIGA_LLC_SNAP_FORMAT (1 << 9) +#define MV_EGIGA_TX_LAST_FRAME (1 << 20)
/* Rx descriptors status */ -#define KWGBE_CRC_ERROR 0 -#define KWGBE_OVERRUN_ERROR (1 << 1) -#define KWGBE_MAX_FRAME_LENGTH_ERROR (1 << 2) -#define KWGBE_RESOURCE_ERROR ((1 << 2) | (1 << 1)) -#define KWGBE_VLAN_TAGGED (1 << 19) -#define KWGBE_BPDU_FRAME (1 << 20) -#define KWGBE_TCP_FRAME_OVER_IP_V_4 0 -#define KWGBE_UDP_FRAME_OVER_IP_V_4 (1 << 21) -#define KWGBE_OTHER_FRAME_TYPE (1 << 22) -#define KWGBE_LAYER_2_IS_KWGBE_V_2 (1 << 23) -#define KWGBE_FRAME_TYPE_IP_V_4 (1 << 24) -#define KWGBE_FRAME_HEADER_OK (1 << 25) -#define KWGBE_RX_LAST_DESC (1 << 26) -#define KWGBE_RX_FIRST_DESC (1 << 27) -#define KWGBE_UNKNOWN_DESTINATION_ADDR (1 << 28) -#define KWGBE_RX_EN_INTERRUPT (1 << 29) -#define KWGBE_LAYER_4_CHECKSUM_OK (1 << 30) +#define MV_EGIGA_CRC_ERROR 0 +#define MV_EGIGA_OVERRUN_ERROR (1 << 1) +#define MV_EGIGA_MAX_FRAME_LENGTH_ERROR (1 << 2) +#define MV_EGIGA_RESOURCE_ERROR ((1 << 2) | (1 << 1)) +#define MV_EGIGA_VLAN_TAGGED (1 << 19) +#define MV_EGIGA_BPDU_FRAME (1 << 20) +#define MV_EGIGA_TCP_FRAME_OVER_IP_V_4 0 +#define MV_EGIGA_UDP_FRAME_OVER_IP_V_4 (1 << 21) +#define MV_EGIGA_OTHER_FRAME_TYPE (1 << 22) +#define MV_EGIGA_LAYER_2_IS_MV_EGIGA_V_2 (1 << 23) +#define MV_EGIGA_FRAME_TYPE_IP_V_4 (1 << 24) +#define MV_EGIGA_FRAME_HEADER_OK (1 << 25) +#define MV_EGIGA_RX_LAST_DESC (1 << 26) +#define MV_EGIGA_RX_FIRST_DESC (1 << 27) +#define MV_EGIGA_UNKNOWN_DESTINATION_ADDR (1 << 28) +#define MV_EGIGA_RX_EN_INTERRUPT (1 << 29) +#define MV_EGIGA_LAYER_4_CHECKSUM_OK (1 << 30)
/* Rx descriptors byte count */ -#define KWGBE_FRAME_FRAGMENTED (1 << 2) +#define MV_EGIGA_FRAME_FRAGMENTED (1 << 2)
/* Tx descriptors command */ -#define KWGBE_LAYER_4_CHECKSUM_FIRST_DESC (1 << 10) -#define KWGBE_FRAME_SET_TO_VLAN (1 << 15) -#define KWGBE_TCP_FRAME 0 -#define KWGBE_UDP_FRAME (1 << 16) -#define KWGBE_GEN_TCP_UDP_CHECKSUM (1 << 17) -#define KWGBE_GEN_IP_V_4_CHECKSUM (1 << 18) -#define KWGBE_ZERO_PADDING (1 << 19) -#define KWGBE_TX_LAST_DESC (1 << 20) -#define KWGBE_TX_FIRST_DESC (1 << 21) -#define KWGBE_GEN_CRC (1 << 22) -#define KWGBE_TX_EN_INTERRUPT (1 << 23) -#define KWGBE_AUTO_MODE (1 << 30) +#define MV_EGIGA_LAYER_4_CHECKSUM_FIRST_DESC (1 << 10) +#define MV_EGIGA_FRAME_SET_TO_VLAN (1 << 15) +#define MV_EGIGA_TCP_FRAME 0 +#define MV_EGIGA_UDP_FRAME (1 << 16) +#define MV_EGIGA_GEN_TCP_UDP_CHECKSUM (1 << 17) +#define MV_EGIGA_GEN_IP_V_4_CHECKSUM (1 << 18) +#define MV_EGIGA_ZERO_PADDING (1 << 19) +#define MV_EGIGA_TX_LAST_DESC (1 << 20) +#define MV_EGIGA_TX_FIRST_DESC (1 << 21) +#define MV_EGIGA_GEN_CRC (1 << 22) +#define MV_EGIGA_TX_EN_INTERRUPT (1 << 23) +#define MV_EGIGA_AUTO_MODE (1 << 30)
/* Address decode parameters */ /* Ethernet Base Address Register bits */ @@ -341,24 +341,24 @@ #define EWIN_ACCESS_FULL ((1 << 1) | 1)
/* structures represents Controller registers */ -struct kwgbe_barsz { +struct mv_egiga_barsz { u32 bar; u32 size; };
-struct kwgbe_rxcdp { - struct kwgbe_rxdesc *rxcdp; +struct mv_egiga_rxcdp { + struct mv_egiga_rxdesc *rxcdp; u32 rxcdp_pad[3]; };
-struct kwgbe_tqx { +struct mv_egiga_tqx { u32 qxttbc; u32 tqxtbc; u32 tqxac; u32 tqxpad; };
-struct kwgbe_registers { +struct mv_egiga_registers { u32 phyadr; u32 smi; u32 euda; @@ -372,7 +372,7 @@ struct kwgbe_registers { u8 pad3[0x0b0 - 0x098 - 4]; u32 euc; u8 pad3a[0x200 - 0x0b0 - 4]; - struct kwgbe_barsz barsz[6]; + struct mv_egiga_barsz barsz[6]; u8 pad4[0x280 - 0x22c - 4]; u32 ha_remap[4]; u32 bare; @@ -417,14 +417,14 @@ struct kwgbe_registers { u32 pmtu; u32 pmtbs; u8 pad14[0x60c - 0x4ec - 4]; - struct kwgbe_rxcdp rxcdp[7]; - struct kwgbe_rxdesc *rxcdp7; + struct mv_egiga_rxcdp rxcdp[7]; + struct mv_egiga_rxdesc *rxcdp7; u32 rqc; - struct kwgbe_txdesc *tcsdp; + struct mv_egiga_txdesc *tcsdp; u8 pad15[0x6c0 - 0x684 - 4]; - struct kwgbe_txdesc *tcqdp[8]; + struct mv_egiga_txdesc *tcqdp[8]; u8 pad16[0x700 - 0x6dc - 4]; - struct kwgbe_tqx tqx[8]; + struct mv_egiga_tqx tqx[8]; u32 pttbc; u8 pad17[0x7a8 - 0x780 - 4]; u32 tqxipg0; @@ -447,26 +447,26 @@ struct kwgbe_registers { };
/* structures/enums needed by driver */ -enum kwgbe_adrwin { - KWGBE_WIN0, - KWGBE_WIN1, - KWGBE_WIN2, - KWGBE_WIN3, - KWGBE_WIN4, - KWGBE_WIN5 +enum mv_egiga_adrwin { + MV_EGIGA_WIN0, + MV_EGIGA_WIN1, + MV_EGIGA_WIN2, + MV_EGIGA_WIN3, + MV_EGIGA_WIN4, + MV_EGIGA_WIN5 };
-enum kwgbe_target { - KWGBE_TARGET_DRAM, - KWGBE_TARGET_DEV, - KWGBE_TARGET_CBS, - KWGBE_TARGET_PCI0, - KWGBE_TARGET_PCI1 +enum mv_egiga_target { + MV_EGIGA_TARGET_DRAM, + MV_EGIGA_TARGET_DEV, + MV_EGIGA_TARGET_CBS, + MV_EGIGA_TARGET_PCI0, + MV_EGIGA_TARGET_PCI1 };
-struct kwgbe_winparam { - enum kwgbe_adrwin win; /* Window number */ - enum kwgbe_target target; /* System targets */ +struct mv_egiga_winparam { + enum mv_egiga_adrwin win; /* Window number */ + enum mv_egiga_target target; /* System targets */ u16 attrib; /* BAR attrib. See above macros */ u32 base_addr; /* Window base address in u32 form */ u32 high_addr; /* Window high address in u32 form */ @@ -475,29 +475,29 @@ struct kwgbe_winparam { u16 access_ctrl; /*Access ctrl register. see above macros */ };
-struct kwgbe_rxdesc { +struct mv_egiga_rxdesc { u32 cmd_sts; /* Descriptor command status */ u16 buf_size; /* Buffer size */ u16 byte_cnt; /* Descriptor buffer byte count */ u8 *buf_ptr; /* Descriptor buffer pointer */ - struct kwgbe_rxdesc *nxtdesc_p; /* Next descriptor pointer */ + struct mv_egiga_rxdesc *nxtdesc_p; /* Next descriptor pointer */ };
-struct kwgbe_txdesc { +struct mv_egiga_txdesc { u32 cmd_sts; /* Descriptor command status */ u16 l4i_chk; /* CPU provided TCP Checksum */ u16 byte_cnt; /* Descriptor buffer byte count */ u8 *buf_ptr; /* Descriptor buffer ptr */ - struct kwgbe_txdesc *nxtdesc_p; /* Next descriptor ptr */ + struct mv_egiga_txdesc *nxtdesc_p; /* Next descriptor ptr */ };
/* port device data struct */ -struct kwgbe_device { +struct mv_egiga_device { struct eth_device dev; - struct kwgbe_registers *regs; - struct kwgbe_txdesc *p_txdesc; - struct kwgbe_rxdesc *p_rxdesc; - struct kwgbe_rxdesc *p_rxdesc_curr; + struct mv_egiga_registers *regs; + struct mv_egiga_txdesc *p_txdesc; + struct mv_egiga_rxdesc *p_rxdesc; + struct mv_egiga_rxdesc *p_rxdesc_curr; u8 *p_rxbuf; u8 *p_aligned_txbuf; }; diff --git a/include/configs/guruplug.h b/include/configs/guruplug.h index 2fbc6ad..f933017 100644 --- a/include/configs/guruplug.h +++ b/include/configs/guruplug.h @@ -172,9 +172,9 @@ #define CONFIG_NET_MULTI /* specify more that one ports available */ #define CONFIG_MII /* expose smi ove miiphy interface */ #define CONFIG_CMD_MII -#define CONFIG_KIRKWOOD_EGIGA /* Enable kirkwood Gbe Controller Driver */ +#define CONFIG_MV_EGIGA /* Enable Marvell Gbe Controller Driver */ #define CONFIG_SYS_FAULT_ECHO_LINK_DOWN /* detect link using phy */ -#define CONFIG_KIRKWOOD_EGIGA_PORTS {1,1} /* enable both ports */ +#define CONFIG_MV_EGIGA_PORTS {1,1} /* enable both ports */ #define CONFIG_PHY_BASE_ADR 0 #define CONFIG_ENV_OVERWRITE /* ethaddr can be reprogrammed */ #define CONFIG_RESET_PHY_R /* use reset_phy() to init mv88e1121 PHY */ diff --git a/include/configs/km_arm.h b/include/configs/km_arm.h index a928c2c..ec7d9c5 100644 --- a/include/configs/km_arm.h +++ b/include/configs/km_arm.h @@ -127,9 +127,9 @@ #define CONFIG_NETCONSOLE /* include NetConsole support */ #define CONFIG_NET_MULTI /* specify more that one ports available */ #define CONFIG_MII /* expose smi ove miiphy interface */ -#define CONFIG_KIRKWOOD_EGIGA /* Enable kirkwood Gbe Controller Driver */ +#define CONFIG_MV_EGIGA /* Enable Marvell Gbe Controller Driver */ #define CONFIG_SYS_FAULT_ECHO_LINK_DOWN /* detect link using phy */ -#define CONFIG_KIRKWOOD_EGIGA_PORTS {1,0} /* enable port 0 only */ +#define CONFIG_MV_EGIGA_PORTS {1,0} /* enable port 0 only */ #define CONFIG_PHY_BASE_ADR 0 #define CONFIG_ENV_OVERWRITE /* ethaddr can be reprogrammed */ #define CONFIG_RESET_PHY_R /* use reset_phy() to init 88E1118 PHY */ diff --git a/include/configs/mv88f6281gtw_ge.h b/include/configs/mv88f6281gtw_ge.h index 96b4d1c..8281d49 100644 --- a/include/configs/mv88f6281gtw_ge.h +++ b/include/configs/mv88f6281gtw_ge.h @@ -172,9 +172,9 @@ #define CONFIG_NETCONSOLE /* include NetConsole support */ #define CONFIG_NET_MULTI /* specify more that one ports available */ #define CONFIG_MII /* expose smi ove miiphy interface */ -#define CONFIG_KIRKWOOD_EGIGA /* Enable kirkwood Gbe Controller Driver */ +#define CONFIG_MV_EGIGA /* Enable Marvell Gbe Controller Driver */ #define CONFIG_SYS_FAULT_ECHO_LINK_DOWN /* detect link using phy */ -#define CONFIG_KIRKWOOD_EGIGA_PORTS {1,0} /* enable port 0 only */ +#define CONFIG_MV_EGIGA_PORTS {1,0} /* enable port 0 only */ #define CONFIG_ENV_OVERWRITE /* ethaddr can be reprogrammed */ #endif /* CONFIG_CMD_NET */
diff --git a/include/configs/openrd_base.h b/include/configs/openrd_base.h index d2f4502..03ee2ad 100644 --- a/include/configs/openrd_base.h +++ b/include/configs/openrd_base.h @@ -183,9 +183,9 @@ #define CONFIG_NETCONSOLE /* include NetConsole support */ #define CONFIG_NET_MULTI /* specify more that one ports available */ #define CONFIG_MII /* expose smi ove miiphy interface */ -#define CONFIG_KIRKWOOD_EGIGA /* Enable kirkwood Gbe Controller Driver */ +#define CONFIG_MV_EGIGA /* Enable Marvell Gbe Controller Driver */ #define CONFIG_SYS_FAULT_ECHO_LINK_DOWN /* detect link using phy */ -#define CONFIG_KIRKWOOD_EGIGA_PORTS {1,0} /* enable port 0 only */ +#define CONFIG_MV_EGIGA_PORTS {1,0} /* enable port 0 only */ #define CONFIG_PHY_BASE_ADR 0x8 #define CONFIG_ENV_OVERWRITE /* ethaddr can be reprogrammed */ #define CONFIG_RESET_PHY_R /* use reset_phy() to init mv8831116 PHY */ diff --git a/include/configs/rd6281a.h b/include/configs/rd6281a.h index 3d8e25c..799f50b 100644 --- a/include/configs/rd6281a.h +++ b/include/configs/rd6281a.h @@ -171,8 +171,8 @@ #define CONFIG_NETCONSOLE /* include NetConsole support */ #define CONFIG_NET_MULTI /* specify more that one ports available */ #define CONFIG_MII /* expose smi ove miiphy interface */ -#define CONFIG_KIRKWOOD_EGIGA /* Enable kirkwood Gbe Controller Driver */ -#define CONFIG_KIRKWOOD_EGIGA_PORTS {1,1} /* enable both ports */ +#define CONFIG_MV_EGIGA /* Enable Marvell Gbe Controller Driver */ +#define CONFIG_MV_EGIGA_PORTS {1,1} /* enable both ports */ #define CONFIG_MV88E61XX_MULTICHIP_ADRMODE #define CONFIG_DIS_AUTO_NEG_SPEED_GMII /*Disable Auto speed negociation */ #define CONFIG_PHY_SPEED _1000BASET /*Force PHYspeed to 1GBPs */ diff --git a/include/configs/sheevaplug.h b/include/configs/sheevaplug.h index e9edc44..40c3f96 100644 --- a/include/configs/sheevaplug.h +++ b/include/configs/sheevaplug.h @@ -174,9 +174,9 @@ #define CONFIG_NETCONSOLE /* include NetConsole support */ #define CONFIG_NET_MULTI /* specify more that one ports available */ #define CONFIG_MII /* expose smi ove miiphy interface */ -#define CONFIG_KIRKWOOD_EGIGA /* Enable kirkwood Gbe Controller Driver */ +#define CONFIG_MV_EGIGA /* Enable Marvell Gbe Controller Driver */ #define CONFIG_SYS_FAULT_ECHO_LINK_DOWN /* detect link using phy */ -#define CONFIG_KIRKWOOD_EGIGA_PORTS {1,0} /* enable port 0 only */ +#define CONFIG_MV_EGIGA_PORTS {1,0} /* enable port 0 only */ #define CONFIG_PHY_BASE_ADR 0 #define CONFIG_ENV_OVERWRITE /* ethaddr can be reprogrammed */ #define CONFIG_RESET_PHY_R /* use reset_phy() to init mv8831116 PHY */ diff --git a/include/netdev.h b/include/netdev.h index 882642a..434848d 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -61,7 +61,6 @@ int ftmac100_initialize(bd_t *bits); int greth_initialize(bd_t *bis); void gt6426x_eth_initialize(bd_t *bis); int inca_switch_initialize(bd_t *bis); -int kirkwood_egiga_initialize(bd_t *bis); int lan91c96_initialize(u8 dev_num, int base_addr); int macb_eth_initialize(int id, void *regs, unsigned int phy_addr); int mcdmafec_initialize(bd_t *bis); @@ -70,6 +69,7 @@ int mpc512x_fec_initialize(bd_t *bis); int mpc5xxx_fec_initialize(bd_t *bis); int mpc8220_fec_initialize(bd_t *bis); int mpc82xx_scc_enet_initialize(bd_t *bis); +int mv_egiga_initialize(bd_t *bis); int natsemi_initialize(bd_t *bis); int npe_initialize(bd_t *bis); int ns8382x_initialize(bd_t *bis);
Add a configuration option to allow SoCs without random generation capability to fill in local MACs with a fixed rather than random value
Signed-off-by: Albert Aribaud albert.aribaud@free.fr --- drivers/net/mv_egiga.c | 10 +++++++++- 1 files changed, 9 insertions(+), 1 deletions(-)
diff --git a/drivers/net/mv_egiga.c b/drivers/net/mv_egiga.c index 4fecf1e..e8315fa 100644 --- a/drivers/net/mv_egiga.c +++ b/drivers/net/mv_egiga.c @@ -705,13 +705,21 @@ int mv_egiga_initialize(bd_t * bis) }
while (!eth_getenv_enetaddr(s, dev->enetaddr)) { - /* Generate Random Private MAC addr if not set */ + /* Generate Private MAC addr if not set */ dev->enetaddr[0] = 0x02; dev->enetaddr[1] = 0x50; dev->enetaddr[2] = 0x43; +#if defined (CONFIG_SKIP_LOCAL_MAC_RANDOMIZATION) + /* Generate fixed lower MAC half using devnum */ + dev->enetaddr[3] = 0; + dev->enetaddr[4] = 0; + dev->enetaddr[5] = devnum; +#else + /* Generate random lower MAC half */ dev->enetaddr[3] = get_random_hex(); dev->enetaddr[4] = get_random_hex(); dev->enetaddr[5] = get_random_hex(); +#endif eth_setenv_enetaddr(s, dev->enetaddr); }
Add definitions and initialization in orion5x for mv_egiga. Add orion5x in mv_egiga SoC includes.
Signed-off-by: Albert Aribaud albert.aribaud@free.fr --- arch/arm/cpu/arm926ejs/orion5x/cpu.c | 8 ++++++++ arch/arm/include/asm/arch-orion5x/orion5x.h | 5 +++++ drivers/net/mv_egiga.c | 2 ++ 3 files changed, 15 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/orion5x/cpu.c b/arch/arm/cpu/arm926ejs/orion5x/cpu.c index 03c6d06..fc9455e 100644 --- a/arch/arm/cpu/arm926ejs/orion5x/cpu.c +++ b/arch/arm/cpu/arm926ejs/orion5x/cpu.c @@ -268,3 +268,11 @@ int arch_misc_init(void) return 0; } #endif /* CONFIG_ARCH_MISC_INIT */ + +#ifdef CONFIG_MV_EGIGA +int cpu_eth_init(bd_t *bis) +{ + mv_egiga_initialize(bis); + return 0; +} +#endif diff --git a/arch/arm/include/asm/arch-orion5x/orion5x.h b/arch/arm/include/asm/arch-orion5x/orion5x.h index 4008c84..6783b74 100644 --- a/arch/arm/include/asm/arch-orion5x/orion5x.h +++ b/arch/arm/include/asm/arch-orion5x/orion5x.h @@ -56,6 +56,11 @@ #define ORION5X_USB20_PORT1_BASE (ORION5X_REGISTER(0xA0000)) #define ORION5X_EGIGA_BASE (ORION5X_REGISTER(0x72000))
+/* Oron5x has one Marvell egiga controller */ +#if defined (CONFIG_MV_EGIGA) +#define MV_EGIGA0_BASE ORION5X_EGIGA_BASE +#endif + #define CONFIG_MAX_RAM_BANK_SIZE (64*1024*1024)
/* include here SoC variants. 5181, 5281, 6183 should go here when diff --git a/drivers/net/mv_egiga.c b/drivers/net/mv_egiga.c index e8315fa..3401f64 100644 --- a/drivers/net/mv_egiga.c +++ b/drivers/net/mv_egiga.c @@ -38,6 +38,8 @@
#if defined (CONFIG_KIRKWOOD) #include <asm/arch/kirkwood.h> +#elif defined (CONFIG_ORION5X) +#include <asm/arch/orion5x.h> #endif
Add edminiv2 board support for mv_egiga. Add edminiv2 config to enable mv_egiga.
Signed-off-by: Albert Aribaud albert.aribaud@free.fr --- board/LaCie/edminiv2/edminiv2.c | 36 ++++++++++++++++++++++++++++++++++ board/LaCie/edminiv2/edminiv2.h | 41 +++++++++++++++++++++++++++++++++++++++ include/configs/edminiv2.h | 23 ++++++++++++++++----- 3 files changed, 94 insertions(+), 6 deletions(-) create mode 100644 board/LaCie/edminiv2/edminiv2.h
diff --git a/board/LaCie/edminiv2/edminiv2.c b/board/LaCie/edminiv2/edminiv2.c index 54c0ffe..d46ee4a 100644 --- a/board/LaCie/edminiv2/edminiv2.c +++ b/board/LaCie/edminiv2/edminiv2.c @@ -27,6 +27,7 @@ #include <common.h> #include <miiphy.h> #include <asm/arch/orion5x.h> +#include "edminiv2.h"
@@ -90,3 +91,38 @@ int board_init(void)
return 0; } + +#if defined (CONFIG_CMD_NET) && defined (CONFIG_RESET_PHY_R) +/* Configure and enable MV88E1116 PHY */ +void reset_phy(void) +{ + u16 reg; + u16 devadr; + char *name = "egiga0"; + + if (miiphy_set_current_dev(name)) + return; + + /* command to read PHY dev address */ + if (miiphy_read(name, 0xEE, 0xEE, (u16 *) &devadr)) { + printf("Err..%s could not read PHY dev address\n", + __FUNCTION__); + return; + } + + /* + * Enable RGMII delay on Tx and Rx for CPU port + * Ref: sec 4.7.2 of chip datasheet + */ + miiphy_write(name, devadr, MV88E1116_PGADR_REG, 2); + miiphy_read(name, devadr, MV88E1116_MAC_CTRL_REG, ®); + reg |= (MV88E1116_RGMII_RXTM_CTRL | MV88E1116_RGMII_TXTM_CTRL); + miiphy_write(name, devadr, MV88E1116_MAC_CTRL_REG, reg); + miiphy_write(name, devadr, MV88E1116_PGADR_REG, 0); + + /* reset the phy */ + miiphy_reset(name, devadr); + + printf("88E1116 Initialized on %s\n", name); +} +#endif /* CONFIG_RESET_PHY_R */ diff --git a/board/LaCie/edminiv2/edminiv2.h b/board/LaCie/edminiv2/edminiv2.h new file mode 100644 index 0000000..88e62b2 --- /dev/null +++ b/board/LaCie/edminiv2/edminiv2.h @@ -0,0 +1,41 @@ +/* + * (C) Copyright 2009 + * Net Insight <www.netinsight.net> + * Written-by: Simon Kagstrom simon.kagstrom@netinsight.net + * + * Based on sheevaplug.h: + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef __EDMINIV2_BASE_H +#define __EDMINIV2_BASE_H + +/* PHY related */ +#define MV88E1116_LED_FCTRL_REG 10 +#define MV88E1116_CPRSP_CR3_REG 21 +#define MV88E1116_MAC_CTRL_REG 21 +#define MV88E1116_PGADR_REG 22 +#define MV88E1116_RGMII_TXTM_CTRL (1 << 4) +#define MV88E1116_RGMII_RXTM_CTRL (1 << 5) + +#endif /* __EDMINIV2_BASE_H */ diff --git a/include/configs/edminiv2.h b/include/configs/edminiv2.h index c3d95a0..458e313 100644 --- a/include/configs/edminiv2.h +++ b/include/configs/edminiv2.h @@ -110,6 +110,15 @@ #define CONFIG_SYS_FLASH_SECTSZ \ {16384, 8192, 8192, 32768, \ 65536, 65536, 65536, 65536, 65536, 65536, 65536} +/* + * Ethernet + */ + +#define CONFIG_MV_EGIGA /* Enable Marvell egiga Controller Driver */ +#define CONFIG_MV_EGIGA_PORTS {1,0} /* enable port 0 only */ +#define CONFIG_SKIP_LOCAL_MAC_RANDOMIZATION /* don't randomize MAC */ +#define CONFIG_PHY_BASE_ADR 0x8 +#define CONFIG_RESET_PHY_R /* use reset_phy() to init mv8831116 PHY */
/* auto boot */ #define CONFIG_BOOTDELAY 3 /* default enable autoboot */ @@ -131,12 +140,14 @@ * Commands configuration - using default command set for now */ #include <config_cmd_default.h> -/* - * Disabling some default commands for staggered bring-up - */ -#undef CONFIG_CMD_BOOTD /* no bootd since no net */ -#undef CONFIG_CMD_NET /* no net since no eth */ -#undef CONFIG_CMD_NFS /* no NFS since no net */ + +#ifdef CONFIG_CMD_NET +#define CONFIG_NETCONSOLE /* include NetConsole support */ +#define CONFIG_NET_MULTI /* specify more that one ports available */ +#define CONFIG_MII /* expose smi ove miiphy interface */ +#define CONFIG_SYS_FAULT_ECHO_LINK_DOWN /* detect link using phy */ +#define CONFIG_ENV_OVERWRITE /* ethaddr can be reprogrammed */ +#endif
/* * Environment variables configurations
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Albert Aribaud Sent: Sunday, July 11, 2010 1:32 PM To: u-boot@lists.denx.de Subject: [U-Boot] [PATCH V3 5/5] edminiv2: add ethernet support
return 0; }
- u16 reg;
- u16 devadr;
- char *name = "egiga0";
- if (miiphy_set_current_dev(name))
return;
- /* command to read PHY dev address */
- if (miiphy_read(name, 0xEE, 0xEE, (u16 *) &devadr)) {
__FUNCTION__);
return;
- miiphy_write(name, devadr, MV88E1116_PGADR_REG, 2);
- miiphy_read(name, devadr, MV88E1116_MAC_CTRL_REG, ®);
- reg |= (MV88E1116_RGMII_RXTM_CTRL | MV88E1116_RGMII_TXTM_CTRL);
- miiphy_write(name, devadr, MV88E1116_MAC_CTRL_REG, reg);
- miiphy_write(name, devadr, MV88E1116_PGADR_REG, 0);
- /* reset the phy */
- miiphy_reset(name, devadr);
- printf("88E1116 Initialized on %s\n", name);
- (C) Copyright 2009
- Net Insight <www.netinsight.net>
- Written-by: Simon Kagstrom simon.kagstrom@netinsight.net
- Based on sheevaplug.h:
- Marvell Semiconductor <www.marvell.com>
- Written-by: Prafulla Wadaskar prafulla@marvell.com
- project.
- Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston,
- MA 02110-1301 USA
- Ethernet
Pls remove additional space char here
Shift above definition below (inside #ifdef CONFIG_CMD_NET), that makes more sense
- Commands configuration - using default command set for now
- Disabling some default commands for staggered bring-up
- Environment variables configurations
-- 1.6.4.4
Hi Prafulla,
Le 12/07/2010 08:00, Prafulla Wadaskar a écrit :
- Ethernet
Done.
+#define CONFIG_MV_EGIGA /* Enable Marvell egiga [...] +#define CONFIG_RESET_PHY_R /* use reset_phy() to init mv8831116 PHY */
Done--actually replaced "Ethernet" with "Network" in block comment as the whole block is not only about Eth.
Thanks for the feedback.
Any remaining comments on patches 1-4?
Amicalement,
Hi Albert,
On 7/11/2010 11:14 PM, Albert ARIBAUD wrote:
Hi Prafulla,
- Ethernet
Done.
Amicalement,
That should be it. Please post updates as needed.
regards, Ben
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Albert Aribaud Sent: Sunday, July 11, 2010 1:32 PM To: u-boot@lists.denx.de Subject: [U-Boot] [PATCH V3 4/5] mv_egiga: add support for orion5x egiga controller
- mv_egiga_initialize(bis);
You need to move a macro MAX_KWGBE_DEVS from kirkwood_egiga.h to here, and also in kirkwood.h
Ifdef not needed, pls remove
Regards.. Prafulla . .
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Albert Aribaud Sent: Sunday, July 11, 2010 1:32 PM To: u-boot@lists.denx.de Subject: [U-Boot] [PATCH V3 3/5] mv_egiga: CONFIG_SKIP_LOCAL_MAC_RANDOMIZATION
not set */
+#else
This is standalone patch, Pls make this patch independent on the top of current driver version. Acked otherwise
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Albert Aribaud Sent: Sunday, July 11, 2010 1:32 PM To: u-boot@lists.denx.de Subject: [U-Boot] [PATCH V3 2/5] mv_egiga: support SoCs other than kirkwood
Rename all references to kirkwood in mv_egiga symbols throughout the whole codebase.
arch/arm/cpu/arm926ejs/kirkwood/cpu.c | 4 +- arch/arm/include/asm/arch-kirkwood/kirkwood.h | 5 + drivers/net/Makefile | 2 +- drivers/net/mv_egiga.c | 322 +++++++++--------- drivers/net/mv_egiga.h | 466 ++++++++++++------------ include/configs/guruplug.h | 4 +- include/configs/km_arm.h | 4 +- include/configs/mv88f6281gtw_ge.h | 4 +- include/configs/openrd_base.h | 4 +- include/configs/rd6281a.h | 4 +- include/configs/sheevaplug.h | 4 +- include/netdev.h | 2 +- 12 files changed, 418 insertions(+), 407 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/kirkwood/cpu.c b/arch/arm/cpu/arm926ejs/kirkwood/cpu.c index 6fc3902..786ffc6 100644 --- a/arch/arm/cpu/arm926ejs/kirkwood/cpu.c +++ b/arch/arm/cpu/arm926ejs/kirkwood/cpu.c @@ -378,10 +378,10 @@ int arch_misc_init(void) } #endif /* CONFIG_ARCH_MISC_INIT */
-#ifdef CONFIG_KIRKWOOD_EGIGA +#ifdef CONFIG_MV_EGIGA int cpu_eth_init(bd_t *bis) {
- kirkwood_egiga_initialize(bis);
- mv_egiga_initialize(bis); return 0;
} #endif diff --git a/arch/arm/include/asm/arch-kirkwood/kirkwood.h b/arch/arm/include/asm/arch-kirkwood/kirkwood.h index 2470efb..9200605 100644 --- a/arch/arm/include/asm/arch-kirkwood/kirkwood.h +++ b/arch/arm/include/asm/arch-kirkwood/kirkwood.h @@ -60,6 +60,11 @@ #define KW_EGIGA0_BASE (KW_REGISTER(0x72000)) #define KW_EGIGA1_BASE (KW_REGISTER(0x76000))
I think you don't need ifdef here
+#define MV_EGIGA0_BASE KW_EGIGA0_BASE +#define MV_EGIGA1_BASE KW_EGIGA1_BASE +#endif
#if defined (CONFIG_KW88F6281) #include <asm/arch/kw88f6281.h> #elif defined (CONFIG_KW88F6192) diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 1599c26..04f8de0 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -52,7 +52,7 @@ COBJS-$(CONFIG_MACB) += macb.o COBJS-$(CONFIG_MCFFEC) += mcffec.o mcfmii.o COBJS-$(CONFIG_MPC5xxx_FEC) += mpc5xxx_fec.o COBJS-$(CONFIG_MPC512x_FEC) += mpc512x_fec.o -COBJS-$(CONFIG_KIRKWOOD_EGIGA) += mv_egiga.o +COBJS-$(CONFIG_MV_EGIGA) += mv_egiga.o COBJS-$(CONFIG_NATSEMI) += natsemi.o COBJS-$(CONFIG_DRIVER_NE2000) += ne2000.o ne2000_base.o COBJS-$(CONFIG_DRIVER_AX88796L) += ax88796.o ne2000_base.o diff --git a/drivers/net/mv_egiga.c b/drivers/net/mv_egiga.c index b7ecc9d..4fecf1e 100644 --- a/drivers/net/mv_egiga.c +++ b/drivers/net/mv_egiga.c @@ -35,13 +35,17 @@ #include <asm/errno.h> #include <asm/types.h> #include <asm/byteorder.h>
+#if defined (CONFIG_KIRKWOOD) #include <asm/arch/kirkwood.h> +#endif
#include "mv_egiga.h"
DECLARE_GLOBAL_DATA_PTR;
-#define KIRKWOOD_PHY_ADR_REQUEST 0xee -#define KWGBE_SMI_REG (((struct kwgbe_registers *)KW_EGIGA0_BASE)->smi) +#define MV_PHY_ADR_REQUEST 0xee +#define MV_EGIGA_SMI_REG (((struct mv_egiga_registers *)MV_EGIGA0_BASE)->smi)
- smi_reg_read - miiphy_read callback function.
@@ -51,16 +55,16 @@ DECLARE_GLOBAL_DATA_PTR; static int smi_reg_read(char *devname, u8 phy_adr, u8 reg_ofs, u16 * data) { struct eth_device *dev = eth_get_dev_by_name(devname);
- struct mv_egiga_device *dmvegiga = to_mv_egiga(dev);
- struct mv_egiga_registers *regs = dmvegiga->regs;
I suggest to keep name as mvgbe here instead of mv_egiga, 3 additional chars, increases overall code size
u32 smi_reg; u32 timeout;
/* Phyadr read request */
- if (phy_adr == KIRKWOOD_PHY_ADR_REQUEST &&
reg_ofs == KIRKWOOD_PHY_ADR_REQUEST) {
- if (phy_adr == MV_PHY_ADR_REQUEST &&
/* */reg_ofs == MV_PHY_ADR_REQUEST) {
*data = (u16) (KWGBEREG_RD(regs->phyadr) & PHYADR_MASK);
*data = (u16) (MV_EGIGA_REG_RD(regs->phyadr) &
Same here, pls use MVGBEREG instead of MV_EGIGA_REG, 4 extra chars
Pls just replace kw/KW by mv/MV to avoide indentation issues
I think these are the only changes in this patch (i.e. find and replace), are there any other?
Signed-off-by: Albert Aribaudalbert.aribaud@free.fr
- mv_egiga_initialize(bis); return 0; } #endif
- #if defined (CONFIG_KW88F6281) #include<asm/arch/kw88f6281.h> #elif defined (CONFIG_KW88F6192)
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 1599c26..04f8de0 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -52,7 +52,7 @@ COBJS-$(CONFIG_MACB) += macb.o COBJS-$(CONFIG_MCFFEC) += mcffec.o mcfmii.o COBJS-$(CONFIG_MPC5xxx_FEC) += mpc5xxx_fec.o COBJS-$(CONFIG_MPC512x_FEC) += mpc512x_fec.o -COBJS-$(CONFIG_KIRKWOOD_EGIGA) += mv_egiga.o +COBJS-$(CONFIG_MV_EGIGA) += mv_egiga.o COBJS-$(CONFIG_NATSEMI) += natsemi.o COBJS-$(CONFIG_DRIVER_NE2000) += ne2000.o ne2000_base.o COBJS-$(CONFIG_DRIVER_AX88796L) += ax88796.o ne2000_base.o diff --git a/drivers/net/mv_egiga.c b/drivers/net/mv_egiga.c index b7ecc9d..4fecf1e 100644 --- a/drivers/net/mv_egiga.c +++ b/drivers/net/mv_egiga.c @@ -35,13 +35,17 @@ #include<asm/errno.h> #include<asm/types.h> #include<asm/byteorder.h>
+#if defined (CONFIG_KIRKWOOD) #include<asm/arch/kirkwood.h> +#endif
huh? The name is consistent with the rest of his work, and *if* the code really increases in size, I can't imagine that 3 chars really matters...
- if (phy_adr == KIRKWOOD_PHY_ADR_REQUEST&&
- if (phy_adr == MV_PHY_ADR_REQUEST&&
*data = (u16) (KWGBEREG_RD(regs->phyadr)& PHYADR_MASK);
*data = (u16) (MV_EGIGA_REG_RD(regs->phyadr)&
Same comment as above. Clarity is king.
Regards.. Prafulla . . _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
-----Original Message----- From: Ben Warren [mailto:biggerbadderben@gmail.com] Sent: Monday, July 12, 2010 11:54 AM To: Prafulla Wadaskar Cc: Albert Aribaud; u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH V3 2/5] mv_egiga: support SoCs other than kirkwood
...snip...
additional chars, increases overall code size huh? The name is consistent with the rest of his work, and *if* the code really increases in size, I can't imagine that 3 chars really matters...
That's true. But if we can do it why to avoid it? again it helps to keep same indentation (keeping them below 80char size)
I don't think I changed indentation here, and the issue is about line lengths, right?
Initially I chose mv egiga because the file names used egiga while the code used gbe, and I wanted clarity, so I decided to keep only one of egiga and gbe. Now which one I should keep is not really important to me, and a Google search for marvell egiga vs marvell gbe indicates gbe appears much more frequently, so someone looking into this will probably know "GbE" more than "egiga".
I suggest that:
- I switch the file names from mv_egiga to "mvgbe" (to be consistent with Prafulla's comment on mv_sata becoming mvsata), and
- I replace mv_egiga/MV_EGIGA symbols with mvgbe/MVGBE.
That will retain (as much) clarity and uniformity (as egiga does), which is what I think Ben is looking for, and it'll keep name length at a minimum, which should satisfy Prafulla.
Ben, Prafulla (and others as well, of course), do you agree?
Amicalement,
Hi Albert,
I suggest that:
OK with me.
Amicalement,
-- Albert.
regards, Ben
Le 12/07/2010 16:19, Ben Warren a écrit :
I suggest that: - I switch the file names from mv_egiga to "mvgbe" (to be consistent with Prafulla's comment on mv_sata becoming mvsata), and - I replace mv_egiga/MV_EGIGA symbols with mvgbe/MVGBE. That will retain (as much) clarity and uniformity (as egiga does), which is what I think Ben is looking for, and it'll keep name length at a minimum, which should satisfy Prafulla. Ben, Prafulla (and others as well, of course), do you agree?
OK with me.
Thanks Ben. I assume Prafulla will agree too. I'll regenerate a patch set with all changes requested by Prafulla, keeping the symbol-change in a single patch as discussed elsewhere in this thread.
Note that the last patch of the series (edminiv2 support) will only build above the CONFIG_SKIP_LOCAL_MAC_RANDOMIZATION patch that I posted separately.
Amicalement,
Actually the ifdef is intended to make sure these symbols do not get defined uselessly for kirkwood boards that don't have Ethernet support. Granted, their being defined without being used is no big deal.
However the whole thing about the egiga driver supporting one or two ports could be streamlined (e.g., one might define KIRKWOOD_EGIGAn_BASE while not enabling port n in CONFIG_KIRKWOOD_EGIGA_PORTS) and integrate the suggestion about the PHYs that occurred some time ago:
http://lists.denx.de/pipermail/u-boot/2010-June/073138.html
So I'll leave that one to a later patch set.
Amicalement,
Pls break this patch as-
Kirkwood SOC specific
drivers/net/Makefile | 2 +- drivers/net/mv_egiga.c | 322 +++++++++--------- drivers/net/mv_egiga.h | 466 include/netdev.h | 2 +-
Net: driver specific for net repo
Board updates In the same order, so that it is easier to pick them separately by net and Marvell repos.
If I split this patch, it will not build correctly any more.
Amicalement,
Hi Albert,
and Marvell repos.
Usually, these should be split up. In this case, the dependencies are
significant, so just leave it as-is. If Prafulla ACKs, I'll pull the whole group into the net repo.
Amicalement,
Albert.
regards, Ben
-----Original Message----- From: Ben Warren [mailto:biggerbadderben@gmail.com] Sent: Monday, July 12, 2010 7:54 PM To: Albert ARIBAUD Cc: Prafulla Wadaskar; u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH V3 2/5] mv_egiga: support SoCs other than kirkwood
Hi Albert,
On Mon, Jul 12, 2010 at 1:56 AM, Albert ARIBAUD albert.aribaud@free.fr wrote:
Albert Aribaud
Usually, these should be split up. In this case, the dependencies are significant, so just leave it as-is. If Prafulla ACKs, I'll pull the whole group into the net repo.
Ack Hi Ben, its good if you pull entire patch series.
Albert ARIBAUD
Albert Aribaud
Ben Warren
Prafulla Wadaskar
