[U-Boot] [PATCH 0/6] sunxi: update Pine64/A64 DTs
in the wake of the sunxi DM enablement series it became apparent that the current device tree files for the A64 SoC and its board are outdated.
Since Linux v4.10-rc1 there are now basic .dts files for the Allwinner A64 SoC and the Pine64 boards in the mainline kernel. Linux v4.11-rc1 added MMC and USB support. Because our preliminary device trees used in U-Boot differ significantly, let's update our copy with what's in the current Linus' master tree. Since in contrast to U-Boot the kernel still lacks support for Ethernet, we keep our preliminary nodes for that IP, but adjust it slightly to match the new clocks and reset bindings.
As the sun8i-emac driver is actually using the DT for the pinmux setup, we teach it how to cope with the new pinctrl bindings in the first two patches. This is probably becoming somewhat obsolete very soon (with DM GPIO support on the list already), however I consider these two patches as merely fixes for the existing driver to maintain bisectability. It would make sense to merge the new DTs before the DM patches, so we need to have something in place which works meanwhile.
Let me know what you think.
Cheers, Andre.
Andre Przywara (6): sunxi: GPIO: introduce sunxi_gpio_setup_dt_pins() net: sun8i-emac: use new, generic GPIO setup routine sunxi: dts: update sun50i-a64.dtsi from Linux sunxi: dts: update Pine64 .dts sunxi: dts: remove now obsolete pine64-common.dtsi sunxi: dts: add Bananapi M64 .dts
arch/arm/dts/Makefile | 3 +- arch/arm/dts/sun50i-a64-bananapi-m64.dts | 135 +++++++ arch/arm/dts/sun50i-a64-pine64-common.dtsi | 93 ----- arch/arm/dts/sun50i-a64-pine64-plus.dts | 16 +- arch/arm/dts/sun50i-a64-pine64.dts | 72 +++- arch/arm/dts/sun50i-a64.dtsi | 615 +++++++++-------------------- arch/arm/include/asm/arch-sunxi/gpio.h | 4 + arch/arm/mach-sunxi/pinmux.c | 77 ++++ drivers/net/sun8i_emac.c | 38 +- include/dt-bindings/clock/sun50i-a64-ccu.h | 134 +++++++ include/dt-bindings/reset/sun50i-a64-ccu.h | 98 +++++ 11 files changed, 706 insertions(+), 579 deletions(-) create mode 100644 arch/arm/dts/sun50i-a64-bananapi-m64.dts delete mode 100644 arch/arm/dts/sun50i-a64-pine64-common.dtsi create mode 100644 include/dt-bindings/clock/sun50i-a64-ccu.h create mode 100644 include/dt-bindings/reset/sun50i-a64-ccu.h
Instead of hard-coding GPIO pins used for a certain peripheral, we should just use the pinctrl information from the DT. The sun8i-emac driver has some simple implementation of that, so let's just generalize this and move the code into a more common location. On the way we add support for the new, generic pinctrl binding now used by all Allwinner SoCs.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/include/asm/arch-sunxi/gpio.h | 4 ++ arch/arm/mach-sunxi/pinmux.c | 77 ++++++++++++++++++++++++++++++++++ 2 files changed, 81 insertions(+)
diff --git a/arch/arm/include/asm/arch-sunxi/gpio.h b/arch/arm/include/asm/arch-sunxi/gpio.h index 85a4ec3..ba8c661 100644 --- a/arch/arm/include/asm/arch-sunxi/gpio.h +++ b/arch/arm/include/asm/arch-sunxi/gpio.h @@ -239,4 +239,8 @@ int axp_gpio_init(void); static inline int axp_gpio_init(void) { return 0; } #endif
+int sunxi_gpio_parse_pin_name(const char *pin_name); +int sunxi_gpio_setup_dt_pins(const void * volatile fdt_blob, int node, + const char * mux_name, int mux_sel); + #endif /* _SUNXI_GPIO_H */ diff --git a/arch/arm/mach-sunxi/pinmux.c b/arch/arm/mach-sunxi/pinmux.c index b026f78..f1e1e8f 100644 --- a/arch/arm/mach-sunxi/pinmux.c +++ b/arch/arm/mach-sunxi/pinmux.c @@ -9,6 +9,9 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/gpio.h> +#include <fdtdec.h> +#include <fdt_support.h> +#include <dt-bindings/pinctrl/sun4i-a10.h>
void sunxi_gpio_set_cfgbank(struct sunxi_gpio *pio, int bank_offset, u32 val) { @@ -69,3 +72,77 @@ int sunxi_gpio_set_pull(u32 pin, u32 val)
return 0; } + +int sunxi_gpio_parse_pin_name(const char *pin_name) +{ + int pin; + + if (pin_name[0] != 'P') + return -1; + + if (pin_name[1] < 'A' || pin_name[1] > 'Z') + return -1; + + pin = (pin_name[1] - 'A') << 5; + pin += simple_strtol(&pin_name[2], NULL, 10); + + return pin; +} + +int sunxi_gpio_setup_dt_pins(const void * volatile fdt_blob, int node, + const char * mux_name, int mux_sel) +{ + int drive, pull, pin, i; + const char *pin_name; + int offset; + + offset = fdtdec_lookup_phandle(fdt_blob, node, "pinctrl-0"); + if (offset < 0) + return offset; + + drive = fdt_getprop_u32_default_node(fdt_blob, offset, 0, + "drive-strength", 0); + if (drive) { + if (drive <= 10) + drive = SUN4I_PINCTRL_10_MA; + else if (drive <= 20) + drive = SUN4I_PINCTRL_20_MA; + else if (drive <= 30) + drive = SUN4I_PINCTRL_30_MA; + else + drive = SUN4I_PINCTRL_40_MA; + } else { + drive = fdt_getprop_u32_default_node(fdt_blob, offset, 0, + "allwinner,drive", 4); + } + + if (fdt_get_property(fdt_blob, offset, "bias-pull-up", NULL)) + pull = SUN4I_PINCTRL_PULL_UP; + else if (fdt_get_property(fdt_blob, offset, "bias-disable", NULL)) + pull = SUN4I_PINCTRL_NO_PULL; + else if (fdt_get_property(fdt_blob, offset, "bias-pull-down", NULL)) + pull = SUN4I_PINCTRL_PULL_DOWN; + else + pull = fdt_getprop_u32_default_node(fdt_blob, offset, 0, + "allwinner,pull", 0); + + for (i = 0; ; i++) { + pin_name = fdt_stringlist_get(fdt_blob, offset, + "allwinner,pins", i, NULL); + if (!pin_name) { + pin_name = fdt_stringlist_get(fdt_blob, offset, + "pins", i, NULL); + if (!pin_name) + break; + } + pin = sunxi_gpio_parse_pin_name(pin_name); + if (pin < 0) + continue; + + sunxi_gpio_set_cfgpin(pin, mux_sel); + sunxi_gpio_set_drv(pin, drive); + sunxi_gpio_set_pull(pin, pull); + } + + return i; +}
On Mon, Feb 27, 2017 at 8:26 AM, Andre Przywara andre.przywara@arm.com wrote:
int pin;
return -1;
return -1;
return pin;
int offset;
if (offset < 0)
return offset;
if (drive) {
if (drive <= 10)
else
} else {
You should use a different default, something invalid.
else
Same here.
if (!pin_name) {
"pins", i, NULL);
if (!pin_name)
break;
if (pin < 0)
continue;
As the defaults implied by the bindings are to not touch the settings if they aren't specified, as in "whatever the hardware was set to". This applies to both drive strength and bias/pull.
Regards ChenYu
return i;
2.8.2
return 0; }
- int pin;
- if (pin_name[0] != 'P')
return -1;
- if (pin_name[1] < 'A' || pin_name[1] > 'Z')
return -1;
- pin = (pin_name[1] - 'A') << 5;
- pin += simple_strtol(&pin_name[2], NULL, 10);
- return pin;
That function already exists, sunxi_name_to_gpio.
Maxime
return 0; }
- int pin;
return -1;
return -1;
- return pin;
Indeed, I found this yesterday _after_ sending the patches ;-) For some reasons I missed that when I originally wrote the patches, sorry for that.
Cheers, Andre.
Instead of open-coding the fairly generic pinmux setup in the sun8i-emac driver, let's just use the new common implementation of that. This has also the advantage of supporting the newpinctrl bindings, so the driver can cope with the upstream Linux DTs.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- drivers/net/sun8i_emac.c | 38 ++++++-------------------------------- 1 file changed, 6 insertions(+), 32 deletions(-)
diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index abdfada..8a1ea55 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -438,42 +438,16 @@ static int _sun8i_emac_eth_init(struct emac_eth_dev *priv, u8 *enetaddr)
static int parse_phy_pins(struct udevice *dev) { - int offset; - const char *pin_name; - int drive, pull, i; + int ret = sunxi_gpio_setup_dt_pins(gd->fdt_blob, dev->of_offset, + "emac", SUN8I_GPD8_GMAC);
- offset = fdtdec_lookup_phandle(gd->fdt_blob, dev_of_offset(dev), - "pinctrl-0"); - if (offset < 0) { + if (ret < 0) { printf("WARNING: emac: cannot find pinctrl-0 node\n"); - return offset; + return ret; }
- drive = fdt_getprop_u32_default_node(gd->fdt_blob, offset, 0, - "allwinner,drive", 4); - pull = fdt_getprop_u32_default_node(gd->fdt_blob, offset, 0, - "allwinner,pull", 0); - for (i = 0; ; i++) { - int pin; - - pin_name = fdt_stringlist_get(gd->fdt_blob, offset, - "allwinner,pins", i, NULL); - if (!pin_name) - break; - if (pin_name[0] != 'P') - continue; - pin = (pin_name[1] - 'A') << 5; - if (pin >= 26 << 5) - continue; - pin += simple_strtol(&pin_name[2], NULL, 10); - - sunxi_gpio_set_cfgpin(pin, SUN8I_GPD8_GMAC); - sunxi_gpio_set_drv(pin, drive); - sunxi_gpio_set_pull(pin, pull); - } - - if (!i) { - printf("WARNING: emac: cannot find allwinner,pins property\n"); + if (!ret) { + printf("WARNING: emac: cannot find pins property\n"); return -2; }
Now with USB and MMC for the A64 supported in mainline Linux, let's sync our DT with what's in the official Linux repository. This completely changes the clock representation, but U-Boot doesn't use this anyway. Also it switches to a new pinctrl binding, which uses generic property names. The only user of that was the sun8i-emac, which has just learned how to deal with this. Since mainline Linux does not support this Ethernet IP yet, let's copy over our previous DT nodes for that, adjusting them to match the new clock and pinctrl bindings.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun50i-a64-pine64-common.dtsi | 2 +- arch/arm/dts/sun50i-a64.dtsi | 615 +++++++++-------------------- include/dt-bindings/clock/sun50i-a64-ccu.h | 134 +++++++ include/dt-bindings/reset/sun50i-a64-ccu.h | 98 +++++ 4 files changed, 411 insertions(+), 438 deletions(-) create mode 100644 include/dt-bindings/clock/sun50i-a64-ccu.h create mode 100644 include/dt-bindings/reset/sun50i-a64-ccu.h
diff --git a/arch/arm/dts/sun50i-a64-pine64-common.dtsi b/arch/arm/dts/sun50i-a64-pine64-common.dtsi index 9ec81c6..a42b0fa 100644 --- a/arch/arm/dts/sun50i-a64-pine64-common.dtsi +++ b/arch/arm/dts/sun50i-a64-pine64-common.dtsi @@ -61,7 +61,7 @@
&mmc0 { pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins>, <&mmc0_default_cd_pin>; + pinctrl-0 = <&mmc0_pins>; vmmc-supply = <®_vcc3v3>; cd-gpios = <&pio 5 6 0>; cd-inverted; diff --git a/arch/arm/dts/sun50i-a64.dtsi b/arch/arm/dts/sun50i-a64.dtsi index bef0d00..3a5515f 100644 --- a/arch/arm/dts/sun50i-a64.dtsi +++ b/arch/arm/dts/sun50i-a64.dtsi @@ -42,8 +42,9 @@ * OTHER DEALINGS IN THE SOFTWARE. */
+#include <dt-bindings/clock/sun50i-a64-ccu.h> #include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/pinctrl/sun4i-a10.h> +#include <dt-bindings/reset/sun50i-a64-ccu.h>
/ { interrupt-parent = <&gic>; @@ -54,28 +55,28 @@ #address-cells = <1>; #size-cells = <0>;
- cpu@0 { + cpu0: cpu@0 { compatible = "arm,cortex-a53", "arm,armv8"; device_type = "cpu"; reg = <0>; enable-method = "psci"; };
- cpu@1 { + cpu1: cpu@1 { compatible = "arm,cortex-a53", "arm,armv8"; device_type = "cpu"; reg = <1>; enable-method = "psci"; };
- cpu@2 { + cpu2: cpu@2 { compatible = "arm,cortex-a53", "arm,armv8"; device_type = "cpu"; reg = <2>; enable-method = "psci"; };
- cpu@3 { + cpu3: cpu@3 { compatible = "arm,cortex-a53", "arm,armv8"; device_type = "cpu"; reg = <3>; @@ -83,28 +84,23 @@ }; };
- psci { - compatible = "arm,psci-0.2"; - method = "smc"; + osc24M: osc24M_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <24000000>; + clock-output-names = "osc24M"; };
- memory { - device_type = "memory"; - reg = <0x40000000 0>; + osc32k: osc32k_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <32768>; + clock-output-names = "osc32k"; };
- gic: interrupt-controller@1c81000 { - compatible = "arm,gic-400"; - interrupt-controller; - #interrupt-cells = <3>; - #address-cells = <0>; - - reg = <0x01c81000 0x1000>, - <0x01c82000 0x2000>, - <0x01c84000 0x2000>, - <0x01c86000 0x2000>; - interrupts = <GIC_PPI 9 - (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; + psci { + compatible = "arm,psci-0.2"; + method = "smc"; };
timer { @@ -119,199 +115,6 @@ (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; };
- clocks { - #address-cells = <1>; - #size-cells = <1>; - ranges; - - osc24M: osc24M_clk { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <24000000>; - clock-output-names = "osc24M"; - }; - - osc32k: osc32k_clk { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <32768>; - clock-output-names = "osc32k"; - }; - - pll1: pll1_clk@1c20000 { - #clock-cells = <0>; - compatible = "allwinner,sun8i-a23-pll1-clk"; - reg = <0x01c20000 0x4>; - clocks = <&osc24M>; - clock-output-names = "pll1"; - }; - - pll6: pll6_clk@1c20028 { - #clock-cells = <1>; - compatible = "allwinner,sun6i-a31-pll6-clk"; - reg = <0x01c20028 0x4>; - clocks = <&osc24M>; - clock-output-names = "pll6", "pll6x2"; - }; - - pll6d2: pll6d2_clk { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clock-div = <2>; - clock-mult = <1>; - clocks = <&pll6 0>; - clock-output-names = "pll6d2"; - }; - - pll7: pll7_clk@1c2002c { - #clock-cells = <1>; - compatible = "allwinner,sun6i-a31-pll6-clk"; - reg = <0x01c2002c 0x4>; - clocks = <&osc24M>; - clock-output-names = "pll7", "pll7x2"; - }; - - cpu: cpu_clk@1c20050 { - #clock-cells = <0>; - compatible = "allwinner,sun4i-a10-cpu-clk"; - reg = <0x01c20050 0x4>; - clocks = <&osc32k>, <&osc24M>, <&pll1>, <&pll1>; - clock-output-names = "cpu"; - critical-clocks = <0>; - }; - - axi: axi_clk@1c20050 { - #clock-cells = <0>; - compatible = "allwinner,sun4i-a10-axi-clk"; - reg = <0x01c20050 0x4>; - clocks = <&cpu>; - clock-output-names = "axi"; - }; - - ahb1: ahb1_clk@1c20054 { - #clock-cells = <0>; - compatible = "allwinner,sun6i-a31-ahb1-clk"; - reg = <0x01c20054 0x4>; - clocks = <&osc32k>, <&osc24M>, <&axi>, <&pll6 0>; - clock-output-names = "ahb1"; - }; - - ahb2: ahb2_clk@1c2005c { - #clock-cells = <0>; - compatible = "allwinner,sun8i-h3-ahb2-clk"; - reg = <0x01c2005c 0x4>; - clocks = <&ahb1>, <&pll6d2>; - clock-output-names = "ahb2"; - }; - - apb1: apb1_clk@1c20054 { - #clock-cells = <0>; - compatible = "allwinner,sun4i-a10-apb0-clk"; - reg = <0x01c20054 0x4>; - clocks = <&ahb1>; - clock-output-names = "apb1"; - }; - - apb2: apb2_clk@1c20058 { - #clock-cells = <0>; - compatible = "allwinner,sun4i-a10-apb1-clk"; - reg = <0x01c20058 0x4>; - clocks = <&osc32k>, <&osc24M>, <&pll6 1>, <&pll6 1>; - clock-output-names = "apb2"; - }; - - bus_gates: bus_gates_clk@1c20060 { - #clock-cells = <1>; - compatible = "allwinner,sun50i-a64-bus-gates-clk", - "allwinner,sunxi-multi-bus-gates-clk"; - reg = <0x01c20060 0x14>; - ahb1_parent { - clocks = <&ahb1>; - clock-indices = <1>, <5>, - <6>, <8>, - <9>, <10>, - <13>, <14>, - <18>, <19>, - <20>, <21>, - <23>, <24>, - <25>, <28>, - <32>, <35>, - <36>, <37>, - <40>, <43>, - <44>, <52>, - <53>, <54>, - <135>; - clock-output-names = "bus_mipidsi", "bus_ce", - "bus_dma", "bus_mmc0", - "bus_mmc1", "bus_mmc2", - "bus_nand", "bus_sdram", - "bus_ts", "bus_hstimer", - "bus_spi0", "bus_spi1", - "bus_otg", "bus_otg_ehci0", - "bus_ehci0", "bus_otg_ohci0", - "bus_ve", "bus_lcd0", - "bus_lcd1", "bus_deint", - "bus_csi", "bus_hdmi", - "bus_de", "bus_gpu", - "bus_msgbox", "bus_spinlock", - "bus_dbg"; - }; - ahb2_parent { - clocks = <&ahb2>; - clock-indices = <17>, <29>; - clock-output-names = "bus_gmac", "bus_ohci0"; - }; - apb1_parent { - clocks = <&apb1>; - clock-indices = <64>, <65>, - <69>, <72>, - <76>, <77>, - <78>; - clock-output-names = "bus_codec", "bus_spdif", - "bus_pio", "bus_ths", - "bus_i2s0", "bus_i2s1", - "bus_i2s2"; - }; - abp2_parent { - clocks = <&apb2>; - clock-indices = <96>, <97>, - <98>, <101>, - <112>, <113>, - <114>, <115>, - <116>; - clock-output-names = "bus_i2c0", "bus_i2c1", - "bus_i2c2", "bus_scr", - "bus_uart0", "bus_uart1", - "bus_uart2", "bus_uart3", - "bus_uart4"; - }; - }; - - mmc0_clk: mmc0_clk@1c20088 { - #clock-cells = <0>; - compatible = "allwinner,sun4i-a10-mod0-clk"; - reg = <0x01c20088 0x4>; - clocks = <&osc24M>, <&pll6 1>, <&pll7 1>; - clock-output-names = "mmc0"; - }; - - mmc1_clk: mmc1_clk@1c2008c { - #clock-cells = <0>; - compatible = "allwinner,sun4i-a10-mod0-clk"; - reg = <0x01c2008c 0x4>; - clocks = <&osc24M>, <&pll6 1>, <&pll7 1>; - clock-output-names = "mmc1"; - }; - - mmc2_clk: mmc2_clk@1c20090 { - #clock-cells = <0>; - compatible = "allwinner,sun4i-a10-mod0-clk"; - reg = <0x01c20090 0x4>; - clocks = <&osc24M>, <&pll6 1>, <&pll7 1>; - clock-output-names = "mmc2"; - }; - }; - soc { compatible = "simple-bus"; #address-cells = <1>; @@ -319,240 +122,196 @@ ranges;
mmc0: mmc@1c0f000 { - compatible = "allwinner,sun50i-a64-mmc", - "allwinner,sun5i-a13-mmc"; + compatible = "allwinner,sun50i-a64-mmc"; reg = <0x01c0f000 0x1000>; - clocks = <&bus_gates 8>, <&mmc0_clk>, - <&mmc0_clk>, <&mmc0_clk>; - clock-names = "ahb", "mmc", - "output", "sample"; - resets = <&ahb_rst 8>; + clocks = <&ccu CLK_BUS_MMC0>, <&ccu CLK_MMC0>; + clock-names = "ahb", "mmc"; + resets = <&ccu RST_BUS_MMC0>; reset-names = "ahb"; interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>; + max-frequency = <150000000>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; };
mmc1: mmc@1c10000 { - compatible = "allwinner,sun50i-a64-mmc", - "allwinner,sun5i-a13-mmc"; + compatible = "allwinner,sun50i-a64-mmc"; reg = <0x01c10000 0x1000>; - clocks = <&bus_gates 9>, <&mmc1_clk>, - <&mmc1_clk>, <&mmc1_clk>; - clock-names = "ahb", "mmc", - "output", "sample"; - resets = <&ahb_rst 9>; + clocks = <&ccu CLK_BUS_MMC1>, <&ccu CLK_MMC1>; + clock-names = "ahb", "mmc"; + resets = <&ccu RST_BUS_MMC1>; reset-names = "ahb"; interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>; + max-frequency = <150000000>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; };
mmc2: mmc@1c11000 { - compatible = "allwinner,sun50i-a64-mmc", - "allwinner,sun5i-a13-mmc"; + compatible = "allwinner,sun50i-a64-emmc"; reg = <0x01c11000 0x1000>; - clocks = <&bus_gates 10>, <&mmc2_clk>, - <&mmc2_clk>, <&mmc2_clk>; - clock-names = "ahb", "mmc", - "output", "sample"; - resets = <&ahb_rst 10>; + clocks = <&ccu CLK_BUS_MMC2>, <&ccu CLK_MMC2>; + clock-names = "ahb", "mmc"; + resets = <&ccu RST_BUS_MMC2>; reset-names = "ahb"; interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>; + max-frequency = <200000000>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; };
+ usb_otg: usb@01c19000 { + compatible = "allwinner,sun8i-a33-musb"; + reg = <0x01c19000 0x0400>; + clocks = <&ccu CLK_BUS_OTG>; + resets = <&ccu RST_BUS_OTG>; + interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "mc"; + phys = <&usbphy 0>; + phy-names = "usb"; + extcon = <&usbphy 0>; + status = "disabled"; + }; + + usbphy: phy@01c19400 { + compatible = "allwinner,sun50i-a64-usb-phy"; + reg = <0x01c19400 0x14>, + <0x01c1b800 0x4>; + reg-names = "phy_ctrl", + "pmu1"; + clocks = <&ccu CLK_USB_PHY0>, + <&ccu CLK_USB_PHY1>; + clock-names = "usb0_phy", + "usb1_phy"; + resets = <&ccu RST_USB_PHY0>, + <&ccu RST_USB_PHY1>; + reset-names = "usb0_reset", + "usb1_reset"; + status = "disabled"; + #phy-cells = <1>; + }; + + ehci1: usb@01c1b000 { + compatible = "allwinner,sun50i-a64-ehci", "generic-ehci"; + reg = <0x01c1b000 0x100>; + interrupts = <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_OHCI1>, + <&ccu CLK_BUS_EHCI1>, + <&ccu CLK_USB_OHCI1>; + resets = <&ccu RST_BUS_OHCI1>, + <&ccu RST_BUS_EHCI1>; + phys = <&usbphy 1>; + phy-names = "usb"; + status = "disabled"; + }; + + ohci1: usb@01c1b400 { + compatible = "allwinner,sun50i-a64-ohci", "generic-ohci"; + reg = <0x01c1b400 0x100>; + interrupts = <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_OHCI1>, + <&ccu CLK_USB_OHCI1>; + resets = <&ccu RST_BUS_OHCI1>; + phys = <&usbphy 1>; + phy-names = "usb"; + status = "disabled"; + }; + + ccu: clock@01c20000 { + compatible = "allwinner,sun50i-a64-ccu"; + reg = <0x01c20000 0x400>; + clocks = <&osc24M>, <&osc32k>; + clock-names = "hosc", "losc"; + #clock-cells = <1>; + #reset-cells = <1>; + }; + pio: pinctrl@1c20800 { compatible = "allwinner,sun50i-a64-pinctrl"; reg = <0x01c20800 0x400>; interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&bus_gates 69>; + clocks = <&ccu 58>; gpio-controller; #gpio-cells = <3>; interrupt-controller; - #interrupt-cells = <2>; - - uart0_pins_a: uart0@0 { - allwinner,pins = "PB8", "PB9"; - allwinner,function = "uart0"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - uart0_pins_b: uart0@1 { - allwinner,pins = "PF2", "PF3"; - allwinner,function = "uart0"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - uart1_2pins: uart1_2@0 { - allwinner,pins = "PG6", "PG7"; - allwinner,function = "uart1"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - uart1_4pins: uart1_4@0 { - allwinner,pins = "PG6", "PG7", "PG8", "PG9"; - allwinner,function = "uart1"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - uart2_2pins: uart2_2@0 { - allwinner,pins = "PB0", "PB1"; - allwinner,function = "uart2"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - uart2_4pins: uart2_4@0 { - allwinner,pins = "PB0", "PB1", "PB2", "PB3"; - allwinner,function = "uart2"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - uart3_pins_a: uart3@0 { - allwinner,pins = "PD0", "PD1"; - allwinner,function = "uart3"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - uart3_2pins_b: uart3_2@1 { - allwinner,pins = "PH4", "PH5"; - allwinner,function = "uart3"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - uart3_4pins_b: uart3_4@1 { - allwinner,pins = "PH4", "PH5", "PH6", "PH7"; - allwinner,function = "uart3"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - uart4_2pins: uart4_2@0 { - allwinner,pins = "PD2", "PD3"; - allwinner,function = "uart4"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - uart4_4pins: uart4_4@0 { - allwinner,pins = "PD2", "PD3", "PD4", "PD5"; - allwinner,function = "uart4"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; + #interrupt-cells = <3>;
- mmc0_pins: mmc0@0 { - allwinner,pins = "PF0", "PF1", "PF2", "PF3", - "PF4", "PF5"; - allwinner,function = "mmc0"; - allwinner,drive = <SUN4I_PINCTRL_30_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + i2c1_pins: i2c1_pins { + pins = "PH2", "PH3"; + function = "i2c1"; };
- mmc0_default_cd_pin: mmc0_cd_pin@0 { - allwinner,pins = "PF6"; - allwinner,function = "gpio_in"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; + mmc0_pins: mmc0-pins { + pins = "PF0", "PF1", "PF2", "PF3", + "PF4", "PF5"; + function = "mmc0"; + drive-strength = <30>; + bias-pull-up; };
- mmc1_pins: mmc1@0 { - allwinner,pins = "PG0", "PG1", "PG2", "PG3", - "PG4", "PG5"; - allwinner,function = "mmc1"; - allwinner,drive = <SUN4I_PINCTRL_30_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + mmc1_pins: mmc1-pins { + pins = "PG0", "PG1", "PG2", "PG3", + "PG4", "PG5"; + function = "mmc1"; + drive-strength = <30>; + bias-pull-up; };
- mmc2_pins: mmc2@0 { - allwinner,pins = "PC1", "PC5", "PC6", "PC8", - "PC9", "PC10"; - allwinner,function = "mmc2"; - allwinner,drive = <SUN4I_PINCTRL_30_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + mmc2_pins: mmc2-pins { + pins = "PC1", "PC5", "PC6", "PC8", "PC9", + "PC10","PC11", "PC12", "PC13", + "PC14", "PC15", "PC16"; + function = "mmc2"; + drive-strength = <30>; + bias-pull-up; };
- i2c0_pins: i2c0_pins { - allwinner,pins = "PH0", "PH1"; - allwinner,function = "i2c0"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + rmii_pins: rmii_pins { + pins = "PD10", "PD11", "PD13", "PD14", + "PD17", "PD18", "PD19", "PD20", + "PD22", "PD23"; + function = "emac"; + drive-strength = <40>; };
- i2c1_pins: i2c1_pins { - allwinner,pins = "PH2", "PH3"; - allwinner,function = "i2c1"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + rgmii_pins: rgmii_pins { + pins = "PD8", "PD9", "PD10", "PD11", + "PD12", "PD13", "PD15", + "PD16", "PD17", "PD18", "PD19", + "PD20", "PD21", "PD22", "PD23"; + function = "emac"; + drive-strength = <40>; };
- i2c2_pins: i2c2_pins { - allwinner,pins = "PE14", "PE15"; - allwinner,function = "i2c2"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + uart0_pins_a: uart0@0 { + pins = "PB8", "PB9"; + function = "uart0"; };
- rmii_pins: rmii_pins { - allwinner,pins = "PD10", "PD11", "PD13", "PD14", - "PD17", "PD18", "PD19", "PD20", - "PD22", "PD23"; - allwinner,function = "emac"; - allwinner,drive = <SUN4I_PINCTRL_40_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + uart1_pins: uart1_pins { + pins = "PG6", "PG7"; + function = "uart1"; };
- rgmii_pins: rgmii_pins { - allwinner,pins = "PD8", "PD9", "PD10", "PD11", - "PD12", "PD13", "PD15", - "PD16", "PD17", "PD18", "PD19", - "PD20", "PD21", "PD22", "PD23"; - allwinner,function = "emac"; - allwinner,drive = <SUN4I_PINCTRL_40_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + uart1_rts_cts_pins: uart1_rts_cts_pins { + pins = "PG8", "PG9"; + function = "uart1"; }; };
- ahb_rst: reset@1c202c0 { - #reset-cells = <1>; - compatible = "allwinner,sun6i-a31-clock-reset"; - reg = <0x01c202c0 0xc>; - }; - - apb1_rst: reset@1c202d0 { - #reset-cells = <1>; - compatible = "allwinner,sun6i-a31-clock-reset"; - reg = <0x01c202d0 0x4>; - }; - - apb2_rst: reset@1c202d8 { - #reset-cells = <1>; - compatible = "allwinner,sun6i-a31-clock-reset"; - reg = <0x01c202d8 0x4>; - }; - uart0: serial@1c28000 { compatible = "snps,dw-apb-uart"; reg = <0x01c28000 0x400>; interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clocks = <&bus_gates 112>; - resets = <&apb2_rst 16>; + clocks = <&ccu 67>; + resets = <&ccu 46>; status = "disabled"; };
@@ -562,8 +321,8 @@ interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clocks = <&bus_gates 113>; - resets = <&apb2_rst 17>; + clocks = <&ccu 68>; + resets = <&ccu 47>; status = "disabled"; };
@@ -573,8 +332,8 @@ interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clocks = <&bus_gates 114>; - resets = <&apb2_rst 18>; + clocks = <&ccu 69>; + resets = <&ccu 48>; status = "disabled"; };
@@ -584,8 +343,8 @@ interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clocks = <&bus_gates 115>; - resets = <&apb2_rst 19>; + clocks = <&ccu 70>; + resets = <&ccu 49>; status = "disabled"; };
@@ -595,24 +354,17 @@ interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clocks = <&bus_gates 116>; - resets = <&apb2_rst 20>; + clocks = <&ccu 71>; + resets = <&ccu 50>; status = "disabled"; };
- rtc: rtc@1f00000 { - compatible = "allwinner,sun6i-a31-rtc"; - reg = <0x01f00000 0x54>; - interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; - }; - i2c0: i2c@1c2ac00 { compatible = "allwinner,sun6i-a31-i2c"; reg = <0x01c2ac00 0x400>; interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&bus_gates 96>; - resets = <&apb2_rst 0>; + clocks = <&ccu 63>; + resets = <&ccu 42>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; @@ -622,8 +374,8 @@ compatible = "allwinner,sun6i-a31-i2c"; reg = <0x01c2b000 0x400>; interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&bus_gates 97>; - resets = <&apb2_rst 1>; + clocks = <&ccu 64>; + resets = <&ccu 43>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; @@ -633,8 +385,8 @@ compatible = "allwinner,sun6i-a31-i2c"; reg = <0x01c2b400 0x400>; interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&bus_gates 98>; - resets = <&apb2_rst 2>; + clocks = <&ccu 65>; + resets = <&ccu 44>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; @@ -645,42 +397,31 @@ reg = <0x01c30000 0x2000>, <0x01c00030 0x4>; reg-names = "emac", "syscon"; interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; - resets = <&ahb_rst 17>; + resets = <&ccu RST_BUS_EMAC>; reset-names = "ahb"; - clocks = <&bus_gates 17>; + clocks = <&ccu CLK_BUS_EMAC>; clock-names = "ahb"; status = "disabled"; #address-cells = <1>; #size-cells = <0>; };
- usbphy: phy@1c1b810 { - compatible = "allwinner,sun50i-a64-usb-phy", - "allwinner,sun8i-a33-usb-phy"; - reg = <0x01c1b810 0x14>, <0x01c1b800 0x4>; - reg-names = "phy_ctrl", "pmu1"; - status = "disabled"; - #phy-cells = <1>; - }; - - ehci1: usb@01c1b000 { - compatible = "allwinner,sun50i-a64-ehci", - "generic-ehci"; - reg = <0x01c1b000 0x100>; - interrupts = <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>; - phys = <&usbphy 1>; - phy-names = "usb"; - status = "disabled"; + gic: interrupt-controller@1c81000 { + compatible = "arm,gic-400"; + reg = <0x01c81000 0x1000>, + <0x01c82000 0x2000>, + <0x01c84000 0x2000>, + <0x01c86000 0x2000>; + interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; + interrupt-controller; + #interrupt-cells = <3>; };
- ohci1: usb@01c1b400 { - compatible = "allwinner,sun50i-a64-ohci", - "generic-ohci"; - reg = <0x01c1b400 0x100>; - interrupts = <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>; - phys = <&usbphy 1>; - phy-names = "usb"; - status = "enabled"; + rtc: rtc@1f00000 { + compatible = "allwinner,sun6i-a31-rtc"; + reg = <0x01f00000 0x54>; + interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; }; }; }; diff --git a/include/dt-bindings/clock/sun50i-a64-ccu.h b/include/dt-bindings/clock/sun50i-a64-ccu.h new file mode 100644 index 0000000..370c0a0 --- /dev/null +++ b/include/dt-bindings/clock/sun50i-a64-ccu.h @@ -0,0 +1,134 @@ +/* + * Copyright (C) 2016 Maxime Ripard maxime.ripard@free-electrons.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#ifndef _DT_BINDINGS_CLK_SUN50I_A64_H_ +#define _DT_BINDINGS_CLK_SUN50I_A64_H_ + +#define CLK_BUS_MIPI_DSI 28 +#define CLK_BUS_CE 29 +#define CLK_BUS_DMA 30 +#define CLK_BUS_MMC0 31 +#define CLK_BUS_MMC1 32 +#define CLK_BUS_MMC2 33 +#define CLK_BUS_NAND 34 +#define CLK_BUS_DRAM 35 +#define CLK_BUS_EMAC 36 +#define CLK_BUS_TS 37 +#define CLK_BUS_HSTIMER 38 +#define CLK_BUS_SPI0 39 +#define CLK_BUS_SPI1 40 +#define CLK_BUS_OTG 41 +#define CLK_BUS_EHCI0 42 +#define CLK_BUS_EHCI1 43 +#define CLK_BUS_OHCI0 44 +#define CLK_BUS_OHCI1 45 +#define CLK_BUS_VE 46 +#define CLK_BUS_TCON0 47 +#define CLK_BUS_TCON1 48 +#define CLK_BUS_DEINTERLACE 49 +#define CLK_BUS_CSI 50 +#define CLK_BUS_HDMI 51 +#define CLK_BUS_DE 52 +#define CLK_BUS_GPU 53 +#define CLK_BUS_MSGBOX 54 +#define CLK_BUS_SPINLOCK 55 +#define CLK_BUS_CODEC 56 +#define CLK_BUS_SPDIF 57 +#define CLK_BUS_PIO 58 +#define CLK_BUS_THS 59 +#define CLK_BUS_I2S0 60 +#define CLK_BUS_I2S1 61 +#define CLK_BUS_I2S2 62 +#define CLK_BUS_I2C0 63 +#define CLK_BUS_I2C1 64 +#define CLK_BUS_I2C2 65 +#define CLK_BUS_SCR 66 +#define CLK_BUS_UART0 67 +#define CLK_BUS_UART1 68 +#define CLK_BUS_UART2 69 +#define CLK_BUS_UART3 70 +#define CLK_BUS_UART4 71 +#define CLK_BUS_DBG 72 +#define CLK_THS 73 +#define CLK_NAND 74 +#define CLK_MMC0 75 +#define CLK_MMC1 76 +#define CLK_MMC2 77 +#define CLK_TS 78 +#define CLK_CE 79 +#define CLK_SPI0 80 +#define CLK_SPI1 81 +#define CLK_I2S0 82 +#define CLK_I2S1 83 +#define CLK_I2S2 84 +#define CLK_SPDIF 85 +#define CLK_USB_PHY0 86 +#define CLK_USB_PHY1 87 +#define CLK_USB_HSIC 88 +#define CLK_USB_HSIC_12M 89 + +#define CLK_USB_OHCI0 91 + +#define CLK_USB_OHCI1 93 + +#define CLK_DRAM_VE 95 +#define CLK_DRAM_CSI 96 +#define CLK_DRAM_DEINTERLACE 97 +#define CLK_DRAM_TS 98 +#define CLK_DE 99 +#define CLK_TCON0 100 +#define CLK_TCON1 101 +#define CLK_DEINTERLACE 102 +#define CLK_CSI_MISC 103 +#define CLK_CSI_SCLK 104 +#define CLK_CSI_MCLK 105 +#define CLK_VE 106 +#define CLK_AC_DIG 107 +#define CLK_AC_DIG_4X 108 +#define CLK_AVS 109 +#define CLK_HDMI 110 +#define CLK_HDMI_DDC 111 + +#define CLK_DSI_DPHY 113 +#define CLK_GPU 114 + +#endif /* _DT_BINDINGS_CLK_SUN50I_H_ */ diff --git a/include/dt-bindings/reset/sun50i-a64-ccu.h b/include/dt-bindings/reset/sun50i-a64-ccu.h new file mode 100644 index 0000000..db60b29 --- /dev/null +++ b/include/dt-bindings/reset/sun50i-a64-ccu.h @@ -0,0 +1,98 @@ +/* + * Copyright (C) 2016 Maxime Ripard maxime.ripard@free-electrons.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#ifndef _DT_BINDINGS_RST_SUN50I_A64_H_ +#define _DT_BINDINGS_RST_SUN50I_A64_H_ + +#define RST_USB_PHY0 0 +#define RST_USB_PHY1 1 +#define RST_USB_HSIC 2 +#define RST_DRAM 3 +#define RST_MBUS 4 +#define RST_BUS_MIPI_DSI 5 +#define RST_BUS_CE 6 +#define RST_BUS_DMA 7 +#define RST_BUS_MMC0 8 +#define RST_BUS_MMC1 9 +#define RST_BUS_MMC2 10 +#define RST_BUS_NAND 11 +#define RST_BUS_DRAM 12 +#define RST_BUS_EMAC 13 +#define RST_BUS_TS 14 +#define RST_BUS_HSTIMER 15 +#define RST_BUS_SPI0 16 +#define RST_BUS_SPI1 17 +#define RST_BUS_OTG 18 +#define RST_BUS_EHCI0 19 +#define RST_BUS_EHCI1 20 +#define RST_BUS_OHCI0 21 +#define RST_BUS_OHCI1 22 +#define RST_BUS_VE 23 +#define RST_BUS_TCON0 24 +#define RST_BUS_TCON1 25 +#define RST_BUS_DEINTERLACE 26 +#define RST_BUS_CSI 27 +#define RST_BUS_HDMI0 28 +#define RST_BUS_HDMI1 29 +#define RST_BUS_DE 30 +#define RST_BUS_GPU 31 +#define RST_BUS_MSGBOX 32 +#define RST_BUS_SPINLOCK 33 +#define RST_BUS_DBG 34 +#define RST_BUS_LVDS 35 +#define RST_BUS_CODEC 36 +#define RST_BUS_SPDIF 37 +#define RST_BUS_THS 38 +#define RST_BUS_I2S0 39 +#define RST_BUS_I2S1 40 +#define RST_BUS_I2S2 41 +#define RST_BUS_I2C0 42 +#define RST_BUS_I2C1 43 +#define RST_BUS_I2C2 44 +#define RST_BUS_SCR 45 +#define RST_BUS_UART0 46 +#define RST_BUS_UART1 47 +#define RST_BUS_UART2 48 +#define RST_BUS_UART3 49 +#define RST_BUS_UART4 50 + +#endif /* _DT_BINDINGS_RST_SUN50I_A64_H_ */
Update the two .dts files for the Pine64 boards with those used in the kernel. This switches from using a -common.dtsi to including the .dts for the non-plus model in the -plus file. Again we keep our EMAC driver nodes in, which are not yet in mainline Linux.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun50i-a64-pine64-plus.dts | 16 ++------ arch/arm/dts/sun50i-a64-pine64.dts | 72 +++++++++++++++++++++++++++++++-- 2 files changed, 72 insertions(+), 16 deletions(-)
diff --git a/arch/arm/dts/sun50i-a64-pine64-plus.dts b/arch/arm/dts/sun50i-a64-pine64-plus.dts index 389c609..65c698c 100644 --- a/arch/arm/dts/sun50i-a64-pine64-plus.dts +++ b/arch/arm/dts/sun50i-a64-pine64-plus.dts @@ -40,22 +40,13 @@ * OTHER DEALINGS IN THE SOFTWARE. */
-/dts-v1/; - -#include "sun50i-a64-pine64-common.dtsi" +#include "sun50i-a64-pine64.dts"
/ { model = "Pine64+"; compatible = "pine64,pine64-plus", "allwinner,sun50i-a64";
- chosen { - stdout-path = "serial0:115200n8"; - }; - - /* There is a model with 2GB of DRAM, but U-Boot fixes this for us. */ - memory { - reg = <0x40000000 0x40000000>; - }; + /* TODO: Camera, Ethernet PHY, touchscreen, etc. */ };
&emac { @@ -66,7 +57,6 @@ status = "okay";
phy1: ethernet-phy@1 { - reg = <1>; + reg = <1>; }; }; - diff --git a/arch/arm/dts/sun50i-a64-pine64.dts b/arch/arm/dts/sun50i-a64-pine64.dts index ebe029e..006aa04 100644 --- a/arch/arm/dts/sun50i-a64-pine64.dts +++ b/arch/arm/dts/sun50i-a64-pine64.dts @@ -42,17 +42,83 @@
/dts-v1/;
-#include "sun50i-a64-pine64-common.dtsi" +#include "sun50i-a64.dtsi" + +#include <dt-bindings/gpio/gpio.h>
/ { model = "Pine64"; compatible = "pine64,pine64", "allwinner,sun50i-a64";
+ aliases { + serial0 = &uart0; + ethernet0 = &emac; + }; + chosen { stdout-path = "serial0:115200n8"; };
- memory { - reg = <0x40000000 0x20000000>; + reg_vcc3v3: vcc3v3 { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; +}; + +&ehci1 { + status = "okay"; +}; + +&emac { + pinctrl-names = "default"; + pinctrl-0 = <&rmii_pins>; + phy-mode = "rmii"; + phy = <&phy1>; + status = "okay"; + + phy1: ethernet-phy@1 { + reg = <1>; }; }; + +&i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins>; + status = "okay"; +}; + +&i2c1_pins { + bias-pull-up; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins>; + vmmc-supply = <®_vcc3v3>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; + cd-inverted; + disable-wp; + bus-width = <4>; + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; + +&usb_otg { + dr_mode = "host"; + status = "okay"; +}; + +&usbphy { + status = "okay"; +};
Now since the common DT nodes between the two Pine64 boards have been moved into the .dts for the non-plus model, we no longer need the extra -common.dtsi. Let's just remove it.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun50i-a64-pine64-common.dtsi | 93 ------------------------------ 1 file changed, 93 deletions(-) delete mode 100644 arch/arm/dts/sun50i-a64-pine64-common.dtsi
diff --git a/arch/arm/dts/sun50i-a64-pine64-common.dtsi b/arch/arm/dts/sun50i-a64-pine64-common.dtsi deleted file mode 100644 index a42b0fa..0000000 --- a/arch/arm/dts/sun50i-a64-pine64-common.dtsi +++ /dev/null @@ -1,93 +0,0 @@ -/* - * Copyright (c) 2016 ARM Ltd. - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This library is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This library is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#include "sun50i-a64.dtsi" - -/ { - - aliases { - serial0 = &uart0; - ethernet0 = &emac; - }; - - soc { - reg_vcc3v3: vcc3v3 { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - }; -}; - -&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins>; - vmmc-supply = <®_vcc3v3>; - cd-gpios = <&pio 5 6 0>; - cd-inverted; - status = "okay"; -}; - -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_pins_a>; - status = "okay"; -}; - -&i2c1 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c1_pins>; - status = "okay"; -}; - -&usbphy { - status = "okay"; -}; - -&ohci1 { - status = "okay"; -}; - -&ehci1 { - status = "okay"; -};
Since mainline Linux gained support for the BananaPi-M64, let's just copy this DT to prepare the U-Boot support for that board. Again add the required DT nodes for the Ethernet IP.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/sun50i-a64-bananapi-m64.dts | 135 +++++++++++++++++++++++++++++++ 2 files changed, 137 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/sun50i-a64-bananapi-m64.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index eeaa9e0..ffe1a9e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -299,7 +299,8 @@ dtb-$(CONFIG_MACH_SUN50I_H5) += \ sun50i-h5-orangepi-pc2.dtb dtb-$(CONFIG_MACH_SUN50I) += \ sun50i-a64-pine64-plus.dtb \ - sun50i-a64-pine64.dtb + sun50i-a64-pine64.dtb \ + sun50i-a64-bananapi-m64.dtb dtb-$(CONFIG_MACH_SUN9I) += \ sun9i-a80-optimus.dtb \ sun9i-a80-cubieboard4.dtb diff --git a/arch/arm/dts/sun50i-a64-bananapi-m64.dts b/arch/arm/dts/sun50i-a64-bananapi-m64.dts new file mode 100644 index 0000000..943b303 --- /dev/null +++ b/arch/arm/dts/sun50i-a64-bananapi-m64.dts @@ -0,0 +1,135 @@ +/* + * Copyright (c) 2016 ARM Ltd. + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This library is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This library is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; + +#include "sun50i-a64.dtsi" + +#include <dt-bindings/gpio/gpio.h> + +/ { + model = "BananaPi-M64"; + compatible = "sinovoip,bananapi-m64", "allwinner,sun50i-a64"; + + aliases { + serial0 = &uart0; + serial1 = &uart1; + ethernet0 = &emac; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + reg_vcc3v3: vcc3v3 { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; +}; + +&i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins>; + status = "okay"; +}; + +&i2c1_pins { + bias-pull-up; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins>; + vmmc-supply = <®_vcc3v3>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; + cd-inverted; + disable-wp; + bus-width = <4>; + status = "okay"; +}; + +&mmc1 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins>; + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + non-removable; + status = "okay"; +}; + +&mmc2 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_pins>; + vmmc-supply = <®_vcc3v3>; + bus-width = <8>; + non-removable; + cap-mmc-hw-reset; + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins>, <&uart1_rts_cts_pins>; + status = "okay"; +}; + +&emac { + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + phy-handle = <&phy1>; + phy-mode = "rgmii"; + + allwinner,leds-active-low; + status = "okay"; + + phy1: ethernet-phy@1 { + reg = <1>; + }; +};
Cheers, Andre.
Could we keep this simple, and just do a "sync with the kernel" commit for sun50i, which also keeps the sun8i-emac specific bits. And also explicitly mention the git commit or tag you are syncing to.
ChenYu
-- 2.8.2
Cheers, Andre.
So you mean to drop patch 1 and 2 and keep the old style pinctrl bindings around for the EMAC node? I can certainly do this (if others agree), but didn't want to dodge a more proper solution in the first place.
Another alternative would be to squash the functionality of patch 1 directly into sun8i_emac.c, so without the moving to pinmux.c. This would mean dropping patch 1/6 and just having a fix for the sun8i_emac.
Let me know what's the preferred solution here.
Cheers, Andre.
-- 2.8.2
On Mon, Feb 27, 2017 at 5:53 PM, Andre Przywara andre.przywara@arm.com wrote:
Cheers, Andre.
I've actually no preference on this. What I meant was you don't need four patches to do the sync-up, just one, i.e. copy sun50i*.{dts,dtsi} from the kernel, and patch back whatever the emac needs, since it's not in mainline yet.
I guess you could update sun8i-emac to deal with generic pinconf, or update the gpio driver, but that would be a separate series.
ChenYu
Cheers, Andre.
-- 2.8.2
Cheers, Andre.
Agree with ChenYu, and will update the status on this on patchwork as "Superseded"
thanks!
Andre Przywara
Chen-Yu Tsai
Jagan Teki
Maxime Ripard
