[U-Boot] [PATCH v2 0/7] da850evm NAND, MII and bootparam fix
This patch series adds NAND support to the da850evm. The support is in the spirit of that found in the omap-l1 and u-boot-davinci trees where NAND support can be enabled with the addition of a single '#define CONFIG_USE_NAND' to the top of the include/configs/da850evm.h file. Pinmux entries are added for NAND so that NAND is usable even when the boot mode is not from NAND. Also the mtdpart, ubi and ubifs commands are proposed to be added to the NAND support because of their importance when using NAND.
I have also integrated the two remaining da850evm patches [1] [2].
V2: * Integrated the "da850evm: basic MII EMAC support" and "da850evm: fix linux bootparam address" patches into this series and rebased to u-boot-ti/master to facilitate pickup by Sandeep
Ben Gardiner (7): davinci_nand, trivial : use symbolic ECC start command da850evm : enable NAND even when not in NAND boot mode da850evm: setup the NAND flash timings da850evm: setup NAND support under CONFIG_USE_NAND da850evm: add mtdpart and ubi commands with NAND support da850evm: basic MII EMAC support da850evm: fix linux bootparam address
board/davinci/da8xxevm/da850evm.c | 89 +++++++++++++++++++++++++++++++++++++ drivers/mtd/nand/davinci_nand.c | 3 +- include/configs/da850evm.h | 54 ++++++++++++++++++++++- 3 files changed, 144 insertions(+), 2 deletions(-)
[1] http://www.mail-archive.com/u-boot@lists.denx.de/msg38461.html [2] http://www.mail-archive.com/u-boot@lists.denx.de/msg38363.html
V2:
- Integrated the "da850evm: basic MII EMAC support" and "da850evm: fix
Thanks I have pushed this set to
http://git.denx.de/cgi-bin/gitweb.cgi?p=u-boot/u-boot-ti.git;a=summary
Regards, Sandeep
Ben Gardiner
Paulraj, Sandeep
