[U-Boot] [GIT PULL] Please pull u-boot-mpc85xx.git
The following changes since commit e1ccf97c5d7651664d37c0c5aa243874b8851b2d:
Merge branch 'master' of git://git.denx.de/u-boot-mpc85xx (2011-01-17 20:31:46 +0100)
git://git.denx.de/u-boot-mpc85xx master
Dipen Dudhat (1): powerpc/85xx: Protect all LBC code with CONFIG_FSL_LBC
Haiying Wang (1): 8xxx/ddr: add support to only compute the ddr sdram size
Kumar Gala (6): powerpc/85xx: Move RESET_VECTOR_ADDRESS into config.h powerpc/p3041: Add various p3041 specific information powerpc/p5020: Add various p5020 specific information powerpc/p2040: Add various p2040 specific information powerpc/8xxx: Add hwconfig APIs to address early parsing used by DDR init powerpc/8xxx: Introduce 85xx, 86xx, QorIQ config headers
Poonam Aggrwal (2): powerpc/85xx: Add Support for Freescale P1010 Processor powerpc/85xx: Add Support for Freescale P1014 Processor
Prabhakar (1): Fix wrong CONFIG_SYS_MPC85xx_SERDES1_ADDR
Prabhakar Kushwaha (1): ppc/85xx: Fix compile err when PCI disabled on P1_P2_RDB
York Sun (8): mpc8xxx: Display RDIMM if detected mpc8xxx: Enable ECC on/off control in hwconfig corenet_ds: Enable ECC for corenet_ds mpc85xx: Adding more registers and options mpc85xx: Enable unique mode registers and dynamic ODT for DDR3 mpc85xx: Implement workaround for erratum DDR-A003 corenet_ds: Extend board specific parameters powerpc/p4080: Fix warning in serdes code from early use of hwconfig
arch/powerpc/cpu/mpc85xx/Makefile | 6 + arch/powerpc/cpu/mpc85xx/cmd_errata.c | 3 + arch/powerpc/cpu/mpc85xx/cpu.c | 9 +- arch/powerpc/cpu/mpc85xx/ddr-gen3.c | 99 +++++- arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c | 17 +- arch/powerpc/cpu/mpc85xx/p2040_serdes.c | 66 ++++ arch/powerpc/cpu/mpc85xx/p3041_ids.c | 105 ++++++ arch/powerpc/cpu/mpc85xx/p3041_serdes.c | 151 ++++++++ arch/powerpc/cpu/mpc85xx/p5020_ids.c | 105 ++++++ arch/powerpc/cpu/mpc85xx/p5020_serdes.c | 151 ++++++++ arch/powerpc/cpu/mpc85xx/speed.c | 6 +- arch/powerpc/cpu/mpc85xx/u-boot.lds | 8 +- arch/powerpc/cpu/mpc8xxx/cpu.c | 8 +- arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c | 262 +++++++++++--- arch/powerpc/cpu/mpc8xxx/ddr/ddr.h | 8 +- .../cpu/mpc8xxx/ddr/lc_common_dimm_params.c | 20 +- arch/powerpc/cpu/mpc8xxx/ddr/main.c | 31 ++- arch/powerpc/cpu/mpc8xxx/ddr/options.c | 395 ++++++++++++++++++-- arch/powerpc/include/asm/config.h | 39 +-- arch/powerpc/include/asm/config_mpc85xx.h | 188 ++++++++++ arch/powerpc/include/asm/config_mpc86xx.h | 38 ++ arch/powerpc/include/asm/fsl_ddr_sdram.h | 52 +++ arch/powerpc/include/asm/immap_85xx.h | 23 +- arch/powerpc/include/asm/processor.h | 6 + board/freescale/corenet_ds/config.mk | 27 -- board/freescale/corenet_ds/ddr.c | 159 ++++---- board/freescale/mpc8536ds/config.mk | 14 +- board/freescale/mpc8572ds/config.mk | 4 +- board/freescale/p1022ds/config.mk | 10 - board/freescale/p1_p2_rdb/config.mk | 14 +- board/freescale/p1_p2_rdb/p1_p2_rdb.c | 4 +- board/freescale/p1_p2_rdb/tlb.c | 4 +- board/freescale/p2020ds/config.mk | 26 -- board/tqc/tqm85xx/sdram.c | 8 +- common/hwconfig.c | 86 +++-- doc/README.fsl-ddr | 74 ++++- drivers/misc/fsl_law.c | 23 +- include/configs/MPC8536DS.h | 6 + include/configs/MPC8572DS.h | 4 + include/configs/P1022DS.h | 4 + include/configs/P1_P2_RDB.h | 19 +- include/configs/P2020DS.h | 4 + include/configs/P4080DS.h | 16 - include/configs/corenet_ds.h | 8 +- include/hwconfig.h | 68 +++- 45 files changed, 1940 insertions(+), 438 deletions(-) create mode 100644 arch/powerpc/cpu/mpc85xx/p2040_serdes.c create mode 100644 arch/powerpc/cpu/mpc85xx/p3041_ids.c create mode 100644 arch/powerpc/cpu/mpc85xx/p3041_serdes.c create mode 100644 arch/powerpc/cpu/mpc85xx/p5020_ids.c create mode 100644 arch/powerpc/cpu/mpc85xx/p5020_serdes.c create mode 100644 arch/powerpc/include/asm/config_mpc85xx.h create mode 100644 arch/powerpc/include/asm/config_mpc86xx.h delete mode 100644 board/freescale/corenet_ds/config.mk delete mode 100644 board/freescale/p1022ds/config.mk delete mode 100644 board/freescale/p2020ds/config.mk
Updated to include:
Kumar Gala (1): powerpc/8xxx: Fix compile warning when build for a DDR1 or DDR2 board
Updated to include:
poke
- k
Dear Kumar Gala,
Applied, thanks.
Kumar Gala
