[U-Boot] [PATCH] mflash: use common cmd_usage function
Signed-off-by: Mike Frysinger vapier@gentoo.org --- note: i have no target that uses it, so i havent compile tested this. but the change is straight forward enough ...
common/cmd_mgdisk.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/common/cmd_mgdisk.c b/common/cmd_mgdisk.c index 3ba62f6..03bed88 100644 --- a/common/cmd_mgdisk.c +++ b/common/cmd_mgdisk.c @@ -54,7 +54,7 @@ int do_mg_disk_cmd (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) return 1; break; default: - printf("Usage:\n%s\n", cmdtp->usage); + cmd_usage(cmdtp); return 1; } return 0;
Hi Mike,
return 1; } return 0;cmd_usage(cmdtp);
With commit 47e26b1bf91ddef69f4a3892815c857db094cef9 [cmd_usage(): simplify return code handling] I suppose this should be directly changed to a return cmd_usage.
This applies to one other patch you sent.
Cheers Detlev
return 1;
break;
default:
cmd_usage(cmdtp);
return 1;
} return 0;
hadnt noticed that. ill send updated patches; thanks. -mike
Signed-off-by: Mike Frysinger vapier@gentoo.org --- v2 - tail into cmd_usage() as pointed out by Detlev Zundel
common/cmd_mgdisk.c | 3 +-- 1 files changed, 1 insertions(+), 2 deletions(-)
diff --git a/common/cmd_mgdisk.c b/common/cmd_mgdisk.c index c2d5217..51c994b 100644 --- a/common/cmd_mgdisk.c +++ b/common/cmd_mgdisk.c @@ -54,8 +54,7 @@ int do_mg_disk_cmd (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 1; break; default: - printf("Usage:\n%s\n", cmdtp->usage); - return 1; + return cmd_usage(cmdtp); } return 0; }
Dear Mike Frysinger,
v2
Applied, thanks.
Detlev Zundel
Mike Frysinger
