[U-Boot] Pull request: u-boot-arm
The following changes since commit e1b4c57096b87b4ada56df4154d9acee6a59141f:
Merge branch 'master' of git://git.denx.de/u-boot-arm (2010-10-13 20:59:47 +0200)
git://git.denx.de/u-boot-arm.git master
Ben Gardiner (7): davinci_nand, trivial : use symbolic ECC start command da850evm : enable NAND even when not in NAND boot mode da850evm: setup the NAND flash timings da850evm: setup NAND support under CONFIG_USE_NAND da850evm: add mtdpart and ubi commands with NAND support da850evm: basic MII EMAC support da850evm: fix linux bootparam address
Enric Balletbo i Serra (3): OMAP3: SDRC: Introduce Numonyx DDR type OMAP3: Add support for the IGEP v2 board. OMAP3: Add support for the OMAP3 IGEP module.
Loic Minier (1): mx51evk: add u-boot.imx to ALL target
Stefano Babic (6): FPGA: add support for downloading Lattice bitstream MX31: Adding missing iomux pin to MX.31 registers MX31: Add support to update FPGA bitstream MX31: add support for setting pin pads MX31: Add support for MXC EHCI controller MX31: Add USB Host support to the QONG board
Steve Sakoman (8): env_mmc: Fix crashing bug encountered after enabling ARM relocation ARMV7: OMAP: Use default vendor/product ID for USB gadget ARMV7: OMAP4: Use generic mmc driver on Beagle ARMV7: OMAP4: Use generic mmc driver on Overo ARMV7: OMAP3: Implement relocation for Overo ARMV7: OMAP3: Enable cache support on Overo ARMV7: OMAP3: Fix bug in get_sdr_cs_offset() ARMV7: OMAP4: Implement relocation for Panda and OMAP4430SDP
Sukumar Ghorai (5): MMC: Fix for capacity calculation on eMMC ARMV7: OMAP: Add new mmc driver compatible with CONFIG_GENERIC_MMC ARMV7: OMAP4: Use generic mmc driver on Panda ARMV7: OMAP4: Use generic mmc driver on SDP4430 ARMV7: OMAP4: Enable saveenv to eMMC for SDP4430
Wolfgang Denk (1): Merge branch 'master' of git://git.denx.de/u-boot-imx
MAINTAINERS | 5 + MAKEALL | 2 + arch/arm/cpu/arm1136/mx31/generic.c | 17 + arch/arm/cpu/armv7/omap3/sdrc.c | 2 +- arch/arm/cpu/armv7/omap4/board.c | 5 + arch/arm/include/asm/arch-mx31/mx31-regs.h | 411 +++ arch/arm/include/asm/arch-omap3/mem.h | 43 + arch/arm/include/asm/arch-omap3/mmc_host_def.h | 10 + arch/arm/include/asm/arch-omap4/mmc_host_def.h | 10 + arch/arm/lib/board.c | 10 +- board/davedenx/qong/Makefile | 2 +- board/davedenx/qong/fpga.c | 95 + board/davedenx/qong/qong.c | 44 + board/davedenx/qong/qong_fpga.h | 3 +- board/davinci/da8xxevm/da850evm.c | 89 + board/freescale/mx51evk/config.mk | 1 + board/isee/igep0020/Makefile | 49 + board/isee/igep0020/config.mk | 33 + board/isee/igep0020/igep0020.c | 129 + board/isee/igep0020/igep0020.h | 156 ++ board/isee/igep0030/Makefile | 49 + board/isee/igep0030/config.mk | 34 + board/isee/igep0030/igep0030.c | 71 + board/isee/igep0030/igep0030.h | 147 ++ board/overo/config.mk | 2 +- board/overo/overo.c | 9 + board/ti/beagle/beagle.c | 9 + board/ti/panda/config.mk | 4 +- board/ti/panda/panda.c | 9 + board/ti/sdp4430/config.mk | 3 +- board/ti/sdp4430/sdp.c | 10 + boards.cfg | 2 + common/env_mmc.c | 17 +- drivers/fpga/Makefile | 1 + drivers/fpga/fpga.c | 11 + drivers/fpga/ivm_core.c | 3167 ++++++++++++++++++++++++ drivers/fpga/lattice.c | 399 +++ drivers/mmc/Makefile | 1 + drivers/mmc/mmc.c | 11 + drivers/mmc/omap_hsmmc.c | 415 ++++ drivers/mtd/nand/davinci_nand.c | 3 +- drivers/usb/host/Makefile | 1 + drivers/usb/host/ehci-mxc.c | 130 + drivers/video/mx3fb.c | 31 - include/configs/da850evm.h | 54 +- include/configs/igep0020.h | 228 ++ include/configs/igep0030.h | 215 ++ include/configs/omap3_beagle.h | 15 +- include/configs/omap3_overo.h | 14 +- include/configs/omap4_panda.h | 23 +- include/configs/omap4_sdp4430.h | 35 +- include/configs/qong.h | 21 +- include/fpga.h | 1 + include/lattice.h | 319 +++ 54 files changed, 6472 insertions(+), 105 deletions(-) create mode 100644 board/davedenx/qong/fpga.c create mode 100644 board/isee/igep0020/Makefile create mode 100644 board/isee/igep0020/config.mk create mode 100644 board/isee/igep0020/igep0020.c create mode 100644 board/isee/igep0020/igep0020.h create mode 100644 board/isee/igep0030/Makefile create mode 100644 board/isee/igep0030/config.mk create mode 100644 board/isee/igep0030/igep0030.c create mode 100644 board/isee/igep0030/igep0030.h create mode 100755 drivers/fpga/ivm_core.c create mode 100644 drivers/fpga/lattice.c create mode 100644 drivers/mmc/omap_hsmmc.c create mode 100644 drivers/usb/host/ehci-mxc.c create mode 100644 include/configs/igep0020.h create mode 100644 include/configs/igep0030.h create mode 100755 include/lattice.h
Applied, thanks.
