[PATCH v5 1/8] bootstd: Tweak bootflow logic for device tree
We should only store the FDT filename if we were unable to determine one. Adjust the logic for this.
This corrects the case where no FDT is needed to boot, such as with EFI using ACPI.
Changes in v5: - Add new patch to tweak bootflow logic for device tree
boot/bootmeth_efi.c | 22 +++++++++++----------- 1 file changed, 11 insertions(+), 11 deletions(-)
diff --git a/boot/bootmeth_efi.c b/boot/bootmeth_efi.c index 6a97ac02ff5c..d7e042cf01ee 100644 --- a/boot/bootmeth_efi.c +++ b/boot/bootmeth_efi.c @@ -235,21 +235,21 @@ static int distro_efi_read_bootflow_file(struct udevice *dev,
/* try the various available names */ ret = -ENOENT; - for (seq = 0; ret; seq++) { + *fname = '\0'; + for (seq = 0; ret == -ENOENT; seq++) { ret = distro_efi_get_fdt_name(fname, sizeof(fname), seq); - if (ret == -EALREADY) { + if (ret == -EALREADY) bflow->flags = BOOTFLOWF_USE_PRIOR_FDT; - break; - } - if (ret) - return log_msg_ret("nam", ret); - ret = bootmeth_common_read_file(dev, bflow, fname, fdt_addr, - &size); + if (!ret) + ret = bootmeth_common_read_file(dev, bflow, fname, + fdt_addr, &size); }
- bflow->fdt_fname = strdup(fname); - if (!bflow->fdt_fname) - return log_msg_ret("fil", -ENOMEM); + if (*fname) { + bflow->fdt_fname = strdup(fname); + if (!bflow->fdt_fname) + return log_msg_ret("fil", -ENOMEM); + }
if (!ret) { bflow->fdt_size = size;
Sometimes virtio may rely on PCI, or at least that is what the distro_bootcmd script suggests. Add this in.
Changes in v5: Add new patch to ensure PCI is set up first
drivers/virtio/virtio-uclass.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/virtio/virtio-uclass.c b/drivers/virtio/virtio-uclass.c index de9bc90359ca..918cc15b019f 100644 --- a/drivers/virtio/virtio-uclass.c +++ b/drivers/virtio/virtio-uclass.c @@ -373,6 +373,12 @@ static int virtio_bootdev_hunt(struct bootdev_hunter *info, bool show) { int ret;
+ if (IS_ENABLED(CONFIG_PCI)) { + ret = uclass_probe_all(UCLASS_PCI); + if (ret && ret != -ENOENT) + return log_msg_ret("pci", ret); + } + ret = uclass_probe_all(UCLASS_VIRTIO); if (ret && ret != -ENOENT) return log_msg_ret("vir", ret);
The current EFI implementation has a strange quirk where it watches loaded files and uses the last-loaded file to determine the device that is being booted from.
This is confusing with bootstd, where multiple options may exist. Even loading a device tree will cause it to go wrong. There is no API for passing this information, since the only entry into booting an EFI image is the 'bootefi' command.
To work around this, call efi_set_bootdev() for EFI images, if possible, just before booting.
Changes in v5: - Add new patch to support booting EFI where multiple options exist
boot/bootmeth_efi.c | 26 +++++++++++++++++++------- 1 file changed, 19 insertions(+), 7 deletions(-)
diff --git a/boot/bootmeth_efi.c b/boot/bootmeth_efi.c index d7e042cf01ee..d8bc7fafd127 100644 --- a/boot/bootmeth_efi.c +++ b/boot/bootmeth_efi.c @@ -94,7 +94,7 @@ static int get_efi_pxe_vci(char *str, int max_len) return 0; }
-static int efiload_read_file(struct blk_desc *desc, struct bootflow *bflow) +static void set_efi_bootdev(struct blk_desc *desc, struct bootflow *bflow) { const struct udevice *media_dev; int size = bflow->size; @@ -102,11 +102,6 @@ static int efiload_read_file(struct blk_desc *desc, struct bootflow *bflow) char devnum_str[9]; char dirname[200]; char *last_slash; - int ret; - - ret = bootmeth_alloc_file(bflow, 0x2000000, 0x10000); - if (ret) - return log_msg_ret("read", ret);
/* * This is a horrible hack to tell EFI about this boot device. Once we @@ -117,7 +112,8 @@ static int efiload_read_file(struct blk_desc *desc, struct bootflow *bflow) * this can go away. */ media_dev = dev_get_parent(bflow->dev); - snprintf(devnum_str, sizeof(devnum_str), "%x", dev_seq(media_dev)); + snprintf(devnum_str, sizeof(devnum_str), "%x:%x", dev_seq(media_dev), + bflow->part);
strlcpy(dirname, bflow->fname, sizeof(dirname)); last_slash = strrchr(dirname, '/'); @@ -130,6 +126,15 @@ static int efiload_read_file(struct blk_desc *desc, struct bootflow *bflow) dev_name = device_get_uclass_id(media_dev) == UCLASS_MASS_STORAGE ? "usb" : dev_get_uclass_name(media_dev); efi_set_bootdev(dev_name, devnum_str, bflow->fname, bflow->buf, size); +} + +static int efiload_read_file(struct blk_desc *desc, struct bootflow *bflow) +{ + int ret; + + ret = bootmeth_alloc_file(bflow, 0x2000000, 0x10000); + if (ret) + return log_msg_ret("read", ret);
return 0; } @@ -373,6 +378,13 @@ int distro_efi_boot(struct udevice *dev, struct bootflow *bflow)
/* A non-zero buffer indicates the kernel is there */ if (bflow->buf) { + /* Set the EFI bootdev again, since reading an FDT loses it! */ + if (bflow->blk) { + struct blk_desc *desc = dev_get_uclass_plat(bflow->blk); + + set_efi_bootdev(desc, bflow); + } + kernel = (ulong)map_to_sysmem(bflow->buf);
Shouldn't this all be a simple wrapper around the EFI Standard BootDeviceOrder or whatever that's called?
Hi Tom,
I think you are referring to boot manager, which isn't used here. This is replicating the existing distroboot functionality in standard boot. I've been trying to tease out the rules around finding the image and the devicetree files, and this is what I've got it.
On Sat, Apr 01, 2023 at 07:31:49PM +1300, Simon Glass wrote:
Hi Tom,
The distroboot functionality *was* trying to behave like the EFI spec expects the bootmanager to behave. Unfortunately I haven't had time to review the distroboot patches closely, but back when this started, my point was that EFI doesn't need anything. Whenever the EFI flow is added bootstd should 'just' call the bootmanager.
Regards/Ilias
Hi Tom,
Yes, this. We're trying make things cleaner overall, so the EFI portion of bootstd distro boot should just be "call EFI bootmanager" as that has a well defined standard way to specify what devices to try in what order.
Am 3. April 2023 16:17:42 MESZ schrieb Tom Rini trini@konsulko.com:
Hi Tom,
Distroboot used to load the devicetree from a default location too.
This makes good sense on many boards but poses a problem for secure boot.
@Ilias, we need to evaluate this.
Regards
Heinrich
Hi Heinrich
Hi Tom,
Yes ideally you want to load the DTB that comes along with u-boot since it's implicitly verified by the device chain of trust. However we can now measure the dtb that gets installed on a config table.
Regards /Ilias
Regards
Heinrich
Hi Tom,
Hi Tom,
that
Even
for
possible,
point
bootstd
We already call bootmgr in standard boot, if it is enabled.
But I am not sure how widely that is used...
This patch is about corner cases in the distro scripts. If we are to turn these down we do need to try to do the same thing.
On Wed, Apr 05, 2023 at 05:28:07PM +1200, Simon Glass wrote:
Hi Tom,
Hi Tom,
that
Even
for
possible,
point
bootstd
We probably need some distro people to chime in about what they're doing / expecting at this point in time? I would have sworn that the long term part of EFI "distro boot" would be using bootmgr since that's the standards based way to set boot order. And if you don't have a device tree in U-Boot, and want the distribution one, aren't you then using something like grub which has a "dtb" keyword to handle that on its own? That's not saying that "distro boot" doesn't need to load the device tree, for when it's then calling booti/bootz/bootm, but not for the EFI case these days? Or no?
Date: Wed, 5 Apr 2023 10:47:59 -0400 From: Tom Rini trini@konsulko.com
Hi Tom,
Hi Tom,
> The current EFI implementation has a strange quirk where it watches > loaded files and uses the last-loaded file to determine the device
that
> is being booted from. > > This is confusing with bootstd, where multiple options may exist.
Even
for
> is the 'bootefi' command. > > To work around this, call efi_set_bootdev() for EFI images, if
possible,
> just before booting. > > Signed-off-by: Simon Glass sjg@chromium.org
point
bootstd
The short anserwer is no.
The long answer:
OpenBSD requires EFI (booti/bootz/bootm only support booting Linux kernels in various forms) but also relies on a proper device tree being provided to its EFI bootloader. While we have made significant progress in having U-Boot provide a fully synched up device tree for most of the SoCs that OpenBSD supports, we're not quite there yet, so some people rely on U-Boot loading (and tweaking) an updated device-tree from the EFI System Partition.
Our bootloader does have a "mach dtb" command to load a device tree from the OpenBSD root partition, but this is considered to be a debugging command and can't load a device tree from the EFI System Partition. Loading a device tree this way means the device tree does not get tweaked by U-Boot, which is problematic on some SoCs/boards.
We now have the EFI_DT_FIXUP_PROTOCOL, but our bootloader doesn't use this yet. If the consensus is that distroboot-with-efiboot needs to deprecated I can work on supporting that protocol in our bootloader. But a release of OpenBSD with support for that will not be available until november 2023.
Alternatively bootmgr could implement the device tree loading and fixup. Or the bootstd stuff could do this before starting bootmgr. I understand the concerns about loading device trees from disk when secure boot is enabled. So maybe this should only be done when secure boot is disabled.
Also note that setting the BootOrder EFI variable from inside the OS isn't supported by most (all?) boards currently supported by U-Boot. So a convenient way to set the BootOrder EFI variable from within U-Boot is needed.
Cheers,
Mark
P.S. Does grub support the EFI_DT_FIXUP_PROTOCOL these days? If not (or if your Linux distro still ships with an older version of grub) you'll face the same issue as OpenBSD regarding the lack of fixups for loaded devictrees.
Am 5. April 2023 23:56:59 MESZ schrieb Mark Kettenis mark.kettenis@xs4all.nl:
Hi Tom,
Hi Tom,
On Sat, 1 Apr 2023 at 07:02, Tom Rini trini@konsulko.com wrote: > > On Fri, Mar 31, 2023 at 10:25:56AM +1300, Simon Glass wrote: > > > The current EFI implementation has a strange quirk where it watches > > loaded files and uses the last-loaded file to determine the device
that
> > is being booted from. > > > > This is confusing with bootstd, where multiple options may exist.
Even
for
> > is the 'bootefi' command. > > > > To work around this, call efi_set_bootdev() for EFI images, if
possible,
> > just before booting. > > > > Signed-off-by: Simon Glass sjg@chromium.org > > Shouldn't this all be a simple wrapper around the EFI Standard > BootDeviceOrder or whatever that's called?
point
bootstd
The long answer:
Ubuntu has patched GRUB's devicetree command to call the protocol.
Currently a U-Boot boot option can define a kernel and an initrd to load. We could add the dtb location to the boot option in U-Boot.
The approach discussed on the Linux side is to provide drivers that replace runtime calls and directly interface with the variable storage.
Please, have a look at the eficonfig and efidebug commands.
Best regards
Heinrich
Cheers,
Mark
Hi Tom,
Hi Tom,
that
Even
for
possible,
point
bootstd
The long answer:
Cheers,
Mark
I just want to chime in and say thanks for explaining your use case, so we can make sure what we're doing will actually work for everyone.
Hi Tom,
Hi Tom,
Hi Tom,
that
Even
for
possible,
point
bootstd
That's all fine, but the goal here is to match the functionality we have today, i.e. the distroboot scripts. If people move to bootmgr for EFI at some point, that's a separate thing from this patch. If I am misunderstanding something, please let me know.
Regards, SImon
On Sat, Apr 08, 2023 at 06:55:20AM +1200, Simon Glass wrote:
Hi Tom,
Hi Tom,
Hi Tom,
that
Even
for
possible,
point
bootstd
Well, I'm going to change my mind (about a few things at this point) and say yes, OK, we'll go with replicating the current behavior first and make improvements on certain parts of the flow be a follow-up.
Hi Tom,
Hi Tom,
On Sat, Apr 01, 2023 at 07:31:49PM +1300, Simon Glass wrote: > Hi Tom, > > On Sat, 1 Apr 2023 at 07:02, Tom Rini trini@konsulko.com wrote: > > > > On Fri, Mar 31, 2023 at 10:25:56AM +1300, Simon Glass wrote: > > > > > The current EFI implementation has a strange quirk where it watches > > > loaded files and uses the last-loaded file to determine the device
that
> > > is being booted from. > > > > > > This is confusing with bootstd, where multiple options may exist.
Even
for
> > > is the 'bootefi' command. > > > > > > To work around this, call efi_set_bootdev() for EFI images, if
possible,
> > > just before booting. > > > > > > Signed-off-by: Simon Glass sjg@chromium.org > > > > Shouldn't this all be a simple wrapper around the EFI Standard > > BootDeviceOrder or whatever that's called? > > I think you are referring to boot manager, which isn't used here. This > is replicating the existing distroboot functionality in standard boot.
point
bootstd
I still don't think this is needed. The missing part from the efibootmgr which was left in the distroboot implementation was booting a default named binary (r.g bootaa64.efi for arm64) if no boot options were configured.
This is implementing the missing parts [0], so I would prefer not to replicate things.
[0] https://lore.kernel.org/u-boot/20230405000654.1121544-1-raymond.mao@linaro.o...
Cheers /Ilias
-- Tom
Hi Ilias,
On Sat, 8 Apr 2023 at 07:45, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Tom,
Hi Tom,
On Mon, Apr 03, 2023 at 12:56:49PM +0300, Ilias Apalodimas wrote: > On Sat, Apr 01, 2023 at 07:31:49PM +1300, Simon Glass wrote: > > Hi Tom, > > > > On Sat, 1 Apr 2023 at 07:02, Tom Rini trini@konsulko.com wrote: > > > > > > On Fri, Mar 31, 2023 at 10:25:56AM +1300, Simon Glass wrote: > > > > > > > The current EFI implementation has a strange quirk where it watches > > > > loaded files and uses the last-loaded file to determine the device that > > > > is being booted from. > > > > > > > > This is confusing with bootstd, where multiple options may exist. Even > > > > loading a device tree will cause it to go wrong. There is no API for > > > > passing this information, since the only entry into booting an EFI image > > > > is the 'bootefi' command. > > > > > > > > To work around this, call efi_set_bootdev() for EFI images, if possible, > > > > just before booting. > > > > > > > > Signed-off-by: Simon Glass sjg@chromium.org > > > > > > Shouldn't this all be a simple wrapper around the EFI Standard > > > BootDeviceOrder or whatever that's called? > > > > I think you are referring to boot manager, which isn't used here. This > > is replicating the existing distroboot functionality in standard boot. > > The distroboot functionality *was* trying to behave like the EFI spec > expects the bootmanager to behave. Unfortunately I haven't had time to > review the distroboot patches closely, but back when this started, my point > was that EFI doesn't need anything. Whenever the EFI flow is added bootstd > should 'just' call the bootmanager.
Are you saying you want to drop loading EFI files except through bootmgr? Won't that break distros which don't support it?
Hi Tom,
Hi Tom,
Didn't Mark explain that OpenBSD needs it? They too count as generic distribution. :)
Drop the distro-boot scripts and use standard boot instead.
(no changes since v4)
Changes in v4: - Add back BOOT_TARGETS
Changes in v3: - Update rk3588 boards too
Changes in v2: - Add new patch to move rockchip to standard boot
include/configs/px30_common.h | 3 +- include/configs/rk3036_common.h | 4 +-- include/configs/rk3066_common.h | 4 +-- include/configs/rk3128_common.h | 3 +- include/configs/rk3188_common.h | 4 +-- include/configs/rk322x_common.h | 4 +-- include/configs/rk3288_common.h | 4 +-- include/configs/rk3308_common.h | 3 +- include/configs/rk3328_common.h | 3 +- include/configs/rk3368_common.h | 6 ++-- include/configs/rk3568_common.h | 5 ++- include/configs/rk3588_common.h | 5 ++- include/configs/rockchip-common.h | 58 ------------------------------- include/configs/rv1108_common.h | 2 +- 14 files changed, 16 insertions(+), 92 deletions(-)
diff --git a/include/configs/px30_common.h b/include/configs/px30_common.h index 8df481b09788..6fbd2679f099 100644 --- a/include/configs/px30_common.h +++ b/include/configs/px30_common.h @@ -24,12 +24,11 @@ "kernel_addr_c=0x03e80000\0" \ "ramdisk_addr_r=0x0a200000\0"
-#include <config_distro_bootcmd.h> #define CFG_EXTRA_ENV_SETTINGS \ ENV_MEM_LAYOUT_SETTINGS \ "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ "partitions=" PARTS_DEFAULT \ ROCKCHIP_DEVICE_SETTINGS \ - BOOTENV + "boot_targets=" BOOT_TARGETS "\0"
#endif diff --git a/include/configs/rk3036_common.h b/include/configs/rk3036_common.h index ea6073f29446..c2abd14e114b 100644 --- a/include/configs/rk3036_common.h +++ b/include/configs/rk3036_common.h @@ -21,8 +21,6 @@ "kernel_addr_r=0x62000000\0" \ "ramdisk_addr_r=0x64000000\0"
-#include <config_distro_bootcmd.h> - /* Linux fails to load the fdt if it's loaded above 512M on a evb-rk3036 board, * so limit the fdt reallocation to that */ #define CFG_EXTRA_ENV_SETTINGS \ @@ -30,6 +28,6 @@ "fdt_high=0x7fffffff\0" \ "partitions=" PARTS_DEFAULT \ ENV_MEM_LAYOUT_SETTINGS \ - BOOTENV + "boot_targets=" BOOT_TARGETS "\0"
#endif diff --git a/include/configs/rk3066_common.h b/include/configs/rk3066_common.h index 1a6d3678df3e..d70c8f77d487 100644 --- a/include/configs/rk3066_common.h +++ b/include/configs/rk3066_common.h @@ -22,14 +22,12 @@ "kernel_addr_r=0x62000000\0" \ "ramdisk_addr_r=0x64000000\0"
-#include <config_distro_bootcmd.h> - #define CFG_EXTRA_ENV_SETTINGS \ "fdt_high=0x6fffffff\0" \ "initrd_high=0x6fffffff\0" \ "partitions=" PARTS_DEFAULT \ ENV_MEM_LAYOUT_SETTINGS \ ROCKCHIP_DEVICE_SETTINGS \ - BOOTENV + "boot_targets=" BOOT_TARGETS "\0"
#endif diff --git a/include/configs/rk3128_common.h b/include/configs/rk3128_common.h index 8736b14d1015..d8269b0ec96f 100644 --- a/include/configs/rk3128_common.h +++ b/include/configs/rk3128_common.h @@ -22,11 +22,10 @@ "kernel_addr_r=0x62000000\0" \ "ramdisk_addr_r=0x64000000\0"
-#include <config_distro_bootcmd.h> #define CFG_EXTRA_ENV_SETTINGS \ ENV_MEM_LAYOUT_SETTINGS \ "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ "partitions=" PARTS_DEFAULT \ - BOOTENV + "boot_targets=" BOOT_TARGETS "\0"
#endif diff --git a/include/configs/rk3188_common.h b/include/configs/rk3188_common.h index fcb274565e9e..a8cee1e44d4d 100644 --- a/include/configs/rk3188_common.h +++ b/include/configs/rk3188_common.h @@ -21,8 +21,6 @@ "kernel_addr_r=0x62000000\0" \ "ramdisk_addr_r=0x64000000\0"
-#include <config_distro_bootcmd.h> - /* Linux fails to load the fdt if it's loaded above 256M on a Rock board, * so limit the fdt reallocation to that */ #define CFG_EXTRA_ENV_SETTINGS \ @@ -32,6 +30,6 @@ "partitions=" PARTS_DEFAULT \ ENV_MEM_LAYOUT_SETTINGS \ ROCKCHIP_DEVICE_SETTINGS \ - BOOTENV + "boot_targets=" BOOT_TARGETS "\0"
#endif diff --git a/include/configs/rk322x_common.h b/include/configs/rk322x_common.h index 39a40f4e2d10..15f77df3e17e 100644 --- a/include/configs/rk322x_common.h +++ b/include/configs/rk322x_common.h @@ -22,8 +22,6 @@ "kernel_addr_r=0x62000000\0" \ "ramdisk_addr_r=0x64000000\0"
-#include <config_distro_bootcmd.h> - /* Linux fails to load the fdt if it's loaded above 512M on a evb-rk3036 board, * so limit the fdt reallocation to that */ #define CFG_EXTRA_ENV_SETTINGS \ @@ -31,6 +29,6 @@ "fdt_high=0x7fffffff\0" \ "partitions=" PARTS_DEFAULT \ ENV_MEM_LAYOUT_SETTINGS \ - BOOTENV + "boot_targets=" BOOT_TARGETS "\0"
#endif diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index 71d2426d72a4..3063076a97af 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -23,8 +23,6 @@ "kernel_addr_r=0x02000000\0" \ "ramdisk_addr_r=0x04000000\0"
-#include <config_distro_bootcmd.h> - /* Linux fails to load the fdt if it's loaded above 256M on a Rock 2 board, so * limit the fdt reallocation to that */ #define CFG_EXTRA_ENV_SETTINGS \ @@ -34,6 +32,6 @@ "partitions=" PARTS_DEFAULT \ ENV_MEM_LAYOUT_SETTINGS \ ROCKCHIP_DEVICE_SETTINGS \ - BOOTENV + "boot_targets=" BOOT_TARGETS "\0"
#endif diff --git a/include/configs/rk3308_common.h b/include/configs/rk3308_common.h index ba9ee112e2df..7d55fcd975c6 100644 --- a/include/configs/rk3308_common.h +++ b/include/configs/rk3308_common.h @@ -20,11 +20,10 @@ "kernel_addr_r=0x00680000\0" \ "ramdisk_addr_r=0x04000000\0"
-#include <config_distro_bootcmd.h> #define CFG_EXTRA_ENV_SETTINGS \ ENV_MEM_LAYOUT_SETTINGS \ "partitions=" PARTS_DEFAULT \ ROCKCHIP_DEVICE_SETTINGS \ - BOOTENV + "boot_targets=" BOOT_TARGETS "\0"
#endif diff --git a/include/configs/rk3328_common.h b/include/configs/rk3328_common.h index e565ccff8979..e920ec7e5ddb 100644 --- a/include/configs/rk3328_common.h +++ b/include/configs/rk3328_common.h @@ -22,11 +22,10 @@ "kernel_comp_addr_r=0x08000000\0" \ "kernel_comp_size=0x2000000\0"
-#include <config_distro_bootcmd.h> #define CFG_EXTRA_ENV_SETTINGS \ ENV_MEM_LAYOUT_SETTINGS \ "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ "partitions=" PARTS_DEFAULT \ - BOOTENV + "boot_targets=" BOOT_TARGETS "\0"
#endif diff --git a/include/configs/rk3368_common.h b/include/configs/rk3368_common.h index 9aa256b59592..ccb5369b9018 100644 --- a/include/configs/rk3368_common.h +++ b/include/configs/rk3368_common.h @@ -23,11 +23,9 @@ "kernel_addr_r=0x280000\0" \ "ramdisk_addr_r=0x5bf0000\0"
-#include <config_distro_bootcmd.h> - #define CFG_EXTRA_ENV_SETTINGS \ "fdtfile=" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ - ENV_MEM_LAYOUT_SETTINGS \ - BOOTENV + ENV_MEM_LAYOUT_SETTINGS \ + "boot_targets=" BOOT_TARGETS "\0"
#endif diff --git a/include/configs/rk3568_common.h b/include/configs/rk3568_common.h index a5e1dde50888..366ccc97db75 100644 --- a/include/configs/rk3568_common.h +++ b/include/configs/rk3568_common.h @@ -22,12 +22,11 @@ "kernel_addr_r=0x02080000\0" \ "ramdisk_addr_r=0x0a200000\0"
-#include <config_distro_bootcmd.h> #define CFG_EXTRA_ENV_SETTINGS \ ENV_MEM_LAYOUT_SETTINGS \ "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ "partitions=" PARTS_DEFAULT \ - ROCKCHIP_DEVICE_SETTINGS \ - BOOTENV + ROCKCHIP_DEVICE_SETTINGS \ + "boot_targets=" BOOT_TARGETS "\0"
#endif diff --git a/include/configs/rk3588_common.h b/include/configs/rk3588_common.h index abd20139aaf3..1cc16fe15206 100644 --- a/include/configs/rk3588_common.h +++ b/include/configs/rk3588_common.h @@ -21,12 +21,11 @@ "kernel_addr_r=0x02080000\0" \ "ramdisk_addr_r=0x0a200000\0"
-#include <config_distro_bootcmd.h> #define CFG_EXTRA_ENV_SETTINGS \ "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ "partitions=" PARTS_DEFAULT \ ENV_MEM_LAYOUT_SETTINGS \ - ROCKCHIP_DEVICE_SETTINGS \ - BOOTENV + ROCKCHIP_DEVICE_SETTINGS \ + "boot_targets=" BOOT_TARGETS "\0"
#endif /* __CONFIG_RK3588_COMMON_H */ diff --git a/include/configs/rockchip-common.h b/include/configs/rockchip-common.h index 18544d75acc6..e9f4072b7e78 100644 --- a/include/configs/rockchip-common.h +++ b/include/configs/rockchip-common.h @@ -13,67 +13,9 @@
#ifndef CONFIG_SPL_BUILD
-/* First try to boot from SD (index 1), then eMMC (index 0) */ -#if IS_ENABLED(CONFIG_CMD_MMC) - #define BOOT_TARGET_MMC(func) \ - func(MMC, mmc, 1) \ - func(MMC, mmc, 0) -#else - #define BOOT_TARGET_MMC(func) -#endif - -#if IS_ENABLED(CONFIG_CMD_NVME) - #define BOOT_TARGET_NVME(func) func(NVME, nvme, 0) -#else - #define BOOT_TARGET_NVME(func) -#endif - -#if IS_ENABLED(CONFIG_CMD_SCSI) - #define BOOT_TARGET_SCSI(func) func(SCSI, scsi, 0) -#else - #define BOOT_TARGET_SCSI(func) -#endif - -#if IS_ENABLED(CONFIG_CMD_USB) - #define BOOT_TARGET_USB(func) func(USB, usb, 0) -#else - #define BOOT_TARGET_USB(func) -#endif - -#if CONFIG_IS_ENABLED(CMD_PXE) - #define BOOT_TARGET_PXE(func) func(PXE, pxe, na) -#else - #define BOOT_TARGET_PXE(func) -#endif - -#if CONFIG_IS_ENABLED(CMD_DHCP) - #define BOOT_TARGET_DHCP(func) func(DHCP, dhcp, na) -#else - #define BOOT_TARGET_DHCP(func) -#endif - -#if IS_ENABLED(CONFIG_CMD_SF) - #define BOOT_TARGET_SF(func) func(SF, sf, 0) -#else - #define BOOT_TARGET_SF(func) -#endif - #ifdef CONFIG_ROCKCHIP_RK3399 -#define BOOT_TARGET_DEVICES(func) \ - BOOT_TARGET_MMC(func) \ - BOOT_TARGET_NVME(func) \ - BOOT_TARGET_SCSI(func) \ - BOOT_TARGET_USB(func) \ - BOOT_TARGET_PXE(func) \ - BOOT_TARGET_DHCP(func) \ - BOOT_TARGET_SF(func) #define BOOT_TARGETS "mmc1 mmc0 nvme scsi usb pxe dhcp spi" #else -#define BOOT_TARGET_DEVICES(func) \ - BOOT_TARGET_MMC(func) \ - BOOT_TARGET_USB(func) \ - BOOT_TARGET_PXE(func) \ - BOOT_TARGET_DHCP(func) #define BOOT_TARGETS "mmc1 mmc0 usb pxe dhcp" #endif
diff --git a/include/configs/rv1108_common.h b/include/configs/rv1108_common.h index 050d37bff0b5..3bf70a0e0ae2 100644 --- a/include/configs/rv1108_common.h +++ b/include/configs/rv1108_common.h @@ -28,6 +28,6 @@ ENV_MEM_LAYOUT_SETTINGS \ "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ "partitions=" PARTS_DEFAULT \ - BOOTENV + "boot_targets=" BOOT_TARGETS "\0"
#endif
It doesn't really matter if we mention things which are not present. For example, if 'nvme' is included but the board does not support it, we get a message like:
Unknown uclass 'nvme' in label
This seems tolerable. If it creates confusion we could perhaps find a way to avoid the message, e.g. by maintaining a list of uclasses which may be missing from the build and supressing warnings about them.
It is simpler to use the same target list for all boards, so drop the different one for rk3399.
Changes in v5: - Drop patch to relax the argument requirements for bootflow scan
Changes in v4: - Rebase to -next - Add new patch to use the same boot_targets for all boards
include/configs/rockchip-common.h | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/include/configs/rockchip-common.h b/include/configs/rockchip-common.h index e9f4072b7e78..9121bba37384 100644 --- a/include/configs/rockchip-common.h +++ b/include/configs/rockchip-common.h @@ -13,11 +13,7 @@
-#ifdef CONFIG_ROCKCHIP_RK3399 #define BOOT_TARGETS "mmc1 mmc0 nvme scsi usb pxe dhcp spi" -#else -#define BOOT_TARGETS "mmc1 mmc0 usb pxe dhcp" -#endif
#ifdef CONFIG_ARM64 #define ROOT_UUID "B921B045-1DF0-41C3-AF44-4C6F280D3FAE;\0"
Enable some messages that might provide hints, but only for CMD_BOOTFLOW_FULL since otherwise the -l flag is not available.
(no changes since v1)
cmd/bootflow.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/cmd/bootflow.c b/cmd/bootflow.c index 42f6e14a4370..aa06999e3db3 100644 --- a/cmd/bootflow.c +++ b/cmd/bootflow.c @@ -181,6 +181,9 @@ static int do_bootflow_scan(struct cmd_tbl *cmdtp, int flag, int argc, if (list) show_footer(i, num_valid);
+ if (IS_ENABLED(CONFIG_CMD_BOOTFLOW_FULL) && !num_valid && !list) + printf("No bootflows found; try again with -l\n"); + return 0; }
Use the -l flag to indicate whether to report missing uclasses.
Also try to be more helpful when no devices are found. For example, when we see something 'scsi0' requested and nothing was found, this indicates that there are no SCSI devices, so show a suitable message.
Move messages out of the low-level functions so that silent operation is possible.
This means they are never reported unless BOOTSTD_FULL is enabled, since that flag cannot otherwise be set.
boot/bootdev-uclass.c | 32 +++++++++++++++++++++++++------- include/bootdev.h | 2 +- test/boot/bootdev.c | 12 +++++------- 3 files changed, 31 insertions(+), 15 deletions(-)
diff --git a/boot/bootdev-uclass.c b/boot/bootdev-uclass.c index d34b7e37cf79..91087981d213 100644 --- a/boot/bootdev-uclass.c +++ b/boot/bootdev-uclass.c @@ -364,7 +364,8 @@ int bootdev_unbind_dev(struct udevice *parent) * @seqp: Returns the sequence number, or -1 if none * @method_flagsp: If non-NULL, returns any flags implied by the label * (enum bootflow_meth_flags_t), 0 if none - * Returns: sequence number on success, else -ve error code + * Returns: sequence number on success, -EPFNOSUPPORT is the uclass is not + * known, other -ve error code on other error */ static int label_to_uclass(const char *label, int *seqp, int *method_flagsp) { @@ -394,8 +395,7 @@ static int label_to_uclass(const char *label, int *seqp, int *method_flagsp) id = UCLASS_ETH; method_flags |= BOOTFLOW_METHF_DHCP_ONLY; } else { - log_warning("Unknown uclass '%s' in label\n", label); - return -EINVAL; + return -EPFNOSUPPORT; } } if (id == UCLASS_USB) @@ -458,7 +458,6 @@ int bootdev_find_by_label(const char *label, struct udevice **devp, } log_debug("- no device in %s\n", media->name); } - log_warning("Unknown seq %d for label '%s'\n", seq, label);
return -ENOENT; } @@ -577,9 +576,28 @@ int bootdev_next_label(struct bootflow_iter *iter, struct udevice **devp,
log_debug("next\n"); for (dev = NULL; !dev && iter->labels[++iter->cur_label];) { - log_debug("Scanning: %s\n", iter->labels[iter->cur_label]); - bootdev_hunt_and_find_by_label(iter->labels[iter->cur_label], - &dev, method_flagsp); + const char *label = iter->labels[iter->cur_label]; + int ret; + + log_debug("Scanning: %s\n", label); + ret = bootdev_hunt_and_find_by_label(label, &dev, + method_flagsp); + if (iter->flags & BOOTFLOWIF_SHOW) { + if (ret == -EPFNOSUPPORT) { + log_warning("Unknown uclass '%s' in label\n", + label); + } else if (ret == -ENOENT) { + /* + * looking for, e.g. 'scsi0' should find + * something if SCSI is present + */ + if (!trailing_strtol(label)) { + log_warning("No bootdevs for '%s'\n", + label); + } + } + } + }
if (!dev) diff --git a/include/bootdev.h b/include/bootdev.h index b92ff4d4f154..e72ef3650f7c 100644 --- a/include/bootdev.h +++ b/include/bootdev.h @@ -258,7 +258,7 @@ int bootdev_find_by_label(const char *label, struct udevice **devp, * @devp: returns the device found, on success * @method_flagsp: If non-NULL, returns any flags implied by the label * (enum bootflow_meth_flags_t), 0 if none. Unset if function fails - * Return: 0 if OK, -EINVAL if the uclass is not supported by this board, + * Return: 0 if OK, -EPFNOSUPPORT if the uclass is not supported by this board, * -ENOENT if there is no device with that number */ int bootdev_find_by_any(const char *name, struct udevice **devp, diff --git a/test/boot/bootdev.c b/test/boot/bootdev.c index 4fe9fd722084..0899c78c2c4a 100644 --- a/test/boot/bootdev.c +++ b/test/boot/bootdev.c @@ -124,7 +124,8 @@ static int bootdev_test_labels(struct unit_test_state *uts) mflags);
/* Check invalid uclass */ - ut_asserteq(-EINVAL, bootdev_find_by_label("fred0", &dev, &mflags)); + ut_asserteq(-EPFNOSUPPORT, + bootdev_find_by_label("fred0", &dev, &mflags));
/* Check unknown sequence number */ ut_asserteq(-ENOENT, bootdev_find_by_label("mmc6", &dev, &mflags)); @@ -179,9 +180,8 @@ static int bootdev_test_any(struct unit_test_state *uts)
/* Check invalid uclass */ mflags = 123; - ut_asserteq(-EINVAL, bootdev_find_by_any("fred0", &dev, &mflags)); - ut_assert_nextline("Unknown uclass 'fred0' in label"); - ut_assert_nextline("Cannot find bootdev 'fred0' (err=-22)"); + ut_asserteq(-EPFNOSUPPORT, bootdev_find_by_any("fred0", &dev, &mflags)); + ut_assert_nextline("Cannot find bootdev 'fred0' (err=-96)"); ut_asserteq(123, mflags); ut_assert_console_end();
@@ -512,9 +512,8 @@ static int bootdev_test_hunt_label(struct unit_test_state *uts) old = (void *)&mflags; /* arbitrary pointer to check against dev */ dev = old; mflags = 123; - ut_asserteq(-EINVAL, + ut_asserteq(-EPFNOSUPPORT, bootdev_hunt_and_find_by_label("fred", &dev, &mflags)); - ut_assert_nextline("Unknown uclass 'fred' in label"); ut_asserteq_ptr(old, dev); ut_asserteq(123, mflags); ut_assert_console_end(); @@ -525,7 +524,6 @@ static int bootdev_test_hunt_label(struct unit_test_state *uts) bootdev_hunt_and_find_by_label("mmc4", &dev, &mflags)); ut_asserteq_ptr(old, dev); ut_asserteq(123, mflags); - ut_assert_nextline("Unknown seq 4 for label 'mmc4'"); ut_assert_console_end();
ut_assertok(bootstd_test_check_mmc_hunter(uts));
This is needed to enable the boot command used to start standard boot. Enable it by default. This brings in quite a few features, mostly in common with DISTRO_DEFAULTS
Exclude boards which have what looks like a custom boot command:
git grep CONFIG_BOOTCOM configs/* |grep -v distro_bootcmd | sed -n 's/configs/(.*)_defconfig.*/\1/p'
Disable this option for boards which don't have enough space.
Disable CONFIG_ENV_VARS_UBOOT_CONFIG for some Xilinx boards which have a very small environment. Disable BOOTSTD_DEFAULTS for smartweb since it is too close to its limit.
boot/Kconfig | 1 + configs/M5253DEMO_defconfig | 3 --- configs/MPC837XERDB_defconfig | 4 ---- configs/P1010RDB-PA_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PA_NAND_defconfig | 1 + configs/P1010RDB-PA_NOR_defconfig | 1 + configs/P1010RDB-PA_SDCARD_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_NAND_defconfig | 1 + configs/P1010RDB-PB_NOR_defconfig | 1 + configs/P1010RDB-PB_SDCARD_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_36BIT_defconfig | 1 + configs/P1020RDB-PC_NAND_defconfig | 1 + configs/P1020RDB-PC_SDCARD_defconfig | 1 + configs/P1020RDB-PC_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_defconfig | 1 + configs/P1020RDB-PD_NAND_defconfig | 1 + configs/P1020RDB-PD_SDCARD_defconfig | 1 + configs/P1020RDB-PD_SPIFLASH_defconfig | 1 + configs/P1020RDB-PD_defconfig | 1 + configs/P2020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_36BIT_defconfig | 1 + configs/P2020RDB-PC_NAND_defconfig | 1 + configs/P2020RDB-PC_SDCARD_defconfig | 1 + configs/P2020RDB-PC_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_defconfig | 1 + configs/P2041RDB_NAND_defconfig | 1 + configs/P2041RDB_SDCARD_defconfig | 1 + configs/P2041RDB_SPIFLASH_defconfig | 1 + configs/P2041RDB_defconfig | 1 + configs/T1024RDB_NAND_defconfig | 1 + configs/T1024RDB_SDCARD_defconfig | 1 + configs/T1024RDB_SPIFLASH_defconfig | 1 + configs/T1024RDB_defconfig | 1 + configs/T1042D4RDB_NAND_defconfig | 1 + configs/T1042D4RDB_SDCARD_defconfig | 1 + configs/T1042D4RDB_SPIFLASH_defconfig | 1 + configs/T1042D4RDB_defconfig | 1 + configs/T2080QDS_NAND_defconfig | 1 + configs/T2080QDS_SDCARD_defconfig | 1 + configs/T2080QDS_SECURE_BOOT_defconfig | 1 + configs/T2080QDS_SPIFLASH_defconfig | 1 + configs/T2080QDS_SRIO_PCIE_BOOT_defconfig | 1 + configs/T2080QDS_defconfig | 1 + configs/T2080RDB_NAND_defconfig | 1 + configs/T2080RDB_SDCARD_defconfig | 1 + configs/T2080RDB_SPIFLASH_defconfig | 1 + configs/T2080RDB_defconfig | 1 + configs/T2080RDB_revD_NAND_defconfig | 1 + configs/T2080RDB_revD_SDCARD_defconfig | 1 + configs/T2080RDB_revD_SPIFLASH_defconfig | 1 + configs/T2080RDB_revD_defconfig | 1 + configs/T4240RDB_SDCARD_defconfig | 1 + configs/T4240RDB_defconfig | 1 + configs/alt_defconfig | 8 -------- configs/am335x_baltos_defconfig | 1 + configs/am335x_igep003x_defconfig | 1 + configs/am335x_pdu001_defconfig | 1 + configs/am335x_shc_defconfig | 1 + configs/am335x_shc_ict_defconfig | 1 + configs/am335x_shc_netboot_defconfig | 1 + configs/am335x_shc_sdboot_defconfig | 1 + configs/am3517_evm_defconfig | 1 + configs/am62ax_evm_r5_defconfig | 1 - configs/am62x_evm_r5_defconfig | 1 - configs/am64x_evm_a53_defconfig | 1 + configs/am64x_evm_r5_defconfig | 4 ---- configs/am65x_evm_r5_defconfig | 3 --- configs/am65x_evm_r5_usbdfu_defconfig | 4 ---- configs/am65x_evm_r5_usbmsc_defconfig | 4 ---- configs/am65x_hs_evm_a53_defconfig | 1 + configs/am65x_hs_evm_r5_defconfig | 3 --- configs/arbel_evb_defconfig | 1 + configs/aristainetos2c_defconfig | 1 + configs/aristainetos2ccslb_defconfig | 1 + configs/at91sam9260ek_dataflash_cs0_defconfig | 1 + configs/at91sam9260ek_dataflash_cs1_defconfig | 1 + configs/at91sam9260ek_nandflash_defconfig | 1 + configs/at91sam9261ek_dataflash_cs0_defconfig | 1 + configs/at91sam9261ek_dataflash_cs3_defconfig | 1 + configs/at91sam9261ek_nandflash_defconfig | 1 + configs/at91sam9263ek_dataflash_cs0_defconfig | 1 + configs/at91sam9263ek_dataflash_defconfig | 1 + configs/at91sam9263ek_nandflash_defconfig | 1 + configs/at91sam9263ek_norflash_boot_defconfig | 4 ---- configs/at91sam9263ek_norflash_defconfig | 4 ---- configs/at91sam9g10ek_dataflash_cs0_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs3_defconfig | 1 + configs/at91sam9g10ek_nandflash_defconfig | 1 + configs/at91sam9g20ek_2mmc_defconfig | 1 + configs/at91sam9g20ek_2mmc_nandflash_defconfig | 1 + configs/at91sam9g20ek_dataflash_cs0_defconfig | 1 + configs/at91sam9g20ek_dataflash_cs1_defconfig | 1 + configs/at91sam9g20ek_nandflash_defconfig | 1 + configs/at91sam9m10g45ek_mmc_defconfig | 1 + configs/at91sam9m10g45ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_mmc_defconfig | 1 + configs/at91sam9n12ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_spiflash_defconfig | 1 + configs/at91sam9rlek_dataflash_defconfig | 1 + configs/at91sam9rlek_mmc_defconfig | 1 + configs/at91sam9rlek_nandflash_defconfig | 1 + configs/at91sam9x5ek_dataflash_defconfig | 1 + configs/at91sam9x5ek_mmc_defconfig | 5 ----- configs/at91sam9x5ek_nandflash_defconfig | 1 + configs/at91sam9x5ek_spiflash_defconfig | 1 + configs/at91sam9xeek_dataflash_cs0_defconfig | 1 + configs/at91sam9xeek_dataflash_cs1_defconfig | 1 + configs/at91sam9xeek_nandflash_defconfig | 1 + configs/axs101_defconfig | 6 ------ configs/axs103_defconfig | 6 ------ configs/bayleybay_defconfig | 1 + configs/bcm7260_defconfig | 4 ---- configs/bcm7445_defconfig | 4 ---- configs/bcm947622_defconfig | 1 - configs/bcm94908_defconfig | 1 - configs/bcm94912_defconfig | 1 - configs/bcm963138_defconfig | 1 - configs/bcm963146_defconfig | 1 - configs/bcm963148_defconfig | 1 - configs/bcm963158_defconfig | 1 - configs/bcm963178_defconfig | 1 - configs/bcm96756_defconfig | 1 - configs/bcm96813_defconfig | 1 - configs/bcm96846_defconfig | 1 - configs/bcm96855_defconfig | 1 - configs/bcm96856_defconfig | 1 - configs/bcm96858_defconfig | 1 - configs/bcm96878_defconfig | 1 - configs/bcm_ns3_defconfig | 1 + configs/bitmain_antminer_s9_defconfig | 10 ---------- configs/bk4r1_defconfig | 1 + configs/blanche_defconfig | 8 -------- configs/brppt1_mmc_defconfig | 1 + configs/brppt2_defconfig | 1 + configs/brsmarc1_defconfig | 1 + configs/brxre1_defconfig | 1 + configs/cgtqmx8_defconfig | 1 + configs/cherryhill_defconfig | 1 + configs/chiliboard_defconfig | 1 + configs/chromebook_coral_defconfig | 1 + configs/chromebook_link64_defconfig | 1 + configs/chromebook_link_defconfig | 1 + configs/chromebook_samus_defconfig | 1 + configs/chromebook_samus_tpl_defconfig | 1 + configs/chromebox_panther_defconfig | 1 + configs/ci20_mmc_defconfig | 1 + configs/cl-som-imx7_defconfig | 1 + configs/cm_t43_defconfig | 1 + configs/colibri_vf_defconfig | 11 ----------- configs/comtrend_ar5315u_ram_defconfig | 3 --- configs/comtrend_ar5387un_ram_defconfig | 3 --- configs/comtrend_ct5361_ram_defconfig | 3 --- configs/comtrend_vr3032u_ram_defconfig | 3 --- configs/comtrend_wap5813n_ram_defconfig | 3 --- .../conga-qeval20-qa3-e3845-internal-uart_defconfig | 1 + configs/conga-qeval20-qa3-e3845_defconfig | 1 + configs/controlcenterdc_defconfig | 1 + configs/coreboot64_defconfig | 1 + configs/coreboot_defconfig | 1 + configs/cortina_presidio-asic-emmc_defconfig | 3 --- configs/corvus_defconfig | 1 + configs/cougarcanyon2_defconfig | 1 + configs/crownbay_defconfig | 1 + configs/d2net_v2_defconfig | 1 + configs/da850evm_defconfig | 1 + configs/da850evm_direct_nor_defconfig | 1 + configs/da850evm_nand_defconfig | 1 + configs/db-88f6720_defconfig | 8 -------- configs/db-88f6820-amc_defconfig | 9 --------- configs/db-88f6820-amc_nand_defconfig | 9 --------- configs/db-88f6820-gp_defconfig | 9 --------- configs/db-mv784mp-gp_defconfig | 9 --------- configs/db-xc3-24g4xg_defconfig | 8 -------- configs/deneb_defconfig | 1 + configs/devkit8000_defconfig | 1 + configs/dfi-bt700-q7x-151_defconfig | 1 + configs/display5_defconfig | 1 + configs/display5_factory_defconfig | 1 + configs/dns325_defconfig | 1 + configs/dockstar_defconfig | 1 + configs/draco_defconfig | 5 ----- configs/dreamplug_defconfig | 1 + configs/ds109_defconfig | 1 + configs/ds414_defconfig | 1 + configs/edison_defconfig | 4 ---- configs/efi-x86_payload32_defconfig | 1 + configs/efi-x86_payload64_defconfig | 1 + configs/emsdp_defconfig | 1 - configs/etamin_defconfig | 5 ----- configs/ethernut5_defconfig | 1 + configs/ev-imx280-nano-x-mb_defconfig | 7 ------- configs/evb-ast2600_defconfig | 1 + configs/evb-rv1108_defconfig | 1 + configs/galileo_defconfig | 1 + configs/gazerbeam_defconfig | 1 + configs/ge_b1x5v2_defconfig | 1 + configs/ge_bx50v3_defconfig | 1 + configs/giedi_defconfig | 1 + configs/goflexhome_defconfig | 1 + configs/gose_defconfig | 8 -------- configs/grpeach_defconfig | 6 ------ configs/gurnard_defconfig | 5 ----- configs/guruplug_defconfig | 1 + configs/gwventana_emmc_defconfig | 1 + configs/gwventana_gw5904_defconfig | 1 + configs/gwventana_nand_defconfig | 1 + configs/hihope_rzg2_defconfig | 1 + configs/hsdk_4xd_defconfig | 6 ------ configs/hsdk_defconfig | 6 ------ configs/huawei_hg556a_ram_defconfig | 3 --- configs/ib62x0_defconfig | 1 + configs/iconnect_defconfig | 1 + configs/imx28_xea_defconfig | 1 + configs/imx28_xea_sb_defconfig | 7 ------- configs/imx6dl_icore_nand_defconfig | 1 + configs/imx6q_bosch_acc_defconfig | 1 + configs/imx6q_icore_nand_defconfig | 1 + configs/imx6q_logic_defconfig | 1 + configs/imx6qdl_icore_mipi_defconfig | 1 + configs/imx6qdl_icore_mmc_defconfig | 1 + configs/imx6qdl_icore_nand_defconfig | 1 + configs/imx6qdl_icore_rqs_defconfig | 1 + configs/imx6ul_geam_mmc_defconfig | 1 + configs/imx6ul_geam_nand_defconfig | 1 + configs/imx6ul_isiot_emmc_defconfig | 1 + configs/imx6ul_isiot_nand_defconfig | 1 + configs/imx7_cm_defconfig | 1 + configs/imx8mm-mx8menlo_defconfig | 1 + configs/imx8mm_beacon_defconfig | 1 + configs/imx8mm_data_modul_edm_sbc_defconfig | 1 + configs/imx8mn_beacon_2g_defconfig | 1 + configs/imx8mn_beacon_defconfig | 1 + configs/imx8mn_beacon_fspi_defconfig | 1 + configs/imx8mp_dhcom_pdk2_defconfig | 13 ------------- configs/imx8mq_phanbell_defconfig | 1 + configs/imx8qm_mek_defconfig | 1 + configs/imx8qm_rom7720_a1_4G_defconfig | 1 + configs/imx8qxp_mek_defconfig | 1 + configs/inetspace_v2_defconfig | 1 + configs/iot_devkit_defconfig | 2 -- configs/j7200_evm_a72_defconfig | 1 + configs/j7200_evm_r5_defconfig | 3 --- configs/j7200_hs_evm_a72_defconfig | 1 + configs/j7200_hs_evm_r5_defconfig | 3 --- configs/j721e_evm_r5_defconfig | 3 --- configs/j721e_hs_evm_a72_defconfig | 1 + configs/j721e_hs_evm_r5_defconfig | 3 --- configs/j721s2_evm_a72_defconfig | 1 + configs/j721s2_evm_r5_defconfig | 3 --- configs/j721s2_hs_evm_a72_defconfig | 1 + configs/j721s2_hs_evm_r5_defconfig | 3 --- configs/k2e_evm_defconfig | 1 + configs/k2e_hs_evm_defconfig | 1 + configs/k2g_evm_defconfig | 1 + configs/k2g_hs_evm_defconfig | 1 + configs/k2hk_evm_defconfig | 1 + configs/k2hk_hs_evm_defconfig | 1 + configs/k2l_evm_defconfig | 1 + configs/k2l_hs_evm_defconfig | 1 + configs/kmcent2_defconfig | 4 ---- configs/koelsch_defconfig | 8 -------- configs/kp_imx53_defconfig | 11 ----------- configs/lager_defconfig | 8 -------- configs/legoev3_defconfig | 1 + configs/linkit-smart-7688_defconfig | 8 -------- configs/liteboard_defconfig | 1 + configs/ls1021aiot_qspi_defconfig | 6 ------ configs/ls1021aiot_sdcard_defconfig | 6 ------ configs/ls1021aqds_ddr4_nor_defconfig | 7 ------- configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 7 ------- configs/ls1021aqds_nand_defconfig | 7 ------- configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 7 ------- configs/ls1021aqds_nor_defconfig | 7 ------- configs/ls1021aqds_nor_lpuart_defconfig | 7 ------- configs/ls1021aqds_qspi_defconfig | 7 ------- configs/ls1021aqds_sdcard_ifc_defconfig | 7 ------- configs/ls1021aqds_sdcard_qspi_defconfig | 7 ------- configs/ls1088aqds_defconfig | 1 + configs/ls1088aqds_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1088aqds_qspi_defconfig | 1 + configs/ls1088aqds_sdcard_ifc_defconfig | 1 + configs/ls1088aqds_sdcard_qspi_defconfig | 1 + configs/ls2080aqds_SECURE_BOOT_defconfig | 1 + configs/ls2080aqds_defconfig | 1 + configs/ls2080aqds_nand_defconfig | 1 + configs/ls2080aqds_qspi_defconfig | 1 + configs/ls2080aqds_sdcard_defconfig | 1 + configs/m53menlo_defconfig | 1 + configs/malta64_defconfig | 2 -- configs/malta64el_defconfig | 2 -- configs/malta_defconfig | 2 -- configs/maltael_defconfig | 2 -- configs/meerkat96_defconfig | 7 ------- configs/minnowmax_defconfig | 1 + configs/mt7620_rfb_defconfig | 4 ---- configs/mt7621_nand_rfb_defconfig | 5 ----- configs/mt7621_rfb_defconfig | 3 --- configs/mt7622_rfb_defconfig | 1 - configs/mt7629_rfb_defconfig | 4 ---- configs/mt7981_emmc_rfb_defconfig | 4 ---- configs/mt7981_sd_rfb_defconfig | 4 ---- configs/mt7986a_bpir3_emmc_defconfig | 4 ---- configs/mt7986a_bpir3_sd_defconfig | 4 ---- configs/mt8183_pumpkin_defconfig | 6 ------ configs/mt8512_bm1_emmc_defconfig | 4 ---- configs/mt8516_pumpkin_defconfig | 7 ------- configs/mt8518_ap1_emmc_defconfig | 1 - configs/mx23_olinuxino_defconfig | 1 + configs/mx23evk_defconfig | 1 + configs/mx28evk_defconfig | 1 + configs/mx51evk_defconfig | 1 + configs/mx53loco_defconfig | 1 + configs/mx53ppd_defconfig | 1 + configs/mx6sabreauto_defconfig | 1 + configs/mx6sabresd_defconfig | 1 + configs/mx6slevk_defconfig | 1 + configs/mx6slevk_spinor_defconfig | 1 + configs/mx6slevk_spl_defconfig | 1 + configs/mx6sllevk_defconfig | 1 + configs/mx6sllevk_plugin_defconfig | 1 + configs/mx6sxsabreauto_defconfig | 1 + configs/mx6sxsabresd_defconfig | 1 + configs/mx6ul_14x14_evk_defconfig | 1 + configs/mx6ul_9x9_evk_defconfig | 1 + configs/mx6ull_14x14_evk_defconfig | 1 + configs/mx6ull_14x14_evk_plugin_defconfig | 1 + configs/mx6ulz_14x14_evk_defconfig | 1 + configs/mx7ulp_com_defconfig | 1 + configs/mx7ulp_evk_defconfig | 1 + configs/mx7ulp_evk_plugin_defconfig | 1 + configs/nas220_defconfig | 11 ----------- configs/net2big_v2_defconfig | 1 + configs/netgear_dgnd3700v2_ram_defconfig | 3 --- configs/netspace_lite_v2_defconfig | 1 + configs/netspace_max_v2_defconfig | 1 + configs/netspace_mini_v2_defconfig | 1 + configs/netspace_v2_defconfig | 1 + configs/nitrogen6dl2g_defconfig | 11 ----------- configs/nitrogen6dl_defconfig | 11 ----------- configs/nitrogen6q2g_defconfig | 11 ----------- configs/nitrogen6q_defconfig | 11 ----------- configs/nitrogen6s1g_defconfig | 11 ----------- configs/nitrogen6s_defconfig | 11 ----------- configs/nsim_hs38_defconfig | 1 - configs/o4-imx6ull-nano_defconfig | 7 ------- configs/octeon_ebb7304_defconfig | 9 --------- configs/octeon_nic23_defconfig | 7 ------- configs/octeontx2_95xx_defconfig | 11 ----------- configs/octeontx2_96xx_defconfig | 12 ------------ configs/octeontx_81xx_defconfig | 12 ------------ configs/octeontx_83xx_defconfig | 12 ------------ configs/omap35_logic_defconfig | 1 + configs/omap35_logic_somlv_defconfig | 1 + configs/omap3_logic_defconfig | 1 + configs/omap3_logic_somlv_defconfig | 1 + configs/omapl138_lcdk_defconfig | 1 + configs/openpiton_riscv64_defconfig | 1 + configs/openpiton_riscv64_spl_defconfig | 1 + configs/openrd_base_defconfig | 1 + configs/openrd_client_defconfig | 1 + configs/openrd_ultimate_defconfig | 1 + configs/opos6uldev_defconfig | 1 + configs/origen_defconfig | 1 + configs/pcm052_defconfig | 1 + configs/pcm058_defconfig | 1 + configs/phycore-am335x-r2-regor_defconfig | 7 ------- configs/phycore-am335x-r2-wega_defconfig | 7 ------- configs/phycore-imx8mm_defconfig | 1 + configs/phycore-imx8mp_defconfig | 1 + configs/phycore_pcl063_ull_defconfig | 1 + configs/pico-imx6_defconfig | 1 + configs/pico-imx7d_bl33_defconfig | 6 ------ configs/pico-imx8mq_defconfig | 1 + configs/pm9261_defconfig | 1 + configs/pm9263_defconfig | 1 + configs/pm9g45_defconfig | 1 + configs/pogo_e02_defconfig | 1 + configs/poleg_evb_defconfig | 1 + configs/porter_defconfig | 8 -------- configs/pxm2_defconfig | 6 ------ configs/qcs404evb_defconfig | 6 ------ configs/qemu-ppce500_defconfig | 1 + configs/qemu_arm64_defconfig | 1 - configs/qemu_arm_defconfig | 1 - configs/r2dplus_defconfig | 4 ---- configs/r8a77980_condor_defconfig | 1 + configs/r8a77990_ebisu_defconfig | 1 + configs/r8a77995_draak_defconfig | 1 + configs/r8a779a0_falcon_defconfig | 1 + configs/rastaban_defconfig | 5 ----- configs/rcar3_ulcb_defconfig | 1 + configs/rut_defconfig | 6 ------ configs/rzg2_beacon_defconfig | 1 + configs/s5p4418_nanopi2_defconfig | 4 ---- configs/s5p_goni_defconfig | 1 + configs/s5pc210_universal_defconfig | 1 + configs/sam9x60_curiosity_mmc1_defconfig | 1 + configs/sam9x60_curiosity_mmc_defconfig | 1 + configs/sam9x60ek_mmc_defconfig | 1 + configs/sam9x60ek_nandflash_defconfig | 1 + configs/sam9x60ek_qspiflash_defconfig | 1 + configs/sama5d27_giantboard_defconfig | 1 + configs/sama5d27_som1_ek_mmc1_defconfig | 1 + configs/sama5d27_som1_ek_mmc_defconfig | 1 + configs/sama5d27_som1_ek_qspiflash_defconfig | 1 + configs/sama5d27_wlsom1_ek_mmc_defconfig | 1 + configs/sama5d27_wlsom1_ek_qspiflash_defconfig | 1 + configs/sama5d2_icp_mmc_defconfig | 1 + configs/sama5d2_icp_qspiflash_defconfig | 1 + configs/sama5d2_ptc_ek_mmc_defconfig | 1 + configs/sama5d2_ptc_ek_nandflash_defconfig | 1 + configs/sama5d2_xplained_emmc_defconfig | 1 + configs/sama5d2_xplained_mmc_defconfig | 1 + configs/sama5d2_xplained_qspiflash_defconfig | 1 + configs/sama5d2_xplained_spiflash_defconfig | 1 + configs/sama5d36ek_cmp_mmc_defconfig | 1 + configs/sama5d36ek_cmp_nandflash_defconfig | 1 + configs/sama5d36ek_cmp_spiflash_defconfig | 1 + configs/sama5d3_xplained_mmc_defconfig | 1 + configs/sama5d3_xplained_nandflash_defconfig | 1 + configs/sama5d3xek_mmc_defconfig | 1 + configs/sama5d3xek_nandflash_defconfig | 1 + configs/sama5d3xek_spiflash_defconfig | 1 + configs/sama5d4_xplained_mmc_defconfig | 1 + configs/sama5d4_xplained_nandflash_defconfig | 1 + configs/sama5d4_xplained_spiflash_defconfig | 1 + configs/sama5d4ek_mmc_defconfig | 1 + configs/sama5d4ek_nandflash_defconfig | 1 + configs/sama5d4ek_spiflash_defconfig | 1 + configs/sama7g5ek_mmc1_defconfig | 1 + configs/sama7g5ek_mmc_defconfig | 1 + configs/sfr_nb4-ser_ram_defconfig | 3 --- configs/sheevaplug_defconfig | 1 + configs/silinux_ek874_defconfig | 1 + configs/silk_defconfig | 8 -------- configs/sipeed_maix_bitm_defconfig | 1 + configs/sipeed_maix_smode_defconfig | 1 + configs/slimbootloader_defconfig | 1 + configs/smartweb_defconfig | 1 + configs/smdkv310_defconfig | 1 + configs/smegw01_defconfig | 1 + configs/socfpga_agilex_atf_defconfig | 1 + configs/socfpga_agilex_defconfig | 1 + configs/socfpga_agilex_vab_defconfig | 1 + configs/socfpga_dbm_soc1_defconfig | 1 + configs/socfpga_mcvevk_defconfig | 1 + configs/socfpga_n5x_atf_defconfig | 1 + configs/socfpga_n5x_defconfig | 1 + configs/socfpga_n5x_vab_defconfig | 1 + configs/socfpga_secu1_defconfig | 1 + configs/socfpga_stratix10_atf_defconfig | 1 + configs/socfpga_stratix10_defconfig | 1 + configs/socfpga_vining_fpga_defconfig | 1 + configs/socrates_defconfig | 1 + configs/som-db5800-som-6867_defconfig | 1 + configs/somlabs_visionsom_6ull_defconfig | 1 + configs/stemmy_defconfig | 1 + configs/stm32h750-art-pi_defconfig | 1 + configs/stm32mp13_defconfig | 1 + configs/stm32mp15-icore-stm32mp1-ctouch2_defconfig | 1 + configs/stm32mp15-icore-stm32mp1-edimm2.2_defconfig | 1 + ...32mp15-microgea-stm32mp1-microdev2-of7_defconfig | 1 + .../stm32mp15-microgea-stm32mp1-microdev2_defconfig | 1 + configs/stm32mp15_basic_defconfig | 1 + configs/stm32mp15_defconfig | 1 + configs/stm32mp15_dhcom_basic_defconfig | 1 + configs/stm32mp15_dhcor_basic_defconfig | 1 + configs/stm32mp15_trusted_defconfig | 1 + configs/stout_defconfig | 8 -------- configs/synquacer_developerbox_defconfig | 9 --------- configs/taurus_defconfig | 1 + ...headorable-x86-conga-qa3-e3845-pcie-x4_defconfig | 10 ---------- configs/theadorable-x86-conga-qa3-e3845_defconfig | 10 ---------- configs/theadorable-x86-dfi-bt700_defconfig | 10 ---------- configs/theadorable_debug_defconfig | 10 ---------- configs/thuban_defconfig | 5 ----- configs/ti816x_evm_defconfig | 1 + configs/tools-only_defconfig | 2 +- configs/topic_miami_defconfig | 1 + configs/topic_miamilite_defconfig | 1 + configs/topic_miamiplus_defconfig | 1 + configs/total_compute_defconfig | 1 + configs/tplink_wdr4300_defconfig | 1 + configs/tqma6dl_mba6_mmc_defconfig | 1 + configs/tqma6dl_mba6_spi_defconfig | 1 + configs/tqma6q_mba6_mmc_defconfig | 1 + configs/tqma6q_mba6_spi_defconfig | 1 + configs/tqma6s_mba6_mmc_defconfig | 1 + configs/tqma6s_mba6_spi_defconfig | 1 + configs/trats2_defconfig | 1 + configs/trats_defconfig | 1 + configs/uniphier_ld4_sld8_defconfig | 1 + configs/uniphier_v7_defconfig | 1 + configs/uniphier_v8_defconfig | 1 + configs/variscite_dart6ul_defconfig | 1 + configs/vf610twr_defconfig | 1 + configs/vf610twr_nand_defconfig | 1 + configs/vinco_defconfig | 1 + configs/vining_2000_defconfig | 13 ------------- configs/vocore2_defconfig | 9 --------- configs/warp7_bl33_defconfig | 1 + configs/warp7_defconfig | 1 + configs/x530_defconfig | 8 -------- configs/xenguest_arm64_defconfig | 3 --- configs/xilinx_versal_mini_emmc0_defconfig | 1 + configs/xilinx_versal_mini_emmc1_defconfig | 1 + configs/xilinx_zynqmp_mini_emmc0_defconfig | 1 + configs/xilinx_zynqmp_mini_emmc1_defconfig | 1 + 522 files changed, 380 insertions(+), 777 deletions(-)
diff --git a/boot/Kconfig b/boot/Kconfig index d95a2a702665..61ebc2750154 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -435,6 +435,7 @@ if BOOTSTD config BOOTSTD_DEFAULTS bool "Select some common defaults for standard boot" depends on BOOTSTD + default y imply USE_BOOTCOMMAND select BOOT_DEFAULTS help diff --git a/configs/M5253DEMO_defconfig b/configs/M5253DEMO_defconfig index e6ab998f292e..d061a1428956 100644 --- a/configs/M5253DEMO_defconfig +++ b/configs/M5253DEMO_defconfig @@ -19,10 +19,7 @@ CONFIG_SYS_BOOTM_LEN=0x1000000 CONFIG_CMD_IMLS=y CONFIG_CMD_IDE=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y CONFIG_MAC_PARTITION=y CONFIG_OVERWRITE_ETHADDR_ONCE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/MPC837XERDB_defconfig b/configs/MPC837XERDB_defconfig index 8f3f54cb4f2e..b322f599b7c2 100644 --- a/configs/MPC837XERDB_defconfig +++ b/configs/MPC837XERDB_defconfig @@ -137,11 +137,7 @@ CONFIG_CMD_SATA=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_BOOTFILESIZE=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_DATE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_USE_BOOTFILE=y diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index ecbe95992ddb..57169e2d4bc1 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -28,6 +28,7 @@ CONFIG_PHYS_64BIT=y CONFIG_SYS_MONITOR_LEN=786432 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_TPL_SYS_MONITOR_BASE=0xD0000000 diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index 851f94c4ba11..c2cc65aed7f3 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -19,6 +19,7 @@ CONFIG_PHYS_64BIT=y CONFIG_SYS_MONITOR_LEN=786432 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_NO_PBL=y diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index 3e1c7795e2e7..dd88927d5903 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -26,6 +26,7 @@ CONFIG_PHYS_64BIT=y CONFIG_SYS_MONITOR_LEN=786432 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_FSL_FIXED_MMC_LOCATION=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index 59b7cf0295f8..f0390b54c1cb 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -28,6 +28,7 @@ CONFIG_PHYS_64BIT=y CONFIG_SYS_MONITOR_LEN=786432 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SPIFLASH=y diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index 41ada955adc3..b52ed2bf9baa 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -27,6 +27,7 @@ CONFIG_PCIE2=y CONFIG_SYS_MONITOR_LEN=786432 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_TPL_SYS_MONITOR_BASE=0xD0000000 diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index aad962def24e..3291d713cdd2 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -18,6 +18,7 @@ CONFIG_PCIE2=y CONFIG_SYS_MONITOR_LEN=786432 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_NO_PBL=y diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index d29294a0c39e..924ef74b7a91 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -25,6 +25,7 @@ CONFIG_PCIE2=y CONFIG_SYS_MONITOR_LEN=786432 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_FSL_FIXED_MMC_LOCATION=y diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index d97df4eaba90..b8a513276fb8 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -27,6 +27,7 @@ CONFIG_PCIE2=y CONFIG_SYS_MONITOR_LEN=786432 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SPIFLASH=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index cec50ed3d4e8..88510eb09144 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -28,6 +28,7 @@ CONFIG_PHYS_64BIT=y CONFIG_SYS_MONITOR_LEN=786432 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_TPL_SYS_MONITOR_BASE=0xD0000000 diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index 77a469a9b4cc..10024166bb60 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -19,6 +19,7 @@ CONFIG_PHYS_64BIT=y CONFIG_SYS_MONITOR_LEN=786432 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_NO_PBL=y diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index 60615df14dc0..38f4e2109acd 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -26,6 +26,7 @@ CONFIG_PHYS_64BIT=y CONFIG_SYS_MONITOR_LEN=786432 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_FSL_FIXED_MMC_LOCATION=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index 3256a1c2a065..b542d001d125 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -28,6 +28,7 @@ CONFIG_PHYS_64BIT=y CONFIG_SYS_MONITOR_LEN=786432 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SPIFLASH=y diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index 8ee391b5a56a..f8123a269785 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -27,6 +27,7 @@ CONFIG_PCIE2=y CONFIG_SYS_MONITOR_LEN=786432 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_TPL_SYS_MONITOR_BASE=0xD0000000 diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index 28639db945f2..ad4c7092df39 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -18,6 +18,7 @@ CONFIG_PCIE2=y CONFIG_SYS_MONITOR_LEN=786432 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_NO_PBL=y diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index d8711132e2f3..1a6ef7bd2154 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -25,6 +25,7 @@ CONFIG_PCIE2=y CONFIG_SYS_MONITOR_LEN=786432 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_FSL_FIXED_MMC_LOCATION=y diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index 3315c9af9b4d..c5d77bf7c8ab 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -27,6 +27,7 @@ CONFIG_PCIE2=y CONFIG_SYS_MONITOR_LEN=786432 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SPIFLASH=y diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index 686f45dff2a7..8750a5510469 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -29,6 +29,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_TPL_SYS_MONITOR_BASE=0xF8F80000 diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index 1e88fc0199aa..83b0d73b0494 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -27,6 +27,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SPL_SYS_MONITOR_BASE=0xF8F80000 diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index 281afee12ab4..9a308dd3f5c8 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -29,6 +29,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SPL_SYS_MONITOR_BASE=0xF8F80000 diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index fd963cd8fe67..64ac16a9ee02 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_NO_PBL=y diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index 17e1482cf25f..16cb6e9df0d8 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -28,6 +28,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_TPL_SYS_MONITOR_BASE=0xF8F80000 diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index 1e09d74055b2..7200b9f0bbc1 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -26,6 +26,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SPL_SYS_MONITOR_BASE=0xF8F80000 diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index db31ef38b729..643112850471 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -28,6 +28,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SPL_SYS_MONITOR_BASE=0xF8F80000 diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index 68877c5285fb..94801bd74eda 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_NO_PBL=y diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index d1b1826abe92..b12f121a7e39 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -28,6 +28,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_TPL_SYS_MONITOR_BASE=0xF8F80000 diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index 577b5f8ec319..9296be0cfbbe 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -26,6 +26,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SPL_SYS_MONITOR_BASE=0xF8F80000 diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index 537968d35fee..cdccf8ee3597 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -28,6 +28,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SPL_SYS_MONITOR_BASE=0xF8F80000 diff --git a/configs/P1020RDB-PD_defconfig b/configs/P1020RDB-PD_defconfig index 5e08f152da78..579bf020ba61 100644 --- a/configs/P1020RDB-PD_defconfig +++ b/configs/P1020RDB-PD_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_NO_PBL=y diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index aafc4a2413bd..f99f0b4aa924 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -29,6 +29,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_TPL_SYS_MONITOR_BASE=0xF8F80000 diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index 7d3c90e24fde..d4856df571c3 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -27,6 +27,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SPL_SYS_MONITOR_BASE=0xF8F80000 diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index 233c03b8629f..70f339b18684 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -29,6 +29,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SPL_SYS_MONITOR_BASE=0xF8F80000 diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index 791c5ff85da7..b6dee41d7477 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_NO_PBL=y diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index 922faa7a602e..e2e9527fbaf3 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -28,6 +28,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_TPL_SYS_MONITOR_BASE=0xF8F80000 diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index cf2f086e7ef1..b53531471d38 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -26,6 +26,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SPL_SYS_MONITOR_BASE=0xF8F80000 diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index 6428e800d103..24ad7dfca7f0 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -28,6 +28,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SPL_SYS_MONITOR_BASE=0xF8F80000 diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index e1dd5e93d14d..d340ff805d27 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_NO_PBL=y diff --git a/configs/P2041RDB_NAND_defconfig b/configs/P2041RDB_NAND_defconfig index 411eb5086b0a..74c29e03486c 100644 --- a/configs/P2041RDB_NAND_defconfig +++ b/configs/P2041RDB_NAND_defconfig @@ -25,6 +25,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DYNAMIC_SYS_CLK_FREQ=y diff --git a/configs/P2041RDB_SDCARD_defconfig b/configs/P2041RDB_SDCARD_defconfig index 7a394140385c..c5b8dbd6b913 100644 --- a/configs/P2041RDB_SDCARD_defconfig +++ b/configs/P2041RDB_SDCARD_defconfig @@ -25,6 +25,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DYNAMIC_SYS_CLK_FREQ=y diff --git a/configs/P2041RDB_SPIFLASH_defconfig b/configs/P2041RDB_SPIFLASH_defconfig index 99ef9d01ab07..731af1d7c644 100644 --- a/configs/P2041RDB_SPIFLASH_defconfig +++ b/configs/P2041RDB_SPIFLASH_defconfig @@ -26,6 +26,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DYNAMIC_SYS_CLK_FREQ=y diff --git a/configs/P2041RDB_defconfig b/configs/P2041RDB_defconfig index c535217351a2..d04e0d7a977b 100644 --- a/configs/P2041RDB_defconfig +++ b/configs/P2041RDB_defconfig @@ -26,6 +26,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DYNAMIC_SYS_CLK_FREQ=y diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index 1913ccdd62b0..9350950b14da 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -29,6 +29,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_RAMBOOT_PBL=y diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index bd0de9f4115a..7df67e6bcd43 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -29,6 +29,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_RAMBOOT_PBL=y diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index 83fe21072b2d..fca9cb5a21f3 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -31,6 +31,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_RAMBOOT_PBL=y diff --git a/configs/T1024RDB_defconfig b/configs/T1024RDB_defconfig index 1b5152974457..09cd9a083fb7 100644 --- a/configs/T1024RDB_defconfig +++ b/configs/T1024RDB_defconfig @@ -23,6 +23,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index 3b3f596e1db6..5e985359b990 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -28,6 +28,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_RAMBOOT_PBL=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index 7c756e9edd28..015cb8343265 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -28,6 +28,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_RAMBOOT_PBL=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index c486558ea772..c0019823ce6e 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -30,6 +30,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_RAMBOOT_PBL=y diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index c325f151d981..a406a3d79c28 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -22,6 +22,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index c54a1f7e0be1..d29b84cc4513 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -39,6 +39,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DYNAMIC_SYS_CLK_FREQ=y diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index 97d39466e967..d487d71c7bd6 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -39,6 +39,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DYNAMIC_SYS_CLK_FREQ=y diff --git a/configs/T2080QDS_SECURE_BOOT_defconfig b/configs/T2080QDS_SECURE_BOOT_defconfig index 70c2104c7f4f..39ced50ac3a6 100644 --- a/configs/T2080QDS_SECURE_BOOT_defconfig +++ b/configs/T2080QDS_SECURE_BOOT_defconfig @@ -34,6 +34,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DYNAMIC_SYS_CLK_FREQ=y diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index d176d3be44b0..b3c634151887 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -41,6 +41,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DYNAMIC_SYS_CLK_FREQ=y diff --git a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig index 9fd0dafd78c3..e8d7df79e814 100644 --- a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig @@ -33,6 +33,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DYNAMIC_SYS_CLK_FREQ=y diff --git a/configs/T2080QDS_defconfig b/configs/T2080QDS_defconfig index 330bed02d659..7313e6429633 100644 --- a/configs/T2080QDS_defconfig +++ b/configs/T2080QDS_defconfig @@ -33,6 +33,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DYNAMIC_SYS_CLK_FREQ=y diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index 667bdc4a92fc..6b0fc3ca77a9 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -34,6 +34,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_RAMBOOT_PBL=y diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index 237ddbab0528..f0e19ad70e8c 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -34,6 +34,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_RAMBOOT_PBL=y diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index 2a66d77f618b..4e72997d2ca4 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -36,6 +36,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_RAMBOOT_PBL=y diff --git a/configs/T2080RDB_defconfig b/configs/T2080RDB_defconfig index f2086b5614ad..08585616a747 100644 --- a/configs/T2080RDB_defconfig +++ b/configs/T2080RDB_defconfig @@ -28,6 +28,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 diff --git a/configs/T2080RDB_revD_NAND_defconfig b/configs/T2080RDB_revD_NAND_defconfig index 3cc1391fc70b..f36f7b957059 100644 --- a/configs/T2080RDB_revD_NAND_defconfig +++ b/configs/T2080RDB_revD_NAND_defconfig @@ -35,6 +35,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_RAMBOOT_PBL=y diff --git a/configs/T2080RDB_revD_SDCARD_defconfig b/configs/T2080RDB_revD_SDCARD_defconfig index 8b0ce6208e04..6df301c8a494 100644 --- a/configs/T2080RDB_revD_SDCARD_defconfig +++ b/configs/T2080RDB_revD_SDCARD_defconfig @@ -35,6 +35,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_RAMBOOT_PBL=y diff --git a/configs/T2080RDB_revD_SPIFLASH_defconfig b/configs/T2080RDB_revD_SPIFLASH_defconfig index 644932aa2f08..5c2fb96e277e 100644 --- a/configs/T2080RDB_revD_SPIFLASH_defconfig +++ b/configs/T2080RDB_revD_SPIFLASH_defconfig @@ -37,6 +37,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_RAMBOOT_PBL=y diff --git a/configs/T2080RDB_revD_defconfig b/configs/T2080RDB_revD_defconfig index eeb744b9fc0e..c95a73e0e7bd 100644 --- a/configs/T2080RDB_revD_defconfig +++ b/configs/T2080RDB_revD_defconfig @@ -29,6 +29,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index 0d994f895d51..8b0f070bd8f2 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -32,6 +32,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_RAMBOOT_PBL=y diff --git a/configs/T4240RDB_defconfig b/configs/T4240RDB_defconfig index 22872d48ab16..0d1eb725097f 100644 --- a/configs/T4240RDB_defconfig +++ b/configs/T4240RDB_defconfig @@ -26,6 +26,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 diff --git a/configs/alt_defconfig b/configs/alt_defconfig index 5852a34fc147..c19e7e932d6b 100644 --- a/configs/alt_defconfig +++ b/configs/alt_defconfig @@ -45,7 +45,6 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=256 -CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_XIMG is not set CONFIG_CMD_GPIO=y @@ -55,15 +54,9 @@ CONFIG_CMD_PCI=y CONFIG_CMD_SDRAM=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=spi0.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k(u-boot-env2),768k(u-boot),-(user)" @@ -104,5 +97,4 @@ CONFIG_SH_QSPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_PCI=y -CONFIG_USB_STORAGE=y CONFIG_SYS_TIMER_COUNTS_DOWN=y diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index 090b902be30d..fd0fadfde013 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL=y CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run findfdt; run usbboot;run mmcboot;setenv mmcdev 1; setenv bootpart 1:2; run mmcboot;run nandboot;" diff --git a/configs/am335x_igep003x_defconfig b/configs/am335x_igep003x_defconfig index 37e1259a8b15..5c07586401de 100644 --- a/configs/am335x_igep003x_defconfig +++ b/configs/am335x_igep003x_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL=y CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run findfdt;run mmcboot;run nandboot;run netboot;" diff --git a/configs/am335x_pdu001_defconfig b/configs/am335x_pdu001_defconfig index e68efde33b65..d87f487c7cfc 100644 --- a/configs/am335x_pdu001_defconfig +++ b/configs/am335x_pdu001_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL=y CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_LOCALVERSION="-EETS-1.0.0" +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=1 CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/am335x_shc_defconfig b/configs/am335x_shc_defconfig index 51b25fda643a..ae99e311c219 100644 --- a/configs/am335x_shc_defconfig +++ b/configs/am335x_shc_defconfig @@ -20,6 +20,7 @@ CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SERIES=y CONFIG_TIMESTAMP=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_SHOW_BOOT_PROGRESS=y CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/am335x_shc_ict_defconfig b/configs/am335x_shc_ict_defconfig index 5766f71c1c88..b0b7f7da3a49 100644 --- a/configs/am335x_shc_ict_defconfig +++ b/configs/am335x_shc_ict_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SHC_ICT=y CONFIG_SERIES=y CONFIG_TIMESTAMP=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_SHOW_BOOT_PROGRESS=y CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/am335x_shc_netboot_defconfig b/configs/am335x_shc_netboot_defconfig index 5073efa01abd..7ff268a02dfe 100644 --- a/configs/am335x_shc_netboot_defconfig +++ b/configs/am335x_shc_netboot_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SHC_NETBOOT=y CONFIG_SERIES=y CONFIG_TIMESTAMP=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_SHOW_BOOT_PROGRESS=y CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/am335x_shc_sdboot_defconfig b/configs/am335x_shc_sdboot_defconfig index f35df6c23c6e..25d4637c7707 100644 --- a/configs/am335x_shc_sdboot_defconfig +++ b/configs/am335x_shc_sdboot_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SHC_SDBOOT=y CONFIG_SERIES=y CONFIG_TIMESTAMP=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_SHOW_BOOT_PROGRESS=y CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index cc635bdedcdd..cae85a10d485 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL_SYS_MALLOC_F_LEN=0x2500 CONFIG_SPL=y CONFIG_LTO=y CONFIG_SYS_MONITOR_LEN=262144 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=10 CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then echo SD/MMC found on device $mmcdev; if run loadbootenv; then run importbootenv; fi; echo Checking if uenvcmd is set ...; if test -n $uenvcmd; then echo Running uenvcmd ...; run uenvcmd; fi; echo Running default loadimage ...; setenv bootfile zImage; if run loadimage; then run loadfdt; run mmcboot; fi; else run nandboot; fi" diff --git a/configs/am62ax_evm_r5_defconfig b/configs/am62ax_evm_r5_defconfig index e5bee144466e..4beffcf56a0e 100644 --- a/configs/am62ax_evm_r5_defconfig +++ b/configs/am62ax_evm_r5_defconfig @@ -62,7 +62,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_REMOTEPROC=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_ENV_IS_NOWHERE=y diff --git a/configs/am62x_evm_r5_defconfig b/configs/am62x_evm_r5_defconfig index 3205491cebfa..7a3ca7b6d617 100644 --- a/configs/am62x_evm_r5_defconfig +++ b/configs/am62x_evm_r5_defconfig @@ -70,7 +70,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_REMOTEPROC=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_SPL_MULTI_DTB_FIT=y diff --git a/configs/am64x_evm_a53_defconfig b/configs/am64x_evm_a53_defconfig index 4589624e965b..e420ff4231f6 100644 --- a/configs/am64x_evm_a53_defconfig +++ b/configs/am64x_evm_a53_defconfig @@ -31,6 +31,7 @@ CONFIG_SPL_SPI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run get_kern_${boot}; run get_fdt_${boot}; run run_kern" CONFIG_BOARD_LATE_INIT=y diff --git a/configs/am64x_evm_r5_defconfig b/configs/am64x_evm_r5_defconfig index b75cae6d803e..9b268e860a1b 100644 --- a/configs/am64x_evm_r5_defconfig +++ b/configs/am64x_evm_r5_defconfig @@ -29,7 +29,6 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 -CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run distro_bootcmd" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_SIZE_LIMIT_SUBTRACT_GD=y @@ -80,9 +79,7 @@ CONFIG_CMD_REMOTEPROC=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y CONFIG_CMD_TIME=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_SPL_MULTI_DTB_FIT=y @@ -162,7 +159,6 @@ CONFIG_USB_CDNS3_GADGET=y CONFIG_USB_CDNS3_HOST=y CONFIG_SPL_USB_CDNS3_GADGET=y CONFIG_SPL_USB_CDNS3_HOST=y -CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 diff --git a/configs/am65x_evm_r5_defconfig b/configs/am65x_evm_r5_defconfig index d5196c2024ee..fcb2239f6929 100644 --- a/configs/am65x_evm_r5_defconfig +++ b/configs/am65x_evm_r5_defconfig @@ -29,7 +29,6 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y -CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_SIZE_LIMIT_SUBTRACT_GD=y CONFIG_SPL_SIZE_LIMIT_SUBTRACT_MALLOC=y @@ -63,7 +62,6 @@ CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=64 -CONFIG_CMD_BOOTZ=y CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_ASKENV=y CONFIG_CMD_GPT=y @@ -72,7 +70,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_REMOTEPROC=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_SPL_MULTI_DTB_FIT=y diff --git a/configs/am65x_evm_r5_usbdfu_defconfig b/configs/am65x_evm_r5_usbdfu_defconfig index 8b0192579c64..1814c0863557 100644 --- a/configs/am65x_evm_r5_usbdfu_defconfig +++ b/configs/am65x_evm_r5_usbdfu_defconfig @@ -26,7 +26,6 @@ CONFIG_SPL_LIBDISK_SUPPORT=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 -CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_SIZE_LIMIT_SUBTRACT_GD=y CONFIG_SPL_SIZE_LIMIT_SUBTRACT_MALLOC=y @@ -56,7 +55,6 @@ CONFIG_SPL_DFU=y CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=64 -CONFIG_CMD_BOOTZ=y CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_ASKENV=y CONFIG_CMD_DFU=y @@ -65,7 +63,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_REMOTEPROC=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_SPL_MULTI_DTB_FIT=y @@ -128,7 +125,6 @@ CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y CONFIG_SPL_USB_DWC3_GENERIC=y -CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 diff --git a/configs/am65x_evm_r5_usbmsc_defconfig b/configs/am65x_evm_r5_usbmsc_defconfig index 01e46e6a626b..1973fadb9514 100644 --- a/configs/am65x_evm_r5_usbmsc_defconfig +++ b/configs/am65x_evm_r5_usbmsc_defconfig @@ -25,7 +25,6 @@ CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y -CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_SIZE_LIMIT_SUBTRACT_GD=y CONFIG_SPL_SIZE_LIMIT_SUBTRACT_MALLOC=y @@ -56,7 +55,6 @@ CONFIG_SPL_USB_GADGET=y CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=64 -CONFIG_CMD_BOOTZ=y CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_ASKENV=y CONFIG_CMD_GPT=y @@ -64,7 +62,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_REMOTEPROC=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_SPL_MULTI_DTB_FIT=y @@ -124,7 +121,6 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y -CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 diff --git a/configs/am65x_hs_evm_a53_defconfig b/configs/am65x_hs_evm_a53_defconfig index f450e15d08b2..90e568ae969b 100644 --- a/configs/am65x_hs_evm_a53_defconfig +++ b/configs/am65x_hs_evm_a53_defconfig @@ -31,6 +31,7 @@ CONFIG_SPL_SPI=y # CONFIG_PSCI_RESET is not set # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run get_fit_${boot}; run get_overlaystring; run run_fit" diff --git a/configs/am65x_hs_evm_r5_defconfig b/configs/am65x_hs_evm_r5_defconfig index 0c7b53ca2c08..087f1981a600 100644 --- a/configs/am65x_hs_evm_r5_defconfig +++ b/configs/am65x_hs_evm_r5_defconfig @@ -28,7 +28,6 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y -CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_MAX_SIZE=0x58000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -59,7 +58,6 @@ CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=64 -CONFIG_CMD_BOOTZ=y CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_ASKENV=y CONFIG_CMD_GPT=y @@ -68,7 +66,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_REMOTEPROC=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_SPL_MULTI_DTB_FIT=y diff --git a/configs/arbel_evb_defconfig b/configs/arbel_evb_defconfig index 29c4c187b585..40574b8abee1 100644 --- a/configs/arbel_evb_defconfig +++ b/configs/arbel_evb_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_LOAD_ADDR=0x10000000 CONFIG_ENV_ADDR=0x803C0000 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run common_bootargs; run romboot" CONFIG_HUSH_PARSER=y diff --git a/configs/aristainetos2c_defconfig b/configs/aristainetos2c_defconfig index db68b21c0361..7c4b4c1894c8 100644 --- a/configs/aristainetos2c_defconfig +++ b/configs/aristainetos2c_defconfig @@ -13,6 +13,7 @@ CONFIG_ENV_OFFSET_REDUND=0xE0000 CONFIG_IMX_HAB=y # CONFIG_CMD_DEKBLOB is not set CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=-2 CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/aristainetos2ccslb_defconfig b/configs/aristainetos2ccslb_defconfig index d369505e8bf0..43f22b3bd59e 100644 --- a/configs/aristainetos2ccslb_defconfig +++ b/configs/aristainetos2ccslb_defconfig @@ -13,6 +13,7 @@ CONFIG_ENV_OFFSET_REDUND=0xE0000 CONFIG_IMX_HAB=y # CONFIG_CMD_DEKBLOB is not set CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=-2 CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/at91sam9260ek_dataflash_cs0_defconfig b/configs/at91sam9260ek_dataflash_cs0_defconfig index 854d2de11e9b..8f22d0cecd5e 100644 --- a/configs/at91sam9260ek_dataflash_cs0_defconfig +++ b/configs/at91sam9260ek_dataflash_cs0_defconfig @@ -19,6 +19,7 @@ CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9260ek_dataflash_cs1_defconfig b/configs/at91sam9260ek_dataflash_cs1_defconfig index 1e219cf3f9a9..c7a180f4dc66 100644 --- a/configs/at91sam9260ek_dataflash_cs1_defconfig +++ b/configs/at91sam9260ek_dataflash_cs1_defconfig @@ -19,6 +19,7 @@ CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9260ek_nandflash_defconfig b/configs/at91sam9260ek_nandflash_defconfig index 75520adbb452..97edb6367c69 100644 --- a/configs/at91sam9260ek_nandflash_defconfig +++ b/configs/at91sam9260ek_nandflash_defconfig @@ -17,6 +17,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9261ek_dataflash_cs0_defconfig b/configs/at91sam9261ek_dataflash_cs0_defconfig index a398e6d97a1e..5d1ceebef477 100644 --- a/configs/at91sam9261ek_dataflash_cs0_defconfig +++ b/configs/at91sam9261ek_dataflash_cs0_defconfig @@ -18,6 +18,7 @@ CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9261ek_dataflash_cs3_defconfig b/configs/at91sam9261ek_dataflash_cs3_defconfig index 1b464ff29259..f5628154897e 100644 --- a/configs/at91sam9261ek_dataflash_cs3_defconfig +++ b/configs/at91sam9261ek_dataflash_cs3_defconfig @@ -18,6 +18,7 @@ CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9261ek_nandflash_defconfig b/configs/at91sam9261ek_nandflash_defconfig index f23262494250..cdb9559bbf21 100644 --- a/configs/at91sam9261ek_nandflash_defconfig +++ b/configs/at91sam9261ek_nandflash_defconfig @@ -16,6 +16,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9263ek_dataflash_cs0_defconfig b/configs/at91sam9263ek_dataflash_cs0_defconfig index 1498ade5deee..95c101ccfc9f 100644 --- a/configs/at91sam9263ek_dataflash_cs0_defconfig +++ b/configs/at91sam9263ek_dataflash_cs0_defconfig @@ -18,6 +18,7 @@ CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9263ek_dataflash_defconfig b/configs/at91sam9263ek_dataflash_defconfig index 1498ade5deee..95c101ccfc9f 100644 --- a/configs/at91sam9263ek_dataflash_defconfig +++ b/configs/at91sam9263ek_dataflash_defconfig @@ -18,6 +18,7 @@ CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9263ek_nandflash_defconfig b/configs/at91sam9263ek_nandflash_defconfig index 119117dfea5b..8f31ee846da4 100644 --- a/configs/at91sam9263ek_nandflash_defconfig +++ b/configs/at91sam9263ek_nandflash_defconfig @@ -16,6 +16,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9263ek_norflash_boot_defconfig b/configs/at91sam9263ek_norflash_boot_defconfig index d5db00448151..366d3b863b08 100644 --- a/configs/at91sam9263ek_norflash_boot_defconfig +++ b/configs/at91sam9263ek_norflash_boot_defconfig @@ -28,17 +28,13 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=281 # CONFIG_CMD_BDI is not set -CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -CONFIG_CMD_PING=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y diff --git a/configs/at91sam9263ek_norflash_defconfig b/configs/at91sam9263ek_norflash_defconfig index d82cd2147217..5b92b1d3675e 100644 --- a/configs/at91sam9263ek_norflash_defconfig +++ b/configs/at91sam9263ek_norflash_defconfig @@ -29,17 +29,13 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=281 # CONFIG_CMD_BDI is not set -CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -CONFIG_CMD_PING=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y diff --git a/configs/at91sam9g10ek_dataflash_cs0_defconfig b/configs/at91sam9g10ek_dataflash_cs0_defconfig index 8559fee39628..995ce58ddb4d 100644 --- a/configs/at91sam9g10ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs0_defconfig @@ -18,6 +18,7 @@ CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9g10ek_dataflash_cs3_defconfig b/configs/at91sam9g10ek_dataflash_cs3_defconfig index 0ca773981e82..2d09a4aede5b 100644 --- a/configs/at91sam9g10ek_dataflash_cs3_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs3_defconfig @@ -18,6 +18,7 @@ CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9g10ek_nandflash_defconfig b/configs/at91sam9g10ek_nandflash_defconfig index 3b0180a3ae0a..970499a3c399 100644 --- a/configs/at91sam9g10ek_nandflash_defconfig +++ b/configs/at91sam9g10ek_nandflash_defconfig @@ -16,6 +16,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9g20ek_2mmc_defconfig b/configs/at91sam9g20ek_2mmc_defconfig index d1b0a2e55621..e21fa3eda1da 100644 --- a/configs/at91sam9g20ek_2mmc_defconfig +++ b/configs/at91sam9g20ek_2mmc_defconfig @@ -19,6 +19,7 @@ CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9g20ek_2mmc_nandflash_defconfig b/configs/at91sam9g20ek_2mmc_nandflash_defconfig index 2f6e4fb9f2d8..a57cf2d7aafe 100644 --- a/configs/at91sam9g20ek_2mmc_nandflash_defconfig +++ b/configs/at91sam9g20ek_2mmc_nandflash_defconfig @@ -18,6 +18,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9g20ek_dataflash_cs0_defconfig b/configs/at91sam9g20ek_dataflash_cs0_defconfig index 419d2c820189..d601b9df5372 100644 --- a/configs/at91sam9g20ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs0_defconfig @@ -19,6 +19,7 @@ CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9g20ek_dataflash_cs1_defconfig b/configs/at91sam9g20ek_dataflash_cs1_defconfig index 741ae967f600..0c09dc623491 100644 --- a/configs/at91sam9g20ek_dataflash_cs1_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs1_defconfig @@ -19,6 +19,7 @@ CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9g20ek_nandflash_defconfig b/configs/at91sam9g20ek_nandflash_defconfig index 6528cffd37a5..88b1a06c66d6 100644 --- a/configs/at91sam9g20ek_nandflash_defconfig +++ b/configs/at91sam9g20ek_nandflash_defconfig @@ -17,6 +17,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9m10g45ek_mmc_defconfig b/configs/at91sam9m10g45ek_mmc_defconfig index d7d3d60b300c..89698e5c3c9c 100644 --- a/configs/at91sam9m10g45ek_mmc_defconfig +++ b/configs/at91sam9m10g45ek_mmc_defconfig @@ -18,6 +18,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y CONFIG_SYS_MONITOR_LEN=524288 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9m10g45ek_nandflash_defconfig b/configs/at91sam9m10g45ek_nandflash_defconfig index f3fb8fa46570..e3d18ea9c695 100644 --- a/configs/at91sam9m10g45ek_nandflash_defconfig +++ b/configs/at91sam9m10g45ek_nandflash_defconfig @@ -18,6 +18,7 @@ CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y CONFIG_SYS_MONITOR_LEN=524288 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9n12ek_mmc_defconfig b/configs/at91sam9n12ek_mmc_defconfig index 517ff169f816..9ab3d2e5ee62 100644 --- a/configs/at91sam9n12ek_mmc_defconfig +++ b/configs/at91sam9n12ek_mmc_defconfig @@ -17,6 +17,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y CONFIG_SYS_MONITOR_LEN=524288 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/at91sam9n12ek_nandflash_defconfig b/configs/at91sam9n12ek_nandflash_defconfig index e54a51dce23b..c37a860f096a 100644 --- a/configs/at91sam9n12ek_nandflash_defconfig +++ b/configs/at91sam9n12ek_nandflash_defconfig @@ -17,6 +17,7 @@ CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y CONFIG_SYS_MONITOR_LEN=524288 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/at91sam9n12ek_spiflash_defconfig b/configs/at91sam9n12ek_spiflash_defconfig index 839c4007ceb9..88081d34be4e 100644 --- a/configs/at91sam9n12ek_spiflash_defconfig +++ b/configs/at91sam9n12ek_spiflash_defconfig @@ -19,6 +19,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y CONFIG_SYS_MONITOR_LEN=524288 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/at91sam9rlek_dataflash_defconfig b/configs/at91sam9rlek_dataflash_defconfig index 8daec289bc62..2f7aeb53e971 100644 --- a/configs/at91sam9rlek_dataflash_defconfig +++ b/configs/at91sam9rlek_dataflash_defconfig @@ -18,6 +18,7 @@ CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9rlek_mmc_defconfig b/configs/at91sam9rlek_mmc_defconfig index bc5c9cf19ccb..1e80fc37b39a 100644 --- a/configs/at91sam9rlek_mmc_defconfig +++ b/configs/at91sam9rlek_mmc_defconfig @@ -16,6 +16,7 @@ CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9rlek_nandflash_defconfig b/configs/at91sam9rlek_nandflash_defconfig index 5ec0efc67ff1..78f78bea9078 100644 --- a/configs/at91sam9rlek_nandflash_defconfig +++ b/configs/at91sam9rlek_nandflash_defconfig @@ -16,6 +16,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index eb4f852991f9..0fcc889f75ab 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -22,6 +22,7 @@ CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,768k(uboot)ro,256k(env_redundant),256k(env),512k(dtb),6M(kernel)ro,-(rootfs) rootfstype=ubifs ubi.mtd=6 root=ubi0:rootfs rw" diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index a3ca030634bc..512927659d27 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -30,17 +30,13 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=281 -CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -CONFIG_CMD_PING=y -CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y @@ -68,7 +64,6 @@ CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y CONFIG_VIDEO=y # CONFIG_VIDEO_BPP8 is not set # CONFIG_VIDEO_BPP32 is not set diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index a1ee9dc14315..5be1340f5af8 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index d226fccebe49..69c603de5921 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -22,6 +22,7 @@ CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9xeek_dataflash_cs0_defconfig b/configs/at91sam9xeek_dataflash_cs0_defconfig index 854d2de11e9b..8f22d0cecd5e 100644 --- a/configs/at91sam9xeek_dataflash_cs0_defconfig +++ b/configs/at91sam9xeek_dataflash_cs0_defconfig @@ -19,6 +19,7 @@ CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9xeek_dataflash_cs1_defconfig b/configs/at91sam9xeek_dataflash_cs1_defconfig index 1e219cf3f9a9..c7a180f4dc66 100644 --- a/configs/at91sam9xeek_dataflash_cs1_defconfig +++ b/configs/at91sam9xeek_dataflash_cs1_defconfig @@ -19,6 +19,7 @@ CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/at91sam9xeek_nandflash_defconfig b/configs/at91sam9xeek_nandflash_defconfig index 75520adbb452..97edb6367c69 100644 --- a/configs/at91sam9xeek_nandflash_defconfig +++ b/configs/at91sam9xeek_nandflash_defconfig @@ -17,6 +17,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/axs101_defconfig b/configs/axs101_defconfig index 22031f0c2d39..3faac044159d 100644 --- a/configs/axs101_defconfig +++ b/configs/axs101_defconfig @@ -27,12 +27,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_FAT=y @@ -63,5 +58,4 @@ CONFIG_DESIGNWARE_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y -CONFIG_USB_STORAGE=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/axs103_defconfig b/configs/axs103_defconfig index 0757ddf5aca2..2e4984e50339 100644 --- a/configs/axs103_defconfig +++ b/configs/axs103_defconfig @@ -27,12 +27,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_FAT=y @@ -63,5 +58,4 @@ CONFIG_DESIGNWARE_SPI=y CONFIG_USB=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_GENERIC=y -CONFIG_USB_STORAGE=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index 5035ccb78b04..56daaffae024 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -16,6 +16,7 @@ CONFIG_GENERATE_MP_TABLE=y CONFIG_SEABIOS=y CONFIG_SYS_MONITOR_LEN=2097152 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SHOW_BOOT_PROGRESS=y diff --git a/configs/bcm7260_defconfig b/configs/bcm7260_defconfig index 51e0a5ddd716..eb57bf0d30c7 100644 --- a/configs/bcm7260_defconfig +++ b/configs/bcm7260_defconfig @@ -28,10 +28,6 @@ CONFIG_CMD_GPT=y # CONFIG_RANDOM_UUID is not set CONFIG_CMD_MMC=y CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_DOS_PARTITION=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y diff --git a/configs/bcm7445_defconfig b/configs/bcm7445_defconfig index f5f1e8d39707..96af114d0b8a 100644 --- a/configs/bcm7445_defconfig +++ b/configs/bcm7445_defconfig @@ -29,10 +29,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF_TEST=y CONFIG_CMD_SPI=y CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_DOS_PARTITION=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y diff --git a/configs/bcm947622_defconfig b/configs/bcm947622_defconfig index 38d35d467e33..3183fee5d213 100644 --- a/configs/bcm947622_defconfig +++ b/configs/bcm947622_defconfig @@ -11,7 +11,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 CONFIG_DEFAULT_DEVICE_TREE="bcm947622" CONFIG_IDENT_STRING=" Broadcom BCM47622" CONFIG_SYS_LOAD_ADDR=0x01000000 -CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y diff --git a/configs/bcm94908_defconfig b/configs/bcm94908_defconfig index 29b858e9567d..adf961282f48 100644 --- a/configs/bcm94908_defconfig +++ b/configs/bcm94908_defconfig @@ -12,7 +12,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 CONFIG_DEFAULT_DEVICE_TREE="bcm94908" CONFIG_IDENT_STRING=" Broadcom BCM4908" CONFIG_SYS_LOAD_ADDR=0x01000000 -CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y diff --git a/configs/bcm94912_defconfig b/configs/bcm94912_defconfig index 950fc7a6a354..b212102a67e3 100644 --- a/configs/bcm94912_defconfig +++ b/configs/bcm94912_defconfig @@ -12,7 +12,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 CONFIG_DEFAULT_DEVICE_TREE="bcm94912" CONFIG_IDENT_STRING=" Broadcom BCM4912" CONFIG_SYS_LOAD_ADDR=0x01000000 -CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y diff --git a/configs/bcm963138_defconfig b/configs/bcm963138_defconfig index 5a4b27d8777b..5d7fce752839 100644 --- a/configs/bcm963138_defconfig +++ b/configs/bcm963138_defconfig @@ -11,7 +11,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 CONFIG_DEFAULT_DEVICE_TREE="bcm963138" CONFIG_IDENT_STRING=" Broadcom BCM63138" CONFIG_SYS_LOAD_ADDR=0x01000000 -CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y diff --git a/configs/bcm963146_defconfig b/configs/bcm963146_defconfig index 2f1fd89b2440..9fedbdb1d3ed 100644 --- a/configs/bcm963146_defconfig +++ b/configs/bcm963146_defconfig @@ -12,7 +12,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 CONFIG_DEFAULT_DEVICE_TREE="bcm963146" CONFIG_IDENT_STRING=" Broadcom BCM63146" CONFIG_SYS_LOAD_ADDR=0x01000000 -CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y diff --git a/configs/bcm963148_defconfig b/configs/bcm963148_defconfig index 78e51dce8a39..ecb1e9e83634 100644 --- a/configs/bcm963148_defconfig +++ b/configs/bcm963148_defconfig @@ -12,7 +12,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 CONFIG_DEFAULT_DEVICE_TREE="bcm963148" CONFIG_IDENT_STRING=" Broadcom BCM63148" CONFIG_SYS_LOAD_ADDR=0x01000000 -CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y diff --git a/configs/bcm963158_defconfig b/configs/bcm963158_defconfig index adbf86c8538e..faf9e46c2f47 100644 --- a/configs/bcm963158_defconfig +++ b/configs/bcm963158_defconfig @@ -12,7 +12,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 CONFIG_DEFAULT_DEVICE_TREE="bcm963158" CONFIG_IDENT_STRING=" Broadcom BCM63158" CONFIG_SYS_LOAD_ADDR=0x01000000 -CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y diff --git a/configs/bcm963178_defconfig b/configs/bcm963178_defconfig index 8b378fd0307e..4743b624ce17 100644 --- a/configs/bcm963178_defconfig +++ b/configs/bcm963178_defconfig @@ -12,7 +12,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 CONFIG_DEFAULT_DEVICE_TREE="bcm963178" CONFIG_IDENT_STRING=" Broadcom BCM63178" CONFIG_SYS_LOAD_ADDR=0x01000000 -CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y diff --git a/configs/bcm96756_defconfig b/configs/bcm96756_defconfig index da24e26b0788..53ce1e8d887a 100644 --- a/configs/bcm96756_defconfig +++ b/configs/bcm96756_defconfig @@ -12,7 +12,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 CONFIG_DEFAULT_DEVICE_TREE="bcm96756" CONFIG_IDENT_STRING=" Broadcom BCM6756" CONFIG_SYS_LOAD_ADDR=0x01000000 -CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y diff --git a/configs/bcm96813_defconfig b/configs/bcm96813_defconfig index 8baff9ca9e59..dc8a5012ae05 100644 --- a/configs/bcm96813_defconfig +++ b/configs/bcm96813_defconfig @@ -12,7 +12,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 CONFIG_DEFAULT_DEVICE_TREE="bcm96813" CONFIG_IDENT_STRING=" Broadcom BCM6813" CONFIG_SYS_LOAD_ADDR=0x01000000 -CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y diff --git a/configs/bcm96846_defconfig b/configs/bcm96846_defconfig index 9a9674750c04..5e7e24ac0664 100644 --- a/configs/bcm96846_defconfig +++ b/configs/bcm96846_defconfig @@ -12,7 +12,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 CONFIG_DEFAULT_DEVICE_TREE="bcm96846" CONFIG_IDENT_STRING=" Broadcom BCM6846" CONFIG_SYS_LOAD_ADDR=0x01000000 -CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y diff --git a/configs/bcm96855_defconfig b/configs/bcm96855_defconfig index 54c35ee8fda9..b3d40215ddc4 100644 --- a/configs/bcm96855_defconfig +++ b/configs/bcm96855_defconfig @@ -12,7 +12,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 CONFIG_DEFAULT_DEVICE_TREE="bcm96855" CONFIG_IDENT_STRING=" Broadcom BCM6855" CONFIG_SYS_LOAD_ADDR=0x01000000 -CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y diff --git a/configs/bcm96856_defconfig b/configs/bcm96856_defconfig index 16d57f26fd03..dd830e688a96 100644 --- a/configs/bcm96856_defconfig +++ b/configs/bcm96856_defconfig @@ -12,7 +12,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 CONFIG_DEFAULT_DEVICE_TREE="bcm96856" CONFIG_IDENT_STRING=" Broadcom BCM6856" CONFIG_SYS_LOAD_ADDR=0x01000000 -CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y diff --git a/configs/bcm96858_defconfig b/configs/bcm96858_defconfig index 333aa87d9fb5..b1d9720289bb 100644 --- a/configs/bcm96858_defconfig +++ b/configs/bcm96858_defconfig @@ -12,7 +12,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 CONFIG_DEFAULT_DEVICE_TREE="bcm96858" CONFIG_IDENT_STRING=" Broadcom BCM6858" CONFIG_SYS_LOAD_ADDR=0x01000000 -CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y diff --git a/configs/bcm96878_defconfig b/configs/bcm96878_defconfig index ea0d02e08784..8d18c804e3e7 100644 --- a/configs/bcm96878_defconfig +++ b/configs/bcm96878_defconfig @@ -12,7 +12,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x2000000 CONFIG_DEFAULT_DEVICE_TREE="bcm96878" CONFIG_IDENT_STRING=" Broadcom BCM6878" CONFIG_SYS_LOAD_ADDR=0x01000000 -CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_HUSH_PARSER=y diff --git a/configs/bcm_ns3_defconfig b/configs/bcm_ns3_defconfig index 40b3d89ab147..f3d69859f395 100644 --- a/configs/bcm_ns3_defconfig +++ b/configs/bcm_ns3_defconfig @@ -15,6 +15,7 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_SIGNATURE_MAX_SIZE=0x20000000 CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/bitmain_antminer_s9_defconfig b/configs/bitmain_antminer_s9_defconfig index c38ba15cd03d..9de2991cb45d 100644 --- a/configs/bitmain_antminer_s9_defconfig +++ b/configs/bitmain_antminer_s9_defconfig @@ -39,7 +39,6 @@ CONFIG_SYS_SPL_MALLOC_SIZE=0x2000000 CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=2075 -CONFIG_CMD_BOOTZ=y CONFIG_SYS_BOOTM_LEN=0x3c00000 # CONFIG_CMD_ELF is not set # CONFIG_CMD_DM is not set @@ -51,21 +50,12 @@ CONFIG_CMD_FPGA_LOADP=y CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND_LOCK_UNLOCK=y -CONFIG_CMD_PART=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y CONFIG_BOOTP_MAY_FAIL=y # CONFIG_CMD_NFS is not set CONFIG_SYS_DISABLE_AUTOLOAD=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_PXE=y CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FAT=y CONFIG_ENV_IS_IN_NAND=y diff --git a/configs/bk4r1_defconfig b/configs/bk4r1_defconfig index 66adeac725ce..298518e7ea59 100644 --- a/configs/bk4r1_defconfig +++ b/configs/bk4r1_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_MEMTEST_END=0x87c00000 CONFIG_HAS_BOARD_SIZE_LIMIT=y CONFIG_BOARD_SIZE_LIMIT=520192 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Enter passphrase to stop autoboot, booting in %d seconds\n" diff --git a/configs/blanche_defconfig b/configs/blanche_defconfig index 983c55870182..453621273300 100644 --- a/configs/blanche_defconfig +++ b/configs/blanche_defconfig @@ -24,7 +24,6 @@ CONFIG_BOOTDELAY=3 CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=256 -CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_XIMG is not set CONFIG_CMD_GPIO=y @@ -34,15 +33,9 @@ CONFIG_CMD_PCI=y CONFIG_CMD_SDRAM=y # CONFIG_CMD_SF is not set CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y @@ -80,5 +73,4 @@ CONFIG_SH_QSPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_PCI=y -CONFIG_USB_STORAGE=y CONFIG_SYS_TIMER_COUNTS_DOWN=y diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index 2c9b0662159d..5783143f2c43 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -24,6 +24,7 @@ CONFIG_LOCALVERSION="-2.0.0" # CONFIG_LOCALVERSION_AUTO is not set # CONFIG_EXPERT is not set # CONFIG_FIT is not set +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=0 CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/brppt2_defconfig b/configs/brppt2_defconfig index 00ef3d9908e6..19c05ab52797 100644 --- a/configs/brppt2_defconfig +++ b/configs/brppt2_defconfig @@ -25,6 +25,7 @@ CONFIG_SPL_SPI=y # CONFIG_CMD_BMODE is not set CONFIG_SYS_LOAD_ADDR=0x10700000 # CONFIG_EXPERT is not set +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=0 diff --git a/configs/brsmarc1_defconfig b/configs/brsmarc1_defconfig index 1e55ed7c60d1..a73f05a007bb 100644 --- a/configs/brsmarc1_defconfig +++ b/configs/brsmarc1_defconfig @@ -25,6 +25,7 @@ CONFIG_SPL_SPI=y CONFIG_SYS_LOAD_ADDR=0x80000000 # CONFIG_EXPERT is not set # CONFIG_FIT is not set +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=0 CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index 1c437e9743ce..ec409a9516ce 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -22,6 +22,7 @@ CONFIG_ENV_OFFSET_REDUND=0x50000 CONFIG_SYS_LOAD_ADDR=0x80000000 # CONFIG_EXPERT is not set # CONFIG_FIT is not set +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=0 CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/cgtqmx8_defconfig b/configs/cgtqmx8_defconfig index 32e0647c93c0..652f43c1eb2b 100644 --- a/configs/cgtqmx8_defconfig +++ b/configs/cgtqmx8_defconfig @@ -23,6 +23,7 @@ CONFIG_REMAKE_ELF=y CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/cherryhill_defconfig b/configs/cherryhill_defconfig index 83d5712e6163..0f33a31a18b9 100644 --- a/configs/cherryhill_defconfig +++ b/configs/cherryhill_defconfig @@ -13,6 +13,7 @@ CONFIG_DEBUG_UART=y CONFIG_SMP=y CONFIG_GENERATE_MP_TABLE=y CONFIG_SYS_MONITOR_LEN=2097152 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SHOW_BOOT_PROGRESS=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="ext2load scsi 0:3 01000000 /boot/vmlinuz; zboot 01000000" diff --git a/configs/chiliboard_defconfig b/configs/chiliboard_defconfig index 0c3fd428407c..02b23bd29fc1 100644 --- a/configs/chiliboard_defconfig +++ b/configs/chiliboard_defconfig @@ -18,6 +18,7 @@ CONFIG_ENV_OFFSET_REDUND=0x22000 CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_TIMESTAMP=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=1 CONFIG_BOOTCOMMAND="run mmcboot; run nandboot; run netboot" diff --git a/configs/chromebook_coral_defconfig b/configs/chromebook_coral_defconfig index f5995f22004e..e8d738e3ee48 100644 --- a/configs/chromebook_coral_defconfig +++ b/configs/chromebook_coral_defconfig @@ -22,6 +22,7 @@ CONFIG_X86_OFFSET_U_BOOT=0xffd00000 CONFIG_X86_OFFSET_SPL=0xffe80000 CONFIG_INTEL_ACPIGEN=y CONFIG_INTEL_GENERIC_WIFI=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SYS_MONITOR_BASE=0x01110000 CONFIG_CHROMEOS=y CONFIG_BOOTSTAGE=y diff --git a/configs/chromebook_link64_defconfig b/configs/chromebook_link64_defconfig index 8c75d654290b..f2a7433b6384 100644 --- a/configs/chromebook_link64_defconfig +++ b/configs/chromebook_link64_defconfig @@ -20,6 +20,7 @@ CONFIG_HAVE_VGA_BIOS=y CONFIG_X86_OFFSET_U_BOOT=0xffa00000 CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SHOW_BOOT_PROGRESS=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index 3098857d6e17..e22779180675 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -16,6 +16,7 @@ CONFIG_HAVE_MRC=y CONFIG_SMP=y CONFIG_HAVE_VGA_BIOS=y CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SHOW_BOOT_PROGRESS=y diff --git a/configs/chromebook_samus_defconfig b/configs/chromebook_samus_defconfig index b933a2352e3f..85221faed99f 100644 --- a/configs/chromebook_samus_defconfig +++ b/configs/chromebook_samus_defconfig @@ -16,6 +16,7 @@ CONFIG_HAVE_MRC=y CONFIG_HAVE_REFCODE=y CONFIG_SMP=y CONFIG_HAVE_VGA_BIOS=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SHOW_BOOT_PROGRESS=y diff --git a/configs/chromebook_samus_tpl_defconfig b/configs/chromebook_samus_tpl_defconfig index 337768b45fd0..6b4230420b2d 100644 --- a/configs/chromebook_samus_tpl_defconfig +++ b/configs/chromebook_samus_tpl_defconfig @@ -20,6 +20,7 @@ CONFIG_HAVE_REFCODE=y CONFIG_SMP=y CONFIG_HAVE_VGA_BIOS=y CONFIG_X86_OFFSET_U_BOOT=0xffee0000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SYS_MONITOR_BASE=0xFFED0000 CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index 96c739cbfbca..179bc07d1f1f 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -12,6 +12,7 @@ CONFIG_HAVE_MRC=y CONFIG_HAVE_VGA_BIOS=y CONFIG_X86_OFFSET_U_BOOT=0xffa00000 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SHOW_BOOT_PROGRESS=y diff --git a/configs/ci20_mmc_defconfig b/configs/ci20_mmc_defconfig index 000567fe8f37..019374a8d220 100644 --- a/configs/ci20_mmc_defconfig +++ b/configs/ci20_mmc_defconfig @@ -17,6 +17,7 @@ CONFIG_ARCH_JZ47XX=y CONFIG_SYS_MIPS_TIMER_FREQ=1200000000 CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS4,115200 rw rootwait root=/dev/mmcblk0p1" CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/cl-som-imx7_defconfig b/configs/cl-som-imx7_defconfig index d4e70b21a8b4..ddb807b4fbf7 100644 --- a/configs/cl-som-imx7_defconfig +++ b/configs/cl-som-imx7_defconfig @@ -23,6 +23,7 @@ CONFIG_ARMV7_BOOT_SEC_DEFAULT=y CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y CONFIG_SYS_MONITOR_LEN=409600 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index 41f5038bbb4c..42dd2e932991 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -26,6 +26,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_SYS_MONITOR_LEN=524288 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="mmc dev 0; if mmc rescan; then if run loadbootscript; then run bootscript; fi; fi; mmc dev 1; if mmc rescan; then run emmcboot; fi;" CONFIG_SYS_CONSOLE_INFO_QUIET=y diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index c47bfc801a2e..70e42de6c0ca 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -15,11 +15,9 @@ CONFIG_TARGET_COLIBRI_VF=y CONFIG_SYS_LOAD_ADDR=0x80008000 CONFIG_SYS_MEMTEST_START=0x80010000 CONFIG_SYS_MEMTEST_END=0x87c00000 -CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_HAS_BOARD_SIZE_LIMIT=y CONFIG_BOARD_SIZE_LIMIT=520192 CONFIG_BOOTDELAY=1 -CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run ubiboot || run distro_bootcmd;" CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="test -n ${fdtfile} || setenv fdtfile ${soc}-colibri-${fdt_board}.dtb" @@ -33,7 +31,6 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PBSIZE=1056 # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_BOOTM is not set -CONFIG_CMD_BOOTZ=y # CONFIG_CMD_ELF is not set # CONFIG_CMD_IMI is not set CONFIG_CMD_ASKENV=y @@ -46,17 +43,10 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y -CONFIG_CMD_PART=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_MTDIDS_DEFAULT="nand0=vf610_nfc" CONFIG_MTDPARTS_DEFAULT="mtdparts=vf610_nfc:128k(vf-bcb)ro,1408k(u-boot)ro,512k(u-boot-env),-(ubi)" CONFIG_CMD_UBI=y @@ -98,7 +88,6 @@ CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Toradex" CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 diff --git a/configs/comtrend_ar5315u_ram_defconfig b/configs/comtrend_ar5315u_ram_defconfig index 01f7e7009ab7..d7ac4db4ccb2 100644 --- a/configs/comtrend_ar5315u_ram_defconfig +++ b/configs/comtrend_ar5315u_ram_defconfig @@ -34,15 +34,12 @@ CONFIG_CMD_LICENSE=y # CONFIG_CMD_IMPORTENV is not set # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_SAVEENV is not set -# CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_CRC32 is not set CONFIG_CMD_MEMINFO=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y # CONFIG_CMD_SLEEP is not set CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/comtrend_ar5387un_ram_defconfig b/configs/comtrend_ar5387un_ram_defconfig index 1d8e0d7e1574..57557dcd3957 100644 --- a/configs/comtrend_ar5387un_ram_defconfig +++ b/configs/comtrend_ar5387un_ram_defconfig @@ -34,15 +34,12 @@ CONFIG_CMD_LICENSE=y # CONFIG_CMD_IMPORTENV is not set # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_SAVEENV is not set -# CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_CRC32 is not set CONFIG_CMD_MEMINFO=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y # CONFIG_CMD_SLEEP is not set CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/comtrend_ct5361_ram_defconfig b/configs/comtrend_ct5361_ram_defconfig index c649104adfe4..67b0ca34148b 100644 --- a/configs/comtrend_ct5361_ram_defconfig +++ b/configs/comtrend_ct5361_ram_defconfig @@ -34,13 +34,10 @@ CONFIG_CMD_LICENSE=y # CONFIG_CMD_IMPORTENV is not set # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_SAVEENV is not set -# CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_CRC32 is not set CONFIG_CMD_MEMINFO=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_USB=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y # CONFIG_CMD_SLEEP is not set CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/comtrend_vr3032u_ram_defconfig b/configs/comtrend_vr3032u_ram_defconfig index 8bdb959b5d15..1e6e0958a679 100644 --- a/configs/comtrend_vr3032u_ram_defconfig +++ b/configs/comtrend_vr3032u_ram_defconfig @@ -34,15 +34,12 @@ CONFIG_CMD_LICENSE=y # CONFIG_CMD_IMPORTENV is not set # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_SAVEENV is not set -# CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_CRC32 is not set CONFIG_CMD_MEMINFO=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y CONFIG_CMD_USB=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y # CONFIG_CMD_SLEEP is not set CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/comtrend_wap5813n_ram_defconfig b/configs/comtrend_wap5813n_ram_defconfig index d2622491bbaa..f31421b87268 100644 --- a/configs/comtrend_wap5813n_ram_defconfig +++ b/configs/comtrend_wap5813n_ram_defconfig @@ -34,13 +34,10 @@ CONFIG_CMD_LICENSE=y # CONFIG_CMD_IMPORTENV is not set # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_SAVEENV is not set -# CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_CRC32 is not set CONFIG_CMD_MEMINFO=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_USB=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y # CONFIG_CMD_SLEEP is not set CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig index f1bfc9653ca7..23d257b5eeb7 100644 --- a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig +++ b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig @@ -21,6 +21,7 @@ CONFIG_SEABIOS=y CONFIG_SYS_MONITOR_LEN=2097152 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SHOW_BOOT_PROGRESS=y diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index 09d08a842f09..deeb1f1ac358 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -17,6 +17,7 @@ CONFIG_SEABIOS=y CONFIG_SYS_MONITOR_LEN=2097152 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SHOW_BOOT_PROGRESS=y diff --git a/configs/controlcenterdc_defconfig b/configs/controlcenterdc_defconfig index 9c906edf1ef3..4fca683b15b4 100644 --- a/configs/controlcenterdc_defconfig +++ b/configs/controlcenterdc_defconfig @@ -27,6 +27,7 @@ CONFIG_OF_BOARD_FIXUP=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="if env exists keyprogram; then; setenv keyprogram; run nfsboot; fi; run dobootfail" CONFIG_USE_PREBOOT=y diff --git a/configs/coreboot64_defconfig b/configs/coreboot64_defconfig index ec672e59e898..bffc749ec817 100644 --- a/configs/coreboot64_defconfig +++ b/configs/coreboot64_defconfig @@ -10,6 +10,7 @@ CONFIG_VENDOR_COREBOOT=y CONFIG_TARGET_COREBOOT=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SYS_MONITOR_BASE=0x01120000 CONFIG_SHOW_BOOT_PROGRESS=y CONFIG_USE_BOOTARGS=y diff --git a/configs/coreboot_defconfig b/configs/coreboot_defconfig index 4db728991692..406d8e778230 100644 --- a/configs/coreboot_defconfig +++ b/configs/coreboot_defconfig @@ -8,6 +8,7 @@ CONFIG_VENDOR_COREBOOT=y CONFIG_TARGET_COREBOOT=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SYS_MONITOR_BASE=0x01110000 CONFIG_SHOW_BOOT_PROGRESS=y CONFIG_USE_BOOTARGS=y diff --git a/configs/cortina_presidio-asic-emmc_defconfig b/configs/cortina_presidio-asic-emmc_defconfig index 24caa84c43d1..087830bad5bb 100644 --- a/configs/cortina_presidio-asic-emmc_defconfig +++ b/configs/cortina_presidio-asic-emmc_defconfig @@ -15,7 +15,6 @@ CONFIG_SYS_PROMPT="G3#" CONFIG_IDENT_STRING="Presidio-SoC" CONFIG_SYS_LOAD_ADDR=0x10000000 CONFIG_REMAKE_ELF=y -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_SHOW_BOOT_PROGRESS=y CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_R=y @@ -31,8 +30,6 @@ CONFIG_BOOTP_BOOTFILESIZE=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIMER=y CONFIG_CMD_SMC=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_OF_CONTROL=y CONFIG_OF_LIVE=y CONFIG_CORTINA_GPIO=y diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index 363158e7a6aa..60797fee5c64 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -26,6 +26,7 @@ CONFIG_SPL_STACK=0x4000 CONFIG_SPL=y CONFIG_ENV_OFFSET_REDUND=0x180000 CONFIG_SYS_LOAD_ADDR=0x70000000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/cougarcanyon2_defconfig b/configs/cougarcanyon2_defconfig index 8e53eec74e57..2f17eadf2562 100644 --- a/configs/cougarcanyon2_defconfig +++ b/configs/cougarcanyon2_defconfig @@ -13,6 +13,7 @@ CONFIG_SMP=y CONFIG_GENERATE_PIRQ_TABLE=y CONFIG_GENERATE_MP_TABLE=y CONFIG_SYS_MONITOR_LEN=2097152 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SHOW_BOOT_PROGRESS=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/sdb3 init=/sbin/init rootwait ro" diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index 69ad017f987d..ec9cacb7c5d3 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -14,6 +14,7 @@ CONFIG_GENERATE_PIRQ_TABLE=y CONFIG_GENERATE_MP_TABLE=y CONFIG_SEABIOS=y CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SHOW_BOOT_PROGRESS=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/sdb3 init=/sbin/init rootwait ro" diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig index b70762cd6135..d8c02ae683e1 100644 --- a/configs/d2net_v2_defconfig +++ b/configs/d2net_v2_defconfig @@ -17,6 +17,7 @@ CONFIG_IDENT_STRING=" D2 v2" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 # CONFIG_SYS_MALLOC_F is not set +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index 2001327ab08a..1a849fd13cfc 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -28,6 +28,7 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_SYS_LOAD_ADDR=0xc0700000 CONFIG_LTO=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DYNAMIC_SYS_CLK_FREQ=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/da850evm_direct_nor_defconfig b/configs/da850evm_direct_nor_defconfig index 7c4a174d0410..9f072373c81c 100644 --- a/configs/da850evm_direct_nor_defconfig +++ b/configs/da850evm_direct_nor_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_PROMPT="U-Boot > " CONFIG_SYS_LOAD_ADDR=0xc0700000 CONFIG_ENV_ADDR=0x60100000 CONFIG_LTO=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DYNAMIC_SYS_CLK_FREQ=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/da850evm_nand_defconfig b/configs/da850evm_nand_defconfig index eddaa49f0f29..9525ed08f5c2 100644 --- a/configs/da850evm_nand_defconfig +++ b/configs/da850evm_nand_defconfig @@ -25,6 +25,7 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_SYS_LOAD_ADDR=0xc0700000 CONFIG_LTO=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DYNAMIC_SYS_CLK_FREQ=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/db-88f6720_defconfig b/configs/db-88f6720_defconfig index f30d878a5318..24af0fa58ad2 100644 --- a/configs/db-88f6720_defconfig +++ b/configs/db-88f6720_defconfig @@ -38,16 +38,9 @@ CONFIG_CMD_I2C=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y # CONFIG_DOS_PARTITION is not set CONFIG_ENV_OVERWRITE=y CONFIG_ENV_SPI_MAX_HZ=50000000 @@ -73,4 +66,3 @@ CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y diff --git a/configs/db-88f6820-amc_defconfig b/configs/db-88f6820-amc_defconfig index b3ae1424a9fa..fcf1e718ad07 100644 --- a/configs/db-88f6820-amc_defconfig +++ b/configs/db-88f6820-amc_defconfig @@ -41,17 +41,9 @@ CONFIG_CMD_PCI=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_EFI_PARTITION=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_SPI_MAX_HZ=50000000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y @@ -85,4 +77,3 @@ CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y diff --git a/configs/db-88f6820-amc_nand_defconfig b/configs/db-88f6820-amc_nand_defconfig index f877b72b6de7..3078338fb89f 100644 --- a/configs/db-88f6820-amc_nand_defconfig +++ b/configs/db-88f6820-amc_nand_defconfig @@ -43,17 +43,9 @@ CONFIG_CMD_PCI=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_EFI_PARTITION=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_SPI_MAX_HZ=50000000 @@ -89,4 +81,3 @@ CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y diff --git a/configs/db-88f6820-gp_defconfig b/configs/db-88f6820-gp_defconfig index f3b228a19f1d..e44ec2eb9c2e 100644 --- a/configs/db-88f6820-gp_defconfig +++ b/configs/db-88f6820-gp_defconfig @@ -40,17 +40,9 @@ CONFIG_CMD_PCI=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_EFI_PARTITION=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_SPI_MAX_HZ=50000000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y @@ -81,4 +73,3 @@ CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y diff --git a/configs/db-mv784mp-gp_defconfig b/configs/db-mv784mp-gp_defconfig index c456081085ce..c2aaaed5837d 100644 --- a/configs/db-mv784mp-gp_defconfig +++ b/configs/db-mv784mp-gp_defconfig @@ -41,17 +41,9 @@ CONFIG_CMD_SATA=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_EFI_PARTITION=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_SPI_MAX_HZ=50000000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y @@ -84,4 +76,3 @@ CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y diff --git a/configs/db-xc3-24g4xg_defconfig b/configs/db-xc3-24g4xg_defconfig index cb307995f521..1cf9bc47b5ab 100644 --- a/configs/db-xc3-24g4xg_defconfig +++ b/configs/db-xc3-24g4xg_defconfig @@ -26,16 +26,9 @@ CONFIG_CMD_I2C=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y @@ -61,7 +54,6 @@ CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_RTL8152=y diff --git a/configs/deneb_defconfig b/configs/deneb_defconfig index 0d714bd313b1..4304273d3911 100644 --- a/configs/deneb_defconfig +++ b/configs/deneb_defconfig @@ -29,6 +29,7 @@ CONFIG_SYS_LOAD_ADDR=0x80280000 CONFIG_REMAKE_ELF=y CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_BOOTDELAY=3 diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index b426fddc4154..8854a1955092 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -12,6 +12,7 @@ CONFIG_TARGET_DEVKIT8000=y CONFIG_SPL_SYS_MALLOC_F_LEN=0x400 CONFIG_SPL=y CONFIG_SYS_MONITOR_LEN=262144 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run autoboot" CONFIG_USE_PREBOOT=y diff --git a/configs/dfi-bt700-q7x-151_defconfig b/configs/dfi-bt700-q7x-151_defconfig index a48f7c25134c..37025fe71f3c 100644 --- a/configs/dfi-bt700-q7x-151_defconfig +++ b/configs/dfi-bt700-q7x-151_defconfig @@ -16,6 +16,7 @@ CONFIG_SEABIOS=y CONFIG_SYS_MONITOR_LEN=2097152 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SHOW_BOOT_PROGRESS=y diff --git a/configs/display5_defconfig b/configs/display5_defconfig index 0f6ce871785f..acf9a1401e8d 100644 --- a/configs/display5_defconfig +++ b/configs/display5_defconfig @@ -34,6 +34,7 @@ CONFIG_SYS_MONITOR_LEN=409600 CONFIG_STANDALONE_LOAD_ADDR=0x10001000 CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/display5_factory_defconfig b/configs/display5_factory_defconfig index d4f4de62b226..105a0212fd92 100644 --- a/configs/display5_factory_defconfig +++ b/configs/display5_factory_defconfig @@ -31,6 +31,7 @@ CONFIG_SYS_MONITOR_LEN=409600 CONFIG_STANDALONE_LOAD_ADDR=0x10001000 CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 diff --git a/configs/dns325_defconfig b/configs/dns325_defconfig index fc6f2cd043c3..9a4def161f93 100644 --- a/configs/dns325_defconfig +++ b/configs/dns325_defconfig @@ -14,6 +14,7 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-dns325" CONFIG_IDENT_STRING="\nD-Link DNS-325" CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="if test -n ${bootenv} && usb start; then if run loadbootenv; then echo Loaded environment ${bootenv} from usb;run importbootenv;fi;if test -n ${bootenvcmd}; then echo Running bootenvcmd ...;run bootenvcmd;fi;fi;run setnandbootenv subbootcmd;" diff --git a/configs/dockstar_defconfig b/configs/dockstar_defconfig index 18297088398e..e43569393625 100644 --- a/configs/dockstar_defconfig +++ b/configs/dockstar_defconfig @@ -17,6 +17,7 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-dockstar" CONFIG_SYS_PROMPT="DockStar> " CONFIG_IDENT_STRING="\nSeagate FreeAgent DockStar" CONFIG_SYS_LOAD_ADDR=0x800000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs ${console} ${mtdparts} ${bootargs_root}; ubi part root; ubifsmount ubi:root; ubifsload 0x800000 ${kernel}; ubifsload 0x1100000 ${initrd}; bootm 0x800000 0x1100000" diff --git a/configs/draco_defconfig b/configs/draco_defconfig index b71b23faac79..4e04f8fb9be4 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -25,7 +25,6 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_SYS_LOAD_ADDR=0x81000000 -CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_BOOTDELAY=3 CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" @@ -63,13 +62,9 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y CONFIG_BOOTP_DNS2=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=omap2-nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:128k(spl),128k(spl.backup1),128k(spl.backup2),128k(spl.backup3),1920k(u-boot),512k(u-boot.env0),512k(u-boot.env1),512k(mtdoops),-(rootfs)" diff --git a/configs/dreamplug_defconfig b/configs/dreamplug_defconfig index de79176bfdb0..5fdcd02ba876 100644 --- a/configs/dreamplug_defconfig +++ b/configs/dreamplug_defconfig @@ -17,6 +17,7 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-dreamplug" CONFIG_IDENT_STRING="\nMarvell-DreamPlug" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x100000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv ethact ethernet-controller@72000; ${x_bootcmd_ethernet}; setenv ethact ethernet-controller@76000; ${x_bootcmd_ethernet}; ${x_bootcmd_usb}; ${x_bootcmd_kernel}; setenv bootargs ${x_bootargs} ${x_bootargs_root}; bootm 0x6400000;" diff --git a/configs/ds109_defconfig b/configs/ds109_defconfig index ea21717c2b38..603b679a6db5 100644 --- a/configs/ds109_defconfig +++ b/configs/ds109_defconfig @@ -18,6 +18,7 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ds109" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x3D0000 # CONFIG_SYS_MALLOC_F is not set +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv ethact egiga0; ${x_bootcmd_ethernet}; ${x_bootcmd_usb}; ${x_bootcmd_kernel}; setenv bootargs ${x_bootargs} ${x_bootargs_root}; bootm 0x6400000;" CONFIG_USE_PREBOOT=y diff --git a/configs/ds414_defconfig b/configs/ds414_defconfig index b79f96c1922e..6844428cc472 100644 --- a/configs/ds414_defconfig +++ b/configs/ds414_defconfig @@ -24,6 +24,7 @@ CONFIG_DEBUG_UART_BASE=0xf1012000 CONFIG_DEBUG_UART_CLOCK=250000000 CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 ip=off initrd=0x8000040,8M root=/dev/md0 rw syno_hw_version=DS414r1 ihd_num=4 netif_num=2 flash_size=8 SataLedSpecial=1 HddHotplug=1" diff --git a/configs/edison_defconfig b/configs/edison_defconfig index be8320194cc5..59c3dbec3042 100644 --- a/configs/edison_defconfig +++ b/configs/edison_defconfig @@ -27,14 +27,10 @@ CONFIG_CMD_MEMINFO=y CONFIG_CMD_DFU=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y -CONFIG_CMD_PART=y # CONFIG_CMD_NFS is not set CONFIG_CMD_TIMER=y CONFIG_CMD_HASH=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/efi-x86_payload32_defconfig b/configs/efi-x86_payload32_defconfig index a5c629b46f37..253356fe6bd9 100644 --- a/configs/efi-x86_payload32_defconfig +++ b/configs/efi-x86_payload32_defconfig @@ -7,6 +7,7 @@ CONFIG_VENDOR_EFI=y CONFIG_TARGET_EFI_PAYLOAD=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SHOW_BOOT_PROGRESS=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/sdb3 init=/sbin/init rootwait ro" diff --git a/configs/efi-x86_payload64_defconfig b/configs/efi-x86_payload64_defconfig index 5cde04a5ac91..044ce699d809 100644 --- a/configs/efi-x86_payload64_defconfig +++ b/configs/efi-x86_payload64_defconfig @@ -7,6 +7,7 @@ CONFIG_VENDOR_EFI=y CONFIG_TARGET_EFI_PAYLOAD=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SHOW_BOOT_PROGRESS=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/sdb3 init=/sbin/init rootwait ro" diff --git a/configs/emsdp_defconfig b/configs/emsdp_defconfig index 86cc59a2c786..913242f60187 100644 --- a/configs/emsdp_defconfig +++ b/configs/emsdp_defconfig @@ -21,7 +21,6 @@ CONFIG_SYS_PBSIZE=280 # CONFIG_CMD_XIMG is not set CONFIG_CMD_MMC=y CONFIG_CMD_CACHE=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_FAT=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index 43cfed9fb347..a773895fa79e 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -26,7 +26,6 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_SYS_LOAD_ADDR=0x81000000 -CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_BOOTDELAY=3 CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" @@ -64,13 +63,9 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y CONFIG_BOOTP_DNS2=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand2=omap2-nand_concat" CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand_concat:512k(spl),512k(spl.backup1),512k(spl.backup2),512k(spl.backup3),7680k(u-boot),2048k(u-boot.env0),2048k(u-boot.env1),2048k(mtdoops),-(rootfs)" diff --git a/configs/ethernut5_defconfig b/configs/ethernut5_defconfig index c3d0bc2455b5..c0f228292f37 100644 --- a/configs/ethernut5_defconfig +++ b/configs/ethernut5_defconfig @@ -15,6 +15,7 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="ethernut5" CONFIG_SYS_PROMPT="U-Boot> " CONFIG_SYS_LOAD_ADDR=0x020000000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock0 mtdparts=atmel_nand:-(root) rw rootfstype=jffs2" diff --git a/configs/ev-imx280-nano-x-mb_defconfig b/configs/ev-imx280-nano-x-mb_defconfig index 0546cb7445d6..845743ba8505 100644 --- a/configs/ev-imx280-nano-x-mb_defconfig +++ b/configs/ev-imx280-nano-x-mb_defconfig @@ -11,20 +11,13 @@ CONFIG_IMX_MODULE_FUSE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 -CONFIG_CMD_BOOTZ=y CONFIG_CMD_MEMINFO=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y -CONFIG_CMD_PART=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_FAT=y CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" diff --git a/configs/evb-ast2600_defconfig b/configs/evb-ast2600_defconfig index 32e022fb8a2b..7726338fdf2e 100644 --- a/configs/evb-ast2600_defconfig +++ b/configs/evb-ast2600_defconfig @@ -31,6 +31,7 @@ CONFIG_FIT=y CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x10000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS4,115200n8 root=/dev/ram rw" CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/evb-rv1108_defconfig b/configs/evb-rv1108_defconfig index 7c6f9b55a5fd..2912d3dc2c0d 100644 --- a/configs/evb-rv1108_defconfig +++ b/configs/evb-rv1108_defconfig @@ -12,6 +12,7 @@ CONFIG_DEBUG_UART_CLOCK=24000000 # CONFIG_DEBUG_UART_BOARD_INIT is not set CONFIG_SYS_LOAD_ADDR=0x62000000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTCOMMAND="sf probe;sf read 0x62000000 0x140800 0x500000;dcache off;go 0x62000000" CONFIG_DEFAULT_FDT_FILE="rv1108-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/galileo_defconfig b/configs/galileo_defconfig index 0d2ebdab9267..e3860888e2d6 100644 --- a/configs/galileo_defconfig +++ b/configs/galileo_defconfig @@ -10,6 +10,7 @@ CONFIG_TARGET_GALILEO=y CONFIG_GENERATE_PIRQ_TABLE=y CONFIG_GENERATE_MP_TABLE=y CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SHOW_BOOT_PROGRESS=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/sdb3 init=/sbin/init rootwait ro" diff --git a/configs/gazerbeam_defconfig b/configs/gazerbeam_defconfig index 63488da30aa5..303d6bc96626 100644 --- a/configs/gazerbeam_defconfig +++ b/configs/gazerbeam_defconfig @@ -94,6 +94,7 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=5 diff --git a/configs/ge_b1x5v2_defconfig b/configs/ge_b1x5v2_defconfig index 07e357e26c92..7c001026a0c4 100644 --- a/configs/ge_b1x5v2_defconfig +++ b/configs/ge_b1x5v2_defconfig @@ -27,6 +27,7 @@ CONFIG_SPL_SPI=y CONFIG_SPL_PAYLOAD="u-boot.img" CONFIG_DEBUG_UART=y CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=1 diff --git a/configs/ge_bx50v3_defconfig b/configs/ge_bx50v3_defconfig index 44f20c5c74ef..a9e2b968e7d1 100644 --- a/configs/ge_bx50v3_defconfig +++ b/configs/ge_bx50v3_defconfig @@ -13,6 +13,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6q-bx50v3" CONFIG_BOOTCOUNT_BOOTLIMIT=10 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=1 diff --git a/configs/giedi_defconfig b/configs/giedi_defconfig index 75d5d89823f0..3aa5f6c46248 100644 --- a/configs/giedi_defconfig +++ b/configs/giedi_defconfig @@ -29,6 +29,7 @@ CONFIG_SYS_LOAD_ADDR=0x80280000 CONFIG_REMAKE_ELF=y CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_BOOTDELAY=3 diff --git a/configs/goflexhome_defconfig b/configs/goflexhome_defconfig index ef74086cfa96..bed05b5267ba 100644 --- a/configs/goflexhome_defconfig +++ b/configs/goflexhome_defconfig @@ -17,6 +17,7 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-goflexnet" CONFIG_SYS_PROMPT="GoFlexHome> " CONFIG_IDENT_STRING="\nSeagate GoFlex Home" CONFIG_SYS_LOAD_ADDR=0x800000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs ${console} ${mtdparts} ${bootargs_root}; ubi part root; ubifsmount ubi:root; ubifsload 0x800000 ${kernel}; bootm 0x800000" diff --git a/configs/gose_defconfig b/configs/gose_defconfig index 265c7a617d71..c58dc429012a 100644 --- a/configs/gose_defconfig +++ b/configs/gose_defconfig @@ -45,7 +45,6 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=256 -CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_XIMG is not set CONFIG_CMD_GPIO=y @@ -55,15 +54,9 @@ CONFIG_CMD_PCI=y CONFIG_CMD_SDRAM=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=spi0.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k(u-boot-env2),768k(u-boot),-(user)" @@ -102,5 +95,4 @@ CONFIG_SH_QSPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_PCI=y -CONFIG_USB_STORAGE=y CONFIG_SYS_TIMER_COUNTS_DOWN=y diff --git a/configs/grpeach_defconfig b/configs/grpeach_defconfig index 04edcf34f232..1910df5cb152 100644 --- a/configs/grpeach_defconfig +++ b/configs/grpeach_defconfig @@ -28,13 +28,8 @@ CONFIG_SYS_PBSIZE=256 # CONFIG_CMD_ELF is not set CONFIG_CMD_GPIO=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_CACHE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_MAC_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y @@ -64,5 +59,4 @@ CONFIG_TIMER=y CONFIG_RENESAS_OSTM_TIMER=y CONFIG_USB=y CONFIG_USB_R8A66597_HCD=y -CONFIG_USB_STORAGE=y # CONFIG_EFI_LOADER is not set diff --git a/configs/gurnard_defconfig b/configs/gurnard_defconfig index 60bd11aab808..136b4fd6d9b4 100644 --- a/configs/gurnard_defconfig +++ b/configs/gurnard_defconfig @@ -27,17 +27,12 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y -CONFIG_CMD_PART=y CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y -CONFIG_CMD_MII=y # CONFIG_CMD_MDIO is not set -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y diff --git a/configs/guruplug_defconfig b/configs/guruplug_defconfig index 81f0fe0ee162..0a07245307c4 100644 --- a/configs/guruplug_defconfig +++ b/configs/guruplug_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set CONFIG_HAS_BOARD_SIZE_LIMIT=y CONFIG_BOARD_SIZE_LIMIT=917504 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs ${console} ${mtdparts} ${bootargs_root}; ubi part root; ubifsmount ubi:rootfs; ubifsload 0x800000 ${kernel}; ubifsload 0x700000 ${fdt}; ubifsumount; fdt addr 0x700000; fdt resize; fdt chosen; bootz 0x800000 - 0x700000" diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index 032dcfe343cd..b7293d9ec6eb 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -29,6 +29,7 @@ CONFIG_SYS_MONITOR_LEN=409600 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index ee833a59f3d4..69dda23220dc 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -29,6 +29,7 @@ CONFIG_SYS_MONITOR_LEN=409600 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index 194faa5607dd..1fb419aaf270 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -29,6 +29,7 @@ CONFIG_SYS_MONITOR_LEN=409600 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 diff --git a/configs/hihope_rzg2_defconfig b/configs/hihope_rzg2_defconfig index a663aa772bc9..edefa41750d7 100644 --- a/configs/hihope_rzg2_defconfig +++ b/configs/hihope_rzg2_defconfig @@ -15,6 +15,7 @@ CONFIG_SYS_LOAD_ADDR=0x58000000 CONFIG_REMAKE_ELF=y CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTARGS=y CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/hsdk_4xd_defconfig b/configs/hsdk_4xd_defconfig index df8e55f898e7..8a394e6d9c44 100644 --- a/configs/hsdk_4xd_defconfig +++ b/configs/hsdk_4xd_defconfig @@ -31,13 +31,8 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_FAT=y @@ -69,6 +64,5 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_GENERIC=y -CONFIG_USB_STORAGE=y CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_PANIC_HANG=y diff --git a/configs/hsdk_defconfig b/configs/hsdk_defconfig index 20374024f2ce..4f3bcaecd79d 100644 --- a/configs/hsdk_defconfig +++ b/configs/hsdk_defconfig @@ -30,13 +30,8 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_FAT=y @@ -68,6 +63,5 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_GENERIC=y -CONFIG_USB_STORAGE=y CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_PANIC_HANG=y diff --git a/configs/huawei_hg556a_ram_defconfig b/configs/huawei_hg556a_ram_defconfig index ae8baa1d1cc3..8a7798521feb 100644 --- a/configs/huawei_hg556a_ram_defconfig +++ b/configs/huawei_hg556a_ram_defconfig @@ -34,13 +34,10 @@ CONFIG_CMD_LICENSE=y # CONFIG_CMD_IMPORTENV is not set # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_SAVEENV is not set -# CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_CRC32 is not set CONFIG_CMD_MEMINFO=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_USB=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y # CONFIG_CMD_SLEEP is not set CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/ib62x0_defconfig b/configs/ib62x0_defconfig index 310fb7536ba2..b9e08f04463a 100644 --- a/configs/ib62x0_defconfig +++ b/configs/ib62x0_defconfig @@ -15,6 +15,7 @@ CONFIG_SYS_PROMPT="ib62x0 => " CONFIG_IDENT_STRING=" RaidSonic ICY BOX IB-NAS62x0" CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs ${console} ${mtdparts} ${bootargs_root}; ubi part root; ubifsmount ubi:rootfs; ubifsload 0x800000 ${kernel}; ubifsload 0x700000 ${fdt}; ubifsumount; fdt addr 0x700000; fdt resize; fdt chosen; bootz 0x800000 - 0x700000" diff --git a/configs/iconnect_defconfig b/configs/iconnect_defconfig index 9d20865e0142..a8b9258e9320 100644 --- a/configs/iconnect_defconfig +++ b/configs/iconnect_defconfig @@ -17,6 +17,7 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-iconnect" CONFIG_SYS_PROMPT="iConnect> " CONFIG_IDENT_STRING=" Iomega iConnect" CONFIG_SYS_LOAD_ADDR=0x800000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs ${console} ${mtdparts} ${bootargs_root}; ubi part rootfs; ubifsmount ubi:rootfs; ubifsload 0x800000 ${kernel}; bootm 0x800000" diff --git a/configs/imx28_xea_defconfig b/configs/imx28_xea_defconfig index 06dd6b1f0ede..761a68c6711d 100644 --- a/configs/imx28_xea_defconfig +++ b/configs/imx28_xea_defconfig @@ -26,6 +26,7 @@ CONFIG_SYS_LOAD_ADDR=0x42000000 CONFIG_SPL_PAYLOAD="u-boot.img" CONFIG_FIT=y CONFIG_TIMESTAMP=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyAMA0,115200n8" diff --git a/configs/imx28_xea_sb_defconfig b/configs/imx28_xea_sb_defconfig index bb7bf5d9dab6..39bff5bf70f7 100644 --- a/configs/imx28_xea_sb_defconfig +++ b/configs/imx28_xea_sb_defconfig @@ -46,13 +46,8 @@ CONFIG_CMD_MTD=y # CONFIG_CMD_PINMUX is not set CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_REGULATOR=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_MTDPARTS=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y @@ -101,6 +96,4 @@ CONFIG_MXS_SPI=y CONFIG_USB=y # CONFIG_SPL_DM_USB is not set CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y -CONFIG_FS_FAT=y # CONFIG_SPL_OF_LIBFDT is not set diff --git a/configs/imx6dl_icore_nand_defconfig b/configs/imx6dl_icore_nand_defconfig index f4adda5b6d41..6c4852c14808 100644 --- a/configs/imx6dl_icore_nand_defconfig +++ b/configs/imx6dl_icore_nand_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_MEMTEST_END=0x88000000 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/imx6q_bosch_acc_defconfig b/configs/imx6q_bosch_acc_defconfig index 68a63f8a4b5f..ccf621ac6b07 100644 --- a/configs/imx6q_bosch_acc_defconfig +++ b/configs/imx6q_bosch_acc_defconfig @@ -30,6 +30,7 @@ CONFIG_SYS_MONITOR_LEN=409600 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SHOW_BOOT_PROGRESS=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run mmc_mmc_fit" diff --git a/configs/imx6q_icore_nand_defconfig b/configs/imx6q_icore_nand_defconfig index 3b579bac4603..416081004211 100644 --- a/configs/imx6q_icore_nand_defconfig +++ b/configs/imx6q_icore_nand_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_MEMTEST_END=0x88000000 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index 9ac6e4bf5546..803e33d13887 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -23,6 +23,7 @@ CONFIG_SYS_MEMTEST_START=0x10000000 CONFIG_SYS_MEMTEST_END=0x10010000 CONFIG_LTO=y CONFIG_SYS_MONITOR_LEN=409600 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 CONFIG_BOOTCOMMAND="run autoboot" diff --git a/configs/imx6qdl_icore_mipi_defconfig b/configs/imx6qdl_icore_mipi_defconfig index 6cd6bf792fe5..76c641102e14 100644 --- a/configs/imx6qdl_icore_mipi_defconfig +++ b/configs/imx6qdl_icore_mipi_defconfig @@ -28,6 +28,7 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index a0b91b677d8f..cd921ba0237a 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -31,6 +31,7 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 diff --git a/configs/imx6qdl_icore_nand_defconfig b/configs/imx6qdl_icore_nand_defconfig index 3b579bac4603..416081004211 100644 --- a/configs/imx6qdl_icore_nand_defconfig +++ b/configs/imx6qdl_icore_nand_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_MEMTEST_END=0x88000000 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 diff --git a/configs/imx6qdl_icore_rqs_defconfig b/configs/imx6qdl_icore_rqs_defconfig index 0d4919c0c409..c6a5167bb55d 100644 --- a/configs/imx6qdl_icore_rqs_defconfig +++ b/configs/imx6qdl_icore_rqs_defconfig @@ -25,6 +25,7 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 diff --git a/configs/imx6ul_geam_mmc_defconfig b/configs/imx6ul_geam_mmc_defconfig index c597a18879d8..a5d8f726a672 100644 --- a/configs/imx6ul_geam_mmc_defconfig +++ b/configs/imx6ul_geam_mmc_defconfig @@ -24,6 +24,7 @@ CONFIG_SYS_MONITOR_LEN=409600 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 diff --git a/configs/imx6ul_geam_nand_defconfig b/configs/imx6ul_geam_nand_defconfig index 0b989e648473..2a65835ebb91 100644 --- a/configs/imx6ul_geam_nand_defconfig +++ b/configs/imx6ul_geam_nand_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_MEMTEST_END=0x88000000 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 diff --git a/configs/imx6ul_isiot_emmc_defconfig b/configs/imx6ul_isiot_emmc_defconfig index b4e65d0f0f89..78aa0f8ed40a 100644 --- a/configs/imx6ul_isiot_emmc_defconfig +++ b/configs/imx6ul_isiot_emmc_defconfig @@ -24,6 +24,7 @@ CONFIG_SYS_MONITOR_LEN=409600 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 diff --git a/configs/imx6ul_isiot_nand_defconfig b/configs/imx6ul_isiot_nand_defconfig index 8318197fdef2..7abd9f01b3ff 100644 --- a/configs/imx6ul_isiot_nand_defconfig +++ b/configs/imx6ul_isiot_nand_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_MEMTEST_END=0x88000000 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 diff --git a/configs/imx7_cm_defconfig b/configs/imx7_cm_defconfig index ae057ecc77ad..6fe829e5766e 100644 --- a/configs/imx7_cm_defconfig +++ b/configs/imx7_cm_defconfig @@ -21,6 +21,7 @@ CONFIG_ARMV7_BOOT_SEC_DEFAULT=y CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y CONFIG_SYS_MONITOR_LEN=409600 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run boot${boot-mode}" CONFIG_DEFAULT_FDT_FILE="ask" diff --git a/configs/imx8mm-mx8menlo_defconfig b/configs/imx8mm-mx8menlo_defconfig index 81af9dd8a6b1..4ff45786bcaa 100644 --- a/configs/imx8mm-mx8menlo_defconfig +++ b/configs/imx8mm-mx8menlo_defconfig @@ -29,6 +29,7 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="mmc partconf 0 distro_bootpart && load ${devtype} ${devnum}:${distro_bootpart} ${loadaddr} boot/fitImage && source ${loadaddr}:bootscr-boot.cmd ; reset" diff --git a/configs/imx8mm_beacon_defconfig b/configs/imx8mm_beacon_defconfig index 597fe256d0f7..b2a6f2cd3c4a 100644 --- a/configs/imx8mm_beacon_defconfig +++ b/configs/imx8mm_beacon_defconfig @@ -24,6 +24,7 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; fi;" diff --git a/configs/imx8mm_data_modul_edm_sbc_defconfig b/configs/imx8mm_data_modul_edm_sbc_defconfig index 55dd54f8b19b..f00080beafed 100644 --- a/configs/imx8mm_data_modul_edm_sbc_defconfig +++ b/configs/imx8mm_data_modul_edm_sbc_defconfig @@ -35,6 +35,7 @@ CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x44000000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_USE_BOOTARGS=y diff --git a/configs/imx8mn_beacon_2g_defconfig b/configs/imx8mn_beacon_2g_defconfig index c87cdd65164a..a592b57a1de1 100644 --- a/configs/imx8mn_beacon_2g_defconfig +++ b/configs/imx8mn_beacon_2g_defconfig @@ -31,6 +31,7 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else booti ${loadaddr} - ${fdt_addr}; fi" diff --git a/configs/imx8mn_beacon_defconfig b/configs/imx8mn_beacon_defconfig index d68c1207cd83..d5994cac9c2f 100644 --- a/configs/imx8mn_beacon_defconfig +++ b/configs/imx8mn_beacon_defconfig @@ -30,6 +30,7 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else booti ${loadaddr} - ${fdt_addr}; fi" diff --git a/configs/imx8mn_beacon_fspi_defconfig b/configs/imx8mn_beacon_fspi_defconfig index ecd383a8962b..998898be730d 100644 --- a/configs/imx8mn_beacon_fspi_defconfig +++ b/configs/imx8mn_beacon_fspi_defconfig @@ -30,6 +30,7 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else booti ${loadaddr} - ${fdt_addr}; fi" diff --git a/configs/imx8mp_dhcom_pdk2_defconfig b/configs/imx8mp_dhcom_pdk2_defconfig index 09660ce80217..6f24ccef3d46 100644 --- a/configs/imx8mp_dhcom_pdk2_defconfig +++ b/configs/imx8mp_dhcom_pdk2_defconfig @@ -33,16 +33,13 @@ CONFIG_IMX_BOOTAUX=y CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 CONFIG_SYS_LOAD_ADDR=0x50000000 CONFIG_DEBUG_UART=y -CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x44000000 -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_USE_BOOTARGS=y -CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run dh_update_env distro_bootcmd ; reset" CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="imx8mp-dhcom-pdk2.dtb" @@ -102,16 +99,11 @@ CONFIG_CMD_MBR=y CONFIG_CMD_MMC=y CONFIG_CMD_BKOPS_ENABLE=y CONFIG_CMD_MTD=y -CONFIG_CMD_PART=y CONFIG_CMD_READ=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_SDP=y CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_PXE=y CONFIG_CMD_BOOTCOUNT=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y @@ -124,11 +116,7 @@ CONFIG_CMD_HASH=y CONFIG_CMD_SMC=y CONFIG_HASH_VERIFY=y CONFIG_CMD_BTRFS=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_FS_UUID=y CONFIG_CMD_MTDPARTS=y CONFIG_CMD_MTDPARTS_SHOW_NET_SIZES=y @@ -248,7 +236,6 @@ CONFIG_USB_XHCI_DWC3_OF_SIMPLE=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y -CONFIG_USB_STORAGE=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_GADGET=y diff --git a/configs/imx8mq_phanbell_defconfig b/configs/imx8mq_phanbell_defconfig index bcf48c55aa05..9fc91171a615 100644 --- a/configs/imx8mq_phanbell_defconfig +++ b/configs/imx8mq_phanbell_defconfig @@ -27,6 +27,7 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_SD_BOOT=y CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/imx8qm_mek_defconfig b/configs/imx8qm_mek_defconfig index 7f7a20e5a2f9..7a54823481ac 100644 --- a/configs/imx8qm_mek_defconfig +++ b/configs/imx8qm_mek_defconfig @@ -26,6 +26,7 @@ CONFIG_SYS_LOAD_ADDR=0x80280000 CONFIG_REMAKE_ELF=y CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_BOOTDELAY=3 diff --git a/configs/imx8qm_rom7720_a1_4G_defconfig b/configs/imx8qm_rom7720_a1_4G_defconfig index 83f07768278f..ecf5c43e0c87 100644 --- a/configs/imx8qm_rom7720_a1_4G_defconfig +++ b/configs/imx8qm_rom7720_a1_4G_defconfig @@ -22,6 +22,7 @@ CONFIG_REMAKE_ELF=y CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else booti ${loadaddr} - ${fdt_addr}; fi" diff --git a/configs/imx8qxp_mek_defconfig b/configs/imx8qxp_mek_defconfig index f34b988c2e10..159efca52312 100644 --- a/configs/imx8qxp_mek_defconfig +++ b/configs/imx8qxp_mek_defconfig @@ -26,6 +26,7 @@ CONFIG_SYS_LOAD_ADDR=0x80280000 CONFIG_REMAKE_ELF=y CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_BOOTDELAY=3 diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig index 6a81b979a7ec..0352da58e764 100644 --- a/configs/inetspace_v2_defconfig +++ b/configs/inetspace_v2_defconfig @@ -17,6 +17,7 @@ CONFIG_IDENT_STRING=" IS v2" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 # CONFIG_SYS_MALLOC_F is not set +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" diff --git a/configs/iot_devkit_defconfig b/configs/iot_devkit_defconfig index 4a5bfc5e1a22..860442988ce4 100644 --- a/configs/iot_devkit_defconfig +++ b/configs/iot_devkit_defconfig @@ -26,7 +26,6 @@ CONFIG_SYS_PBSIZE=280 # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y CONFIG_CMD_USB=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_FAT=y @@ -43,5 +42,4 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_DWC2=y CONFIG_USB_DWC2_BUFFER_SIZE=16 -CONFIG_USB_STORAGE=y CONFIG_FS_FAT_MAX_CLUSTSIZE=4096 diff --git a/configs/j7200_evm_a72_defconfig b/configs/j7200_evm_a72_defconfig index 7e1b22853a4e..1ebfb8e87927 100644 --- a/configs/j7200_evm_a72_defconfig +++ b/configs/j7200_evm_a72_defconfig @@ -31,6 +31,7 @@ CONFIG_SPL_SPI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" diff --git a/configs/j7200_evm_r5_defconfig b/configs/j7200_evm_r5_defconfig index 00ec48b83b78..9f05caa0fc8b 100644 --- a/configs/j7200_evm_r5_defconfig +++ b/configs/j7200_evm_r5_defconfig @@ -28,7 +28,6 @@ CONFIG_SPL_SPI=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y -CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_MAX_SIZE=0xc0000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -74,7 +73,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_REMOTEPROC=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y @@ -164,7 +162,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0x6164 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_FS_EXT4=y CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 CONFIG_LIB_RATIONAL=y CONFIG_SPL_LIB_RATIONAL=y diff --git a/configs/j7200_hs_evm_a72_defconfig b/configs/j7200_hs_evm_a72_defconfig index e8bd1610eb09..e5eff9a86da2 100644 --- a/configs/j7200_hs_evm_a72_defconfig +++ b/configs/j7200_hs_evm_a72_defconfig @@ -32,6 +32,7 @@ CONFIG_SPL_SPI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; run get_fit_${boot}; run get_overlaystring; run run_fit" diff --git a/configs/j7200_hs_evm_r5_defconfig b/configs/j7200_hs_evm_r5_defconfig index 94a6523f06c2..9af59c50cc2f 100644 --- a/configs/j7200_hs_evm_r5_defconfig +++ b/configs/j7200_hs_evm_r5_defconfig @@ -28,7 +28,6 @@ CONFIG_SPL_SPI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 -CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_MAX_SIZE=0xc0000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -74,7 +73,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_REMOTEPROC=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y @@ -164,7 +162,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0x6164 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_FS_EXT4=y CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 CONFIG_LIB_RATIONAL=y CONFIG_SPL_LIB_RATIONAL=y diff --git a/configs/j721e_evm_r5_defconfig b/configs/j721e_evm_r5_defconfig index 16fa386792d4..b3d1ecad55ba 100644 --- a/configs/j721e_evm_r5_defconfig +++ b/configs/j721e_evm_r5_defconfig @@ -29,7 +29,6 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y CONFIG_OF_BOARD_SETUP=y -CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_MAX_SIZE=0xc0000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -75,7 +74,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_REMOTEPROC=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y -CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y @@ -170,7 +168,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0x6163 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_FS_EXT4=y CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 CONFIG_LIB_RATIONAL=y CONFIG_SPL_LIB_RATIONAL=y diff --git a/configs/j721e_hs_evm_a72_defconfig b/configs/j721e_hs_evm_a72_defconfig index 99a7bcd2faef..3bf0c706bac1 100644 --- a/configs/j721e_hs_evm_a72_defconfig +++ b/configs/j721e_hs_evm_a72_defconfig @@ -30,6 +30,7 @@ CONFIG_SPL_SPI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run main_cpsw0_qsgmii_phyinit; run boot_rprocs; run get_fit_${boot}; run get_overlay_${boot}; run run_fit" diff --git a/configs/j721e_hs_evm_r5_defconfig b/configs/j721e_hs_evm_r5_defconfig index 7d6a047f3a58..0fe56b89e4b6 100644 --- a/configs/j721e_hs_evm_r5_defconfig +++ b/configs/j721e_hs_evm_r5_defconfig @@ -29,7 +29,6 @@ CONFIG_SPL_SPI=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 CONFIG_OF_BOARD_SETUP=y -CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_MAX_SIZE=0xc0000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -75,7 +74,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_REMOTEPROC=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y -CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y @@ -170,7 +168,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0x6163 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_FS_EXT4=y CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 CONFIG_LIB_RATIONAL=y CONFIG_SPL_LIB_RATIONAL=y diff --git a/configs/j721s2_evm_a72_defconfig b/configs/j721s2_evm_a72_defconfig index f28a2722a075..b56055fc7bf1 100644 --- a/configs/j721s2_evm_a72_defconfig +++ b/configs/j721s2_evm_a72_defconfig @@ -29,6 +29,7 @@ CONFIG_SPL_SPI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" diff --git a/configs/j721s2_evm_r5_defconfig b/configs/j721s2_evm_r5_defconfig index 343e3c16305f..00895b5adfec 100644 --- a/configs/j721s2_evm_r5_defconfig +++ b/configs/j721s2_evm_r5_defconfig @@ -30,7 +30,6 @@ CONFIG_SPL_SPI=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y -CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_SIZE_LIMIT_SUBTRACT_GD=y CONFIG_SPL_SIZE_LIMIT_SUBTRACT_MALLOC=y @@ -81,7 +80,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_REMOTEPROC=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_SPL_MULTI_DTB_FIT=y @@ -173,7 +171,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0x6168 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_FS_EXT4=y CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 CONFIG_PANIC_HANG=y CONFIG_LIB_RATIONAL=y diff --git a/configs/j721s2_hs_evm_a72_defconfig b/configs/j721s2_hs_evm_a72_defconfig index 6569d7da221f..2d185e99aaf1 100644 --- a/configs/j721s2_hs_evm_a72_defconfig +++ b/configs/j721s2_hs_evm_a72_defconfig @@ -32,6 +32,7 @@ CONFIG_SPL_SPI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; run get_fit_${boot}; run get_overlaystring; run run_fit" diff --git a/configs/j721s2_hs_evm_r5_defconfig b/configs/j721s2_hs_evm_r5_defconfig index c8433a1de950..648e7dc3acc3 100644 --- a/configs/j721s2_hs_evm_r5_defconfig +++ b/configs/j721s2_hs_evm_r5_defconfig @@ -30,7 +30,6 @@ CONFIG_SPL_SPI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 -CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_SIZE_LIMIT_SUBTRACT_GD=y CONFIG_SPL_SIZE_LIMIT_SUBTRACT_MALLOC=y @@ -81,7 +80,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_REMOTEPROC=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y @@ -168,7 +166,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0x6168 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_FS_EXT4=y CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 CONFIG_PANIC_HANG=y CONFIG_LIB_RATIONAL=y diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index 6d9d82594e18..214c43000056 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -26,6 +26,7 @@ CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_TIMESTAMP=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run init_${boot}; run get_mon_${boot} run_mon; run get_kern_${boot}; run init_fw_rd_${boot}; run get_fdt_${boot}; run run_kern" diff --git a/configs/k2e_hs_evm_defconfig b/configs/k2e_hs_evm_defconfig index c782bf118308..04139d5dd192 100644 --- a/configs/k2e_hs_evm_defconfig +++ b/configs/k2e_hs_evm_defconfig @@ -17,6 +17,7 @@ CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x100000 CONFIG_DEFAULT_DEVICE_TREE="keystone-k2e-evm" CONFIG_TIMESTAMP=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run run_mon_hs; run init_${boot}; run get_fit_${boot}; bootm ${addr_fit}#${name_fdt}" diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 756e7502a19d..92a7eee21533 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -25,6 +25,7 @@ CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_TIMESTAMP=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run get_mon_${boot} run_mon; run set_name_pmmc get_pmmc_${boot} run_pmmc; run get_kern_${boot}; run init_fw_rd_${boot}; run get_fdt_${boot}; run run_kern" diff --git a/configs/k2g_hs_evm_defconfig b/configs/k2g_hs_evm_defconfig index f0de3232e9d8..459c4a40e3d0 100644 --- a/configs/k2g_hs_evm_defconfig +++ b/configs/k2g_hs_evm_defconfig @@ -16,6 +16,7 @@ CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_ENV_SIZE=0x40000 CONFIG_DEFAULT_DEVICE_TREE="keystone-k2g-evm" CONFIG_TIMESTAMP=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run findfdt; run envboot; run run_mon_hs; run init_${boot}; run get_fit_${boot}; bootm ${addr_fit}#${name_fdt}" diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index 74ef0668d862..e8f52437942b 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -26,6 +26,7 @@ CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_TIMESTAMP=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run init_${boot}; run get_mon_${boot} run_mon; run get_kern_${boot}; run init_fw_rd_${boot}; run get_fdt_${boot}; run run_kern" diff --git a/configs/k2hk_hs_evm_defconfig b/configs/k2hk_hs_evm_defconfig index 5bd8c28f546d..bd2b4932607b 100644 --- a/configs/k2hk_hs_evm_defconfig +++ b/configs/k2hk_hs_evm_defconfig @@ -17,6 +17,7 @@ CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x100000 CONFIG_DEFAULT_DEVICE_TREE="keystone-k2hk-evm" CONFIG_TIMESTAMP=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run run_mon_hs; run init_${boot}; run get_fit_${boot}; bootm ${addr_fit}#${name_fdt}" diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 378a71f94e1a..fa91e88cf84d 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -26,6 +26,7 @@ CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_TIMESTAMP=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run init_${boot}; run get_mon_${boot} run_mon; run get_kern_${boot}; run init_fw_rd_${boot}; run get_fdt_${boot}; run run_kern" diff --git a/configs/k2l_hs_evm_defconfig b/configs/k2l_hs_evm_defconfig index 31ec3029d76f..9be8e46b9a7d 100644 --- a/configs/k2l_hs_evm_defconfig +++ b/configs/k2l_hs_evm_defconfig @@ -17,6 +17,7 @@ CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x100000 CONFIG_DEFAULT_DEVICE_TREE="keystone-k2l-evm" CONFIG_TIMESTAMP=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run run_mon_hs; run init_${boot}; run get_fit_${boot}; bootm ${addr_fit}#${name_fdt}" diff --git a/configs/kmcent2_defconfig b/configs/kmcent2_defconfig index 29c86530795b..16db4054287d 100644 --- a/configs/kmcent2_defconfig +++ b/configs/kmcent2_defconfig @@ -41,12 +41,8 @@ CONFIG_CMD_MTD=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_SPI=y CONFIG_BOOTP_BOOTFILESIZE=y -CONFIG_CMD_PING=y CONFIG_CMD_ETHSW=y CONFIG_CMD_CRAMFS=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FAT=y CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor,nand0=ffa000000.flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:128k(RCW),128k(fman),128k(QE),128k(zarlink),512k(res),62m(ubi0),128k(envred),128k(env),768k(u-boot);ffa000000.flash:-(ubi1);" CONFIG_CMD_UBI=y diff --git a/configs/koelsch_defconfig b/configs/koelsch_defconfig index 45fa50725c15..9b3fcc778856 100644 --- a/configs/koelsch_defconfig +++ b/configs/koelsch_defconfig @@ -45,7 +45,6 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=256 -CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_XIMG is not set CONFIG_CMD_GPIO=y @@ -55,15 +54,9 @@ CONFIG_CMD_PCI=y CONFIG_CMD_SDRAM=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=spi0.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k(u-boot-env2),768k(u-boot),-(user)" @@ -102,5 +95,4 @@ CONFIG_SH_QSPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_PCI=y -CONFIG_USB_STORAGE=y CONFIG_SYS_TIMER_COUNTS_DOWN=y diff --git a/configs/kp_imx53_defconfig b/configs/kp_imx53_defconfig index 14cb69d9f199..0cd82d3819cc 100644 --- a/configs/kp_imx53_defconfig +++ b/configs/kp_imx53_defconfig @@ -11,11 +11,9 @@ CONFIG_ENV_OFFSET_REDUND=0x102000 # CONFIG_CMD_BMODE is not set CONFIG_SYS_LOAD_ADDR=0x72000000 CONFIG_FIT=y -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_SHOW_BOOT_PROGRESS=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR="." -CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run usbupd; run distro_bootcmd" CONFIG_SILENT_CONSOLE=y # CONFIG_SILENT_CONSOLE_UPDATE_ON_SET is not set @@ -23,18 +21,10 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PBSIZE=532 -CONFIG_CMD_BOOTZ=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y -CONFIG_CMD_PART=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_PMIC=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y @@ -60,6 +50,5 @@ CONFIG_CONS_INDEX=2 CONFIG_MXC_UART=y CONFIG_USB=y CONFIG_USB_EHCI_MX5=y -CONFIG_USB_STORAGE=y CONFIG_HEXDUMP=y # CONFIG_EFI_LOADER is not set diff --git a/configs/lager_defconfig b/configs/lager_defconfig index c9dbf697cc4d..531877b0ac37 100644 --- a/configs/lager_defconfig +++ b/configs/lager_defconfig @@ -45,7 +45,6 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=256 -CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_XIMG is not set CONFIG_CMD_GPIO=y @@ -55,15 +54,9 @@ CONFIG_CMD_PCI=y CONFIG_CMD_SDRAM=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=spi0.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k(u-boot-env2),768k(u-boot),-(user)" @@ -104,5 +97,4 @@ CONFIG_SH_QSPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_PCI=y -CONFIG_USB_STORAGE=y CONFIG_SYS_TIMER_COUNTS_DOWN=y diff --git a/configs/legoev3_defconfig b/configs/legoev3_defconfig index d739e186610b..3bb67c0c255a 100644 --- a/configs/legoev3_defconfig +++ b/configs/legoev3_defconfig @@ -12,6 +12,7 @@ CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_ENV_SIZE=0x4000 CONFIG_DEFAULT_DEVICE_TREE="da850-lego-ev3" CONFIG_SYS_LOAD_ADDR=0xc0700000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DYNAMIC_SYS_CLK_FREQ=y CONFIG_BOOTDELAY=0 CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/linkit-smart-7688_defconfig b/configs/linkit-smart-7688_defconfig index 0bdb4e612c54..35f56b8310b0 100644 --- a/configs/linkit-smart-7688_defconfig +++ b/configs/linkit-smart-7688_defconfig @@ -48,14 +48,9 @@ CONFIG_CMD_MEMINFO=y CONFIG_CMD_GPIO=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_MTD=y -CONFIG_CMD_PART=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_TIME=y -CONFIG_CMD_FS_GENERIC=y # CONFIG_DOS_PARTITION is not set CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y @@ -82,9 +77,6 @@ CONFIG_MT7621_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y -CONFIG_USB_STORAGE=y -CONFIG_FS_EXT4=y -CONFIG_FS_FAT=y CONFIG_LZMA=y CONFIG_LZO=y CONFIG_SPL_LZMA=y diff --git a/configs/liteboard_defconfig b/configs/liteboard_defconfig index adf65b399af1..4fd176cfd7ad 100644 --- a/configs/liteboard_defconfig +++ b/configs/liteboard_defconfig @@ -19,6 +19,7 @@ CONFIG_SPL=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x88000000 CONFIG_SYS_MONITOR_LEN=409600 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=1 CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/ls1021aiot_qspi_defconfig b/configs/ls1021aiot_qspi_defconfig index e6cd6a7d19c4..7ba3c0210d1e 100644 --- a/configs/ls1021aiot_qspi_defconfig +++ b/configs/ls1021aiot_qspi_defconfig @@ -27,19 +27,13 @@ CONFIG_MISC_INIT_R=y CONFIG_ID_EEPROM=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 -CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 CONFIG_CMD_MEMINFO=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y # CONFIG_CMD_MDIO is not set -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y diff --git a/configs/ls1021aiot_sdcard_defconfig b/configs/ls1021aiot_sdcard_defconfig index 9c298b0cc973..7a6c46fc28f2 100644 --- a/configs/ls1021aiot_sdcard_defconfig +++ b/configs/ls1021aiot_sdcard_defconfig @@ -54,19 +54,13 @@ CONFIG_SPL_MPC8XXX_INIT_DDR=y CONFIG_SPL_WATCHDOG=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 -CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 CONFIG_CMD_MEMINFO=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y # CONFIG_CMD_MDIO is not set -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index e694619efce0..fa369006dc80 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -37,7 +37,6 @@ CONFIG_ID_EEPROM=y CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 -CONFIG_CMD_BOOTZ=y CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_IMLS=y CONFIG_CMD_GREPENV=y @@ -51,11 +50,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y @@ -103,4 +97,3 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_STORAGE=y diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index e4e49baa32d2..366b2215cbe8 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -37,7 +37,6 @@ CONFIG_ID_EEPROM=y CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 -CONFIG_CMD_BOOTZ=y CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_IMLS=y CONFIG_CMD_GREPENV=y @@ -51,11 +50,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y @@ -103,4 +97,3 @@ CONFIG_LPUART=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_STORAGE=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index de632a3f38c3..ef2f5bc19e6f 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -66,7 +66,6 @@ CONFIG_SPL_WATCHDOG=y CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 -CONFIG_CMD_BOOTZ=y CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_IMLS=y CONFIG_CMD_GREPENV=y @@ -80,11 +79,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y @@ -134,4 +128,3 @@ CONFIG_SYS_NS16550_SERIAL=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_STORAGE=y diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index 40228acaa896..75ad7a9f2053 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -36,7 +36,6 @@ CONFIG_ID_EEPROM=y CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 -CONFIG_CMD_BOOTZ=y CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_IMLS=y CONFIG_CMD_GREPENV=y @@ -50,11 +49,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_USE_ETHPRIME=y @@ -100,5 +94,4 @@ CONFIG_SYS_NS16550_SERIAL=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_STORAGE=y CONFIG_RSA=y diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index 47eb897b3768..63e4f1837893 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -37,7 +37,6 @@ CONFIG_ID_EEPROM=y CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 -CONFIG_CMD_BOOTZ=y CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_IMLS=y CONFIG_CMD_GREPENV=y @@ -51,11 +50,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y @@ -105,4 +99,3 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_STORAGE=y diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index 7dad3239ab4e..358c78e1bed8 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -37,7 +37,6 @@ CONFIG_ID_EEPROM=y CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 -CONFIG_CMD_BOOTZ=y CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_IMLS=y CONFIG_CMD_GREPENV=y @@ -51,11 +50,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y @@ -105,4 +99,3 @@ CONFIG_LPUART=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_STORAGE=y diff --git a/configs/ls1021aqds_qspi_defconfig b/configs/ls1021aqds_qspi_defconfig index ebf6fdb463c6..6213785c9e47 100644 --- a/configs/ls1021aqds_qspi_defconfig +++ b/configs/ls1021aqds_qspi_defconfig @@ -36,7 +36,6 @@ CONFIG_ID_EEPROM=y CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 -CONFIG_CMD_BOOTZ=y CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_GREPENV=y CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=5 @@ -48,11 +47,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y @@ -92,4 +86,3 @@ CONFIG_FSL_QSPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_STORAGE=y diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index 27784e3715d2..d382c4192f38 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -64,7 +64,6 @@ CONFIG_SPL_WATCHDOG=y CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 -CONFIG_CMD_BOOTZ=y CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_IMLS=y CONFIG_CMD_GREPENV=y @@ -78,11 +77,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y @@ -131,4 +125,3 @@ CONFIG_SYS_NS16550_SERIAL=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_STORAGE=y diff --git a/configs/ls1021aqds_sdcard_qspi_defconfig b/configs/ls1021aqds_sdcard_qspi_defconfig index d8973bf3151e..093657249e47 100644 --- a/configs/ls1021aqds_sdcard_qspi_defconfig +++ b/configs/ls1021aqds_sdcard_qspi_defconfig @@ -63,7 +63,6 @@ CONFIG_SPL_WATCHDOG=y CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 -CONFIG_CMD_BOOTZ=y CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_GREPENV=y CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=5 @@ -75,11 +74,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y @@ -120,4 +114,3 @@ CONFIG_FSL_QSPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_STORAGE=y diff --git a/configs/ls1088aqds_defconfig b/configs/ls1088aqds_defconfig index d4793f8edc99..b6058cbc8e67 100644 --- a/configs/ls1088aqds_defconfig +++ b/configs/ls1088aqds_defconfig @@ -26,6 +26,7 @@ CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_REMAKE_ELF=y CONFIG_MP=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DYNAMIC_SYS_CLK_FREQ=y diff --git a/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig b/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig index ff5714027df7..e423b0e5b45f 100644 --- a/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig @@ -26,6 +26,7 @@ CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_REMAKE_ELF=y CONFIG_MP=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1088aqds_qspi_defconfig b/configs/ls1088aqds_qspi_defconfig index 21d3a3883ae0..167c3cc77fb5 100644 --- a/configs/ls1088aqds_qspi_defconfig +++ b/configs/ls1088aqds_qspi_defconfig @@ -28,6 +28,7 @@ CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_REMAKE_ELF=y CONFIG_MP=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1088aqds_sdcard_ifc_defconfig b/configs/ls1088aqds_sdcard_ifc_defconfig index 1d429a06f3b2..104f178f36c7 100644 --- a/configs/ls1088aqds_sdcard_ifc_defconfig +++ b/configs/ls1088aqds_sdcard_ifc_defconfig @@ -34,6 +34,7 @@ CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_REMAKE_ELF=y CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_MP=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_DYNAMIC_SYS_CLK_FREQ=y CONFIG_SD_BOOT=y diff --git a/configs/ls1088aqds_sdcard_qspi_defconfig b/configs/ls1088aqds_sdcard_qspi_defconfig index a0a8a2b73672..348e48c3a5e7 100644 --- a/configs/ls1088aqds_sdcard_qspi_defconfig +++ b/configs/ls1088aqds_sdcard_qspi_defconfig @@ -35,6 +35,7 @@ CONFIG_REMAKE_ELF=y CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_MP=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SD_BOOT=y diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index 7d7b4d8944a5..94584cb1f728 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -20,6 +20,7 @@ CONFIG_REMAKE_ELF=y CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_MP=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DYNAMIC_SYS_CLK_FREQ=y diff --git a/configs/ls2080aqds_defconfig b/configs/ls2080aqds_defconfig index 6de99f3a0204..d186aa27aebf 100644 --- a/configs/ls2080aqds_defconfig +++ b/configs/ls2080aqds_defconfig @@ -21,6 +21,7 @@ CONFIG_REMAKE_ELF=y CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_MP=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DYNAMIC_SYS_CLK_FREQ=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 8787b9af9386..63ddd1f59742 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -26,6 +26,7 @@ CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DYNAMIC_SYS_CLK_FREQ=y diff --git a/configs/ls2080aqds_qspi_defconfig b/configs/ls2080aqds_qspi_defconfig index 0ef4d126af44..88d5f31dcd4b 100644 --- a/configs/ls2080aqds_qspi_defconfig +++ b/configs/ls2080aqds_qspi_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DYNAMIC_SYS_CLK_FREQ=y diff --git a/configs/ls2080aqds_sdcard_defconfig b/configs/ls2080aqds_sdcard_defconfig index 2fa28a2bb6ab..c496c504c298 100644 --- a/configs/ls2080aqds_sdcard_defconfig +++ b/configs/ls2080aqds_sdcard_defconfig @@ -27,6 +27,7 @@ CONFIG_REMAKE_ELF=y CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_MP=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DYNAMIC_SYS_CLK_FREQ=y diff --git a/configs/m53menlo_defconfig b/configs/m53menlo_defconfig index 9f01bf73ab86..5facc489fe18 100644 --- a/configs/m53menlo_defconfig +++ b/configs/m53menlo_defconfig @@ -23,6 +23,7 @@ CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y CONFIG_ENV_OFFSET_REDUND=0x180000 CONFIG_SYS_LOAD_ADDR=0x70800000 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=1 CONFIG_USE_BOOTARGS=y diff --git a/configs/malta64_defconfig b/configs/malta64_defconfig index 03de1616840b..0804903cff9a 100644 --- a/configs/malta64_defconfig +++ b/configs/malta64_defconfig @@ -25,9 +25,7 @@ CONFIG_CMD_IDE=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set -CONFIG_CMD_PING=y CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y diff --git a/configs/malta64el_defconfig b/configs/malta64el_defconfig index 3ea9fa9857e8..ff18c455f93e 100644 --- a/configs/malta64el_defconfig +++ b/configs/malta64el_defconfig @@ -27,9 +27,7 @@ CONFIG_CMD_IDE=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set -CONFIG_CMD_PING=y CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y diff --git a/configs/malta_defconfig b/configs/malta_defconfig index 317b422a6b65..2968fb90e5a7 100644 --- a/configs/malta_defconfig +++ b/configs/malta_defconfig @@ -24,9 +24,7 @@ CONFIG_CMD_IDE=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set -CONFIG_CMD_PING=y CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y diff --git a/configs/maltael_defconfig b/configs/maltael_defconfig index 3e4d2beda2f3..f56aa123b8aa 100644 --- a/configs/maltael_defconfig +++ b/configs/maltael_defconfig @@ -26,9 +26,7 @@ CONFIG_CMD_IDE=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set -CONFIG_CMD_PING=y CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y diff --git a/configs/meerkat96_defconfig b/configs/meerkat96_defconfig index 4fdcdafac205..1a4804bb9be9 100644 --- a/configs/meerkat96_defconfig +++ b/configs/meerkat96_defconfig @@ -18,21 +18,14 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 # CONFIG_CMD_BOOTD is not set -CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_XIMG is not set CONFIG_CMD_MEMTEST=y CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y -CONFIG_CMD_PART=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index b93c0d729f80..55106d965eeb 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -21,6 +21,7 @@ CONFIG_SEABIOS=y CONFIG_SYS_MONITOR_LEN=2097152 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SHOW_BOOT_PROGRESS=y diff --git a/configs/mt7620_rfb_defconfig b/configs/mt7620_rfb_defconfig index d96da91df364..da98eda59c64 100644 --- a/configs/mt7620_rfb_defconfig +++ b/configs/mt7620_rfb_defconfig @@ -40,13 +40,9 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_NFS is not set -CONFIG_CMD_MII=y # CONFIG_CMD_MDIO is not set -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_ISO_PARTITION is not set -CONFIG_EFI_PARTITION=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clocks clock-names interrupt-parent interrupts resets reset-names" CONFIG_ENV_IS_IN_SPI_FLASH=y diff --git a/configs/mt7621_nand_rfb_defconfig b/configs/mt7621_nand_rfb_defconfig index 5291bb300e47..6eaea383fed4 100644 --- a/configs/mt7621_nand_rfb_defconfig +++ b/configs/mt7621_nand_rfb_defconfig @@ -46,15 +46,11 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y CONFIG_CMD_MTD=y -CONFIG_CMD_PART=y # CONFIG_CMD_PINMUX is not set CONFIG_CMD_USB=y # CONFIG_CMD_NFS is not set -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_ISO_PARTITION is not set -CONFIG_EFI_PARTITION=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_PARTITION_TYPE_GUID=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y @@ -81,7 +77,6 @@ CONFIG_SYSRESET_RESETCTL=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_MTK=y -CONFIG_USB_STORAGE=y CONFIG_WDT=y CONFIG_WDT_MT7621=y CONFIG_FAT_WRITE=y diff --git a/configs/mt7621_rfb_defconfig b/configs/mt7621_rfb_defconfig index b50fbec92dd0..f2e457e4641a 100644 --- a/configs/mt7621_rfb_defconfig +++ b/configs/mt7621_rfb_defconfig @@ -44,14 +44,11 @@ CONFIG_SYS_BOOTM_LEN=0x2000000 CONFIG_CMD_GPIO=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y -CONFIG_CMD_PART=y # CONFIG_CMD_PINMUX is not set CONFIG_CMD_SPI=y # CONFIG_CMD_NFS is not set -CONFIG_DOS_PARTITION=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_ISO_PARTITION is not set -CONFIG_EFI_PARTITION=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_PARTITION_TYPE_GUID=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/mt7622_rfb_defconfig b/configs/mt7622_rfb_defconfig index c09c2221a540..0a76efdbd7ec 100644 --- a/configs/mt7622_rfb_defconfig +++ b/configs/mt7622_rfb_defconfig @@ -21,7 +21,6 @@ CONFIG_CMD_BOOTMENU=y CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y CONFIG_CMD_SF_TEST=y -CONFIG_CMD_PING=y CONFIG_CMD_SMC=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y diff --git a/configs/mt7629_rfb_defconfig b/configs/mt7629_rfb_defconfig index ea8d77c0a26e..e422752d6788 100644 --- a/configs/mt7629_rfb_defconfig +++ b/configs/mt7629_rfb_defconfig @@ -49,9 +49,6 @@ CONFIG_CMD_SF_TEST=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set -CONFIG_CMD_PING=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_LOG=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-parents" CONFIG_ENV_OVERWRITE=y @@ -101,7 +98,6 @@ CONFIG_SYSRESET_WATCHDOG=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_MTK=y -CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_WDT_MTK=y CONFIG_LZMA=y diff --git a/configs/mt7981_emmc_rfb_defconfig b/configs/mt7981_emmc_rfb_defconfig index b3b37b6e5ed4..a739e2733c41 100644 --- a/configs/mt7981_emmc_rfb_defconfig +++ b/configs/mt7981_emmc_rfb_defconfig @@ -32,12 +32,8 @@ CONFIG_CMD_GPT=y CONFIG_CMD_GPT_RENAME=y CONFIG_CMD_LSBLK=y CONFIG_CMD_MMC=y -CONFIG_CMD_PART=y CONFIG_CMD_READ=y -CONFIG_CMD_PING=y CONFIG_CMD_SMC=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_PARTITION_TYPE_GUID=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y diff --git a/configs/mt7981_sd_rfb_defconfig b/configs/mt7981_sd_rfb_defconfig index 85be9bbc5030..e7ab0bd15db0 100644 --- a/configs/mt7981_sd_rfb_defconfig +++ b/configs/mt7981_sd_rfb_defconfig @@ -32,12 +32,8 @@ CONFIG_CMD_GPT=y CONFIG_CMD_GPT_RENAME=y CONFIG_CMD_LSBLK=y CONFIG_CMD_MMC=y -CONFIG_CMD_PART=y CONFIG_CMD_READ=y -CONFIG_CMD_PING=y CONFIG_CMD_SMC=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_PARTITION_TYPE_GUID=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y diff --git a/configs/mt7986a_bpir3_emmc_defconfig b/configs/mt7986a_bpir3_emmc_defconfig index 2d4876f299f4..3d3e40089140 100644 --- a/configs/mt7986a_bpir3_emmc_defconfig +++ b/configs/mt7986a_bpir3_emmc_defconfig @@ -32,12 +32,8 @@ CONFIG_CMD_GPT=y CONFIG_CMD_GPT_RENAME=y CONFIG_CMD_LSBLK=y CONFIG_CMD_MMC=y -CONFIG_CMD_PART=y CONFIG_CMD_READ=y -CONFIG_CMD_PING=y CONFIG_CMD_SMC=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_PARTITION_TYPE_GUID=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y diff --git a/configs/mt7986a_bpir3_sd_defconfig b/configs/mt7986a_bpir3_sd_defconfig index 08edfe7ac409..eba389f79004 100644 --- a/configs/mt7986a_bpir3_sd_defconfig +++ b/configs/mt7986a_bpir3_sd_defconfig @@ -32,12 +32,8 @@ CONFIG_CMD_GPT=y CONFIG_CMD_GPT_RENAME=y CONFIG_CMD_LSBLK=y CONFIG_CMD_MMC=y -CONFIG_CMD_PART=y CONFIG_CMD_READ=y -CONFIG_CMD_PING=y CONFIG_CMD_SMC=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_PARTITION_TYPE_GUID=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y diff --git a/configs/mt8183_pumpkin_defconfig b/configs/mt8183_pumpkin_defconfig index fdfe2a160088..3a7a85546c30 100644 --- a/configs/mt8183_pumpkin_defconfig +++ b/configs/mt8183_pumpkin_defconfig @@ -19,7 +19,6 @@ CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_FIT=y # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set -CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="mt8183-pumpkin" # CONFIG_DISPLAY_BOARDINFO is not set @@ -29,7 +28,6 @@ CONFIG_SYS_PBSIZE=276 # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set -# CONFIG_CMD_BOOTI is not set # CONFIG_CMD_ELF is not set # CONFIG_CMD_GO is not set # CONFIG_CMD_IMI is not set @@ -45,14 +43,10 @@ CONFIG_CMD_GPT=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y -CONFIG_CMD_PART=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_BLOCK_CACHE is not set CONFIG_CMD_SYSBOOT=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y # CONFIG_DOS_PARTITION is not set CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_MMC_ENV_PART=2 diff --git a/configs/mt8512_bm1_emmc_defconfig b/configs/mt8512_bm1_emmc_defconfig index 772306c1525c..b14bf56a7f97 100644 --- a/configs/mt8512_bm1_emmc_defconfig +++ b/configs/mt8512_bm1_emmc_defconfig @@ -20,10 +20,7 @@ CONFIG_SYS_PBSIZE=281 CONFIG_CMD_BOOTMENU=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y # CONFIG_DOS_PARTITION is not set -CONFIG_EFI_PARTITION=y CONFIG_ENV_OVERWRITE=y CONFIG_REGMAP=y CONFIG_SYSCON=y @@ -54,7 +51,6 @@ CONFIG_USB=y CONFIG_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_MTU3=y -CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="MediaTek" CONFIG_USB_GADGET_VENDOR_NUM=0x0e8d diff --git a/configs/mt8516_pumpkin_defconfig b/configs/mt8516_pumpkin_defconfig index 10d82142558a..c1fb9a98abfc 100644 --- a/configs/mt8516_pumpkin_defconfig +++ b/configs/mt8516_pumpkin_defconfig @@ -17,7 +17,6 @@ CONFIG_SYS_LOAD_ADDR=0x4c000000 CONFIG_DEBUG_UART=y CONFIG_FIT=y # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set -CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="mt8516-pumpkin" # CONFIG_DISPLAY_BOARDINFO is not set @@ -28,7 +27,6 @@ CONFIG_SYS_PBSIZE=276 # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set -# CONFIG_CMD_BOOTI is not set # CONFIG_CMD_ELF is not set # CONFIG_CMD_GO is not set # CONFIG_CMD_IMI is not set @@ -36,7 +34,6 @@ CONFIG_SYS_PBSIZE=276 # CONFIG_CMD_EXPORTENV is not set # CONFIG_CMD_IMPORTENV is not set # CONFIG_CMD_EDITENV is not set -# CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_CRC32 is not set # CONFIG_CMD_MEMORY is not set CONFIG_CMD_GPT=y @@ -44,16 +41,12 @@ CONFIG_CMD_GPT=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y -CONFIG_CMD_PART=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_BLOCK_CACHE is not set # CONFIG_CMD_SLEEP is not set CONFIG_CMD_SYSBOOT=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y # CONFIG_DOS_PARTITION is not set CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/mt8518_ap1_emmc_defconfig b/configs/mt8518_ap1_emmc_defconfig index d75e299ce0d8..ee30e0e17309 100644 --- a/configs/mt8518_ap1_emmc_defconfig +++ b/configs/mt8518_ap1_emmc_defconfig @@ -19,7 +19,6 @@ CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=281 CONFIG_CMD_BOOTMENU=y CONFIG_CMD_MMC=y -CONFIG_EFI_PARTITION=y CONFIG_ENV_OVERWRITE=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/mx23_olinuxino_defconfig b/configs/mx23_olinuxino_defconfig index 89b69fb32366..fa6a02ea3e4f 100644 --- a/configs/mx23_olinuxino_defconfig +++ b/configs/mx23_olinuxino_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x42000000 # CONFIG_SYS_MALLOC_F is not set +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loaduimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" diff --git a/configs/mx23evk_defconfig b/configs/mx23evk_defconfig index 3602ead86358..9188fa42cb20 100644 --- a/configs/mx23evk_defconfig +++ b/configs/mx23evk_defconfig @@ -16,6 +16,7 @@ CONFIG_TARGET_MX23EVK=y CONFIG_SPL_SERIAL=y CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x42000000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else echo ERR: Fail to boot from MMC; fi; fi; else exit; fi" CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index dad8839a6c10..55bb25533535 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x42000000 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx51evk_defconfig b/configs/mx51evk_defconfig index b173648c8ebc..fcb4f0efc7e9 100644 --- a/configs/mx51evk_defconfig +++ b/configs/mx51evk_defconfig @@ -12,6 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx51-babbage" CONFIG_SYS_LOAD_ADDR=0x92000000 CONFIG_HAS_BOARD_SIZE_LIMIT=y CONFIG_BOARD_SIZE_LIMIT=785408 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" CONFIG_USE_PREBOOT=y diff --git a/configs/mx53loco_defconfig b/configs/mx53loco_defconfig index d5f2b7092db9..a8db48b92b0e 100644 --- a/configs/mx53loco_defconfig +++ b/configs/mx53loco_defconfig @@ -16,6 +16,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx53-qsb" CONFIG_SYS_LOAD_ADDR=0x72000000 CONFIG_HAS_BOARD_SIZE_LIMIT=y CONFIG_BOARD_SIZE_LIMIT=785408 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" diff --git a/configs/mx53ppd_defconfig b/configs/mx53ppd_defconfig index 055dbcb03351..cddbe85104b7 100644 --- a/configs/mx53ppd_defconfig +++ b/configs/mx53ppd_defconfig @@ -11,6 +11,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx53-ppd" CONFIG_BOOTCOUNT_BOOTLIMIT=10 CONFIG_SYS_LOAD_ADDR=0x72000000 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=1 diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index 74d710004a56..b9d4321972e6 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -27,6 +27,7 @@ CONFIG_SYS_MONITOR_LEN=409600 CONFIG_FIT=y CONFIG_SPL_FIT_PRINT=y CONFIG_SPL_LOAD_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run findfdt;mmc dev ${mmcdev};if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index b4474de00d84..368fa5b0833e 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -26,6 +26,7 @@ CONFIG_SYS_MONITOR_LEN=409600 CONFIG_FIT=y CONFIG_SPL_FIT_PRINT=y CONFIG_SPL_LOAD_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run findfdt;mmc dev ${mmcdev};if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" diff --git a/configs/mx6slevk_defconfig b/configs/mx6slevk_defconfig index 1748f9fda518..319a4ac48e55 100644 --- a/configs/mx6slevk_defconfig +++ b/configs/mx6slevk_defconfig @@ -11,6 +11,7 @@ CONFIG_TARGET_MX6SLEVK=y CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="imx6sl-evk" # CONFIG_CMD_BMODE is not set +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" diff --git a/configs/mx6slevk_spinor_defconfig b/configs/mx6slevk_spinor_defconfig index 4d477f9a8d65..901e645b1fcb 100644 --- a/configs/mx6slevk_spinor_defconfig +++ b/configs/mx6slevk_spinor_defconfig @@ -12,6 +12,7 @@ CONFIG_TARGET_MX6SLEVK=y CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="imx6sl-evk" # CONFIG_CMD_BMODE is not set +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_SPI_BOOT=y CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/mx6slevk_spl_defconfig b/configs/mx6slevk_spl_defconfig index 096edb3b21b6..f1a93e7fc2b5 100644 --- a/configs/mx6slevk_spl_defconfig +++ b/configs/mx6slevk_spl_defconfig @@ -23,6 +23,7 @@ CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y # CONFIG_CMD_BMODE is not set CONFIG_SYS_MONITOR_LEN=409600 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" diff --git a/configs/mx6sllevk_defconfig b/configs/mx6sllevk_defconfig index ea46071626a1..4f0a96979521 100644 --- a/configs/mx6sllevk_defconfig +++ b/configs/mx6sllevk_defconfig @@ -12,6 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6sll-evk" # CONFIG_CMD_BMODE is not set CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x88000000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" diff --git a/configs/mx6sllevk_plugin_defconfig b/configs/mx6sllevk_plugin_defconfig index 885dda716c19..31897d3b2aa3 100644 --- a/configs/mx6sllevk_plugin_defconfig +++ b/configs/mx6sllevk_plugin_defconfig @@ -13,6 +13,7 @@ CONFIG_USE_IMXIMG_PLUGIN=y # CONFIG_CMD_BMODE is not set CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x88000000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" diff --git a/configs/mx6sxsabreauto_defconfig b/configs/mx6sxsabreauto_defconfig index d41cbfe1a566..e04bc3f5c028 100644 --- a/configs/mx6sxsabreauto_defconfig +++ b/configs/mx6sxsabreauto_defconfig @@ -11,6 +11,7 @@ CONFIG_TARGET_MX6SXSABREAUTO=y CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="imx6sx-sabreauto" # CONFIG_CMD_BMODE is not set +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev};mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" diff --git a/configs/mx6sxsabresd_defconfig b/configs/mx6sxsabresd_defconfig index 7c44e13965d1..39afab42f8d1 100644 --- a/configs/mx6sxsabresd_defconfig +++ b/configs/mx6sxsabresd_defconfig @@ -12,6 +12,7 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="imx6sx-sdb" # CONFIG_CMD_BMODE is not set CONFIG_NXP_BOARD_REVISION=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run findfdt; mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index 765480cef3e5..fff2194c3454 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -23,6 +23,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x88000000 CONFIG_SYS_MONITOR_LEN=409600 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run findfdt;mmc dev ${mmcdev};mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" diff --git a/configs/mx6ul_9x9_evk_defconfig b/configs/mx6ul_9x9_evk_defconfig index 5eecbf4a7e92..a9ae79fbeabb 100644 --- a/configs/mx6ul_9x9_evk_defconfig +++ b/configs/mx6ul_9x9_evk_defconfig @@ -23,6 +23,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x88000000 CONFIG_SYS_MONITOR_LEN=409600 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run findfdt;mmc dev ${mmcdev};mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" diff --git a/configs/mx6ull_14x14_evk_defconfig b/configs/mx6ull_14x14_evk_defconfig index 8b8a8044e173..6df7fd6608fd 100644 --- a/configs/mx6ull_14x14_evk_defconfig +++ b/configs/mx6ull_14x14_evk_defconfig @@ -12,6 +12,7 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="imx6ull-14x14-evk" CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x88000000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run findfdt;mmc dev ${mmcdev};mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" diff --git a/configs/mx6ull_14x14_evk_plugin_defconfig b/configs/mx6ull_14x14_evk_plugin_defconfig index 4bed72d9cd6f..2959ca277e8d 100644 --- a/configs/mx6ull_14x14_evk_plugin_defconfig +++ b/configs/mx6ull_14x14_evk_plugin_defconfig @@ -13,6 +13,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6ull-14x14-evk" CONFIG_USE_IMXIMG_PLUGIN=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x88000000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run findfdt;mmc dev ${mmcdev};mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" diff --git a/configs/mx6ulz_14x14_evk_defconfig b/configs/mx6ulz_14x14_evk_defconfig index 4abb575a5360..8903e5d33019 100644 --- a/configs/mx6ulz_14x14_evk_defconfig +++ b/configs/mx6ulz_14x14_evk_defconfig @@ -12,6 +12,7 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="imx6ulz-14x14-evk" CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x88000000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run findfdt;mmc dev ${mmcdev};mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" diff --git a/configs/mx7ulp_com_defconfig b/configs/mx7ulp_com_defconfig index 00fd6aa34c9d..1430eaf0364a 100644 --- a/configs/mx7ulp_com_defconfig +++ b/configs/mx7ulp_com_defconfig @@ -13,6 +13,7 @@ CONFIG_TARGET_MX7ULP_COM=y CONFIG_SYS_LOAD_ADDR=0x60800000 CONFIG_HAS_BOARD_SIZE_LIMIT=y CONFIG_BOARD_SIZE_LIMIT=785408 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="if run loadimage; then run mmcboot; fi" CONFIG_DEFAULT_FDT_FILE="imx7ulp-com" diff --git a/configs/mx7ulp_evk_defconfig b/configs/mx7ulp_evk_defconfig index ecc42517b2ea..3775e167f860 100644 --- a/configs/mx7ulp_evk_defconfig +++ b/configs/mx7ulp_evk_defconfig @@ -12,6 +12,7 @@ CONFIG_TARGET_MX7ULP_EVK=y CONFIG_SYS_LOAD_ADDR=0x60800000 CONFIG_SYS_MEMTEST_START=0x60000000 CONFIG_SYS_MEMTEST_END=0x9e000000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; fi; fi; fi" diff --git a/configs/mx7ulp_evk_plugin_defconfig b/configs/mx7ulp_evk_plugin_defconfig index d31633ed8a59..97eda863d4dc 100644 --- a/configs/mx7ulp_evk_plugin_defconfig +++ b/configs/mx7ulp_evk_plugin_defconfig @@ -12,6 +12,7 @@ CONFIG_TARGET_MX7ULP_EVK=y CONFIG_SYS_LOAD_ADDR=0x60800000 CONFIG_SYS_MEMTEST_START=0x60000000 CONFIG_SYS_MEMTEST_END=0x9e000000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; fi; fi; fi" CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index 996bd186951f..3405cb4509c6 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -16,7 +16,6 @@ CONFIG_IDENT_STRING="\nNAS 220" CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set CONFIG_BOOTDELAY=3 -CONFIG_USE_BOOTCOMMAND=y CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_RESET_PHY_R=y @@ -28,21 +27,12 @@ CONFIG_CMD_IDE=y CONFIG_CMD_NAND=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y CONFIG_SYS_DISABLE_AUTOLOAD=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=orion_nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=orion_nand:0xa0000@0x0(uboot),0x010000@0xa0000(env),0x500000@0xc0000(uimage),0x1a40000@0x5c0000(rootfs)" CONFIG_CMD_UBI=y -CONFIG_ISO_PARTITION=y -CONFIG_EFI_PARTITION=y -# CONFIG_PARTITION_UUIDS is not set CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y @@ -66,6 +56,5 @@ CONFIG_SYS_NS16550_SERIAL=y CONFIG_SYS_NS16550_REG_SIZE=-4 CONFIG_USB=y CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y CONFIG_JFFS2_LZO=y CONFIG_JFFS2_NAND=y diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig index 94ef73f9c40f..77c9007d6ebc 100644 --- a/configs/net2big_v2_defconfig +++ b/configs/net2big_v2_defconfig @@ -18,6 +18,7 @@ CONFIG_IDENT_STRING=" 2Big v2" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 # CONFIG_SYS_MALLOC_F is not set +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" diff --git a/configs/netgear_dgnd3700v2_ram_defconfig b/configs/netgear_dgnd3700v2_ram_defconfig index 42d007bbe329..3174ceafe145 100644 --- a/configs/netgear_dgnd3700v2_ram_defconfig +++ b/configs/netgear_dgnd3700v2_ram_defconfig @@ -35,13 +35,10 @@ CONFIG_CMD_LICENSE=y # CONFIG_CMD_IMPORTENV is not set # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_SAVEENV is not set -# CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_CRC32 is not set CONFIG_CMD_MEMINFO=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_USB=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y # CONFIG_CMD_SLEEP is not set CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig index 02cf49c2e268..3ca2692cb159 100644 --- a/configs/netspace_lite_v2_defconfig +++ b/configs/netspace_lite_v2_defconfig @@ -18,6 +18,7 @@ CONFIG_IDENT_STRING=" NS v2 Lite" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 # CONFIG_SYS_MALLOC_F is not set +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig index 6683bc0682bf..76e6a6a96959 100644 --- a/configs/netspace_max_v2_defconfig +++ b/configs/netspace_max_v2_defconfig @@ -18,6 +18,7 @@ CONFIG_IDENT_STRING=" NS Max v2" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 # CONFIG_SYS_MALLOC_F is not set +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" diff --git a/configs/netspace_mini_v2_defconfig b/configs/netspace_mini_v2_defconfig index e810ccb2b218..7fd38ea48041 100644 --- a/configs/netspace_mini_v2_defconfig +++ b/configs/netspace_mini_v2_defconfig @@ -18,6 +18,7 @@ CONFIG_IDENT_STRING=" NS v2 Mini" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 # CONFIG_SYS_MALLOC_F is not set +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig index 6147152bf3a9..aacd874d9198 100644 --- a/configs/netspace_v2_defconfig +++ b/configs/netspace_v2_defconfig @@ -18,6 +18,7 @@ CONFIG_IDENT_STRING=" NS v2" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_ENV_ADDR=0x70000 # CONFIG_SYS_MALLOC_F is not set +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index 9d2bad415c2b..bf7223165d1c 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -21,9 +21,7 @@ CONFIG_CMD_HDMIDETECT=y CONFIG_AHCI=y CONFIG_SYS_MEMTEST_START=0x10000000 CONFIG_SYS_MEMTEST_END=0x10010000 -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 -CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run distro_bootcmd" CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y @@ -32,7 +30,6 @@ CONFIG_MISC_INIT_R=y CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 -CONFIG_CMD_BOOTZ=y CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y # CONFIG_CMD_FLASH is not set @@ -41,17 +38,10 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y @@ -80,7 +70,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MXC_SPI=y CONFIG_USB=y -CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y CONFIG_USB_GADGET=y diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index 3911aba172a6..6e91447709b5 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -21,9 +21,7 @@ CONFIG_CMD_HDMIDETECT=y CONFIG_AHCI=y CONFIG_SYS_MEMTEST_START=0x10000000 CONFIG_SYS_MEMTEST_END=0x10010000 -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 -CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run distro_bootcmd" CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y @@ -32,7 +30,6 @@ CONFIG_MISC_INIT_R=y CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 -CONFIG_CMD_BOOTZ=y CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y # CONFIG_CMD_FLASH is not set @@ -41,17 +38,10 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y @@ -80,7 +70,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MXC_SPI=y CONFIG_USB=y -CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y CONFIG_USB_GADGET=y diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index 9a88b343761d..91b556820888 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -21,9 +21,7 @@ CONFIG_CMD_HDMIDETECT=y CONFIG_AHCI=y CONFIG_SYS_MEMTEST_START=0x10000000 CONFIG_SYS_MEMTEST_END=0x10010000 -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 -CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run distro_bootcmd" CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y @@ -32,7 +30,6 @@ CONFIG_MISC_INIT_R=y CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 -CONFIG_CMD_BOOTZ=y CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y # CONFIG_CMD_FLASH is not set @@ -42,17 +39,10 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SATA=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y @@ -83,7 +73,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MXC_SPI=y CONFIG_USB=y -CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y CONFIG_USB_GADGET=y diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index d6c3cf072301..de6a7a79fd42 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -21,9 +21,7 @@ CONFIG_CMD_HDMIDETECT=y CONFIG_AHCI=y CONFIG_SYS_MEMTEST_START=0x10000000 CONFIG_SYS_MEMTEST_END=0x10010000 -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 -CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run distro_bootcmd" CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y @@ -32,7 +30,6 @@ CONFIG_MISC_INIT_R=y CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 -CONFIG_CMD_BOOTZ=y CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y # CONFIG_CMD_FLASH is not set @@ -42,17 +39,10 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SATA=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y @@ -83,7 +73,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MXC_SPI=y CONFIG_USB=y -CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y CONFIG_USB_GADGET=y diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index 821d4288b3a3..3ab53ff00124 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -21,9 +21,7 @@ CONFIG_CMD_HDMIDETECT=y CONFIG_AHCI=y CONFIG_SYS_MEMTEST_START=0x10000000 CONFIG_SYS_MEMTEST_END=0x10010000 -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 -CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run distro_bootcmd" CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y @@ -32,7 +30,6 @@ CONFIG_MISC_INIT_R=y CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 -CONFIG_CMD_BOOTZ=y CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y # CONFIG_CMD_FLASH is not set @@ -41,17 +38,10 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y @@ -80,7 +70,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MXC_SPI=y CONFIG_USB=y -CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y CONFIG_USB_GADGET=y diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index 2e4db468170e..a4673e9c1407 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -21,9 +21,7 @@ CONFIG_CMD_HDMIDETECT=y CONFIG_AHCI=y CONFIG_SYS_MEMTEST_START=0x10000000 CONFIG_SYS_MEMTEST_END=0x10010000 -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 -CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run distro_bootcmd" CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y @@ -32,7 +30,6 @@ CONFIG_MISC_INIT_R=y CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 -CONFIG_CMD_BOOTZ=y CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y # CONFIG_CMD_FLASH is not set @@ -41,17 +38,10 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y @@ -80,7 +70,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MXC_SPI=y CONFIG_USB=y -CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y CONFIG_USB_GADGET=y diff --git a/configs/nsim_hs38_defconfig b/configs/nsim_hs38_defconfig index 5cc61b054047..6e8c1d7b988f 100644 --- a/configs/nsim_hs38_defconfig +++ b/configs/nsim_hs38_defconfig @@ -23,7 +23,6 @@ CONFIG_SYS_PBSIZE=279 CONFIG_SYS_BOOTM_LEN=0x2000000 CONFIG_CMD_DM=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/o4-imx6ull-nano_defconfig b/configs/o4-imx6ull-nano_defconfig index a94828b1dd41..7068753e38e1 100644 --- a/configs/o4-imx6ull-nano_defconfig +++ b/configs/o4-imx6ull-nano_defconfig @@ -11,21 +11,14 @@ CONFIG_IMX_MODULE_FUSE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 -CONFIG_CMD_BOOTZ=y CONFIG_CMD_MEMINFO=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y -CONFIG_CMD_PART=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_FAT=y CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" diff --git a/configs/octeon_ebb7304_defconfig b/configs/octeon_ebb7304_defconfig index a642a64d5c18..889de3bf9771 100644 --- a/configs/octeon_ebb7304_defconfig +++ b/configs/octeon_ebb7304_defconfig @@ -25,20 +25,12 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_MTD=y -CONFIG_CMD_PART=y CONFIG_CMD_PCI=y CONFIG_CMD_USB=y CONFIG_CMD_WDT=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_RTC=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_AMIGA_PARTITION=y -CONFIG_EFI_PARTITION=y CONFIG_PARTITION_TYPE_GUID=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_TFTP_TSIZE=y @@ -87,7 +79,6 @@ CONFIG_SYSRESET_OCTEON=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_STORAGE=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y diff --git a/configs/octeon_nic23_defconfig b/configs/octeon_nic23_defconfig index f6b86299a307..5020cd6df48d 100644 --- a/configs/octeon_nic23_defconfig +++ b/configs/octeon_nic23_defconfig @@ -35,15 +35,8 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_MTD=y -CONFIG_CMD_PART=y CONFIG_CMD_PCI=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_PING=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_EFI_PARTITION=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_TFTP_TSIZE=y CONFIG_SATA=y diff --git a/configs/octeontx2_95xx_defconfig b/configs/octeontx2_95xx_defconfig index d21c728d59f3..44364916dfe8 100644 --- a/configs/octeontx2_95xx_defconfig +++ b/configs/octeontx2_95xx_defconfig @@ -23,7 +23,6 @@ CONFIG_SYS_MEMTEST_START=0x04000000 CONFIG_SYS_MEMTEST_END=0x040f0000 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 CONFIG_BOOT_RETRY=y @@ -52,30 +51,20 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_BKOPS_ENABLE=y -CONFIG_CMD_PART=y CONFIG_CMD_PCI=y CONFIG_CMD_SF_TEST=y CONFIG_CMD_WDT=y -CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TFTPSRV=y CONFIG_CMD_RARP=y CONFIG_SYS_DISABLE_AUTOLOAD=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CDP=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y CONFIG_CMD_LINK_LOCAL=y -CONFIG_CMD_PXE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_EFI_PARTITION=y CONFIG_PARTITION_TYPE_GUID=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y diff --git a/configs/octeontx2_96xx_defconfig b/configs/octeontx2_96xx_defconfig index 8704a87d2890..6071b32d3f4c 100644 --- a/configs/octeontx2_96xx_defconfig +++ b/configs/octeontx2_96xx_defconfig @@ -23,7 +23,6 @@ CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 CONFIG_BOOT_RETRY=y @@ -52,31 +51,21 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_BKOPS_ENABLE=y -CONFIG_CMD_PART=y CONFIG_CMD_PCI=y CONFIG_CMD_SF_TEST=y CONFIG_CMD_USB=y CONFIG_CMD_WDT=y -CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TFTPSRV=y CONFIG_CMD_RARP=y CONFIG_SYS_DISABLE_AUTOLOAD=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CDP=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y CONFIG_CMD_LINK_LOCAL=y -CONFIG_CMD_PXE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_EFI_PARTITION=y CONFIG_PARTITION_TYPE_GUID=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y @@ -131,7 +120,6 @@ CONFIG_OCTEON_SPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_PCI=y -CONFIG_USB_STORAGE=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y diff --git a/configs/octeontx_81xx_defconfig b/configs/octeontx_81xx_defconfig index 3f4168e35004..9799193f514b 100644 --- a/configs/octeontx_81xx_defconfig +++ b/configs/octeontx_81xx_defconfig @@ -24,7 +24,6 @@ CONFIG_SYS_MEMTEST_START=0x2800000 CONFIG_SYS_MEMTEST_END=0x28f0000 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 CONFIG_BOOT_RETRY=y @@ -52,30 +51,20 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_BKOPS_ENABLE=y -CONFIG_CMD_PART=y CONFIG_CMD_PCI=y CONFIG_CMD_SF_TEST=y CONFIG_CMD_USB=y CONFIG_CMD_WDT=y -CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TFTPSRV=y CONFIG_CMD_RARP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CDP=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y CONFIG_CMD_LINK_LOCAL=y -CONFIG_CMD_PXE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_EFI_PARTITION=y CONFIG_PARTITION_TYPE_GUID=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y @@ -131,7 +120,6 @@ CONFIG_DM_SPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_PCI=y -CONFIG_USB_STORAGE=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y diff --git a/configs/octeontx_83xx_defconfig b/configs/octeontx_83xx_defconfig index aa18794d9653..3bffd5e809cf 100644 --- a/configs/octeontx_83xx_defconfig +++ b/configs/octeontx_83xx_defconfig @@ -22,7 +22,6 @@ CONFIG_DEBUG_UART=y CONFIG_AHCI=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 CONFIG_BOOT_RETRY=y @@ -50,29 +49,19 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_BKOPS_ENABLE=y -CONFIG_CMD_PART=y CONFIG_CMD_PCI=y CONFIG_CMD_SF_TEST=y CONFIG_CMD_USB=y CONFIG_CMD_WDT=y -CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TFTPSRV=y CONFIG_CMD_RARP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CDP=y CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y CONFIG_CMD_LINK_LOCAL=y -CONFIG_CMD_PXE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_EFI_PARTITION=y CONFIG_PARTITION_TYPE_GUID=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y @@ -128,7 +117,6 @@ CONFIG_DM_SPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_PCI=y -CONFIG_USB_STORAGE=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y diff --git a/configs/omap35_logic_defconfig b/configs/omap35_logic_defconfig index 5225aae536b8..0f5c1392bd6e 100644 --- a/configs/omap35_logic_defconfig +++ b/configs/omap35_logic_defconfig @@ -18,6 +18,7 @@ CONFIG_SPL=y CONFIG_LTO=y CONFIG_SYS_MONITOR_LEN=262144 CONFIG_ANDROID_BOOT_IMAGE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run autoboot" CONFIG_USE_PREBOOT=y diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index afcbf019c819..2bae61b2013a 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -18,6 +18,7 @@ CONFIG_SPL=y CONFIG_LTO=y CONFIG_SYS_MONITOR_LEN=262144 CONFIG_ANDROID_BOOT_IMAGE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SYS_MONITOR_BASE=0x10000000 CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run autoboot" diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 9a6c375466c8..aa6feec5ccc6 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -18,6 +18,7 @@ CONFIG_SPL=y CONFIG_LTO=y CONFIG_SYS_MONITOR_LEN=262144 CONFIG_ANDROID_BOOT_IMAGE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run autoboot" CONFIG_USE_PREBOOT=y diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index 6f881ecaada1..cb6cf8b5d98b 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -18,6 +18,7 @@ CONFIG_SPL=y CONFIG_LTO=y CONFIG_SYS_MONITOR_LEN=262144 CONFIG_ANDROID_BOOT_IMAGE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SYS_MONITOR_BASE=0x10000000 CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run autoboot" diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index dec7a4bf3170..e79c244401b7 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -25,6 +25,7 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK=0x8001ff00 CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0xc0700000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DYNAMIC_SYS_CLK_FREQ=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/openpiton_riscv64_defconfig b/configs/openpiton_riscv64_defconfig index 62560729fe6b..cdad88760964 100644 --- a/configs/openpiton_riscv64_defconfig +++ b/configs/openpiton_riscv64_defconfig @@ -16,6 +16,7 @@ CONFIG_OF_BOARD_FIXUP=y # CONFIG_LOCALVERSION_AUTO is not set CONFIG_ENV_VARS_UBOOT_CONFIG=y # CONFIG_EXPERT is not set +# CONFIG_BOOTSTD_DEFAULTS is not set # CONFIG_LEGACY_IMAGE_FORMAT is not set # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/openpiton_riscv64_spl_defconfig b/configs/openpiton_riscv64_spl_defconfig index b7696d7cf307..69b28a35c2d2 100644 --- a/configs/openpiton_riscv64_spl_defconfig +++ b/configs/openpiton_riscv64_spl_defconfig @@ -21,6 +21,7 @@ CONFIG_RISCV_SMODE=y # CONFIG_LOCALVERSION_AUTO is not set CONFIG_ENV_VARS_UBOOT_CONFIG=y # CONFIG_EXPERT is not set +# CONFIG_BOOTSTD_DEFAULTS is not set # CONFIG_LEGACY_IMAGE_FORMAT is not set # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/openrd_base_defconfig b/configs/openrd_base_defconfig index eb2be2426cca..74af6855dff6 100644 --- a/configs/openrd_base_defconfig +++ b/configs/openrd_base_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set CONFIG_HAS_BOARD_SIZE_LIMIT=y CONFIG_BOARD_SIZE_LIMIT=524288 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="${x_bootcmd_kernel}; setenv bootargs ${x_bootargs} ${x_bootargs_root}; ${x_bootcmd_usb}; bootm 0x6400000;" diff --git a/configs/openrd_client_defconfig b/configs/openrd_client_defconfig index 6e35e8b18698..8ee82bc93555 100644 --- a/configs/openrd_client_defconfig +++ b/configs/openrd_client_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set CONFIG_HAS_BOARD_SIZE_LIMIT=y CONFIG_BOARD_SIZE_LIMIT=524288 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="${x_bootcmd_kernel}; setenv bootargs ${x_bootargs} ${x_bootargs_root}; ${x_bootcmd_usb}; bootm 0x6400000;" diff --git a/configs/openrd_ultimate_defconfig b/configs/openrd_ultimate_defconfig index 7ef47044cdd0..840bd40ecbb5 100644 --- a/configs/openrd_ultimate_defconfig +++ b/configs/openrd_ultimate_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_LOAD_ADDR=0x800000 # CONFIG_SYS_MALLOC_F is not set CONFIG_HAS_BOARD_SIZE_LIMIT=y CONFIG_BOARD_SIZE_LIMIT=524288 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="${x_bootcmd_kernel}; setenv bootargs ${x_bootargs} ${x_bootargs_root}; ${x_bootcmd_usb}; bootm 0x6400000;" diff --git a/configs/opos6uldev_defconfig b/configs/opos6uldev_defconfig index d926df67f5c1..0ebcef6d9f53 100644 --- a/configs/opos6uldev_defconfig +++ b/configs/opos6uldev_defconfig @@ -22,6 +22,7 @@ CONFIG_ENV_OFFSET_REDUND=0x180000 CONFIG_SPL_LIBDISK_SUPPORT=y # CONFIG_CMD_BMODE is not set CONFIG_SYS_MONITOR_LEN=409600 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=5 CONFIG_USE_BOOTARGS=y diff --git a/configs/origen_defconfig b/configs/origen_defconfig index 97a6843e1d41..3bb7286b7750 100644 --- a/configs/origen_defconfig +++ b/configs/origen_defconfig @@ -21,6 +21,7 @@ CONFIG_IDENT_STRING=" for ORIGEN" CONFIG_SYS_MEM_TOP_HIDE=0x100000 CONFIG_SYS_LOAD_ADDR=0x43e00000 CONFIG_SYS_MONITOR_LEN=262144 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="if mmc rescan; then echo SD/MMC found on device ${mmcdev};if run loadbootenv; then echo Loaded environment from ${bootenv};run importbootenv;fi;if test -n $uenvcmd; then echo Running uenvcmd ...;run uenvcmd;fi;if run loadbootscript; then run bootscript; fi; fi;load mmc ${mmcdev} ${loadaddr} uImage; bootm ${loadaddr} " CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/pcm052_defconfig b/configs/pcm052_defconfig index e0c7709c5a90..8c37d0428a17 100644 --- a/configs/pcm052_defconfig +++ b/configs/pcm052_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_MEMTEST_START=0x80010000 CONFIG_SYS_MEMTEST_END=0x87c00000 CONFIG_HAS_BOARD_SIZE_LIMIT=y CONFIG_BOARD_SIZE_LIMIT=520192 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run bootcmd_nand" diff --git a/configs/pcm058_defconfig b/configs/pcm058_defconfig index 85858e60415d..25428b228ab4 100644 --- a/configs/pcm058_defconfig +++ b/configs/pcm058_defconfig @@ -27,6 +27,7 @@ CONFIG_SPL_SPI=y CONFIG_CMD_HDMIDETECT=y CONFIG_SYS_MONITOR_LEN=409600 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 CONFIG_BOOTCOMMAND="run mmcboot;run nandboot" diff --git a/configs/phycore-am335x-r2-regor_defconfig b/configs/phycore-am335x-r2-regor_defconfig index d74078c7bed8..4d583f49a074 100644 --- a/configs/phycore-am335x-r2-regor_defconfig +++ b/configs/phycore-am335x-r2-regor_defconfig @@ -19,7 +19,6 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_PAYLOAD="u-boot.img" # CONFIG_FIT is not set CONFIG_OF_BOARD_SETUP=y -CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="am335x-regor-rdk.dtb" CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -34,7 +33,6 @@ CONFIG_SPL_NAND_BASE=y CONFIG_SPL_POWER=y CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=64 -CONFIG_CMD_BOOTZ=y CONFIG_CMD_SPL=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y @@ -42,18 +40,13 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_MTD=y CONFIG_CMD_NAND=y -CONFIG_CMD_PART=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y CONFIG_BOOTP_DNS2=y -CONFIG_CMD_PING=y -CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=nand.0:128k(NAND.SPL),1m(NAND.u-boot),-(NAND.UBI)" CONFIG_CMD_UBI=y -CONFIG_DOS_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y diff --git a/configs/phycore-am335x-r2-wega_defconfig b/configs/phycore-am335x-r2-wega_defconfig index 0f75d56c881c..609491f73779 100644 --- a/configs/phycore-am335x-r2-wega_defconfig +++ b/configs/phycore-am335x-r2-wega_defconfig @@ -19,7 +19,6 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_PAYLOAD="u-boot.img" # CONFIG_FIT is not set CONFIG_OF_BOARD_SETUP=y -CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="am335x-wega-rdk.dtb" CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -34,7 +33,6 @@ CONFIG_SPL_NAND_BASE=y CONFIG_SPL_POWER=y CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=64 -CONFIG_CMD_BOOTZ=y CONFIG_CMD_SPL=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y @@ -42,18 +40,13 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_MTD=y CONFIG_CMD_NAND=y -CONFIG_CMD_PART=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y CONFIG_BOOTP_DNS2=y -CONFIG_CMD_PING=y -CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=nand.0:128k(NAND.SPL),128k(NAND.SPL.backup1),128k(NAND.SPL.backup2),128k(NAND.SPL.backup3),512k(NAND.u-boot),512k(NAND.u-boot.backup1),256k(NAND.u-boot-env),-(NAND.UBI)" CONFIG_CMD_UBI=y -CONFIG_DOS_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y diff --git a/configs/phycore-imx8mm_defconfig b/configs/phycore-imx8mm_defconfig index 3b2eb0a6bbbc..dc3138809e7f 100644 --- a/configs/phycore-imx8mm_defconfig +++ b/configs/phycore-imx8mm_defconfig @@ -24,6 +24,7 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadimage; then run mmcboot; else run netboot; fi; fi;" diff --git a/configs/phycore-imx8mp_defconfig b/configs/phycore-imx8mp_defconfig index 846c8793cca3..4046f599562c 100644 --- a/configs/phycore-imx8mp_defconfig +++ b/configs/phycore-imx8mp_defconfig @@ -24,6 +24,7 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadimage; then run mmcboot; else run netboot; fi; fi;" diff --git a/configs/phycore_pcl063_ull_defconfig b/configs/phycore_pcl063_ull_defconfig index 756789a84d6c..33d4a826a2ce 100644 --- a/configs/phycore_pcl063_ull_defconfig +++ b/configs/phycore_pcl063_ull_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL=y CONFIG_SYS_MONITOR_LEN=409600 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 CONFIG_BOOTCOMMAND="run mmc_mmc_fit" diff --git a/configs/pico-imx6_defconfig b/configs/pico-imx6_defconfig index ed15d32d83d6..8b690e93eae7 100644 --- a/configs/pico-imx6_defconfig +++ b/configs/pico-imx6_defconfig @@ -23,6 +23,7 @@ CONFIG_SYS_MONITOR_LEN=409600 CONFIG_FIT=y CONFIG_SPL_FIT_PRINT=y CONFIG_SPL_LOAD_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run default_boot" CONFIG_DEFAULT_FDT_FILE="ask" diff --git a/configs/pico-imx7d_bl33_defconfig b/configs/pico-imx7d_bl33_defconfig index 112c1114ba3f..b6f9f75901d1 100644 --- a/configs/pico-imx7d_bl33_defconfig +++ b/configs/pico-imx7d_bl33_defconfig @@ -22,7 +22,6 @@ CONFIG_SYS_MONITOR_LEN=409600 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run distro_bootcmd" CONFIG_SPL_MAX_SIZE=0xe000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -35,7 +34,6 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 # CONFIG_CMD_BOOTD is not set -CONFIG_CMD_BOOTZ=y CONFIG_CMD_SPL=y CONFIG_CMD_SPL_WRITE_SIZE=0x20000 CONFIG_CMD_MEMTEST=y @@ -47,12 +45,8 @@ CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_USB_SDP=y CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_PXE=y CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/pico-imx8mq_defconfig b/configs/pico-imx8mq_defconfig index 5c7311c38c4a..6a2e7b97e2f6 100644 --- a/configs/pico-imx8mq_defconfig +++ b/configs/pico-imx8mq_defconfig @@ -27,6 +27,7 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else booti ${loadaddr} - ${fdt_addr}; fi" diff --git a/configs/pm9261_defconfig b/configs/pm9261_defconfig index 4221c63ceed8..100ac61c902d 100644 --- a/configs/pm9261_defconfig +++ b/configs/pm9261_defconfig @@ -14,6 +14,7 @@ CONFIG_DEFAULT_DEVICE_TREE="at91sam9261ek" CONFIG_SYS_PROMPT="pm9261> " CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_ENV_ADDR=0x10040000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/mtdblock4 rootfstype=jffs2 fbcon=rotate:3 " diff --git a/configs/pm9263_defconfig b/configs/pm9263_defconfig index f8ad2fc13295..38d0cb021c32 100644 --- a/configs/pm9263_defconfig +++ b/configs/pm9263_defconfig @@ -14,6 +14,7 @@ CONFIG_DEFAULT_DEVICE_TREE="at91sam9263ek" CONFIG_SYS_PROMPT="u-boot-pm9263> " CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_ENV_ADDR=0x10040000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/mtdblock4 rootfstype=jffs2 fbcon=rotate:3 " diff --git a/configs/pm9g45_defconfig b/configs/pm9g45_defconfig index 0afdd0abcf99..36a7edfc646c 100644 --- a/configs/pm9g45_defconfig +++ b/configs/pm9g45_defconfig @@ -17,6 +17,7 @@ CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_LOAD_ADDR=0x70000000 CONFIG_DEBUG_UART=y CONFIG_SYS_MONITOR_LEN=524288 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/pogo_e02_defconfig b/configs/pogo_e02_defconfig index 469752cd83c4..4e836021722b 100644 --- a/configs/pogo_e02_defconfig +++ b/configs/pogo_e02_defconfig @@ -17,6 +17,7 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-pogo_e02" CONFIG_SYS_PROMPT="PogoE02> " CONFIG_IDENT_STRING="\nPogo E02" CONFIG_SYS_LOAD_ADDR=0x800000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs $(bootargs_console); run bootcmd_usb; bootm 0x00800000 0x01100000" diff --git a/configs/poleg_evb_defconfig b/configs/poleg_evb_defconfig index b00fb48a5a78..c349d72a897d 100644 --- a/configs/poleg_evb_defconfig +++ b/configs/poleg_evb_defconfig @@ -18,6 +18,7 @@ CONFIG_DM_RESET=y CONFIG_TARGET_POLEG=y CONFIG_SYS_LOAD_ADDR=0x10000000 CONFIG_ENV_ADDR=0x80100000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run common_bootargs; run romboot" CONFIG_SYS_MAXARGS=32 diff --git a/configs/porter_defconfig b/configs/porter_defconfig index 1d7462159d43..1a3aea866cfd 100644 --- a/configs/porter_defconfig +++ b/configs/porter_defconfig @@ -45,7 +45,6 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=256 -CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_XIMG is not set CONFIG_CMD_GPIO=y @@ -55,15 +54,9 @@ CONFIG_CMD_PCI=y CONFIG_CMD_SDRAM=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=spi0.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k(u-boot-env2),768k(u-boot),-(user)" @@ -102,5 +95,4 @@ CONFIG_SH_QSPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_PCI=y -CONFIG_USB_STORAGE=y CONFIG_SYS_TIMER_COUNTS_DOWN=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index 88a6dbd7db06..a363452189e6 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -24,7 +24,6 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_SYS_LOAD_ADDR=0x81000000 -CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_BOOTDELAY=3 CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" @@ -62,14 +61,9 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y CONFIG_BOOTP_DNS2=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=omap2-nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:128k(spl),128k(spl.backup1),128k(spl.backup2),128k(spl.backup3),1920k(u-boot),128k(uboot.env),5120k(kernel_a),5120k(kernel_b),8192k(mtdoops),-(rootfs)" diff --git a/configs/qcs404evb_defconfig b/configs/qcs404evb_defconfig index 9e72f64f7849..b43d1c70d5eb 100644 --- a/configs/qcs404evb_defconfig +++ b/configs/qcs404evb_defconfig @@ -22,13 +22,8 @@ CONFIG_SYS_CBSIZE=512 CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y -CONFIG_CMD_PART=y CONFIG_CMD_USB=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y # CONFIG_NET is not set CONFIG_CLK=y CONFIG_MSM_GPIO=y @@ -51,5 +46,4 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y -CONFIG_USB_STORAGE=y CONFIG_LMB_MAX_REGIONS=64 diff --git a/configs/qemu-ppce500_defconfig b/configs/qemu-ppce500_defconfig index a19d555f7d59..c37b8761bc77 100644 --- a/configs/qemu-ppce500_defconfig +++ b/configs/qemu-ppce500_defconfig @@ -12,6 +12,7 @@ CONFIG_USE_UBOOTPATH=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_MONITOR_BASE=0x00F00000 CONFIG_BOOTDELAY=1 diff --git a/configs/qemu_arm64_defconfig b/configs/qemu_arm64_defconfig index d2c3372004b5..d6c2eaed3dba 100644 --- a/configs/qemu_arm64_defconfig +++ b/configs/qemu_arm64_defconfig @@ -20,7 +20,6 @@ CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_BEST_MATCH=y CONFIG_BOOTSTD_FULL=y -CONFIG_BOOTSTD_DEFAULTS=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/qemu_arm_defconfig b/configs/qemu_arm_defconfig index 698c1af17746..b3104f339b72 100644 --- a/configs/qemu_arm_defconfig +++ b/configs/qemu_arm_defconfig @@ -21,7 +21,6 @@ CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_BEST_MATCH=y CONFIG_BOOTSTD_FULL=y -CONFIG_BOOTSTD_DEFAULTS=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/r2dplus_defconfig b/configs/r2dplus_defconfig index 0653089ecae2..3425c0a6ce40 100644 --- a/configs/r2dplus_defconfig +++ b/configs/r2dplus_defconfig @@ -25,11 +25,7 @@ CONFIG_CMD_DM=y CONFIG_CMD_IDE=y CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_DOS_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y diff --git a/configs/r8a77980_condor_defconfig b/configs/r8a77980_condor_defconfig index 4c895cdd6627..f73959db6de5 100644 --- a/configs/r8a77980_condor_defconfig +++ b/configs/r8a77980_condor_defconfig @@ -18,6 +18,7 @@ CONFIG_LTO=y CONFIG_REMAKE_ELF=y CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTARGS=y CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/r8a77990_ebisu_defconfig b/configs/r8a77990_ebisu_defconfig index c13f25ee9a8e..64300c4a0d75 100644 --- a/configs/r8a77990_ebisu_defconfig +++ b/configs/r8a77990_ebisu_defconfig @@ -18,6 +18,7 @@ CONFIG_LTO=y CONFIG_REMAKE_ELF=y CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_SYS_MONITOR_BASE=0x00000000 CONFIG_USE_BOOTARGS=y diff --git a/configs/r8a77995_draak_defconfig b/configs/r8a77995_draak_defconfig index c76ddef0567e..9f54aef4af0d 100644 --- a/configs/r8a77995_draak_defconfig +++ b/configs/r8a77995_draak_defconfig @@ -18,6 +18,7 @@ CONFIG_LTO=y CONFIG_REMAKE_ELF=y CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_SYS_MONITOR_BASE=0x00000000 CONFIG_USE_BOOTARGS=y diff --git a/configs/r8a779a0_falcon_defconfig b/configs/r8a779a0_falcon_defconfig index 89ce53ece74c..f7455bffb12d 100644 --- a/configs/r8a779a0_falcon_defconfig +++ b/configs/r8a779a0_falcon_defconfig @@ -21,6 +21,7 @@ CONFIG_LTO=y CONFIG_REMAKE_ELF=y CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index 7e4580f2cc7a..1144fa7982c7 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -25,7 +25,6 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_SYS_LOAD_ADDR=0x81000000 -CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_BOOTDELAY=3 CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" @@ -63,13 +62,9 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y CONFIG_BOOTP_DNS2=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=omap2-nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:128k(spl),128k(spl.backup1),128k(spl.backup2),128k(spl.backup3),1920k(u-boot),512k(u-boot.env0),512k(u-boot.env1),300m(rootfs),512k(mtdoops),-(configuration)" diff --git a/configs/rcar3_ulcb_defconfig b/configs/rcar3_ulcb_defconfig index 30cbd771fde0..8c262889d79f 100644 --- a/configs/rcar3_ulcb_defconfig +++ b/configs/rcar3_ulcb_defconfig @@ -17,6 +17,7 @@ CONFIG_LTO=y CONFIG_REMAKE_ELF=y CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_SYS_MONITOR_BASE=0x00000000 CONFIG_USE_BOOTARGS=y diff --git a/configs/rut_defconfig b/configs/rut_defconfig index ba89b4d24cd8..371ab0092930 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -24,7 +24,6 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_SYS_LOAD_ADDR=0x81000000 -CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_BOOTDELAY=3 CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" @@ -63,14 +62,9 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y CONFIG_BOOTP_DNS2=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=omap2-nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:128k(spl),128k(spl.backup1),128k(spl.backup2),128k(spl.backup3),1920k(u-boot),128k(uboot.env),5120k(kernel_a),5120k(kernel_b),8192k(mtdoops),-(rootfs)" diff --git a/configs/rzg2_beacon_defconfig b/configs/rzg2_beacon_defconfig index ef1f86237b6d..46be3404db14 100644 --- a/configs/rzg2_beacon_defconfig +++ b/configs/rzg2_beacon_defconfig @@ -14,6 +14,7 @@ CONFIG_LTO=y CONFIG_REMAKE_ELF=y CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/s5p4418_nanopi2_defconfig b/configs/s5p4418_nanopi2_defconfig index 5356161ff0d2..ec11d2bc5a39 100644 --- a/configs/s5p4418_nanopi2_defconfig +++ b/configs/s5p4418_nanopi2_defconfig @@ -26,13 +26,11 @@ CONFIG_SYS_MEMTEST_START=0x71000000 CONFIG_SYS_MEMTEST_END=0xb0000000 CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=1 CONFIG_BOARD_LATE_INIT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PBSIZE=1050 -CONFIG_CMD_BOOTZ=y # CONFIG_BOOTM_NETBSD is not set # CONFIG_BOOTM_RTEMS is not set CONFIG_CMD_MEMTEST=y @@ -43,9 +41,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_BMP=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_MMC_ENV_DEV=2 diff --git a/configs/s5p_goni_defconfig b/configs/s5p_goni_defconfig index 24c996b34f0c..ece64f111aee 100644 --- a/configs/s5p_goni_defconfig +++ b/configs/s5p_goni_defconfig @@ -15,6 +15,7 @@ CONFIG_TARGET_S5P_GONI=y CONFIG_SYS_LOAD_ADDR=0x34000000 CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=262144 +# CONFIG_BOOTSTD_DEFAULTS is not set # CONFIG_AUTOBOOT is not set CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/mtdblock8 rootfstype=ext4 ${console} ${meminfo} ${mtdparts}" diff --git a/configs/s5pc210_universal_defconfig b/configs/s5pc210_universal_defconfig index 274a631a285a..cffa35ac09be 100644 --- a/configs/s5pc210_universal_defconfig +++ b/configs/s5pc210_universal_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_PROMPT="Universal # " CONFIG_SYS_MEM_TOP_HIDE=0x100000 CONFIG_SYS_LOAD_ADDR=0x44800000 CONFIG_SYS_MONITOR_LEN=262144 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="Please use defined boot" diff --git a/configs/sam9x60_curiosity_mmc1_defconfig b/configs/sam9x60_curiosity_mmc1_defconfig index 21b2cc2edda1..ddb025eba6de 100644 --- a/configs/sam9x60_curiosity_mmc1_defconfig +++ b/configs/sam9x60_curiosity_mmc1_defconfig @@ -20,6 +20,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sam9x60_curiosity_mmc_defconfig b/configs/sam9x60_curiosity_mmc_defconfig index 10937d67d73e..969d5edd8bc2 100644 --- a/configs/sam9x60_curiosity_mmc_defconfig +++ b/configs/sam9x60_curiosity_mmc_defconfig @@ -20,6 +20,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sam9x60ek_mmc_defconfig b/configs/sam9x60ek_mmc_defconfig index 2a1399748c85..5d86c0eebe10 100644 --- a/configs/sam9x60ek_mmc_defconfig +++ b/configs/sam9x60ek_mmc_defconfig @@ -21,6 +21,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sam9x60ek_nandflash_defconfig b/configs/sam9x60ek_nandflash_defconfig index c6c468665885..eb7015c27338 100644 --- a/configs/sam9x60ek_nandflash_defconfig +++ b/configs/sam9x60ek_nandflash_defconfig @@ -21,6 +21,7 @@ CONFIG_ENV_OFFSET_REDUND=0x100000 CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sam9x60ek_qspiflash_defconfig b/configs/sam9x60ek_qspiflash_defconfig index ef2e2db8b8a4..d654c1e7b8e4 100644 --- a/configs/sam9x60ek_qspiflash_defconfig +++ b/configs/sam9x60ek_qspiflash_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_QSPI_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d27_giantboard_defconfig b/configs/sama5d27_giantboard_defconfig index 84bd2f5aeed5..58c7de9e2cde 100644 --- a/configs/sama5d27_giantboard_defconfig +++ b/configs/sama5d27_giantboard_defconfig @@ -30,6 +30,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/sama5d27_som1_ek_mmc1_defconfig b/configs/sama5d27_som1_ek_mmc1_defconfig index fd88ce893479..d94bdcbbf659 100644 --- a/configs/sama5d27_som1_ek_mmc1_defconfig +++ b/configs/sama5d27_som1_ek_mmc1_defconfig @@ -30,6 +30,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d27_som1_ek_mmc_defconfig b/configs/sama5d27_som1_ek_mmc_defconfig index e6e5fef1747b..4824abce406a 100644 --- a/configs/sama5d27_som1_ek_mmc_defconfig +++ b/configs/sama5d27_som1_ek_mmc_defconfig @@ -31,6 +31,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d27_som1_ek_qspiflash_defconfig b/configs/sama5d27_som1_ek_qspiflash_defconfig index cc0f08c4cd37..b1d39a13790d 100644 --- a/configs/sama5d27_som1_ek_qspiflash_defconfig +++ b/configs/sama5d27_som1_ek_qspiflash_defconfig @@ -31,6 +31,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_QSPI_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d27_wlsom1_ek_mmc_defconfig b/configs/sama5d27_wlsom1_ek_mmc_defconfig index fde3ab81c0c7..fa86c7b54bc7 100644 --- a/configs/sama5d27_wlsom1_ek_mmc_defconfig +++ b/configs/sama5d27_wlsom1_ek_mmc_defconfig @@ -29,6 +29,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig index 8106018e042d..b2e6cfaf352e 100644 --- a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig +++ b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig @@ -29,6 +29,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_QSPI_BOOT=y CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=3 diff --git a/configs/sama5d2_icp_mmc_defconfig b/configs/sama5d2_icp_mmc_defconfig index 1a92501bcde7..ad51e218e9bc 100644 --- a/configs/sama5d2_icp_mmc_defconfig +++ b/configs/sama5d2_icp_mmc_defconfig @@ -29,6 +29,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d2_icp_qspiflash_defconfig b/configs/sama5d2_icp_qspiflash_defconfig index a884bc2a47df..662ceb9774b9 100644 --- a/configs/sama5d2_icp_qspiflash_defconfig +++ b/configs/sama5d2_icp_qspiflash_defconfig @@ -22,6 +22,7 @@ CONFIG_SYS_BOOT_GET_CMDLINE=y CONFIG_SYS_BOOT_GET_KBD=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_QSPI_BOOT=y CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 diff --git a/configs/sama5d2_ptc_ek_mmc_defconfig b/configs/sama5d2_ptc_ek_mmc_defconfig index 70f61025a17d..de5912db2923 100644 --- a/configs/sama5d2_ptc_ek_mmc_defconfig +++ b/configs/sama5d2_ptc_ek_mmc_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d2_ptc_ek_nandflash_defconfig b/configs/sama5d2_ptc_ek_nandflash_defconfig index e55b140a3684..5135d705a680 100644 --- a/configs/sama5d2_ptc_ek_nandflash_defconfig +++ b/configs/sama5d2_ptc_ek_nandflash_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d2_xplained_emmc_defconfig b/configs/sama5d2_xplained_emmc_defconfig index c1babc4bfacd..48a3a22cf5d7 100644 --- a/configs/sama5d2_xplained_emmc_defconfig +++ b/configs/sama5d2_xplained_emmc_defconfig @@ -30,6 +30,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d2_xplained_mmc_defconfig b/configs/sama5d2_xplained_mmc_defconfig index afc4604f16f9..8ecc456a576b 100644 --- a/configs/sama5d2_xplained_mmc_defconfig +++ b/configs/sama5d2_xplained_mmc_defconfig @@ -31,6 +31,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d2_xplained_qspiflash_defconfig b/configs/sama5d2_xplained_qspiflash_defconfig index cecee28cfbf8..115530914156 100644 --- a/configs/sama5d2_xplained_qspiflash_defconfig +++ b/configs/sama5d2_xplained_qspiflash_defconfig @@ -31,6 +31,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_QSPI_BOOT=y CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 diff --git a/configs/sama5d2_xplained_spiflash_defconfig b/configs/sama5d2_xplained_spiflash_defconfig index 9a15026564e8..b2b8bb591e66 100644 --- a/configs/sama5d2_xplained_spiflash_defconfig +++ b/configs/sama5d2_xplained_spiflash_defconfig @@ -33,6 +33,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d36ek_cmp_mmc_defconfig b/configs/sama5d36ek_cmp_mmc_defconfig index 066c6244477b..ab87fbf77f63 100644 --- a/configs/sama5d36ek_cmp_mmc_defconfig +++ b/configs/sama5d36ek_cmp_mmc_defconfig @@ -19,6 +19,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d36ek_cmp_nandflash_defconfig b/configs/sama5d36ek_cmp_nandflash_defconfig index 857e55d1ac65..6c4a22ccd1e3 100644 --- a/configs/sama5d36ek_cmp_nandflash_defconfig +++ b/configs/sama5d36ek_cmp_nandflash_defconfig @@ -19,6 +19,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d36ek_cmp_spiflash_defconfig b/configs/sama5d36ek_cmp_spiflash_defconfig index 4fbda883d239..4038a1a72295 100644 --- a/configs/sama5d36ek_cmp_spiflash_defconfig +++ b/configs/sama5d36ek_cmp_spiflash_defconfig @@ -21,6 +21,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d3_xplained_mmc_defconfig b/configs/sama5d3_xplained_mmc_defconfig index e73dc0da5865..5457ee608a0b 100644 --- a/configs/sama5d3_xplained_mmc_defconfig +++ b/configs/sama5d3_xplained_mmc_defconfig @@ -30,6 +30,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d3_xplained_nandflash_defconfig b/configs/sama5d3_xplained_nandflash_defconfig index 7939f3d5153c..0684b3078c47 100644 --- a/configs/sama5d3_xplained_nandflash_defconfig +++ b/configs/sama5d3_xplained_nandflash_defconfig @@ -27,6 +27,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index 5a0b551be211..90131c19ffd6 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -30,6 +30,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index cba36f7c78f0..d43a9b2bd7d3 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -27,6 +27,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index 1ed117971137..c5d2d06ca091 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -32,6 +32,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d4_xplained_mmc_defconfig b/configs/sama5d4_xplained_mmc_defconfig index fce8bed9eb74..b8710da2f9ae 100644 --- a/configs/sama5d4_xplained_mmc_defconfig +++ b/configs/sama5d4_xplained_mmc_defconfig @@ -31,6 +31,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d4_xplained_nandflash_defconfig b/configs/sama5d4_xplained_nandflash_defconfig index 0640e206c137..12fc444a6b1d 100644 --- a/configs/sama5d4_xplained_nandflash_defconfig +++ b/configs/sama5d4_xplained_nandflash_defconfig @@ -28,6 +28,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d4_xplained_spiflash_defconfig b/configs/sama5d4_xplained_spiflash_defconfig index 2d8628e59247..d71f07ffec97 100644 --- a/configs/sama5d4_xplained_spiflash_defconfig +++ b/configs/sama5d4_xplained_spiflash_defconfig @@ -33,6 +33,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index 4d3042bc5b43..168ed466b291 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -30,6 +30,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index 3d453c549213..16e52f0c7029 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -27,6 +27,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig index afa6ddfd8eee..6e373f953975 100644 --- a/configs/sama5d4ek_spiflash_defconfig +++ b/configs/sama5d4ek_spiflash_defconfig @@ -32,6 +32,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/sama7g5ek_mmc1_defconfig b/configs/sama7g5ek_mmc1_defconfig index 2f3ccb397f33..5633169e914f 100644 --- a/configs/sama7g5ek_mmc1_defconfig +++ b/configs/sama7g5ek_mmc1_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_MEMTEST_START=0x60000000 CONFIG_SYS_MEMTEST_END=0x70000000 CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SD_BOOT=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mmcblk1p2 rw rootwait" diff --git a/configs/sama7g5ek_mmc_defconfig b/configs/sama7g5ek_mmc_defconfig index c5cbd89d8f59..42ca69edb977 100644 --- a/configs/sama7g5ek_mmc_defconfig +++ b/configs/sama7g5ek_mmc_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_MEMTEST_START=0x60000000 CONFIG_SYS_MEMTEST_END=0x70000000 CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SD_BOOT=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mmcblk0p2 rw rootwait" diff --git a/configs/sfr_nb4-ser_ram_defconfig b/configs/sfr_nb4-ser_ram_defconfig index f2b708b9d6f8..743e625530a8 100644 --- a/configs/sfr_nb4-ser_ram_defconfig +++ b/configs/sfr_nb4-ser_ram_defconfig @@ -35,13 +35,10 @@ CONFIG_CMD_LICENSE=y # CONFIG_CMD_IMPORTENV is not set # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_SAVEENV is not set -# CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_CRC32 is not set CONFIG_CMD_MEMINFO=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_USB=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y # CONFIG_CMD_SLEEP is not set CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/sheevaplug_defconfig b/configs/sheevaplug_defconfig index 2e4901b840cb..8ecb35203333 100644 --- a/configs/sheevaplug_defconfig +++ b/configs/sheevaplug_defconfig @@ -18,6 +18,7 @@ CONFIG_IDENT_STRING="\nMarvell-Sheevaplug" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_HAS_BOARD_SIZE_LIMIT=y CONFIG_BOARD_SIZE_LIMIT=524288 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="${x_bootcmd_kernel}; setenv bootargs ${x_bootargs} ${x_bootargs_root}; bootm 0x6400000;" diff --git a/configs/silinux_ek874_defconfig b/configs/silinux_ek874_defconfig index f79848eda23b..f2957186b005 100644 --- a/configs/silinux_ek874_defconfig +++ b/configs/silinux_ek874_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_LOAD_ADDR=0x58000000 CONFIG_REMAKE_ELF=y CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" diff --git a/configs/silk_defconfig b/configs/silk_defconfig index a212098473a0..00a63dc58055 100644 --- a/configs/silk_defconfig +++ b/configs/silk_defconfig @@ -45,7 +45,6 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=256 -CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_XIMG is not set CONFIG_CMD_GPIO=y @@ -55,15 +54,9 @@ CONFIG_CMD_PCI=y CONFIG_CMD_SDRAM=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=spi0.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k(u-boot-env2),768k(u-boot),-(user)" @@ -104,5 +97,4 @@ CONFIG_SH_QSPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_PCI=y -CONFIG_USB_STORAGE=y CONFIG_SYS_TIMER_COUNTS_DOWN=y diff --git a/configs/sipeed_maix_bitm_defconfig b/configs/sipeed_maix_bitm_defconfig index 289d9fd4f473..51c78f482465 100644 --- a/configs/sipeed_maix_bitm_defconfig +++ b/configs/sipeed_maix_bitm_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_LOAD_ADDR=0x80000000 CONFIG_TARGET_SIPEED_MAIX=y CONFIG_ARCH_RV64I=y CONFIG_STACK_SIZE=0x100000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run k210_bootcmd" CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/sipeed_maix_smode_defconfig b/configs/sipeed_maix_smode_defconfig index a656f599e00d..fba5ebc02694 100644 --- a/configs/sipeed_maix_smode_defconfig +++ b/configs/sipeed_maix_smode_defconfig @@ -11,6 +11,7 @@ CONFIG_TARGET_SIPEED_MAIX=y CONFIG_ARCH_RV64I=y CONFIG_RISCV_SMODE=y CONFIG_STACK_SIZE=0x100000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run k210_bootcmd" CONFIG_HUSH_PARSER=y diff --git a/configs/slimbootloader_defconfig b/configs/slimbootloader_defconfig index dbfed814ded0..fcb02c6a3542 100644 --- a/configs/slimbootloader_defconfig +++ b/configs/slimbootloader_defconfig @@ -4,6 +4,7 @@ CONFIG_DEFAULT_DEVICE_TREE="slimbootloader" CONFIG_VENDOR_INTEL=y CONFIG_TARGET_SLIMBOOTLOADER=y # CONFIG_USE_CAR is not set +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_BOOTDELAY=10 diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index 4cbdab0b37d8..eae8bba87da7 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -25,6 +25,7 @@ CONFIG_SPL=y CONFIG_ENV_OFFSET_REDUND=0x180000 CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/smdkv310_defconfig b/configs/smdkv310_defconfig index c1b5f8475538..4db637b63005 100644 --- a/configs/smdkv310_defconfig +++ b/configs/smdkv310_defconfig @@ -18,6 +18,7 @@ CONFIG_SPL=y CONFIG_IDENT_STRING=" for SMDKC210/V310" CONFIG_SYS_LOAD_ADDR=0x43e00000 CONFIG_SYS_MONITOR_LEN=262144 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="fatload mmc 0 40007000 uImage; bootm 40007000" # CONFIG_SPL_FRAMEWORK is not set diff --git a/configs/smegw01_defconfig b/configs/smegw01_defconfig index 1e0b9aa5be11..69892ba1cac3 100644 --- a/configs/smegw01_defconfig +++ b/configs/smegw01_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0xa0000000 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="if run loadimage; then run mmcboot; fi; " CONFIG_HUSH_PARSER=y diff --git a/configs/socfpga_agilex_atf_defconfig b/configs/socfpga_agilex_atf_defconfig index 07851575444e..8cf5fc9d10d9 100644 --- a/configs/socfpga_agilex_atf_defconfig +++ b/configs/socfpga_agilex_atf_defconfig @@ -25,6 +25,7 @@ CONFIG_FIT=y CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x02000000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=5 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon" diff --git a/configs/socfpga_agilex_defconfig b/configs/socfpga_agilex_defconfig index 406fe712fe46..41f651800487 100644 --- a/configs/socfpga_agilex_defconfig +++ b/configs/socfpga_agilex_defconfig @@ -23,6 +23,7 @@ CONFIG_SYS_LOAD_ADDR=0x02000000 CONFIG_SYS_MEMTEST_START=0x00000000 CONFIG_SYS_MEMTEST_END=0x3fe00000 CONFIG_REMAKE_ELF=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=5 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon" diff --git a/configs/socfpga_agilex_vab_defconfig b/configs/socfpga_agilex_vab_defconfig index 037597f95ce6..12d9ff07ecc5 100644 --- a/configs/socfpga_agilex_vab_defconfig +++ b/configs/socfpga_agilex_vab_defconfig @@ -26,6 +26,7 @@ CONFIG_FIT=y CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x02000000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=5 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon" diff --git a/configs/socfpga_dbm_soc1_defconfig b/configs/socfpga_dbm_soc1_defconfig index de087fabf688..910a3bc7411f 100644 --- a/configs/socfpga_dbm_soc1_defconfig +++ b/configs/socfpga_dbm_soc1_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL_STACK=0x0 CONFIG_TARGET_SOCFPGA_DEVBOARDS_DBM_SOC1=y CONFIG_FIT=y CONFIG_TIMESTAMP=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/socfpga_mcvevk_defconfig b/configs/socfpga_mcvevk_defconfig index f49604becc59..2d8bcf181948 100644 --- a/configs/socfpga_mcvevk_defconfig +++ b/configs/socfpga_mcvevk_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL_STACK=0x0 CONFIG_TARGET_SOCFPGA_ARIES_MCVEVK=y CONFIG_FIT=y CONFIG_TIMESTAMP=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" diff --git a/configs/socfpga_n5x_atf_defconfig b/configs/socfpga_n5x_atf_defconfig index f308239b3fca..9f245e8802eb 100644 --- a/configs/socfpga_n5x_atf_defconfig +++ b/configs/socfpga_n5x_atf_defconfig @@ -24,6 +24,7 @@ CONFIG_FIT=y CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x02000000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=5 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon panic=-1 earlyprintk=ttyS0,115200" diff --git a/configs/socfpga_n5x_defconfig b/configs/socfpga_n5x_defconfig index 99a12df91ac8..0b4cc3fb992e 100644 --- a/configs/socfpga_n5x_defconfig +++ b/configs/socfpga_n5x_defconfig @@ -20,6 +20,7 @@ CONFIG_IDENT_STRING="socfpga_n5x" CONFIG_SPL_FS_FAT=y # CONFIG_PSCI_RESET is not set CONFIG_REMAKE_ELF=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=5 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon panic=-1 earlyprintk=ttyS0,115200" diff --git a/configs/socfpga_n5x_vab_defconfig b/configs/socfpga_n5x_vab_defconfig index e82f6cd8aeae..48e86b112e8d 100644 --- a/configs/socfpga_n5x_vab_defconfig +++ b/configs/socfpga_n5x_vab_defconfig @@ -25,6 +25,7 @@ CONFIG_FIT=y CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x02000000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=5 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon panic=-1 earlyprintk=ttyS0,115200" diff --git a/configs/socfpga_secu1_defconfig b/configs/socfpga_secu1_defconfig index 3dc98a259176..c8bbd9d5f689 100644 --- a/configs/socfpga_secu1_defconfig +++ b/configs/socfpga_secu1_defconfig @@ -21,6 +21,7 @@ CONFIG_ENV_OFFSET_REDUND=0x120000 CONFIG_SYS_LOAD_ADDR=0x02000000 CONFIG_BUILD_TARGET="u-boot-with-nand-spl.sfp" CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOT_RETRY=y CONFIG_BOOT_RETRY_TIME=45 diff --git a/configs/socfpga_stratix10_atf_defconfig b/configs/socfpga_stratix10_atf_defconfig index e3e8a6345bfd..8d25b4e37f3b 100644 --- a/configs/socfpga_stratix10_atf_defconfig +++ b/configs/socfpga_stratix10_atf_defconfig @@ -25,6 +25,7 @@ CONFIG_FIT=y CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x02000000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=5 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon" diff --git a/configs/socfpga_stratix10_defconfig b/configs/socfpga_stratix10_defconfig index 7d078dd18e0f..60188957f73b 100644 --- a/configs/socfpga_stratix10_defconfig +++ b/configs/socfpga_stratix10_defconfig @@ -25,6 +25,7 @@ CONFIG_SYS_MEMTEST_END=0x3fe00000 CONFIG_OPTIMIZE_INLINING=y CONFIG_SPL_OPTIMIZE_INLINING=y CONFIG_REMAKE_ELF=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=5 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon" diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index 62caec7597ec..65408eefc08f 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -17,6 +17,7 @@ CONFIG_TARGET_SOCFPGA_SOFTING_VINING_FPGA=y CONFIG_ENV_OFFSET_REDUND=0x110000 CONFIG_FIT=y CONFIG_TIMESTAMP=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=5 CONFIG_USE_BOOTARGS=y diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index 24655131a8af..9ad1b974b3e1 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_MONITOR_LEN=786432 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=1 diff --git a/configs/som-db5800-som-6867_defconfig b/configs/som-db5800-som-6867_defconfig index 73813500fa11..1d511f60e035 100644 --- a/configs/som-db5800-som-6867_defconfig +++ b/configs/som-db5800-som-6867_defconfig @@ -18,6 +18,7 @@ CONFIG_SEABIOS=y CONFIG_SYS_MONITOR_LEN=2097152 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SHOW_BOOT_PROGRESS=y diff --git a/configs/somlabs_visionsom_6ull_defconfig b/configs/somlabs_visionsom_6ull_defconfig index 0968e6dd86d9..34ec9c5fa590 100644 --- a/configs/somlabs_visionsom_6ull_defconfig +++ b/configs/somlabs_visionsom_6ull_defconfig @@ -11,6 +11,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6ull-somlabs-visionsom" CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x88000000 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run setfdtfile; run checkbootdev; run loadfdt;if run loadbootscript; then run bootscript; else if run loadimage; then run setbootargs; bootz ${loadaddr} - ${fdt_addr}; fi; fi" diff --git a/configs/stemmy_defconfig b/configs/stemmy_defconfig index 9b78ab36cfc5..00254abc302f 100644 --- a/configs/stemmy_defconfig +++ b/configs/stemmy_defconfig @@ -13,6 +13,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x100000 CONFIG_DEFAULT_DEVICE_TREE="ste-ux500-samsung-stemmy" CONFIG_SYS_LOAD_ADDR=0x100000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_OF_BOARD_SETUP=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run fastbootcmd" diff --git a/configs/stm32h750-art-pi_defconfig b/configs/stm32h750-art-pi_defconfig index 3e4c7f9a8cd1..3970dfe6d8ae 100644 --- a/configs/stm32h750-art-pi_defconfig +++ b/configs/stm32h750-art-pi_defconfig @@ -13,6 +13,7 @@ CONFIG_STM32H7=y CONFIG_TARGET_STM32H750_ART_PI=y CONFIG_SYS_LOAD_ADDR=0xc1800000 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/stm32mp13_defconfig b/configs/stm32mp13_defconfig index b076573c450f..39561a12c125 100644 --- a/configs/stm32mp13_defconfig +++ b/configs/stm32mp13_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_LOAD_ADDR=0xc2000000 CONFIG_SYS_MEMTEST_START=0xc0000000 CONFIG_SYS_MEMTEST_END=0xc4000000 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=1 CONFIG_BOOTCOMMAND="run bootcmd_stm32mp" diff --git a/configs/stm32mp15-icore-stm32mp1-ctouch2_defconfig b/configs/stm32mp15-icore-stm32mp1-ctouch2_defconfig index e01745498c09..7b7c6393274b 100644 --- a/configs/stm32mp15-icore-stm32mp1-ctouch2_defconfig +++ b/configs/stm32mp15-icore-stm32mp1-ctouch2_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_LOAD_ADDR=0xc2000000 CONFIG_SYS_MEMTEST_START=0xc0000000 CONFIG_SYS_MEMTEST_END=0xc4000000 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run bootcmd_stm32mp" CONFIG_SPL_FOOTPRINT_LIMIT=y diff --git a/configs/stm32mp15-icore-stm32mp1-edimm2.2_defconfig b/configs/stm32mp15-icore-stm32mp1-edimm2.2_defconfig index e72684683e71..1b36e7598eac 100644 --- a/configs/stm32mp15-icore-stm32mp1-edimm2.2_defconfig +++ b/configs/stm32mp15-icore-stm32mp1-edimm2.2_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_LOAD_ADDR=0xc2000000 CONFIG_SYS_MEMTEST_START=0xc0000000 CONFIG_SYS_MEMTEST_END=0xc4000000 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run bootcmd_stm32mp" CONFIG_SPL_FOOTPRINT_LIMIT=y diff --git a/configs/stm32mp15-microgea-stm32mp1-microdev2-of7_defconfig b/configs/stm32mp15-microgea-stm32mp1-microdev2-of7_defconfig index b910d474ca7e..77b5f4415973 100644 --- a/configs/stm32mp15-microgea-stm32mp1-microdev2-of7_defconfig +++ b/configs/stm32mp15-microgea-stm32mp1-microdev2-of7_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_LOAD_ADDR=0xc2000000 CONFIG_SYS_MEMTEST_START=0xc0000000 CONFIG_SYS_MEMTEST_END=0xc4000000 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run bootcmd_stm32mp" CONFIG_SPL_FOOTPRINT_LIMIT=y diff --git a/configs/stm32mp15-microgea-stm32mp1-microdev2_defconfig b/configs/stm32mp15-microgea-stm32mp1-microdev2_defconfig index 5007e6246d4a..bd1da0004fab 100644 --- a/configs/stm32mp15-microgea-stm32mp1-microdev2_defconfig +++ b/configs/stm32mp15-microgea-stm32mp1-microdev2_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_LOAD_ADDR=0xc2000000 CONFIG_SYS_MEMTEST_START=0xc0000000 CONFIG_SYS_MEMTEST_END=0xc4000000 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run bootcmd_stm32mp" CONFIG_SPL_FOOTPRINT_LIMIT=y diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index faf5f0993b0f..88c945d9ffec 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -24,6 +24,7 @@ CONFIG_SYS_LOAD_ADDR=0xc2000000 CONFIG_SYS_MEMTEST_START=0xc0000000 CONFIG_SYS_MEMTEST_END=0xc4000000 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=1 CONFIG_BOOTCOMMAND="run bootcmd_stm32mp" diff --git a/configs/stm32mp15_defconfig b/configs/stm32mp15_defconfig index 0005e4266441..6ce432a00f13 100644 --- a/configs/stm32mp15_defconfig +++ b/configs/stm32mp15_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_LOAD_ADDR=0xc2000000 CONFIG_SYS_MEMTEST_START=0xc0000000 CONFIG_SYS_MEMTEST_END=0xc4000000 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=1 CONFIG_BOOTCOMMAND="run bootcmd_stm32mp" diff --git a/configs/stm32mp15_dhcom_basic_defconfig b/configs/stm32mp15_dhcom_basic_defconfig index 93494f83a87b..fb860b50cd68 100644 --- a/configs/stm32mp15_dhcom_basic_defconfig +++ b/configs/stm32mp15_dhcom_basic_defconfig @@ -30,6 +30,7 @@ CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0xc1000000 CONFIG_SPL_FIT_SOURCE="board/dhelectronics/dh_stm32mp1/u-boot-dhcom.its" +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=1 CONFIG_BOOTCOMMAND="run bootcmd_stm32mp" diff --git a/configs/stm32mp15_dhcor_basic_defconfig b/configs/stm32mp15_dhcor_basic_defconfig index b54ff9301461..b8e97f600a2a 100644 --- a/configs/stm32mp15_dhcor_basic_defconfig +++ b/configs/stm32mp15_dhcor_basic_defconfig @@ -28,6 +28,7 @@ CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0xc1000000 CONFIG_SPL_FIT_SOURCE="board/dhelectronics/dh_stm32mp1/u-boot-dhcor.its" +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=1 CONFIG_BOOTCOMMAND="run bootcmd_stm32mp" diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index 06fa43b20f81..940fe00f23fe 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_LOAD_ADDR=0xc2000000 CONFIG_SYS_MEMTEST_START=0xc0000000 CONFIG_SYS_MEMTEST_END=0xc4000000 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=1 CONFIG_BOOTCOMMAND="run bootcmd_stm32mp" diff --git a/configs/stout_defconfig b/configs/stout_defconfig index fb7ec0a7e434..3dd4288fd28f 100644 --- a/configs/stout_defconfig +++ b/configs/stout_defconfig @@ -45,7 +45,6 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=256 -CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_XIMG is not set CONFIG_CMD_GPIO=y @@ -55,15 +54,9 @@ CONFIG_CMD_PCI=y CONFIG_CMD_SDRAM=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=spi0.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=spi0.0:256k(u-boot-spl),512k(u-boot-env1),512k(u-boot-env2),768k(u-boot),-(user)" @@ -103,5 +96,4 @@ CONFIG_SH_QSPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_PCI=y -CONFIG_USB_STORAGE=y CONFIG_SYS_TIMER_COUNTS_DOWN=y diff --git a/configs/synquacer_developerbox_defconfig b/configs/synquacer_developerbox_defconfig index 68f7bacf02a9..1c188fa7c944 100644 --- a/configs/synquacer_developerbox_defconfig +++ b/configs/synquacer_developerbox_defconfig @@ -28,22 +28,15 @@ CONFIG_CMD_DM=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_MTD=y -CONFIG_CMD_PART=y CONFIG_CMD_PCI=y CONFIG_CMD_POWEROFF=y CONFIG_CMD_SATA=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_EFIDEBUG=y CONFIG_CMD_RTC=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_MTDPARTS=y CONFIG_CMD_LOG=y -CONFIG_ISO_PARTITION=y CONFIG_PARTITION_TYPE_GUID=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y @@ -90,8 +83,6 @@ CONFIG_SYNQUACER_SPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_PCI=y -CONFIG_USB_STORAGE=y -CONFIG_FS_EXT4=y CONFIG_EFI_SET_TIME=y CONFIG_EFI_RUNTIME_UPDATE_CAPSULE=y CONFIG_EFI_CAPSULE_ON_DISK=y diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 2a85c0d19026..c77ea219f6ae 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -33,6 +33,7 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_DEBUG_UART=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig b/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig index 00fa3544bd10..95a2cec69cab 100644 --- a/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig +++ b/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig @@ -33,24 +33,15 @@ CONFIG_CMD_CPU=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y -CONFIG_CMD_PART=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y # CONFIG_CMD_NFS is not set -CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_ISO_PARTITION=y CONFIG_AMIGA_PARTITION=y -CONFIG_EFI_PARTITION=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y @@ -69,7 +60,6 @@ CONFIG_WINBOND_W83627=y CONFIG_E1000=y CONFIG_SYS_NS16550_PORT_MAPPED=y CONFIG_SPI=y -CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_RTL8152=y diff --git a/configs/theadorable-x86-conga-qa3-e3845_defconfig b/configs/theadorable-x86-conga-qa3-e3845_defconfig index 7cf8c551451e..fb24645cecc1 100644 --- a/configs/theadorable-x86-conga-qa3-e3845_defconfig +++ b/configs/theadorable-x86-conga-qa3-e3845_defconfig @@ -32,24 +32,15 @@ CONFIG_CMD_CPU=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y -CONFIG_CMD_PART=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y # CONFIG_CMD_NFS is not set -CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_MAC_PARTITION=y -CONFIG_ISO_PARTITION=y -CONFIG_EFI_PARTITION=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y @@ -68,7 +59,6 @@ CONFIG_WINBOND_W83627=y CONFIG_E1000=y CONFIG_SYS_NS16550_PORT_MAPPED=y CONFIG_SPI=y -CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_RTL8152=y diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index 82c348884559..a4accee47862 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -30,24 +30,15 @@ CONFIG_SYS_PBSIZE=532 CONFIG_CMD_CPU=y CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y -CONFIG_CMD_PART=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y CONFIG_BOOTP_BOOTFILESIZE=y # CONFIG_CMD_NFS is not set -CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_MAC_PARTITION=y -CONFIG_ISO_PARTITION=y -CONFIG_EFI_PARTITION=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y @@ -64,7 +55,6 @@ CONFIG_DM_I2C=y CONFIG_NUVOTON_NCT6102D=y CONFIG_E1000=y CONFIG_SPI=y -CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_RTL8152=y diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index a59cf73e2da2..15a12e49640f 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -40,24 +40,15 @@ CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_I2C=y CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=32 -CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_PCI=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_EFI_PARTITION=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_SPI_MAX_HZ=50000000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y @@ -91,7 +82,6 @@ CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y CONFIG_VIDEO=y # CONFIG_VIDEO_BPP8 is not set # CONFIG_VIDEO_BPP32 is not set diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index 6302c1a4151a..02cc8a23347e 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -25,7 +25,6 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_SYS_LOAD_ADDR=0x81000000 -CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_BOOTDELAY=3 CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" @@ -63,13 +62,9 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y CONFIG_BOOTP_DNS2=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=omap2-nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:128k(spl),128k(spl.backup1),128k(spl.backup2),128k(spl.backup3),1920k(u-boot),512k(u-boot.env0),512k(u-boot.env1),512k(mtdoops),-(rootfs)" diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index a4bc99329796..0f7c6fd1918c 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -21,6 +21,7 @@ CONFIG_ENV_OFFSET_REDUND=0x1E0000 CONFIG_SYS_CLK_FREQ=27000000 CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/tools-only_defconfig b/configs/tools-only_defconfig index 23e1f0e9dba0..910986a1b55c 100644 --- a/configs/tools-only_defconfig +++ b/configs/tools-only_defconfig @@ -10,8 +10,8 @@ CONFIG_TIMESTAMP=y CONFIG_FIT_SIGNATURE=y # CONFIG_BOOTSTD_FULL is not set # CONFIG_BOOTMETH_VBE is not set -CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run distro_bootcmd" +# CONFIG_AVB_VERIFY is not set # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_BOOTM is not set # CONFIG_CMD_ELF is not set diff --git a/configs/topic_miami_defconfig b/configs/topic_miami_defconfig index ef1b66e9069a..6e6fa2108552 100644 --- a/configs/topic_miami_defconfig +++ b/configs/topic_miami_defconfig @@ -22,6 +22,7 @@ CONFIG_SYS_MEMTEST_END=0x18000000 CONFIG_REMAKE_ELF=y CONFIG_SYS_CUSTOM_LDSCRIPT=y CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=0 CONFIG_BOOTCOMMAND="if mmcinfo; then if fatload mmc 0 0x1900000 ${bootscript}; then source 0x1900000; fi; fi; run $modeboot" diff --git a/configs/topic_miamilite_defconfig b/configs/topic_miamilite_defconfig index af829ac15b82..1d9c637d722b 100644 --- a/configs/topic_miamilite_defconfig +++ b/configs/topic_miamilite_defconfig @@ -22,6 +22,7 @@ CONFIG_SYS_MEMTEST_END=0x18000000 CONFIG_REMAKE_ELF=y CONFIG_SYS_CUSTOM_LDSCRIPT=y CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=0 CONFIG_BOOTCOMMAND="if mmcinfo; then if fatload mmc 0 0x1900000 ${bootscript}; then source 0x1900000; fi; fi; run $modeboot" diff --git a/configs/topic_miamiplus_defconfig b/configs/topic_miamiplus_defconfig index 9287b1d79aa4..b4e219d2c8ec 100644 --- a/configs/topic_miamiplus_defconfig +++ b/configs/topic_miamiplus_defconfig @@ -22,6 +22,7 @@ CONFIG_SYS_MEMTEST_END=0x18000000 CONFIG_REMAKE_ELF=y CONFIG_SYS_CUSTOM_LDSCRIPT=y CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=0 CONFIG_BOOTCOMMAND="if mmcinfo; then if fatload mmc 0 0x1900000 ${bootscript}; then source 0x1900000; fi; fi; run $modeboot" diff --git a/configs/total_compute_defconfig b/configs/total_compute_defconfig index d25ed38c7642..87ac2060c19a 100644 --- a/configs/total_compute_defconfig +++ b/configs/total_compute_defconfig @@ -16,6 +16,7 @@ CONFIG_REMAKE_ELF=y CONFIG_ANDROID_BOOT_IMAGE=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=5 diff --git a/configs/tplink_wdr4300_defconfig b/configs/tplink_wdr4300_defconfig index 41e7076b7777..eeb7aa2d16a1 100644 --- a/configs/tplink_wdr4300_defconfig +++ b/configs/tplink_wdr4300_defconfig @@ -11,6 +11,7 @@ CONFIG_BOARD_TPLINK_WDR4300=y CONFIG_SYS_MIPS_TIMER_FREQ=280000000 CONFIG_SYS_MEMTEST_START=0x80100000 CONFIG_SYS_MEMTEST_END=0x83f00000 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock2 rootfstype=squashfs" diff --git a/configs/tqma6dl_mba6_mmc_defconfig b/configs/tqma6dl_mba6_mmc_defconfig index f5ae20c5f8d6..c32dbefd5fb2 100644 --- a/configs/tqma6dl_mba6_mmc_defconfig +++ b/configs/tqma6dl_mba6_mmc_defconfig @@ -10,6 +10,7 @@ CONFIG_TARGET_TQMA6=y CONFIG_DEFAULT_DEVICE_TREE="imx6dl-mba6b" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 diff --git a/configs/tqma6dl_mba6_spi_defconfig b/configs/tqma6dl_mba6_spi_defconfig index 6e8361fd1a1a..7bb9b3003804 100644 --- a/configs/tqma6dl_mba6_spi_defconfig +++ b/configs/tqma6dl_mba6_spi_defconfig @@ -13,6 +13,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6dl-mba6b" CONFIG_ENV_OFFSET_REDUND=0x90000 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 diff --git a/configs/tqma6q_mba6_mmc_defconfig b/configs/tqma6q_mba6_mmc_defconfig index 2cd2a34951bb..3513befef830 100644 --- a/configs/tqma6q_mba6_mmc_defconfig +++ b/configs/tqma6q_mba6_mmc_defconfig @@ -10,6 +10,7 @@ CONFIG_TARGET_TQMA6=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-mba6b" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 diff --git a/configs/tqma6q_mba6_spi_defconfig b/configs/tqma6q_mba6_spi_defconfig index 9588ec62cd81..6248de62c649 100644 --- a/configs/tqma6q_mba6_spi_defconfig +++ b/configs/tqma6q_mba6_spi_defconfig @@ -13,6 +13,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6q-mba6b" CONFIG_ENV_OFFSET_REDUND=0x90000 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 diff --git a/configs/tqma6s_mba6_mmc_defconfig b/configs/tqma6s_mba6_mmc_defconfig index cc0c666f1394..ea48837ad2e7 100644 --- a/configs/tqma6s_mba6_mmc_defconfig +++ b/configs/tqma6s_mba6_mmc_defconfig @@ -10,6 +10,7 @@ CONFIG_TARGET_TQMA6=y CONFIG_DEFAULT_DEVICE_TREE="imx6dl-mba6b" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 diff --git a/configs/tqma6s_mba6_spi_defconfig b/configs/tqma6s_mba6_spi_defconfig index db2e83713e4e..c733d90c04ae 100644 --- a/configs/tqma6s_mba6_spi_defconfig +++ b/configs/tqma6s_mba6_spi_defconfig @@ -13,6 +13,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6dl-mba6b" CONFIG_ENV_OFFSET_REDUND=0x90000 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 diff --git a/configs/trats2_defconfig b/configs/trats2_defconfig index 5b2f1fb5a354..6ea81b7c589e 100644 --- a/configs/trats2_defconfig +++ b/configs/trats2_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_LOAD_ADDR=0x43e00000 CONFIG_SYS_MONITOR_LEN=262144 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="Please use defined boot" diff --git a/configs/trats_defconfig b/configs/trats_defconfig index 35a36159e256..32583986f7a6 100644 --- a/configs/trats_defconfig +++ b/configs/trats_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_LOAD_ADDR=0x44800000 CONFIG_SYS_MONITOR_LEN=262144 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="Please use defined boot" diff --git a/configs/uniphier_ld4_sld8_defconfig b/configs/uniphier_ld4_sld8_defconfig index f77b14fcb0e4..fdd72f40d1ed 100644 --- a/configs/uniphier_ld4_sld8_defconfig +++ b/configs/uniphier_ld4_sld8_defconfig @@ -15,6 +15,7 @@ CONFIG_MICRO_SUPPORT_CARD=y CONFIG_SYS_LOAD_ADDR=0x85000000 CONFIG_SYS_MONITOR_LEN=2097152 CONFIG_TIMESTAMP=y +# CONFIG_BOOTSTD_DEFAULTS is not set # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_BOOTCOMMAND="run ${bootdev}script; run ${bootdev}boot" CONFIG_USE_PREBOOT=y diff --git a/configs/uniphier_v7_defconfig b/configs/uniphier_v7_defconfig index b7b86b668c01..a0c201e50419 100644 --- a/configs/uniphier_v7_defconfig +++ b/configs/uniphier_v7_defconfig @@ -15,6 +15,7 @@ CONFIG_MICRO_SUPPORT_CARD=y CONFIG_SYS_LOAD_ADDR=0x85000000 CONFIG_SYS_MONITOR_LEN=2097152 CONFIG_TIMESTAMP=y +# CONFIG_BOOTSTD_DEFAULTS is not set # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_BOOTCOMMAND="run ${bootdev}script; run ${bootdev}boot" CONFIG_USE_PREBOOT=y diff --git a/configs/uniphier_v8_defconfig b/configs/uniphier_v8_defconfig index ed58b5746e72..1b3ea6527130 100644 --- a/configs/uniphier_v8_defconfig +++ b/configs/uniphier_v8_defconfig @@ -11,6 +11,7 @@ CONFIG_MICRO_SUPPORT_CARD=y CONFIG_SYS_LOAD_ADDR=0x85000000 CONFIG_SYS_MONITOR_LEN=2097152 CONFIG_TIMESTAMP=y +# CONFIG_BOOTSTD_DEFAULTS is not set # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_BOOTCOMMAND="run ${bootdev}script; run ${bootdev}boot" CONFIG_USE_PREBOOT=y diff --git a/configs/variscite_dart6ul_defconfig b/configs/variscite_dart6ul_defconfig index f8c3f0ac4fbe..7dca4569af91 100644 --- a/configs/variscite_dart6ul_defconfig +++ b/configs/variscite_dart6ul_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL=y CONFIG_SYS_MONITOR_LEN=409600 CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 CONFIG_BOOTCOMMAND="run mmc_mmc_fit" diff --git a/configs/vf610twr_defconfig b/configs/vf610twr_defconfig index 75cc68ed9e1a..fe7aca16f598 100644 --- a/configs/vf610twr_defconfig +++ b/configs/vf610twr_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_MEMTEST_START=0x80010000 CONFIG_SYS_MEMTEST_END=0x87c00000 CONFIG_HAS_BOARD_SIZE_LIMIT=y CONFIG_BOARD_SIZE_LIMIT=520192 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" diff --git a/configs/vf610twr_nand_defconfig b/configs/vf610twr_nand_defconfig index b3ccf494b2e5..5117cc58f0c4 100644 --- a/configs/vf610twr_nand_defconfig +++ b/configs/vf610twr_nand_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_MEMTEST_START=0x80010000 CONFIG_SYS_MEMTEST_END=0x87c00000 CONFIG_HAS_BOARD_SIZE_LIMIT=y CONFIG_BOARD_SIZE_LIMIT=520192 +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" diff --git a/configs/vinco_defconfig b/configs/vinco_defconfig index 8a99bcace89a..5460caa4b3fa 100644 --- a/configs/vinco_defconfig +++ b/configs/vinco_defconfig @@ -16,6 +16,7 @@ CONFIG_DEFAULT_DEVICE_TREE="at91-vinco" CONFIG_SYS_PROMPT="vinco => " CONFIG_SYS_LOAD_ADDR=0x22000000 CONFIG_ENV_VARS_UBOOT_CONFIG=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/vining_2000_defconfig b/configs/vining_2000_defconfig index 7f84209b6555..012e15804acd 100644 --- a/configs/vining_2000_defconfig +++ b/configs/vining_2000_defconfig @@ -26,9 +26,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SYS_MONITOR_LEN=409600 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=0 -CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run distro_bootcmd" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_EARLY_INIT_F=y @@ -43,26 +41,16 @@ CONFIG_SPL_WATCHDOG=y CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532 -CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y -CONFIG_CMD_PART=y CONFIG_CMD_PCI=y # CONFIG_CMD_PINMUX is not set CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y @@ -97,7 +85,6 @@ CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y CONFIG_USB_MAX_CONTROLLER_COUNT=2 -CONFIG_USB_STORAGE=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_GADGET=y diff --git a/configs/vocore2_defconfig b/configs/vocore2_defconfig index 98429a69a777..f3a9b226742b 100644 --- a/configs/vocore2_defconfig +++ b/configs/vocore2_defconfig @@ -21,7 +21,6 @@ CONFIG_MIPS_CACHE_SETUP=y CONFIG_MIPS_CACHE_DISABLE=y CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y CONFIG_MIPS_BOOT_FDT=y -CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_BOOT_GET_CMDLINE=y CONFIG_SYS_BOOT_GET_KBD=y CONFIG_FIT=y @@ -57,17 +56,11 @@ CONFIG_CMD_GPT_RENAME=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y CONFIG_CMD_MTD=y -CONFIG_CMD_PART=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_WDT=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_BOOTCOUNT=y CONFIG_CMD_TIME=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=spi0.0" CONFIG_MTDPARTS_DEFAULT="spi0.0:312k(u-boot),4k(env),4k(factory),2368k(kernel),-(filesystem)" @@ -103,10 +96,8 @@ CONFIG_MT7621_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y -CONFIG_USB_STORAGE=y CONFIG_WDT=y CONFIG_WDT_MT7621=y -CONFIG_FS_EXT4=y CONFIG_FAT_WRITE=y CONFIG_LZMA=y CONFIG_LZO=y diff --git a/configs/warp7_bl33_defconfig b/configs/warp7_bl33_defconfig index bb699cfe8529..5f05d7c96de7 100644 --- a/configs/warp7_bl33_defconfig +++ b/configs/warp7_bl33_defconfig @@ -16,6 +16,7 @@ CONFIG_BOARD_SIZE_LIMIT=785408 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then run do_bootscript_hab;if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; fi; fi; fi" # CONFIG_BOARD_EARLY_INIT_F is not set diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index d0b4e747dd23..0b175dec76f7 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -19,6 +19,7 @@ CONFIG_HAS_BOARD_SIZE_LIMIT=y CONFIG_BOARD_SIZE_LIMIT=785408 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then run do_bootscript_hab;if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; fi; fi; fi" # CONFIG_BOARD_EARLY_INIT_F is not set diff --git a/configs/x530_defconfig b/configs/x530_defconfig index 4466e35a78ec..65c95fe2a9c6 100644 --- a/configs/x530_defconfig +++ b/configs/x530_defconfig @@ -47,16 +47,9 @@ CONFIG_CMD_PCI=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=nand:240M(user),8M(errlog),8M(nand-bbt)" @@ -90,7 +83,6 @@ CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y diff --git a/configs/xenguest_arm64_defconfig b/configs/xenguest_arm64_defconfig index a696c2807b06..18767a0a76c8 100644 --- a/configs/xenguest_arm64_defconfig +++ b/configs/xenguest_arm64_defconfig @@ -24,7 +24,6 @@ CONFIG_SYS_BOOTM_LEN=0x800000 # CONFIG_CMD_IMPORTENV is not set # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_SAVEENV is not set -# CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_CRC32 is not set # CONFIG_CMD_LZMADEC is not set # CONFIG_CMD_UNZIP is not set @@ -36,8 +35,6 @@ CONFIG_CMD_PVBLOCK=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_SLEEP is not set -CONFIG_CMD_EXT4=y -CONFIG_CMD_FAT=y # CONFIG_NET is not set # CONFIG_MMC is not set # CONFIG_REQUIRE_SERIAL_CONSOLE is not set diff --git a/configs/xilinx_versal_mini_emmc0_defconfig b/configs/xilinx_versal_mini_emmc0_defconfig index 31b3c02f7389..8aadc7f6805b 100644 --- a/configs/xilinx_versal_mini_emmc0_defconfig +++ b/configs/xilinx_versal_mini_emmc0_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_PROMPT="Versal> " CONFIG_SYS_LOAD_ADDR=0x8000000 # CONFIG_EXPERT is not set CONFIG_REMAKE_ELF=y +# CONFIG_BOOTSTD_DEFAULTS is not set # CONFIG_AUTOBOOT is not set CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run distro_bootcmd" diff --git a/configs/xilinx_versal_mini_emmc1_defconfig b/configs/xilinx_versal_mini_emmc1_defconfig index 5480cf1d9cc4..5ccc20048212 100644 --- a/configs/xilinx_versal_mini_emmc1_defconfig +++ b/configs/xilinx_versal_mini_emmc1_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_PROMPT="Versal> " CONFIG_SYS_LOAD_ADDR=0x8000000 # CONFIG_EXPERT is not set CONFIG_REMAKE_ELF=y +# CONFIG_BOOTSTD_DEFAULTS is not set # CONFIG_AUTOBOOT is not set CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run distro_bootcmd" diff --git a/configs/xilinx_zynqmp_mini_emmc0_defconfig b/configs/xilinx_zynqmp_mini_emmc0_defconfig index cf7c7eda8c94..47eab450c90a 100644 --- a/configs/xilinx_zynqmp_mini_emmc0_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc0_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_LOAD_ADDR=0x8000000 CONFIG_REMAKE_ELF=y # CONFIG_MP is not set CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y # CONFIG_AUTOBOOT is not set # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/xilinx_zynqmp_mini_emmc1_defconfig b/configs/xilinx_zynqmp_mini_emmc1_defconfig index a4a43b58a85e..03b34777c9f4 100644 --- a/configs/xilinx_zynqmp_mini_emmc1_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc1_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_LOAD_ADDR=0x8000000 CONFIG_REMAKE_ELF=y # CONFIG_MP is not set CONFIG_FIT=y +# CONFIG_BOOTSTD_DEFAULTS is not set CONFIG_SUPPORT_RAW_INITRD=y # CONFIG_AUTOBOOT is not set # CONFIG_DISPLAY_CPUINFO is not set
On Fri, Mar 31, 2023 at 10:26:01AM +1300, Simon Glass wrote:
This is needed to enable the boot command used to start standard boot. Enable it by default. This brings in quite a few features, mostly in common with DISTRO_DEFAULTS
Exclude boards which have what looks like a custom boot command:
git grep CONFIG_BOOTCOM configs/* |grep -v distro_bootcmd | sed -n 's/configs/(.*)_defconfig.*/\1/p'
Disable this option for boards which don't have enough space.
Disable CONFIG_ENV_VARS_UBOOT_CONFIG for some Xilinx boards which have a very small environment. Disable BOOTSTD_DEFAULTS for smartweb since it is too close to its limit.
Signed-off-by: Simon Glass sjg@chromium.org
I wasn't clear, sorry. What I want to see first is a standalone patch that disables BOOTSTD on platforms that have their own custom bootcmd, that is not just a more complex wrapper around distro_bootcmd (those platforms will require more work to convert, but won't be impacted by BOOTSTD_DEFAULTS being default). It needs to be on its own so it can be reviewed. Thanks.
Hi Tom,
Oh OK, I was wondering how it could be standard if it was just disabling BOOTSTD_DEFAULTS... I will give it a crack. I wonder if this is the same set which doesn't enable DISTRO_DEFAULTS?
On Sat, Apr 01, 2023 at 07:31:56PM +1300, Simon Glass wrote:
Hi Tom,
"standard" as in default/regular, not "standard" as in rigidly defined by external specification.
The ones which do things around "run distro_bootcmd" ? No, probably not. But the ones which have unexplained large size growth? Likely yes.
participants (5)
Ilias Apalodimas
Mark Kettenis
