[U-Boot] [PATCH 1/2] EXYNOS: EXYNOS5250: add exynos5250 register addresses
This patch add exynos5250 register addresses. Exynos5xxx series has each different register, so it is needed to separate.
Signed-off-by: Donghwa Lee dh09.lee@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- arch/arm/include/asm/arch-exynos/cpu.h | 33 ++++++++++++++++++++++++++++++++ 1 files changed, 33 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-exynos/cpu.h b/arch/arm/include/asm/arch-exynos/cpu.h index eb34422..0b382be 100644 --- a/arch/arm/include/asm/arch-exynos/cpu.h +++ b/arch/arm/include/asm/arch-exynos/cpu.h @@ -130,6 +130,37 @@ #define EXYNOS5_ADC_BASE DEVICE_NOT_AVAILABLE #define EXYNOS5_MODEM_BASE DEVICE_NOT_AVAILABLE
+#define EXYNOS5250_GPIO_PART4_BASE 0x03860000 +#define EXYNOS5250_PRO_ID 0x10000000 +#define EXYNOS5250_CLOCK_BASE 0x10010000 +#define EXYNOS5250_POWER_BASE 0x10040000 +#define EXYNOS5250_SWRESET 0x10040400 +#define EXYNOS5250_SYSREG_BASE 0x10050000 +#define EXYNOS5250_WATCHDOG_BASE 0x101D0000 +#define EXYNOS5250_DMC_PHY0_BASE 0x10C00000 +#define EXYNOS5250_DMC_PHY1_BASE 0x10C10000 +#define EXYNOS5250_GPIO_PART3_BASE 0x10D10000 +#define EXYNOS5250_DMC_CTRL_BASE 0x10DD0000 +#define EXYNOS5250_GPIO_PART1_BASE 0x11400000 +#define EXYNOS5250_MIPI_DSIM_BASE 0x11D00000 +#define EXYNOS5250_USB_HOST_EHCI_BASE 0x12110000 +#define EXYNOS5250_USBPHY_BASE 0x12130000 +#define EXYNOS5250_USBOTG_BASE 0x12140000 +#define EXYNOS5250_MMC_BASE 0x12200000 +#define EXYNOS5250_SROMC_BASE 0x12250000 +#define EXYNOS5250_UART_BASE 0x12C00000 +#define EXYNOS5250_I2C_BASE 0x12C60000 +#define EXYNOS5250_SPI_BASE 0x12D20000 +#define EXYNOS5250_I2S_BASE 0x12D60000 +#define EXYNOS5250_PWMTIMER_BASE 0x12DD0000 +#define EXYNOS5250_SPI_ISP_BASE 0x131A0000 +#define EXYNOS5250_GPIO_PART2_BASE 0x13400000 +#define EXYNOS5250_FIMD_BASE 0x14400000 +#define EXYNOS5250_DP_BASE 0x145B0000 + +#define EXYNOS5250_ADC_BASE DEVICE_NOT_AVAILABLE +#define EXYNOS5250_MODEM_BASE DEVICE_NOT_AVAILABLE + #ifndef __ASSEMBLY__ #include <asm/io.h> /* CPU detection macros */ @@ -198,6 +229,8 @@ static inline unsigned int samsung_get_base_##device(void) \ return EXYNOS4X12_##base; \ return EXYNOS4_##base; \ } else if (cpu_is_exynos5()) { \ + if (proid_is_exynos5250()) \ + return EXYNOS5250_##base; \ return EXYNOS5_##base; \ } \ return 0; \
Donghwa Lee
