[PATCH] spl: spl_fit: add weak prototype for fpga_load
In case OPTIMIZE_DEBUG is set, unused code will not be optimized out, hence the reference to fpga_load will be compiled. if DM_FPGA and SPL_FPGA are not set, the build will fail with :
aarch64-none-linux-gnu-ld.bfd: common/spl/spl_fit.o: in function `spl_fit_upload_fpga': u-boot/common/spl/spl_fit.c:595: undefined reference to `fpga_load'
By adding a weak prototype, build is successful.
Signed-off-by: Eugen Hristev eugen.hristev@collabora.com --- common/spl/spl_fit.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index c51482b3b659..ca2e337b1ec4 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -570,6 +570,12 @@ static void warn_deprecated(const char *msg) printf("\tSee doc/uImage.FIT/source_file_format.txt\n"); }
+__weak int fpga_load(int devnum, const void *buf, size_t bsize, + bitstream_type bstype, int flags) +{ + return 0; +} + static int spl_fit_upload_fpga(struct spl_fit_info *ctx, int node, struct spl_image_info *fpga_image) {
- static int spl_fit_upload_fpga(struct spl_fit_info *ctx, int node, struct spl_image_info *fpga_image) {
Gentle ping
Eugen Hristev
