[U-Boot] Pull request, u-boot-tegra/master
Tom,
Please pull u-boot-tegra/master into U-Boot/master. Thanks!
All tegra builds are OK (32-bit and 64-bit), and P2571 T210 64-bit boots to cmd prompt OK.
The following changes since commit fa43ce842c3026c2abf19d4234d02cd4c62eeec0:
Merge git://git.denx.de/u-boot-fdt (2015-09-16 09:53:37 -0400)
git://git.denx.de/u-boot-tegra.git master
for you to fetch changes up to 8e1601d994e2fa8b8c7826470c3d923a684492a4:
ARM: tegra114: Clear IDDQ when enabling PLLC (2015-09-16 16:11:31 -0700)
---------------------------------------------------------------- Axel Lin (1): tegra: Remove tegra_spl_gpio_direction_output declaration from header file
Mirza Krak (1): ARM: tegra: Add Tegra20 SPI device nodes
Stephen Warren (4): ARM: tegra: Add p2371-2180 board ARM: tegra: fix COUNTER_FREQUENCY for T210 ARM: tegra: fix PLLP frequency calc on T210 ARM: tegra: replace V_PROMPT define with kconfig
Thierry Reding (8): armv8: Make COUNTER_FREQUENCY optional ARM: tegra: Implement clk_m ARM: tegra: clk_m is the architected timer source clock e2220-1170: Remove hard-coded counter frequency p2371: Remove hard-coded counter frequency p2571: Remove hard-coded counter frequency ARM: tegra124: Clear IDDQ when enabling PLLC ARM: tegra114: Clear IDDQ when enabling PLLC
arch/arm/cpu/armv8/start.S | 2 + arch/arm/dts/Makefile | 1 + arch/arm/dts/tegra20.dtsi | 57 +++++ arch/arm/dts/tegra210-p2371-2180.dts | 60 +++++ arch/arm/include/asm/arch-tegra/clock.h | 7 +- arch/arm/include/asm/arch-tegra/gpio.h | 9 - arch/arm/include/asm/arch-tegra114/clock-tables.h | 1 + arch/arm/include/asm/arch-tegra114/clock.h | 3 + arch/arm/include/asm/arch-tegra124/clock-tables.h | 1 + arch/arm/include/asm/arch-tegra124/clock.h | 3 + arch/arm/include/asm/arch-tegra20/clock-tables.h | 1 + arch/arm/include/asm/arch-tegra210/clock-tables.h | 1 + arch/arm/include/asm/arch-tegra30/clock-tables.h | 1 + arch/arm/mach-tegra/clock.c | 21 +- arch/arm/mach-tegra/tegra114/clock.c | 9 +- arch/arm/mach-tegra/tegra124/clock.c | 9 +- arch/arm/mach-tegra/tegra210/Kconfig | 9 + arch/arm/mach-tegra/tegra210/clock.c | 21 +- board/nvidia/p2371-2180/Kconfig | 12 + board/nvidia/p2371-2180/MAINTAINERS | 6 + board/nvidia/p2371-2180/Makefile | 8 + board/nvidia/p2371-2180/p2371-2180.c | 51 ++++ board/nvidia/p2371-2180/pinmux-config-p2371-2180.h | 265 +++++++++++++++++++++ configs/e2220-1170_defconfig | 1 + configs/p2371-0000_defconfig | 1 + configs/p2371-2180_defconfig | 18 ++ configs/p2571_defconfig | 1 + include/configs/e2220-1170.h | 3 - include/configs/p2371-0000.h | 3 - include/configs/p2371-2180.h | 65 +++++ include/configs/p2571.h | 2 - 31 files changed, 622 insertions(+), 30 deletions(-) create mode 100644 arch/arm/dts/tegra210-p2371-2180.dts create mode 100644 board/nvidia/p2371-2180/Kconfig create mode 100644 board/nvidia/p2371-2180/MAINTAINERS create mode 100644 board/nvidia/p2371-2180/Makefile create mode 100644 board/nvidia/p2371-2180/p2371-2180.c create mode 100644 board/nvidia/p2371-2180/pinmux-config-p2371-2180.h create mode 100644 configs/p2371-2180_defconfig create mode 100644 include/configs/p2371-2180.h
On Wed, Sep 16, 2015 at 04:27:51PM -0700, Tom Warren wrote:
Tom,
Tom Warren
