[U-Boot-Users] u-boot TEXT_BASE relocatable
Hey fellas, I am in a fix...and am a newbie... I have my u-boot for ARM926Ejs... And there are two DDR banks. The problem is I want to be able to run u-boot from both the banks...
Reason? I need to do DDR testing (so need to change the offset values at times in the control registers of the DDR)... So if u-boot runs from Bank A, I can test Bank B, but as soon as I try and change control register of Bank A...my system crashes or resets... So I want to somehow use offsets to be used by the linker... Is that possible? And can nething be done to TEXT_BASE value in CONFIG.MK file to do this ?
thanks alot in advance guys
Sincerely Jayant
Oops? U-Boot will (if configured properly) map all banks of RAM as a single contiguous memory area and use it all.
Sounds as if you don't present us all information. Normally, i. e. when booting from NOR flash, U-Boot does the RAM testing while still running from flash, i. e. before relocation.
You sound as if U-Boot was not booting from flash memory, but from some sort of storage device like NAND or data flash. In this case it is the responsibility of the bootstrap loader which sets up RAM to test it before using it.
------=_Part_54830_4138933.1196732954043 Content-Type: text/html; charset=us-ascii Content-Transfer-Encoding: 7bit
And NEVER post HTML here.
Jayant Chauhan
