[PATCH 0/2] uboot: fs/btrfs: Fix read error on LZO compressed extents
There is a bug that uboot can't load LZO compressed data extent while kernel can handle it without any problem.
It turns out to be a page boundary case. The 2nd patch is the proper fix, backported from btrfs-progs.
The first patch is just to make my eyes less hurt.
I guess it's time to backport proper code from btrfs-progs, other than using tons of immediate numbers.
Qu Wenruo (2): uboot: fs/btrfs: Use LZO_LEN to replace immediate number uboot: fs/btrfs: Fix LZO false decompression error caused by pending zero
fs/btrfs/compression.c | 42 ++++++++++++++++++++++++++++++++---------- 1 file changed, 32 insertions(+), 10 deletions(-)
Just a cleanup. The immediate number makes my eye hurt.
Signed-off-by: Qu Wenruo wqu@suse.com --- fs/btrfs/compression.c | 22 ++++++++++++---------- 1 file changed, 12 insertions(+), 10 deletions(-)
diff --git a/fs/btrfs/compression.c b/fs/btrfs/compression.c index 346875d45a1b..4ef44ce11485 100644 --- a/fs/btrfs/compression.c +++ b/fs/btrfs/compression.c @@ -12,36 +12,38 @@ #include <u-boot/zlib.h> #include <asm/unaligned.h>
+/* Header for each segment, LE32, recording the compressed size */ +#define LZO_LEN 4 static u32 decompress_lzo(const u8 *cbuf, u32 clen, u8 *dbuf, u32 dlen) { u32 tot_len, in_len, res; size_t out_len; int ret;
- if (clen < 4) + if (clen < LZO_LEN) return -1;
tot_len = le32_to_cpu(get_unaligned((u32 *)cbuf)); - cbuf += 4; - clen -= 4; - tot_len -= 4; + cbuf += LZO_LEN; + clen -= LZO_LEN; + tot_len -= LZO_LEN;
if (tot_len == 0 && dlen) return -1; - if (tot_len < 4) + if (tot_len < LZO_LEN) return -1;
res = 0;
- while (tot_len > 4) { + while (tot_len > LZO_LEN) { in_len = le32_to_cpu(get_unaligned((u32 *)cbuf)); - cbuf += 4; - clen -= 4; + cbuf += LZO_LEN; + clen -= LZO_LEN;
- if (in_len > clen || tot_len < 4 + in_len) + if (in_len > clen || tot_len < LZO_LEN + in_len) return -1;
- tot_len -= 4 + in_len; + tot_len -= (LZO_LEN + in_len);
out_len = dlen; ret = lzo1x_decompress_safe(cbuf, in_len, dbuf, &out_len);
[BUG] For certain btrfs files with compressed file extent, uboot will fail to load it:
btrfs_read_extent_reg: disk_bytenr=14229504 disk_len=73728 offset=0 nr_bytes=131 072 decompress_lzo: tot_len=70770 decompress_lzo: in_len=1389 decompress_lzo: in_len=2400 decompress_lzo: in_len=3002 decompress_lzo: in_len=1379 decompress_lzo: in_len=88539136 decompress_lzo: header error, in_len=88539136 clen=65534 tot_len=62580
NOTE: except the last line, all other lines are debug output.
[CAUSE] Btrfs lzo compression uses its own format to record compressed size (segmant header, LE32).
However to make decompression easier, we never put such segment header across page boundary.
In above case, the xxd dump of the lzo compressed data looks like this:
00001fe0: 4cdc 02fc 0bfd 02c0 dc02 0d13 0100 0001 L............... 00001ff0: 0000 0008 0300 0000 0000 0011 0000|0000 ................ 00002000: 4705 0000 0001 cc02 0000 0000 0000 1e01 G...............
'|' is the "expected" segment header start position.
But in that page, there are only 2 bytes left, can't contain the 4 bytes segment header.
So btrfs compression will skip that 2 bytes, put the segment header in next page directly.
Uboot doesn't have such check, and read the header with 2 bytes offset, result 0x05470000 (88539136), other than the expected result 0x00000547 (1351), resulting above error.
[FIX] Follow the btrfs-progs restore implementation, by introducing tot_in to record total processed bytes (including headers), and do proper page boundary skip to fix it.
Signed-off-by: Qu Wenruo wqu@suse.com --- fs/btrfs/compression.c | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+)
diff --git a/fs/btrfs/compression.c b/fs/btrfs/compression.c index 4ef44ce11485..2a6ac8bb1029 100644 --- a/fs/btrfs/compression.c +++ b/fs/btrfs/compression.c @@ -9,6 +9,7 @@ #include <malloc.h> #include <linux/lzo.h> #include <linux/zstd.h> +#include <linux/compat.h> #include <u-boot/zlib.h> #include <asm/unaligned.h>
@@ -17,6 +18,7 @@ static u32 decompress_lzo(const u8 *cbuf, u32 clen, u8 *dbuf, u32 dlen) { u32 tot_len, in_len, res; + u32 tot_in = 0; size_t out_len; int ret;
@@ -27,6 +29,7 @@ static u32 decompress_lzo(const u8 *cbuf, u32 clen, u8 *dbuf, u32 dlen) cbuf += LZO_LEN; clen -= LZO_LEN; tot_len -= LZO_LEN; + tot_in += LZO_LEN;
if (tot_len == 0 && dlen) return -1; @@ -36,6 +39,9 @@ static u32 decompress_lzo(const u8 *cbuf, u32 clen, u8 *dbuf, u32 dlen) res = 0;
while (tot_len > LZO_LEN) { + size_t mod_page; + size_t rem_page; + in_len = le32_to_cpu(get_unaligned((u32 *)cbuf)); cbuf += LZO_LEN; clen -= LZO_LEN; @@ -44,6 +50,7 @@ static u32 decompress_lzo(const u8 *cbuf, u32 clen, u8 *dbuf, u32 dlen) return -1;
tot_len -= (LZO_LEN + in_len); + tot_in += (LZO_LEN + in_len);
out_len = dlen; ret = lzo1x_decompress_safe(cbuf, in_len, dbuf, &out_len); @@ -56,6 +63,19 @@ static u32 decompress_lzo(const u8 *cbuf, u32 clen, u8 *dbuf, u32 dlen) dlen -= out_len;
res += out_len; + + /* + * If the 4 bytes header does not fit to the rest of the page we + * have to move to next one, or we read some garbage. + */ + mod_page = tot_in % PAGE_SIZE; + rem_page = PAGE_SIZE - mod_page; + if (rem_page < LZO_LEN) { + cbuf += rem_page; + tot_in += rem_page; + clen -= rem_page; + tot_len -= rem_page; + } }
return res;
On Thu, 19 Mar 2020 20:33:19 +0800 Qu Wenruo wqu@suse.com wrote:
[BUG]
The subject line should not contain uboot keyword. If you check git log for fs/btrfs, the commits always start with: fs: btrfs:
Also please don't use [BUG] [CAUSE] and [FIX] in commit messages.
You could have also added myself to CC, since I am the original author of U-Boots btrfs implementation. I just stumbled on your patches by chance.
Also do not add linux-btrfs mailing list for u-boot patches.
- u32 tot_in = 0;
This function does not define local variable values in declaration, please don't mix this. Also tot_in is of the same type as the variables above, so use u32 tot_len, tot_in, in_len, res;
And put tot_in = 0; after line 24: tot_len = le32_to_cpu(get_unaligned((u32 *)cbuf));
tot_in += LZO_LEN;
size_t mod_page;
size_t rem_page;
The rest of the function uses u32, not size_t. Please use it as well. Also since the variables are of same type, please use one-line declaration only, eg: u32 mod_page, rem_page;
- in_len = le32_to_cpu(get_unaligned((u32 *)cbuf)); cbuf += LZO_LEN; clen -= LZO_LEN;
res += out_len;
Is there a reasof for mod_page? You could use just rem_page = PAGE_SIZE - (tot_in % PAGE_SIZE);
cbuf += rem_page;
tot_in += rem_page;
clen -= rem_page;
return res;
Sorry for this nitpicking, but I would like my driver to remain consistent in coding style.
Marek
[BUG]
Why? I think such section makes the analyse much easier to read.
Since there is no maintainer name in MAINTAINERS file, there is no way other guys would know who to CC.
I don't see any reason why we can't include the mail list for more experts to review.
- u32 tot_in = 0;
Please give us the proper code style doc, I understand that each project or even each subsystem has its own style, but without proper doc it will be a mess to maintain.
So, please show the proper code style for us to follow.
tot_in += LZO_LEN;
size_t mod_page;
size_t rem_page;
res += out_len;
I tend to keep the difference from btrfs-progs to minimal, as that's what I tend to plan to backport soon.
cbuf += rem_page;
tot_in += rem_page;
clen -= rem_page;
return res;
I know uboot btrfs is mostly backported by yourself and I respect the work.
But please add yourself to maintainers files, and also consider use existing btrfs-progs code to make code sycn easier, which would avoid such bug from the very beginning.
Thanks, Qu
Marek
[BUG]
Hi Qu,
I think your commit message without the tags is well-readable, but maybe this is just my personal view. On the other hand such tagging is not customary for U-Boot commit messages nor for Linux.
You have a fair point, sorry about that.
See below.
- u32 tot_in = 0;
When patches are being sent for example to netdev, sometimes netdev maintainer or reviewers nitpick about coding style and ask the author to fix this. Not all of these coding style requests are documented nor does the checkpatch script checks for all of them. Sometimes the only way for to get to know the coding style is by reading the code, and sometimes even that does not suffice. Either way these are reasonable requests and the authors fix the patches. I know that I always did it, for example when I sent patches for the mv88e6xxx linux driver, and Vivien or David asked me to fix such things.
I understand that people may find this exaggeration, but we know what happens when nobody cares about such things: look at U-Boot's ext4 driver.
tot_in += LZO_LEN;
size_t mod_page;
size_t rem_page;
res += out_len;
See below.
cbuf += rem_page;
tot_in += rem_page;
clen -= rem_page;
return res;
I am going to call this crossporting (porting from Linux to U-Boot), since I understand backporting to mean porting code to a previous version of the same program (ie. Linux 5.6 to Linux <5.6).
The U-Boot btrfs driver was not exactly crossported from Linux btrfs driver. Sure I have many times read Linux sources when I was not sure about something from documentation, and this reflected on the U-Boot implementation. But code-syncing is not possible with the original, as it was never intended to.
I also did not collaborate with Linux btrfs authors when writing this driver. These are the reasons why I don't see much point in adding linux-btrfs mailing list to Cc, since they may have never seen the codebase.
Marek
On the other hand it can't hurt for Linux btrfs authors to have a look at U-Boot's implementation, so I am withdrawing my objection. :) Sorry.
[BUG]
Hi Qu,
Got it, would try to control my eager to use such sections at least for U-boot code.
See below.
- u32 tot_in = 0;
Fine.
Although it may be tricky that if we cross port btrfs-progs (not kernel, as we don't really need to bother the full functionality from kernel), the code style would greatly change from the current one.
tot_in += LZO_LEN;
size_t mod_page;
size_t rem_page;
res += out_len;
See below.
cbuf += rem_page;
tot_in += rem_page;
clen -= rem_page;
return res;
Indeed crossport is much appropriate.
The kernel part is too complex, too fully functional, and too limited to kernel infrastructure. Things like bio is never really used out of kernel. So kernel code is seldom a good source for cross port.
And any complain about the doc is welcome since it helps us to improve the doc. (Yep, another reason why getting btrfs community involved could be helpful)
But from the git history, there are some other problem which can be exposed earlier, like the tree search behavior.
Thus sometimes it would be nicer to get the fs guys involved, some ideas like cross port btrfs-progs to u-boot even before trying to implement the code base.
Anyway, I'll update the patchset to address your comment soon, and explore the possibility to cross port btrfs-progs to make it easier to sync code.
Thanks, Qu
Marek
Marek Behun
Qu Wenruo
Qu Wenruo
