[U-Boot] [PATCH v2 2/5] sf: Minor cleanups.
- Add comments. - Renamed few macros. - Add tabs.
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com Signed-off-by: Bo Shen voice.shen@atmel.com --- Changes for v2: - none
drivers/mtd/spi/sf_internal.h | 6 +++--- drivers/mtd/spi/sf_ops.c | 2 +- drivers/mtd/spi/sf_probe.c | 5 +++-- include/spi.h | 14 +++++++------- 4 files changed, 14 insertions(+), 13 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 12d02f9..ad044ee 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -7,8 +7,8 @@ * Licensed under the GPL-2 or later. */
-#ifndef _SPI_FLASH_INTERNAL_H_ -#define _SPI_FLASH_INTERNAL_H_ +#ifndef _SF_INTERNAL_H_ +#define _SF_INTERNAL_H_
#define SPI_FLASH_16MB_BOUN 0x1000000
@@ -139,4 +139,4 @@ int spi_flash_read_common(struct spi_flash *flash, const u8 *cmd, int spi_flash_cmd_read_ops(struct spi_flash *flash, u32 offset, size_t len, void *data);
-#endif /* _SPI_FLASH_INTERNAL_H_ */ +#endif /* _SF_INTERNAL_H_ */ diff --git a/drivers/mtd/spi/sf_ops.c b/drivers/mtd/spi/sf_ops.c index 1003038..dde6231 100644 --- a/drivers/mtd/spi/sf_ops.c +++ b/drivers/mtd/spi/sf_ops.c @@ -292,7 +292,7 @@ int spi_flash_cmd_read_ops(struct spi_flash *flash, u32 offset, return ret; } #endif - remain_len = (SPI_FLASH_16MB_BOUN * (bank_sel + 1) - offset); + remain_len = (SPI_FLASH_16MB_BOUN * (bank_sel + 1)) - offset; if (len < remain_len) read_len = len; else diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index 4251b1b..9bb5a5f 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -25,7 +25,7 @@ DECLARE_GLOBAL_DATA_PTR; * @jedec: Device jedec ID (0x[1byte_manuf_id][2byte_dev_id]) * @ext_jedec: Device ext_jedec ID * @sector_size: Sector size of this device - * @nr_sectors: No.of sectors on this device + * @nr_sectors: No.of sectors on this device * @flags: Importent param, for flash specific behaviour */ struct spi_flash_params { @@ -139,7 +139,7 @@ static const struct spi_flash_params spi_flash_params_table[] = { #endif /* * Note: - * Below paired flash devices has similar spi_flash_params params. + * Below paired flash devices has similar spi_flash params. * (S25FL129P_64K, S25FL128S_64K) * (W25Q80BL, W25Q80BV) * (W25Q16CL, W25Q16DV) @@ -188,6 +188,7 @@ static struct spi_flash *spi_flash_validate_params(struct spi_slave *spi, } memset(flash, '\0', sizeof(*flash));
+ /* Assign spi data */ flash->spi = spi; flash->name = params->name; flash->memory_map = spi->memory_map; diff --git a/include/spi.h b/include/spi.h index 5164d43..ad9248b 100644 --- a/include/spi.h +++ b/include/spi.h @@ -1,4 +1,6 @@ /* + * Common SPI Interface: Controller-specific definitions + * * (C) Copyright 2001 * Gerald Van Baren, Custom IDEAS, vanbaren@cideas.com. * @@ -8,8 +10,6 @@ #ifndef _SPI_H_ #define _SPI_H_
-/* Controller-specific definitions: */ - /* SPI mode flags */ #define SPI_CPHA 0x01 /* clock phase */ #define SPI_CPOL 0x02 /* clock polarity */ @@ -241,11 +241,11 @@ static inline int spi_w8r8(struct spi_slave *slave, unsigned char byte) * This calls spi_setup_slave() with the correct bus number. Call * spi_free_slave() to free it later. * - * @param blob Device tree blob - * @param node SPI peripheral node to use - * @param cs Chip select to use - * @param max_hz Maximum SCK rate in Hz (0 for default) - * @param mode Clock polarity, clock phase and other parameters + * @param blob: Device tree blob + * @param node: SPI peripheral node to use + * @param cs: Chip select to use + * @param max_hz: Maximum SCK rate in Hz (0 for default) + * @param mode: Clock polarity, clock phase and other parameters * @return pointer to new spi_slave structure */ struct spi_slave *spi_setup_slave_fdt(const void *blob, int node,
