[U-Boot] [PATCH] NAND: Add Support for 4K page size in DaVinci NAND driver
This patch adds support for NAND devices with a page size of 4K in the DaVinci NAND driver. The layout matches the layout that TI uses for 4K page size NAND devices in the kernel NAND driver.
Signed-off-by: Sandeep Paulraj s-paulraj@ti.com --- patch applies to u-boot-nand-flash/next drivers/mtd/nand/davinci_nand.c | 23 ++++++++++++++++------- 1 files changed, 16 insertions(+), 7 deletions(-)
diff --git a/drivers/mtd/nand/davinci_nand.c b/drivers/mtd/nand/davinci_nand.c index eabaf3e..41a9568 100644 --- a/drivers/mtd/nand/davinci_nand.c +++ b/drivers/mtd/nand/davinci_nand.c @@ -182,13 +182,7 @@ static int nand_davinci_correct_data(struct mtd_info *mtd, u_char *dat, u_char *
#ifdef CONFIG_SYS_NAND_4BIT_HW_ECC_OOBFIRST static struct nand_ecclayout nand_davinci_4bit_layout_oobfirst = { -/* - * TI uses a different layout for 4K page deviecs. Since the - * eccpos filed can hold only a limited number of entries, adding - * support for 4K page will result in compilation warnings - * 4K Support will be added later - */ -#ifdef CONFIG_SYS_NAND_PAGE_2K +#if defined(CONFIG_SYS_NAND_PAGE_2K) .eccbytes = 40, .eccpos = { 24, 25, 26, 27, 28, @@ -200,6 +194,21 @@ static struct nand_ecclayout nand_davinci_4bit_layout_oobfirst = { .oobfree = { {.offset = 2, .length = 22, }, }, +#elif defined(CONFIG_SYS_NAND_PAGE_4K) + .eccbytes = 80, + .eccpos = { + 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, + 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, + 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, + 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, + 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, + 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, + 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, + 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, + }, + .oobfree = { + {.offset = 2, .length = 46, }, + }, #endif };
Applied.
-Scott
s-paulraj@ti.com
Scott Wood
