[U-Boot] [PATCH] 85xx: enable FDT support for STX SSA board
We also have to shift TEXT_BASE to accomodate for the additional code size.
Signed-off-by: Wolfgang Denk wd@denx.de Cc: Kumar Gala galak@kernel.crashing.org
--- board/stx/stxssa/stxssa.c | 8 ++++++++ include/configs/stxssa.h | 7 ++++++- 2 files changed, 14 insertions(+), 1 deletions(-)
diff --git a/board/stx/stxssa/stxssa.c b/board/stx/stxssa/stxssa.c index 83ffcd2..c78538d 100644 --- a/board/stx/stxssa/stxssa.c +++ b/board/stx/stxssa/stxssa.c @@ -34,6 +34,7 @@ #include <asm/processor.h> #include <asm/mmu.h> #include <asm/immap_85xx.h> +#include <asm/fsl_pci.h> #include <asm/fsl_ddr_sdram.h> #include <ioports.h> #include <asm/io.h> @@ -247,6 +248,13 @@ reset_phy(void) #endif }
+#ifdef CONFIG_OF_BOARD_SETUP +void ft_board_setup (void *blob, bd_t *bd) +{ + ft_cpu_setup (blob, bd); +} +#endif /* CONFIG_OF_BOARD_SETUP */ + int board_early_init_f(void) { diff --git a/include/configs/stxssa.h b/include/configs/stxssa.h index d5dd94f..141da26 100644 --- a/include/configs/stxssa.h +++ b/include/configs/stxssa.h @@ -43,7 +43,7 @@ #define CONFIG_STXSSA 1 /* Silicon Tx GPPP SSA board specific*/ #define CONFIG_MPC8560 1
-#define CONFIG_SYS_TEXT_BASE 0xFFFC0000 +#define CONFIG_SYS_TEXT_BASE 0xFFF80000
#define CONFIG_PCI /* PCI ethernet support */ #define CONFIG_TSEC_ENET /* tsec ethernet support*/ @@ -194,6 +194,11 @@ #define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #endif
+/* pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 +#define CONFIG_OF_STDOUT_VIA_ALIAS 1 + /* * I2C */
Hello.
Signed-off-by: Wolfgang Denkwd@denx.de Cc: Kumar Galagalak@kernel.crashing.org
- ft_cpu_setup (blob, bd);
I guess this won't pass checkpatch.pl (spaces before paren).
WBR, Sergei
On Jul 26, 2011, at 6:49 AM, Sergei Shtylyov wrote:
Hello.
WBR, Sergei
applied to 85xx & fixed whitespace issue.
- k
Dear Sergei Shtylyov,
You are right. Bad me. I apologize.
Thanks to Kumar for cleaning this up.
Kumar Gala
Sergei Shtylyov
