[PATCHv4] drivers: tpm2: update reset gpio semantics
Use the more generic reset-gpios property name.
Signed-off-by: Jorge Ramirez-Ortiz jorge@foundries.io ---
v4: s/will be deprecated/is deprecated
.../tpm2/tis-tpm2-spi.txt | 3 ++- drivers/tpm/tpm2_tis_spi.c | 23 ++++++++++++------- 2 files changed, 17 insertions(+), 9 deletions(-)
diff --git a/doc/device-tree-bindings/tpm2/tis-tpm2-spi.txt b/doc/device-tree-bindings/tpm2/tis-tpm2-spi.txt index 3a2ee4bd17..16f870225f 100644 --- a/doc/device-tree-bindings/tpm2/tis-tpm2-spi.txt +++ b/doc/device-tree-bindings/tpm2/tis-tpm2-spi.txt @@ -6,7 +6,8 @@ Required properties: - reg : SPI Chip select
Optional properties: -- gpio-reset : Reset GPIO (if not connected to the SoC reset line) +- reset-gpios : Reset GPIO (if not connected to the SoC reset line) +- gpio-reset : Reset GPIO (deprecated, use reset-gpios instead) - spi-max-frequency : See spi-bus.txt
Example: diff --git a/drivers/tpm/tpm2_tis_spi.c b/drivers/tpm/tpm2_tis_spi.c index 4b33ac8fd3..1d24d32d86 100644 --- a/drivers/tpm/tpm2_tis_spi.c +++ b/drivers/tpm/tpm2_tis_spi.c @@ -589,18 +589,25 @@ static int tpm_tis_spi_probe(struct udevice *dev) if (CONFIG_IS_ENABLED(DM_GPIO)) { struct gpio_desc reset_gpio;
- ret = gpio_request_by_name(dev, "gpio-reset", 0, + ret = gpio_request_by_name(dev, "reset-gpios", 0, &reset_gpio, GPIOD_IS_OUT); if (ret) { - log(LOGC_NONE, LOGL_NOTICE, "%s: missing reset GPIO\n", - __func__); - } else { - dm_gpio_set_value(&reset_gpio, 1); - mdelay(1); - dm_gpio_set_value(&reset_gpio, 0); + /* legacy reset */ + ret = gpio_request_by_name(dev, "gpio-reset", 0, + &reset_gpio, GPIOD_IS_OUT); + if (ret) { + log(LOGC_NONE, LOGL_NOTICE, + "%s: missing reset GPIO\n", __func__); + goto init; + } + log(LOGC_NONE, LOGL_NOTICE, + "%s: gpio-reset is deprecated\n", __func__); } + dm_gpio_set_value(&reset_gpio, 1); + mdelay(1); + dm_gpio_set_value(&reset_gpio, 0); } - +init: /* Ensure a minimum amount of time elapsed since reset of the TPM */ mdelay(drv_data->time_before_first_cmd_ms);
if (ret) {ret = gpio_request_by_name(dev, "reset-gpios", 0, &reset_gpio, GPIOD_IS_OUT);
__func__);
} else {
mdelay(1);
/* legacy reset */
if (ret) {
goto init;
}"%s: gpio-reset is deprecated\n", __func__);
mdelay(1);
}dm_gpio_set_value(&reset_gpio, 0);
Acked-by: Michal Simek michal.simek@xilinx.com
Thanks, Michal
Jorge Ramirez-Ortiz
Michal Simek
