[PATCH v2 0/3] gpio: intel_gpio: Fix Intel gpio driver
This series fixes some issues in the Intel gpio driver. I have tested it on an Apollo Lake device, where U-Boot is booted as a coreboot payload.
Changes in v2: - Fixed typo in the commit description - Fixed the same error in both intel_gpio_direction_output() and intel_gpio_set_value() (Thanks to Bin Meng for catching this) - Reworded commit description - Added reviewed-by tags
Wolfgang Wallner (3): gpio: intel_gpio: Pass pinctrl device to pcr_clrsetbits32() gpio: intel_gpio: Clear tx state bit when setting output gpio: intel_gpio: Fix register/bit offsets intel_gpio_get_value()
drivers/gpio/intel_gpio.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
The function pcr_clrsetbits32() expects a device with a P2SB parent device. In intel_gpio_direction_output() and intel_gpio_set_value() the device 'dev' is passed to pcr_clrsetbits32(), which is a gpio-controller with a device 'pinctrl' as parent. This does not match the expectations of pcr_clrsetbits32(). But the 'pinctrl' device has a P2SB as parent.
Pass the 'pinctrl' device instead of the 'dev' device to pcr_clrsetbits32().
Signed-off-by: Wolfgang Wallner wolfgang.wallner@br-automation.com
drivers/gpio/intel_gpio.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/gpio/intel_gpio.c b/drivers/gpio/intel_gpio.c index 4bf1c9ddc4..b05cfc4aed 100644 --- a/drivers/gpio/intel_gpio.c +++ b/drivers/gpio/intel_gpio.c @@ -39,7 +39,7 @@ static int intel_gpio_direction_output(struct udevice *dev, uint offset, struct udevice *pinctrl = dev_get_parent(dev); uint config_offset = intel_pinctrl_get_config_reg_addr(pinctrl, offset);
- pcr_clrsetbits32(dev, config_offset, + pcr_clrsetbits32(pinctrl, config_offset, PAD_CFG0_MODE_MASK | PAD_CFG0_RX_STATE | PAD_CFG0_TX_DISABLE, PAD_CFG0_MODE_GPIO | PAD_CFG0_RX_DISABLE | @@ -72,7 +72,7 @@ static int intel_gpio_set_value(struct udevice *dev, unsigned offset, int value) struct udevice *pinctrl = dev_get_parent(dev); uint config_offset = intel_pinctrl_get_config_reg_addr(pinctrl, offset);
- pcr_clrsetbits32(dev, config_offset, PAD_CFG0_TX_STATE, + pcr_clrsetbits32(pinctrl, config_offset, PAD_CFG0_TX_STATE, value ? PAD_CFG0_TX_STATE : 0);
On Mon, Feb 3, 2020 at 6:38 PM Wolfgang Wallner wolfgang.wallner@br-automation.com wrote:
Changes in v2:
Changes in v2:
applied to u-boot-x86, thanks!
Add missing 'PAD_CFG0_TX_STATE' to the clear mask for pcr_clrsetbits32(). Otherwise this bit cannot be cleared again after it has been set once.
Signed-off-by: Wolfgang Wallner wolfgang.wallner@br-automation.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com
Changes in v2: - Added reviewed-by tags
drivers/gpio/intel_gpio.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/gpio/intel_gpio.c b/drivers/gpio/intel_gpio.c index b05cfc4aed..be91626cc5 100644 --- a/drivers/gpio/intel_gpio.c +++ b/drivers/gpio/intel_gpio.c @@ -41,7 +41,7 @@ static int intel_gpio_direction_output(struct udevice *dev, uint offset,
pcr_clrsetbits32(pinctrl, config_offset, PAD_CFG0_MODE_MASK | PAD_CFG0_RX_STATE | - PAD_CFG0_TX_DISABLE, + PAD_CFG0_TX_DISABLE | PAD_CFG0_TX_STATE, PAD_CFG0_MODE_GPIO | PAD_CFG0_RX_DISABLE | (value ? PAD_CFG0_TX_STATE : 0));
Changes in v2:
Fix the following in intel_gpio_get_value():
* The value of the register is contained in the variable 'reg', not in 'mode'. The variable 'mode' contains only the configuration whether the gpio is currently an input or an output.
* The correct bitmasks for the input and output value are PAD_CFG0_RX_STATE and PAD_CFG0_TX_STATE. Use them instead of the currently used PAD_CFG0_RX_STATE_BIT and PAD_CFG0_TX_STATE_BIT.
Changes in v2: None
diff --git a/drivers/gpio/intel_gpio.c b/drivers/gpio/intel_gpio.c index be91626cc5..67b8b80b9d 100644 --- a/drivers/gpio/intel_gpio.c +++ b/drivers/gpio/intel_gpio.c @@ -59,9 +59,9 @@ static int intel_gpio_get_value(struct udevice *dev, uint offset) if (!mode) { rx_tx = reg & (PAD_CFG0_TX_DISABLE | PAD_CFG0_RX_DISABLE); if (rx_tx == PAD_CFG0_TX_DISABLE) - return mode & PAD_CFG0_RX_STATE_BIT ? 1 : 0; + return reg & PAD_CFG0_RX_STATE ? 1 : 0; else if (rx_tx == PAD_CFG0_RX_DISABLE) - return mode & PAD_CFG0_TX_STATE_BIT ? 1 : 0; + return reg & PAD_CFG0_TX_STATE ? 1 : 0; }
On Mon, Feb 3, 2020 at 12:38 PM Wolfgang Wallner wolfgang.wallner@br-automation.com wrote:
Is it style of U-Boot? Because return !!(...); will have same effect while consuming less characters.
'else' is redundant here
Hi Andy,
On Mon, Feb 3, 2020 at 8:34 PM Andy Shevchenko andy.shevchenko@gmail.com wrote:
checkpatch does not complain, so I assume it is okay for U-Boot.
Regards, Bin
Changes in v2: None
When you send series, be sure you put all maintainers (not me, but like Bin) to *all* patches in it.
Changes in v2:
-- 2.25.0
Hi Andy,
-----"Andy Shevchenko" andy.shevchenko@gmail.com schrieb: ----- On Mon, Feb 3, 2020 at 12:38 PM Wolfgang Wallner wolfgang.wallner@br-automation.com wrote:
I can't follow you. I have used the following configuration for patman:
Series-to: u-boot Series-cc: bmeng, sjg
And according to my local mail client all patches in this series have been sent with this configuration (U-Boot mailing list as receiver, Bin Meng and Simon Glass as CC).
Does it look different for you? Or did I miss something (e.g. other maintainers)?
regards, Wolfgang
On Mon, Feb 3, 2020 at 3:19 PM Wolfgang Wallner wolfgang.wallner@br-automation.com wrote:
Hi Andy,
Yes, for example for this mail (initial cover letter above) I see only ML in To and none in Cc.
from: Wolfgang Wallner wolfgang.wallner@br-automation.com via lists.denx.de to: u-boot@lists.denx.de date: Feb 3, 2020, 12:38 PM subject: [PATCH v2 0/3] gpio: intel_gpio: Fix Intel gpio driver mailing list: u-boot@lists.denx.de Filter messages from this mailing list mailed-by: lists.denx.de unsubscribe: Unsubscribe from this mailing list security:  Standard encryption (TLS) Learn more
Are you sure you have Cc filled at the end before sending?
Hi Andy,
On Mon, Feb 3, 2020 at 10:17 PM Andy Shevchenko andy.shevchenko@gmail.com wrote:
Hi Andy,
I can see both Simon and me are cc'ed.
From: Wolfgang Wallner wolfgang.wallner@br-automation.com To: u-boot@lists.denx.de Cc: Simon Glass sjg@chromium.org, Bin Meng bmeng.cn@gmail.com, Wolfgang Wallner wolfgang.wallner@br-automation.com Subject: [PATCH v2 0/3] gpio: intel_gpio: Fix Intel gpio driver Date: Mon, 3 Feb 2020 11:38:03 +0100 Message-Id: 20200203103806.29445-1-wolfgang.wallner@br-automation.com
Regards, Bin
Okay, that means Gmail is somehow broken. :-(
Andy Shevchenko
Bin Meng
Wolfgang Wallner
