env: ext4: add test for env in ext4
In this serie, I add sandbox test with CONFIG_ENV_IS_NOWHERE activated with other location: at least one CONFIG_ENV_IS_IN_... is defined and ENV_IS_IN_DEVICE is automatically defined.
To test this feature, I activate and test ENV_IS_IN_EXT4 in sandbox; I add a new command "env_loc" to change this ENV location.
This serie depends on previous env test introduced in: "cmd: env: add option for quiet output on env info" http://patchwork.ozlabs.org/project/uboot/list/?series=158105
To be able to test invalid file (bad CRC), I also add the support of the command "env erase" for EXT4 env location.
Regards
Patrick
Patrick Delaunay (10): env: add absolute path at CONFIG_ENV_EXT4_FILE env: ext4: set gd->env_valid env: correctly handle result in env_init sandbox: activate env in ext4 support sandbox: support the change of env location test: environment in ext4 env: ext4: fix possible compilation issue env: ext4: introduce new function env_ext4_save_buffer env: ext4: add support of command env erase test: sandbox: add test for erase command
board/sandbox/sandbox.c | 50 ++++++++++++++ configs/sandbox64_defconfig | 5 ++ configs/sandbox_defconfig | 5 ++ configs/sandbox_flattree_defconfig | 5 ++ configs/sandbox_spl_defconfig | 5 ++ env/Kconfig | 2 +- env/env.c | 5 +- env/ext4.c | 63 +++++++++++++++--- test/py/tests/test_env.py | 103 +++++++++++++++++++++++++++++ 9 files changed, 232 insertions(+), 11 deletions(-)
Add the absolute path to the default value of CONFIG_ENV_EXT4_FILE = "/uboot.env".
This patch avoid the error : Saving Environment to EXT4... File System is consistent Please supply Absolute path
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
For information, it is the value used today by all the boards:
dragonboard820c_defconfig:29:CONFIG_ENV_EXT4_FILE="/uboot.env" hikey960_defconfig:25:CONFIG_ENV_EXT4_FILE="/uboot.env" stm32mp15_basic_defconfig:64:CONFIG_ENV_EXT4_FILE="/uboot.env" stm32mp15_optee_defconfig:51:CONFIG_ENV_EXT4_FILE="/uboot.env" stm32mp15_trusted_defconfig:50:CONFIG_ENV_EXT4_FILE="/uboot.env"
env/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/env/Kconfig b/env/Kconfig index 0d6f559b39..8059749701 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -467,7 +467,7 @@ config ENV_EXT4_DEVICE_AND_PART config ENV_EXT4_FILE string "Name of the EXT4 file to use for the environment" depends on ENV_IS_IN_EXT4 - default "uboot.env" + default "/uboot.env" help It's a string of the EXT4 file name. This file use to store the environment (explicit path to the file)
Add a missing initialization of gd->env_valid in env_ext4_load as it is already done in some other env device.
Set gd->env_valid = ENV_VALID in env_ext4_save() and env_ext4_load().
This patch allows to have a correct information in 'env info' command.
env/ext4.c | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/env/ext4.c b/env/ext4.c index 1f6b1b5bd8..e3bbf4a4e0 100644 --- a/env/ext4.c +++ b/env/ext4.c @@ -31,6 +31,8 @@ #include <ext4fs.h> #include <mmc.h>
+DECLARE_GLOBAL_DATA_PTR; + __weak const char *env_ext4_get_intf(void) { return (const char *)CONFIG_ENV_EXT4_INTERFACE; @@ -79,6 +81,7 @@ static int env_ext4_save(void) CONFIG_ENV_EXT4_FILE, ifname, dev, part); return 1; } + gd->env_valid = ENV_VALID;
puts("done\n"); return 0; @@ -125,7 +128,11 @@ static int env_ext4_load(void) goto err_env_relocate; }
- return env_import(buf, 1); + err = env_import(buf, 1); + if (!err) + gd->env_valid = ENV_VALID; + + return err;
err_env_relocate: env_set_default(NULL, 0);
Don't return error with ret=-ENOENT when the optional ops drv->init is absent but only if env_driver_lookup don't found driver.
This patch correct an issue for the code if (!env_init()) env_load() When only ext4 is supported (CONFIG_ENV_IS_IN_EXT4), as the backend env/ext4.c doesn't define an ops .init
env/env.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/env/env.c b/env/env.c index 9237bb9c74..e4df1715e4 100644 --- a/env/env.c +++ b/env/env.c @@ -292,7 +292,10 @@ int env_init(void) int prio;
for (prio = 0; (drv = env_driver_lookup(ENVOP_INIT, prio)); prio++) { - if (!drv->init || !(ret = drv->init())) + ret = 0; + if (drv->init) + ret = drv->init(); + if (!ret) env_set_inited(drv->location);
debug("%s: Environment %s init done (ret=%d)\n", __func__,
The default environment is still used with "ENVL_NOWHERE" indicated by the weak function env_get_location() and activated by CONFIG_ENV_IS_NOWHERE.
board/sandbox/sandbox.c | 12 ++++++++++++ configs/sandbox64_defconfig | 4 ++++ configs/sandbox_defconfig | 4 ++++ configs/sandbox_flattree_defconfig | 4 ++++ configs/sandbox_spl_defconfig | 4 ++++ 5 files changed, 28 insertions(+)
diff --git a/board/sandbox/sandbox.c b/board/sandbox/sandbox.c index 0c3d245dff..01f356be31 100644 --- a/board/sandbox/sandbox.c +++ b/board/sandbox/sandbox.c @@ -7,6 +7,7 @@ #include <cpu_func.h> #include <cros_ec.h> #include <dm.h> +#include <env_internal.h> #include <init.h> #include <led.h> #include <os.h> @@ -44,6 +45,17 @@ unsigned long timer_read_counter(void) } #endif
+enum env_location env_get_location(enum env_operation op, int prio) +{ + /* only one location supported */ + if (prio != 0) + return ENVL_UNKNOWN; + + gd->env_load_prio = 0; + + return ENVL_NOWHERE; +} + int dram_init(void) { gd->ram_size = CONFIG_SYS_SDRAM_SIZE; diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index cdcb0acbdc..6172259924 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -75,6 +75,10 @@ CONFIG_OF_CONTROL=y CONFIG_OF_LIVE=y CONFIG_OF_HOSTFILE=y CONFIG_DEFAULT_DEVICE_TREE="sandbox64" +CONFIG_ENV_IS_NOWHERE=y +CONFIG_ENV_IS_IN_EXT4=y +CONFIG_ENV_EXT4_INTERFACE="host" +CONFIG_ENV_EXT4_DEVICE_AND_PART="0:0" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NETCONSOLE=y CONFIG_IP_DEFRAG=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 33a103edab..28a6211189 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -84,6 +84,10 @@ CONFIG_OF_CONTROL=y CONFIG_OF_LIVE=y CONFIG_OF_HOSTFILE=y CONFIG_DEFAULT_DEVICE_TREE="sandbox" +CONFIG_ENV_IS_NOWHERE=y +CONFIG_ENV_IS_IN_EXT4=y +CONFIG_ENV_EXT4_INTERFACE="host" +CONFIG_ENV_EXT4_DEVICE_AND_PART="0:0" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NETCONSOLE=y CONFIG_IP_DEFRAG=y diff --git a/configs/sandbox_flattree_defconfig b/configs/sandbox_flattree_defconfig index 2bfbb66453..1324aaca37 100644 --- a/configs/sandbox_flattree_defconfig +++ b/configs/sandbox_flattree_defconfig @@ -59,6 +59,10 @@ CONFIG_AMIGA_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_HOSTFILE=y CONFIG_DEFAULT_DEVICE_TREE="sandbox" +CONFIG_ENV_IS_NOWHERE=y +CONFIG_ENV_IS_IN_EXT4=y +CONFIG_ENV_EXT4_INTERFACE="host" +CONFIG_ENV_EXT4_DEVICE_AND_PART="0:0" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NETCONSOLE=y CONFIG_IP_DEFRAG=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index 3bf27c974a..eadcdb9f43 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -76,6 +76,10 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_OF_HOSTFILE=y CONFIG_DEFAULT_DEVICE_TREE="sandbox" CONFIG_SPL_OF_PLATDATA=y +CONFIG_ENV_IS_NOWHERE=y +CONFIG_ENV_IS_IN_EXT4=y +CONFIG_ENV_EXT4_INTERFACE="host" +CONFIG_ENV_EXT4_DEVICE_AND_PART="0:0" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NETCONSOLE=y CONFIG_IP_DEFRAG=y
Add support of environment location with a new sandbox command 'env_loc'.
When the user change the environment location with the command 'env_loc <location>' the env is reinitialized and saved; the GD_FLG_ENV_DEFAULT flag is also updated.
When the user set the same env location, the environment is re-loaded.
board/sandbox/sandbox.c | 40 +++++++++++++++++++++++++++++++++++++++- 1 file changed, 39 insertions(+), 1 deletion(-)
diff --git a/board/sandbox/sandbox.c b/board/sandbox/sandbox.c index 01f356be31..023a71d5f0 100644 --- a/board/sandbox/sandbox.c +++ b/board/sandbox/sandbox.c @@ -21,6 +21,9 @@ */ gd_t *gd;
+/* env location: current location used during test */ +static enum env_location sandbox_env_location = ENVL_NOWHERE; + /* Add a simple GPIO device */ U_BOOT_DEVICE(gpio_sandbox) = { .name = "gpio_sandbox", @@ -53,9 +56,44 @@ enum env_location env_get_location(enum env_operation op, int prio)
- return ENVL_NOWHERE; + return sandbox_env_location; }
+static int do_env_loc(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + enum env_location loc; + + if (argc < 2) + return CMD_RET_USAGE; + + loc = (enum env_location)simple_strtoul(argv[1], NULL, 10); + if (loc >= ENVL_COUNT) + return CMD_RET_FAILURE; + + if (sandbox_env_location != loc) { + sandbox_env_location = loc; + if (loc == ENVL_NOWHERE) { + gd->flags |= GD_FLG_ENV_DEFAULT; + gd->env_valid = ENV_VALID; + } else { + if (gd->flags & GD_FLG_ENV_DEFAULT) { + gd->flags &= ~GD_FLG_ENV_DEFAULT; + if (!env_init()) + env_save(); + } + } + } else { + if (!env_init()) + env_load(); + } + + return CMD_RET_SUCCESS; +} + +U_BOOT_CMD(env_loc, 2, 1, do_env_loc, + "set the environment location", "[loc]" +); + int dram_init(void) { gd->ram_size = CONFIG_SYS_SDRAM_SIZE;
Add basic test to persistent environment in ext4: save and load in host ext4 file 'uboot.env'.
On first execution a empty EXT4 file system is created in persistent data dir: env.ext4.img.
test/py/tests/test_env.py | 87 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 87 insertions(+)
diff --git a/test/py/tests/test_env.py b/test/py/tests/test_env.py index cbdb41031c..d35ad888a7 100644 --- a/test/py/tests/test_env.py +++ b/test/py/tests/test_env.py @@ -4,6 +4,10 @@
# Test operation of shell commands relating to environment variables.
+import os +import os.path +from subprocess import call, check_call + import pytest import u_boot_utils
@@ -380,3 +384,86 @@ def test_env_info_quiet(state_test_env): assert response == "" response = c.run_command('echo $?') assert response == "1" + +def mk_env_ext4(state_test_env): + c = state_test_env.u_boot_console + + """Create a empty ext4 file system volume. + """ + filename = 'env.ext4.img' + persistent = c.config.persistent_data_dir + '/' + filename + fs_img = c.config.result_dir + '/' + filename + + if os.path.exists(persistent): + c.log.action('Disk image file ' + persistent + ' already exists') + else: + try: + check_call('rm -f %s' % persistent, shell=True) + check_call('dd if=/dev/zero of=%s bs=1M count=16' + % persistent, shell=True) + check_call('mkfs.ext4 -O ^metadata_csum %s' % persistent, shell=True) + except CalledProcessError: + call('rm -f %s' % persistent, shell=True) + raise + + call('cp -f %s %s' % (persistent, fs_img), shell=True) + return fs_img + +@pytest.mark.boardspec('sandbox') +@pytest.mark.buildconfigspec('cmd_nvedit_info') +@pytest.mark.buildconfigspec('cmd_echo') +@pytest.mark.buildconfigspec('env_is_in_ext4') +def test_env_ext4(state_test_env): + + c = state_test_env.u_boot_console + + fs_img = mk_env_ext4(state_test_env) + c.run_command('host bind 0 %s' % fs_img) + + response = c.run_command('ext4ls host 0:0') + assert 'uboot.env' not in response + + """ env_location: ENVL_EXT4 (2) + """ + response = c.run_command('env_loc 2') + assert 'Saving Environment to EXT4' in response + + response = c.run_command('env_loc 2') + assert 'Loading Environment from EXT4... OK' in response + + response = c.run_command('ext4ls host 0:0') + assert '8192 uboot.env' in response + + response = c.run_command('env info') + assert 'env_valid = valid' in response + assert 'env_ready = true' in response + assert 'env_use_default = false' in response + + response = c.run_command('env info -p -d') + assert 'Environment was loaded from persistent storage' in response + assert 'Environment can be persisted' in response + + response = c.run_command('env info -d -q') + assert response == "" + response = c.run_command('echo $?') + assert response == "1" + + response = c.run_command('env info -p -q') + assert response == "" + response = c.run_command('echo $?') + assert response == "0" + + """ restore env_location: ENVL_NOWHERE (12) + """ + c.run_command('env_loc 12') + + response = c.run_command('env info') + assert 'env_valid = valid' in response + assert 'env_ready = true' in response + assert 'env_use_default = true' in response + + response = c.run_command('env info -p -d') + assert 'Default environment is used' in response + assert 'Environment cannot be persisted' in response + + call('rm -f %s' % fs_img, shell=True)
Fix possible compilation issue in env ext4 support when CONFIG_CMD_SAVEENV is not activated.
env/ext4.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/env/ext4.c b/env/ext4.c index e3bbf4a4e0..aa77261649 100644 --- a/env/ext4.c +++ b/env/ext4.c @@ -144,5 +144,7 @@ U_BOOT_ENV_LOCATION(ext4) = { .location = ENVL_EXT4, ENV_NAME("EXT4") .load = env_ext4_load, +#ifdef CONFIG_CMD_SAVEENV .save = env_save_ptr(env_ext4_save), +#endif };
Split the function env_ext4_save to prepare the erase support
env/ext4.c | 32 +++++++++++++++++++++++--------- 1 file changed, 23 insertions(+), 9 deletions(-)
diff --git a/env/ext4.c b/env/ext4.c index aa77261649..49ed06659f 100644 --- a/env/ext4.c +++ b/env/ext4.c @@ -43,10 +43,9 @@ __weak const char *env_ext4_get_dev_part(void) return (const char *)CONFIG_ENV_EXT4_DEVICE_AND_PART; }
-#ifdef CONFIG_CMD_SAVEENV -static int env_ext4_save(void) +#if defined(CONFIG_CMD_SAVEENV) +static int env_ext4_save_buffer(env_t *env_new) { - env_t env_new; struct blk_desc *dev_desc = NULL; disk_partition_t info; int dev, part; @@ -54,10 +53,6 @@ static int env_ext4_save(void) const char *ifname = env_ext4_get_intf(); const char *dev_and_part = env_ext4_get_dev_part();
- err = env_export(&env_new); - if (err) - return err; - part = blk_get_device_part_str(ifname, dev_and_part, &dev_desc, &info, 1); if (part < 0) @@ -72,7 +67,7 @@ static int env_ext4_save(void) return 1; }
- err = ext4fs_write(CONFIG_ENV_EXT4_FILE, (void *)&env_new, + err = ext4fs_write(CONFIG_ENV_EXT4_FILE, (void *)env_new, sizeof(env_t), FILETYPE_REG); ext4fs_close();
@@ -81,9 +76,28 @@ static int env_ext4_save(void) CONFIG_ENV_EXT4_FILE, ifname, dev, part); return 1; } - gd->env_valid = ENV_VALID;
+ return 0; +} +#endif + +#ifdef CONFIG_CMD_SAVEENV +static int env_ext4_save(void) +{ + env_t env_new; + int err; + + err = env_export(&env_new); + if (err) + return err; + + err = env_ext4_save_buffer(&env_new); + if (err) + return err; + + gd->env_valid = ENV_VALID; puts("done\n"); + return 0; } #endif /* CONFIG_CMD_SAVEENV */
Add support of opts erase for env in ext4, this opts is used by command 'env erase'.
This command only fill the env file (CONFIG_ENV_EXT4_FILE) with 0, the CRC and the saved environment becomes invalid.
env/ext4.c | 24 +++++++++++++++++++++++- 1 file changed, 23 insertions(+), 1 deletion(-)
diff --git a/env/ext4.c b/env/ext4.c index 49ed06659f..aec2a33fad 100644 --- a/env/ext4.c +++ b/env/ext4.c @@ -43,7 +43,7 @@ __weak const char *env_ext4_get_dev_part(void) return (const char *)CONFIG_ENV_EXT4_DEVICE_AND_PART; }
-#if defined(CONFIG_CMD_SAVEENV) +#if defined(CONFIG_CMD_SAVEENV) || defined(CONFIG_CMD_ERASEENV) static int env_ext4_save_buffer(env_t *env_new) { struct blk_desc *dev_desc = NULL; @@ -102,6 +102,25 @@ static int env_ext4_save(void) } #endif /* CONFIG_CMD_SAVEENV */
+#if defined(CONFIG_CMD_ERASEENV) +static int env_ext4_erase(void) +{ + env_t env_new; + int err; + + memset(&env_new, 0, sizeof(env_t)); + + err = env_ext4_save_buffer(&env_new); + if (err) + return err; + + gd->env_valid = ENV_INVALID; + puts("done\n"); + + return 0; +} +#endif + static int env_ext4_load(void) { ALLOC_CACHE_ALIGN_BUFFER(char, buf, CONFIG_ENV_SIZE); @@ -161,4 +180,7 @@ U_BOOT_ENV_LOCATION(ext4) = { #ifdef CONFIG_CMD_SAVEENV .save = env_save_ptr(env_ext4_save), #endif +#if defined(CONFIG_CMD_ERASEENV) + .erase = env_ext4_erase, +#endif };
Add test for the erase command tested on ENV in EXT4.
configs/sandbox64_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/sandbox_flattree_defconfig | 1 + configs/sandbox_spl_defconfig | 1 + test/py/tests/test_env.py | 20 ++++++++++++++++++-- 5 files changed, 22 insertions(+), 2 deletions(-)
diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index 6172259924..a92dc957e8 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_ELF is not set CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y +CONFIG_CMD_ERASEENV=y CONFIG_CMD_ENV_CALLBACK=y CONFIG_CMD_ENV_FLAGS=y CONFIG_CMD_NVEDIT_INFO=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 28a6211189..82a980e652 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_ABOOTIMG=y # CONFIG_CMD_ELF is not set CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y +CONFIG_CMD_ERASEENV=y CONFIG_CMD_ENV_CALLBACK=y CONFIG_CMD_ENV_FLAGS=y CONFIG_CMD_NVEDIT_INFO=y diff --git a/configs/sandbox_flattree_defconfig b/configs/sandbox_flattree_defconfig index 1324aaca37..93d587fe38 100644 --- a/configs/sandbox_flattree_defconfig +++ b/configs/sandbox_flattree_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_ELF is not set CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y +CONFIG_CMD_ERASEENV=y CONFIG_CMD_NVEDIT_INFO=y CONFIG_LOOPW=y CONFIG_CMD_MD5SUM=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index eadcdb9f43..2337eade06 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_ELF is not set CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y +CONFIG_CMD_ERASEENV=y CONFIG_CMD_ENV_CALLBACK=y CONFIG_CMD_ENV_FLAGS=y CONFIG_CMD_NVEDIT_INFO=y diff --git a/test/py/tests/test_env.py b/test/py/tests/test_env.py index d35ad888a7..a71b4c2571 100644 --- a/test/py/tests/test_env.py +++ b/test/py/tests/test_env.py @@ -423,7 +423,7 @@ def test_env_ext4(state_test_env): response = c.run_command('ext4ls host 0:0') assert 'uboot.env' not in response
- """ env_location: ENVL_EXT4 (2) + """ env location: ENVL_EXT4 (2) """ response = c.run_command('env_loc 2') assert 'Saving Environment to EXT4' in response @@ -453,7 +453,23 @@ def test_env_ext4(state_test_env): response = c.run_command('echo $?') assert response == "0"
- """ restore env_location: ENVL_NOWHERE (12) + response = c.run_command('env erase') + assert 'OK' in response + + response = c.run_command('env_loc 2') + assert 'Loading Environment from EXT4... ' in response + assert 'bad CRC, using default environment' in response + + response = c.run_command('env info') + assert 'env_valid = invalid' in response + assert 'env_ready = true' in response + assert 'env_use_default = true' in response + + response = c.run_command('env info -p -d') + assert 'Default environment is used' in response + assert 'Environment can be persisted' in response + + """ restore env location: ENVL_NOWHERE (12) """ c.run_command('env_loc 12')
Patrick Delaunay
