[U-Boot] twister fails to start u-boot from NAND
I am facing some issues when booting u-boot (755b06d1c0f) from _NAND_ on a twister board. It works fine when booting from mmc. u-boot v2016.09 works fine from NAND as well.
The first issue is that it hangs after DRAM initialization / before NAND is found. Git bisect points to 085be482f6 (ARM: revive CONFIG_USE_ARCH_MEMCPY/MEMSET for UniPhier and Tegra) and while reverting that patch makes the issue go away, it doesn't seem to me like the root cause.
With the patch reverted, the board hangs after getting the first ethernet address from the i2c EEPROM.
Disabling reading from the EEPROM, it reaches the prompt but every issued command cause a data abort.
So clearly something is wrong, but I have no clue what at the moment. I guess the most likely area which could cause such an issue would be the spl NAND driver corrupting memory or something, since it is the main difference between booting from mmc vs NAND. However almost nothing has changed in that area since v2016.09...
Perhaps stack usage is significantly higher in the NAND boot..?
If someone has idea what could be wrong here, let me know.
With kind regards,
Jeroen
to reproduce: --------------------------------------------------------------------------- arm-linux-gnueabi-gcc (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609
# from sd-card env default -f -a fatload mmc 0 ${loadaddr} u-boot.img && run update fatload mmc 0 ${loadaddr} mlo && run updatemlo
# remove sd-card / reboot
Hi Jeroen,
Right, or this is not the direct cause.
It looks like that reading from NAND is not correct. Rather on the twister there is no JTAG available.
It seems strange - I will guess that for some reason data in RAM are not equal to the data in NAND, and u-boot is corrupted. But I have not other clue.
Best regards, Stefano
Jeroen Hofstee
Stefano Babic
