[U-Boot] [PATCH] Fix a few printf argument verification warnings
The parameters of size_t type shall be formatted using "%zu" and not using "%d".
Precision argument for the "%.*s" parameters shall be of int type.
Signed-off-by: Vasili Galka vvv444@gmail.com --- common/bouncebuf.c | 2 +- common/cmd_mtdparts.c | 4 ++-- common/spl/spl.c | 2 +- 3 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/common/bouncebuf.c b/common/bouncebuf.c index 9eece6d..054d9e0 100644 --- a/common/bouncebuf.c +++ b/common/bouncebuf.c @@ -23,7 +23,7 @@ static int addr_aligned(struct bounce_buffer *state)
/* Check if length is aligned */ if (state->len != state->len_aligned) { - debug("Unaligned buffer length %d\n", state->len); + debug("Unaligned buffer length %zu\n", state->len); return 0; }
diff --git a/common/cmd_mtdparts.c b/common/cmd_mtdparts.c index 40b6333..d793f74 100644 --- a/common/cmd_mtdparts.c +++ b/common/cmd_mtdparts.c @@ -861,7 +861,7 @@ static int device_parse(const char *const mtd_dev, const char **ret, struct mtd_ debug("dev type = %d (%s), dev num = %d, mtd-id = %s\n", id->type, MTD_DEV_TYPE(id->type), id->num, id->mtd_id); - debug("parsing partitions %.*s\n", (pend ? pend - p : strlen(p)), p); + debug("parsing partitions %.*s\n", (int)(pend ? pend - p : strlen(p)), p);
/* parse partitions */ @@ -1006,7 +1006,7 @@ static struct mtdids* id_find_by_mtd_id(const char *mtd_id, unsigned int mtd_id_ list_for_each(entry, &mtdids) { id = list_entry(entry, struct mtdids, link);
- debug("entry: '%s' (len = %d)\n", + debug("entry: '%s' (len = %zu)\n", id->mtd_id, strlen(id->mtd_id));
if (mtd_id_len != strlen(id->mtd_id)) diff --git a/common/spl/spl.c b/common/spl/spl.c index 774fdad..b16664f 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -86,7 +86,7 @@ void spl_parse_image_header(const struct image_header *header) spl_image.os = image_get_os(header); spl_image.name = image_get_name(header); debug("spl: payload image: %.*s load addr: 0x%x size: %d\n", - sizeof(spl_image.name), spl_image.name, + (int)sizeof(spl_image.name), spl_image.name, spl_image.load_addr, spl_image.size); } else { /* Signature not found - assume u-boot.bin */
Vasili Galka
